设置 GrabCAD Analyze(续)– 配置
本文是安装指南的续篇。现在您已经启动了 Analyze 应用程序,您需要连接 Analyze Agent 和 Server 并添加打印机,以便应用程序开始为仪表板生成数据。
启动 Analyze 后,您将进入主页,其中您将看到 2 列:仪表板和提醒。提醒将在稍后设置。
应用程序中已内置许多仪表板。添加打印机后,您可以探索并使用与您最相关的仪表板。
Note: If you are unable to launch Analyze or see the screen above, there might an issue with the installation or your network settings, which is preventing the page from loading. Review the installation guide again or contact streamline@grabcad.com to resolve the issues.
配置 Analyze Agent 设置
对于此步骤,您将需要安装了 Analyze Agent 的计算机的 IP 地址。
  1. 单击下面显示的管理员图标。然后单击“Analyze Agent 设置”。
  1. Next, add your Analyze Agent IP address as shown below. Then enter the port (default is 5010).
  1. Once entered, the Analyze application should be able to communicate with the Agent, and you should see a green heart with a success message (this will take atleast 1 minute and a page refresh might be required). If Analyze cannot connect with the agent, a broken red heart will appear.
  2. 如果您没有 Analyze Agent IP 地址,请按照以下步骤操作:
    1. 在安装了代理的 Windows 计算机上打开命令提示符 (cmd)。
    2. 输入 ipconfig。
    3. 复制 IPV4 地址(以太网适配器或无线局域网 - 取决于计算机如何连接到网络)。
    4. 这是分析代理的 IP 地址。
您现在可以添加打印机了。
Add / Manage Printers
As the admin, you need to add your Stratasys printers to Analyze. You can manually add them or use the discover button to add them in bulk.
  1. Go to the Admin icon and go to Printers. This is where you will see all your Stratasys printers that have been added to GrabCAD Analyze. If this is your first time launching Analyze, this list will be empty.
  1. Click the ‘Discover’ button to view all the Stratasys printers in the network.
  2. Select the devices and click add.
  1. Once the printers have been added, you can rename and edit them.
If your printer is not discoverable, use the 'Manually Add' button to add your printer using its IP address.
  1. Enter the Printer's IP and click discover.
  2. The other fields should automatically populate once your printer is discovered.
    1. 确保输入所有必填字段并保存。
    2. Ensure that the technology is correct as well (FDM, POLYJET).
添加打印机后,其利用率数据将在约 30 分钟后开始填充 GrabCAD Analyze 中的仪表板。您可以返回任何仪表板并查看利用率数据。
分配班次时间(可选)
如果您希望查看一天内 2 个或更多时间段内的信息中心数据,班次会非常有用。这样您就可以比较班次(白天和晚上)。
单击“管理”按钮,然后单击“班次”。默认班次已添加。调整这些时间以符合您的日常流程。要添加新班次,请单击“+”按钮,添加所需的班次详细信息,然后保存。
计算机屏幕截图 自动生成的描述
添加/配置班次后,您可以看到每个班次的利用率,如下例所示。
注意:确保班次时间具有唯一性。也就是说,班次时间不得相互重叠。
验证打印机数据(可选)
转到“主页”屏幕,查看已配置的仪表板列表。
  1. Machine-360-FDM 和 Machine-360-POLYJET 仪表板显示实时 FDM 和 POLYJET 数据。您可以在屏幕左上角选择任何一个机器来开始。
  1. 打印机历史记录和材料使用情况与旧作业详细信息以及这些作业的材料使用情况相关。
  1. AML 管理器报告的每日、每周和每月仪表板结合了我们所有的利用率数据,为您提供了一个全面的操作概览。每个仪表板以不同的时间间隔收集数据。
提醒:配置贵组织的提醒电子邮件 SMTP 设置
提醒是 GrabCAD Analyze 的一个关键部分,用于在发生某些事件时通知您。您可以根据需要配置它。以下是一些示例:
  1. 当作业完成 95% 时通知我。
  2. 当打印机没有响应时通知我。
  3. 当材料含量达到 5% 时通知我。
但是,由于 Analyze 是在您的网络本地安装和托管的,因此您需要 IT 部门的协助来配置提醒电子邮件设置(SMTP 设置)。设置完成后,您将使用您组织的电子邮件服务器接收已在 Analyze 应用程序中配置的提醒通知。
在“管理员”页面中,单击“电子邮件设置”。
您需要从 IT 部门获取以下信息:
  1. SMTP 主机,
  2. SMTP 端口,
  3. SMTP 用户,
  4. SMTP 密码。
The User/Password can also be an API key pair depending on the SMTP server.
此信息不会与 Stratasys 或您组织以外的任何人共享。
配置提醒:在 Analyze 服务器中设置通知渠道。
配置 SMTP 设置后,您可以启用提醒。通知渠道是您希望在触发提醒时通知的一个或多个电子邮件地址。
单击左侧导航和通知渠道上的“提醒”。
默认的 JOB_STATUS_ALERT 及其通知渠道应该已经可用,当打印机上的打印作业状态发生变化时,它将通知您。
添加您的电子邮件地址或运营商的电子邮件地址,以便在触发此提醒时通知他们。您可以添加多个电子邮件地址。您可以单击“测试”以确保使用您的电子邮件设置通过电子邮件发送提醒。
您现在可以使用 Analyze 了。请记住,Analyze 服务器应始终保持运行状态,避免任何中断或计划外停机,以确保仪表板数据的连续性不受影响。
找不到所需内容? 向我们发送消息 向我们发送消息
