System Requirements for GrabCAD IoT Platform
The IoT Gateway must be installed on a computer which meets the following requirements:
운영 체제
Windows 10 이상
사용자 권한
설치를 위한 Windows 관리 권한
램
8GB minimum
CPU
코어가 4개 이상인 Intel x64, 최소 2.6GHz
디스크 공간
20GB available
Prerequisites AWS Coretto v21 OpenJDK for Windows x64 (download)
네트워크
  • Ethernet or wireless connectivity to Local Area Network
  • Static IP address
  • Internet connection
  • Ports:
    • MQTT (8883) for communication with the printer(s)
    • HTTPS (443) for communication with the cloud-based IoT backend on AWS with hostnames part of this subdomain iot.us-east-1.amazonaws.com
Availability To ensure uninterrupted data capture the IoT gateway is best run on a server computer that is available and running 24/7/365.
필요한 항목을 찾을 수 없습니까? 메시지 보내기 메시지 보내기
