GrabCAD Print mobile apps
Once you have set up GrabCAD Print Server, you can use the GrabCAD Print mobile apps (for iOS and Android) or the Alexa app.
GrabCAD Print mobile apps for Android and iOS
To use the GrabCAD Print mobile apps:
- Set up GrabCAD Print Server
- Download and install the mobile apps using the links below
- Log in and select the company account associated with GrabCAD Print Server
In the app, you will be able to:
- Get notifications about your print jobs
- Get details on your printer status, including the printer camera view and tray preview
- View all your printer queues
- Monitor material usage of the current job and the printer's capacity
- Remotely pause a print job (available for the F123 Series and J750 printers only)
GrabCAD Print on the Alexa
To use Alexa to monitor your printers:
- In the Alexa mobile app, search for GrabCAD Voice for Stratasys 3D Printers and hit Enable to Use.
- You'll be redirected to the GrabCAD Print sign-in page. Sign in and select the company account associated with GrabCAD Print Server.
- Speaking to your smart speaker, say "Alexa enable GrabCAD"
The following voice commands will now work with Alexa:
- What is / Give me the status of Printer <printer_name>
- What is / Give me the material status of Printer <printer_name>
- List my printers.
- What is / Give me the job status on Printer <printer_name>
- Pause Printer <printer_name> (Only F123 and J750)
- Cancel current job on printer <printer_name> (Only F123 and J750)
- How many jobs are queued on printer <printer_name>
- Which printers are in the status <printer_status>
Note: Since many of these commands use the printer's name, you may want to rename your printers to be easier to say.
