System Requirements for GrabCAD IoT Platform
The IoT Gateway must be installed on a computer which meets the following requirements:
Operating System
Windows 10 or newer
User Privileges
Windows administrative rights for installation
RAM
8GB minimum
CPU
Intel x64 with 4 or more cores, minimum 2.6 GHz
Disk Space
20GB available
Prerequisites AWS Coretto v21 OpenJDK for Windows x64 (download)
Network
  • Ethernet or wireless connectivity to Local Area Network
  • Static IP address
  • Internet connection
  • Ports:
    • MQTT (8883) for communication with the printer(s)
    • HTTPS (443) for communication with the cloud-based IoT backend on AWS with hostnames part of this subdomain iot.us-east-1.amazonaws.com
Availability To ensure uninterrupted data capture the IoT gateway is best run on a server computer that is available and running 24/7/365.
