GrabCAD Streamline Pro Updates
9월 17, 2024
Simplified printer addition in GrabCAD Analyze
GrabCAD Analyze users can now easily add all their Stratasys printers to Analyze with a few clicks using the new "Discover" button in the printers page. Printers that aren't discoverable can still be added by IP using the "Manually Add" button, which has been improved and simplified.
Go to the Analyze Agent Settings page and ensure that the Agent is connected. Then, go to the Printers page and click Discover, to see all the printers in your network. Select and add the printers that you want to show in Analyze. (A GrabCAD Print desktop or GrabCAD PrintSserver installation is required on the computer that has the Analyze Server installed). Once the printers are added, they can be renamed, edited as needed.
9월 17, 2024
Performance, stability and installer improvements to GrabCAD Analyze
Users with many printers (up to 50) can now use GrabCAD Analyze to collect data and generate dashboards and reports. The data collection, storage and aggregation has been simplified and improved in the Analyze Agent and Server to scale and work with more printers. However, the computational requirements of the server needs to increased to account for the increased influx of data from the machines. (Current requirements are for 10 printers).
With the latest installer, a number of improvements have been made to improve the installation success in different user environments. The Analyze Server will also be configured to automatically restart in the event of a Windows update or restart, to prevent any unexpected downtime.
8월 27, 2024
Print orientation selection of order items to obtain more revelant estimates
GrabCAD Shop requesters and operators can now select the desired orientation for an FDM or PolyJet order item to ensure it is printed accordingly. This feature allows for greater specification and control over order items, as well as the estimation and print results, reducing the back-and-forth communication between requesters and operators.
Once an order is submitted and GrabCAD Shop completes an automatic estimation of the items, users can view the orientation used by GrabCAD Shop to generate the estimation (usually the CAD orientation or the recommended orientation from GrabCAD Print, depending on the Shop's preferences). If users wish to specify a different orientation to capture design intent or enhance printability, they can select one of the seven available options. This orientation is then saved and preserved in the order, and if the item is added to a job, the selected orientation will be used. The order item's thumbnail will also be updated to reflect the currently selected orientation.
6월 28, 2024
Improvements to .cmb and .print files in GrabCAD Shop
GrabCAD Shop requesters and operators can now work directly with .cmb and .print files. This feature is available for advanced users who use GrabCAD Shop to submit their print requests but want to specify all the build parameters using project files in GrabCAD Print. When these files are uploaded to GrabCAD Shop, the desired machine, material estimates, time estimates, tray preview, and other high-level build estimates are extracted and displayed, allowing operators to understand exactly what is being requested.
Create a new order and upload project files from GrabCAD Print. After submitting the order, you can see a preview and all other details related to the order. Note that these files cannot be added to Jobs, as they are not intended to be combined with other parts, which could affect the requester's design intent.
6월 28, 2024
Automatically estimate, preview and generate printable trays from your Shop
In addition to automatic estimations for FDM and PolyJet requests in GrabCAD Shop, operators can use the Jobs feature to group similar parts and requests and have an tray generated automatically with estimates and a preview. This allows operators to reduce their backlog by quickly consolidating requests, grouping parts that can be printed together, and downloading valid printable trays for queuing purposes.
Go to Jobs and click "New Job" to see all the order items in your Shop that need to be printed. Filter these items by technology, machine, and material, and select the parts that you want to print together. Once the job is created, GrabCAD Shop will pack these parts and try to generate a tray that can be printed and downloaded (a .print file is generated, which can be opened in GrabCAD Print), along with a tray preview and estimation details. If any parts don't fit, they will be highlighted and can be removed from the job, and can be added in other jobs.
6월 3, 2024
Introducing GrabCAD Streamline Pro - new software suite to grow and scale your operations
GrabCAD Streamline Pro is a new paid software suite from Stratasys designed for users with FDM and PolyJet printers. It includes GrabCAD Shop and simplifies order management by allowing administrators and printer operators to create virtual model shops for managing 3D printing requests. Streamline Pro introduces new automation capabilities that save operators time by managing their backlog more efficiently. Each FDM and PolyJet request will be automatically estimated—powered by GrabCAD Print—with default machine parameters and optimal orientation, providing realistic material, time, and cost estimates. This eliminates the need to generate these estimates manually. Operators can then review, compare, append, and override the estimates as needed.
Streamline Pro also features a new cybersecurity device, Shield, which protects the printer from network vulnerabilities, provides IPv6 support, and acts as a firewall for the printer. Additionally, it includes role-based access control to restrict visibility to Stratasys printers and prevent unauthorized access.
Furthermore, Streamline Pro includes GrabCAD Analyze (Version 1.90), an advanced analytics, dashboard, and notification tool that operates on-premise. It offers out-of-the-box dashboards detailing and tracking printer and material utilization for FDM and PolyJet systems. Operators can also set up custom alerts for various printing events (e.g., print job at 95%, material level at 5%) to prevent unexpected issues or delays.
All these capabilities are accessible only with a valid GrabCAD Streamline Pro license. Learn more about Streamline Pro here.
5월 23, 2024
New Stratays printers and materials available
New Stratasys machines and materials are now available to be added to your Shop. These include :
  • PolyJet printers like the J55 Pro, J3 and J5 DentaJet, and new models of J850 printers (Prime FabriX, Prime TechStyle, Pro and Digital Anatomy),
  • FDM printers like the F190CR, F370CR, and F3300.
  • P3 technology Origin One Dental with Dental materials,
  • New PA12 and PP materials for the SAF technology H350,
  • New FDM HIPS, Kimya, VICTREX, Polycarbonate and Ultem materials and colors for the Fortus 450mc and Stratasys F900 printers,
상점에 장비를 추가하고 싶은데 여전히 사용할 수 없는 경우 알려주십시오!
4월 1, 2024
New password rules for increased security
Users who are creating GrabCAD accounts to use GrabCAD software (GrabCAD Print, Shop, Control) are now required to set their passwords conforming to our new rules : 8 character minimum, with numbers, lower case and upper case characters required. This enhancement will increase the security of user accounts and provide IT and security managers at Stratasys printer sites with greater confidence in the security and management of GrabCAD software.
Go to login.grabcad.com or select the user icon in GrabCAD Print to create an account or reset your password.
1월 11, 2024
Control access to Printers
Administrators at Stratasys printer sites can now control access to their printers in GrabCAD Control, to prevent unauthorized, untrained or accidental visibility and usage of Stratasys printers at their site. This allows them to prevent printer downtime and wasted material in cases where users intentionally or accidentally modify the printer queues, cancel a long running print job and more. This also allows administratros to hide printers that are running sensitive and secretive print jobs, and only grant access to trained operators.
Go to GrabCAD Control, add your printers and group them. Then you can assign selected users in your company to the printer groups to grant them access and revoke access for everyone else. If you do not have access to GrabCAD Control, you can request a company account by emailed shop@grabcad.com.
8월 20, 2023
Units and bounding box dimensions for order items
GrabCAD Shop requesters can now specify units for order items with unitless file formats (STL, OBJ, VRML and similar formats) and view the bounding box dimensions (length, width and depth) in the Shop's preferred display units. This will reduce the feedback loop with operators as they can easily understand the size of the requests, and ensure that these items are fabricated with the correct desired size. CAD files not in the unitless file format will have the CAD units and bounding box dimensions displayed in a read-only format.
Go to a Shop and click "New order" to upload your files. After a CAD file is uploaded, the units and bounding box dimensions will be visible next to the order item. Once the order is submitted, the operators can see the selected units and dimensions in each order item's details. If the units are changed after the order is submitted, it is noted in the history section of the order.
6월 20, 2023
Introducing GrabCAD Control
Administrators, managers and IT who manage Stratasys printers can now use GrabCAD Control, the Stratasys printer and user management solution. Previously called Admin Console (used to manage GrabCAD Shop invitations and roles), GrabCAD Control can only be used by selected users (Admins) in a company. They can login to their "company account" in GrabCAD Control, and they can
  • Invite users to their company,
  • Add other admins,
  • Connect their GrabCAD Print Server and manage their Stratasys printers,
  • View and assign GrabCAD software licenses to your users,
  • Create user and printer groups,
  • Control user access,
  • Assign user roles,
  • Manage Shops and more.
Learn more about GrabCAD Control here. Contact print@grabcad.com to request a "company account". Our customer support team will create a company account for you and make you an admin, after which you can login and perform the actions above.
3월 7, 2023
주문 페이지의 새로운 구성 가능한 열
이제 GrabCAD Shop 관리자는 주문 페이지에서 "총 부품 수"라는 선택적 열을 켤 수 있습니다. 이 기능을 통해 운영자는 각 주문을 열지 않고도 주문 규모를 효과적으로 측정할 수 있습니다.
"총 부품 수" 열은 주문에서 인쇄 가능한 고유 부품 수를 표시하는 "CAD 파일" 열과 달리 주문에서 인쇄 가능한 총 부품 수를 해당 수량과 함께 표시합니다. 이 새 열을 표시하거나 숨기려면 Shop으로 이동한 후 "기본 설정"을 클릭하세요.
12월 13, 2021
겨울 2021 업데이트 요약
마지막 업데이트 요약 이후로 더 많은 기능을 추가했습니다. 비디오 요약을 보려면 여기를 클릭하십시오.
12월 13, 2021
더 많은 프린터 및 기술 사용 가능
이제 새로운 모든 Stratasys 장비와 여러 타사 장비를 Shop에 추가할 수 있습니다.
Stratasys의 추가 기능은 다음과 같습니다.
  • J5 MediJet, J35 pro, J55 Prime과 같은 PolyJet 프린터
  • FDM F770,
  • P3 기술 Origin One,
  • SAF 기술 H350,
  • 레진 기반 RPS Neo 프린터
  • F123 프린터의 새로운 Stratasys ABS CF10 재료
다음 기술에 대한 새로운 장비 옵션 및 해당 재료:
  • 재료 압출: 3DGence, Zortrax, Raise3D, MakerGear, Fusion3
  • 파우더 베드(SLS): Sinterit
  • 바인더 분사: ExOne
  • 수지 기반(SLA, DLP): 새로운 Formlabs 재료
11월 18, 2021
작업 - 한 번에 여러 주문 관리
GrabCAD Shop 운영자는 이제 ‘작업’을 사용하여 여러 주문 또는 부품을 한 번에 신속하게 처리하고 추적할 수 있습니다. 개별 주문을 사용할 때에 비해 소요 시간과 클릭 횟수가 감소합니다.
작업은 제출에서 완료까지 동일한 경로를 따르는(즉, 사용 가능한 기계 또는 후처리 단계에서 동일한 요청 기술, 재료, 트레이/베드를 공유하는) 유사한 부품의 모음입니다. 작업을 시작하려면 왼쪽 탐색에서 ‘작업’을 클릭하고 ‘새 작업’을 클릭합니다. 여기서 상점의 모든 활성(상태가 ‘완료’ 또는 ‘취소됨’이 아닌) 부품을 볼 수 있습니다. 그런 다음 목록에서 부품을 필터링 및 선택하고 상점의 기계를 위한 작업을 생성할 수 있습니다. 작업이 생성되면 다음을 수행할 수 있습니다.
  • 모든 개별 부품 상태를 ‘진행 중’으로 쉽게 업데이트.
  • 다른 프로세스 단계(작업 생성, 대기 중, 인쇄, 후처리 중, 완료)를 거치는 부품을 이동/끌어다 놓기.
  • GrabCAD Print에서 모든 부품을 함께 열기(Stratasys 기계의 작업인 경우).
  • 작업 이름 지정(예: Friday F370 Tray).
작업의 모든 파트가 완료/제작/픽업 준비가 되면 작업을 "완료"로 표시할 수 있습니다. 또한 모든 파트 상태가 "완료"로 업데이트되어 다른 작업으로 이동할 수 있습니다. 여기에서 작업 기능에 대해 자세히 알아보세요.
7월 7, 2021
개별 주문 항목의 종속성 및 첨부 파일
이제 GrabCAD Shop 요청자는 어셈블리(어셈블리 파일 + 어셈블리 구성 요소) 또는 텍스처 파일(STL, OBJ, VRML 파일 + 이미지/범프 텍스처 파일) 주문을 쉽게 제출할 수 있습니다. 요청자는 주문의 모든 파일과 종속성을 개별 항목으로 업로드하는 대신 상위 CAD 파일/어셈블리(예: SLDASM, OBJ 등)만 업로드하고 주문을 제출하여 시작할 수 있습니다. 그런 다음 주문을 열고 각 주문 항목에서 ’파일 첨부’ 아이콘을 클릭하여 종속성을 추가할 수 있습니다(예: SLDPRT, STL, PNG). 그런 다음 운영자는 GrabCAD Shop의 주문 항목과 해당 주문 항목의 모든 종속성을 GrabCAD Print에서 열 수 있습니다.
이로 인해 이제 주문 항목(종속성 포함) 수가 더 적은 주문이 더 효율적입니다. 종속성은 주문 항목과 연결되며 개별 항목으로 처리되지 않습니다. 운영자가 요청자와 불필요하게 연락을 주고받을 필요 없이 관련 정보/종속성 연결이 모두 포함된 주문 항목을 제작할 수 있다는 이점도 있습니다.
5월 11, 2021
PolyJet 단일 재료 옵션 사용 가능
FDM과 유사하게 PolyJet 장비를 사용하는 상점 관리자는 이제 기존의 다중 색상 옵션 외에도 Vero, Agilus 및 Tango 단일 색상 옵션을 선택하고 상점 요청자에게 노출할 수 있습니다. 이러한 단일 색상/재료 옵션은 GrabCAD Shop 데이터베이스의 모든 PolyJet 장비 유형을 위한 장비 페이지에서 구성할 수 있으며, PolyJet 주문 및 사용 사례에 더 많은 유연성을 제공합니다.
요청자는 PolyJet 재료를 혼합하지 않으려는 경우 주문을 제출하고 사용 가능한 단일 기본 PolyJet 색상을 지정할 수 있습니다(예: Vero PureWhite에서 CAD 파일 인쇄).
4월 25, 2021
성능 및 보안 개선
주문이 많거나, 사용자 지정 열이 있거나 주문당 부품/아이템이 많은 상점의 페이지 로딩 시간이 크게 개선됩니다. 주문 목록 페이지 로드 속도는 10배 빨라졌으며, 주문 세부 정보 페이지 로드 속도는 2배 빨라졌습니다. 상점 홈페이지, 장비 페이지 및 기록 섹션 쿼리의 효율성도 개선되었습니다. 이러한 변경 사항은 모두 GrabCAD Shop 사용자가 상점, 주문 및 관련 콘텐츠를 더 빠르게 관리하고 액세스할 수 있도록 고안되었습니다.
GrabCAD Shop 주문 및 관련 메타데이터의 보안을 유지하기 위해 정기적으로 보안 취약성을 추적, 식별 및 수정합니다. GrabCAD Shop은 최근 유명 기관으로부터 보안 침투 테스트를 받았으며 우선 순위가 중간이거나 높은 취약점을 모두 해결했습니다.
1월 31, 2021
주문 업데이트에 대한 내역 및 이메일 알림
이제 요청자와 할당된 운영자는 "기록" 섹션에서 주문의 모든 변경 사항에 대한 요약을 볼 수 있습니다. 이러한 변경에는 다음이 포함될 수 있습니다.
  • 주문 세부 정보, 날짜, 견적 및 가격 변경
  • 상태 변경
  • 주문 품목/파일 추가 또는 제거
  • 운영자 할당
이러한 변경 사항이 있을 경우 주문 요청자 및 할당된 운영자에게도 이메일로 통보됩니다. 상점의 다른 사용자는 해당 주문의 "업데이트 정보 알림" 상자를 선택하여 주문을 '확인'하고 알림을 받을 수 있습니다.
10월 12, 2020
가을 2020 업데이트 요약
5월 2020의 업데이트 요약 이후 더 많은 기능을 추가했습니다. 비디오 요약을 보려면 여기를 클릭하십시오.
10월 6, 2020
주문에 운영자 할당
운영자는 이제 자신이나 상점의 다른 운영자를 주문에 할당할 수 있습니다. 그런 다음 할당된 운영자에게 알림이 전송되고 해당 주문을 이행하고 요청자와 향후 소통할 책임이 있습니다. 할당은 추적 목적으로 "내역" 섹션에도 기록됩니다.
할당된 운영자는 또한 "기본 설정"에 "운영자" 열을 표시하여 "주문" 페이지에서 볼 수 있으며, 모든 주문 및 운영자의 개요를 볼 수 있습니다.
9월 29, 2020
원가 계산기
이제 관리자는 GrabCAD Shop에서 장비 및 재료를 구성하는 동안 장비 사용, 감가 상각, 인건비 및 재료비를 추가할 수 있습니다. 그러면 이 요율은 주문 견적과 모델 상점 운영의 효과적인 비용 분석에 사용될 수 있습니다.
운영자는 요청을 처리한 후 주문으로 이동하여 재료 및 예상 시간을 입력하고 이전에 구성된 요율을 기준으로 자동 가격 결과를 볼 수 있습니다. "계산기" 아이콘을 클릭하면 요율 및 비용에 대한 상세 분석과 추가, 인상, 할인 및 비용 재정의 기능이 표시됩니다.
8월 30, 2020
이메일 도메인을 사용하여 대량으로 사용자 추가
이제 이메일을 한 번에 하나씩 추가하는 대신 조직의 이메일 도메인(my_email_ID@ domain)을 사용하는 모든 사용자에게 GrabCAD Shop 액세스 권한을 동시에 제공할 수 있습니다. GrabCAD Control에서 사용자 페이지의 "사용자 초대" 탭으로 이동하여 "도메인별 추가"를 선택합니다. 사용자의 이메일 도메인을 입력하고 사용자 그룹을 할당하여 사용자가 로그인할 때 액세스 권한을 제공하는 것을 잊지 마세요.
보안상의 이유로 Stratasys 직원이 최대한 빨리 귀하의 도메인 요청을 검토할 것입니다. 승인되면 모든 팀원이 이메일을 사용해 GrabCAD Shop에 로그인하고 Shop에 액세스할 수 있습니다.
7월 31, 2020
주문 상태 사용자 지정
이제 주문 및 파트 상태는 상점별로 관리자가 구성하여 요청 상태를 효과적으로 전달할 수 있습니다. 상점으로 이동한 후 기본 설정을 클릭하여 내장 상태를 표시하거나 숨기고, 디스플레이 색상을 변경하고, 상태 순서를 변경하며, 최대 8개의 새로운 사용자 지정 상태를 추가할 수 있습니다. 관리자는 사용자 지정 상태가 활성 또는 비활성 주문인지 여부를 구성할 수도 있습니다.
주문 페이지에서 열 구성
상점의 모든 사용자가 관련 데이터만 볼 수 있도록 관리자는 이제 상점의 기본 설정 섹션에서 주문 페이지의 열을 표시하거나 숨길 수 있습니다. 또한 주문 페이지의 유용성을 개선하기 위해 다음과 같은 새 열을 추가할 수 있습니다.
  • 주문 프로젝트 코드
  • 주문에 포함된 CAD 파일 수
  • 주문에서 요청된 기술
  • 주문에서 요청된 재료
6월 25, 2020
새로운 주문 페이지 필터
이제 제출, 필요 기준 또는 배송 날짜별로 주문을 필터링할 수 있습니다. 이러한 필터는 결과 보기를 내보내기 전에 주문 페이지의 상태 및 기술 필터와 함께 적용할 수 있습니다.
6월 3, 2020
쇼핑 주문 검색
이제 프로젝트 이름, 요청자 이름, 이메일 주소 또는 프로젝트 코드를 사용하여 주문 페이지에서 특정 주문을 검색할 수 있습니다. 검색 결과를 얻은 후에는 결과 보기를 CSV 파일로 내보낼 수도 있습니다.
축소 가능한 탐색 모음
더 작은 화면에서 GrabCAD Shop의 유용성을 개선하기 위해 이제 화면 상단(회사 이름 옆)에 있는 작은 화살표를 사용하여 회색 탐색 모음을 축소할 수 있습니다. 축소된 경우 커서를 화면 왼쪽으로 이동하여 볼 수 있습니다.
6월 2, 2020
더 많은 프린터 및 기술 사용 가능
다음 Stratasys PolyJet 프린터가 상점에서 사용 가능한 장비로 추가되었습니다.
  • Stratasys J750 디지털 해부학 프린터
  • Stratasys j55
  • Stratasys J720 치과
  • Objet 및 Connex 260/350/500 프린터의 전체 라인업
또한 다음 기술에 몇 가지 새로운 장비 옵션과 해당 재료를 추가했습니다.
  • 재료 압출 — Desktop Metal, Prusa, Dynamical 3D
  • 바인더 분사 — Desktop Metal
  • 파우더 베드 퓨전 — HP
  • FDM — Makerbot
또한 더 많은 제조업체와 재료가 CNC 기술에 추가되었습니다. 마지막으로 레이저 가공 기술과 해당하는 일반 재료도 추가되었습니다.
5월 22, 2020
분기별 업데이트 요약
2020년 1월 출시 이후 몇 가지 업데이트가 추가되었습니다. 비디오 요약을 보려면 여기를 클릭하십시오.
5월 20, 2020
주문 페이지의 기본 보기 개선
주문 페이지는 이제 페이지의 로딩 성능을 개선하고 운영자가 주의가 필요한 주문에만 집중할 수 있도록 기본적으로 "활성" 주문 만 표시하도록 필터링되었습니다. 상태가 "완료됨"및 "취소됨"인 주문은 비활성 주문으로 간주되고 필터를 변경하여 표시할 수 있습니다.
5월 19, 2020
상점 주문 보고
이제 주문 페이지의 현재 보기를 .CSV 파일로 다운로드할 수 있습니다. 다른 보고 시스템을 사용하여 주문을 추적해야 하는 경우 필터를 적용하여 원하는 보기를 얻은 다음 내보내기 버튼을 누르십시오.
5월 11, 2020
유용성 및 성능 향상
운영자의 시간을 절약하기 위해 몇 가지 작은 변경 사항이 적용되었습니다. 주문 페이지의 정렬 및 필터 선택은 이제 세션 내내 유지되며 상점에서 총 주문 수를 볼 수 있습니다. 주문 페이지의 로딩 성능도 향상되었습니다.
4월 22, 2020
GrabCAD Print 통합을 사용하여 쉽게 작업 계획
주문 페이지에서 하나 이상의 주문을 선택하고 상단의 "P" 버튼을 클릭하여 GrabCAD Print에서 해당 주문의 파일을 즉시 여십시오. 더 이상 파일을 다운로드하고 수동으로 추가할 필요가 없으며 클릭 한 번으로 파일을 GrabCAD Print로 가져올 수 있습니다. 이는 GrabCAD Print 버전 1.41의 출시와 일치합니다.
3월 23, 2020
상점 및 사용자 그룹 생성 개선
관리자가 Shop을 생성하면 두 개의 사용자 그룹(요청자, 운영자)이 자동으로 생성되고 관리자가 두 그룹에 모두 추가됩니다. 이러한 그룹은 GrabCAD Control에서 볼 수 있으며 이를 통해 관리자는 Shop을 쉽게 설정하고 사용자에게 액세스 권한을 제공할 수 있습니다.
필요한 항목을 찾을 수 없습니까? 메시지 보내기 메시지 보내기
