List of supported printers
GrabCAD Print can connect to a variety of printers. If you are having problems connecting to your 3D printer, make sure it is on the list of printers below.
Manufacturer |
Model |
Printing technology |
Stratasys | F123 Series F900 Fortus — all types uPrint SE and SE Plus * Dimension Elite * Dimension BST/SST1200es * |
FDM |
J8-Series J7-Series J5-Series J4100 Connex3 — all types Objet30 — all except Dental Objet1000 Plus |
PolyJet |
* Dimension BST/SST 768, Dimension BST/SST 1200 (non-ES), and uPrint/uPrint Plus (non-SE) printers are included in GrabCAD Print, however any printer-specific issues will not be investigated.
For printing on the F370 and larger Fortus systems, you may still want to use Insight to access some of the more advanced print prep features, such as manually removing support areas or adding stabilizer walls. For more details, see: Advanced print prep with Insight and Control Center.
