設定 GrabCAD Analyze (續) – 組態
本文是安裝指南的續篇。現在,您已經啟動 Analyze 應用程式,必須將 Analyze Agent 與 Server 連線並新增印表機,讓應用程式開始為儀表板產生資料。
啟動 Analyze 後,會將您帶往首頁,在此您將看到 2 欄:「儀表板」與「警示」。「警示」將於稍後設定。
應用程式中已內建許多儀表板。新增印表機後,您可以探索和使用與您最相關的儀表板。
Note: If you are unable to launch Analyze or see the screen above, there might an issue with the installation or your network settings, which is preventing the page from loading. Review the installation guide again or contact streamline@grabcad.com to resolve the issues.
設定 Analyze Agent
在此步驟中,您將需要安裝 Analyze Agent 所在電腦的 IP 位址。
  1. 按一下「管理員」圖示,如下所示。然後按一下「Analyze Agent 設定」。
  1. Next, add your Analyze Agent IP address as shown below. Then enter the port (default is 5010).
  1. Once entered, the Analyze application should be able to communicate with the Agent, and you should see a green heart with a success message (this will take atleast 1 minute and a page refresh might be required). If Analyze cannot connect with the agent, a broken red heart will appear.
  2. 如果您沒有 Analyze Agent IP 位址,請遵循以下步驟:
    1. 在安裝 Agent 的 Windows 電腦上開啟命令提示字元 (cmd)。
    2. 輸入 ipconfig。
    3. 複製 IPV4 位址 (乙太網路轉接器或無線 LAN – 取決於電腦連線到網路的方式)。
    4. 這是 Analyze Agent IP 位址。
現在,您已準備好新增印表機。
Add / Manage Printers
As the admin, you need to add your Stratasys printers to Analyze. You can manually add them or use the discover button to add them in bulk.
  1. Go to the Admin icon and go to Printers. This is where you will see all your Stratasys printers that have been added to GrabCAD Analyze. If this is your first time launching Analyze, this list will be empty.
  1. Click the ‘Discover’ button to view all the Stratasys printers in the network.
  2. Select the devices and click add.
  1. Once the printers have been added, you can rename and edit them.
If your printer is not discoverable, use the 'Manually Add' button to add your printer using its IP address.
  1. Enter the Printer's IP and click discover.
  2. The other fields should automatically populate once your printer is discovered.
    1. 確定所有必填欄位皆已輸入,然後儲存。
    2. Ensure that the technology is correct as well (FDM, POLYJET).
新增印表機後,其利用率資料將在約 30 分鐘內開始填入 GrabCAD Analyze 的儀表板中。您可以返回到任何儀表板並查看利用率資料。
指派班次時間 (選用)
如果您希望看到儀表板資料分割成一天內 2 個或以上的時段,則「班次」很有用。這允許您比較班次 (白天與晚上)。
按一下「管理員」按鈕,然後按一下「班次」。系統中已新增預設班次。請調整這些時間以符合您的日常流程。若要新增新班次,請按一下「+」按鈕,新增所需的班次詳細資訊,然後儲存。
自動產生的電腦描述螢幕截圖
新增/設定班次後,您可以看到每個班次的利用率,如下例所示。
注意:請確保班次時間是獨占的。這意味著,班次時間不得互相重疊。
驗證印表機資料 (選用)
移至首頁畫面,以檢視「已佈建儀表板」清單。
  1. 「機器-360-FDM 和機器-360-POLYJET」儀表板會顯示即時 FDM 和 POLYJET 資料。您可以在畫面左上角選擇任何個別機器以開始使用。
  1. 「印表機歷史」和「材料使用情況」與這些作業的舊作業詳細資訊和材料使用情況相關。
  1. AML 管理員的每日、每週和每月儀表板結合了我們所有的利用率資料,讓您能夠一覽您的經營情況。每個儀表板會以不同的時間間隔收集資料。
警示:為警示電子郵件設定您的組織 SMTP 設定
警示是 GrabCAD Analyze 的關鍵部分,可在發生某些事件時通知您。您可以根據需要進行設定。例如:
  1. 作業完成 95% 時通知我。
  2. 印表機沒有回應時通知我。
  3. 當材料存量為 5% 時通知我。
但是,由於 Analyze 是在您的網路中安裝與託管的,因此您將需要 IT 人員協助設定「警示」電子郵件設定 (SMTP 設定)。設定後,您將會收到已使用組織的電子郵件伺服器在 Analyze 應用程式中設定的警示其通知。
在「管理」頁面中,按一下「電子郵件設定」。
您需要從您的 IT 部門取得以下資訊:
  1. SMTP 主機、
  2. SMTP 連接埠、
  3. SMTP 使用者、
  4. SMTP 密碼。
The User/Password can also be an API key pair depending on the SMTP server.
此資訊不會分享給 Stratasys 或組織外部的任何人。
設定警示:在 Analyze 伺服器中設定通知管道。
設定 SMTP 設定後,可以啟用警示。通知管道是當觸發警示時,您想要通知的一個或多個電子郵件地址。
按一下左側導覽列上的「警示」和「通知」管道。
預設 JOB_STATUS_ALERT 及其通知管道應已可用,當印表機上的列印作業狀態變更時,該管道將通知您。
新增您的電子郵件地址或經營者的電子郵件地址,以便在觸發此警示時通知他們。您可以新增多個電子郵件地址。您可以按一下「測試」,以確定使用您的電子郵件設定透過電子郵件傳送警示。
現在,您可以使用 Analyze。請記住,Analyze 伺服器應一律執行,不會出現任何中斷或非計畫性停機,以確保儀表板資料不會中斷。
找不到所需內容? 向我們傳送消息 向我們傳送消息
