GrabCAD Streamline Pro Updates
сентябрь 17, 2024
Simplified printer addition in GrabCAD Analyze
GrabCAD Analyze users can now easily add all their Stratasys printers to Analyze with a few clicks using the new "Discover" button in the printers page. Printers that aren't discoverable can still be added by IP using the "Manually Add" button, which has been improved and simplified.
Go to the Analyze Agent Settings page and ensure that the Agent is connected. Then, go to the Printers page and click Discover, to see all the printers in your network. Select and add the printers that you want to show in Analyze. (A GrabCAD Print desktop or GrabCAD PrintSserver installation is required on the computer that has the Analyze Server installed). Once the printers are added, they can be renamed, edited as needed.
сентябрь 17, 2024
Performance, stability and installer improvements to GrabCAD Analyze
Users with many printers (up to 50) can now use GrabCAD Analyze to collect data and generate dashboards and reports. The data collection, storage and aggregation has been simplified and improved in the Analyze Agent and Server to scale and work with more printers. However, the computational requirements of the server needs to increased to account for the increased influx of data from the machines. (Current requirements are for 10 printers).
With the latest installer, a number of improvements have been made to improve the installation success in different user environments. The Analyze Server will also be configured to automatically restart in the event of a Windows update or restart, to prevent any unexpected downtime.
август 27, 2024
Print orientation selection of order items to obtain more revelant estimates
GrabCAD Shop requesters and operators can now select the desired orientation for an FDM or PolyJet order item to ensure it is printed accordingly. This feature allows for greater specification and control over order items, as well as the estimation and print results, reducing the back-and-forth communication between requesters and operators.
Once an order is submitted and GrabCAD Shop completes an automatic estimation of the items, users can view the orientation used by GrabCAD Shop to generate the estimation (usually the CAD orientation or the recommended orientation from GrabCAD Print, depending on the Shop's preferences). If users wish to specify a different orientation to capture design intent or enhance printability, they can select one of the seven available options. This orientation is then saved and preserved in the order, and if the item is added to a job, the selected orientation will be used. The order item's thumbnail will also be updated to reflect the currently selected orientation.
июнь 28, 2024
Improvements to .cmb and .print files in GrabCAD Shop
GrabCAD Shop requesters and operators can now work directly with .cmb and .print files. This feature is available for advanced users who use GrabCAD Shop to submit their print requests but want to specify all the build parameters using project files in GrabCAD Print. When these files are uploaded to GrabCAD Shop, the desired machine, material estimates, time estimates, tray preview, and other high-level build estimates are extracted and displayed, allowing operators to understand exactly what is being requested.
Create a new order and upload project files from GrabCAD Print. After submitting the order, you can see a preview and all other details related to the order. Note that these files cannot be added to Jobs, as they are not intended to be combined with other parts, which could affect the requester's design intent.
июнь 28, 2024
Automatically estimate, preview and generate printable trays from your Shop
In addition to automatic estimations for FDM and PolyJet requests in GrabCAD Shop, operators can use the Jobs feature to group similar parts and requests and have an tray generated automatically with estimates and a preview. This allows operators to reduce their backlog by quickly consolidating requests, grouping parts that can be printed together, and downloading valid printable trays for queuing purposes.
Go to Jobs and click "New Job" to see all the order items in your Shop that need to be printed. Filter these items by technology, machine, and material, and select the parts that you want to print together. Once the job is created, GrabCAD Shop will pack these parts and try to generate a tray that can be printed and downloaded (a .print file is generated, which can be opened in GrabCAD Print), along with a tray preview and estimation details. If any parts don't fit, they will be highlighted and can be removed from the job, and can be added in other jobs.
июнь 3, 2024
Introducing GrabCAD Streamline Pro - new software suite to grow and scale your operations
GrabCAD Streamline Pro is a new paid software suite from Stratasys designed for users with FDM and PolyJet printers. It includes GrabCAD Shop and simplifies order management by allowing administrators and printer operators to create virtual model shops for managing 3D printing requests. Streamline Pro introduces new automation capabilities that save operators time by managing their backlog more efficiently. Each FDM and PolyJet request will be automatically estimated—powered by GrabCAD Print—with default machine parameters and optimal orientation, providing realistic material, time, and cost estimates. This eliminates the need to generate these estimates manually. Operators can then review, compare, append, and override the estimates as needed.
Streamline Pro also features a new cybersecurity device, Shield, which protects the printer from network vulnerabilities, provides IPv6 support, and acts as a firewall for the printer. Additionally, it includes role-based access control to restrict visibility to Stratasys printers and prevent unauthorized access.
Furthermore, Streamline Pro includes GrabCAD Analyze (Version 1.90), an advanced analytics, dashboard, and notification tool that operates on-premise. It offers out-of-the-box dashboards detailing and tracking printer and material utilization for FDM and PolyJet systems. Operators can also set up custom alerts for various printing events (e.g., print job at 95%, material level at 5%) to prevent unexpected issues or delays.
All these capabilities are accessible only with a valid GrabCAD Streamline Pro license. Learn more about Streamline Pro here.
май 23, 2024
New Stratays printers and materials available
New Stratasys machines and materials are now available to be added to your Shop. These include :
  • PolyJet printers like the J55 Pro, J3 and J5 DentaJet, and new models of J850 printers (Prime FabriX, Prime TechStyle, Pro and Digital Anatomy),
  • FDM printers like the F190CR, F370CR, and F3300.
  • P3 technology Origin One Dental with Dental materials,
  • New PA12 and PP materials for the SAF technology H350,
  • New FDM HIPS, Kimya, VICTREX, Polycarbonate and Ultem materials and colors for the Fortus 450mc and Stratasys F900 printers,
Если вы хотите добавить устройство в свой цех, а оно все еще недоступно, сообщите нам об этом!
апрель 1, 2024
New password rules for increased security
Users who are creating GrabCAD accounts to use GrabCAD software (GrabCAD Print, Shop, Control) are now required to set their passwords conforming to our new rules : 8 character minimum, with numbers, lower case and upper case characters required. This enhancement will increase the security of user accounts and provide IT and security managers at Stratasys printer sites with greater confidence in the security and management of GrabCAD software.
Go to login.grabcad.com or select the user icon in GrabCAD Print to create an account or reset your password.
январь 11, 2024
Control access to Printers
Administrators at Stratasys printer sites can now control access to their printers in GrabCAD Control, to prevent unauthorized, untrained or accidental visibility and usage of Stratasys printers at their site. This allows them to prevent printer downtime and wasted material in cases where users intentionally or accidentally modify the printer queues, cancel a long running print job and more. This also allows administratros to hide printers that are running sensitive and secretive print jobs, and only grant access to trained operators.
Go to GrabCAD Control, add your printers and group them. Then you can assign selected users in your company to the printer groups to grant them access and revoke access for everyone else. If you do not have access to GrabCAD Control, you can request a company account by emailed shop@grabcad.com.
август 20, 2023
Units and bounding box dimensions for order items
GrabCAD Shop requesters can now specify units for order items with unitless file formats (STL, OBJ, VRML and similar formats) and view the bounding box dimensions (length, width and depth) in the Shop's preferred display units. This will reduce the feedback loop with operators as they can easily understand the size of the requests, and ensure that these items are fabricated with the correct desired size. CAD files not in the unitless file format will have the CAD units and bounding box dimensions displayed in a read-only format.
Go to a Shop and click "New order" to upload your files. After a CAD file is uploaded, the units and bounding box dimensions will be visible next to the order item. Once the order is submitted, the operators can see the selected units and dimensions in each order item's details. If the units are changed after the order is submitted, it is noted in the history section of the order.
июнь 20, 2023
Introducing GrabCAD Control
Administrators, managers and IT who manage Stratasys printers can now use GrabCAD Control, the Stratasys printer and user management solution. Previously called Admin Console (used to manage GrabCAD Shop invitations and roles), GrabCAD Control can only be used by selected users (Admins) in a company. They can login to their "company account" in GrabCAD Control, and they can
  • Invite users to their company,
  • Add other admins,
  • Connect their GrabCAD Print Server and manage their Stratasys printers,
  • View and assign GrabCAD software licenses to your users,
  • Create user and printer groups,
  • Control user access,
  • Assign user roles,
  • Manage Shops and more.
Learn more about GrabCAD Control here. Contact print@grabcad.com to request a "company account". Our customer support team will create a company account for you and make you an admin, after which you can login and perform the actions above.
март 7, 2023
Новый настраиваемый столбец на странице заказов
Теперь администраторы GrabCAD Shop могут включить на странице заказов дополнительный столбец под названием «Всего деталей», что позволяет операторам эффективно оценивать размер заказов без необходимости открывать каждый заказ.
В столбце «Всего деталей» показано общее число доступных для печати деталей в заказе, а также их соответствующее количество, в отличие от столбца «Файлы САПР», в котором показано количество уникальных доступных для печати деталей в заказе. Перейдите в магазин и нажмите «Настройки», чтобы показать или скрыть этот новый столбец.
декабрь 13, 2021
Сводка зимнего обновления 2021
С момента последнего краткого описания обновлений добавлено еще больше функций. Нажмите здесь, чтобы просмотреть небольшой видеоролик с описанием.
декабрь 13, 2021
Доступно больше принтеров и технологий
Все новые машины Stratasys и многие машины сторонних производителей теперь можно добавить в ваш магазин.
Дополнения Stratasys включают в себя следующее:
  • Принтеры PolyJet, например, J5 MediJet, J35 pro, J55 Prime,
  • ФДМ Ф770,
  • Технология P3 Origin One,
  • Технология SAF для H350,
  • Принтеры RPS Neo на основе смолы.
  • Новый материал Stratasys ABS CF10 для принтеров F123.
Новые параметры машины и соответствующие материалы для следующих технологий:
  • Экструзия материалов: 3DGence, Zortrax, Raise3D, MakerGear и Fusion3
  • Спекание порошковых компонентов (SLS): Sinterit
  • Струйная печать связующим веществом: ExOne
  • На основе смолы (SLA, DLP): новые материалы Formlabs.
ноябрь 18, 2021
Задания — Одновременное управление несколькими заказами
Операторы GrabCAD Shop теперь могут быстро обрабатывать и отслеживать печать нескольких заказов или деталей одновременно с помощью функции «Задания». Теперь это быстрее и проще по сравнению с обработкой отдельных заказов.
Задание — это набор схожих деталей, обрабатываемых одним и тем же способом от их отправки на печать до завершения процесса, то есть изготавливаемых по одной и той же технологии, из одинаковых материалов, на одинаковых лотках/платформах используемой машины, или которые проходят одни и те же этапы постобработки. Сначала нажмите «Задания» на левой панели навигации, а затем нажмите «Новое задание». Здесь отображаются все Активные (статус не «Завершено» или «Отменено») детали в вашем центре печати. После этого можно применить фильтр, выбрать детали из списка и создать задание для машины в вашем центре печати. После создания задания можно
  • Легко обновляйте статусы всех отдельных деталей до «В работе».
  • Перемещайте/перетаскивайте детали, когда они находятся на различных этапах процесса (задание создано, поставлено в очередь, выполняется печать, постобработка, завершено).
  • Открывайте все детали одновременно в GrabCAD Print (задания для машины Stratasys).
  • Введите имя задания (например, Friday F370 Tray).
Задание может быть помечено как «Завершено», если все детали в нем завершены / изготовлены / готовы к выдаче. При этом все статусы деталей также обновятся до «Завершено», после чего можно выполнять другие задания. Подробнее о функции «Задания» см. здесь.
июль 7, 2021
Зависимости и приложения к отдельным позициям заказа
Заказчики GrabCAD Shop теперь могут легко отправлять заказы на сборку (файл сборки и компоненты сборки) или файлы текстуры (файлы STL, OBJ, VRML и файлы изображений / рельефного текстурирования). Вместо загрузки всех файлов и зависимостей заказа в виде отдельных элементов, заказчик может сначала загрузить только родительский файл САПР / сборки (например, SLDASM, OBJ и т. д.) и отправить заказ. Затем можно открыть заказ и щелкнуть по значку «Прикрепить файл» в каждом элементе заказа, чтобы добавить зависимости (например, SLDPRT, STL, PNG). После этого операторы могут открыть GrabCAD Print элемент заказа со всеми зависимостями из GrabCAD Shop.
В результате повышается эффективность работы с заказами при уменьшении числа элементов в заказе (с зависимостями). Зависимости связаны с элементами заказа и не рассматриваются как отдельные элементы. Это также упрощает работу операторов, так как они могут создавать элементы заказа со всеми необходимыми данными/зависимостями без излишних согласований с заказчиками.
май 11, 2021
Новая опция «Один материал» в PolyJet
Как и в случае с FDM, администраторы центров печати при работе с машинами PolyJet в дополнение к уже доступным возможностям многоцветной печати теперь могут выбирать и предлагать заказчикам центра печати опции одноцветной печати Vero, Agilus и Tango. Одноцветная печать / использование одного материала настраивается на странице «Машины» принтеров PolyJet всех типов из базы данных GrabCAD Shop. Эта функция повышает гибкость при выполнении заказов на оборудовании PolyJet и разнообразит доступные варианты.
После этого заказчики могут отправить заказы и указать отдельные доступные основные цвета PolyJet, если не требуется смешивать любые разные материалы PolyJet (например, печать файла САПР цветом Vero PureWhite).
апрель 25, 2021
Повышение производительности и уровня безопасности
Центры печати, выполняющие большое число заказов и/или работающие с заказами, которые содержат большое число столбцов данных или деталей/элементов, теперь смогут значительно быстрее загружать страницы. Скорость загрузки страницы со списком заказов сокращена в 10 раза, а количество страниц с подробной информацией о заказе увеличилось в 2 раза. Также повышено быстродействие главной страницы центра печати, страницы «Машины» и раздела «История действий». Все эти изменения нацелены на оптимизацию управления пользователями GrabCAD Shop работой центров печати, заказами и соответствующим контентом, и упрощение доступа к ним.
С целью обеспечения безопасности ваших заказов и соответствующих метаданных в GrabCAD Shop мы регулярно отслеживаем, выявляем и исправляем уязвимости. Недавно GrabCAD Shop был проверен специалистами одной из известных компаний на предмет возможности взлома системы безопасности, по результатам которой были устранены все уязвимости средней и высокой степени важности.
январь 31, 2021
История обновлений заказов и уведомления о них по электронной почте
Заказчики и назначенные операторы теперь могут просматривать сводку всех изменений заказа в разделе «История». Эти изменения могут включать
  • Изменения в деталях заказа, датах, оценках и цене
  • Изменения статуса
  • Добавление или удаление элементов/файлов заказа
  • Назначение оператора
Заказчик и назначенный оператор заказа также будут уведомлены по электронной почте о внесении этих изменений. Другие пользователи в цехе могут выбрать «отслеживание» заказа и получать уведомления, установив флажок «Уведомлять меня об обновлениях» в этом конкретном заказе.
октябрь 12, 2020
Сводка осеннего обновления 2020
После обновлений, сводка которых приведена в май 2020, мы добавили еще больше функций. Щелкните здесь для просмотра видео с кратким обзором.
октябрь 6, 2020
Назначьте оператора для заказа
Операторы теперь могут назначать заказу себя или других операторов из цеха. Назначенный оператор получает уведомление и несет ответственность за выполнение этого заказа и дальнейшую коммуникацию с заказчиком. Назначение также отмечается в разделе «История» в целях его отслеживания.
Назначенных операторов также можно увидеть на странице «Заказы», сделав видимым столбец «Оператор» в «Настройках», чтобы получить обзор всех заказов и их операторов.
сентябрь 29, 2020
Калькулятор затрат
Теперь администраторы могут добавлять эксплуатацию оборудования, амортизацию, затраты на рабочую силу и материалы при настройке машин и материалов в GrabCAD Shop. Эти величины затем можно использовать при назначении цены заказа и для эффективного анализа операционных расходов модельного цеха.
Затем операторы могут перейти к заказу, ввести оценки материалов и времени после обработки запроса и увидеть результат автоматического расчета цены на основе ранее настроенных величин. При нажатии на значок «Калькулятор» отображается подробная разбивка величин затрат и расходов, с возможностью добавить еще, добавить наценку или скидку, либо переопределить затраты.
август 30, 2020
Массовое добавление пользователей с использованием домена электронной почты
Теперь вы можете предоставить доступ к GrabCAD Shop одновременно всем пользователям с помощью домена электронной почты вашей организации (my_email_ID@) домен), вместо того чтобы добавлять адреса электронной почты по одному. В GrabCAD Control перейдите на вкладку «Пригласить пользователей» на странице «Пользователи» и выберите «Добавить по домену». Введите домен электронной почты ваших пользователей и не забудьте назначить группы пользователей, чтобы предоставить этим пользователям доступ при входе в систему.
Из соображений безопасности сотрудник Stratasys в ближайшее время рассмотрит ваш запрос на домен. После одобрения все члены вашей команды смогут войти в GrabCAD Shop с помощью своей электронной почты и получить доступ к вашим магазинам.
июль 31, 2020
Настройте статусы вашего заказа
Администраторы теперь могут настраивать статусы заказов и деталей для каждого цеха, чтобы эффективно передавать статус запросов. Перейдите к цеху и нажмите «Настройки», чтобы показать или скрыть встроенные статусы, изменить цвета отображения, изменить порядок статусов и добавить до 8 новых настраиваемых статусов. Администраторы также могут указывать, представляет ли настраиваемый статус активный или неактивный заказ.
Настройте столбцы на странице заказов
Чтобы все пользователи Shop могли видеть только актуальные данные, администраторы теперь могут отображать или скрывать столбцы на странице заказов в разделе «Настройки» цеха. Кроме того, для повышения удобства использования страницы заказов можно добавить следующие новые столбцы:
  • Код проекта заказа
  • Количество файлов САПР в заказе
  • Технологии, запрошенные в заказе
  • Материалы, запрошенные в заказе
июнь 25, 2020
Фильтры страницы новых заказов
Теперь вы можете фильтровать свои заказы по датам отправки, доставки или датам сроков доставки. Эти фильтры можно применять в дополнение к фильтрам статуса и технологии на странице заказов пе��ед экспортом полученного представления.
июнь 3, 2020
Поиск заказов Shop
Теперь на странице заказов можно искать конкретные заказы, используя имя проекта, имя заказчика, адрес электронной почты или код проекта. После получения результатов поиска полученное представление также можно экспортировать в файл CSV.
Сворачиваемая панель навигации
Чтобы повысить удобство использования GrabCAD Shop на небольших экранах, теперь можно свернуть серую панель навигации, используя маленькую стрелку в верхней части экрана (рядом с названием компании). Когда она свернута, ее можно просмотреть, переместив курсор в левую часть экрана.
июнь 2, 2020
Следующие принтеры Stratasys PolyJet были добавлены в качестве доступных в Shop:
  • Цифровой анатомический принтер Stratasys J750
  • Stratasys j55
  • Стоматологический принтер Stratasys J720
  • Полная линейка принтеров Objet и Connex 260/350/500
Мы также добавили несколько новых вариантов оборудования и соответствующие материалы для следующих технологий:
  • Экструзия материалов — Desktop Metal, Prusa, Dynamical 3 D
  • Струйная печать связующим веществом — Desktop Metal
  • Спекание или плавление порошков — HP
  • Послойное наплавление — Makerbot
Кроме того, добавлено больше производителей и материалов для технологии ЧПУ. Наконец, были добавлены технология лазерной обработки и соответствующие типовые материалы.
май 22, 2020
Ежеквартальная сводка обновлений
С момента запуска в январе 2020 мы добавили несколько обновлений. Нажмите здесь для просмотра видеосводки.
май 20, 2020
Улучшенный вид по умолчанию для страницы заказов
Страница заказов теперь фильтруется, чтобы по умолчанию отображались только «Активные» заказы. Это улучшает скорость загрузки страницы и помогает операторам сосредоточиться только на заказах, требующих внимания. Заказы со статусами «Выполнен» и «Отменен» считаются «Неактивными». Их можно отобразить путем изменения фильтра.
май 19, 2020
Отчетность по заказам цеха
Теперь текущий вид страницы «Заказы» можно загрузить в виде файла .CSV. Если нужно использовать другую систему отчетности для отслеживания заказов, примените фильтры, чтобы получить желаемое представление, и нажмите кнопку «Экспорт».
май 11, 2020
Улучшения удобства использования и производительности
Чтобы сэкономить время операторам, было внесено несколько небольших изменений. Сортировка и выбор фильтров на странице заказа теперь сохраняются на протяжении всего сеанса, и теперь вы можете видеть общее количество заказов в Shop. Также была улучшена скорость загрузки страницы заказов.
апрель 22, 2020
Простое планирование заданий с помощью интеграции GrabCAD Print
На странице «Заказы» выберите один или несколько заказов и нажмите кнопку «P» наверху, чтобы немедленно открыть файлы из этих заказов в GrabCAD Print. Больше не нужно загружать файлы и добавлять их вручную, файлы отправляются в GrabCAD Print одним щелчком мыши. Это совпадает с выпуском версии 1.41 GrabCAD Print.
март 23, 2020
Улучшено создание цехов и групп пользователей
Когда администратор создает магазин, автоматически создаются две группы пользователей (Заказчики и Операторы), и администратор добавляется в обе. Эти группы можно просмотреть в GrabCAD Control, они позволяют администратору легко настраивать магазин и предоставлять доступ своим пользователям.
Не удается найти то, что нужно? отправьте нам сообщение отправьте нам сообщение
