GrabCAD Print Pro
GrabCAD Print Pro 是一套新功能和工具組合,可擴充 GrabCAD Print Standard 的功能,並專注於提高準確度和節省成本。
Print Pro 不是有別於 Print Standard 的應用程式或安裝程式。當滿足以下要求時,Print Standard 會變成Print Pro,Pro 版功能便會開放使用。
GrabCAD Print Pro 的要求
  • 必須透過 GrabCAD Control 公司帳戶將 Print Pro 授權指派給您。請參閱以下的授權部分。
  • 如「說明」>「關於」中所示,GrabCAD Print 版本必須是 1.78 或更新版本。
  • 您必須登入 GrabCAD Print(而非使用離線模式),才能連接到擁有授權的公司帳戶。按一下左下角的頭像即可查看登入電子郵件和所選公司。
  • You must select an FDM, PolyJet, SAF, or Neo printer to see Pro features, as there are no Pro features for Origin printers at this time.
所有支援技術適用的 Pro 功能
目前,GrabCAD Print Pro 支援三種技術:FDM、PolyJet 和 SAF。當您擁有啟用中 Pro 授權時,以下功能適用於這些技術:
  • Thickness Analysis — Quickly ascertain if your part contains geometry which is below the resolution of your printer. The resolution is set by default based on printer technology, but you may set your own value. The display can be binary red fail / green pass or a continuous yellow-red gradient. The cursor also provides a ‘probe’ to show the specific value at any point over the part.
    *請參閱下面的部分以取得更詳細的說明。
  • Labels — This feature was first introduced for SAF printing and is now available for FDM and PolyJet with Print Pro. You can add custom text to be embossed or debossed on the surface of your model. You can also create label templates to programmatically add text such as an index number or file name. Read more about labels here.
  • Split model with registrations — A tool panel on the right side allows you to split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
  • Export models — Any selection of parts or bodies can be exported as an STL or 3MF file from the right-click menu. Exported models will contain any fixes made in Analysis Mode, as well as any labels applied. Note that materials and colors assigned on a PolyJet printer are currently not exported.
  • 組裝模型 — Pro 版使用者可以將多個模型的任意選項轉換為組件。將模型排列到想要的位置後,按一下「組裝」以建立新組件,該組件被視為用於支撐和刀具路徑產生的單一模型。您能夠因此實現比以前更緊密的排列,對於在環形或 C 形模型中巢套較小模型時特別有用。注意:STL 檔案只能包含在具有其他 STL 檔案的組件中。
  • Automatic mesh repair — An option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
  • 溶解組件 — 新增到專案或使用組件工具建立的任何組件模型都可以溶解為個別的模型。此功能與現有的拆解功能非常相似,但是當組件遭到溶解時,專案面板的組件結構中將不再顯示該模型名稱。
  • Automatic groups — A popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
  • Separate settings for STL assemblies — When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
  • Search filters for the model list — A search box and filter tool allow you to locate models or assembly components in your project.
  • Sustainability estimations — Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
  • 合作夥伴外掛程式 — 我們的軟體合作夥伴開發的一些新外掛程式功能令人驚嘆,但這些功能僅開放 Pro 版使用者使用。
    • AlphaSTAR 的軟體提供刀具路徑的品質評估,以預測氣隙和熱流程模擬。此軟體讓您能夠評估填充樣式、方向、輪廓和其他流程設定的效果,使您可以在開始構建之前做出明智的決定。在這裡瞭解更多。
    • CASTOR 的軟體可自動識別適合積層製造零件的流程,並突出顯示那些從技術、經濟、永續性、前置時間和供應鏈角度來看,構成良好商業案例的零件。在這裡瞭解更多。
    • 認知積層軟體透過認知設計系統產生儀表板,其中顯示成本明細、可列印性資訊以及所選零件針對特定機器和材料的積層適用性評估。在這裡瞭解更多。
FDM 的 Pro 版功能
  • 準確度中心 — 根據掃描結果建立翹曲已適應模型 (WAM™),以在單一步驟中將零件準確度提高 10 倍。在這裡瞭解更多
  • 製造範本 — 儲存常見列印作業類型的列印設定,以縮短工作流程並確保團隊的作業保持同步。對於專案中的任一模型,選取所需的印表機並使用所需的托盤、支撐和主體級模型設定,然後使用「檔案」>「匯出為製造範本」建立新的製造範本。從範本開啟的專案將停用以下功能,並顯示其範本值:印表機類型、除切片樣式外的所有托盤設定、所有模型設定、所有支撐設定。製造範本包括建立範本時托盤上的模型。在透過範本建立的任何專案中都包含此模型,但其遭到隱藏。儘管製造範本需要 Pro 版授權,但 Standard 版和 Pro 版使用者都可以使用製造範本來建立新的列印專案。
  • 按零件預估與成本 — Pro 版的預估結果快顯視窗已改善,並包含名為「構建報告」的新區段。本區段顯示托盤中每個獨特模型的時間和材料使用情況。除了托盤摘要與構建報告標籤外,另一個標籤也可讓您設定成本工具,該工具可根據預估結果計算列印成本。當模型以相同方向複製時,數量欄位會更新,並且預估值會反映所有副本的總和。構建報告和托盤摘要均可複製到剪貼板,或匯出為 CSV 或 XLSX 檔案。
  • 3D 陣列 — 最初是因為 SAF 列印而引進此功能,現在可透過 Print Pro 將此功能用於 FDM。如果您想要盡可能列印更多的模型副本,請使用 3D 陣列工具,以建立副本網格,既可以放在托盤上,也可以垂直堆疊。您可以為每個方向獨立設定副本的間距。建立陣列時,建構體積內的副本顯示為綠色,跨過或位於建構體積外的副本顯示為黃色。
PolyJet 的 Pro 版功能
  • Print directly on tray — Allows printing onto materials such as glass or carbon fiber, creating a perfect surface finish on the underside of the part(s) and eliminating the need for post-processing on the underside.
  • 空氣作為材料 (僅限 J7/8 系列) — 允許使用空氣代替樹脂,以顯著減輕零件的重量,進而省下多達 30% 的材料。
  • Smart Insert™ — Allows for the embedding of various functional/decorative elements directly into the print.
  • Print-on-Object — Allows model customization and personalization with direct-to-object printing onto a wide variety of substrates.
  • Voxel Print 應用程式 (僅限 J7/8 系列) — 用於列印由其他軟體定義的圖塊資料的工具,允許控制模型的每個細節,包括體素等級的顏色、透明度和邵氏硬度。
  • Support-as-Material — Allows creating textured finishes on your designs by printing a dual glossy and matte surface.
  • 液體作為材料 (僅限 J7/8 系列) — 允許建立中空空腔,例如微流控結構、中空管、液壓零件等。
  • 高速模式 (僅限 J55) — 保持相同的圖層厚度,但在使用 2 材料時以兩倍速度作業。
SAF 的 Pro 版功能
  • 儲存和列印 SAF 內容 — 需要 GrabCAD Print Pro 授權才能:
    • 列印 SAF 作業
    • 匯出 SAFB 檔案
    • 使用所選的 SAF 印表機儲存專案
授權
您現在可透過 Stratasys 增值經銷商或 Stratasys 客戶中心購買 GrabCAD Print Pro 授權。定價和包裝詳細資訊可在此處取得。
可填寫此表格申請免費試用。
獲得批准後,試用版授權將新增到 GrabCAD Control 公司帳戶中。如果您還沒有控制項公司帳戶,我們將為您進行建立。
一般版和教育版授權是按使用者計算,因此公司帳戶的管理員必須建立使用者群組,將 Pro 版授權指派給此群組,然後在其中新增使用者,以便分配這些使用者對 Pro 版功能的存取權限。此流程的更詳細描述請見以下:開始使用 GrabCAD Control
試用版和企業版授權是全公司適用,因此公司管理員無需建立或指派使用者群組。公司的所有成員在登入並在 GrabCAD Print 中選取該公司後就可以使用 Pro 版功能。
使用者必須登入 GrabCAD Print 並使用其公司帳戶連線才能使用授權,但無法存取網際網路的客戶可以使用因應措施。請聯絡您的 Stratasys 銷售代表以取得更多詳細資訊。
厚度分析的其他詳細資訊
厚度分析的臨界值直接與工具路徑寬度且通常與圖塊高度相關,FDM 材料的預設最小厚度規則是圖塊高度的四倍。以 ABS-M30為例,高度為 0.0100 英吋 (0.2540 公厘) 的圖塊預設最小厚度為 0.0400 英吋 (1.0016 公厘)。
此規則的例外情況如下:
Stratasys F900、Fortus 450mc 和 900mc 印表機
對於 0.0050 英吋 (0.1270公厘) 圖塊高度的厚度臨界值為 0.0240 英吋 (0.6096 公厘)。
F123 系列
臨界值因材料和圖塊高度而異,如下定義。
材料 切片高度 最小厚度
腹肌 0.0050 英吋 (0.1270 公厘) 0.0280 英吋 (0.7112 公厘)
作為一個 0.0050 英吋 (0.1270 公厘)
0.0070 英吋 (0.1778 公厘)
0.0130 英吋 (0.3302 公厘)
0.0400 英吋 (1.0160 公厘)
0.0440 英吋 (1.1176 公厘)
ABS CF10 0.0070 英吋 (0.1778 公厘) 0.0320 英吋 (0.8128 公厘)
迪蘭410MF07 0.0070 英吋 (0.1778 公厘) 0.0400 英吋 (1.0160 公厘)
具有 QSR 支撐的 Nylon CF10 0.0070 英吋 (0.1778 公厘) 0.0400 英吋 (1.0160 公厘)
具有 SUP4000B 支撐的 Nylon CF10 0.0070 英吋 (0.1778 公厘)
0.0500 英吋 (1.2700 公厘)
0.0520 英吋 (1.3208 公厘)
熱塑性聚氨酯92A 0.0070 英吋 (0.1778 公厘)
解放軍 0.0070 英吋 (0.1778 公厘)
0.0300 英吋 (0.7620 公厘)
0.0360 英吋 (0.9144 公厘)
找不到所需內容? 向我們傳送消息 向我們傳送消息
