GrabCAD Streamline Pro Updates
Settembre 17, 2024
Simplified printer addition in GrabCAD Analyze
GrabCAD Analyze users can now easily add all their Stratasys printers to Analyze with a few clicks using the new "Discover" button in the printers page. Printers that aren't discoverable can still be added by IP using the "Manually Add" button, which has been improved and simplified.
Go to the Analyze Agent Settings page and ensure that the Agent is connected. Then, go to the Printers page and click Discover, to see all the printers in your network. Select and add the printers that you want to show in Analyze. (A GrabCAD Print desktop or GrabCAD PrintSserver installation is required on the computer that has the Analyze Server installed). Once the printers are added, they can be renamed, edited as needed.
Settembre 17, 2024
Performance, stability and installer improvements to GrabCAD Analyze
Users with many printers (up to 50) can now use GrabCAD Analyze to collect data and generate dashboards and reports. The data collection, storage and aggregation has been simplified and improved in the Analyze Agent and Server to scale and work with more printers. However, the computational requirements of the server needs to increased to account for the increased influx of data from the machines. (Current requirements are for 10 printers).
With the latest installer, a number of improvements have been made to improve the installation success in different user environments. The Analyze Server will also be configured to automatically restart in the event of a Windows update or restart, to prevent any unexpected downtime.
Agosto 27, 2024
Print orientation selection of order items to obtain more revelant estimates
GrabCAD Shop requesters and operators can now select the desired orientation for an FDM or PolyJet order item to ensure it is printed accordingly. This feature allows for greater specification and control over order items, as well as the estimation and print results, reducing the back-and-forth communication between requesters and operators.
Once an order is submitted and GrabCAD Shop completes an automatic estimation of the items, users can view the orientation used by GrabCAD Shop to generate the estimation (usually the CAD orientation or the recommended orientation from GrabCAD Print, depending on the Shop's preferences). If users wish to specify a different orientation to capture design intent or enhance printability, they can select one of the seven available options. This orientation is then saved and preserved in the order, and if the item is added to a job, the selected orientation will be used. The order item's thumbnail will also be updated to reflect the currently selected orientation.
Giugno 28, 2024
Improvements to .cmb and .print files in GrabCAD Shop
GrabCAD Shop requesters and operators can now work directly with .cmb and .print files. This feature is available for advanced users who use GrabCAD Shop to submit their print requests but want to specify all the build parameters using project files in GrabCAD Print. When these files are uploaded to GrabCAD Shop, the desired machine, material estimates, time estimates, tray preview, and other high-level build estimates are extracted and displayed, allowing operators to understand exactly what is being requested.
Create a new order and upload project files from GrabCAD Print. After submitting the order, you can see a preview and all other details related to the order. Note that these files cannot be added to Jobs, as they are not intended to be combined with other parts, which could affect the requester's design intent.
Giugno 28, 2024
Automatically estimate, preview and generate printable trays from your Shop
In addition to automatic estimations for FDM and PolyJet requests in GrabCAD Shop, operators can use the Jobs feature to group similar parts and requests and have an tray generated automatically with estimates and a preview. This allows operators to reduce their backlog by quickly consolidating requests, grouping parts that can be printed together, and downloading valid printable trays for queuing purposes.
Go to Jobs and click "New Job" to see all the order items in your Shop that need to be printed. Filter these items by technology, machine, and material, and select the parts that you want to print together. Once the job is created, GrabCAD Shop will pack these parts and try to generate a tray that can be printed and downloaded (a .print file is generated, which can be opened in GrabCAD Print), along with a tray preview and estimation details. If any parts don't fit, they will be highlighted and can be removed from the job, and can be added in other jobs.
Giugno 3, 2024
Introducing GrabCAD Streamline Pro - new software suite to grow and scale your operations
GrabCAD Streamline Pro is a new paid software suite from Stratasys designed for users with FDM and PolyJet printers. It includes GrabCAD Shop and simplifies order management by allowing administrators and printer operators to create virtual model shops for managing 3D printing requests. Streamline Pro introduces new automation capabilities that save operators time by managing their backlog more efficiently. Each FDM and PolyJet request will be automatically estimated—powered by GrabCAD Print—with default machine parameters and optimal orientation, providing realistic material, time, and cost estimates. This eliminates the need to generate these estimates manually. Operators can then review, compare, append, and override the estimates as needed.
Streamline Pro also features a new cybersecurity device, Shield, which protects the printer from network vulnerabilities, provides IPv6 support, and acts as a firewall for the printer. Additionally, it includes role-based access control to restrict visibility to Stratasys printers and prevent unauthorized access.
Furthermore, Streamline Pro includes GrabCAD Analyze (Version 1.90), an advanced analytics, dashboard, and notification tool that operates on-premise. It offers out-of-the-box dashboards detailing and tracking printer and material utilization for FDM and PolyJet systems. Operators can also set up custom alerts for various printing events (e.g., print job at 95%, material level at 5%) to prevent unexpected issues or delays.
All these capabilities are accessible only with a valid GrabCAD Streamline Pro license. Learn more about Streamline Pro here.
Maggio 23, 2024
New Stratays printers and materials available
New Stratasys machines and materials are now available to be added to your Shop. These include :
  • PolyJet printers like the J55 Pro, J3 and J5 DentaJet, and new models of J850 printers (Prime FabriX, Prime TechStyle, Pro and Digital Anatomy),
  • FDM printers like the F190CR, F370CR, and F3300.
  • P3 technology Origin One Dental with Dental materials,
  • New PA12 and PP materials for the SAF technology H350,
  • New FDM HIPS, Kimya, VICTREX, Polycarbonate and Ultem materials and colors for the Fortus 450mc and Stratasys F900 printers,
Se si desidera aggiungere una macchina allo Shop ma non è ancora disponibile, faccelo sapere!
Aprile 1, 2024
New password rules for increased security
Users who are creating GrabCAD accounts to use GrabCAD software (GrabCAD Print, Shop, Control) are now required to set their passwords conforming to our new rules : 8 character minimum, with numbers, lower case and upper case characters required. This enhancement will increase the security of user accounts and provide IT and security managers at Stratasys printer sites with greater confidence in the security and management of GrabCAD software.
Go to login.grabcad.com or select the user icon in GrabCAD Print to create an account or reset your password.
Gennaio 11, 2024
Control access to Printers
Administrators at Stratasys printer sites can now control access to their printers in GrabCAD Control, to prevent unauthorized, untrained or accidental visibility and usage of Stratasys printers at their site. This allows them to prevent printer downtime and wasted material in cases where users intentionally or accidentally modify the printer queues, cancel a long running print job and more. This also allows administratros to hide printers that are running sensitive and secretive print jobs, and only grant access to trained operators.
Go to GrabCAD Control, add your printers and group them. Then you can assign selected users in your company to the printer groups to grant them access and revoke access for everyone else. If you do not have access to GrabCAD Control, you can request a company account by emailed shop@grabcad.com.
Agosto 20, 2023
Units and bounding box dimensions for order items
GrabCAD Shop requesters can now specify units for order items with unitless file formats (STL, OBJ, VRML and similar formats) and view the bounding box dimensions (length, width and depth) in the Shop's preferred display units. This will reduce the feedback loop with operators as they can easily understand the size of the requests, and ensure that these items are fabricated with the correct desired size. CAD files not in the unitless file format will have the CAD units and bounding box dimensions displayed in a read-only format.
Go to a Shop and click "New order" to upload your files. After a CAD file is uploaded, the units and bounding box dimensions will be visible next to the order item. Once the order is submitted, the operators can see the selected units and dimensions in each order item's details. If the units are changed after the order is submitted, it is noted in the history section of the order.
Giugno 20, 2023
Introducing GrabCAD Control
Administrators, managers and IT who manage Stratasys printers can now use GrabCAD Control, the Stratasys printer and user management solution. Previously called Admin Console (used to manage GrabCAD Shop invitations and roles), GrabCAD Control can only be used by selected users (Admins) in a company. They can login to their "company account" in GrabCAD Control, and they can
  • Invite users to their company,
  • Add other admins,
  • Connect their GrabCAD Print Server and manage their Stratasys printers,
  • View and assign GrabCAD software licenses to your users,
  • Create user and printer groups,
  • Control user access,
  • Assign user roles,
  • Manage Shops and more.
Learn more about GrabCAD Control here. Contact print@grabcad.com to request a "company account". Our customer support team will create a company account for you and make you an admin, after which you can login and perform the actions above.
Marzo 7, 2023
Nuova colonna configurabile nella pagina degli ordini
Gli amministratori di GrabCAD Shop ora possono attivare una colonna opzionale nella pagina degli ordini denominata "Parti totali". Consente agli operatori di valutare efficacemente la dimensione degli ordini senza che sia necessario aprire ciascun ordine.
La colonna "Parti totali" mostra il numero totale di parti stampabili in un ordine insieme alle rispettive quantità, a differenza della colonna "File CAD", che mostra il numero di parti stampabili uniche nell'ordine. Portati in Negozio e fai clic su "Preferenze" per mostrare o nascondere questa nuova colonna.
Dicembre 13, 2021
Riepilogo aggiornamento inverno 2021
Sin dal nostro riepilogo dell'ultimo aggiornamento, abbiamo aggiunto altre funzionalità. Fare clic qui per vedere un video riassuntivo.
Dicembre 13, 2021
Più stampanti e tecnologie disponibili
Tutte le nuove macchine Stratasys e molte macchine di 3° parti sono ora disponibili per essere aggiunte allo Shop.
Le aggiunte di Stratasys includono
  • Stampanti PolyJet come J5 MediJet, J35 pro, J55 Prime,
  • FDM F770,
  • Tecnologia P3 Origin one,
  • Tecnologia SAF H350,
  • Stampanti RPS Neo a base di resina.
  • Il nuovo materiale Stratasys ABS CF10 sulle stampanti F123.
Nuove opzioni macchina e materiali corrispondenti alle seguenti tecnologie:
  • Estrusione materiale: 3DGence, Zortrax, Raise3D, MakerGear e Fusion3
  • Powder Bed (SLS): Sinterit
  • Getto legante: ExOne
  • A base di resina (SLA, DLP): nuovi materiali Formlabs.
Novembre 18, 2021
Lavori - Gestisci più ordini contemporaneamente
Gli operatori di GrabCAD Shop possono ora elaborare e tracciare rapidamente più ordini o parti contemporaneamente utilizzando un "Lavoro". Ciò consente di risparmiare tempo e clic rispetto all'utilizzo di ordini individuali.
Un lavoro è una raccolta di parti simili che seguono lo stesso percorso dall'invio al completamento, ovvero che condividono la stessa tecnologia richiesta, il materiale, il vassoio/letto su una macchina disponibile o le fasi di post-elaborazione. Per iniziare, fare clic su "Lavori" nella barra di navigazione a sinistra e fare clic su "Nuovo lavoro". Qui è possibile vedere tutte le parti Attive (stato non "Completato" o "Annullato") nel Negozio. Si può quindi filtrare, selezionare parti dall'elenco e creare un lavoro per una macchina nel tuo negozio. Una volta creato un lavoro, è possibile
  • Aggiornare facilmente tutti gli stati delle singole parti su "In corso".
  • Spostare/trascinare le parti durante le diverse fasi del processo (lavoro creato, accodato, stampa, post-elaborazione, completato).
  • Aprire tutte le parti insieme in GrabCAD Print (se si tratta di un lavoro per una macchina Stratasys).
  • Assegnare un nome al lavoro (Esempio: Friday F370 Tray).
Un lavoro può essere contrassegnato come "Completato" quando tutte le parti in esso contenute sono state completate/fabbricate/pronte per il ritiro. Questo aggiornerà anche tutti gli stati delle parti su "Completato", permettendoti di passare ad altri lavori. Ulteriori informazioni su questa funzionalità sono disponibili qui.
Luglio 7, 2021
Dipendenze e allegati ai singoli articoli dell'Ordine
I richiedenti di GrabCAD Shop possono ora inviare facilmente ordini per assiemi (file di assieme + componenti di assieme) o file di texture (file STL, OBJ, VRML + file di texture di immagine/bump). Invece di caricare tutti i file e le dipendenze nell'ordine come singoli elementi, un richiedente può iniziare caricando solo il file/assiemi CAD padre (es. SLDASM, OBJ, ecc.) e inviando l'ordine. Quindi è possibile aprire l'ordine e fare clic sull'icona "Allega file" in ogni elemento dell'ordine per aggiungere dipendenze (ad es. SLDPRT, STL, PNG). Gli operatori possono quindi aprire un articolo dell'ordine con tutte le sue dipendenze da GrabCAD Shop in GrabCAD Print.
Ciò si traduce in ordini più efficienti con meno articoli dell'ordine (con dipendenze). Le dipendenze sono associate agli articoli dell'ordine e non trattate come singoli articoli. Anche gli operatori ne traggono vantaggio, in quanto possono fabbricare articoli dell'ordine con tutte le informazioni rilevanti/associazioni di dipendenze, senza inutili avanti e indietro con i richiedenti.
Maggio 11, 2021
Opzioni PolyJet Single Material ora disponibili
Analogamente a FDM, gli amministratori con macchine PolyJet possono ora selezionare ed esporre le opzioni di colore singolo Vero, Agilus e Tango ai richiedenti del negozio, oltre alle opzioni multi-colore già disponibili. Queste opzioni di colore/materiale singolo possono essere configurate nella pagina Macchine per tutti i tipi di macchine PolyJet nel database di GrabCAD Shop e offrono maggiore flessibilità per gli ordini e i casi d'uso PolyJet.
I richiedenti possono quindi inviare ordini e specificare i singoli colori primari PolyJet disponibili, se non desiderano mischiare materiali PolyJet. (es. stampare un file CAD in Vero PureWhite).
Aprile 25, 2021
Miglioramenti delle prestazioni e della sicurezza
I negozi con molti ordini, colonne personalizzate o molte parti/articoli per ordine ora vedranno miglioramenti significativi nei tempi di caricamento della pagina. La velocità di caricamento della pagina dell'elenco degli ordini è aumentata di 10 volta e le pagine dei dettagli dell'ordine sono aumentate di 2 volte. Anche la home page dei negozi, la pagina delle macchine e le query della sezione Cronologia sono state rese più efficienti. Tutte queste modifiche sono progettate per aiutare gli utenti di GrabCAD Shop a gestire e accedere più rapidamente ai loro negozi, ordini e contenuti pertinenti.
Nel tentativo di mantenere al sicuro gli ordini del GrabCAD Shop e i relativi metadati, monitoriamo, identifichiamo e risolviamo regolarmente le vulnerabilità della sicurezza. GrabCAD Shop è stato recentemente sottoposto a test di penetrazione della sicurezza da un'agenzia di buona reputazione e sono state risolte tutte le vulnerabilità di priorità medio/alta.
Gennaio 31, 2021
Cronologia e notifiche e-mail sugli aggiornamenti degli ordini
I richiedenti e gli operatori assegnati possono ora visualizzare un riepilogo ordinato di tutte le modifiche nella sezione "Cronologia". Queste modifiche comprendono, ad esempio,
  • Modifiche ai dettagli dell'ordine, alle date, alle stime e al prezzo
  • Modifiche di stato
  • Aggiunta o rimozione di articoli/file dell'ordine
  • Assegnazione dell'operatore
Il richiedente e l'operatore assegnato di un ordine riceveranno anche una notifica via e-mail quando vengono apportate queste modifiche. Altri utenti nel negozio possono scegliere di "visualizzare" un ordine ed essere avvisati, selezionando la casella "Invia notifica sugli aggiornamenti" in quell'ordine specifico.
Ottobre 12, 2020
Riepilogo aggiornamenti 2020 autunnale
Dal riepilogo degli aggiornamenti in Maggio 2020, abbiamo aggiunto ancora più funzionalità. Fare clic qui per un riepilogo video.
Ottobre 6, 2020
Assegna un operatore a un ordine
Gli operatori possono ora assegnare se stessi o altri operatori dello shop a un ordine. L'operatore assegnato viene quindi informato ed è responsabile dell'adempimento di tale ordine e delle future comunicazioni con il richiedente. L'assegnazione viene annotata anche nella sezione "Cronologia" per scopi di monitoraggio.
Gli operatori assegnati possono essere visualizzati anche nella pagina “Ordini” rendendo visibile in “Preferenze” la colonna “Operatore”, per avere una panoramica di tutti gli ordini e dei loro operatori.
Settembre 29, 2020
Calcolatore dei costi
Gli amministratori possono ora aggiungere l'utilizzo della macchina, l'ammortamento, la manodopera e i costi dei materiali durante la configurazione di macchine e materiali in GrabCAD Shop. Queste tariffe possono quindi essere utilizzate durante la quotazione di un ordine e per un'efficace analisi dei costi delle operazioni dello shop di modelli.
Gli operatori possono quindi accedere a un ordine e inserire stime di materiali e tempi dopo l'elaborazione di una richiesta e visualizzare un risultato di prezzo automatico basato sulle tariffe precedentemente configurate. Facendo clic sull'icona "Calcolatrice" viene visualizzata una ripartizione dettagliata delle tariffe e dei costi e la possibilità di aggiungere altri, markup, sconti e sovrascrivere i costi.
Agosto 30, 2020
Aggiunta di utenti in blocco utilizzando il dominio di posta
Ora puoi fornire l'accesso a GrabCAD Shop a tutti i tuoi utenti con il dominio e-mail della tua organizzazione (ID_my_email@dominio), invece di aggiungere e-mail una alla volta. In GrabCAD Control, vai alla scheda "Invita utenti" nella pagina Utenti e seleziona "Aggiungi per dominio". Inserisci il dominio e-mail dei tuoi utenti e non dimenticare di assegnare gruppi di utenti per fornire loro l'accesso quando si collegano.
Per motivi di sicurezza, un incaricato di Stratasys esaminerà la tua richiesta di dominio il prima possibile. Una volta approvata, tutti i membri del tuo team potranno accedere a GrabCAD Shop con la propria e-mail e accedere ai tuoi Negozi.
Luglio 31, 2020
Personalizzare gli stati dell’ordine
Gli stati degli ordini e delle parti possono ora essere configurati da un amministratore per shop, per comunicare efficacemente lo stato delle richieste. Andare a uno Shop e fare clic su Preferenze per mostrare o nascondere gli stati incorporati, modificare i colori di visualizzazione, riordinare gli stati e aggiungere fino a 8 nuovi stati personalizzati. Gli amministratori possono anche configurare se lo stato personalizzato rappresenta un ordine attivo o inattivo.
Configurare le colonne nella pagina degli ordini
Per garantire che tutti gli utenti in uno Shop vedano solo i dati rilevanti, gli amministratori possono ora mostrare o nascondere le colonne nella pagina degli ordini nella sezione Preferenze di uno Shop. Inoltre, le seguenti nuove colonne possono essere aggiunte per migliorare l'usabilità della pagina degli ordini:
  • Codice progetto di un ordine
  • Numero di file CAD in un ordine
  • Tecnologie richieste in un ordine
  • Materiali richiesti in un ordine
Giugno 25, 2020
Nuovi filtri della pagina degli ordini
Ora è possibile filtrare gli ordini in base alle date di invio, richiesta entro o consegna. Questi filtri possono essere applicati in aggiunta ai filtri di stato e tecnologia nella pagina degli ordini prima di esportare la visualizzazione risultante.
Giugno 3, 2020
Cercare gli ordini dello Shop
È ora possibile cercare ordini specifici nella pagina degli ordini utilizzando il nome del progetto, il nome del richiedente, l'indirizzo e-mail o il codice del progetto. Una volta ottenuti i risultati della ricerca, è anche possibile esportare la visualizzazione risultante in un file CSV.
Barra di navigazione comprimibile
Per migliorare l'usabilità di GrabCAD Shop su schermi più piccoli, ora è possibile comprimere la barra di navigazione grigia usando la piccola freccia vicino alla parte superiore dello schermo (accanto al nome dell'azienda). Quando è compressa, è possibile visualizzarla spostando il cursore a sinistra dello schermo.
Giugno 2, 2020
Le seguenti stampanti Stratasys PolyJet sono state aggiunte come macchine disponibili nello Shop:
  • Stampante digitale per modelli anatomici Stratasys J750
  • Stratasys j55
  • Stratasys j720 dental
  • La gamma completa di stampanti Objet e Connex 260/350/500
Abbiamo anche aggiunto alcune nuove opzioni macchina e materiali corrispondenti alle seguenti tecnologie:
  • Estrusione di materiali - Desktop Metal, Prusa, Dynamical 3 D
  • Binder jetting - Desktop Metal
  • Fusione a letto di polvere - HP
  • FDM - Makerbot
Inoltre, più produttori e materiali sono stati aggiunti alla tecnologia CNC. Infine, sono stati aggiunti anche la tecnologia di lavorazione laser e i materiali generici corrispondenti.
Maggio 22, 2020
Riepilogo aggiornamenti trimestrale
Abbiamo aggiunto alcuni aggiornamenti dal nostro lancio a gennaio 2020. Fare clic qui per un riepilogo video.
Maggio 20, 2020
Visualizzazione predefinita migliorata per la pagina Ordini
La pagina Ordini è ora filtrata per mostrare solo gli ordini "Attivi" per impostazione predefinita, al fine di migliorare le prestazioni di caricamento della pagina e aiutare gli operatori a concentrarsi solo sugli ordini che richiedono attenzione. Gli ordini con gli stati "Completato" e "Annullato" sono considerati ordini inattivi e possono essere visualizzati modificando il filtro.
Maggio 19, 2020
Reporting sugli ordini dello Shop
È ora possibile scaricare la visualizzazione corrente della pagina Ordini come file .CSV. Per utilizzare un altro sistema di reportistica per tracciare gli ordini, applicare i filtri per ottenere la visualizzazione desiderata, quindi premere il pulsante Esporta.
Maggio 11, 2020
Usabilità e miglioramenti delle prestazioni
Sono state apportate alcune piccole modifiche per far risparmiare tempo agli operatori. Le selezioni di ordinamento e filtro nella pagina dell'ordine vengono ora mantenute per tutta la sessione e ora è possibile vedere un conteggio degli ordini totali nello Shop. Anche le prestazioni di caricamento della pagina Ordini sono state migliorate.
Aprile 22, 2020
Pianificare facilmente i lavori utilizzando l'integrazione di GrabCAD Print
Dalla pagina degli ordini, selezionare uno o più ordini e fare clic sul pulsante "P" in alto per aprire immediatamente i file di quegli ordini in GrabCAD Print. Non è più necessario scaricare file e aggiungerli manualmente, è possibile caricare i file in GrabCAD Print con un clic. Ciò coincide con il rilascio della versione GrabCAD Print 1.41.
Marzo 23, 2020
Creazione di Shop e gruppi di utenti migliorata
Quando un amministratore crea un Negozio, vengono creati automaticamente due gruppi di utenti (Richiedenti e Operatori) e l'amministratore viene aggiunto a entrambi. Questi gruppi possono essere visualizzati in GrabCAD Control e consentono all'amministratore di configurare facilmente il proprio Negozio e fornire l'accesso agli utenti.
Non trovi quello che ti serve? Send us a message Send us a message
