List of supported printers
GrabCAD Print can connect to a variety of printers. If you are having problems connecting to your 3D printer, make sure it is on the list of printers below.
Manufacturer
Model
Printing technology
Stratasys F123 Series
Fortus — all types
uPrint — all types
Dimension — all types *
FDM
J750
Objet 1000
PolyJet
* Dimension 1200 (non-ES) printers are included in GrabCAD Print, however any printer-specific issues will not be investigated.
For printing on the F370 and larger Fortus systems, you may still want to use Insight to access some of the more advanced print prep features, such as manually removing support areas or adding stabilizer walls. For more details, see:  Advanced print prep with Insight and Control Center.
If your Stratasys/Objet printer isn't listed, please contact us at  print@grabcad.com for more info on support timelines.
