GrabCAD Print mobile apps
GrabCAD Print mobile apps (for  iOS and Android) lets you monitor your printers from anywhere.
With GrabCAD Print you can easily:
  • Check the status of your 3D printers.
  • View printer queues.
  • Monitor material levels of your 3D printer.
Note: To use the mobile apps, setup the Print Server to connect your printers to the cloud.   Learn how to set up the Print Server
Known limitations for now:
  • Material volumes are only shown in cm3.
  • There are no push notifications.
  • "End time" for jobs is not shown.
  • Material estimations are not available for jobs in the queue.
