Printers
- PolyJet Legacy Printers
- Alaris30 V1
- Connex260
- Connex350/500
- Eden250
- Eden260
- Eden260V/VS
- Eden330
- Eden350
- Eden350V/500V
- J700 & J720 Dental
- J750/J735
- J750 Digital Anatomy
- Objet24/30 V2 Family
- Objet24/30 V3 Family
- Objet30 V5 Pro & Prime
- Objet260 Connex 1-2-3
- Objet260 Dental & Dental Selection
- Objet350/500 Connex 1-2-3
- Objet1000 Plus
Materials
- PolyJet Materials
- Agilus30 family
- Biocompatible
- Biocompatible Clear MED610
- Dental Materials
- Dental TrueDent Materials
- Dental TrueDent-D Materials
- Digital ABS Plus
- DraftGrey
- Elastico Clear/Black
- High Temperature
- PolyJet Support
- Rigur & Durus
- Tango
- Transparent
- Vero ContactClear
- Vero Family
- Veroflex
- VeroUltra Opaque
- Vivid Colors
- Stereolithography Materials
- Somos® 9120™
- Somos® BioClear™
- Somos® DMX SL™ 100
- Somos® Element™
- Somos® EvoLVe™ 128
- Somos® GP Plus™ 14122
- Somos® Momentum™
- Somos® NeXt™
- Somos® PerFORM™
- Somos® PerFORM Reflect™
- Somos® ProtoGen™ 18420
- Somos® ProtoTherm™ 12120
- Somos® Taurus™
- Somos® WaterClear® Ultra 10122
- Somos® WaterShed® AF
- Somos® WaterShed® Black
- Somos® WaterShed® XC 11122
System Requirements for GrabCAD Streamline Pro
For the system requirements for GrabCAD Print and GrabCAD Print Server, please see: System requirements for GrabCAD Print
Requirements for GrabCAD Analyze
These requirements are for installing both components of Analyze (Server and Agent) together on the same computer.
Operating System | Windows 10 or newer |
User Privileges | Windows administrative rights for installation |
RAM | 16GB minimum, 32GB or more recommended |
CPU | Intel x64 with 4 or more cores, minimum 2.6 GHz |
Disk Space | 500GB SSD recommended (for up to 10 printers*) |
Network | Ethernet or wireless connectivity to Local Area Network, broadband internet connection (for licensing purposes only) |
Security Considerations | Ability to allow prerequisite applications (Vagrant by Hashicorp, Oracle VM Virtual Box) through Windows Firewall, Defender and other network security software |
BIOS Requirements | Virtualization turned on |
Alternate Method for Installing GrabCAD Analyze
The two components of GrabCAD Analyze do not necessarily need to be installed on the same computer. Analyze Server is natively a Linux application, and may be installed on a Linux machine. Additionally, Agent has much lower requirements.
Analyze Server | Analyze Agent | |
Operating Systems | Windows 10 or newer, Linux system (Ubuntu Server 22.04 LTS) | Windows 10 and newer, Windows Server 2016 and newer. Only 64-bit versions of Windows are supported |
User Privileges | Windows administrative rights for installation | Windows administrative rights for installation |
RAM | 16GB minimum, 32GB or more recommended | 8GB minimum, 16GB or more recommended |
CPU | Intel x64 with 4 cores or greater, minimum 2.6 GHz | Intel x64 with 4 cores or greater, minimum 2.6 GHz |
Disk Space | 500GB SSD recommended (for up to 10 printers*) | 5GB minimum, 20GB or more recommended |
Network | Ethernet or wireless connectivity to Local Area Network, broadband internet connection | Ethernet or wireless connectivity to Local Area Network Port 5010 needs to be accessible from the Analyze Server |
.NET Framework | 4.8 or above | 4.8 or above |
Security Considerations | Ability to download, install, and run prerequisite applications (Vagrant by Hashicorp, Oracle VirtualBox). | |
*If you have more than 10 printers, it is recommended to use multiple Analyze Servers, each installed on separate computers.
Requirements for Web Applications (GrabCAD Shop, GrabCAD Control, GrabCAD Analyze):
Web browser version | Google Chrome: 79.0.3945 or later Mozilla Firefox: 71.1 or later Microsoft Edge: 79.0.309 or later Apple Safari: 13 or later Microsoft Internet Explorer: Not supported |
Screen resolution | 1280x1024 minimum, 1920x1080 or more recommended. |
Access to GrabCAD domains through your firewall, antivirus, and/or proxy server | GrabCAD Shop company.grabcad.com shop.grabcad.com shop-api.grabcad.com s3.amazonaws.com GrabCAD Control company.grabcad.com login.grabcad.com GrabCAD Analyze company.grabcad.com |
Web browser clients need following ports to be open | GrabCAD Analyze For Analyze Server: 3000, 9000, 9010, 9100, 5601 For Analyze Agent: 5010 |
