Mouse and keyboard controls
Mouse controls in the viewer
NOTE: These controls are configurable in File > System Preferences > View Manipulation. The default controls are:
Rotate right-mouse-button
Zoom  scroll
Pan
middle-mouse-button OR
shift + right-mouse-button
Select model left-mouse-button
Select multiple models in the Model List
ctrl + left-mouse-button OR
shift + left-mouse-button
Select multiple models in the viewer
left-mouse-button and drag*
Move model left-mouse button and drag
* You can select multiple models by drawing a box in the viewer. Click and drag with the left-mouse-button. When dragging towards the right, only models wholly contained in the box are selected. When dragging towards the left, models that are partially inside the box boundaries are also selected.
Mouse controls in Schedule View
Scroll up and down (printer list) scroll
Scroll left and right (time)
shift + scroll OR
middle-mouse-button
Zoom in or out in time ctrl + scroll
Keyboard shortcuts for the viewer
In addition to the following keyboard shortcuts, the standard views are available by the buttons at the top of the viewer, as well as the View menu.
Turn perspective on or off ctrl + L Top ctrl + 1
Fit to models ctrl + F Bottom ctrl + 2
Fit to selection ctrl + E Left ctrl + 3
Fit to tray ctrl + T Right ctrl + 4
Isometric ctrl + shift + 1 Front ctrl + 5
Dimetric ctrl + shift + 2 Back ctrl + 6
Trimetric ctrl + shift + 3
Keyboard shortcuts in Slice Preview
Play or pause slice animation space
Change selected layer up / down arrow
Other shortcuts
Add models ctrl + shift + O Undo ctrl + Z
Insert STLs as assembly ctrl + shift + A  Redo ctrl + shift + Z
Import OBJZF, OBJTF, or CMB ctrl + shift + I Select all ctrl + A
New project ctrl + N Copy ctrl + C
Open project ctrl + O Paste ctrl + V
Save project ctrl + S Delete selected delete
Save project as ctrl + shift + S
Quit alt + F4
