System Requirements for GrabCAD IoT Platform
The IoT Gateway must be installed on a computer which meets the following requirements:
Sistema operativo |
Windows 10 o posterior |
Privilegios de usuario |
Derechos administrativos de Windows para la instalación |
RAM |
8GB minimum |
UPC |
Intel x64 con 4 o más núcleos, mínimo 2.6 GHz |
Espacio en disco |
20GB available |
Prerequisites | AWS Coretto v21 OpenJDK for Windows x64 (download) |
Red |
Availability | To ensure uninterrupted data capture the IoT gateway is best run on a server computer that is available and running 24/7/365. |
