Take a quick tour
GETTING STARTED GUIDE:
  1. Sign up, download, and install
  2. Setting up your J750 for GrabCAD Print
  3. Connect your FDM printers
  4. Take a quick tour
  5. Start printing!
  6. Printing & monitoring remotely with GrabCAD Print Server
This article shows the names of all the elements of GrabCAD Print, and has links to the related articles.
  1. Main Navigation
  2. Project Panel
  3. Printer Panel
  4. View Modes
  5. Tools
  6. Login/Switch Account
Print (shown above)
Schedule ( go to article)
Reports ( go to article)
Project Panel
Here you can add and manage the files in your project. The same right-click menu that is available in the graphics area also works here. You can also create, remove, and estimate the trays in your project.
Learn more about managing and arranging files in your project.
Printer Panel
Here is where you select the printer to be applied to all of the project's trays. If you haven't connected any printers yet, click here to learn  how to connect your printers.
When you first open the Printer Panel, you see the My Printers list, where you can quickly change between printers. To add a printer to this list hit "Add a printer"
To get some details about a printer such as its material levels or status, click the printer name to go to the details panel.
Learn more about  printing to an offline printer or managing multiple printers
View Modes
  1. Model View - prepare and arrange files on trays. Learn more
  2. Analysis Mode - view any mesh problems with your files and repair them with one click.* Learn more.
  3. Slice Preview - see how your tray will look after printing. (Available only for FDM printers)
Tools
  1. Model info — change units of an STL or VRML file.
  2. Print Settings — change model-related settings like infill and support style, as well as tray-wide settings like material choice and slice height. Learn more.
  3. Arrange — automatically move parts around on the tray or trays such that there is enough space for printing. Learn more.
  4. Orient — Incrementally change the orientation about an axis. Also an "Orient face to plane" feature which allows you to pick a model surface and orient it to top, front, right, etc. Learn more.
  5. Scale — If you select a model and open the scale tool, you can see its overall dimensions, and make adjustments to scale by inputting your desired dimension. Adjust the units in System Preferences > Units Controls > Display Units.
Login/switch account
See also:  All about company accounts
The 3D Viewer
See also:  Keyboard shortcuts and mouse controls
Next step: Start printing!
*Mesh analysis and healing functionality is provided by Polygonica by MachineWorks, Ltd. all copyrights and trademarks reserved
