GrabCAD Streamline Pro Updates
septembre 17, 2024
Simplified printer addition in GrabCAD Analyze
GrabCAD Analyze users can now easily add all their Stratasys printers to Analyze with a few clicks using the new "Discover" button in the printers page. Printers that aren't discoverable can still be added by IP using the "Manually Add" button, which has been improved and simplified.
Go to the Analyze Agent Settings page and ensure that the Agent is connected. Then, go to the Printers page and click Discover, to see all the printers in your network. Select and add the printers that you want to show in Analyze. (A GrabCAD Print desktop or GrabCAD PrintSserver installation is required on the computer that has the Analyze Server installed). Once the printers are added, they can be renamed, edited as needed.
septembre 17, 2024
Performance, stability and installer improvements to GrabCAD Analyze
Users with many printers (up to 50) can now use GrabCAD Analyze to collect data and generate dashboards and reports. The data collection, storage and aggregation has been simplified and improved in the Analyze Agent and Server to scale and work with more printers. However, the computational requirements of the server needs to increased to account for the increased influx of data from the machines. (Current requirements are for 10 printers).
With the latest installer, a number of improvements have been made to improve the installation success in different user environments. The Analyze Server will also be configured to automatically restart in the event of a Windows update or restart, to prevent any unexpected downtime.
août 27, 2024
Print orientation selection of order items to obtain more revelant estimates
GrabCAD Shop requesters and operators can now select the desired orientation for an FDM or PolyJet order item to ensure it is printed accordingly. This feature allows for greater specification and control over order items, as well as the estimation and print results, reducing the back-and-forth communication between requesters and operators.
Once an order is submitted and GrabCAD Shop completes an automatic estimation of the items, users can view the orientation used by GrabCAD Shop to generate the estimation (usually the CAD orientation or the recommended orientation from GrabCAD Print, depending on the Shop's preferences). If users wish to specify a different orientation to capture design intent or enhance printability, they can select one of the seven available options. This orientation is then saved and preserved in the order, and if the item is added to a job, the selected orientation will be used. The order item's thumbnail will also be updated to reflect the currently selected orientation.
juin 28, 2024
Improvements to .cmb and .print files in GrabCAD Shop
GrabCAD Shop requesters and operators can now work directly with .cmb and .print files. This feature is available for advanced users who use GrabCAD Shop to submit their print requests but want to specify all the build parameters using project files in GrabCAD Print. When these files are uploaded to GrabCAD Shop, the desired machine, material estimates, time estimates, tray preview, and other high-level build estimates are extracted and displayed, allowing operators to understand exactly what is being requested.
Create a new order and upload project files from GrabCAD Print. After submitting the order, you can see a preview and all other details related to the order. Note that these files cannot be added to Jobs, as they are not intended to be combined with other parts, which could affect the requester's design intent.
juin 28, 2024
Automatically estimate, preview and generate printable trays from your Shop
In addition to automatic estimations for FDM and PolyJet requests in GrabCAD Shop, operators can use the Jobs feature to group similar parts and requests and have an tray generated automatically with estimates and a preview. This allows operators to reduce their backlog by quickly consolidating requests, grouping parts that can be printed together, and downloading valid printable trays for queuing purposes.
Go to Jobs and click "New Job" to see all the order items in your Shop that need to be printed. Filter these items by technology, machine, and material, and select the parts that you want to print together. Once the job is created, GrabCAD Shop will pack these parts and try to generate a tray that can be printed and downloaded (a .print file is generated, which can be opened in GrabCAD Print), along with a tray preview and estimation details. If any parts don't fit, they will be highlighted and can be removed from the job, and can be added in other jobs.
juin 3, 2024
Introducing GrabCAD Streamline Pro - new software suite to grow and scale your operations
GrabCAD Streamline Pro is a new paid software suite from Stratasys designed for users with FDM and PolyJet printers. It includes GrabCAD Shop and simplifies order management by allowing administrators and printer operators to create virtual model shops for managing 3D printing requests. Streamline Pro introduces new automation capabilities that save operators time by managing their backlog more efficiently. Each FDM and PolyJet request will be automatically estimated—powered by GrabCAD Print—with default machine parameters and optimal orientation, providing realistic material, time, and cost estimates. This eliminates the need to generate these estimates manually. Operators can then review, compare, append, and override the estimates as needed.
Streamline Pro also features a new cybersecurity device, Shield, which protects the printer from network vulnerabilities, provides IPv6 support, and acts as a firewall for the printer. Additionally, it includes role-based access control to restrict visibility to Stratasys printers and prevent unauthorized access.
Furthermore, Streamline Pro includes GrabCAD Analyze (Version 1.90), an advanced analytics, dashboard, and notification tool that operates on-premise. It offers out-of-the-box dashboards detailing and tracking printer and material utilization for FDM and PolyJet systems. Operators can also set up custom alerts for various printing events (e.g., print job at 95%, material level at 5%) to prevent unexpected issues or delays.
All these capabilities are accessible only with a valid GrabCAD Streamline Pro license. Learn more about Streamline Pro here.
mai 23, 2024
New Stratays printers and materials available
New Stratasys machines and materials are now available to be added to your Shop. These include :
  • PolyJet printers like the J55 Pro, J3 and J5 DentaJet, and new models of J850 printers (Prime FabriX, Prime TechStyle, Pro and Digital Anatomy),
  • FDM printers like the F190CR, F370CR, and F3300.
  • P3 technology Origin One Dental with Dental materials,
  • New PA12 and PP materials for the SAF technology H350,
  • New FDM HIPS, Kimya, VICTREX, Polycarbonate and Ultem materials and colors for the Fortus 450mc and Stratasys F900 printers,
Si vous souhaitez ajouter une machine à votre atelier et qu'elle n'est toujours pas disponible, faites-le nous savoir !
avril 1, 2024
New password rules for increased security
Users who are creating GrabCAD accounts to use GrabCAD software (GrabCAD Print, Shop, Control) are now required to set their passwords conforming to our new rules : 8 character minimum, with numbers, lower case and upper case characters required. This enhancement will increase the security of user accounts and provide IT and security managers at Stratasys printer sites with greater confidence in the security and management of GrabCAD software.
Go to login.grabcad.com or select the user icon in GrabCAD Print to create an account or reset your password.
janvier 11, 2024
Control access to Printers
Administrators at Stratasys printer sites can now control access to their printers in GrabCAD Control, to prevent unauthorized, untrained or accidental visibility and usage of Stratasys printers at their site. This allows them to prevent printer downtime and wasted material in cases where users intentionally or accidentally modify the printer queues, cancel a long running print job and more. This also allows administratros to hide printers that are running sensitive and secretive print jobs, and only grant access to trained operators.
Go to GrabCAD Control, add your printers and group them. Then you can assign selected users in your company to the printer groups to grant them access and revoke access for everyone else. If you do not have access to GrabCAD Control, you can request a company account by emailed shop@grabcad.com.
août 20, 2023
Units and bounding box dimensions for order items
GrabCAD Shop requesters can now specify units for order items with unitless file formats (STL, OBJ, VRML and similar formats) and view the bounding box dimensions (length, width and depth) in the Shop's preferred display units. This will reduce the feedback loop with operators as they can easily understand the size of the requests, and ensure that these items are fabricated with the correct desired size. CAD files not in the unitless file format will have the CAD units and bounding box dimensions displayed in a read-only format.
Go to a Shop and click "New order" to upload your files. After a CAD file is uploaded, the units and bounding box dimensions will be visible next to the order item. Once the order is submitted, the operators can see the selected units and dimensions in each order item's details. If the units are changed after the order is submitted, it is noted in the history section of the order.
juin 20, 2023
Introducing GrabCAD Control
Administrators, managers and IT who manage Stratasys printers can now use GrabCAD Control, the Stratasys printer and user management solution. Previously called Admin Console (used to manage GrabCAD Shop invitations and roles), GrabCAD Control can only be used by selected users (Admins) in a company. They can login to their "company account" in GrabCAD Control, and they can
  • Invite users to their company,
  • Add other admins,
  • Connect their GrabCAD Print Server and manage their Stratasys printers,
  • View and assign GrabCAD software licenses to your users,
  • Create user and printer groups,
  • Control user access,
  • Assign user roles,
  • Manage Shops and more.
Learn more about GrabCAD Control here. Contact print@grabcad.com to request a "company account". Our customer support team will create a company account for you and make you an admin, after which you can login and perform the actions above.
mars 7, 2023
Nouvelle colonne configurable dans la page des commandes
Les administrateurs de GrabCAD Shop peuvent désormais activer une colonne facultative dans leur page de commandes appelée « Nombre total de pièces ». Cela permettra aux opérateurs d’évaluer efficacement la taille des commandes sans avoir à ouvrir chaque commande.
La colonne « Nombre total de pièces » affiche le nombre total de pièces imprimables dans une commande ainsi que leurs quantités respectives, contrairement à la colonne « Fichiers CAO », qui affiche le nombre de pièces imprimables uniques dans la commande. Allez dans un atelier et cliquez sur « Préférences » pour afficher ou masquer cette nouvelle colonne.
décembre 13, 2021
Résumé de la mise à jour 2021 d’hiver
Depuis notre dernier résumé de mise à jour, nous avons ajouté encore plus de fonctionnalités. Cliquez ici pour découvrir un résumé vidéo.
décembre 13, 2021
Plus d'imprimantes et de technologies disponibles
Toutes les nouvelles machines Stratasys et de nombreuses machines tierces sont désormais disponibles pour être ajoutées à votre atelier.
Les nouveautés de Stratasys incluent
  • Les imprimantes PolyJet comme la J5 MediJet, la J35 pro, la J55 Prime,
  • FDM F770,
  • Technologie P3 Origine One,
  • H350 avec technologie SAF,
  • Imprimantes RPS Neo Résine.
  • Le nouveau matériau ABS CF10 de Stratasys sur les imprimantes F123.
Nouvelles options de machine et matériaux correspondants aux technologies suivantes :
  • Extrusion de matériaux : 3DGence, Zortrax, Raise3D, MakerGear et Fusion3
  • Lit de poudre (SLS) : Sinterit
  • Projection de liant : ExOne
  • À base de résine (SLA, DLP) : Nouveaux matériaux Formlabs.
novembre 18, 2021
Tâches - Gérez plusieurs commandes à la fois
Les opérateurs de GrabCAD Shop peuvent désormais traiter et suivre rapidement plusieurs commandes ou pièces à la fois à l’aide d’une « tâche ». Cela permet d’économiser du temps et des clics par rapport à l’utilisation de commandes individuelles.
Une tâche est un ensemble de pièces similaires qui suivent le même itinéraire de la soumission à l’achèvement, c’est-à-dire qu’elles font appel à la même technologie, utilisent le même matériau et le même plateau/lit sur une machine disponible, ou suivent les mêmes étapes de post-traitement. Pour commencer, cliquez sur « Tâches » dans le menu de navigation de gauche, puis cliquez sur « Nouvelle tâche ». Dans cet emplacement, vous pouvez voir toutes les pièces actives (dont le statut n’est pas « Terminé » ou « Annulé ») dans votre atelier. Vous pouvez ensuite filtrer, sélectionner des pièces dans la liste et créer une tâche pour une machine dans votre atelier. Une fois qu’une tâche est créée, vous pouvez :
  • Mettre facilement à jour tous les statuts des pièces individuelles sur « En cours ».
  • Déplacer/faire glisser les pièces tandis qu’elles passent par différentes étapes de processus (tâche créée, mise en file d’attente, impression, post-traitement, terminée).
  • Ouvrir toutes les pièces ensemble dans GrabCAD Print (s’il s’agit d’une tâche pour une machine Stratasys).
  • Nommer la tâche (exemple : Plateau F370 Vendredi).
Une tâche peut être marquée « Terminée » lorsque toutes les pièces qu'elle contient ont été terminées / fabriquées / sont prêtes à être récupérées. Cela mettra également à jour tous les statuts des pièces sur « Terminé », vous permettant ainsi de passer à d'autres tâches. En savoir plus sur la fonctionnalité Tâches ici.
juillet 7, 2021
Dépendances et pièces jointes à des articles de commande individuels
Les donneurs d’ordres de GrabCAD Shop peuvent désormais facilement soumettre des commandes d’assemblages (fichier d’assemblage + composants d’assemblage) ou de fichiers texturés (fichiers STL, OBJ, VRML + fichiers image/texture en relief). Au lieu de télécharger tous les fichiers et dépendances de la commande en tant qu’éléments individuels, un donneur d’ordres peut commencer par télécharger uniquement le fichier CAO parent/les assemblages (par exemple SLDASM, OBJ, etc.) et soumettre la commande. Ensuite, il peut ouvrir la commande et cliquer sur l’icône « Joindre un fichier » de chaque élément de la commande pour ajouter des dépendances (par exemple SLDPRT, STL, PNG). Les opérateurs peuvent ensuite ouvrir un article d’une commande avec toutes ses dépendances de GrabCAD Shop dans GrabCAD Print.
Les commandes sont plus efficaces avec moins d’articles dans une commande (avec des dépendances). Les dépendances sont associées aux articles de la commande et ne sont pas traitées comme des articles individuels. Cela présente également des avantages pour les opérateurs, car ils peuvent fabriquer les articles d’une commande avec toutes les associations d’informations/dépendances pertinentes, sans devoir sans arrêt se renseigner auprès des donneurs d’ordres.
mai 11, 2021
Les options de matériau unique PolyJet sont désormais disponibles
Comme pour FDM, les administrateurs de l’atelier disposant de machines PolyJet peuvent désormais sélectionner et exposer les options de couleur unique Vero, Agilus et Tango aux donneurs d’ordres de l’atelier, en plus des options multicolores qui étaient déjà disponibles. Ces options de couleur/matériau uniques peuvent être configurées dans la page Machines pour tous les types de machines PolyJet dans la base de données GrabCAD Shop et offrent plus de flexibilité pour les commandes et les cas d’utilisation PolyJet.
Les donneurs d’ordres peuvent ensuite soumettre des commandes et spécifier les couleurs primaires PolyJet disponibles, s’ils ne souhaitent pas mélanger de matériaux PolyJet (comme pour l’impression d’un fichier CAO dans Vero PureWhite par exemple).
avril 25, 2021
Améliorations des performances et de la sécurité
Les ateliers comptant de nombreuses commandes, colonnes personnalisées ou de nombreuses pièces/articles par commande verront désormais des améliorations significatives des temps de chargement des pages. La vitesse de chargement de la page de liste des commandes a été multipliée par 10 et celle des pages dédiées aux informations de la commande a été multipliée par 2. Les requêtes vers la page d’accueil de l’atelier, la page Machines et la section Historique sont également plus efficaces. Tous ces changements ont été pensés pour aider les utilisateurs de GrabCAD Shop à gérer et à accéder plus rapidement à leurs ateliers, commandes et contenus pertinents.
Afin de garantir la sécurité de vos commandes GrabCAD Shop et des métadonnées correspondantes, nous suivons, identifions et corrigeons régulièrement les failles de sécurité. GrabCAD Shop a récemment fait l’objet d’un test de pénétration de sécurité effectué par une agence réputée, et toutes les vulnérabilités de priorité moyenne ou élevée ont été corrigées.
janvier 31, 2021
Historique et notifications par e-mail concernant les mises à jour des commandes
Les donneurs d’ordre et leurs opérateurs affectés peuvent désormais afficher une synthèse de toutes les modifications apportées à une commande dans la section « Historique ». Ces modifications peuvent inclure
  • Modifications des détails de la commande, des dates, des estimations et du prix
  • Changements de statut
  • Ajout ou suppression d’articles/fichiers de commande
  • Affectation de l’opérateur
Le donneur d’ordre d’une commande et son opérateur assigné seront également informés par e-mail lorsque ces modifications seront apportées. Les autres utilisateurs de l’atelier peuvent choisir de « surveiller » une commande et d’être avertis en cochant la case « M’informer des mises à jour » dans cette commande spécifique.
octobre 12, 2020
Résumé de la mise à jour 2020 d'automne
Depuis les mises à jour dans mai 2020, nous avons ajouté encore plus de fonctionnalités. Cliquez ici pour un résumé vidéo.
octobre 6, 2020
Affecter un opérateur à une commande
Les opérateurs peuvent désormais s'attribuer eux-mêmes ou affecter d'autres opérateurs de l’atelier à une commande. L'opérateur affecté est alors informé et est responsable de l'exécution de cette commande et de la communication future avec le donneur d’ordre. L'affectation est également indiquée dans la section « Historique » à des fins de suivi.
Les opérateurs attribués peuvent également être consultés dans la page « Commandes » en rendant visible la colonne « Opérateur » dans « Préférences », pour avoir une vue d'ensemble de toutes les commandes et de leurs opérateurs.
septembre 29, 2020
Calculateur de coûts
Les administrateurs peuvent désormais ajouter l'utilisation des machines, l'amortissement, les coûts de main-d'œuvre et de matériel lors de la configuration des machines et des matériaux dans GrabCAD Shop. Ces tarifs peuvent ensuite être utilisés lors de la soumission d'une commande et pour une analyse efficace des coûts des opérations de l'atelier des modèles.
Les opérateurs peuvent ensuite accéder à une commande et saisir des estimations de matériel et de temps après le traitement d'une demande. Ils voient ainsi un résultat de prix automatique basé sur les tarifs précédemment configurés. Cliquez sur l'icône « Calculatrice » pour afficher une grille tarifaire détaillée, ainsi que la possibilité d'en ajouter, de majorer, de réduire et de remplacer les coûts.
août 30, 2020
Ajout d'utilisateurs en masse à l'aide du domaine de messagerie
Vous pouvez désormais fournir simultanément un accès à GrabCAD Shop à tous vos utilisateurs avec le domaine de messagerie de votre organisation (my_email_ID@ domaine), au lieu d’ajouter les adresses e-mail une par une. Dans GrabCAD Control, accédez à l’onglet « Inviter des utilisateurs » de la page Utilisateurs et sélectionnez « Ajouter par domaine ». Entrez le domaine de messagerie de vos utilisateurs et n’oubliez pas d’attribuer des groupes d’utilisateurs, pour donner accès à ces utilisateurs lorsqu’ils se connectent.
Pour des raisons de sécurité, un membre du personnel de Stratasys examinera votre demande de domaine dès que possible. Une fois la demande approuvée, tous les membres de votre équipe pourront se connecter à GrabCAD Shop avec leur e-mail et accéder à vos ateliers.
juillet 31, 2020
Personnalisez les statuts de vos commandes
Les statuts des commandes et des pièces peuvent désormais être configurés par un administrateur par atelier, pour communiquer efficacement le statut des demandes. Accédez à un atelier et cliquez sur Préférences pour afficher ou masquer les statuts intégrés, modifier les couleurs d'affichage, réorganiser les statuts et ajouter jusqu'à 8 nouveaux statuts personnalisés. Les administrateurs peuvent également configurer si l'état personnalisé représente une commande active ou inactive.
Configurer les colonnes dans la page des commandes
Pour garantir que tous les utilisateurs d'un atelier ne voient que les données pertinentes, les administrateurs peuvent désormais afficher ou masquer les colonnes de la page des commandes dans la section Préférences d'un atelier. De plus, les nouvelles colonnes suivantes peuvent être ajoutées pour améliorer l’ergonomie de la page des commandes :
  • Code de projet d'une commande
  • Nombre de fichiers CAO dans une commande
  • Technologies demandées dans une commande
  • Matériaux demandés dans une commande
juin 25, 2020
Nouveaux filtres sur la page de commandes
Vous pouvez désormais filtrer vos commandes par date d'envoi, par besoin ou par date de livraison. Ces filtres peuvent être appliqués en plus de ceux de statut et de technologie dans la page des commandes avant d'exporter le résultat.
juin 3, 2020
Rechercher vos commandes d’atelier
Vous pouvez maintenant rechercher sur la page, des commandes spécifiques à l'aide du nom du projet, du nom du donneur d’ordre, de l'adresse e-mail ou du code du projet. Une fois les résultats de la recherche obtenus, vous pouvez également exporter le résultat dans un fichier CSV.
Barre de navigation pliable
Pour améliorer l’ergonomie de GrabCAD Shop sur des écrans plus petits, vous pouvez maintenant réduire la barre de navigation grise à l'aide de la petite flèche en haut de l'écran (à côté du nom de la société). Lorsqu'elle est réduite, vous pouvez la visualiser en déplaçant votre curseur vers la gauche de l'écran.
juin 2, 2020
Les imprimantes Stratasys PolyJet suivantes ont été ajoutées comme machines disponibles dans Shop :
  • Imprimante Stratasys J750 Digital Anatomy
  • Stratasys j55
  • Stratasys J720 dentaire
  • La gamme complète des imprimantes Objet et Connex 260/350/500
Nous avons également ajouté de nouvelles options de machine et de matériaux correspondants aux technologies suivantes :
  • Extrusion de matériaux - Desktop Metal, Prusa, Dynamical 3D
  • Projection de liant - Desktop Metal
  • Fusion sur lit de poudre - HP
  • FDM - Makerbot
En outre, plus de fabricants et de matériaux ont été ajoutés à la technologie MOCN. Enfin, la technologie de traitement laser et les matériaux génériques correspondants ont également été ajoutés.
mai 22, 2020
Résumé de la mise à jour trimestrielle
Nous avons ajouté quelques mises à jour depuis notre lancement de 2020 en janvier. Cliquez ici pour avoir un résumé vidéo.
mai 20, 2020
Affichage par défaut amélioré pour la page Commandes
La page Commandes est désormais filtrée pour n'afficher par défaut que les commandes « Actives », afin d'améliorer les performances de chargement de la page. Elle aide les opérateurs à se concentrer uniquement sur les commandes qui nécessitent une attention. Les commandes avec les statuts « Terminé » et « Annulé » sont considérées comme des commandes inactives et peuvent être affichées en modifiant le filtre.
mai 19, 2020
Rapports sur les commandes Shop
Vous pouvez maintenant télécharger la vue actuelle de la page Commandes sous forme de fichier .CSV. Si vous devez utiliser un autre système de reporting pour suivre vos commandes, appliquez les filtres pour obtenir la vue de votre choix, puis cliquez sur le bouton Exporter.
mai 11, 2020
Améliorations de l’ergonomie et des performances
Quelques petites modifications ont été apportées pour faire gagner du temps aux opérateurs. Les sélections de tri et de filtrage sur la page de commandes sont désormais conservées tout au long de la session, et vous pouvez désormais voir un décompte du total des commandes dans l’atelier. Les performances de chargement de la page Commandes ont également été améliorées.
avril 22, 2020
Planifiez facilement les travaux à l'aide de l'intégration de GrabCAD Print
À partir de votre page Commandes, sélectionnez une ou plusieurs commandes et cliquez sur le bouton « P » en haut pour ouvrir immédiatement les fichiers de ces commandes dans GrabCAD Print. Vous n'avez plus besoin de télécharger des fichiers et de les ajouter manuellement, vous pouvez obtenir vos fichiers dans GrabCAD Print en un seul clic. Cela coïncide avec la sortie de la version 1.41 de GrabCAD Print.
mars 23, 2020
Amélioration de Shop et de la création de groupes
Lorsqu’un administrateur crée un atelier, deux groupes d’utilisateurs sont automatiquement créés (donneurs d’ordre et opérateurs) et l’administrateur est ajouté aux deux. Ces groupes peuvent être consultés dans GrabCAD Control. Ils permettent à l’administrateur de configurer facilement son atelier et de donner accès à ses utilisateurs.
Vous ne trouvez pas ce que vous cherchez ? envoyez-nous un message envoyez-nous un message
