GrabCAD Streamline Pro Updates
septiembre 17, 2024
Simplified printer addition in GrabCAD Analyze
GrabCAD Analyze users can now easily add all their Stratasys printers to Analyze with a few clicks using the new "Discover" button in the printers page. Printers that aren't discoverable can still be added by IP using the "Manually Add" button, which has been improved and simplified.
Go to the Analyze Agent Settings page and ensure that the Agent is connected. Then, go to the Printers page and click Discover, to see all the printers in your network. Select and add the printers that you want to show in Analyze. (A GrabCAD Print desktop or GrabCAD PrintSserver installation is required on the computer that has the Analyze Server installed). Once the printers are added, they can be renamed, edited as needed.
septiembre 17, 2024
Performance, stability and installer improvements to GrabCAD Analyze
Users with many printers (up to 50) can now use GrabCAD Analyze to collect data and generate dashboards and reports. The data collection, storage and aggregation has been simplified and improved in the Analyze Agent and Server to scale and work with more printers. However, the computational requirements of the server needs to increased to account for the increased influx of data from the machines. (Current requirements are for 10 printers).
With the latest installer, a number of improvements have been made to improve the installation success in different user environments. The Analyze Server will also be configured to automatically restart in the event of a Windows update or restart, to prevent any unexpected downtime.
agosto 27, 2024
Print orientation selection of order items to obtain more revelant estimates
GrabCAD Shop requesters and operators can now select the desired orientation for an FDM or PolyJet order item to ensure it is printed accordingly. This feature allows for greater specification and control over order items, as well as the estimation and print results, reducing the back-and-forth communication between requesters and operators.
Once an order is submitted and GrabCAD Shop completes an automatic estimation of the items, users can view the orientation used by GrabCAD Shop to generate the estimation (usually the CAD orientation or the recommended orientation from GrabCAD Print, depending on the Shop's preferences). If users wish to specify a different orientation to capture design intent or enhance printability, they can select one of the seven available options. This orientation is then saved and preserved in the order, and if the item is added to a job, the selected orientation will be used. The order item's thumbnail will also be updated to reflect the currently selected orientation.
junio 28, 2024
Improvements to .cmb and .print files in GrabCAD Shop
GrabCAD Shop requesters and operators can now work directly with .cmb and .print files. This feature is available for advanced users who use GrabCAD Shop to submit their print requests but want to specify all the build parameters using project files in GrabCAD Print. When these files are uploaded to GrabCAD Shop, the desired machine, material estimates, time estimates, tray preview, and other high-level build estimates are extracted and displayed, allowing operators to understand exactly what is being requested.
Create a new order and upload project files from GrabCAD Print. After submitting the order, you can see a preview and all other details related to the order. Note that these files cannot be added to Jobs, as they are not intended to be combined with other parts, which could affect the requester's design intent.
junio 28, 2024
Automatically estimate, preview and generate printable trays from your Shop
In addition to automatic estimations for FDM and PolyJet requests in GrabCAD Shop, operators can use the Jobs feature to group similar parts and requests and have an tray generated automatically with estimates and a preview. This allows operators to reduce their backlog by quickly consolidating requests, grouping parts that can be printed together, and downloading valid printable trays for queuing purposes.
Go to Jobs and click "New Job" to see all the order items in your Shop that need to be printed. Filter these items by technology, machine, and material, and select the parts that you want to print together. Once the job is created, GrabCAD Shop will pack these parts and try to generate a tray that can be printed and downloaded (a .print file is generated, which can be opened in GrabCAD Print), along with a tray preview and estimation details. If any parts don't fit, they will be highlighted and can be removed from the job, and can be added in other jobs.
junio 3, 2024
Introducing GrabCAD Streamline Pro - new software suite to grow and scale your operations
GrabCAD Streamline Pro is a new paid software suite from Stratasys designed for users with FDM and PolyJet printers. It includes GrabCAD Shop and simplifies order management by allowing administrators and printer operators to create virtual model shops for managing 3D printing requests. Streamline Pro introduces new automation capabilities that save operators time by managing their backlog more efficiently. Each FDM and PolyJet request will be automatically estimated—powered by GrabCAD Print—with default machine parameters and optimal orientation, providing realistic material, time, and cost estimates. This eliminates the need to generate these estimates manually. Operators can then review, compare, append, and override the estimates as needed.
Streamline Pro also features a new cybersecurity device, Shield, which protects the printer from network vulnerabilities, provides IPv6 support, and acts as a firewall for the printer. Additionally, it includes role-based access control to restrict visibility to Stratasys printers and prevent unauthorized access.
Furthermore, Streamline Pro includes GrabCAD Analyze (Version 1.90), an advanced analytics, dashboard, and notification tool that operates on-premise. It offers out-of-the-box dashboards detailing and tracking printer and material utilization for FDM and PolyJet systems. Operators can also set up custom alerts for various printing events (e.g., print job at 95%, material level at 5%) to prevent unexpected issues or delays.
All these capabilities are accessible only with a valid GrabCAD Streamline Pro license. Learn more about Streamline Pro here.
mayo 23, 2024
New Stratays printers and materials available
New Stratasys machines and materials are now available to be added to your Shop. These include :
  • PolyJet printers like the J55 Pro, J3 and J5 DentaJet, and new models of J850 printers (Prime FabriX, Prime TechStyle, Pro and Digital Anatomy),
  • FDM printers like the F190CR, F370CR, and F3300.
  • P3 technology Origin One Dental with Dental materials,
  • New PA12 and PP materials for the SAF technology H350,
  • New FDM HIPS, Kimya, VICTREX, Polycarbonate and Ultem materials and colors for the Fortus 450mc and Stratasys F900 printers,
Si desea agregar una máquina a su tienda y esta todavía no está disponible, ¡infórmenos!
abril 1, 2024
New password rules for increased security
Users who are creating GrabCAD accounts to use GrabCAD software (GrabCAD Print, Shop, Control) are now required to set their passwords conforming to our new rules : 8 character minimum, with numbers, lower case and upper case characters required. This enhancement will increase the security of user accounts and provide IT and security managers at Stratasys printer sites with greater confidence in the security and management of GrabCAD software.
Go to login.grabcad.com or select the user icon in GrabCAD Print to create an account or reset your password.
enero 11, 2024
Control access to Printers
Administrators at Stratasys printer sites can now control access to their printers in GrabCAD Control, to prevent unauthorized, untrained or accidental visibility and usage of Stratasys printers at their site. This allows them to prevent printer downtime and wasted material in cases where users intentionally or accidentally modify the printer queues, cancel a long running print job and more. This also allows administratros to hide printers that are running sensitive and secretive print jobs, and only grant access to trained operators.
Go to GrabCAD Control, add your printers and group them. Then you can assign selected users in your company to the printer groups to grant them access and revoke access for everyone else. If you do not have access to GrabCAD Control, you can request a company account by emailed shop@grabcad.com.
agosto 20, 2023
Units and bounding box dimensions for order items
GrabCAD Shop requesters can now specify units for order items with unitless file formats (STL, OBJ, VRML and similar formats) and view the bounding box dimensions (length, width and depth) in the Shop's preferred display units. This will reduce the feedback loop with operators as they can easily understand the size of the requests, and ensure that these items are fabricated with the correct desired size. CAD files not in the unitless file format will have the CAD units and bounding box dimensions displayed in a read-only format.
Go to a Shop and click "New order" to upload your files. After a CAD file is uploaded, the units and bounding box dimensions will be visible next to the order item. Once the order is submitted, the operators can see the selected units and dimensions in each order item's details. If the units are changed after the order is submitted, it is noted in the history section of the order.
junio 20, 2023
Introducing GrabCAD Control
Administrators, managers and IT who manage Stratasys printers can now use GrabCAD Control, the Stratasys printer and user management solution. Previously called Admin Console (used to manage GrabCAD Shop invitations and roles), GrabCAD Control can only be used by selected users (Admins) in a company. They can login to their "company account" in GrabCAD Control, and they can
  • Invite users to their company,
  • Add other admins,
  • Connect their GrabCAD Print Server and manage their Stratasys printers,
  • View and assign GrabCAD software licenses to your users,
  • Create user and printer groups,
  • Control user access,
  • Assign user roles,
  • Manage Shops and more.
Learn more about GrabCAD Control here. Contact print@grabcad.com to request a "company account". Our customer support team will create a company account for you and make you an admin, after which you can login and perform the actions above.
marzo 7, 2023
Nueva columna configurable en la página de pedidos
Los administradores de la tienda GrabCAD ahora pueden activar una columna opcional en su página de pedidos llamada “Total de piezas”. Esto permitirá a los operadores evaluar eficazmente el tamaño de los pedidos sin tener que abrir cada uno.
La columna “Total de piezas” muestra el número total de piezas imprimibles en un pedido junto con sus respectivas cantidades, a diferencia de la columna “Archivos CAD”, que muestra la cantidad de piezas imprimibles únicas en el pedido. Vaya a una Tienda y haga clic en “Preferencias” para mostrar u ocultar esta nueva columna.
diciembre 13, 2021
Resumen de actualización de invierno 2021
Desde nuestro último resumen de actualización, hemos agregado aún más funciones. Hacer clic aquí para un resumen en video.
diciembre 13, 2021
Más impresoras y tecnologías disponibles
Todas las máquinas nuevas de Stratasys y muchas máquinas de 3eros ya están disponibles para agregarlas a su tienda.
Las adiciones de Stratasys incluyen
  • Impresoras PolyJet, como J5 MediJet, J35 pro, J55 Prime,
  • FDM F770,
  • Origin one con tecnología P3,
  • Tecnología SAF H350,
  • Impresoras RPS Neo a base de resina.
  • El nuevo material Stratasys ABS CF10 en las impresoras F123.
Nuevas opciones de máquinas y materiales correspondientes a las siguientes tecnologías:
  • Extrusión de materiales: 3DGence, Zortrax, Raise3D, MakerGear y Fusion3
  • Lecho de polvo (SLS): Sinterit
  • Chorro de aglutinante: ExOne
  • A base de resina (SLA, DLP): Nuevos materiales de Formlabs.
noviembre 18, 2021
Trabajos: administre varios pedidos a la vez
Los operadores de GrabCAD Shop ahora pueden procesar y hacer seguimiento rápidamente de varios pedidos o piezas a la vez mediante un "Trabajo". De esta forma ahorran tiempo y pasos en comparación con el uso de pedidos individuales.
Un trabajo es una colección de piezas similares que siguen la misma ruta desde el envío hasta la finalización, es decir, que comparten la misma tecnología, material, bandeja/plataforma solicitada en una máquina disponible o pasos de posprocesamiento. Para comenzar, haga clic en "Trabajos" en el panel de navegación izquierdo y haga clic en "Nuevo trabajo". Aquí puede ver todas las piezas Activas (en estado no "Completado" o "Cancelado") de su tienda. Luego puede filtrar y seleccionar piezas de la lista y crear un trabajo para una máquina en su tienda. Después de crear un trabajo, puede
  • Actualizar fácilmente todos los estados de las piezas individuales a "En curso".
  • Mover/arrastrar las piezas a medida que pasan por los diferentes pasos del proceso (trabajo creado, en cola, imprimiendo, posprocesando, completado).
  • Abrir todas las piezas juntas en GrabCAD Print (si es un trabajo para una máquina Stratasys).
  • Asignar un nombre al trabajo (por ejemplo: Bandeja F370, viernes).
Un trabajo se puede marcar como “Completado” cuando todas las piezas que incluye se han completado, fabricado o están listas para retiro. Esto también actualizará todos los estados de las piezas a “Completado”, lo que le permitirá pasar a otros trabajos. Para obtener más información sobre la función Trabajos, haga clic aquí.
julio 7, 2021
Dependencias y adjuntos a artículos de pedido individuales
Los solicitantes de GrabCAD Shop ahora pueden enviar fácilmente pedidos de ensamblajes (archivo de ensamblaje + componentes de ensamblaje) o archivos texturizados (archivos STL, OBJ, VRML + archivos de textura de imagen/relieve). En lugar de cargar todos los archivos y dependencias del pedido como artículos individuales, un solicitante puede comenzar cargando solo el archivo/ensamblajes CAD principales (por ejemplo, SLDASM, OBJ, etc.) y enviar el pedido. Luego, puede abrir el pedido y hacer clic en el icono "adjuntar archivo" en cada artículo del pedido para agregar dependencias (por ejemplo, SLDPRT, STL, PNG). Luego, los operadores pueden abrir un artículo del pedido con todas sus dependencias desde GrabCAD Shop en GrabCAD Print.
De esta manera, los pedidos son más eficientes y tienen menos artículos de pedido (con dependencias). Las dependencias están asociadas con los artículos de pedido y no se tratan como artículos individuales. Los operadores también se benefician, ya que pueden fabricar artículos de pedido con toda la información y las asociaciones de dependencias pertinentes, sin constantes consultas con los solicitantes.
mayo 11, 2021
Opciones de material único PolyJet ahora disponibles
De manera similar a FDM, los administradores de Shop con máquinas PolyJet ahora pueden seleccionar y exponer opciones de un solo color Vero, Agilus y Tango a los solicitantes de Shop, además de las opciones multicolores que ya estaban disponibles. Estas opciones de un solo color/material se pueden configurar en la página Máquinas para todos los tipos de máquinas PolyJet en la base de datos de GrabCAD Shop y ofrecen más flexibilidad para los pedidos y casos de uso de PolyJet.
Los solicitantes pueden enviar pedidos y especificar colores PolyJet primarios únicos disponibles, si no desean mezclar materiales PolyJet (por ejemplo, imprimir un archivo CAD en Vero PureWhite).
abril 25, 2021
Mejoras en el rendimiento y la seguridad
Si hay muchos pedidos en Shop, ahora las páginas de pedidos con columnas personalizadas o con muchas piezas/artículos presentan una mejora considerable en los tiempos de carga. La velocidad de carga de la página de la lista de pedidos ha aumentado en 10x y la de las páginas de detalles de los pedidos ha aumentado en 2x. Las consultas a la página de inicio de Shop, la página de Máquinas y la sección de Historial ahora también son más eficientes. Todos estos cambios buscan ayudar a los usuarios de GrabCAD Shop a administrar y acceder en menos tiempo a sus tiendas, pedidos y contenido relacionado.
En un esfuerzo por mantener seguros sus pedidos de GrabCAD Shop y los metadatos relacionados, rastreamos, identificamos y corregimos regularmente las vulnerabilidades de seguridad. GrabCAD Shop se sometió recientemente a pruebas de penetración de seguridad de una agencia de renombre y se abordaron todas las vulnerabilidades de prioridad media y alta.
enero 31, 2021
Historial y notificaciones por correo electrónico sobre actualizaciones de pedidos
Los solicitantes y los operadores asignados ahora pueden ver un resumen de todos los cambios en un pedido en la sección “Historial”. Estos cambios pueden incluir
  • Cambios en los detalles, fechas, estimaciones y precio del pedido.
  • Cambios de estado
  • Adición o eliminación de elementos/archivos de pedidos
  • Asignación de un operador
El solicitante y el operador asignado de un pedido también recibirán notificación por correo electrónico cuando se realicen estos cambios. Otros usuarios de la tienda pueden elegir “ver” un pedido y recibir una notificación, marcando la casilla “Notificarme sobre actualizaciones” en ese pedido específico.
octubre 12, 2020
Otoño 2020 Resumen de actualizaciones
Desde el resumen de actualizaciones en mayo 2020, agregamos aún más características. Haga clic aquí para ver un resumen en video.
octubre 6, 2020
Asignar un operador a un pedido
Los operadores ahora pueden asignarse a sí mismos o a otros operadores de la tienda a un pedido. El operador asignado recibe una notificación y es responsable de satisfacer ese pedido y de la comunicación futura con el solicitante. La asignación también se registra en la sección “Historial” para fines de seguimiento.
Los operadores asignados también se pueden ver en la página “Pedidos” si hace visible la columna “Operador” en “Preferencias”, para obtener una visión general de todos los pedidos y sus operadores.
septiembre 29, 2020
Calculadora de costos
Los administradores ahora pueden agregar el uso de la máquina, la depreciación, los costos de mano de obra y material mientras configuran las máquinas y los materiales en GrabCAD Shop. Estas tarifas se pueden usar para cotizar un pedido y para analizar costos en efectivo de las operaciones de la tienda de modelos.
Luego, los operadores pueden dirigirse a un pedido e ingresar materiales y estimaciones de tiempo después de procesar una solicitud y ver un resultado de precio automático basado en las tarifas configuradas previamente. Al hacer clic en el icono de “Calculadora” se muestra un desglose detallado de tarifas y costos, así como la capacidad de agregar más, marcar, descontar y anular los costos.
agosto 30, 2020
Agregar usuarios de forma masiva mediante el dominio de correo electrónico
Ahora, puede otorgar simultáneamente acceso a GrabCAD Shop a todos sus usuarios con el dominio de correo electrónico de su organización (mi_correo_electrónico_ID @ dominio), en lugar de agregar un correo electrónico a la vez. En GrabCAD Control, diríjase a la pestaña “Invitar usuarios” en la página Usuarios y seleccione “Agregar por dominio”. Ingrese el dominio de correo electrónico de sus usuarios y no olvide asignar grupos de usuarios para otorgar acceso a estos usuarios cuando inicien sesión.
Por motivos de seguridad, alguien de Stratasys revisará su solicitud de dominio lo antes posible. Una vez aprobado, todos los miembros de su equipo pueden iniciar sesión en GrabCAD Shop con su correo electrónico y acceder a sus Tiendas.
julio 31, 2020
Personalizar los estados de sus pedidos
Ahora, un administrador por tienda puede configurar los estados de los pedidos y las piezas para comunicar de manera eficaz el estado de las solicitudes. Vaya a una tienda y haga clic en Preferencias para mostrar u ocultar los estados incorporados, cambiar los colores de visualización, reordenar estados y agregar hasta 8 nuevos estados personalizados. Los administradores también pueden configurar si el estado personalizado representa una orden activa o inactiva.
Configurar las columnas en la página de pedidos
Para garantizar que todos los usuarios de una tienda vean solo datos relevantes, los administradores ahora pueden mostrar u ocultar columnas en la página de pedidos en la sección Preferencias de una tienda. Además, pueden agregar las siguientes columnas nuevas para optimizar la facilidad de uso de la página de pedidos:
  • Código de proyecto de un pedido
  • Número de archivos CAD en un pedido
  • Tecnología(s) solicitada(s) en un pedido
  • Material(es) solicitado(s) en un pedido
junio 25, 2020
Nuevos filtros de la página de pedidos
Ahora, puede filtrar sus pedidos por fecha de envío, necesidad o entrega. Estos filtros se pueden aplicar además de los filtros de estado y tecnología en la página de pedidos antes de exportar la vista resultante.
junio 3, 2020
Buscar los pedidos de su tienda
Ahora, en la página de pedidos, puede buscar pedidos específicos utilizando el nombre del proyecto, el nombre del solicitante, la dirección de correo electrónico o el código del proyecto. Después de obtener los resultados de búsqueda, también puede exportar la vista resultante a un archivo CSV.
Barra de navegación comprimible
Para facilitar el uso de GrabCAD Shop en pantallas más pequeñas, ahora puede contraer la barra de navegación gris usando la pequeña flecha cerca de la parte superior de la pantalla (junto al nombre de la empresa). Cuando está contraída, para verla, mueva el cursor a la izquierda de la pantalla.
junio 2, 2020
Agregamos las siguientes impresoras Stratasys PolyJet como máquinas disponibles en la tienda:
  • Impresora de anatomía digital Stratasys J750
  • Stratasys j55
  • Stratasys j720 Dental
  • La gama completa de impresoras Objet y Connex 260/350/500
También agregamos algunas opciones de máquinas nuevas y los materiales correspondientes a las siguientes tecnologías:
  • Extrusión de material: Desktop Metal, Prusa, Dynamical 3D
  • Chorro de aglutinante: Desktop Metal
  • Fusión en lecho de polvo: HP
  • FDM: Makerbot
Además, hemos agregado más fabricantes y materiales a la tecnología CNC. Finalmente, también agregamos la tecnología de procesamiento láser y los materiales genéricos correspondientes.
mayo 22, 2020
Resumen de actualizaciones trimestrales
Hemos agregado algunas actualizaciones desde nuestro lanzamiento en enero de 2020. Haga clic aquí para ver un resumen en video.
mayo 20, 2020
Vista predeterminada mejorada de la página de pedidos
La página Pedidos ahora está filtrada para mostrar solo los pedidos “Activos” de forma predeterminada, con el fin de mejorar el rendimiento de carga de la página y ayudar a los operadores a centrarse solo en los pedidos que necesitan atención. Los pedidos con los estados “Se completó” y “Se canceló” se consideran pedidos inactivos y se pueden mostrar cambiando el filtro.
mayo 19, 2020
Informar sobre pedidos de la tienda
Ahora, puede descargar la vista actual de la página Pedidos como un archivo .CSV. Si necesita usar otro sistema de informes para hacer seguimiento de sus pedidos, aplique filtros para obtener la vista que desea y luego, presione el botón Exportar.
mayo 11, 2020
Mejoras en facilidad de uso y rendimiento
Se han realizado algunos pequeños cambios para ahorrar tiempo a los operadores. Las selecciones de clasificación y filtro en la página de pedidos ahora se mantienen durante toda la sesión, y ahora puede ver un recuento del total de pedidos en la tienda. También mejoramos el rendimiento de carga de la página Pedidos.
abril 22, 2020
Planificar trabajos fácilmente con la integración de GrabCAD Print
Desde su página Pedidos, seleccione uno o más pedidos y haga clic en el botón “P” situado en la parte superior para abrir inmediatamente los archivos de esos pedidos en GrabCAD Print. Ya no es necesario descargar archivos y agregarlos manualmente, pues puede obtener sus archivos en GrabCAD Print con un solo clic. Esto coincide con el lanzamiento de la versión 1.41 de GrabCAD Print.
marzo 23, 2020
Creación mejorada de tiendas y grupos de usuarios
Cuando un administrador crea una tienda, se crean automáticamente dos grupos de usuarios (Solicitantes y Operadores) y el administrador se agrega a ambos. Estos grupos se pueden ver en GrabCAD Control y permiten al administrador configurar fácilmente su tienda y otorgar acceso a sus usuarios.
¿No puede encontrar lo que necesita? envíenos un mensaje envíenos un mensaje
