GrabCAD Print Pro
GrabCAD Print Pro 是一个包含多种新功能和工具的安装包,它扩展了 GrabCAD Print Standard 的功能,并专注于提高准确性和节省时间。
Print Pro 不是一个独立于 Print Standard 的单独应用程序或安装程序。当满足以下要求时,Print Standard 便成为 Print Pro,解锁专业功能。
GrabCAD Print Pro 的要求
- Print Pro 许可证必须通过您的 GrabCAD Control 公司帐户分配给您。请参见下方的许可部分。
- 您的 GrabCAD Print 版本必须是 1.78 或更高版本,如“帮助”>“关于”中所示。
- 您必须登录 GrabCAD Print(而不是在离线模式下)才能连接到持有许可证的公司帐户。单击左下角的头像,可以看到您的登录电子邮件和所选公司。
- You must select an FDM, PolyJet, SAF, or Neo printer to see Pro features, as there are no Pro features for Origin printers at this time.
所有支持技术的 Pro 功能
目前,GrabCAD Print Pro 支持三种技术:FDM、PolyJet 和 SAF。如果您拥有有效的 Pro 许可证,则可以使用这些技术的以下功能:
Thickness Analysis — Quickly ascertain if your part contains geometry which is below the resolution of your printer. The resolution is set by default based on printer technology, but you may set your own value. The display can be binary red fail / green pass or a continuous yellow-red gradient. The cursor also provides a ‘probe’ to show the specific value at any point over the part.
*请参阅下面的部分,以获取更详细的说明。
- Labels — This feature was first introduced for SAF printing and is now available for FDM and PolyJet with Print Pro. You can add custom text to be embossed or debossed on the surface of your model. You can also create label templates to programmatically add text such as an index number or file name. Read more about labels here.
- Split model with registrations — A tool panel on the right side allows you to split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
- Export models — Any selection of parts or bodies can be exported as an STL or 3MF file from the right-click menu. Exported models will contain any fixes made in Analysis Mode, as well as any labels applied. Note that materials and colors assigned on a PolyJet printer are currently not exported.
- 组装模型 - Pro 用户可以将多个模型的任何选择组合变成一个组装模型。将模型排列到所需位置后,单击“组装”创建一个新的组装模型,它被当作一个单一的模型来用于支撑和工具路径生成。这使您可以实现比以前更紧密的排列,对于在环形或 C 形模型中嵌套较小的模型特别有用。注意:STL 文件只能与其他 STL 文件一起包含在组装模型中。
- Automatic mesh repair — An option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
- 分解组件 - 您添加到项目中或用组装工具创建的任何组件模型都可以被分解成独立的模型。这与现有拆解功能的工作原理基本相同,但是当组件被分解后,模型名称将不再显示在项目面板的组件结构中。
- Automatic groups — A popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
- Separate settings for STL assemblies — When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
- Search filters for the model list — A search box and filter tool allow you to locate models or assembly components in your project.
- Sustainability estimations — Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
- 合作伙伴插件 - 我们的软件合作伙伴开发了一些极佳的新插件,只有 Pro 用户才能使用。
FDM 的 Pro 功能
- 精度中心 - 根据扫描结果创建翘曲调整模型 (WAM™),只需一步即可将零件精度提高 10 倍。单击此处了解更多信息。
- 制造模板 - 保存用于常见打印作业类型的打印设置,以加快工作流程并与您的团队保持同步。在您项目中的任意一个模型中,选择所需的打印机并应用所需的托盘、支撑和主体级别的模型设置,然后用“文件”>“导出为制造模板”创建一个新的制造模板。从模板打开的项目将禁用以下内容,显示其模板值:打印机类型、除切片样式外的所有托盘设置、所有模型设置、所有支撑设置。一个制造模板包括创建模板时托盘上的模型。这个模型包括在任何由模板创建的项目中,但是处于隐藏状态。虽然创建制造模板需要 Pro 许可证,但 Standard 和 Pro 用户都可以利用制造模板来创建新的打印项目。
- 按零件预估(带有成本计算)– 对于 Pro,预估结果弹出窗口经过改进,并包括名为“构建报告”的新部分。该部分显示托盘中每个独特模型的时间和材料使用情况。除了“托盘摘要”和“构建报告”选项卡外,还有一个选项卡允许您配置成本计算工具,该工具可根据估算结果计算打印成本。当模型在同一方向重复时,数量字段会更新,并且预估值反映所有重复模型的总和。“构建报告”和“托盘摘要”可以分别复制到剪贴板,或导出到 CSV 或 XLSX 文件。
- 3D 阵列 - 该功能最初是为 SAF 打印引入的,现在可用于 FDM with Print Pro。如果您要尽可能打印模型的多个副本,请使用 3D 阵列工具来创建副本的网格,既要在托盘上也要垂直堆叠。每个方向的副本之间的间距可以单独设置。在创建阵列时,构建体积内的副本显示为绿色,而跨越或在构建体积外的副本为黄色。
PolyJet 的 Pro 功能
- Print directly on tray — Allows printing onto materials such as glass or carbon fiber, creating a perfect surface finish on the underside of the part(s) and eliminating the need for post-processing on the underside.
- 空气即材料(仅限 J7/8 系列)– 可允许使用空气代替树脂,从而显著减轻零件重量,可节省高达 30% 的材料。
- Smart Insert™ — Allows for the embedding of various functional/decorative elements directly into the print.
- Print-on-Object — Allows model customization and personalization with direct-to-object printing onto a wide variety of substrates.
- 体素打印应用程序(仅限 J7/8 系列)– 用于打印由其他软件定义的切片数据的工具,可允许控制模型的每个细节,包括体素级别的颜色、透明度和邵氏硬度。
- Support-as-Material — Allows creating textured finishes on your designs by printing a dual glossy and matte surface.
- 液体即材料(仅限 J7/8 系列)– 可允许创建空腔,例如微流体结构、空心管、液压零件等。
- 高速模式(仅限 J55)– 使用 2 材料时,保持相同的图层厚度,但以两倍的速度运行。
SAF 的 Pro 功能
- 保存和打印 SAF 内容 - 要执行以下任务,需要拥有 GrabCAD Print Pro 许可证:
- 打印 SAF 作业
- 导出 SAFB 文件
- 在选择 SAF 打印机的情况下保存项目
许可
GrabCAD Print Pro 许可证现在可以通过您的 Stratasys 增值经销商或通过 Stratasys 客户中心购买。您可以单击此处了解定价和包装细节。
可通过此表按要求提供免费试用。
获批后,试用许可证将添加到您的 GrabCAD Control 公司帐户。如果您还没有 Control 公司帐户,我们将为您创建一个帐户。
普通和教育许可证是按用户发放,因此您公司帐户的管理员必须创建一个用户组,将 Pro 许可证分配给此用户组,然后将用户添加到这个组,以便分配 Pro 功能的访问权限。有关此流程的更详细描述,请参见此处:开始使用 GrabCAD Control
试用和企业许可证在全公司范围内适用,因此公司管理员没有必要创建或分配用户组。当公司的所有成员登录并在 GrabCAD Print 中选择该公司时,他们将获得 Pro 功能的使用权限。
用户必须登录 GrabCAD Print 并连接其公司帐户,才能使用许可证,但对于未联网的客户,也有替代方法。请联系您的 Stratasys 销售代表,了解更多详细信息。
厚度分析的其他详细信息
厚度分析的阈值直接与刀具路径宽度以及切片高度相关,FDM 材料的默认最小厚度规则是切片高度的四倍。以 ABS-M30 为例,切片高度为 0.2540 毫米( 0.0100 英寸),默认最小厚度为 1.0016 毫米( 0.0400 英寸)。
该规则的例外情况如下:
Stratasys F900、Fortus 450mc 和 900mc 打印机
对于 0.1270 毫米( 0.0050 英寸)切片高度,厚度阈值为 0.6096 毫米( 0.0240 英寸)。
F123 系列
阈值因材料和切片高度而异,如下定义。
材料 | 切片高度 | 最小厚度 |
绝对值 | 0.0050 英寸(0.1270 毫米) | 0.0280 英寸(0.7112 毫米) |
作为一个 | 0.1270 毫米(0.0050 英寸) 0.1778 毫米(0.0070 英寸) 0.3302 毫米(0.0130 英寸) |
0.7112 毫米(0.0280 英寸) 1.0160 毫米(0.0400 英寸) 1.1176 毫米(0.0440 英寸) |
ABS CF10 | 0.0070 英寸(0.1778 毫米) | 0.0320 英寸(0.8128 毫米) |
迪兰410MF07 | 0.0070 英寸(0.1778 毫米) | 0.0400 英寸(1.0160 毫米) |
带 QSR 支持的 Nylon CF10 | 0.0070 英寸(0.1778 毫米) | 0.0400 英寸(1.0160 毫米) |
带 SUP4000B 支持的 Nylon CF10 | 0.1778 毫米(0.0070 英寸) 0.2540 毫米(0.0100 英寸) 0.3302 毫米(0.0130 英寸) |
1.2700 毫米(0.0500 英寸) 1.2700 毫米(0.0500 英寸) 1.3208 毫米(0.0520 英寸) |
热塑性聚氨酯92A | 0.1778 毫米(0.0070 英寸) 0.2540 毫米(0.0100 英寸) |
0.8128 毫米(0.0320 英寸) 0.8128 毫米(0.0320 英寸) |
解放军 | 0.1778 毫米(0.0070 英寸) 0.2540 毫米(0.0100 英寸) |
0.7620 毫米(0.0300 英寸) 0.9144 毫米(0.0360 英寸) |
