GrabCAD Streamline Pro Updates
9月 17, 2024
Simplified printer addition in GrabCAD Analyze
GrabCAD Analyze users can now easily add all their Stratasys printers to Analyze with a few clicks using the new "Discover" button in the printers page. Printers that aren't discoverable can still be added by IP using the "Manually Add" button, which has been improved and simplified.
Go to the Analyze Agent Settings page and ensure that the Agent is connected. Then, go to the Printers page and click Discover, to see all the printers in your network. Select and add the printers that you want to show in Analyze. (A GrabCAD Print desktop or GrabCAD PrintSserver installation is required on the computer that has the Analyze Server installed). Once the printers are added, they can be renamed, edited as needed.
9月 17, 2024
Performance, stability and installer improvements to GrabCAD Analyze
Users with many printers (up to 50) can now use GrabCAD Analyze to collect data and generate dashboards and reports. The data collection, storage and aggregation has been simplified and improved in the Analyze Agent and Server to scale and work with more printers. However, the computational requirements of the server needs to increased to account for the increased influx of data from the machines. (Current requirements are for 10 printers).
With the latest installer, a number of improvements have been made to improve the installation success in different user environments. The Analyze Server will also be configured to automatically restart in the event of a Windows update or restart, to prevent any unexpected downtime.
8月 27, 2024
Print orientation selection of order items to obtain more revelant estimates
GrabCAD Shop requesters and operators can now select the desired orientation for an FDM or PolyJet order item to ensure it is printed accordingly. This feature allows for greater specification and control over order items, as well as the estimation and print results, reducing the back-and-forth communication between requesters and operators.
Once an order is submitted and GrabCAD Shop completes an automatic estimation of the items, users can view the orientation used by GrabCAD Shop to generate the estimation (usually the CAD orientation or the recommended orientation from GrabCAD Print, depending on the Shop's preferences). If users wish to specify a different orientation to capture design intent or enhance printability, they can select one of the seven available options. This orientation is then saved and preserved in the order, and if the item is added to a job, the selected orientation will be used. The order item's thumbnail will also be updated to reflect the currently selected orientation.
6月 28, 2024
Improvements to .cmb and .print files in GrabCAD Shop
GrabCAD Shop requesters and operators can now work directly with .cmb and .print files. This feature is available for advanced users who use GrabCAD Shop to submit their print requests but want to specify all the build parameters using project files in GrabCAD Print. When these files are uploaded to GrabCAD Shop, the desired machine, material estimates, time estimates, tray preview, and other high-level build estimates are extracted and displayed, allowing operators to understand exactly what is being requested.
Create a new order and upload project files from GrabCAD Print. After submitting the order, you can see a preview and all other details related to the order. Note that these files cannot be added to Jobs, as they are not intended to be combined with other parts, which could affect the requester's design intent.
6月 28, 2024
Automatically estimate, preview and generate printable trays from your Shop
In addition to automatic estimations for FDM and PolyJet requests in GrabCAD Shop, operators can use the Jobs feature to group similar parts and requests and have an tray generated automatically with estimates and a preview. This allows operators to reduce their backlog by quickly consolidating requests, grouping parts that can be printed together, and downloading valid printable trays for queuing purposes.
Go to Jobs and click "New Job" to see all the order items in your Shop that need to be printed. Filter these items by technology, machine, and material, and select the parts that you want to print together. Once the job is created, GrabCAD Shop will pack these parts and try to generate a tray that can be printed and downloaded (a .print file is generated, which can be opened in GrabCAD Print), along with a tray preview and estimation details. If any parts don't fit, they will be highlighted and can be removed from the job, and can be added in other jobs.
6月 3, 2024
Introducing GrabCAD Streamline Pro - new software suite to grow and scale your operations
GrabCAD Streamline Pro is a new paid software suite from Stratasys designed for users with FDM and PolyJet printers. It includes GrabCAD Shop and simplifies order management by allowing administrators and printer operators to create virtual model shops for managing 3D printing requests. Streamline Pro introduces new automation capabilities that save operators time by managing their backlog more efficiently. Each FDM and PolyJet request will be automatically estimated—powered by GrabCAD Print—with default machine parameters and optimal orientation, providing realistic material, time, and cost estimates. This eliminates the need to generate these estimates manually. Operators can then review, compare, append, and override the estimates as needed.
Streamline Pro also features a new cybersecurity device, Shield, which protects the printer from network vulnerabilities, provides IPv6 support, and acts as a firewall for the printer. Additionally, it includes role-based access control to restrict visibility to Stratasys printers and prevent unauthorized access.
Furthermore, Streamline Pro includes GrabCAD Analyze (Version 1.90), an advanced analytics, dashboard, and notification tool that operates on-premise. It offers out-of-the-box dashboards detailing and tracking printer and material utilization for FDM and PolyJet systems. Operators can also set up custom alerts for various printing events (e.g., print job at 95%, material level at 5%) to prevent unexpected issues or delays.
All these capabilities are accessible only with a valid GrabCAD Streamline Pro license. Learn more about Streamline Pro here.
5月 23, 2024
New Stratays printers and materials available
New Stratasys machines and materials are now available to be added to your Shop. These include :
  • PolyJet printers like the J55 Pro, J3 and J5 DentaJet, and new models of J850 printers (Prime FabriX, Prime TechStyle, Pro and Digital Anatomy),
  • FDM printers like the F190CR, F370CR, and F3300.
  • P3 technology Origin One Dental with Dental materials,
  • New PA12 and PP materials for the SAF technology H350,
  • New FDM HIPS, Kimya, VICTREX, Polycarbonate and Ultem materials and colors for the Fortus 450mc and Stratasys F900 printers,
ショップに追加したい機器が見当たらない場合は、お知らせください!
4月 1, 2024
New password rules for increased security
Users who are creating GrabCAD accounts to use GrabCAD software (GrabCAD Print, Shop, Control) are now required to set their passwords conforming to our new rules : 8 character minimum, with numbers, lower case and upper case characters required. This enhancement will increase the security of user accounts and provide IT and security managers at Stratasys printer sites with greater confidence in the security and management of GrabCAD software.
Go to login.grabcad.com or select the user icon in GrabCAD Print to create an account or reset your password.
1月 11, 2024
Control access to Printers
Administrators at Stratasys printer sites can now control access to their printers in GrabCAD Control, to prevent unauthorized, untrained or accidental visibility and usage of Stratasys printers at their site. This allows them to prevent printer downtime and wasted material in cases where users intentionally or accidentally modify the printer queues, cancel a long running print job and more. This also allows administratros to hide printers that are running sensitive and secretive print jobs, and only grant access to trained operators.
Go to GrabCAD Control, add your printers and group them. Then you can assign selected users in your company to the printer groups to grant them access and revoke access for everyone else. If you do not have access to GrabCAD Control, you can request a company account by emailed shop@grabcad.com.
8月 20, 2023
Units and bounding box dimensions for order items
GrabCAD Shop requesters can now specify units for order items with unitless file formats (STL, OBJ, VRML and similar formats) and view the bounding box dimensions (length, width and depth) in the Shop's preferred display units. This will reduce the feedback loop with operators as they can easily understand the size of the requests, and ensure that these items are fabricated with the correct desired size. CAD files not in the unitless file format will have the CAD units and bounding box dimensions displayed in a read-only format.
Go to a Shop and click "New order" to upload your files. After a CAD file is uploaded, the units and bounding box dimensions will be visible next to the order item. Once the order is submitted, the operators can see the selected units and dimensions in each order item's details. If the units are changed after the order is submitted, it is noted in the history section of the order.
6月 20, 2023
Introducing GrabCAD Control
Administrators, managers and IT who manage Stratasys printers can now use GrabCAD Control, the Stratasys printer and user management solution. Previously called Admin Console (used to manage GrabCAD Shop invitations and roles), GrabCAD Control can only be used by selected users (Admins) in a company. They can login to their "company account" in GrabCAD Control, and they can
  • Invite users to their company,
  • Add other admins,
  • Connect their GrabCAD Print Server and manage their Stratasys printers,
  • View and assign GrabCAD software licenses to your users,
  • Create user and printer groups,
  • Control user access,
  • Assign user roles,
  • Manage Shops and more.
Learn more about GrabCAD Control here. Contact print@grabcad.com to request a "company account". Our customer support team will create a company account for you and make you an admin, after which you can login and perform the actions above.
3月 7, 2023
注文ページの新しい構成可能な列
GrabCAD ショップ管理者は、注文ページで [合計部品数] と呼ばれるオプションの列をオンにできるようになりました。これにより、オペレーターは各注文を開くことなく、注文のサイズを効果的に測定できます。
[合計部品数] 列には、注文内の印刷可能な部品の合計数とそれぞれの数量が表示されます。 注文内の固有の印刷可能な部品数を示す「CAD ファイル」列とは異なります。ショップに移動し、[設定] をクリックして、この新しい列を表示または非表示にします。
12月 13, 2021
2021冬の新着情報の概要
最後の更新情報の概要以降、さらに多くの機能が追加されました。こちらをクリックして、概要の動画をご覧ください。
12月 13, 2021
より多くのプリンタと技術が利用可能
すべての新しいStratasys機械と多くの3パーティマシンをショップに追加できるようになりました。
Stratasysの追加には以下が含まれます
  • J5 MediJetなどのPolyJetプリンタ、J35 pro、J55 Prime、
  • FDM F770、
  • P3技術オリジンワン、
  • SAF技術H350、
  • 樹脂ベースのRPS Neoプリンタ。
  • F123プリンタの新しいStratasys ABS CF10材料。
次の技術に対応する新しい機械オプションと対応する材料:
  • 材料押出: 3DGence、Zortrax、Raise3D、MakerGear、Fusion3
  • 粉末床(SLS): Sinterit
  • 結合材噴射: ExOne
  • 樹脂ベース(SLA、DLP): 新しいFormlabs材料。
11月 18, 2021
ジョブ-一度に複数の注文を管理する
GrabCAD Shopのオペレーターは、「ジョブ」を使用して、複数の注文または部品を一度にすばやく処理および追跡できるようになりました。これにより、個別の注文を使用する場合に比べて時間とクリック数を節約できます。
ジョブは、提出から完了まで同じルートをたどる類似の部品のコレクションです。つまり、使用可能なマシンまたは後処理ステップで同じ要求された技術、材料、トレイ/ベッドを共有します。開始するには、左側のナビゲーションの[ジョブ]をクリックし、[新しいジョブ]をクリックします。ここでは、ショップ内のすべてのアクティブな(ステータスが「完了」または「キャンセル済み」ではない)パーツを確認できます。次に、フィルタリングしてリストからパーツを選択し、ショップ内のマシンのジョブを作成できます。ジョブが作成されると、次のことができます
  • 個々のパーツのステータスをすべて簡単に「進行中」に更新できます。
  • パーツがさまざまなプロセスステップ(ジョブの作成、キューに入れる、印刷、後処理、完了)を通過するときに、パーツを移動/ドラッグします。
  • GrabCAD Printですべてのパーツを一緒に開きます(Stratasysマシンのジョブの場合)。
  • ジョブに名前を付けます(例:Friday F370 Tray)。
ジョブ内のすべてのパーツが完了するか、製造されるか、ピックアップの準備ができたら、ジョブに「完了」のマークを付けることができます。これにより、すべてのパーツステータスが「完了」に更新され、他のジョブに進むことができます。ジョブ機能の詳細は、こちらをご覧ください。
7月 7, 2021
個々の注文アイテムへの依存関係と添付ファイル
GrabCAD Shopリクエスターは、簡単にアセンブリ(アセンブリファイル+アセンブリコンポーネント)またはテクスチャファイル(STL、OBJ、VRMLファイル+画像/バンプテクスチャファイル)の注文を送信できるようになりました。注文のすべてのファイルと依存関係を個別のアイテムとしてアップロードする代わりに、リクエスターは、親CADファイル/アセンブリ(SLDASM、OBJなど)をアップロードして注文を送信するだけで開始できます。次に、注文を開き、各注文アイテムの[ファイルを添付]アイコンをクリックして、依存関係(SLDPRT、STL、PNGなど)を追加します。その後、オペレーターは、GrabCAD ShopからGrabCAD Printへのすべての依存関係を含む注文アイテムを開くことができます。
これにより、(依存関係のある)注文アイテムが少なくなり、注文がより効率的になります。依存関係は注文アイテムに関連付けられており、個別のアイテムとしては扱われません。オペレーターは、リクエスターと不必要なやりとりを行うことなく、すべての関連情報/依存関係の関連付けを使用して注文アイテムを作成できるため、メリットもあります。
5月 11, 2021
PolyJetシングル材料オプションが利用可能になりました
FDMと同様に、PolyJetマシンを使用するショップ管理者は、すでに利用可能だったマルチカラーオプションに加えて、Vero、Agilus、およびTangoのシングルカラーオプションを選択してショップリクエスターに公開できるようになりました。これらの単色/材料オプションは、GrabCAD ShopデータベースのすべてのPolyJetマシンタイプの[マシン]ページで構成でき、PolyJetの注文とユースケースがさらに柔軟に利用できます。
その後、リクエスターは注文を送信し、PolyJet材料を混合したくない場合は、使用可能な単一のプライマリーPolyJetカラーを指定することができます。 (たとえば、Vero PureWhiteでCADファイルを印刷)。
4月 25, 2021
パフォーマンスとセキュリティの向上
多くの注文、カスタム列、または注文ごとの多くのパーツ/アイテムがあるショップでは、ページの読み込み時間が大幅に改善されます。注文リストページの読み込み速度が10 x増加し、注文詳細ページが2 x増加しました。 Shopsホームページ、Machinesページ、Historyセクションのクエリもより効率的になりました。これらの変更はすべて、GrabCAD Shopユーザーがショップ、注文、および関連コンテンツをより迅速に管理およびアクセスできるように設計されています。
GrabCAD Shopの注文と関連するメタデータを安全に保つために、セキュリティの脆弱性を定期的に追跡、特定、修正しています。 GrabCAD Shopは最近、評判の高い機関によるセキュリティ侵入テストを受け、中/高優先度のすべての脆弱性に対処しました。
1月 31, 2021
注文の更新に関する履歴と電子メール通知
依頼者と割り当てられたオペレーターは、「履歴」セクションですべての変更の概要を順番に表示できるようになりました。これらの変更には次のものが含まれる場合があります
  • 注文の詳細、日付、見積もり、価格の変更
  • ステータスの変更
  • 注文アイテム/ファイルの追加または削除
  • オペレーターの割り当て
これらの変更が行われると、注文の依頼者と割り当てられたオペレーターにも電子メールで通知されます。ショップの他のユーザーは、特定の注文の[更新について通知する]チェックボックスをオンにすることで、注文を「監視」して通知を受けることを選択できます。
10月 12, 2020
2020秋の新着情報の概要
5月 2020の新着情報の概要以降、さらに多くの機能が追加されました。ここをクリックして、概要の動画をご覧ください。
10月 6, 2020
注文へのオペレータの割り当て
オペレータは、自分自身やショップ内の他のオペレータを注文に割り当てることができます。割り当てられたオペレータに通知が送信されると、そのオペレータは、特定の注文の履行や、依頼者とのやり取りを担当することになります。追跡ができるよう、タスクは「履歴」セクションにも記載されます。
すべての注文と担当オペレータ全体を確認できよう、タスクを割り当てられたオペレータを、「注文」ページでも閲覧することができます。閲覧を可能にするには、「環境設定」に「オペレータ」列を表示させてください。
9月 29, 2020
原価計算機
管理者は、GrabCAD Shopで機器と材料を設定しながら、機器の使用状況、減価償却費、人件費、材料費を追加できます。これらの数値は、注文を見積もる際や、モデルショップ運営の効果的なコスト分析に利用できます。
オペレータは注文を処理した後、注文に移動して材料と時間の見積もりを入力し、事前に構成された数値に基づいて、自動的に価格の結果を確認できます。「電卓」アイコンをクリックすると、料金とコストの詳細な内訳が表示されます。また、追加、マークアップ、値引き、コストの上書きが可能です。
8月 30, 2020
電子メールドメインを使用したユーザーの一括追加
電子メールを 1 つずつ追加するのではなく、組織の電子メール ドメイン (my_email_ID@ ドメイン) を持つすべてのユーザーに、同時に GrabCAD Shop アクセスを提供できるようになりました。GrabCAD Control で、[ユーザー] ページの [ユーザーを招待] タブに移動し、[ドメインで追加] を選択します。ユーザーの電子メール ドメインを入力し、必ずユーザー グループを割り当てて、ユーザーがログイン時にアクセスできるようにします。
セキュリティ上の理由から、Stratasys の担当者がドメイン リクエストをできるだけ早く確認します。承認されると、チーム メンバー全員が各々の電子メールで GrabCAD ショップにログインし、ショップにアクセスできるようになります。
7月 31, 2020
注文ステータスをカスタマイズする
リクエストのステータスについて効果的にやり取りできるよう、注文とパーツのステータスをショップごとに構成できるようになりました。ショップに移動し、「環境設定」をクリックすれば、組み込みステータスを表示または非表示にしたり、表示カラーを変更したり、ステータスを並び変えたり、新しいカスタムステータスを最大8個まで追加することが可能になります。管理者は、カスタムステータスがアクティブな注文を意味するか、非アクティブな注文を意味するかを構成することもできます。
注文ページの列の構成
関連データのみがショップ内のすべてのユーザーに表示されるようにするために、管理者はショップの「環境設定」セクションの注文ページで列を表示または非表示にすることができます。さらに、注文ページの使いやすさを向上させるために、以下の新しい列を追加することもできます。
  • 注文のプロジェクトコード
  • 注文のCADファイルの数
  • 注文で要求された技術
  • 注文でリクエストされた材料
6月 25, 2020
新規注文ページフィルタ
送信日、必要な日、または配達日で注文をフィルタリングできるようになりました。注文ページのステータスおよび技術フィルタに加え、結果のビューをエクスポートする前に、これらのフィルタを使用することができます。
6月 3, 2020
ショップの注文の検索
プロジェクト名、依頼者名、電子メールアドレス、またはプロジェクトコードを使用して、注文ページで特定の注文を検索できるようになりました。検索結果を取得したら、結果のビューをCSVファイルにエクスポートすることもできます。
折りたたみ可能なナビゲーションバー
小さい画面でも、GrabCAD Shopをより使いやすくするために、画面上部(会社名の横)にある小さな矢印を使用して、灰色のナビゲーションバーを折りたたむことができるようになりました。折りたたまれているときは、画面左にカーソルを合わせるとそれを表示できます。
6月 2, 2020
より多くのプリンタと技術が利用可能
以下のStratasys PolyJetプリンタが、ショップで使用可能な機器として追加されました:
  • StratasysJ750デジタル解剖学プリンター
  • Stratasys j55
  • Stratasysj720デンタル
  • ObjetおよびConnex 260/350/500プリンタの全ラインナップ
また、以下の技術に、いくつかの新機器のオプションと対応する材料を追加しました:
  • 材料押出 — Desktop Metal、Prusa、Dynamical 3D
  • 結合剤噴射 — Desktop Metal
  • 粉末床溶融結合法 — HP
  • FDM — Makerbot
さらに、より多くのメーカーと材料が、CNC技術に追加されました。そして、レーザー加工技術とこれに対応する一般的な材料も追加されました。
5月 22, 2020
四半期ごとの新着情報の概要
2020の1月のリリース以降、いくつかの新着情報が追加されました。ここをクリックして、概要の動画をご覧ください。
5月 20, 2020
注文ページのデフォルトビューが改善されました
デフォルトで「アクティブ」な注文のみを表示するよう、フィルタ処理されるようになりました。これにより、ページのローディング性能が向上し、注意を必要とする注文のみにオペレータが集中できるようになります。ステータスが「完了」および「キャンセル済み」の注文はアクティブでない注文と見なされ、フィルタを変更することで表示できます。
5月 19, 2020
ショップの注文に関するレポート
「注文」ページの現在のビューを.CSVファイルとしてダウンロードできるようになりました。別のレポートシステムを使用して注文を追跡する必要がある場合は、フィルタを使い、好みのビューを取得してから、「エクスポート」ボタンをクリックします。
5月 11, 2020
使いやすさとパフォーマンスが改善
オペレータの時間を節約するために、いくつかのマイナーチェンジが加えられました。注文ページでの並べ替えとフィルタの選択がセッション全体で維持されるようになり、ショップで注文合計のカウントを確認できるようになりました。 注文ページのロ―ティング性能も改善されました。
4月 22, 2020
GrabCAD Printの統合で作業を簡単に計画
注文ページから1つ以上の注文を選択し、上部の「P」ボタンをクリックすれば、それらの注文のファイルをGrabCAD Printですぐに開くことができます。もう、ファイルをダウンロードして手動で追加する必要はありません。ワンクリックでファイルをGrabCAD Printに取り込むことができます。これは、GrabCAD Printのバージョン 1.41のリリースとちょうど重なります。
3月 23, 2020
ショップとユーザーグループの作成の改善
管理者がショップを作成すると、2 つのユーザー グループ (リクエスターとオペレーター) が自動的に作成され、管理者は両方に追加されます。2 グループは GrabCAD Control で表示でき、管理者はショップを簡単にセットアップしてユーザーにアクセスを提供できます。
