System Requirements for GrabCAD Streamline Pro
For the system requirements for GrabCAD Print and GrabCAD Print Server, please see: System requirements for GrabCAD Print
Requirements for GrabCAD Analyze
These requirements are for installing both components of Analyze (Server and Agent) together on the same computer.
Operating System |
Windows 10 or newer |
User Privileges |
Windows administrative rights for installation |
RAM |
16GB minimum, 32GB or more recommended |
CPU |
Intel x64 with 4 or more cores, minimum 2.6 GHz |
Disk Space |
500GB SSD recommended (for up to 10 printers*) |
Network |
Ethernet or wireless connectivity to Local Area Network, broadband internet connection (for licensing purposes only) |
Security Considerations |
Ability to allow prerequisite applications (Vagrant by Hashicorp, Oracle VM Virtual Box) through Windows Firewall, Defender and other network security software |
BIOS Requirements | Virtualization turned on |
Alternate method for installing GrabCAD Analyze
The two components of GrabCAD Analyze do not necessarily need to be installed on the same computer. Analyze Server is natively a Linux application, and may be installed on a Linux machine. Additionally, Agent has much lower requirements.
Analyze Server | Analyze Agent | |
Operating Systems |
Windows 10 or newer, Linux system (Ubuntu Server 22.04 LTS) |
Windows 10 and newer, Windows Server 2016 and newer. Only 64-bit versions of Windows are supported |
User Privileges |
RAM |
8GB minimum, 16GB or more recommended |
CPU |
Intel x64 with 4 cores or greater, minimum 2.6 GHz |
Disk Space |
5GB minimum, 20GB or more recommended |
Network |
Ethernet or wireless connectivity to Local Area Network, broadband internet connection |
Ethernet or wireless connectivity to Local Area Network |
.NET Framework |
4.8 or above |
4.8 or above |
Ability to download, install, and run prerequisite applications (Vagrant by Hashicorp, Oracle VirtualBox). |
*If you have more than 10 printers, it is recommended to use multiple Analyze Servers, each installed on separate computers.
Requirements for web applications (GrabCAD Shop, GrabCAD Control, GrabCAD Analyze):
Web browser version | Google Chrome: 79.0.3945 or later Mozilla Firefox: 71.1 or later Microsoft Edge: 79.0.309 or later Apple Safari: 13 or later Microsoft Internet Explorer: Not supported |
Screen resolution | 1280x1024 minimum, 1920x1080 or more recommended. |
Access to GrabCAD domains through your firewall, antivirus, and/or proxy server | GrabCAD Shop company.grabcad.com shop.grabcad.com shop-api.grabcad.com s3.amazonaws.com GrabCAD Control company.grabcad.com login.grabcad.com GrabCAD Analyze company.grabcad.com |
Web browser clients need following ports to be open | GrabCAD Analyze on Analyze Server: 3000, 9000, 9010, 9100, 5601 |
