How to combine versioned files into one file
If you have two files with two different names, you can combine them into one file on Workbench. This is useful if you use a renaming convention locally to keep track of versions, but you would like Workbench to show only the latest version of the file and contain the older versions in the version history.
- 1
- Say for instance that in your Workbench project, you have several part files with suffixes that denote version. Start with the oldest version and rename it. Use the name you would like for the combined file.
- 2
- Then go to the next newest version and rename it to the same name. You will be asked to decide how to combine these files. In this case you want to chose "Update"
- 4
- Continue this process with each successive newer version. Version numbers will increase from 1 and are not read from the file name
