Offline printing and exporting jobs
Skip to:
Using GrabCAD Print with limited internet connectivity
When is an internet connection required? — An internet connection IS NOT REQUIRED to use GrabCAD Print for local printing.
How do I turn on Offline Mode as a new user? — When you launch for the first time after installing, the app checks if it can make a secure connection to our servers. If this check fails, due to lack of internet connection or a very restrictive firewall, you will be prompted to launch into Offline Mode:
You will not be prompted to log in unless you disable Offline Mode in File > System Preferences > Privacy.
What if I have an internet connection, but I need to prevent GrabCAD Print from connecting to it? — You can force the above message to appear if you temporarily disable the internet connection while launching the app for the first time.
What happens when I have logged in before, but I lose internet connectivity? — You can launch the app normally. A warning message will appear, but unless your selected printer is remote, your work will not be interrupted.
How to I use Offline Mode if I am logged in normally now? —  Go to File > System Preferences > Privacy.
What are the limitations of using GrabCAD Print without an internet connection? — See the table below:
Connected to a
company account
Offline Mode
Access locally connected printers
(send print jobs, read or modify queue)
Access remote printers through
GrabCAD Print Server
Automatic software updates
and "Check for Updates"
Shortcut to Help Center
Send a "Give Feedback" message
Give printers custom names
Preparing a job using a Printer Template
If you can't connect to the desired printer locally or using GrabCAD Print Server, you can add an "Offline Printer" which is a template of the printer type.
  1. Open the printer panel and click "Add a printer".
  2. Select "Add an Offline Printer" and then click on the printer manufacturer.
  3. Select a printer, and the tray will update to the appropriate size.
This printer will remain in your My Printers list. In order to remove this printer, right click and select "Forget this printer."
Exporting a print job file
The best way to transfer a print job from one computer to another is to save the GrabCAD Print Project, creating a .PRINT file. This contains all of the 3D models, as well as all of the print settings for all of the trays.
For FDM systems, you can also export a .CMB file. This works well for doing further modifications on the print in Insight, as well as manually adding the job to the printer queue via a USB drive.
  1. Arrange your tray and adjust material settings as desired.
  2. Go to Slice Preview and let it finish loading.
  3. While in Slice Preview, go to File > "Export as..." or press ctrl + shift + E.
This will save the CMB file in the directory you choose.
