Notas de la versión de GrabCAD Print
Versión de GrabCAD Print 1.98, enero 2025
Número de compilación 1.98.6.50666 liberado el 21 enero 2025
- Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
- Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
- Print Pro: The Assembly created while using the Split tool is now optional.
- An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
- For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
- The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
- When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
- Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
- The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
- If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
Versión de GrabCAD Print 1.97, diciembre 2024
Número de compilación 1.97.10.49657 liberado el 17 diciembre 2024
- Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
- Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
- Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
- Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
- Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
- F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
- For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
- The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
- ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
- Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
- RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
A new material profile has been added to the Validated O2 collections.
30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
- Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
- N3D-FR512 for FR-rating with higher elongation at break
- FL300 from Forward AM for low Shore hardness elastomers in a clear color
- MED414 for elastomeric applications requiring biocompatible capability such as ear bud
Versión de GrabCAD Print 1.96, noviembre 2024
Número de compilación 1.96.8.49045 liberado el 20 noviembre 2024
- Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
- Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
- Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
- Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
- GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
- The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
- Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
- PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
- ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
- For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
- Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
- A new material profile has been added to both the Validated O2 and Open AM collections for P3.
- New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
- The History report in GrabCAD Print now includes material consumption per-job for P3.
Versión de GrabCAD Print 1.95, octubre 2024
- Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
- A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
- A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
- A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
- Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
- The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
Versión de GrabCAD Print 1.94, septiembre 2024
- New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
- The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
- When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
- If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
- A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
- The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
- The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
- Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
- Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
- We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
- Advanced Color Assignment: designed to produce more accurate and consistent shades
- 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
- 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
- New TrueDent Clear Appliances: for fully translucent models and try-ins
- Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
- VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
- When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
Versión de GrabCAD Print 1.93, agosto 2024
- Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
- Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
- The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
- Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
- VeroContactClear is now treated as a transparent material for all transparency-related features.
- Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
- When WSS is the selected support material, "No Grid" becomes the only available support grid type.
- The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
- A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
- Additional dental applications for Origin printers are now supported.
Versión de GrabCAD Print 1.92, julio 2024
- Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
- Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
- Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
- Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
- Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
- Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
- A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
- Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
- The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
- For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
Versión de GrabCAD Print 1.91, junio 2024
- Print Pro: Una nueva acción, Exportar modelos como STL. Seleccione un solo ensamblado, pieza o cuerpo y expórtelo como un archivo STL desde el menú contextual. Los modelos exportados contendrán las correcciones realizadas en el Modo de análisis, así como las etiquetas aplicadas.
- Print Pro: las funciones de Print Pro Imprimir en bandeja, Imprimir en objeto e Inserto inteligente, que anteriormente solo estaban disponibles en las impresoras de las series J7/J8, ahora están disponibles en las impresoras de las series J3/J5.
- GrabCAD Print ahora admite la importación de formatos de archivo FBX (.fbx) y GLTF (.gltf, .glb).
- La opción de Impresión visual de fibra de carbono es una nueva altura del corte para ABS-CF10 que genera un acabado superficial más suave, perfecto para cuando la apariencia visual de una pieza es importante para su aplicación. La altura del corte (0.0050 pulgadas, 0.1270 mm) está disponible en impresoras de las series F123 y F123CR que utilizan un cabezal T14H (requiere la versión de firmware 2.7).
- OpenAM ahora es compatible con la impresora Stratasys F900. Los Paquetes de material se crean cuando los materiales se ajustan mediante OpenAM™, se compilan y distribuyen a GrabCAD Print y una impresora F900. Los Materiales preferidos y validados de Stratasys se pueden ajustar e incluir en paquetes, así como materiales abiertos de terceros (necesita la versión de firmware 4.23 de la impresora).
- VICTREX AM™ 200 se agrega a la cartera de Material validado para impresoras Fortus 450mc y Stratasys F900. VICTREX AM™ 200 es un polímero basado en PEEK de alta resistencia y propiedades mecánicas que es resistente a la temperatura, la corrosión y los productos químicos. VICTREX AM™ 200 es compatible con una altura de corte de 0.0100 pulgadas (0.2540 mm) usando una punta T14F, con soporte tanto de ruptura (SUP4000B) como soluble (soporte SR-100) (requiere la versión de firmware 6.9).
- Comportamiento de contracción del Nylon 12CF actualizado. Cuando el material de una bandeja es Nylon 12CF y la bandeja incluye modelos de relleno escaso y de relleno sólido, se utiliza la tasa de contracción en Z para el relleno sólido. Un mensaje informa al usuario del cambio. Cuando todos los modelos de la bandeja cambian a relleno sólido o relleno escaso, se utiliza la tasa de contracción en Z para el estilo de relleno seleccionado.
- GrabCAD Print admite direcciones IPv6 cuando se comunica con impresoras Stratasys serie F123, excepto la Stratasys F770 (necesita la versión de firmware 2.7).
- J5 DentaJet™ XL, con sus cartuchos de 4kg, es la última innovación en la línea de productos de la serie DentaJet. Esta impresora, diseñada para producción de gran volumen, satisface las exigencias de los fabricantes de alineadores y de modelos e implantes de coronas y puentes gracias a que ofrece una precisión incomparable. Es la solución definitiva para crear productos impecables a escala y, al mismo tiempo, proporciona una solución rentable que revoluciona los flujos de trabajo.
- La impresora J5 Digital Anatomy permite imprimir materiales únicos de Anatomía digital en la plataforma J5, incluidos TissueMatrix, BoneMatrix, GelMatrix y RadioMatrix. Se encuentra disponible con una amplia variedad de ajustes anatómicos preestablecidos para imprimir modelos anatómicos con un comportamiento biomecánico similar al de los tejidos humanos. Para obtener más información, haga clic aquí.
- Ahora, puede seleccionar el perfil de color de entrada para imprimir modelos a color en PolyJet. En Configuración de bandeja > Opciones avanzadas, elija entre sRGB (predeterminado) y el nuevo perfil Adobe RGB 1998. El perfil de Adobe proporciona colores más saturados (verdes/amarillos/rojos) y recomendamos utilizar un monitor muy saturado para hacerse una mejor idea de cuál será el resultado impreso.
- El estilo de la cuadrícula de soporte, que anteriormente estaba bloqueado para las impresoras Serie J3/5, ahora se puede modificar. Nota: permanecerá bloqueado si carga la impresora con materiales TrueDent.
- Para impresoras PolyJet aplicables, las siguientes operaciones ahora están disponibles en el panel Receta LED UV:
- Guardar cambios en una receta privada
- Guardar una receta (tanto SSYS como privada) como una nueva receta privada
- Cambiar de nombre una receta privada
- Eliminar una receta privada
- El polipropileno (PP) ahora se admite en la Configuración de anidado 3D para SAF.
- La validación ahora informa la distancia entre los objetos involucrados en colisiones suaves, lo que permite al usuario decidir si está bien seguir adelante e imprimir.
- Para impresión P3, ahora puede definir el material predeterminado y el perfil de soporte que se seleccionarán automáticamente al iniciar un nuevo proyecto.
- Para impresión P3, cuando modifica el soporte de un modelo específico, aparece un icono de advertencia junto al modelo en el panel del proyecto con la información sobre herramientas “Los parámetros de soporte del modelo difieren de los predeterminados de la bandeja”.
- Para impresión P3, cuando todos los modelos seleccionados tienen el mismo Perfil de soporte, es posible generar sus puntos de anclaje y/o estructuras de soporte automáticamente con un solo botón.
Versión de GrabCAD Print 1.90, mayo 2024
- Print Pro: una nueva acción, Separar, está disponible en el menú contextual cuando selecciona archivos STL en una bandeja. Separar convierte un archivo STL con múltiples armazones en un ensamblado con múltiples cuerpos. Luego se pueden aplicar las configuraciones del modelo a cada cuerpo. El modelo no cambia si solo se identifica un armazón.
- Print Pro: puede seleccionar la fuente Allerta Stencil para usar en etiquetas. Para elegir esta fuente, expanda el menú desplegable Etiquetas y seleccione Allerta Stencil. La fuente Atkinson Hyperlegible sigue siendo la fuente predeterminada.
- Print Pro: el atributo del modelo Nombre del ensamblado ahora se puede incluir en Plantillas de etiquetas. El nombre del ensamblado tiene los mismos modificadores que el nombre de la pieza (desde Inicio/final, Omitir y Longitud). Cuando no hay una estructura de ensamblado, el comportamiento del Nombre del ensamblado y del Nombre de la pieza es el mismo.
- Print Pro: Soporte como material, una configuración de PolyJet que le permite crear acabados texturizados en sus diseños al imprimir una superficie doble brillante y mate, se ha puesto a disposición de todas las impresoras de la serie J.
- Se agregaron nuevas vistas a la barra de herramientas Ver. Además del modo estándar, que muestra los modelos sombreados, las nuevas opciones son el modo Wireframe y el modo Wireframe sombreado, que muestran los modelos como una malla de estructura alámbrica transparente o sombreada, respectivamente. Las nuevas vistas no son compatibles con Vista previa de superficies compatibles.
- Se agrega a GrabCAD Labs una opción para imprimir en FDM sin estructuras de soporte. Después de activar la función (Archivo > Preferencias > GrabCAD Labs), encontrará “Sin soporte” como opción de Estilo de soporte en el panel Configuración de soporte. El modelo se imprimirá con una base pero sin otras estructuras de soporte.
- Se resolvió un problema por el cual un modelo no se podía reorientar cuando había una torre de sacrificios de altura completa.
- Para impresión SAF, ahora puede elegir un subanidado para crear un anidado en una región definida del paquete con control de la dimensión de tamaño X, Y, Z y la posición X, Y, Z del origen de la región especificada desde cualquier esquina elegida del paquete
- El tamaño de texto más pequeño para las etiquetas SAF se ha reducido a 10 pt.
- Para impresión P3, los puntos de anclaje que se agregaron o movieron manualmente se presentarán con un color distinto al de los puntos de anclaje generados automáticamente.
Versión de GrabCAD Print 1.89, abril 2024
Obtenga cotizaciones y solicite piezas de Stratasys Direct en GrabCAD Print en el nuevo modo Piezas bajo demanda. Disponible para una variedad de materiales FDM y con envíos a EE. UU.
Para impresión FDM, se resolvió el problema de que el cuadro delimitador generado para un modelo con estabilizadores era más grande de lo necesario, lo que causaba que infringiera el volumen de construcción.
- Nueva capacidad para moda: Imprimir en la prenda. La interfaz simplificada incluye compatibilidad con el nuevo e innovador kit para Bandejas Direct to Garment, que permite a los diseñadores incorporar complejos elementos 3D directamente en prendas terminadas.
- Un nuevo botón en el panel de anidado de H350 llamado Relleno seleccionado le permite colocar tantos duplicados de una sola pieza como quepan en el paquete.
- Para impresión P3, ahora puede generar puntos de anclaje y/o soporte para múltiples modelos en una sola operación una vez que todos los modelos compartan el mismo perfil de soporte.
- Para impresión P3, ciertos materiales (principalmente elastómeros) requieren un refuerzo de soporte adicional cuando se generan estructuras altas. Puede controlar el tipo de refuerzo por perfil de soporte, por bandeja o por modelo específico. El perfil Elastomérico SSYS ya fue modificado para configurar esta opción.
- Para impresión P3, la definición de Material proporciona parámetros de disposición predeterminados por material: Espacio entre modelos y Espacio desde límites de impresión. Los usuarios de OpenAM pueden modificar estos valores para sus materiales privados. Cualquier usuario puede modificar estos parámetros por bandeja (a través del panel Organizar).
Versión de GrabCAD Print 1.88, marzo 2024
- Print Pro: ¡GrabCAD Print Pro ahora incluye funciones para PolyJet! Estas consisten en funciones que anteriormente solo estaban disponibles a través del Paquete de investigación PolyJet...
- Imprimir directamente en la bandeja (solo serie J7/8): permite imprimir en materiales como vidrio o fibra de carbono, creando un acabado superficial perfecto en la parte inferior de las piezas y eliminando la necesidad de posprocesamiento en la parte inferior.
- Aire como material (solo serie J7/8): permite utilizar aire en lugar de resina para reducir significativamente el peso de las piezas, lo que permite ahorrar hasta un 30 % en material.
- Smart Insert™ (solo serie J7/8): permite incrustar varios elementos funcionales/decorativos directamente en la impresión.
- Imprimir en objeto (solo serie J7/8): permite personalizar el modelo con impresión directa sobre el objeto en una amplia variedad de sustratos.
- Aplicación Voxel Print (solo serie J7/8): herramienta para imprimir datos de corte definidos por otro software, lo que permite controlar cada detalle del modelo, incluidos el color, la transparencia y la dureza Shore a nivel de voxel.
- ...otra funcionalidad nueva...
- Soporte como material (solo J750 y J850 Prime): permite crear acabados texturizados en sus diseños al imprimir una superficie doble brillante y mate.
- Líquido como material (solo serie J7/8): permite crear cavidades huecas como estructuras de microfluidos, tubos huecos, piezas hidráulicas, etc.
- Modo de alta velocidad (solo J55): mantiene el mismo grosor de capa pero funciona al doble de velocidad cuando se utilizan 2 materiales.
- ...así como algunas funciones ya disponibles en Print Pro para FDM y SAF:
- Etiquetas
- Análisis de espesor
- Ensamblar/Disolver
- 3Complementos de terceros
- Print Pro: los resultados de estimación exportados ahora usan el formato de hora hh:mm para facilitar su inclusión en los cálculos.
- GrabCAD Print ahora admite las siguientes versiones de CAD:
- SOLIDWORKS 2024
- Inventor 2024
- Serie NX2306
- Borde sólido 2024
- .X_T36
- .JT 10.9
- Los Materiales digitales (DM), que son combinaciones de Agilus CMY y VeroUltraWhite, VeroPureWhite o VeroClear, ahora están disponibles en todas las impresoras serie J7/8 en todos los modos de impresión permitidos para estos materiales. Los nombres de DM tienen el prefijo FLXAC.
Versión de GrabCAD Print 1.87, febrero 2024
- Print Pro: los resultados de estimación para proyectos Pro ahora incluyen estimaciones de costos en las pestañas Resumen de bandeja/anidado e Informe de construcción (por pieza). Las tasas de cálculo de costos se pueden configurar en una nueva pestaña en la ventana de resultados de la estimación o desde Configuración de impresora.
- Se agregó Vista seccional a la barra de control en la parte superior del visor. Esta opción le permite ver características de modelos que de otro modo podrían quedar ocultas y puede usarla junto con la herramienta de medición o la herramienta de generación de soporte de Origin. Después de habilitar la Vista seccional, los botones a continuación le permiten seleccionar un plano y una dirección de sección, o puede usar los controles deslizantes para seccionar en otros ángulos.
- Ahora, puede seleccionar el texto en la ventana de resultados de la estimación y copiarlo al portapapeles con Ctrl+C.
- La herramienta Posición, que anteriormente solo estaba disponible para proyectos PolyJet y Print Pro, ahora está disponible para todas las tecnologías en Print Standard.
- La configuración predeterminada para Engrosar paredes finas en las impresoras de la serie F123 se modificó a Desactivada.
- Se solucionó un problema de que no se generaba un contorno en el armazón de una pieza y, en algunos casos, su relleno adyacente.
- Stratasys F3300, una nueva impresora FDM industrial de gran formato, ahora está disponible para selección en GrabCAD Print. Conozca las características y el rendimiento de Stratasys F3300 aquí o selecciónela en la lista de plantillas de impresora para ver los materiales y configuraciones disponibles.
- La visualización de soporte de PolyJet, disponible en la barra de control de vista en la parte superior del visor, ha mejorado la visibilidad al mostrar las áreas compatibles en azul, en lugar de un patrón de tablero de ajedrez.
- Esta opción posicionará la pieza en la posición real de la bandeja como se muestra en la pantalla, sin optimizar el proceso de impresión. Con Posición absoluta, la calidad de impresión de piezas pequeñas puede verse afectada.
- La herramienta de medición, que se agregó para otras tecnologías en la actualización 1.83, ahora está disponible para la preparación de impresión de PolyJet.
- Para proyectos SAF, ahora está disponible una versión potente y dinámica del Informe de construcción. De los resultados de la estimación, seleccione Crear informe y elija “HTML” en el menú desplegable de exportación en la esquina superior derecha. El archivo resultante se puede abrir en cualquier navegador web y contiene las estimaciones de anidado y por pieza, así como vistas previas 3D interactivas del anidado y de cada pieza, que muestran su ubicación en el anidado. También existe una herramienta de búsqueda para ayudar a encontrar piezas específicas por nombre.
- Ahora, se muestra una vista previa de la etiqueta de Cuadro de sinterizado, por lo que queda claro si cabe en el espacio disponible.
- Para proyectos P3, el error que impedía que se aceptaran los valores de compensación Z ahora está solucionado. Tenga en cuenta que todavía existe una regla según la cual la compensación Z no puede exceder el valor de Penetración de pieza de soporte.
- For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
- Radio soportado por la isla: el radio alrededor de la primera evidencia de una isla que recibirá puntos de anclaje adicionales.
- Espacio interior de la isla: el espacio entre estos puntos de anclaje adicionales.
- Additional updates for P3 support parameters:
- Para el modelo industrial, el diámetro máximo del pie aumentó de 10 a 30 mm.
- Para modelos dentales, la Penetración de la pieza puede ser 0.
Versión de GrabCAD Print 1.86, enero 2024
- Se solucionó un problema de que el cálculo de trayectoria de la herramienta FDM daba como resultado que una gran parte infringiera el volumen de construcción o que piezas pequeñas interfirieran entre sí.
- El visor 3D se actualizó para la preparación de impresión de PolyJet. Esta actualización era necesaria para las funciones que estarán disponibles próximamente, pero por ahora, no debería notar ningún cambio. Sin embargo, si es necesario, puede volver al visor anterior en Archivo > Preferencias > PolyJet.
- Los archivos creados con la aplicación GrabCAD Voxel Print (archivos .gcvf) ahora se pueden importar por parte de cualquier persona que tenga una impresora Serie J. El uso de la aplicación Voxel Print para crear archivos .gcvf aún requiere una licencia, pero ahora, todos pueden importar los archivos.
- La opción de trabajar con menos materiales de 7 modelo en el modo de impresión Mezcla alta (mediante el uso de Limpiador para los demás canales) se amplió para incluir el modo de impresión Alta calidad.
- Tres actualizaciones para usuarios de J5 DentaJet
- Las IFU (Instrucciones de uso) para materiales TrueDent ahora aparecen cuando selecciona una impresora J5 DentaJet con materiales TrueDent.
- Se modificó el panel Configuración del modelo para la impresión TrueDent a fin de incrementar la facilidad de uso. Elija fácilmente los materiales favoritos y predeterminados para tonos de encía y dientes.
- Los usuarios de J5 DentaJet ahora pueden utilizar un flujo de trabajo de extremo a extremo, desde escaneo intraoral hasta modelo impreso a todo color, utilizando Exocad Model Creator. Un nuevo perfil de color en GrabCAD Print permite igualar el color con Exocad.
- El proceso de curado de la impresión Origin puede causar que se acumule material adicional en las superficies orientadas hacia abajo, lo que se denomina sobrecurado. Un nuevo parámetro llamado Compensación Z soluciona este problema compensando esas superficies hacia arriba.
- Para usuarios de Origin Dental, la opción “Soporte de filtro en la cavidad” mostrará un nuevo mensaje de advertencia, informándoles de que es posible que se hayan eliminado algunos soportes necesarios.
- Cuando los puntales P2P no son viables debido a limitaciones de longitud o altura, la generación de soporte utiliza automáticamente Tarimas P2P.
Versión de GrabCAD Print 1.85, diciembre 2023
- Impresión profesional: Dos actualizaciones para etiquetas
- Ahora, es posible eliminar todas las etiquetas en una sola operación mediante un botón en el panel de etiquetas.
- Cuando crea una etiqueta de plantilla, ahora puede acceder a una vista previa del texto de la etiqueta en la pieza, lo que proporciona una ayuda visual en el ajuste del tamaño, la posición y la rotación.
- Las impresoras de la Serie J8 ahora pueden usar cartuchos de líquido de limpieza como reemplazo de los materiales del modelo en el modo de impresión de materiales 7. Con esta función, puede cargar líquido de limpieza en hasta 4 canales de impresión y seguir imprimiendo, lo que le permite imprimir mientras cambia de material.
- Ahora, puede enviar un trabajo de impresión a una impresora Connex3 cargada con materiales 2, lo que se conoce como modo DM2. (Nota: es necesario deshabilitar la segmentación avanzada en Archivo > Preferencias > PolyJet)
- La opción de utilizar una lámpara UV al imprimir en modo HQ se convirtió en la opción predeterminada en J850 Prime, J850 Prime Fabrix, J850 Pro, J835 y J750.
- La relación de los materiales anatómicos en las combinaciones con otros materiales de modelo o soporte es limitada. La validación de estas limitaciones se agregó a cada paso de modulación del ruido. Se solucionó la limitación de SUP706: SUP706 debe tener menos del 50 % en Capas externas cuando se combina con BoneMatrix, cualquier material Agilus30 o cualquier material Vero.
- Mejoras en las opciones para moda
- Puede seleccionar la receta LED UV sin abrir el panel Recetas.
- El panel Recetas se abre con el botón Administrar recetas.
- El Total de sectores incluye la capa de adhesión definida.
- Se agregó un botón Cancelar a la barra de progreso para procesos de Generación de soporte y puntos de anclaje para impresoras Origin. Si se generaron puntos de anclaje o estructuras de soporte, estos se eliminarán.
- Si modifica un parámetro en los paneles Puntos de anclaje y Soporte, el nombre del Perfil de soporte ahora muestra un asterisco (*) cerca de su nombre para indicar cambios no guardados. Utilice el botón Restablecer a perfil para restablecer los parámetros modificados.
Versión de GrabCAD Print 1.84, noviembre 2023
- Print Pro: ¡Presentamos el Análisis de brechas! Optimizamos la herramienta Análisis de espesor para permitir al usuario detectar brechas, como por ejemplo, bolsillos, en sus modelos, que están por debajo de la resolución de la impresora; esto está disponible en una nueva pestaña de Brecha en el panel Análisis de espesor.
- Print Pro: La función WAM del Centro de precisión ahora ofrece una mejora de precisión aún mayor y permite a los usuarios iterar para mejorar la calidad incluso en los proyectos más complejos.
- Los Materiales validados que introdujimos para Fortus 450mc en 1.75 ahora disponibles para F900. Estos materiales se validan mediante pruebas básicas de fiabilidad antes de ponerlos a disposición para trabajos de programación e impresión. Los Materiales validados requieren la instalación de la versión de firmware 4.22 en la F900 y solo están disponibles para una altura del corte de 0.0100 pulg./0.2540 mm.
- FDM HIPS (Poliestireno de alto impacto)
- Kimya PC-FR (retardante de llama)
- Nuevos colores de la resina ULTEM™ 9085 (Rojo, Gris Avión, Gris Cañonero, Gris Sueño, Blanco 7362, y Blanco Jana)
- Nuevo color de PC (Rojo)
- Nuevo color de PC-ABS (Rojo)
- (BETA) VICTREX AM™ 200 PAEK (Baja fusión)
- Para PolyJet, mejoramos la capa de adherencia para impresoras Fashion. Anteriormente, al imprimir un modelo mate con una capa adhesiva, la capa adhesiva se imprimía debajo del modelo y su soporte circundante. Al retirar el soporte, podía quedar la capa de adherencia alrededor del modelo. Después de la última actualización, la capa de adherencia solo se agrega debajo del modelo, lo que evita el problema de que permanezca cuando se retira el soporte.
- Solucionamos un problema de las impresoras PolyJet Objet30V3 y V5 en el que los trabajos de impresión comenzaron a fallar después de la actualización a GrabCAD Print 1.83.
- Para SAF, el panel de Anidado 3D ahora ofrece información de progreso adicional en el formato X/Y de manera que el usuario pueda ver claramente cuántos modelos se seleccionaron y cuántos están incluidos actualmente en el anidado.
- Para P3, introdujimos una capacidad de corrección automática de parámetros. Cada vez que el usuario ingresa un valor no válido para cualquier parámetro que tenga un rango válido, este valor ahora se corrige automáticamente al valor válido más cercano y se muestra una sugerencia de herramientas para el rango válido corregido en forma automática.
Versión de GrabCAD Print 1.83, octubre 2023
- Print Pro: el Informe de compilación ahora estima el material purgado para impresoras que utilizan una pieza de purga o una torre de sacrificios.
- Print Pro: el Informe de compilación ahora incluye estimaciones del tiempo necesario para imprimir piezas individuales como parte de una exportación a Excel o CSV.
- Print Pro: cuando exporta estimaciones a un archivo de Excel, el Informe de compilación y el Resumen de bandeja ahora se incluyen como hojas separadas del mismo documento.
- ¡Le presentamos la herramienta de Medición! Ahora, puede medir las distancias punto a punto, plano a punto o punto a plano con la opción de ajustar a los vértices. La Medición es compatible con proyectos FDM, SAF y P3.
- Ahora es posible modificar el nombre de piezas, ensamblados y cuerpos en el Panel de proyectos o en el Visor de modelos al resaltar el modelo y seleccionar el comando Renombrar en el menú contextual del mouse.
- Agregamos nuevas opciones de selección al menú contextual. Seleccionar todo ahora se puede aplicar al proyecto completo o solo a la bandeja actual. Y una nueva opción, Invertir selección, permite invertir la selección a piezas que no están seleccionadas, ya sea en la bandeja actual o en el proyecto completo.
- Para impresión H350, existen dos nuevas opciones disponibles en la barra de control de vista:
- Colorear agrega colores aleatorios a piezas de su anidado para visualizar mejor los paquetes densos.
- Visualización de líneas de capas permite ver líneas en superficies orientadas hacia arriba o hacia abajo donde las capas pueden ser visibles en la impresión resultante.
- Para P3, se agregó una nueva herramienta para generar una estructura de soporte en GrabCAD Print. Ahora, puede utilizar GrabCAD Print para preparar completamente sus archivos CAD y enviarlos a impresión; no se necesita software adicional.
Versión de GrabCAD Print 1.82, septiembre 2023
- Print Pro: una nueva capacidad en el modo Análisis llamada Análisis de espesor permite al usuario determinar rápidamente si su pieza contiene una geometría que está por debajo de la resolución de su impresora. La resolución se establece de forma predeterminada según la tecnología de la impresora; el usuario puede establecer su propio valor. La visualización puede ser roja incorrecta/verde correcta binaria o un gradiente continuo amarillo-rojo. El cursor también proporciona una “sonda” para mostrar el valor específico en cualquier punto de la pieza.
- Print Pro: ahora, es posible utilizar valores de espaciado más pequeños y negativos para el comando Matriz FDM 3D, lo que permite disposiciones mucho más ajustadas de las piezas en la bandeja.
- Actualmente, es posible ocultar la bandeja, lo que permite una mejor visualización de la parte inferior de piezas muy apretadas.
- GrabCAD Print admite direcciones IPv6 cuando se comunica con impresoras Stratasys H350, Fortus 450mc, Stratasys F900 y Fortus 900mc. IPv6 para Fortus 450mc requiere la versión de firmware 6.8. Stratasys F900 y Fortus 900mc requerirán una versión de firmware 4.22 para admitir IPv6.
- Presentamos TrueDent™, resinas aprobadas por la FDA (Clase II) desarrolladas para impresión 3D de dentaduras postizas y coronas y puentes temporales en la plataforma J5 DentaJet. Estas permiten la producción por lotes de aparatos dentales multicolores, monolíticos y altamente estéticos en una única bandeja mixta. Aunque actualmente está disponible en regiones específicas, TrueDent™ ofrece una solución prometedora para laboratorios dentales que desean obtener mayor productividad y resultados superiores.
- En la versión 1.81, se agregó una preferencia para activar/desactivar el procesamiento de Texturas avanzadas. Esta casilla de verificación se movió a Configuración de bandeja (en la sección Opciones avanzadas) y permite al usuario determinar el valor por trabajo. La casilla de verificación está desactivada de forma predeterminada para J55 Prime y J850 Prime, que imprimen bandejas pesadas con texturas.
- El recubrimiento de gel se añadió en los modelos de Corazón estructural en una impresora DAP (como se define en los modelos de Vasos sanguíneos).
- Para impresión SAF, las cajas de sinterización ahora pueden tener una etiqueta definida por el usuario como parte de la geometría de la caja, lo que permite separar la torta para saber qué piezas contiene la Caja de sinterización. Las etiquetas largas se alinean automáticamente con el eje más largo de la Caja de sinterización.
- Para impresión SAF, el valor de espaciado mínimo para anidado se puede anular para piezas seleccionadas específicas que necesitan espacio adicional para mejorar la gestión térmica.
- Para impresión SAF, ahora puede elegir si una operación de anidado agrega al contenido existente del anidado o borra el anidado y comienza de nuevo.
- Para impresión P3, la opción Ajustar a bandeja inicia una mejora de orientación que rota el modelo en pasos hasta que se ajuste al área de impresión.
- Para impresión P3, todos los perfiles de soporte dental deben tener un nuevo parámetro para filtrar puntos de anclaje en la calcografía para modelos de férula orientados en 90°.
- Para impresión P3, cuando crea puntos de anclaje, las áreas de soporte se colorean según el ángulo de autosoporte especificado en el perfil de soporte seleccionado.
- Los usuarios de GrabCAD Print con la nube P3 in situ pueden ejecutar GrabCAD Print con una cuenta no de administrador.
Versión de GrabCAD Print 1.81, agosto 2023
- Print Pro: el Centro de precisión ahora emplea pestañas para las vistas Original y Validación. La pestaña Original muestra los resultados de precisión (mapa de calor y puntuación de precisión de impresión (PAS)) de la pieza impresa original. La pestaña Validación permite a los usuarios cargar un escaneo de la impresión WAM para ver exactamente cuánto mejoró la precisión. Esa muestra el nuevo PAS versus la puntuación original y el nuevo histograma se muestra con un contorno gris del original superpuesto; de esta forma, puede ver fácilmente la reducción de bandas de error específicas.
- Impresión profesional: nuevos controles WAM en el Centro de precisión para obtener mejores resultados con superficies horizontales:
- Preservar (ahora la opción predeterminada) permite solo ajuste vertical uniforme de superficies horizontales para preservar la estética y evitar agregar líneas de contorno para suavizar áreas horizontales.
- El alfiler evita cualquier movimiento de las superficies horizontales.
- Ajuste libre permite corregir la deformación libremente en las superficies horizontales, lo que incluye la adición de contornos en las superficies horizontales para una máxima precisión donde se prioriza el ajuste sobre la estética.
- Print Pro: se agregó una vista previa rápida del archivo escaneado seleccionado en el Centro de precisión para ayudar a los usuarios a elegir el archivo escaneado correcto.
- Print Pro: el eje Y del histograma del Centro de precisión ahora muestra el porcentaje de la pieza total para cada barra de nivel de error, de modo que ahora puede ver qué porcentaje de su pieza se encuentra por sobre, por debajo o dentro de la tolerancia seleccionada.
- Print Pro: cuando compara un escaneo en el Centro de precisión, la disparidad local de la pieza impresa y escaneada (por ejemplo, el error versus el diseño en ese punto) ahora se muestra dinámicamente al mover el mouse sobre los resultados de la comparación.
- Para usuarios de P3 con licencias de Local Hub y OpenAM, se solucionó el problema al cargar un archivo de “Configuración por capa”.
- Para usuarios de P3, la preferencia “Crear automáticamente bandejas cuando los modelos no se ajusten a la bandeja actual” en Configuración de inserción de modelo ahora funciona para impresoras P3 al igual que en otras plataformas.
Versión de GrabCAD Print 1.80, julio 2023
- GrabCAD Print admite 2023 versiones de archivos CAD de la siguiente manera: SOLIDWORKS 2023, SolidEdge 2023, Siemens NX 2212.
- Print Pro: ahora se pueden agregar etiquetas de texto ad hoc a piezas FDM (STL y CAD); estas se pueden grabar en relieve o en superficie y se puede controlar el tamaño, la profundidad y el espaciado del texto. Además, se pueden crear plantillas reutilizables para etiquetas, las que pueden incrustar texto, nombre de pieza y generar un número de serie único. Haga clic aquí para obtener más información sobre GrabCAD Print Pro.
- Para el anidado SAF, los nombres de los métodos de anidado cambiaron de Estándar y Avanzado a Sin interbloqueos y Compacto para que su función sea más clara para el usuario. El método predeterminado ahora es Compacto (anteriormente, Avanzado), el que generalmente da como resultado un anidado más denso.
- Para SAF, la validación puede ser muy lenta en algunos casos, por lo que ahora puede cancelar el proceso de validación si necesita realizar más ediciones en el anidado.
- La nueva familia VeroEcoFlex de materiales semiflexibles ya está disponible para usuarios de J850 TechStyle. Más información aquí.
- La mayoría de las impresoras PolyJet utilizan lámparas UV de mercurio, pero la J850 TechStyle las reemplaza por LED UV. Las nuevas LED UV permiten un curado más preciso, lo que es crucial para modelos pequeños que tienen rasgos delgados. La función de Receta LED UV en GrabCAD Print proporciona un mecanismo para controlar la función UV hasta un corte o rango de corte específicos. Puede controlar qué LED usar y la intensidad de cada LED en cualquier parte del proceso de impresión.
- Solucionamos un problema en GrabCAD Print en el que las máquinas P3 no se guardaban como favoritas. Este problema se solucionó y los usuarios ahora pueden asignar máquinas como favoritas.
- Anteriormente, había un problema en el que las estimaciones de trabajos largos para trabajos P3 no se mostraban correctamente. Esto dio lugar a un período mucho más breve para su finalización. Resolvimos este problema.
- Solucionamos un problema para P3 que ocurría cuando ciertos materiales con configuraciones específicas no se podían comenzar a imprimir. Los usuarios ya no experimentarán este problema y los trabajos comenzarán a imprimirse como se esperaba.
- Para los usuarios de P3 con licencias de OpenAM, el rango de Escala en el perfil Material se ha ampliado y ahora es de +2 % a -1 %, lo que permite un mejor ajuste de escala para compensar la contracción de la resina.
- Para usuarios de P3 con licencias de OpenAM, solucionamos un problema con la función “Cargar configuración por capa”, que no funcionaba de manera óptima en determinadas circunstancias.
- Para usuarios de P3 con licencias de OpenAM, solucionamos un problema en el que los trabajos con materiales recién creados no se comenzaban a imprimir.
Versión de GrabCAD Print 1.79, junio 2023
- La herramienta Modelo de envoltura está disponible para Grupos, en los que los organismos miembros pueden tener configuraciones únicas. Está activada en forma predeterminada. La envoltura encierra los cuerpos del modelo en una carcasa común. La carcasa agrega resistencia cuando las juntas entre los cuerpos del modelo no están diseñadas para resistir las cargas aplicadas. Si las juntas entre cuerpos están diseñadas para resistir cargas, la función de envoltura no es necesaria y puede desactivarse.
- Los conflictos relacionados con la importación de CMB describen ahora claramente cómo el archivo que se está agregando no coincide con el proyecto.
- ASA ya está disponible para la impresora Stratasys F770 en los siguientes colores: blanco, negro, gris claro, azul, rojo y amarillo.
- La altura del pedestal en J3/J5 DentaJet se aumentó a 1 mm para mejorar la adherencia.
- Se ha agregado la opción "Optimizar para empaque" a J850 Prime FabriX. Esta opción mejora los resultados de impresión de objetos de empaques transparentes (como botellas).
- En la herramienta Escala, en los ajustes de bandeja para impresoras P3, la unidad de medida se ha mejorado de un decimal a tres decimales. Esta mejora permite mediciones más precisas y ajustes más finos en la funcionalidad de la característica.
- La importación de una pila de cortes para impresoras P3 ahora admite nombres de archivo de cortes con cualquier prefijo, por ejemplo, layer_xxx, slice_xxx, etc.
- Para los usuarios de P3 con licencias OpenAM , existe una nueva función de Descarga de configuración de material. Le permite descargar un archivo CSV que contiene información sobre las primeras + capas de transición del material. Para acceder a esta información, vaya a la Biblioteca de materiales, seleccione un material y presione el botón "Descargar configuración" que se encuentra sobre la tabla de Configuración de capa.
- El panel de proyecto muestra ahora un icono junto a cualquier modelo que se haya creado con el comando espejo.
- Para la impresión SAF, la barra de progreso de anidado indica ahora al usuario cuándo se está produciendo el anidado y cuándo está ocurriendo la validación.
Versión de GrabCAD Print 1.78, mayo 2023
Número de compilación 1.78.18.27879 liberado el 16 mayo 2023
- GrabCAD Print Pro ¡esta aquí! Entre sus funciones se incluyen Modelado ajustado a la deformación, estimaciones por pieza, plantillas de fabricación y más.
- Lea la lista completa de características Pro
Se actualizó el software utilizado internamente en GrabCAD Print para representar los gráficos en pantalla para trabajos FDM, ya que muchas de las nuevas funciones lo requieren. El visor antiguo aún está disponible en el menú de preferencias, si bien quedará obsoleto en algún momento en el futuro.
Para FDM, el comportamiento de vinculación de contornos externos se actualizó para usar siempre el comportamiento definido para el material del modelo y la altura del corte. Anteriormente, los contornos externos se vinculaban para algunos casos de uso, ignorando el comportamiento de vinculación del material.
Nylon-CF10 ahora está disponible con soporte separable para impresoras Stratasys F370CR y F190CR. El material de soporte SUP4000B proporciona una solución de eliminación de soporte sin tanque y un tiempo de separación más rápido con soportes separables fáciles de quitar. SUP4000B utiliza el mismo cabezal de soporte que QSR y las mismas alturas del corte (0.0130 pulgada/0.3302 mm; 0.0100 pulgadas/0.2504 mm; 0.0070 pulgadas/0.1778 mm) como
Nailon-CF10. Nylon-CF10 con soporte separable requiere que actualice el firmware de la impresora a la versión 2.6.
La definición del material Nylon-CF10 con soporte QSR se actualizó para mejorar el comportamiento de relleno para alturas del corte de 0.0100 pulgada (0.2504 mm) y 0.0130 pulgadas (0.3302 mm).
Mejore la precisión de las estimaciones del tiempo de construcción y volumen de material para:
- 0.0200 pulg. (0.5040 mm) ASA utilizando una punta T40A en la impresora Fortus 900mc
- 0.0200 in (0.5040 mm) Nylon CF12 (Negro) utilizando una punta T40C en la impresora Stratasys F900
- 0.0200 pulg. (0.5040 mm) ULTEM 9085 Resina Negra utilizando una punta T40A en las impresoras Stratasys F900 y Fortus 900mc.
- Después de hacer clic en el botón "Imprimir" de un trabajo P3, en la ventana de resumen de Impresión, puede ampliar fácilmente la capa 1 o la miniatura de la vista previa de la bandeja presionando sobre ella. Esto le permitirá ver más de cerca los detalles del primer corte antes de imprimirla.
- Si un modelo se ubica fuera del volumen de construcción para un trabajo P3, aparecerá una notificación con un signo de exclamación naranja en la ventana del panel Proyecto; al deslizar el cursor sobre este, se describirá el problema.
- Para los usuarios de P3 con licencias OpenAM, GrabCAD Print admite ahora la carga de una Configuración por capa que incluye un valor "edgeBuildingCompensation". Una vez cargada, la columna aparecerá en la tabla de Configuración por capa.
Versión de GrabCAD Print 1.77, abril 2023
Número de compilación 1.77.13.26873 liberado el 18 abril 2023
- Se ha restablecido la capacidad de cambiar de tecnología de impresión sin iniciar un nuevo proyecto.
- PolyJet: al cambiar un tono de encía para un ensamble específico, el ensamble y sus carcasas se duplicaban y se marcaban como ocultos en el árbol de bandejas. (El ensamble oculto se creó para simplificar la operación "Deshacer", que es extremadamente complicada). A partir de ahora, estos ensambles no serán visibles en el árbol y la operación de deshacer seguirá funcionando normalmente.
- SAF: ahora puede seleccionar piezas y crear una caja de sinterización para contener y proteger las piezas, especificando el tamaño del orificio, el grosor de la viga y el espaciado.
- P3: los parámetros de las capas de transición se han optimizado y ahora se manejan automáticamente en los materiales validados. Antes, esta función aparecía en Propiedades del material, pero ahora está oculta.
- P3: había un problema en el cual los modelos definidos en pulgadas cambiaban a milímetros antes de imprimir, y se ha solucionado.
Versión de GrabCAD Print 1.76, marzo 2023
Número de compilación 1.76.10.25761 liberado el 21 marzo 2023
- Un problema en el cual Stack (*.zip) aparecía como el tipo de archivo al importar un CMB ha sido restablecido a Archivos CMB (*.cmb, *.cmb.gz).
- Para la impresión P3, en "Configuración de la bandeja" / "Propiedades del material" verá un nuevo parámetro Escala. Esto le ayudará si su pieza impresa se ve afectada por la contracción del material, puede editar y optimizar los valores de escala del material a nivel del trabajo.
- Para la impresión P3, en "Configuración de la bandeja" / "Propiedades del material" verá un nuevo parámetro Capas base adicionales. Esto le ayudará si su pieza tiene una altura Z inferior a la del diseño CAD. Al agregar capas base adicionales se duplicará la primera capa para compensar la pérdida de altura en ellas.
- Para los usuarios de P3 con licencias OpenAM, imprimir una "Configuración por capa" modificada usando CSV funciona ahora correctamente.
Versión de GrabCAD Print 1.75, febrero 2023
Número de compilación 1.75.13.24793 liberado el 21 febrero 2023
- Para que el software sea más robusto, cambiar a una impresora de una tecnología diferente (como FDM a PolyJet) requerirá iniciar un nuevo archivo de proyecto. Puede cambiar libremente entre las tecnologías de impresión antes de agregar modelos a un proyecto.
- Los materiales validados están ahora disponibles en GrabCAD Print al programar trabajos para la impresora Fortus 450mc. Estos materiales se validan mediante pruebas básicas de fiabilidad antes de ponerlos a disposición de trabajos de programación e impresión. Los materiales validados requieren la instalación de la versión de firmware 6.7 en el 450mc.
Material validado | Altura del corte disponible | Punta del modelo | Material de soporte | Punta del soporte |
FDM HIPS (Poliestireno de alto impacto) | 0.0100 pulg. (0.2540 mm) | T16 | SUP1500B | T12 |
Kimya PC-FR (retardante de llama) |
0.0100 pulg. (0.2540 mm) | T16 | SR-100 | T12SR100 |
Nuevos colores de la resina ULTEM™ 9085 (Rojo, Gris Avión, Gris Cañonero, Gris Sueño, Blanco 7362, y Blanco Jana) | 0.0100 pulg. (0.2540 mm) | T16 | SUP8500B | T16 |
Nuevos colores de PC (rojo y negro) | 0.0100 pulg. (0.2540 mm) | T16 | SR-100 | T12SR100 |
Nuevo color de PC-ABS (Rojo) | 0.0100 pulg. (0.2540 mm) | T16 | SR-100 | T12SR100 |
(BETA) VICTREX AM™ 200 PAEK (Baja fusión) |
0.0100 pulg. (0.2540 mm) | T14E | SR-100 | T12SR100 |
(BETA) Covestro Addigy® PA6/66-GF20 FR LS (Nylon relleno de vidrio, retardante de llama) |
0.0100 pulg. (0.2540 mm) | T20G | SUP4000B | T16 |
- Los paquetes de materiales son ahora compatibles con GrabCAD Print. Los paquetes de materiales se crean cuando los materiales se sintonizan en OpenAM™, se compilan y se distribuyen a GrabCAD Print y a una impresora Fortus 450mc habilitada con una licencia OpenAM. Los materiales preferidos y validados Stratasys pueden ajustarse e incluirse en los paquetes, así como los materiales abiertos de terceros. Los paquetes de material requieren la versión del firmware de la impresora 6.7.
- Se ha corregido un error debido al cual los duplicados de un CMB (o copiar/pegar) no tenían la misma ruta de herramienta que el CMB original.
- Basada en la plataforma J35 , la J3 DentaJet™ es nuestra impresora básica PolyJet para laboratorios dentales pequeños y medianos. Puede producir bandejas mixtas de tres materiales biocompatibles, incluida una gran cantidad de modelos de implantes, guías quirúrgicas y máscaras gingivales, todo en la misma bandeja y con una precisión inigualable. Vea el nuevo J3 DentaJet™ aquí.
- La alerta que solicita una actualización de Job Manager para las impresoras PolyJet sólo aparecerá ahora cuando las versiones de GrabCAD Print y de Job Manager no estén alineadas. Anteriormente, la alerta aparecía en cuanto había una nueva versión disponible.
- Ahora es posible agregar una capa de revestimiento a un modelo VRML texturizado para su impresión en PolyJet.
- Para las impresoras SAF, ya está disponible el material PA12 (beta). Leer más aquí.
- Para las impresoras SAF, una nueva opción con el botón secundario del mouse le permite seleccionar los modelos que no son válidos luego de la estimación o la validación.
- En el caso de las impresoras SAF, en algunos casos las piezas en ángulo presentaban pequeños artefactos superficiales por el corte; el algoritmo de corte se hizo más preciso para evitar este problema.
- Para la impresión P3 sin acceso a Internet, ahora se admite la conexión a la impresora Origin One Local a través del Hub Origin Local (más detalles en la guía de referencia de Origin One Local en Centro de Asistencia Stratasys). Consulte las instrucciones de conexiónaquí.
- Para las impresoras P3, ahora puede importar cortes creados por aplicaciones como Netfabb utilizando: Archivo > Importar pila de cortes.
Versión de GrabCAD Print 1.74, enero 2023
Número de compilación 1.74.8.23921 liberado el 17 enero 2023
- La configuración de seguridad de Windows para utilizar el cifrado compatible con FIPS había estado bloqueando anteriormente la conectividad de la impresora para los productos GrabCAD, y esto se ha resuelto para GrabCAD Print y Print Server. FIPS debe seguir desactivado en los sistemas en los que esté instalado Job Manager de PolyJet.
- 3La compatibilidad con DConnexion Spacemouse, que se introdujo en 1.55, ahora se ha restablecido.
- Se habilitó la Entrada de CMYK para materiales VeroFlex en todas las impresoras J7xx/8xx cuando la bandeja de materiales contiene materiales VeroFlex de todos los colores.
- Se ha agregado Edge Compensation a los parámetros del material para las impresoras Origin. Esta nueva herramienta le permite sumar o restar micrones a los bordes del modelo en cada corte. Esto le ayudará si está viendo características, como orificios, que son demasiado grandes o demasiado pequeñas, pero no desea cambiar la escala de su modelo.
Versión de GrabCAD Print 1.73, diciembre 2022
Número de compilación 1.73.5.23276 liberado el 20 diciembre 2022
- Ya no es posible agregar modelos desde Workbench. Obtenga más información sobre el desuso de GrabCAD Workbench en la publicación del blog aquí.
- Para las impresoras dentales PolyJet, el archivo que indica los nombres de los tonos de dientes y encías para la integración con 3Shape se actualizó con los nuevos tonos agregados en la versión 1.72. Además, cuando se abra un proyecto o trabajo antiguo que contenga nombres de tonos que no existan, el nombre del tono estará vacío y se presentará la notificación. Si el usuario selecciona un preajuste que utiliza un tono que no existe, el tono predeterminado se establecerá automáticamente.
- Las notas de GrabCAD Print Manufacturing ya están disponibles para H350, lo que permite a los usuarios anotar sus modelos y crear un informe en PDF que contenga capturas de pantalla de los modelos y las notas en un documento PDF guía.
- También para el H350, se corrigió un error y ahora la vista previa de las etiquetas se muestra en el tamaño correcto.
Versión de GrabCAD Print 1.72, noviembre 2022
Número de compilación 1.72.6.22542 liberado el 16 noviembre 2022
- Se agrega una altura de corte de 0.0200 pulgadas (0.508 mm) para Nylon 12 CF en la impresora Stratasys F900, lo que permite un rendimiento más rápido en piezas grandes. Esta altura de corte utiliza la punta del modelo T40C.
- Se agrega una altura de corte de 0.0200 pulgadas (0.508 mm) para la resina ULTEM™ 9085, la resina ULTEM™ 9085 CG y la resina negra ULTEM™ 9085 en las impresoras Stratasys F900 y Fortus 900mc. La nueva altura de corte permite un rendimiento más rápido en piezas grandes. Esta altura de corte utiliza la punta del modelo T40A.
- Los modelos seleccionados en la H350 3D Nest se pueden aislar visualmente, por lo que todos los modelos no seleccionados se ocultan, cuando el usuario ha terminado de trabajar en los modelos aislados, puede volver a mostrar todos los modelos. Tenga en cuenta que estas operaciones no cambian la posición de ninguna pieza en 3D Nest.
- Para la H350, se puede seleccionar cualquier ensamblaje de CAD creado con el comando Ensamblar o 3D Array agrupado y la estructura del ensamblaje se puede disolver dejando modelos individuales.
- Las estimaciones para la H350 ahora informan la masa para todo el nido y para los modelos, también el fluido HAF para todo el nido.
- El comando de etiqueta para H350 ahora recuerda la configuración entre los usos del comando,con lo cual la creación de una secuencia de etiquetas manuales es mucho más rápida, puesto que el grabado en relieve/bajo relieve, el tamaño del texto, etc. siguen siendo los mismos.
- Para la J5 DentaJet, se mejoraron algunos tonos de Dientes con un color más preciso y se agregaron dos nuevos tonos.
- Para la J5 DentaJet, los tonos de encía mejoraron con mejores texturas. Se agregaron cuatro nuevos tonos.
Versión de GrabCAD Print 1.71, octubre 2022
Número de compilación 1.71.7.21930 liberado el 18 octubre 2022
- Los usuarios de J5 DentaJet ahora pueden utilizar un flujo de trabajo integral, desde el escaneo intraoral hasta el modelo impreso a todo color, utilizando el software 3Shape Dental System y GrabCAD Print. El 3perfil de modelo de color de forma se ha agregado al J5 DentaJet al imprimir con VeroDent PureWhite y Vero CMYK. Tenga en cuenta que esto requiere la versión 2022 del software 3Shape Dental System.
- Aparecerá una notificación en la pantalla de confirmación de impresión cuando se envíen trabajos a impresoras Connex con Advanced Slicer activado.
- Los trabajos impresos en las impresoras serie J7/J8 en el modo Super High Speed no aparecían en la vista de programación, y esto ya está solucionado.
- Se puede cambiar el nombre del área 3D Nest para H350 haciendo clic en la vista previa en el panel del proyecto, de forma similar a cambiar el nombre de una bandeja para FDM o PolyJet, y esto cambiará el nombre del trabajo enviado a la impresora.
- El contenido del informe generado para las estimaciones en la H350 ahora se puede copiar y pegar en otros archivos, como hojas de cálculo, o descargar como archivo .XLSX o .CSV.
- Los usuarios de P3 sin una licencia de OpenAM ahora pueden obtener resultados de estimación precisos a través de GrabCAD Print. Obtenga más información en nuestra última publicación de blog aquí.
Versión de GrabCAD Print 1.70, septiembre 2022
Número de compilación 1.70.12.21501 liberado el 21 septiembre 2022
- GrabCAD Print ahora es compatible con los sistemas operativos Windows 11. Para los requisitos completos del sistema, haga clic aquí.
- GrabCAD Print ahora admite archivos de las últimas versiones del software CAD, incluidos Creo9, Inventor 2023, NX2206 y Parasolid 34.1.
- GrabCAD Print ahora es compatible con las impresoras Origin One y Origin One Dental. Una vez que inicie sesión en su cuenta de Origin en Archivo > Preferencias > P3 DLP, puede configurar y enviar trabajos a sus impresoras. Más información aquí.
- Para proyectos FDM, GrabCAD Print ahora mantiene la configuración del trabajo cuando se recupera un proyecto y no se encuentra la impresora seleccionada. Se solucionó un problema en el que la configuración tendría los valores predeterminados para la impresora aplicada.
- El cabezal de extrusión endurecido T14H ahora es compatible con las impresoras Stratasys F370, F270 y F170. Con una vida útil de 1500 horas, el cabezal es la selección predeterminada para trabajos de programación que utilizan el material ABS-CF10.
- Para las impresoras dentales PolyJet, ahora se permite asignar un tono a la encía en la selección múltiple. Sin embargo, está limitado a una sola carcasa por ensamblaje.
- Tanto en J850 Prime Fabrix como en TechStyle, el espesor válido de la capa adhesiva se aumentó a 3 mm.
- Corrección de errores de PolyJet:
- En J850 Prime Fabrix y TechStyle, los proyectos guardados con una parada planificada se abren sin la parada planificada.
- En J5 DentaJet, la validación falla al abrir un proyecto válido.
- En J5 DentaJet en modo SHS, la estimación total de los materiales del modelo y de soporte es incorrecta.
- Se han agregado los siguientes comandos a la vista 3D Nest para la H350 con el fin de permitir que el usuario trabaje exclusivamente en la 3vista D Nest: modo de Análisis, Unidades, Escala, Agregar modelos, Arrastre libre en el plano X, Y .
- La creación de una construcción H350 de varios modelos, que contiene algunos modelos que son demasiado grandes para anidar, ya no hará que falle toda la operación de anidamiento. Los modelos que sí se ajusten se anidarán y aparecerá una advertencia con una lista de los modelos que son demasiado grandes para ajustarse.
- Para la H350, al crear una etiqueta de plantilla utilizando la automatización de nombre o número, la sintaxis se verifica automáticamente; si es incorrecta, se resalta en rojo y una información sobre herramientas detalla el error.
Versión de GrabCAD Print 1.69, agosto 2022
Número de compilación 1.69.12.20542 liberado el 16 agosto 2022
- Dos nuevas resinas ahora son compatibles con J5MediJet™
- Biocompatible Digital ABS Plus™ está diseñado para simular plásticos ABS estándar al combinar resistencia a altas temperaturas con tenacidad. El material mejora significativamente el rendimiento mecánico de las piezas biocompatibles para diversas aplicaciones médicas.
WSS™150 es un material de soporte soluble en agua para una rápida eliminación del soporte. El material se vuelve soluble cuando se coloca en un recipiente lleno de agua normal del grifo. Se pueden lograr capacidades de remoción de soporte más rápidas usando un lavavajillas estándar o de encimera.
Obtener más información aquí.
- Cuando los materiales de una bandeja J750/850 Digital Anatomy incluyen RadioMatrix, no se seleccionará como el material predeterminado cuando se inserte el modelo.
- Cuando tenga acceso tanto al PolyJet Research Package como a la impresora 3DFashion, deberá elegir una para usar en el proyecto actual, puesto que algunas de las características están en conflicto.
- En las impresoras de las series J7 y J8, se mejoró la experiencia del usuario para configurar modelos con materiales de color Agilus con un comportamiento flexible. La configuración correspondiente se movió de las opciones avanzadas a la sección de configuración principal, y se agregó información sobre herramientas detallada a todas las opciones de configuración.
- La 1.67 actualización introdujo la opción para que las impresoras Connex3 utilicen el Advanced Slicer con una casilla de verificación en Archivo > Preferencias > PolyJet, activada de forma predeterminada. Advanced Slicer es más estricto con los requisitos de gráficos y algunos usuarios observaban un error con respecto a los controladores de gráficos. Hubo un error donde, después de desactivar la preferencia de Advanced Slicer, el error persistió y, por lo tanto, impidió que los trabajos se pusieran en cola. Con la actualización 1.69, esto se solucionó y, al desactivar la preferencia, se borrará el error.
- Para H350, ahora es posible especificar una altura para el paquete, ya sea como el tiempo (esto es útil para preparar un trabajo adaptado al tiempo disponible en el turno) o como la altura del paquete, cualquiera que sea el parámetro que el usuario introduzca actualizará el otro.
- La estimación para la H350 ahora proporciona un informe de construcción, con páginas de resumen y detalles. Listas de resumen: tiempo de impresión, volumen total, modelos anidados, modelos no anidados, densidad, altura del nido y contracción. Listas detalladas: las piezas individuales, cuántas copias de cada pieza y el volumen de cada pieza.
Versión de GrabCAD Print 1.68, julio 2022
Número de compilación 1.68.10.19783 liberado el 19 julio 2022
- Los ensamblajes3MF, OBJ y VRML de varios archivos ahora se pueden importar en su totalidad de la misma manera que STL usando Archivo > Importar como ensamblaje.
- El material de soporte para la resina ULTEM™ 9085 se renombra como soporte SUP8500B, y la resina ULTEM™ 1010 se renombra como soporte SUP9000B.
- Para las Etiquetas (solo H350), ahora se puede especificar la altura o la profundidad del relieve del texto de la etiqueta.
- Para 3D Arrays (solo H350), ahora se pueden seleccionar varios modelos y se puede crear una matriz de esos modelos.
- Tanto para J850 TechStyle como para J850 Prime Fabrix, al conectar una impresora, el tipo de bandeja para el trabajo actual se sincroniza automáticamente con la bandeja que está instalada en la impresora.
- En las impresoras de las series J7 y J8 que recibieron e instalaron la orden de cambio de campo Conducto de aire de la lámpara UV derecha, el cuadro de diálogo Configuración de la impresora se ampliará con la declaración “Se instaló el conducto de aire actualizado”.
- Los ASR-620 DM, que son una combinación de MED620 y SUP711, ahora están disponibles en J5 DentaJet en modo de impresión HQHS.
- Los materiales Color Agilus están disponibles en la aplicación Voxel Print.
- Flex-Touch (tanto Smart como Full) se definirá por modelo en lugar de un Flex-Touch común para todos los modelos en la bandeja.
Versión de GrabCAD Print 1.67, junio 2022
Número de compilación 1.67.10.19143 liberado el 22 junio 2022
- El Advanced PolyJet Slicer, que antes solo estaba disponible para las impresoras de la serie J, ahora es compatible con las impresoras Connex3. Advanced Slicer introduce una calidad mejorada y capacidades adicionales, como:
- Escala de grises con perfiles ByN de transparencia
- Manejo de áreas delgadas/esquinas
- Estimaciones y compensaciones más precisas
Mejor control de Cuadrícula
Si necesita replicar exactamente una impresión anterior, puede volver al cortador antiguo usando Archivo > Preferencias > PolyJet.
- El kit de innovación FabriX™ para la J850™ Prime le permite expandir sus capacidades de creación de prototipos y CMF de PolyJet™ a un nuevo mundo de impresión directa sobre sustratos textiles y flexibles. Ahora puede probar diferentes diseños para aplicaciones que contienen materiales de malla, prototipos de prendas funcionales e incluso visualización de sistemas de filtración.
- Presentamos RadioMatrix™, el primer material de impresión 3D Radiopaque de su tipo disponible en la impresora de anatomía digital. El nuevo material permite 3 modelos anatómicos impresos D con características de radiopacidad en contraste variable que pueden aparecer en una tomografía computarizada o una radiografía. Se han agregado configuraciones de material RadioMatrix™ al software Digital Anatomy Printer, lo que permite ofrecer modelos anatómicos impresos 3D radiopacos con un valor de Hounsfield deseado.
- La nueva característica de Inserción de tejido de red permite a los usuarios planificar una parada durante la impresión para insertar el material para imprimir durante el trabajo. Característica habilitada en los sistemas J850 TechStyle y J850 Prime FabriX.
- Rigid Core para modelos AgilusCMY permite imprimir un modelo rígido de "tacto suave" una vez utilizando el perfil de colores Agilus. El resultado es un modelo rígido con una textura fina a todo color (1 mm Shore A a todo color 30) como superficie blanda externa.
- La entrada CMYK para materiales AgilusCMY permite definir el tono de color deseado específico mediante el ingreso de valores numéricos CMYK para materiales AgilusCMY puros.
- Con el modo de alta velocidad de alta calidad de la J5 DentaJet, los usuarios ahora pueden imprimir modelos dentales, guías quirúrgicas y otras aplicaciones con la misma calidad, en la mitad del tiempo. El modo de alta calidad y alta velocidad se puede seleccionar en GrabCAD Print una vez que se selecciona la configuración de material adecuada y se ejecuta el Asistente de reemplazo de material en la impresora.
- Para la H350, ahora es posible crear un ensamblaje a partir de múltiples modelos de nivel superior cargados en GrabCAD Print. Los modelos se colocan en el 3espacio D, ya sea con el 3widget de arrastre D o la herramienta de posición, y luego se convierten en un ensamblaje que luego se puede anidar.
- La herramienta 3D Array para la H350 ahora admite ensamblajes como fuente para la matriz.
- Ahora es posible utilizar la altura del paquete como criterio de parada para la herramienta 3D Nest para la H350. Si el proceso de anidamiento empaqueta con éxito todos los modelos seleccionados, intentará reducir la altura del paquete hasta alcanzar la altura especificada.
- El valor predeterminado para Espaciado mínimo de modelo en el comando 3D Nest para la H350 ahora es 2 mm, reducido de 3 mm, lo que significa que puede crear un nido más denso de forma segura.
Versión de GrabCAD Print 1.66, mayo 2022
Número de compilación 1.66.7.17878 liberado el 17 mayo 2022
- Presentamos a los miembros más nuevos de la serie F123, Stratasys F370 CR y Stratasys F190 CR. Estas impresoras listas para compuestos (CR) están diseñadas para su uso con materiales rellenos, incluso el último material compuesto FDM de Stratasys, nylon-CF10 y el material actual ABS-CF10. Esto facilita la producción interna de accesorios, herramientas y piezas resistentes para sujeción de trabajos, en una fracción del tiempo que lleva usar tecnologías y materiales de fabricación tradicionales. Las impresoras admiten 8 materiales de grado de ingeniería y se programan mediante la interfaz intuitiva de GrabCAD Print y las funciones FDM avanzadas fáciles de usar. Obtener más información sobre las impresoras F123 Composite Ready aquí.
- La impresora J850 TechStyle 3D está impulsada por la tecnología 3DFashion™ y proporciona capacidades de múltiples materiales a todo color para diseños que se pueden imprimir directamente en textiles, pieles y prendas, así como también para imprimir pequeños accesorios de moda que brindan resultados que no son posibles con los métodos tradicionales. Obtener más información aquí.
- GrabCAD Print ahora es compatible con la impresora con tecnología H350 SAF. Los usuarios con licencia pueden imprimir, los usuarios sin licencia pueden explorar la funcionalidad para aprender y evaluar su potencial. Obtener más información aquí.
- Ahora puede reflejar un modelo en GrabCAD Print usando el menú contextual. Esta característica admite: reflejo de malla y piezas CAD para todas las tecnologías de impresión, modelos con colores de cara, texturas, modelos dentro de ensamblajes y ensamblajes completos. Actualmente, esto no admite la duplicación de modelos con funciones FDM avanzadas y modelos con etiquetas.
- El nylon-CF10, una mezcla de nylon reforzado con carbono, está disponible para las impresoras Stratasys F370 CR y Stratasys F190 CR. El material incluye un 10 % de fibra de carbono picada por peso, lo que da como resultado modelos impresos en 3D que son más rígidos y fuertes con una mejor resistencia química que el ABS-CF10. EL nylon-CF10 es compatible con alturas de corte de 0.0070 pulgadas (0.1778 mm), 0.0100 pulgadas (0.2540 mm) y 0.0130 pulgadas (0.3302 mm), y requiere una nueva cabeza endurecida (T20H) para imprimir. Obtener más información sobre el nylon-CF10 aquí.
- Está disponible un nuevo cabezal endurecido (T14H) para imprimir ABS-CF10, con una vida útil de impresión de 1500 horas. El cabezal T14H es opcional; el cabezal T14 puede seguir utilizándose con ABS-CF10, con una vida útil del cabezal reducida.
- Las nuevas resinas de color Agilus30™ (cian, magenta y amarillo) permiten la creación de prototipos de productos con textura de goma o silicona para piezas a todo color similares a la goma, con alta calidad de superficie y niveles de flexibilidad que pueden soportar dobleces y flexiones repetidas. Obtener más información aquí.
- Los materiales WSS (soporte soluble en agua), VeroUltraClearS y VeroUltraClear ahora se pueden usar en VoxelPrint.
- Para el H350, agregue texto en relieve o grabado a la superficie de su modelo con la herramienta Etiquetas. También puede crear plantillas de etiquetas que se pueden aplicar varias veces o automáticamente al duplicar piezas y que pueden incluir automáticamente nombres de piezas o generar números de serie.
- Para el H350, puede crear una matriz rectangular en X, Y, Z. La matriz se puede agrupar para que se comporte como un solo objeto o se puede crear como modelos individuales.
Versión de GrabCAD Print 1.65, abril 2022
Número de compilación 1.65.13.17318 liberado el 21 abril 2022
- Presentamos la impresora de anatomía digital J850. La impresora de anatomía digital J850 da vida a modelos médicos con un realismo increíble que representa con precisión tanto la apariencia como la respuesta del tejido humano. Estos modelos brindan versatilidad clínica, repetibilidad y precisión inigualables para los profesionales de la salud y las empresas de dispositivos médicos. Leer más aquí.
- Hemos actualizado los formatos de archivo admitidos para incluir SOLIDWORKS 2022, Inventor 2022 y más. Haga clic aquí para ver la lista completa: Lista de formatos de archivo compatibles
- Algunos usuarios experimentaban problemas de conectividad de red debido a servidores proxy o certificados autofirmados. Una nueva opción en Archivo > Preferencias > Privacidad permite que GrabCAD Print confíe en los certificados del almacén de certificados de Windows, lo que debería resolver muchos de estos problemas. La aplicación establecerá automáticamente la preferencia si detecta estas configuraciones.
- Presentamos Digital Anatomy Creator, un nuevo módulo de software complementario para la impresora Digital Anatomy. Utilizando funciones matemáticas sofisticadas, el software Creator ofrece a los usuarios una libertad sin precedentes para personalizar las estructuras internas de los modelos anatómicos. Cree más allá de los ajustes anatómicos existentes predeterminados y calibre los materiales digitales para que cumplan con sus especificaciones exactas. Manipule fácilmente la formación de material y personalice las microestructuras internas para lograr un resultado anatómico específico. Obtener más información aquí.
- Las nuevas resinas ahora son compatibles con Voxel Print en los sistemas PolyJet: VeroUltraWhite y VeroUltraBlack en todas las impresoras compatibles, y DraftWhite en J5 MediJet
Versión de GrabCAD Print 1.64, marzo 2022
Número de compilación 1.64.9.16414 liberado el 17 marzo 2022
- La calidad de la pieza para Diran 410MF07 se mejora en la impresora Stratasys F370 de las siguientes maneras:
- Para la altura de corte de 0.0070 pulg. (0.1778 mm), hay una densidad de relleno mejorada para las superficies visibles que apuntan hacia arriba y hacia abajo, y una mejor adhesión entre la superficie inferior de una pieza y la superficie superior de la base.
Para la altura de corte de 0.0130 pulgadas (0.3302 mm), hay una mejor calidad de unión, superficies verticales y densidad de relleno.
Estas mejoras requieren que el firmware de la impresora se actualice a la versión 2.4.
Versión de GrabCAD Print 1.63, febrero 2022
Número de compilación 1.63.8.15371 liberado el 16 febrero 2022
- WSS™150 es un material de soporte soluble en agua para una rápida eliminación del soporte en los sistemas J55 Prime y J35 Pro PolyJet. WSS150 se vuelve soluble cuando se coloca en un recipiente lleno de agua corriente del grifo. Se pueden lograr capacidades de eliminación de soporte más rápidas usando un lavavajillas estándar o de mostrador. Además, se puede utilizar el polvo L2S™ para desechar de forma segura las aguas residuales sin necesidad de enviarlas para su posterior tratamiento, de acuerdo con las normativas locales.
- Se ha actualizado el panel Vista previa del corte:
- Ahora muestra el nombre, la altura del corte y la punta utilizada para el modelo, y los materiales de soporte.
- Se reorganizan los filtros para la visualización de funciones (Estabilizadores, Anclajes, Costuras, Pausas)
Los controles para la animación (Reproducir animación, Seleccionar capa y Movimientos de la cabeza) y la pausa Z (Agregar o quitar pausa Z, lista de pausas) están agrupados
El acceso al panel de Configuración del modelo se elimina de la Vista previa de corte, ya que ahora se presenta información sobre el material y la altura del corte en el panel Vista previa de corte.
- Al usar la función Optimizar para empaque en J55 Prime o J8 Prime, ahora puede ajustar con precisión su color transparente usando la entrada CMYK que admite VeroUltraClear, lo que brinda una gran transparencia y saturación a cualquier botella o líquido.
- La impresora J5 DentaJet PolyJet ahora utiliza un conjunto de parámetros nuevo y mejorado para obtener impresiones dentales más rápidas y precisas.
- Las nuevas resinas ahora son compatibles con VoxelPrint en los sistemas PolyJet:
- VeroUltraWhite y VeroUltraBlack en todas las impresoras compatibles
- DraftWhite en el J5 MediJet
Versión de GrabCAD Print 1.62, enero 2022
Número de compilación 1.62.8.14676 liberado el 19 enero 2022
- Se agregó la punta del modelo T16A para su uso con ULTEM™ 9085 y materiales de modelo CG de grado certificado ULTEM™ 9085 en la impresora Fortus 450mc. Proporciona propiedades mecánicas altamente repetibles y una calidad mejorada en comparación con la punta T16 estándar para su uso en aplicaciones que requieren certificación de piezas, incluidos los interiores aeroespaciales. El grosor de la capa para la punta del modelo T16A es de 0.010 pulgadas (0.2540 mm). Para usar la punta del modelo T16A, el software del controlador para Fortus 450mc debe actualizarse para la versión 6.6.6906.
- La altura de corte de 0.0130 pulg. (0.3302 mm) ahora es compatible con ULTEM™ 9085 Black si usa la punta de modelo T20 en la impresora Fortus 450mc. El corte más grueso permite construcciones más rápidas de piezas y un mayor rendimiento. La nueva altura de corte requiere que el software del controlador se actualice a la versión 6.6.6906.
- Se han solucionado algunos errores pequeños junto con otras mejoras.
Versión de GrabCAD Print 1.61, diciembre 2021
Número de compilación 1.61.12.14139 liberado el 22 diciembre 2021
- Con las impresiones PolyJet a todo color, la "Apariencia del cuerpo" es ahora el núcleo predeterminado para cuerpos texturizados al cambiar de color con el selector de color. Esto va de la mano con la opción "Anular textura" lanzada recientemente que está desactivada de manera predeterminada, lo que le permite cambiar el color y la transparencia de un cuerpo texturizado con un flujo de trabajo simple e intuitivo.
- Cuando configura una hora de inicio diferido para un trabajo en una impresora de la serie J5, hay disponible una nueva opción de configuración de hora, además de la hora de inicio o finalización existentes. Cuando se agote un material durante el trabajo, puede establecer una hora en la que le gustaría cambiar el recipiente de material y la impresora comenzará el trabajo en el momento adecuado.
- Para la impresora de anatomía digital: los nuevos ajustes preestablecidos de "pared de vaso suturable" ofrecen un rendimiento y una durabilidad mejorados para los modelos de vasos sanguíneos destinados a la sutura.
- Se ha solucionado un problema por el que no se podían crear anclajes y estabilizadores en el mismo modelo.
Versión de GrabCAD Print 1.60, noviembre 2021
Número de compilación 1.60.9.13125 liberado el 17 noviembre 2021
- Notará que hemos modificado la apariencia del lado derecho de GrabCAD Print. Los íconos son un poco más pequeños y están fijados al costado de la ventana. Debido a que siempre estamos agregando herramientas nuevas, redujimos ligeramente el uso del espacio para dar cabida a pantallas más pequeñas.
- Las impresoras PolyJet ahora pueden imprimir modelos que incluyen mapas de desplazamiento (relieve). Después de habilitar la función en Archivo > Preferencias > GrabCAD Labs, los mapas de relieve que se incluyen con modelos Keyshot .3MF u .OBJ estándar se traducirán en la terminación de la superficie de la pieza impresa. Anteriormente, era necesario escribir los mapas de relieve en la malla 3D del archivo, lo cual generaba archivos innecesariamente grandes. Ahora los mapas de relieve se pueden leer directamente. La altura del desplazamiento se puede ajustar en Configuración del modelo o definir en 0 para deshabilitarla. Al igual que con cualquier función de Labs, sus comentarios son bienvenidos.
- Tenemos un nuevo modo disponible para la J35 Pro llamado Modo de utilización de material. Este nuevo modo le da la opción de permitir que la impresora decida automáticamente la combinación de colores para aprovechar al máximo los materiales restantes. La pieza impresa lucirá diferente a la visualización en GrabCAD Print, ya que el color final dependerá del material existente en el momento de la impresión. Esta opción está disponible en la ventana "Resumen de impresión".
- Capacidad para mantener la textura mientras se cambian los colores del cuerpo. Anteriormente, al aplicar un nuevo color a un modelo texturizado, la textura se anulaba. Ahora, el nuevo color actualizará el color del cuerpo de la pieza debajo de la textura, con la opción de anularlo. La "Opción de base y núcleo" seleccionada anulará el color en caso de que no coincidan.
- Nueva optimización para imprimir un trabajo de PolyJet con muchos modelos pesados. Cuando llene la bandeja con modelos pesados, utilice esta función para optimizarlos automáticamente. Esta función reduce de forma automática la complejidad del modelo sin perder calidad ni precisión.
- Se corrigió un problema que había con los controladores de gráficos NVIDIA más recientes, que impedía estimar e imprimir algunos trabajos de PolyJet.
- Se corrigió un problema que causaba que la Vista previa del corte mostrara un modelo con un estabilizador del mismo color que el estabilizador.
Versión de GrabCAD Print 1.59, octubre 2021
Número de compilación 1.59.11.12349 liberado el 25 octubre 2021
- En la impresora J55 Prime, al establecer una configuración de material donde los únicos colores disponibles son el blanco y el negro, hemos agregado un nuevo control deslizante de escala de grises. Además, cuando se carguen texturas, utilizarán el perfil B/N.
- Se corrigió un problema que causaba que los cambios en el grosor del cuerpo de un modelo no se guardaran al guardar un proyecto.
- Se corrigió un problema que causaba que la configuración del cuerpo y la cara de un proyecto no se guardaran cuando un modelo incluía un orificio autoportante.
Versión de GrabCAD Print 1.58, septiembre 2021
Número de compilación 1.58.9.11590 liberado el 23 septiembre 2021
- "Mantener la configuración del proyecto" permite que los proyectos de las impresoras FDM mantengan su configuración cuando se cambia el proyecto a una impresora del mismo tipo (por ejemplo, de Stratasys F370 a Stratasys F370). Puede optar por mantener la configuración de impresión actual incluso si no coincide con la impresora nueva, o actualizar la configuración en función de la impresora nueva.
- Se ha corregido un error presente en algunas impresiones PolyJet a todo color en las que el núcleo blanco se imprimía a pesar de que se seleccionara "Apariencia del cuerpo". Los proyectos guardados en 1.56 o 1.57 donde la configuración del núcleo se haya modificado manualmente deben volver a crearse.
Versión de GrabCAD Print 1.57, agosto 2021
Número de compilación 1.57.8.10644 liberado el 19 agosto 2021
- Presentamos Stratasys® J55™ Prime, una actualización revolucionaria de la J55™. La impresora 3D J55 Prime presenta alta fidelidad a todo color con capacidades táctiles, funcionales y sensoriales para que la eficiencia y la calidad de la tecnología PolyJet sea más asequibles e ideal para la oficina que nunca. Posee avanzadas capacidades de impresión con la combinación de materiales Shore similares a la goma (Elastico™), de alto impacto (ABS digital), rígido ultra visual (VeroUltra™, DraftGrey), translúcido (VeroUltra™ClearS) y biocompatible (Vero™ContactClear). Cree de todo, desde rápidas iteraciones de diseño hasta prototipos finales de alta calidad en un proceso compacto, silencioso e inodoro. Conozca la nueva J55 Prime aquí.
- Presentamos la Stratasys® J35™ Pro. Basada en la plataforma de bandeja giratoria de la J55™ Prime, la J35™ Pro es una solución de impresión 3D PolyJet de bajo costo ideal para entornos de oficina compartida con capacidad de múltiples materiales para el diseño funcional y el modelado de conceptos. La nueva impresora 3D incluye avanzadas capacidades de impresión con la combinación de materiales Shore similares a la goma (Elastico™), de alto impacto (ABS digital), rígido ultra visual (VeroUltra™, DraftGrey), translúcido (VeroUltra™ClearS) y biocompatible (Vero™ContactClear). Su tamaño compacto facilita la instalación en la oficina y el sistema de filtración ProAero elimina por completo los olores en el entorno de trabajo. Conozca la nueva J35 Pro aquí.
- Por primera vez, hemos realizado una actualización a mitad de ciclo del soporte de versiones CAD de impresora. La
- La Vista previa del corte ahora permite controlar la visualización de anclajes y estabilizadores.
- Los anclajes y estabilizadores se muestran en su propio color para que puedan distinguirse fácilmente del modelo y los soportes.
- Desactive la visualización de anclajes y estabilizadores mediante las opciones de la lista de visualización para facilitar la inspección del modelo.
- Las opciones para la visualización de anclajes y estabilizadores aparecen solo si el trabajo incluye estas características.
- El sistema recuerda las configuraciones de la visualización de anclajes y estabilizadores la próxima vez que ingresa a la Vista previa del corte.
- Además, el color del Resalte de capa ahora es blanco transparente para que pueda comprender mejor qué partes de un corte son modelo, soportes, anclajes y estabilizadores.
- Dos actualizaciones para la impresora de anatomía digital:
- Imprima modelos de tejido graso subcutáneo ultrarrealistas con un total de 6 preajustes nuevos utilizando una mezcla de TissueMatrix y GelMatrix. Las principales características del modelo que varían en suavidad son tejido graso subcutáneo contráctil (muy suave) y tejido graso subcutáneo altamente contráctil (máxima suavidad) con las siguientes opciones de recubrimiento:
- Recubrimiento rígido: recubierto con 2 mm de Agilus para crear un modelo independiente más duradero.
- Recubrimiento suave: recubierto con una mezcla de 2 mm de Agilus y GelMatrix que le otorga una apariencia y sensación realista, suave y viscosa a la muestra independiente.
- No encapsulado: sin recubrimiento para usarse en aplicaciones en las que el tejido graso se incorporará como parte del modelo de un órgano.
- Las capacidades mejoradas de GelMatrix ofrecen más opciones de modelado anatómico y requieren un posprocesamiento más simple y breve. Busque dos funciones nuevas en el menú Configuración del modelo de anatomía:
- Imprimir varias anatomías utilizando GelMatrix como material de soporte
- Imprimir utilizando material GelMatrix puro sin ningún otro material
Versión de GrabCAD Print 1.56, julio 2021
Número de compilación 1.56.11.9996 liberado el 20 julio 2021
- El panel de configuración del modelo PolyJet ahora incluye una sección llamada Preajustes. Ya existe una sección de Favoritos que son solo para la selección de color, pero los Preajustes incluyen color y todas las demás configuraciones del modelo. Haga clic con el botón derecho en una parte de la bandeja para guardar un Preajuste. Una vez que se agrega el Preajuste, puede hacer clic derecho sobre él y definirlo como valor predeterminado. Así, el Preajuste se aplicará a los modelos que se agreguen posteriormente a la bandeja.
- Novedades de la serie J8 Prime: "Optimizar para empaque" da una gran apariencia a los prototipos de empaque con un flujo de trabajo sencillo. Utilizando una traducción pionera de transparencia de RGB a los colores impresos, los usuarios ahora pueden obtener transparencias más precisas para volúmenes como líquidos o un vidrio de color. Además de esto, se crea una base blanca automática detrás de las etiquetas para dar una excelente apariencia a los gráficos con una alta opacidad. Esta opción está disponible en impresoras J8 a todo color que utilizan colores Vero Vivid, UltraWhite+UltraBlack y UltraClear, y para archivos 3MF de Keyshot. (Comuníquese con print@grabcad.com para habilitar esta función).
- Mejoras en la función de anclaje:
- Para simplificar la creación y edición de Anclajes entre el modelo y la bandeja (el caso de uso más frecuente), la Vista del modelo se ajusta automáticamente en la Vista inferior cuando se abre el panel Anclaje.
- La bandeja cambia a una vista previa delgada cuando se editan los anclajes y la vista del modelo es frontal, posterior, izquierda o derecha, lo que facilita la inspección de la geometría de vista previa de los anclajes en un conjunto. Cuando se cierra el panel Anclaje, se restaura la vista de la bandeja más gruesa.
- Se agregó la punta del modelo T20F para Antero 800NA en las plataformas Stratasys F900 y Fortus 450mc, y para Antero 840CN03 en la plataforma F900. La punta del modelo T20F proporciona hasta un 20% de rendimiento mecánico mejorado en comparación con la punta del modelo T20D actual, con la misma calidad y precisión de pieza. Para utilizar la punta del modelo T20F, seleccione T20F de 0.0100 pulg | (T20F de 0.2540 mm | T20F) en el menú desplegable Altura del corte después de seleccionar el material compatible.
- La versión de firmware 4.11.0 está disponible para las impresoras Stratasys F900 y Fortus 900mc. Esta actualización no está disponible con el archivo de actualización estándar descargado (.upg). Póngase en contacto con un representante de servicio o con el servicio de atención al cliente de Stratasys para obtener información sobre esta importante actualización.
Versión de GrabCAD Print 1.55, junio 2021
Número de compilación 1.55.8.8912 liberado el 16 junio 2021
- El mouse SpaceMouse 3D ahora es compatible para la manipulación de vistas en GrabCAD Print. Vea un tutorial sobre eso aquí.
- Para modelos cortos y anchos que pueden curvarse al enfriarse, la función de anclaje le permite asegurar el modelo a la bandeja de construcción durante la impresión. La función de anclaje es una columna hecha de material del modelo que fija las superficies horizontales orientadas hacia abajo de un modelo a la bandeja de construcción. Los anclajes pueden ser cilindros o conos, creados individualmente o en conjuntos que comparten un estilo y diámetro(s). haga clic aquí para obtener más información sobre la configuración de anclajes. (Compatible con las impresoras de las series Stratasys F770, F370, F270, F170, F900 y Fortus).
- Los estabilizadores ahora exigen que seleccione una curva de referencia antes de generar. Esto evita que se cree instantáneamente un estabilizador cuando el panel se abre por primera vez y le permite ajustar la configuración antes de generar el estabilizador.
- Presentamos J5 MediJet ™, la nueva impresora médica todo en uno diseñada para modelos anatómicos, guías quirúrgicas y herramientas médicas que utilizan materiales esterilizables y biocompatibles. La J5 MediJet está estableciendo un nuevo estándar para las aplicaciones de impresión médica 3D. Con múltiples materiales y capacidades multicolores, puede crear modelos anatómicos brillantes y vívidos, guías de perforación y corte y herramientas médicas que son esterilizables y biocompatibles, todo en un sistema certificado. Además, es lo suficientemente económica y compacta para espacios de laboratorio pequeños. Obtenga más información aquí.
- Una nueva herramienta en el menú de la derecha para impresoras PolyJet le permite establecer la posición exacta en la bandeja usando las unidades definidas en Preferencias.
- Aviso: en la próxima versión, los medios tonos de color avanzados en las impresoras de la serie J a todo color se marcarán de forma predeterminada para las nuevas bandejas cuando se utilice VeroPureWhite a todo color.
Versión de GrabCAD Print 1.54, mayo 2021
Número de compilación 1.54.6.7969 liberado el 18 mayo 2021
- La impresora Stratasys F770 ™ 3D cuenta con la cámara de construcción completamente calentada más larga del mercado: 46 pulgadas en diagonal. El espacio de construcción amplio tiene más de 13 pies cúbicos (372 litros), lo que ofrece nuevas oportunidades para aplicaciones de fabricación, creación de prototipos y piezas de producción que simplemente no están disponibles con impresoras más pequeñas. Obtenga más información sobre Stratasys F770 aquí.
- Para modelos altos y delgados que no requieren mucho soporte tradicional, la nueva función Estabilizador le permite agregar andamiaje para el modelo a medida que se construye. El estabilizador es una estructura de soporte alta que se adhiere al costado del modelo a intervalos regulares, brindando soporte adicional y minimizando las vibraciones. Haga clic aquí para obtener más información sobre la configuración de estabilizadores. (Compatible con las impresoras de las series Stratasys F770, F370, F270, F170, F900 y Fortus).
- Se solucionó un problema por el cual la casilla de verificación “Usar relleno de ancho variable” estaba deshabilitada para impresoras de la serie F123.
- Para tapar superficies de un modelo FDM, se corrigieron estos problemas de trayectoria:
- Las superficies de recubrimiento pequeñas ya no reciben el doble del relleno de trama que requieren.
- Los agujeros pequeños en las superficies de recubrimiento ya no se ignoran.
- La función GrabCAD Labs se introdujo en 1.48. Ella le permite asignar diferentes acabados PolyJet (mate o brillante) a los componentes de un ensamblaje. Ya no es una opción y siempre está disponible.
Versión de GrabCAD Print 1.53, abril 2021
Número de compilación 1.53.15.7152 liberado el 20 abril 2021
- Cuando selecciona Vista previa del corte, el valor predeterminado para el rango de capa ahora es “Todas las capas”. Los cambios en el rango de capas se recordarán la próxima vez que seleccione Vista previa del corte.
- Estos nuevos materiales opacos permiten imprimir modelos de plástico delgados y realistas, ofrecen una mayor gama de colores de alta precisión, texto nítido para imprimir etiquetas de empaque y tonos de piel suaves y de alta resolución.
Versión de GrabCAD Print 1.52, marzo 2021
Número de compilación 1.52.8.6136 liberado el 16 marzo 2021
Haga clic aquí para ver un video sobre la 1.52 actualización.
- El ABS reforzado con fibra de carbono está disponible en las impresoras Stratasys F370, Stratasys F270 y Stratasys F170. Stratasys ABS-CF10 combina material ABS estándar (acrilonitrilo butadieno estireno) con 10% de fibra de carbono cortada por peso. El resultado es un termoplástico FDM® de baja sensibilidad a la humedad un 50% más rígido y un 15% más resistente que el material de impresión ABS 3D estándar. Las aplicaciones típicas incluyen herramientas de fabricación, plantillas, accesorios y efectores finales que se benefician de la combinación de mayor rigidez y peso reducido. ABS-CF10 es compatible con alturas de corte de 0.0070 pulgadas (0.1778 mm), 0.0100 pulgadas (0.2540 mm) y 0.0130 pulgadas (0.3302 mm). Puede encontrar más información sobre el nuevo material ABS-CF10 aquí.
- Presentamos la J5 DentaJet ™. Basada en la plataforma J55, la impresora J5 DentaJet 3D es la última incorporación a nuestra línea multimaterial de impresoras dentales 3D, que permite a los técnicos cargar bandejas mixtas de piezas dentales. La nueva impresora 3D puede producir al menos cinco veces más piezas dentales en una sola bandeja mixta que las impresoras 3D de la competencia; sin embargo, su tamaño compacto consume solo 4.6 pies cuadrados (. 43 m2) de espacio en el piso. Conozca la nueva J5 DentaJet aquí.
- Se mejoraron las capas base y las capas de interfaz entre las estructuras de soporte y los modelos hechos de Antero 840CN03, lo que aumenta la calidad de las superficies del modelo orientadas hacia abajo. Las estructuras de soporte también cambiaron para aumentar su estabilidad.
- Para Diran 410MF07, altura de corte de 0.0010 pulg. (0.2540 mm), el grosor mínimo del cuerpo se reduce a 0.0200 pulgada(s) (0.5080 mm) para relleno sólido; el ángulo autoportante predeterminado se redujo a 45 grados, y se actualizaron otras configuraciones de impresión para mejorar la calidad de impresión general de los modelos.
- nueva Anatomía del hígado ahora está disponible en la impresora de anatomía digital.4 nuevos preajustes de anatomías hepáticas con diferentes valores de compresión, todos validados con datos disponibles en un informe Biomecánico completo. Variación de muy contráctil a moderadamente rígido con una capa de recubrimiento variable. Puede encontrar más datos sobre la prueba realizadaaquí.
Versión de GrabCAD Print 1.51, febrero 2021
Número de compilación 1.51.18.5360 liberado el 22 febrero 2021
Haga clic aquí para ver un video sobre la 1.51 actualización.
- Ahora puede imprimir archivos de las últimas versiones de la mayoría de los paquetes CAD, incluidos SOLIDWORKS 2021, Inventor 2021 y Creo 7. Revise aquí la lista completa de archivos compatibles. GrabCAD Print versión 1.50, enero 2021
- Presentamos la J850 Pro, una impresora PolyJet de 7 materiales creada específicamente para la creación rápida de prototipos. La J850 Pro tiene el mismo volumen de construcción y capacidad de material que la J850 Prime (antes conocida como J850), pero donde la J850 Prime sobresale en la creación de prototipos CMF, la J850 Pro está diseñada para brindar velocidad y rendimiento con ABS digital, materiales flexibles Agilus, DraftGrey y el modo de velocidad súper alta. Conozca la nueva línea de la serie J8 aquí.
- Una nueva ventana de resumen de impresión reúne cómodamente la configuración, las estimaciones, las opciones de inicio diferido y cualquier advertencia o notificación que necesite ver cuando presiona “Imprimir” para un trabajo de PolyJet.
- Cuando los modelos se reparan en modo de análisis, cualquier cuerpo que tenga un volumen cero, como cuerpos de lámina y capas de ruido, se ocultará automáticamente, ya que estos cuerpos no se pueden interpretar y pueden causar errores de estimación o de impresión.
- Se mejoró la representación gráfica de los archivos CMB en la vista de bandeja. La pantalla CMB ofrece más detalles sobre la forma real del modelo. Los bolsillos que antes se ignoraban ahora se identifican y se muestran. Con la pantalla CMB mejorada, un usuario no tiene que ingresar una Vista previa del corte para comprender el modelo que resulta de una impresión CMB.
- Las barras de menú y los menús de GrabCAD Print pueden cambiar de color para seguir los establecidos en su tema de Windows.
Versión de GrabCAD Print 1.50, enero 2021
Número de compilación 1.50.14.4357 liberado el 19 enero 2021
- Cuando está disponible una actualización para GrabCAD Print, una preferencia (introducida en la versión 1.22) determina si la actualización se instalará automáticamente la próxima vez que se inicie la aplicación. Esta estaba activada de forma predeterminada, pero ahora todo el mundo tendrá esta preferencia desactivada. Las actualizaciones futuras solo se instalarán cuando haga clic en el botón Actualizar ahora y, si lo desea, puede optar por las actualizaciones automáticas en Archivo > Preferencias > Actualizaciones.
- La detección de choques en la carga del modelo ahora puede detectar y advertirle de situaciones en las que los modelos se superponen. Para la impresión en PolyJet, esto le ayudará a determinar dónde puede necesitar cambiar la prioridad de las piezas. Nota: la detección de conflictos está desactivada de forma predeterminada y se habilita en Preferencias > Configuración de inserción del modelo > Detectar conflictos en ensamblados automáticamente
- Cuando inserta un ensamblado con una estructura plana en una impresora serie J, la prioridad predeterminada ahora es visible en la lista de archivos de inmediato. Anteriormente, era necesario realizar un cambio en la prioridad de la pieza para poder verla.
- Cuando utilice Negro + Blanco en impresoras de la serie J, ahora tendrá un control deslizante de escala de grises que funciona con el perfil de color B/N, reemplazando el selector de color a todo color existente.
- DraftGrey, que anteriormente era exclusivo de la nueva versión V5 de la impresora Objet30, ahora está disponible en impresoras V3 (aparece como VeroGrey). Haga clic aquí para obtener más información. Además, esta actualización habilita el modo de alta calidad con materiales Vero.
- En la versión 1.49, algunas impresoras Connex informaban incorrectamente una versión incorrecta del controlador de gráficos. Esto se solucionó con la versión 1.50.
Versión de GrabCAD Print 1.49, diciembre 2020
Número de compilación 1.49.12.3309 liberado el 16 diciembre 2020
- El kit de actualización J4100 está disponible para la impresora Objet1000. El kit mejora las capacidades de la impresora Objet1000 con nueva tecnología de cabezales de impresión y ofertas de materiales más avanzados. Los nuevos cabezales de impresión aportan un canal de modelo adicional (3) para aumentar el rendimiento y la productividad hasta en un 90%. La oferta de materiales ahora incluye la familia Agilus, UltraClear y VeroPureWhite. La J4100 ahora permite imprimir materiales flexibles sobre ABS digital (sobremoldeo).
- Algunos usuarios de la serie J tenían el problema de que no podían imprimir en sus impresoras de la serie J porque los trabajos se atascaban en el procesamiento. Esto era causado por controladores de gráficos obsoletos en la PC de la impresora, pero GCP no pudo detectar el problema. Esto se solucionó y, si se encuentra en esta situación, ahora verá un mensaje que le indicará el enlace para actualizar los controladores.
- Correcciones de software relacionadas con CMB
- Se restauró la opción de incluir/excluir la pieza de purga/torre de sacrificios en la exportación de CMB.
- Se restauró la capacidad de incluir una torre de sacrificios adicional en una bandeja que contiene un CMB.
Versión de GrabCAD Print 1.48, noviembre 2020
Número de compilación 1.48.14.2323 liberado el 17 noviembre 2020
Haga clic aquí para ver un video sobre la 1.48 actualización.
GrabCAD Print ahora es compatible con las impresoras de escritorio Objet30. Además de las impresoras Objet30 V3 existentes (conocidas como Objet30, Objet30 Pro u Objet30 Prime), se lanza una nueva generación: la Objet30 V5 Pro y Prime. Los modelos V5 son impresoras de un solo color, fáciles de usar, con un tamaño reducido y una calidad de impresión insuperable. Ofrecen 3 modos de impresión y una variedad de 13 materiales para modelos, incluido DraftGrey, y materiales flexibles y biocompatibles (solo Prime). Para utilizar GrabCAD Print con su Objet30, deberá seguir esta guía: Configuración de sus impresoras PolyJet para GrabCAD Print
La opción Estilo de base ahora está disponible en el panel Configuración de soporte para impresoras FDM
- Modelo y soportes: las bases se agregan debajo del modelo y las huellas de soporte. Cuando las bases se superponen, se fusionan en una base común. Cuando las bases forman bucles cerrados, el bucle se llena, creando una base grande y estable.
- Solo modelo: las bases solo se agregan debajo de la huella del modelo. Los soportes se extienden hasta la bandeja y los bucles no se llenan.
- Una nueva opción en Archivo > Preferencias > GrabCAD Labs le permite combinar acabados entre mate y brillante en cuerpos en ensamblados para impresoras PolyJet.
- Un nuevo modo de impresión, Velocidad súper alta, ahora está disponible en las impresoras J826. Este nuevo modo ofrece el doble de rendimiento que el modo de alta velocidad y es práctico para numerosas aplicaciones, como la impresión de modelos de concepto rápido.
- Para trabajos que utilizan material de modelo ASA con la punta de extrusión T40 (0.0200 pulgadas, 0.5080 mm de altura de corte) en modeladores Stratasys F900 y Fortus 900mc que utilizan materiales de soporte SR30 o SR35, las propiedades de construcción de las capas se extienden debajo de la primera capa de la pieza para mejorar la calidad de la primera capa de la pieza y evitar la delaminación.
- Para trabajos en Stratasys F900 con material de modelo ASA que utilizan la punta del modelo T40 (0.0200 pulgadas, 0.5080 mm de altura de corte), se ha mejorado la precisión de la estimación de tiempo y volumen. Este cambio está diseñado para usarse con el nuevo firmware del sistema 4.10. 0. Tenga en cuenta que esta actualización de firmware no estará disponible a través del archivo de actualización estándar descargado (.upg). Póngase en contacto con un representante de servicio o con Atención al cliente de Stratasys para obtener información sobre esta importante actualización del software del sistema.
Versión de GrabCAD Print 1.47, octubre 2020
Número de compilación 1.47.20.1644 liberado el 20 octubre 2020
Haga clic aquí para ver un video sobre la 1.47 actualización.
- La apariencia y la densidad de superficie de las superficies orientadas hacia arriba mejoran para ABS y ASA cuando se usa una altura de corte de 0.0100 pulgadas (0.2540 mm) en la impresora Stratasys F370.
- Relleno remanente mejorado mediante una mejor detección de regiones cortas y delgadas para rellenar con sendas remanentes de ancho variable.
- Ahora es posible seleccionar modelos con distintos estados de simplificación de visualización y configurar globalmente todos los modelos seleccionados en Resolución completa o Simplificado.
- Las texturas configuradas como transparentes en SolidWorks ahora se importan correctamente a GrabCAD Print con la transparencia correcta.
- UltraclearS simula el acrílico, lo que permite lograr un 95% de transmisión de luz de ese material y es útil para prototipos de vidrio, polímeros transparentes o empaques transparentes. VeroUltraClear mejora el rendimiento anterior de VeroClear con un mayor nivel de claridad, transparencia y un índice amarillo más bajo.
- La opción de núcleo de soporte ahora también está disponible en la impresora J55. El núcleo de soporte (anteriormente conocido como “Hueco”) le permite imprimir el núcleo del material de soporte. Antes de usar la opción, actívela en Preferencias > GrabCAD Labs.
- La sectorización de hueso para la impresora de anatomía digital le permite diseccionar un modelo óseo en secciones para imitar fracturas o quitar piezas de la bandeja que son irrelevantes para la aplicación.
- Las opciones de perfil de color y textura que estaban anteriormente dentro de la ventana “Cambiar materiales” se movieron a la sección Avanzado en el panel de herramientas Configuraciones de bandeja.
Versión de GrabCAD Print 1.46, septiembre 2020
Número de compilación 1.46.21.661 liberado el 15 septiembre 2020
Número de compilación 1.46.22.826 liberado el 18 septiembre 2020
Haga clic aquí para ver un video sobre la 1.46 actualización.
- La configuración “Hueco”, que anteriormente era una casilla de verificación en la Configuración del modelo PolyJet ahora está disponible como la opción “Soporte” en Opciones de base y núcleo. Además, la preferencia “Núcleo mixto” publicada en la versión 1.42 ahora está activada de forma predeterminada.
- Nuevas características de la impresora de anatomía digital
- Vista previa de hueso: permite obtener una vista previa de corte por corte de la estructura interna de un hueso para validar que la estructura coincide con su intención.
- Extremos abiertos/cerrados: crea una “ventana” en la estructura interna de un hueso. Puede marcar una sección transversal plana de un hueso y luego optar por recubrirlo con un material transparente o dejarlo como está, es decir, expuesto al aire libre.
- La compatibilidad con archivos 3MF, que se introdujo como una característica de Labs en la versión 1.40, ahora está disponible en forma generalizada.
- Los archivos de SOLIDWORKS con texturas con fondos transparentes ahora se cargarán en GrabCAD Print correctamente, mostrando la apariencia subyacente a través del fondo transparente.
- Antero ™ 840 CN03 ahora es compatible con Fortus 450mc. Antero 840 CN03 es una combinación del material del modelo Stratasys® Antero 800NA que tiene propiedades de descarga electrostática (ESD) y es compatible para su uso en aplicaciones de fabricación que utilizan piezas y componentes electrónicos sensibles al contacto. Existe una altura de corte disponible para Antero 840CN03: 0.010 pulgadas (0.2540 mm). Para obtener información sobre este material, lea aquí.
Versión de GrabCAD Print 1.45, agosto 2020
Número de compilación 1.45.21.65369 liberado el 25 agosto 2020
Haga clic aquí para ver un video sobre la 1.45 actualización.
- El modo de impresión de PolyJet se puede seleccionar de antemano al preparar trabajos de impresión. Solo se muestran las funciones y configuraciones disponibles para el modo de impresión seleccionado, lo que facilita la preparación del trabajo. Según el modo de impresión seleccionado, las características y la configuración no disponibles seguirán deshabilitadas con una explicación del motivo por el que no están disponibles.
- ¡Presentamos el estilo Corte adaptativo para FDM! El estilo de corte adaptativo usa la altura seleccionada para las entidades que requieren más detalles (como domos, empalmes y chaflanes) y una altura de corte más gruesa donde no se necesitan detalles. El resultado es una impresión más rápida (según la geometría y la altura del corte, hasta un 24% más rápido). el Estilo de corte es una nueva opción que establece cómo se cortará un modelo. Lea más aquí.
- La preferencia de Configuraciones de pantalla > Calidad de gráficos ahora controla el nivel de simplificación que se aplica a los modelos que se utilizan para la visualización gráfica. Nota: el modelo que se imprime permanece en resolución completa. Existe una opción de menú de clic con el botón derecho Resolución de gráficos que puede alternar la visualización de los modelos seleccionados entre visualización de resolución simplificada y completa.
- Ahora existe una preferencia que se aplica a todos los tipos de archivos para elegir el estado de carga de los ensamblados, ya sea ensamblados o desensamblados.
Versión de GrabCAD Print 1.44, julio 2020
Número de compilación 1.44.22.64105 liberado el 22 julio 2020
Haga clic aquí para ver un video sobre la 1.44 actualización.
- Las asignaciones de Núcleo/Base se pueden personalizar para proporcionar la mejor combinación para el diseño de un modelo.
- La característica de organización automática para las impresoras J720 ofrece un anidamiento mejorado de piezas, lo que aumenta la eficiencia de la producción.
- GrabCAD Print Server anterior a la versión 2.0 ya no se podrá conectar a GrabCAD Cloud a partir del julio 21. Para seguir conectándose a sus impresoras a través de GrabCAD Print Server, desinstale manualmente la versión anterior e instale Print Server 2.0. Puede descargar la última versión aquí.
- GrabCAD Print Server 2.0 solo será compatible con Microsoft Windows 10 (de 64 bits) y Windows Server 2016 y versiones posteriores. Las instancias que se ejecutan en versiones anteriores de Windows que no reciben soporte estándar de Microsoft no se actualizarán automáticamente ni se podrán conectar a GrabCAD Cloud a partir del julio 21. Deberá actualizar el sistema operativo en su instancia de Print Server o instalar Print Server en una máquina con un sistema operativo compatible.
- GrabCAD Print se está trasladando a una instalación de todo el sistema (por máquina). Si esto le afecta, se le notificará cuando haya una actualización disponible y la migración (normalmente) no requerirá ningún esfuerzo de su parte. Después de la versión 1.47, deberá migrar a nuestra instalación por máquina para seguir recibiendo actualizaciones.
- GrabCAD Print ahora le permite enviar archivos de diagnóstico desde su impresora a su contacto de soporte de Stratasys. En caso de problemas de hardware, material, otras impresoras o incluso software, ahora puede ir a Ayuda -> Obtener soporte de impresora, donde puede agregar detalles sobre el problema. GrabCAD Print generará una plantilla de correo electrónico junto con todos los detalles y archivos relevantes, que puede enviar a la dirección de correo electrónico que se le proporcionó en el momento de la venta.
- 3Los archivos MF con una estructura de ensamblado profunda (de varios niveles) ahora mostrarán la estructura de árbol completa en el panel Proyecto.
Versión de GrabCAD Print 1.43, junio 2020
Número de compilación 1.43.17.62943 liberado el 17 junio 2020
Haga clic aquí para ver un video sobre la 1.43 actualización.
- Ahora que las características de Advanced FDM están disponibles en GrabCAD Print, ya no es necesario crear proyectos avanzados de FDM. La opción “Activar Advanced FDM” se eliminó del menú Preferencias y la acción para crear un nuevo Proyecto de Advanced FDM se quitó de la barra de herramientas a la izquierda.
- Como parte del traslado de la funcionalidad de Advanced FDM al núcleo de GrabCAD Print, los proyectos que se crearon en Advanced FDM se abrirán en GrabCAD Print, con cada modelo en una bandeja separada. Se mantienen los grupos, al igual que las configuraciones de cuerpo, las configuraciones de cara, las propiedades de bandeja, la orientación y las notas de fabricación.
- El algoritmo que traduce archivos VRML, OBJ y 3MF en objetos imprimibles se reescribió para evitar errores de corte.
- Si selecciona el cuerpo de un VRML que tiene un color sólido, el selector de color ahora mostrará el color directamente y le permitirá realizar pequeños ajustes.
- Dos nuevas características de la impresora de anatomía digital
- La Herramienta de eje de huesos largos permite al usuario definir las regiones proximal y distal de un hueso largo. Esto permite la impresión de piezas con densidad variable para aproximarse a la estructura de los huesos largos.
- Múltiples procedimientos ortopédicos requieren perforar orificios e insertar tornillos en modelos impresos. En algunas ocasiones, esto puede dar lugar a grietas no deseadas. Para evitar esto, la Herramienta de alivio de tensión le permite establecer un perímetro diseñado para contener cualquier agrietamiento, evitando así un agrietamiento más amplio en la pieza impresa.
- Presentamos la Stratasys J55. Cree sin comprometer cada paso del camino. Desde modelos de concepto rápido hasta modelos de alta fidelidad de calidad, la impresora J55 3D, apta para oficinas, es una opción asequible para obtener el máximo rendimiento del diseñador. Obtenga más información aquí.
Versión de GrabCAD Print 1.42, mayo 2020
Número de compilación 1.42.19.62279 liberado el 20 mayo 2020
Haga clic aquí para ver un video sobre la 1.42 actualización.
- Posicione y oriente sus modelos más fácilmente con el nuevo manipulador. Haga clic en el botón más a la derecha en la franja de control de vista para habilitarlo y luego, los modelos seleccionados mostrarán flechas en las que puede hacer clic y puede arrastrar para mover y rotar su selección libremente o a lo largo de un eje preciso.
- Para las impresoras FDM, el espacio entre los modelos en una bandeja ahora se puede ajustar desde un mínimo de 0.2500 pulgadas (6.35 mm) a un máximo de 2.0000 pulgadas (50.8 mm) con un control deslizante en el panel de la herramienta Organizar. Esto le permitirá empaquetar los modelos con más fuerza en la bandeja o mantenerlos más separados para optimizar el flujo de aire.
- Los nuevos perfiles de color CMYKW y CMYW que se agregaron en 1.41 ahora son los perfiles de color predeterminados cuando se cargan materiales Vivid CMYKW y CMYW en la impresora. El nombre del perfil es X-Rite i1Profiler CMYKW o CMYK.
- Anteriormente, el núcleo de una pieza de PolyJet se imprimía con capas alternas de material en blanco y negro, pero una nueva preferencia de “Núcleo mixto” en Archivo > Preferencias > PolyJet permite que el núcleo se imprima con una combinación de todos los materiales disponibles. Esto reduce en gran medida la probabilidad de problemas de obstrucción de las boquillas, puesto que cada cabezal de impresión se utilizará con más frecuencia, pero requiere que cada cartucho de material cargado tenga suficiente material para completar el trabajo.
Versión de GrabCAD Print 1.41, abril 2020
Número de compilación 1.41.31.61723 liberado el 27 abril 2020
Haga clic aquí para ver un video sobre la 1.41 actualización.
- Las últimas versiones de paquetes CAD ahora son compatibles con GrabCAD Print. Esto incluye SOLIDWORKS 2020, Inventor 2020, Creo 6.0 y más. Lea la lista completa aquí.
- Ahora, puede cambiar el material utilizado en la cuadrícula de soporte de impresiones de la serie J para guardar los materiales de uso más frecuente. Todas las estructuras de soporte de la Bandeja se imprimirán con los materiales seleccionados. Puede efectuar la selección de material en Configuraciones de bandeja> Avanzado> Material utilizado para fortalecer el soporte.
- En un esfuerzo por incorporar más funcionalidad de Advanced FDM a Print, ahora puede aplicar distintas configuraciones de material a los cuerpos dentro de Grupos. Si hace clic con el botón derecho en el Grupo, puede alternar entre:
- Cuerpos separados: los cuerpos y las caras pueden tener ajustes aplicados independientemente de otros cuerpos y caras. Esto es similar a cómo funciona Advanced FDM.
- Cuerpos combinados: todos los cuerpos del Grupo actúan como un solo cuerpo, con una configuración de cuerpo que se aplica a todo el Grupo y se eliminan los límites internos. Esto es similar a cómo funcionan normalmente los ensamblados cuando elige “Ensamblado” sin crear un Grupo.
- Cuando un grupo ensamblado tiene “Cuerpos separados” seleccionados, el grosor de la superficie, la ubicación de la costura y las inserciones están disponibles en el panel Configuración del modelo, en la pestaña Cara. Anteriormente, esta funcionalidad solo estaba disponible en Advanced FDM.
- Las pequeñas características que necesitan soporte en las impresiones FDM generan una compatibilidad que se amplía debajo de la característica. Esto ahora se puede controlar mediante la configuración Soportes de crecimiento, que le permite cambiar del valor predeterminado de “Solo soportes de crecimiento pequeños” a "No cultivar soportes" o “Sin soportes de crecimiento”. Desactivar el soporte de crecimiento puede resultar útil para reducir el uso de material y el tiempo de impresión de algunas piezas.
- Se han agregado nuevos perfiles de color Vivid 2.0 a GrabCAD Print, que ofrecen una reproducción del color mejorada. Los perfiles de color predeterminados no han cambiado y siguen siendo Vivid 1.1.
- Los ensamblados de SOLIDWORKS con colores de cara ahora se pueden cargar directamente en GrabCAD Print sin el paso adicional de guardarlos como una pieza de varios cuerpos.
- Para impresoras FDM, los archivos MF3 con estructura de ensamblado ahora se cargarán con su estructura.
- Cuando cambie una configuración de FDM en un control deslizante, un diamante negro indicará el valor predeterminado. Al hacer clic en él, se restaura el valor predeterminado.
- Con esta versión de GrabCAD Print, puede abrir fácilmente archivos de pedidos de GrabCAD Shop en su bandeja en GrabCAD Print. Esto ahorra tiempo, evita la descarga de archivos CAD de correos electrónicos u otro software de administración de solicitudes y ayuda a planificar sus bandejas de manera eficiente. Si aún no lo ha hecho, regístrese en GrabCAD Shop aquí.
- Se agregó un cuadro de entrada “Agregar por IP” a GrabCAD Print Server para conectarse fácilmente a las impresoras donde el descubrimiento automático no está disponible.
Versión de GrabCAD Print 1.40, marzo 2020
Número de compilación 1.40.28.60898 liberado el 24 marzo 2020
Haga clic aquí para ver un video sobre la 1.40 actualización.
- Los archivos de pieza de SOLIDWORKS, incluidos los archivos de varios cuerpos, ahora incluirán datos de color aplicados al nivel de la cara para la impresión en PolyJet. Anteriormente, solo los colores aplicados a nivel del cuerpo se incluían en GrabCAD Print.
- Pruebe cómo se verán los colores en el modelo impreso en su impresora PolyJet creando una muestra de colores seleccionados por el usuario. Acceda a la herramienta de muestra de colores en Aplicaciones > Herramienta de muestra de colores.
- GrabCAD Print ahora permite a los usuarios imprimir bandejas PolyJet más grandes gracias a que optimiza el consumo de memoria GPU de su computadora. Puede habilitar la característica en Preferencias > PolyJet > Optimización de bandeja pesada.
- La Cortadora avanzada es ahora la única cortadora disponible para impresoras Stratasys J750 y Stratasys J735. La cortadora heredada ya no está disponible para estas impresoras. No hay cambios en otras impresoras PolyJet.
- Cuando envía un trabajo de Insight independiente a GrabCAD Print, la versión independiente debe ser la misma versión o posterior a la versión de Insight disponible con GrabCAD Print o el trabajo no se enviará.
- Hemos actualizado el componente principal de GrabCAD Print a la última versión disponible. Esto no solo corrige algunos problemas pendientes, como la carga de archivos desde una carpeta de OneDrive, sino que también mejora el rendimiento general y el tiempo de inicio.
- GrabCAD Print ahora puede importar archivos 3MF desde numerosas herramientas CAD; en el caso de los archivos 3MF creados en SOLIDWORKS, esto incluye: color de cara, color de cuerpo y texturas. Para impresoras PolyJet, los ensamblados tendrán una estructura plana y para impresoras FDM, no habrá estructura de ensamblado.
- Mejoras específicas de FDM
- Para proporcionar una mejor calidad general de la pieza al utilizar TPU 92A en la impresora Stratasys F370, se redujo el rango de ancho para el relleno remanente de ancho variable.
- El ángulo de los orificios autoportantes se aumentó a 55 grados para adaptarse al ángulo autoportante del material Diran 410mf07.
- Se resolvió un problema por el que se podía generar un soporte incompleto para algunos modelos y orientaciones.
- El nombre predeterminado asignado a un Grupo, introducido en GrabCAD Print 1.36, ahora se puede cambiar a uno más lógico para el usuario.
Versión de GrabCAD Print 1.39, febrero 2020
Número de compilación 1.39.14.59507 liberado el 18 febrero 2020
Haga clic aquí para ver un video sobre la 1.39 actualización.
- El nuevo panel de Configuración del modelo PolyJet ofrece un diseño mejorado y flujos de trabajo del usuario, la capacidad de guardar materiales y colores favoritos y crear sus propios colores y materiales digitales utilizando la nueva función de entrada CMYK. Más información aquí.
- Cuando crea un grupo a partir de un ensamblado que tiene aplicada una escala u orientación, el grupo recién creado hereda estas propiedades del ensamblado.
- Ahora, puede eliminar una impresora desconectada de su lista de impresoras. Simplemente, haga clic con el botón derecho en la impresora que desea eliminar y seleccione “eliminar impresora”.
- Ahora hay una visualización más clara e intuitiva del estado del contenedor de desechos para las impresoras PolyJet ubicadas en el panel de materiales.
- Aviso sobre la Cortadora avanzada PolyJet: en la actualización de marzo, GrabCAD Print versión 1.40, la opción para deshabilitar la Cortadora avanzada PolyJet para J750 y J735 ya no estará disponible.
Versión de GrabCAD Print 1.38, enero 2020
Número de compilación 1.38.21.59019 liberado el 28 enero 2020
Haga clic aquí para ver un video sobre la 1.38 actualización.
- Si tiene impresoras PolyJet, puede probar el nuevo panel de configuración de modelo, que ha mejorado en su diseño y capacidad de guardar favoritos. Vaya a Archivo > Preferencias > PolyJet y seleccione la casilla de verificación para usar el nuevo panel de Configuración de modelo PolyJet.
- El nuevo material VeroUltraClear, introducido para impresoras J850 y en 1.36, ahora está disponible en la J750 y la J735. VeroUltraClear se asemeja al acrílico, logra un 95% de transmisión de luz de ese material, y es útil para prototipos de vidrio, polímeros transparentes o envases transparentes. Obtenga más información sobre el material VeroUltraClear aquí.
- Puede anular las piezas VRML/OBJ con una nueva asignación de color y material desde el panel Configuración del modelo, y restaurar de nuevo al original si es necesario, con una nueva opción de menú de clic derecho en los cuerpos VRML/OBJ seleccionados.
- El estado predeterminado de la preferencia de estructura VRML/OBJ ha cambiado de desactivado a activado.
- Los patrones del relleno para Diran 410MF07 en Advanced FDM ahora incluyen densidad simple, densidad doble y sólida. Además, el material de la primera capa se ha cambiado del soporte al material del modelo para mejorar la adhesión a la bandeja.
- Se ha resuelto un problema que causaba que se mostraran nombres de modelo incorrectos para las impresoras Stratasys en la Vista de programación.
Versión de GrabCAD Print 1.37, diciembre 2019
Número de compilación 1.37.15.57828 liberado el 18 diciembre 2019
Haga clic aquí para ver un video sobre la 1.37 actualización.
- La función de inicio diferido para las impresoras PolyJet que se introdujo en la versión 1.20 ahora es compatible con la Cortadora avanzada PolyJet. NOTA: la impresora debe estar en estado “inactivo” para que la selección esté disponible.
- Una nueva configuración de impresión PolyJet para el después del procesamiento le permite agregar una capa delgada de material transparente para el pulido. Pulir la capa transparente da como resultado un modelo con una superficie lisa y colores y texturas de alta fidelidad.
- Ahora es posible obtener una vista previa y crear un documento PDF guía que contenga las notas de fabricación y las capturas de pantalla de los modelos para la bandeja activa actualmente.
Versión de GrabCAD Print 1.36, noviembre 2019
Número de compilación 1.36.17.57117 liberado el 20 noviembre 2019
Haga clic aquí para ver un video sobre la 1.36 actualización.
- Ahora se admite la nueva impresora digital J750 ™ Anatomy™ 3D, que viene preprogramada con una serie de aplicaciones anatómicas desarrolladas en colaboración con fabricantes de dispositivos médicos, instituciones de investigación de clase mundial, hospitales y personal médico. Con precisión, realismo y funcionalidad, puede lograr la sensación, el comportamiento y las dimensiones de lo real. Obtenga más información sobre la impresora digital J750 Anatomy 3D aquí.
- Las nuevas J850 y J835 ahora son compatibles. El diseño y la creatividad son infinitos. Ahora, con la Stratasys J850/J835, lo mismo sucede con los prototipos. Nuestra tecnología probada y comprobada simplifica todo el proceso de diseño, agilizando los flujos de trabajo para que pueda dedicar más tiempo a lo que importa: crear, refinar y diseñar el mejor producto posible. Obtenga más información sobre Stratasys J850 aquí.
- Los modelos seleccionados ahora se pueden agrupar mediante un nuevo botón en la parte superior del Panel de proyectos o un comando del botón derecho del mouse. Cuando se cree un nuevo grupo, esto colapsará y ocultará el ensamblado existente. El nuevo grupo se puede configurar como ensamblado o desensamblado. Se pueden crear grupos adicionales a partir del ensamblado original.
- Existe una nueva opción en la configuración de Cortadora avanzada de PolyJet para mostrar la estructura de ensamblado de los archivos VRML y OBJ. Con esta opción habilitada, GrabCAD Print determina la estructura geométrica de los archivos VRML u OBJ y muestra la estructura como un conjunto de cuerpos en el panel de proyectos. Cada cuerpo puede ser multicolor (es decir, texturado, de color de vértice, de cara o compuesto de múltiples hojas de diferentes colores) o de un solo color (es decir, todas las hojas del cuerpo comparten un solo color difuso). El usuario puede cambiar las asignaciones de material para cualquier cuerpo de un solo color dentro de dicho ensamblado.
- Cuando importa un archivo SOLIDWORKS (.sldprt o .sldasm), los atributos de transparencia adjuntos a los cuerpos de SOLIDWORKS se convierten automáticamente en valores alfa en el panel de materiales PolyJet si se carga un material transparente.
- Las licencias de materiales para impresoras Stratasys y Fortus que requieren licencias pueden actualizarse desde GrabCAD Print. La actualización de una licencia de material requiere que un usuario tenga privilegios de administrador local.
- El Panel de proyectos ha sido rediseñado para mejorar la capacidad de uso. Los cambios incluyen iconos rediseñados, mejor alineación, resaltado de selección más claro, menú desplegable en lugar de casilla de verificación para el estado ensamblado/desensamblado y una indicación más clara del estado mostrar/ocultar.
- La selección tangente de caras ahora está disponible como comando del botón derecho del mouse cuando Imprimir está en modo de selección de caras. Esto puede ser útil cuando agrega notas de fabricación a una cadena de superficies.
- A los cuerpos y las caras se les pueden agregar anotaciones, conocidas como Notas de fabricación. El comando para agregar una nota está disponible en el botón derecho del mouse; esto agrega una leyenda que se puede activar haciendo clic para mostrar la nota y permitir su edición.
- Nuevo material VeroUltraClear para las impresoras Stratasys J850 y Stratasys J835 3D. VeroUltraClear se asemeja al acrílico, logra un 95% de transmisión de luz de ese material, y es útil para prototipos de vidrio, polímeros transparentes o envases transparentes. Obtenga más información sobre el material VeroUltraClear aquí.
- ABS ESD7 ahora es compatible con la impresora Stratasys F370 para GrabCAD Print. ABS ESD7 es un material de herramientas diseñado para aplicaciones sensibles a la electricidad estática, a fin de evitar descargas o atracción a otros materiales como polvos, polvillo o partículas finas. Obtenga más información sobre el material ABS ESD7 aquí.
Versión de GrabCAD Print 1.35, octubre 2019
Número de compilación 1.35.21.56592 liberado el 24 octubre 2019
Haga clic aquí para ver un video sobre la 1.35 actualización.
- Hemos mejorado el comportamiento tanto del botón Imprimir como de la lista de impresoras cuando se requiere una actualización de Job Manager para su Impresora PolyJet. El botón de impresión mostrará una ventana emergente y, al hacer clic en la lista de impresoras, se lo dirigirá directamente a la pantalla Configuración, donde puede realizar la actualización.
- Se ha agregado una casilla de verificación en la sección Opciones avanzadas de Configuraciones de bandeja para controlar las lámparas UV para impresoras de la serie J. Si tiene problemas de sobreexposición en sus impresiones, hable con su distribuidor o con soporte técnico de Stratasys para averiguar si esta configuración puede ayudar.
- Cuando imprime con colores Pantone en su impresora serie J, solo algunos de los colores requieren VeroBlackPlus. Anteriormente, todo el selector de colores Pantone se desactivaba si no lo tenía cargado, y ahora solo se desactivan colores específicos. Pantone todavía requiere los tres materiales Vivid Vero y VeroPureWhite.
- La carga de modelos ahora es una acción cancelable. Anteriormente, si cometía un error y seleccionaba el archivo incorrecto, tenía que esperar a que se cargara antes de poder eliminarlo, y ahora puede cancelarlo de inmediato.
- Cuando aplica la configuración a una cara específica en Advanced FDM, ahora puede eliminarla mediante el menú contextual. Anteriormente, tenía que usar Deshacer para revertir la configuración de cara.
- Soporte para nuevos materiales FDM:
- Antero 840CN03 ahora es compatible con la impresora Stratasys F900 para GrabCAD Print. Para obtener más información sobre Antero 840CN03, haga clic aquí.
- Diran 410MF07 ahora es compatible con la impresora Stratasys F370 para GrabCAD Print. Diran es el material ideal para aplicaciones de herramientas. Obtenga más información sobre el nuevo material 410Diran MF07 aquí.
- TPU 92A ahora admite un corte de 0.0070 pulgadas (0.1778 mm) en la impresora Stratasys F370. La calidad de impresión se ha mejorado para el corte 0.0070 y el corte de 0.0100 pulgadas (0.2540 mm). El software del controlador F123 debe actualizarse a la versión 2.1 para aprovechar estas mejoras.
- Eliminar historial de impresora ahora requiere que un usuario tenga privilegios de administrador local.
Versión de GrabCAD Print 1.34, septiembre 2019
Número de compilación 1.34.16.55783 liberado el 19 septiembre 2019
Haga clic aquí para ver un video sobre la 1.34 actualización.
- PolyJet Advanced Slicer, introducido como una opción en 1.31, ahora está activado de manera predeterminada. Ha mejorado la precisión en las estimaciones y permite algunas características que se enumeran aquí. Puede desactivar la opción desde Preferencias > PolyJet si necesita usar la cortadora anterior por cualquier motivo.
- Ahora, puede acceder a los Tutoriales y Archivos de ejemplos de GrabCAD en el Menú de ayuda de GrabCAD Print asociado a la impresora seleccionada. Nuestros ingenieros de aplicaciones agregan constantemente contenido nuevo para ayudarlo a utilizar mejor sus máquinas; el contenido estará disponible a través del Menú de ayuda.
- Con el botón de cambio situado en la barra de vista etiquetada “Vista previa de superficies compatibles”, puede ver rápidamente dónde se generarán los soportes en sus modelos. Esta característica se introdujo para las impresoras PolyJet en 1.24 y ahora también está disponible para impresoras FDM. Esto ofrece una alternativa más rápida que Vista previa del corte FDM para ayudar a preparar su bandeja, ya que muestra cómo la configuración de orientación y soporte (como el ángulo de autosoporte) afectará la superficie de su impresión.
- Cuando está viendo un trabajo de PolyJet en progreso en la Vista de programación o en la aplicación móvil GrabCAD Print, la “Hora de finalización” pronosticada ahora ha mejorado enormemente en precisión. La proyección se actualizará periódicamente en todo el trabajo para tener en cuenta las pausas de impresión y otros errores en la estimación inicial.
- Marcar la opción de retardo de corte en el panel de configuración de la bandeja PolyJet reducirá la aparición de depresiones en el modelo. La opción debe usarse solo después de hablar con un representante de soporte técnico de Stratays. El uso de la opción aumentará el tiempo de impresión del trabajo.
- La lista de materiales que se muestra en el panel Configuraciones de bandeja para impresoras PolyJet ahora incluye el material de soporte.
- GrabCAD Print ahora le notificará sobre actualizaciones para impresoras seleccionadas como la serie F123 y J750. Estas pueden incluir información sobre nuevos materiales, contenido de aprendizaje y otros recursos. Cuando seleccione una de estas impresoras y haya una actualización disponible, verá una caja de regalo en la parte inferior izquierda de la pantalla.
Versión de GrabCAD Print 1.33, agosto 2019
Número de compilación 1.33.10.54793 liberado el 20 agosto 2019
Haga clic aquí para ver un video sobre la 1.33 actualización.
- En las impresoras compatibles con Advanced FDM, algunas funciones avanzadas ahora están disponibles en la pestaña Configuración del modelo. Estas incluyen la densidad del relleno, el ángulo de relleno y el espesor del cuerpo, y cuando se utilizan archivos CAD, la capacidad de cambiar un orificio cilíndrico por un diamante de autosoporte.
- De manera similar al cambio realizado para el panel de configuración de FDM en la última actualización, el panel de configuración de PolyJet ahora se divide en configuraciones de bandeja y configuraciones del modelo para permitir espacio para más funcionalidad en futuras actualizaciones.
- Ahora, puede optar por exportar un CMB sin la parte de purga ni la torre de sacrificio. Esto le permite evitar que se impriman varias partes de purga cuando imprime múltiples archivos CMB en un trabajo. Por defecto, se incluye la parte de purga/torre de sacrificio.
- Para las plantillas de impresora Stratasys F900, Fortus 900mc y Fortus 400mc, ABS es ahora el material predeterminado. Para impresoras activas, el material seguirá usando la configuración actual como predeterminada.
- Aviso para usuarios de J750 y J735: la Cortadora avanzada, introducida en 1.31, estará * ON * (Activada) por defecto en la actualización de los próximos meses, versión 1.34.
Versión de GrabCAD Print 1.32, julio 2019
Número de compilación 1.32.19.54065 liberado el 22 julio 2019
Haga clic aquí para ver un video sobre la 1.32 actualización.
- El panel Configuración de impresión para la preparación de impresión FDM se ha dividido en 3 paneles: Configuración de bandeja, Configuración del modelo y Configuración de soporte. También se han agregado nuevos iconos.
- El Modo de análisis ahora puede reparar archivos VRML y OBJ con colores de vértice, y se ha mejorado la reparación de archivos con colores y texturas de cara.
- Los usuarios de J750 y J735 ahora pueden imprimir modelos opacos con materiales Vivid y Cortadora avanzada. Desactive la casilla de verificación “Translúcido” en el panel Configuración de la impresión para imprimir cuerpos con un núcleo blanco. Actualmente, esto solo funciona para archivos/ensamblados de malla sin textura.
- Un problema para algunos trabajos de Fortus y F123 estaba causando un comportamiento extraño para la parte de purga/torre de sacrificio, lo que dio lugar a errores de construcción. Esto ha sido resuelto.
- Cuando selecciona Agilus 30 Clear, su modelo se muestra en el nivel de transparencia asociado al valor Shore A que configuró.
Versión de GrabCAD Print 1.31, junio 2019
Número de compilación 1.31.52720.53058 liberado el 20 junio 2019
Haga clic aquí para ver un video sobre la 1.31 actualización.
- Advanced FDM, que se introdujo en 1.24 para las impresoras F900, F370 y Fortus, ahora está disponible para las F170 y F270. Advanced FDM le permite personalizar el relleno en diferentes secciones del modelo utilizando la geometría CAD real, así como modificar la geometría de orificio para poder imprimirla. Más información aquí.
- La Cortadora avanzada, disponible ahora en Archivo > Preferencias > Polyjet, ofrece a los usuarios de J750 y J735 una gran cantidad de mejoras y nuevas características:
- Colores Pantone® validados en el selector de colores.
- Los modelos VRML con transparencia en la textura utilizarán un núcleo transparente.
- Estimaciones y precisión de impresión mejoradas para pequeñas características y texto.
- Opciones de soporte personalizadas que corrigen el efecto de “sombra de soporte” en paredes verticales que tienen orificios.
- Prioridad de pieza personalizada cuando los componentes del ensamblado se superponen.
- Control total sobre la colocación de piezas en la bandeja.
- La nueva versión de GrabCAD Print Server se ejecuta como un servicio de Windows y seguirá ejecutándose incluso si su usuario de Windows está desconectado. Además, es compatible con Windows Server 2012 y se puede instalar junto con la versión por máquina de GrabCAD Print. Esta actualización no es automática; debe descargar la nueva versión aquí. Para obtener ayuda con la instalación, haga clic aquí.
- El modo de análisis ahora puede reparar errores de malla en archivos VRML con textura.
- El mensaje de error cuando intenta agregar un modelo de un paquete CAD que aún no es compatible, como Inventor 2020, ahora será más informativo que un error genérico.
- Para impresoras FDM, los soportes se generan siempre que el ángulo de la superficie de la pieza caiga por debajo de un valor especificado, conocido como ángulo de autosoporte, y ahora ese valor es ajustable en el panel Configuración de la impresión. Puede aumentar o disminuir la cantidad de soportes que se generan, y también restaurar el valor a la recomendación predeterminada, que varía según las distintas impresoras y materiales.
- Agregar un archivo CAD o CMB que no coincide con el archivo o la configuración en el proyecto actual de GrabCAD Print genera un conflicto en lugar de un error; una nueva advertencia le permite guardar los cambios y abrir un nuevo proyecto.
Versión de GrabCAD Print 1.30, mayo 2019
Número de compilación 1.30.28.52238 liberado el 22 mayo 2019
Haga clic aquí para ver un video sobre la 1.30 actualización.
- El historial de la impresora se puede eliminar desde la página Historial de impresora de la aplicación GrabCAD Print. La opción se habilita con una preferencia; la preferencia está activa solo para la sesión de GrabCAD. Las impresoras deben estar inactivas cuando se elimina el historial, aunque pueden tener trabajos en la cola.
- Revisamos las traducciones en GrabCAD Print y corregimos errores en 6 lugares.
Versión de GrabCAD Print 1.29, abril 2019
Número de compilación 1.29.6.51061 liberado el 16 abril 2019
Haga clic aquí para ver un video sobre la 1.29 actualización.
- Las últimas versiones de los paquetes CAD ahora son compatibles con GrabCAD Print. Esto incluye SOLIDWORKS 2019, Inventor 2019, Creo 5.0, NX 12.0 y más. Más información aquí.
- Acceda fácilmente a sus impresoras con el nuevo panel de impresoras. Esto tiene la capacidad colocar impresoras en Favoritos, búsqueda avanzada y filtrado, y muchas otras mejoras. ¡Queremos conocer su opinión al respecto! Active en Archivo > Preferencias > GrabCAD Labs y díganos lo que piensa.
- La versión Beta del miembro más nuevo de la serie Stratasys F123, F120, es compatible con GrabCAD Print. Lea sobre esto aquí.
- Ahora es posible usar material del modelo en estructuras de soporte para impresión FDM cuando selecciona estilos de soporte SMART, Sparse o Box. Como la impresora tarda unos segundos en cambiar entre el modelo y el material de soporte, esta característica permite que muchas capas del trabajo usen solo material del modelo, ahorrando tiempo en la impresión.
- Los modelos Insight ahora se pueden enviar a GrabCAD Print desde Insight con solo hacer clic en un botón. Si selecciona el icono “Crear trabajo en GrabCAD Print” en la barra de herramientas de Insight, se crea un archivo CMB, se pasa el archivo de Insight a GrabCAD Print y se selecciona automáticamente el tipo de impresora correcto.
Versión de GrabCAD Print 1.28, marzo 2019
Número de compilación 1.28.16.50383 liberado el 21 marzo 2019
Haga clic aquí para ver un video sobre la 1.28 actualización.
- ¿Carece de la tecnología o la capacidad para imprimir más piezas? Vaya a Aplicaciones > “Fabricar mi pieza con Stratasys Direct Manufacturing” para acceder a la página de inicio de SDM. (Solo para clientes de EE. UU./Canadá).
- La orientación automática ahora está disponible en la pestaña Advanced FDM. Tanto los cuerpos estándar como los fusionados se pueden orientar automáticamente, para minimizar el soporte y reducir el tiempo de construcción.
- Los archivos OBJ con texturas de imagen ahora son compatibles. Cuando imprime en impresoras PolyJet, los archivos de textura de imagen asociados al archivo OBJ se leen, muestran y el resultado fusionado se imprime.
- Se solucionó un problema de calidad de pieza cuando se usa el relleno de hexagrama en las impresoras de la serie F123. Para los materiales F123 ASA y F123 ABS, en la altura de corte de 0.005 pulgadas (0.127 mm) y 0.007 pulgadas (0.178 mm), la densidad del relleno se reduce para evitar el sobrellenado.
- Los paneles de configuración de impresión, orientación y escala se han actualizado para contar solo los modelos o cuerpos en la bandeja activa.
- Se produjo un error en el historial de la impresora que exportó desde la aplicación de escritorio donde la “Duración” mostró 00:00:00 para todos los trabajos. Esto fue corregido.
- La aplicación genera algunos archivos en el directorio temporal y, anteriormente, estos se acumulaban con el tiempo. Ahora, se borran en forma automática al cerrar la aplicación.
- Algunos usuarios encontraron un error donde no pudieron iniciar GrabCAD Print y apareció el mensaje: “Demasiadas instancias...”. Esto fue causado por el complemento GrabCAD Print para SOLIDWORKS que ahora se ha descontinuado.
Versión de GrabCAD Print 1.27, febrero 2019
Número de compilación 1.27.17.49710 liberado el 25 febrero 2019
Haga clic aquí para ver un video sobre la 1.27 actualización.
- El relleno de ancho variable, introducido en 1.24 para la serie F123 y Fortus 900mc, ahora está disponible en Fortus 380mc, 380mc CFE y 450mc. Esta característica requiere la versión 6.1 del firmware de la impresora (disponible desde 13 marzo 2019). Siga las instrucciones aquí para actualizar el firmware en su máquina.
- Cuando importe un archivo CMB para imprimir en una impresora FDM, se seleccionará automáticamente la impresora correcta. Además, ahora podrá rotar ese modelo sobre el eje Z.
- Ciertas combinaciones de materiales no están permitidas en un trabajo de impresión PolyJet, como Vero y VeroFlex, o usar solo uno de los dos materiales RGD para ABS digital. Anteriormente, si la impresora se cargaba con esta combinación de materiales no admitida, mostraba un estado de Error y la impresión quedaba deshabilitada, incluso si el trabajo en sí no utilizaba la combinación no admitida. Ahora, los usuarios podrán imprimir sus trabajos independientemente de qué materiales estén cargados actualmente en la impresora, siempre y cuando no se use la combinación no compatible en el trabajo.
Versión de GrabCAD Print 1.26, enero 2019
Número de compilación 1.26.13.48725 liberado el 28 enero 2019
- El relleno de ancho variable, introducido en GrabCAD Print 1.24 como parte del panel de Configuración de la impresión, ahora está disponible en Advanced FDM.
- La parte de purga (Serie F123) y la torre de sacrificio (algunas impresoras Fortus) se colocan automáticamente en la ubicación óptima de la bandeja, aunque se pueden mover manualmente. Ahora, cuando lo haga, permanecerán en esa ubicación hasta que use la herramienta Organizar bandeja u Organizar proyecto. También puede reubicar solo la parte de purga/torre de sacrificio haciendo clic con el botón derecho en ella y seleccionando “Buscar automáticamente”.
- El reinicio ahora está disponible para orientación en GrabCAD Print y Advanced FDM. Si selecciona un modelo y selecciona Restablecer, el modelo volverá a la orientación que tenía cuando lo agregó inicialmente a la bandeja.
- Se solucionó un problema que bloqueaba la instalación de GrabCAD Print en ciertas situaciones. Por favor, póngase en contacto con print@grabcad.com si sigue teniendo problemas con la instalación.
Versión de GrabCAD Print 1.25, diciembre 2018
Número de compilación 1.25.17.47934 liberado el 4 enero 2019
- El instalador por máquina que se lanzó para la prueba beta en 1.16 ahora está disponible generalmente desde print.grabcad.com. Además de ser mucho más estable que el instalador por usuario actual, permite la implementación en escuelas y organizaciones empresariales por parte de los administradores de sistemas de TI. Para obtener más información e instrucciones sobre el cambio, lea nuestro artículo de ayuda.
- Los archivos OBJ y VRML con autointersecciones, problemas de estanqueidad/caras abiertas y normales invertidas ahora pueden repararse con GrabCAD Print antes de imprimir en las tecnologías PolyJet. Para probarlo, por favor contacte a print@grabcad.com.
- Las sugerencias de herramientas en el panel Configuración de la impresión explican el comportamiento del relleno de ancho variable, el estilo de construcción de la pieza, el tipo de parte de purga o torre de sacrificio, el modo de sistema y el material de la primera capa. El contenido de la punta se adapta para mostrar solo el contenido de las opciones disponibles para la acción.
Versión de GrabCAD Print 1.24, noviembre 2018
Número de compilación 1.24.15.46944 liberado el 20 noviembre 2018
- GrabCAD Print Advanced FDM ofrece un conjunto de herramientas potentes e intuitivas para obtener las características deseadas de la pieza al controlar automáticamente los atributos de compilación de FDM. Al asignar atributos directamente a la geometría de su archivo CAD, puede especificar áreas de resistencia y rigidez, controlar los rellenos, garantizar suficiente material alrededor de los orificios con inserciones y evitar las costuras. Todas las sendas necesarias se calculan automáticamente sin requerir la manipulación manual de capas individuales, lo que reduce el tiempo que lleva preparar un trabajo y mejora la calidad general de las piezas. Advanced FDM está disponible para impresoras seleccionadas (F370, 380mc, 380mc CFE, 400mc, 450mc, 900mc y F900), y está disponible en Archivo > Preferencias > FDM.
- Los archivos OBJ ahora se pueden agregar a GrabCAD Print con colores, el archivo .mtl asociado y texturas visuales, para la impresión en PolyJet. Debe habilitar esta característica en Archivo > Preferencias > GrabCAD Labs. Para saber qué es compatible, consulte aquí.
- Los materiales que están disponibles recientemente son compatibles con GrabCAD Print, incluidos VeroCyan Vivid, VeroFlex Cyan/Magenta/Yellow Vivid y Agilus 30 White en la J750/J735, MedABS y Med615 en Connex3, Antero 800NA en F900, y un nuevo material flexible para la serie F123 llamado FDM TPU 92A. Tenga en cuenta que los nuevos materiales para Connex3 y J750/J735 requieren una actualización del software integrado.
- Cuando selecciona una impresora PolyJet, un nuevo modo de visualización disponible en la fila superior de botones sobre el visor 3D permitirá al usuario ver dónde se colocará el material de soporte en la superficie del modelo. Esto determina el límite para el acabado brillante.
- Algunas impresoras FDM ahora ofrecen una configuración opcional para usar relleno de ancho variable para las compilaciones internas de piezas. Cuando se establece, las trayectorias de ancho variable se colocan automáticamente donde hay espacios entre las trayectorias de ancho predeterminado que son menores que el ancho predeterminado y mayores que el ancho mínimo para el tamaño de punta determinado. Esto es compatible con las series F123 y F900 y Fortus 900mc después de instalar la actualización de firmware más reciente (versiones 1.8 y 3.26 respectivamente o posteriores).
- Actualizaciones del panel de detalles del trabajo en la Vista de programación para indicar visualmente la cantidad de material que se estima que se utilizará para ese trabajo seleccionado. Las sugerencias de herramientas muestran a los usuarios la cantidad de material que se estima que quedará en el envase o cartucho al finalizar el trabajo. Para FDM, el primer trabajo en la cola indicará la cantidad de material que estará en el envase/cartucho cuando comience el trabajo.
- El panel de detalles del trabajo en la Vista de programación ahora mostrará una lista de los tamaños de puntas y la resolución de compilación requerida para el trabajo de las impresoras FDM. Esto es útil para que los usuarios verifiquen qué se requiere para el trabajo en comparación con lo que está cargado actualmente en la impresora.
Versión de GrabCAD Print 1.23, octubre 2018
Número de compilación 1.23.20.45529 liberado el 17 octubre 2018
- Realizamos varias mejoras en el informe de Historial:
- La exportación para el historial de trabajos ahora está disponible en formatos .XLSX y .CSV, siendo .XLSX el predeterminado.
- Para distinguir el tiempo de impresión del tiempo de preparación y otro tiempo empleado en el trabajo, la columna “Duración” ahora se divide en “Tiempo total del trabajo”, que es el tiempo total transcurrido entre el inicio y el final, y “Tiempo total de impresión”, que excluye el tiempo cuando la impresora fue pausada o se estaba preparando.
- Una nueva columna en la Vista de historial muestra la lista de piezas en el trabajo. Las cantidades de la misma pieza se mostrarán con un (#) después del nombre de la pieza. Por ejemplo, “HingePin (3)”. Actualmente, esta función solo está disponible para impresoras FDM. (Nota: los trabajos impresos con GrabCAD Print 1.22 y anteriores mostrarán los nombres de las piezas cifrados aquí.)
- Para impresoras FDM, el historial de trabajos exportado ahora incluye dos columnas para los tamaños de punta de soporte y modelo.
- Las piezas se pueden imprimir con ULTEM™ 9085 a una resolución de 0,013” en la impresora Fortus 450mc
- Los modelos se muestran con apariencia mate o brillante según las propiedades del material que se configuran
Versión de GrabCAD Print 1.22, septiembre 2018
Número de compilación 1.22.24.44746 liberado el 26 septiembre 2018
- Existe una nueva opción de preferencia para deshabilitar las actualizaciones automáticas de GrabCAD Print. Seguirá siendo notificado cuando haya una actualización disponible.
- Existe una nueva opción de preferencia para que la importación de archivos CAD sea más precisa; esta agregará más triángulos a la malla que representa el archivo CAD. Sin embargo, ello afectará el rendimiento.
- Con esta versión, solucionamos ciertos problemas con la forma en que las impresoras se conectan con GrabCAD Print (incluida la desaparición de la lista de impresoras después de una actualización) y mejoramos nuestros informes de errores para abordar mejor los posibles problemas de conectividad en el futuro.
- Los modelos ahora se pueden orientar automáticamente para todas las impresoras FDM, que orienta los modelos para generar el menor material de soporte.
- Los trabajos ahora se pueden imprimir utilizando material de soporte como capa base en impresoras F123 para ABS y ASA cuando se usa la resolución 005”. Esto aumenta el riesgo de problemas con la adhesión a la bandeja, pero le permitirá quitar más fácilmente las piezas pequeñas.
- En impresoras FDM donde está disponible el relleno de densidad doble, el estilo de relleno de hexagrama ahora es una opción. Este patrón es muy fuerte y eficiente para la construcción.
- El horario de oficina y el inicio diferido de impresión pueden permitir que una cola parezca vacía en la Vista de programación cuando no lo está, por lo que hay un nuevo botón que aparece cuando necesita desplazarse hacia la derecha para ver los trabajos en cola.
- Si hace clic en un trabajo que se está imprimiendo actualmente en la Vista de programación, ahora verá una estimación de cuánto material quedará al finalizar el trabajo. Y para las impresoras FDM, también puede ver una estimación de los niveles de material de partida para el siguiente trabajo.
- La costura (donde la trayectoria comienza y finaliza para impresoras FDM) ahora está visible en Vista previa del corte.
- Las piezas se pueden imprimir usando Antero 800NA en la impresora 450mc.
Versión de GrabCAD Print 1.20, julio 2018
Número de compilación 1.20.50.42688 liberado el 18 julio 2018
- ¡El inicio diferido para las impresoras PolyJet ya está disponible! Cuando su impresora PolyJet está inactiva y la cola está vacía, ahora puede programar su impresión para que comience en un momento específico después de presionar el botón Imprimir. Tenga en cuenta que esta función aún no está disponible si está conectado de forma remota a su impresora a través de GrabCAD Print Server.
- En la Vista de programación, ahora puede hacer clic en un botón en la imagen de la cámara para que sus impresoras de la serie F123 la agranden a resolución completa. La misma función está disponible para la imagen de vista previa del trabajo para todas las impresoras.
- Después de 3 meses de prueba, los sistemas Connex3 son totalmente compatibles con GrabCAD Print. Lea la guía de configuración para empezar.
- GrabCAD Print ahora es compatible con la nueva impresora Fortus 380mc Carbon Fiber Edition.
- Su sesión de conexión para GrabCAD Print solo caducará después de 2 meses de inactividad. Anteriormente, la caducidad era de 1 semana.
- Si compró los nuevos materiales Vivid Vero para su impresora PolyJet, estos ahora están disponibles para selección en GrabCAD Print.
Versión de GrabCAD Print 1.19, junio 2018
Número de compilación 1.19.14.41748 liberado el 15 junio 2018
- Cuando haga clic en Imprimir para enviar un trabajo a su impresora PolyJet, se mostrará una advertencia si la impresora no tiene suficiente material cargado o si el contenedor de desechos está lleno.
- Los trabajos que contienen una gran cantidad de archivos duplicados se procesarán más rápido que antes. Además, los tiempos de carga de archivos para archivos VRML complejos o de varios cuerpos han mejorado en un 60-80%.
- Ahora, puede exportar el archivo de configuración de la impresora ya sea que esté conectado a la impresora localmente o de forma remota a través de GrabCAD Print Server.
- GrabCAD Print ahora es compatible con el nuevo tipo de sistema Stratasys F900. El Stratasys F900 es el reemplazo del sistema Fortus 900mc e incluye un sistema mejorado de control de humedad y mejoras generales del sistema.
Versión de GrabCAD Print 1.18, mayo 2018
Número de compilación 1.18.19.40241 liberado el 10 mayo 2018
- Algunas mejoras para los usuarios de PolyJet, que incluyen:
- Nueva función copiar y pegar para la configuración de impresión.
- Barras de progreso para validación de bandeja, estimación y puesta en cola.
- Estabilidad de cortadora mejorada para imprimir STL pesados duplicados.
- Los materiales Agilus ahora se pueden imprimir con material de soporte SUP706B. Utilice esta combinación solo si recibió la nueva fórmula de soporte (también conocida como 706B).
- El complemento GrabCAD Print para SOLIDWORKS ahora es compatible con SOLIDWORKS2018. Después de actualizar a GrabCAD Print 1.18, modifique su instalación en el Panel de control para instalar el complemento.
Versión de GrabCAD Print 1.17, abril 2018
Número de compilación 1.17.14.39209 liberado el 12 abril 2018
- Los Sistemas Connex3 (incluidos Objet260, Objet350 y Objet500) serán compatibles pronto, ¡y puede unirse a nuestra prueba beta pública ahora mismo! Además, instale la última actualización de software integrado disponible para descargar ahora. No es necesario firmar un acuerdo beta oficial, solo diríjase aquí para acceder a los enlaces de descarga y las instrucciones completas.
- La estimación de bandejas para las bandejas PolyJet mostrará ahora una barra de progreso real.
- Los perfiles de color y textura se revertirán a los valores predeterminados a medida que cambie los materiales de la bandeja para impresoras PolyJet, a fin de evitar que los usuarios dejen accidentalmente los perfiles en uno que no se recomienda.
Versión de GrabCAD Print 1.16, marzo 2018
Número de compilación 1.16.29.38429 liberado el 20 marzo 2018
- GrabCAD Print dispone de un instalador completamente nuevo para las instalaciones por equipo. Esto permitirá que GrabCAD Print se instale fácilmente en los PCs de los laboratorios de informática, así como a nivel corporativo por parte de los administradores de sistemas. Lea más aquí y envíe un correo electrónico a print@grabcad.com para solicitar acceso.
- Ahora se admiten las últimas versiones de los paquetes CAD. Incluye SOLIDWORKS 2018, Creo 4.0, Inventor 2018, y otros. Lea aquí la lista completa.
- En la última actualización, hemos introducido una nueva función que permite sincronizar los valores de configuración de impresión con la configuración actual de la impresora seleccionada. En esta actualización, hemos hecho que este comportamiento sea automático, justo cuando se ejecuta la aplicación.
- Ahora el material utilizado en la cuadrícula de soporte para las impresiones PolyJet (normalmente VeroPureWht) se especifica en la ventana de resultados de estimación en lugar de decir "Otros".
Versión de GrabCAD Print 1.15, febrero 2018
Número de compilación 1.15.13.37334 publicado el 19 febrero 2018.
- El panel Configuraciones de impresión para impresoras FDM tiene un nuevo aspecto. Verá una indicación cuando los valores de configuración sean diferentes a los de la configuración actual de la impresora y, con un solo clic, podrá actualizar todos los valores para que coincidan. Además, la configuración de cualquier bandeja recién creada siempre coincidirá con la que está viendo actualmente, para acelerar la preparación de la impresión para proyectos con varias bandejas.
- Hay un nuevo control deslizante disponible en la herramienta Organizar que controla la casilla de verificación "Optimizar" para los usuarios de PolyJet. Puede controlar si la organización está optimizada para un tiempo de impresión mínimo o para un uso mínimo del material de soporte.
- SOLUCIONADO: Si la Vista Programar se deja en pantalla durante algún tiempo, la línea "Ahora" permanecerá en su lugar, en lugar de moverse lentamente fuera de la vista.
Versión de GrabCAD Print 1.14, enero 2018
Número de compilación 1.14.20.36110 liberado 17 enero 2018
- Ahora la pantalla de detalles del Panel de la impresora muestra los odómetros de las puntas de modelo y soporte, así como las temperaturas de la capa y del cabezal en los sistemas FDM.
- Si el sistema FDM tiene varias bandejas de material, los nuevos íconos del Panel de la impresora indican qué bandejas de material están cargadas en ese momento en los cabezales de impresión.
- Al hacer clic en el botón Imprimir aparecerá una advertencia emergente si el trabajo tiene puntas o materiales seleccionados que no coincidan con la configuración actual de la impresora.
- Ahora los registros de trabajos de impresión individuales y detallados se pueden descargar en formato XML en las impresoras Fortus 900mc. Vaya a la Vista de informes y utilice el botón de descarga en la columna "Opciones".
- Ahora GrabCAD Print admite la impresora Stratasys J700 Dental.
- SOLUCIONADO: Los informes han estado etiquetando las unidades de material en cm³ sin tener en cuenta sus preferencias de unidad. Esto se ha solucionado.
Versión de GrabCAD Print 1.13, diciembre 2017
Número de compilación 1.13.21.34870 liberado 12 diciembre 2017
Número de compilación 1.13.23.35192 liberado 19 diciembre 2017
- Si ha configurado GrabCAD Print Server, hasta ahora sólo ha disfrutado de algunas de las funciones de acceso remoto de los sistemas PolyJet, como la conectividad de aplicaciones móviles y los informes en línea. Ahora hemos habilitado la última pieza: enviar un trabajo desde GrabCAD Print a un ordenador remoto.
- Varias mejoras sobre
- The Reports View in GrabCAD Print now includes an export button, and works for both FDM and PolyJet systems.
- Se ha corregido un error en la Vista de informes que impedía a algunos usuarios seleccionar una impresora.
- Se han corregido algunos problemas con los informes en línea de Internet Explorer.
- Ya no hace falta hacer clic en "Ver estimaciones" cuando los resultados de la estimación estén listos, aparecerán automáticamente.
- Ahora los detalles del trabajo en la aplicación GrabCAD Print para iOS incluirán la hora de finalización prevista.
Versión de GrabCAD Print 1.12, noviembre 2017
Número de compilación 1.12.26.33454 liberado 13 noviembre 2017
- Ahora puede acceder al historial de trabajos de sus impresoras locales desde la Vista de Informes en la aplicación de escritorio GrabCAD Print. Esto será de gran ayuda para los usuarios en Modo sin conexión, ya que anteriormente este informe sólo estaba disponible en la página Informes en línea después de configurar GrabCAD Print Server. (Todavía no se dispone de historial para sistemas PolyJet, impresoras remotas, y exportación CSV).
- Los nuevos materiales avanzados de PolyJet acaban de ser lanzados por Stratasys, y ahora están soportados por GrabCAD Print. Conocer más sobre Agilus, VeroFlex y DABS2 Plus.
- La aplicación Android a veces informaba de un fallo en la búsqueda de impresoras si la cuenta tenía muchas impresoras conectadas. Hemos aumentado el tiempo de espera para que esto no vuelva a ocurrir.
- Pequeñas mejoras en el uso
- Se ha eliminado el límite de 2 GB de tamaño de archivo individual y de bandeja.
- Ya no se bloquea el cambio a la Vista Programar mientras se realiza otra operación.
Versión de GrabCAD Print 1.11, octubre 2017
Número de compilación 1.11.17.31736 liberado 11 octubre 2017
- Nueva presentación de bandeja, con...
- Realistic tray shape and gridlines for the uPrint, Dimension, F123 Series, and smaller Fortus systems.
- Cuadrículas en centímetros o pulgadas (dependiendo de las preferencias de su unidad de visualización) para sistemas Fortus más grandes.
- Calibration touchpoints for applicable printers.
- Fortus 900mc mostrará el contorno del tamaño de bandeja más pequeño.
- Ahora puede utilizar GrabCAD Print para agregar una pausa a su trabajo de impresión FDM desde la Vista previa del corte. Anteriormente, esta funcionalidad solo estaba disponible en Catalyst e Insight.
- Ahora puede preparar trabajos para ULTEM™ 9085 CG usando GrabCAD Print. Anteriormente, este material solo estaba disponible mediante Insight and Control Center. Los usuarios también tienen la opción de usar la punta T16A con su Fortus 900mc.
- Resolved an issue which prevented some users from being able to launch the GrabCAD Print add-in in SOLIDWORKS.
Versión de GrabCAD Print 1.10, septiembre 2017
Número de compilación 1.10.19.30507 liberado 13 septiembre 2017
- Ahora puede agregar modelos a GrabCAD Print directamente desde sus proyectos de Workbench. Diríjase aquí para obtener más información sobre cómo utilizar Workbench junto con Print.
- Si utiliza GrabCAD Print Server, usted y su equipo pueden ser notificados por correo electrónico cuando su trabajo de impresión finalice o necesite atención. Ajuste la configuración de su perfil de GrabCAD.
- Ahora puede abrir un archivo .PRINT con un doble clic o mediante arrastrar y colocar.
- Ahora GrabCAD Print admite la impresora Objet1000 Plus. Lea la guía de configuración.
- Había un problema en el que los archivos CAD con caracteres no ASCII en el nombre o ruta del archivo no se podían cargar en GrabCAD Print. Esto se ha solucionado.
- Se ha mejorado la importación de archivos CAD. Anteriormente, algunas piezas pueden haber mostrado alguna rugosidad en las superficies curvas, pero las mejoras proporcionarán superficies mucho más lisas.
- Ahora encontrará un acceso directo a "Insight para GrabCAD Print" en el menú Inicio. Le lleva a la versión complementaria de Insight que antes sólo estaba disponible en el menú Aplicaciones de GrabCAD Print.
Versión de GrabCAD Print 1.9, agosto 2017
Número de compilación 1.9.27.701 liberado 9 agosto 2017
- Ahora se puede agregar una torre de sacrificios a los trabajos de impresión de Fortus. Esto puede ayudar a mejorar la calidad de la costura y es necesario cuando se imprime con Nylon 12 CF.
- Ahora los materiales de nylon están disponibles para impresoras Fortus en GrabCAD Print.
- Los trabajos que requieren atención (por ejemplo, si el material se agotará durante o antes del trabajo) mostrarán un icono en el trabajo en la vista Programar. El número total de impresoras con advertencias se mostrará como un recuento en el icono de la vista Programar a la izquierda de la aplicación.
- Los usuarios podrán exportar un CSV que contenga el historial de trabajos de sus impresoras desde el Panel de la impresora (sólo FDM). Esto permite a los clientes sin conexión exportar sus datos del historial de trabajos sin necesidad de habilitar Informes.
- Las versiones anteriores de GrabCAD Print requerían privilegios de administrador del sistema en la primera instalación. Con la versión 1.9, cualquier usuario puede instalar sin necesidad de las credenciales del administrador del sistema (a menos que se incluya el complemento SW opcional).
Versión de GrabCAD Print 1.8, julio 2017
Número de compilación 1.8.16.652 liberado 12 julio 2017
NEW FEATURES:
- GrabCAD Print ahora admite la impresión con ULTEM™ 9085 y ULTEM™ 1010. Esto también significa que los archivos CMB preparados en Insight con estos materiales ahora se pueden imprimir con GrabCAD Print. Para modificar parámetros o utilizar funciones como pines de anclaje o estabilizadores de pared, puede utilizar Insight en el menú Aplicaciones. Aún tendrá que usar el Centro de control para agregar torres de sacrificio. (ULTEM™ 9085 CG aún no es compatible con GrabCAD Print).
- Ahora los usuarios pueden realizar una organización optimizada de todo el proyecto (todas las bandejas a la vez) en sus impresoras FDM. Esto permite a los usuarios comprimir óptimamente más de una bandeja con tantas piezas como sea posible.
- Al insertar piezas para impresoras FDM, las piezas se organizan desde el centro de la bandeja para mejorar la calidad de impresión.
- Para las impresoras de la serie F123, mejora la suavidad de la superficie inferior con características compatibles y no compatibles.
CORRECCIONES DE ERRORES:
- Los caracteres especiales en el nombre de usuario de Windows ya no causan problemas al establecer una conexión con una impresora J750.
- Cuando se visualiza un trabajo de PolyJet en la programación, "Modo de impresión" y "Corte impreso" están nuevamente disponibles.
- Se ha corregido un error en el que las transformaciones de una pieza producían capas superiores parciales.
- Se ha corregido un error en el que al cambiar entre determinadas impresoras FDM, desaparecía un CMB importado.
Versión de GrabCAD Print 1.7, junio 2017
Número de compilación 1.7.28.633 liberado 14 junio 2017
- Ahora los múltiples archivos CMB importados se pueden organizar en la bandeja. Anteriormente, los usuarios que trabajaban con múltiples CMB tenían que utilizar Control Center para sus flujos de trabajo. Para obtener un mejor rendimiento, los CMB se simplifican en la Vista del modelo, pero podrá echar un vistazo a la forma real en la Vista previa del corte. Comience con un proyecto vacío, luego vaya a Archivo > Importar CMB...
- Agregamos "Archivos recientes" al menú Archivo. Puede acceder a sus 5 archivos más recientes agregados (cualquier formato de CAD, CMB o OBJZF) y a sus últimos 5 proyectos de Print.
- Ahora puede reorganizar los trabajos en la vista Programar utilizando arrastrar y colocar.
- Ahora el complemento SOLIDWORKS para GrabCAD Print se incluye en el instalador de GrabCAD Print. El complemento SolidWorks le permite preparar sus archivos CAD para imprimir directamente desde SOLIDWORKS. Para obtener instrucciones de instalación, vaya al menú Aplicaciones en GrabCAD Print.
- Ahora los trabajos de impresión aparecen con su nombre real en lugar del nombre de perfil del equipo para los trabajos locales.
- Ahora GrabCAD Print admite el tipo de archivo .JT
- SOLUCIONADO: Ahora las piezas que contienen caracteres no ascii (como é o à) pueden imprimirse en la J750.
- SOLUCIONADO: Había un problema de escala en las piezas de J750 cuando Tango+ estaba cargado en la bandeja pero no se utilizaba, y ya se ha resuelto.
Versión de GrabCAD Print 1.6, mayo 2017
Número de compilación 1.6.19.601 liberado 9 mayo 2017
- ¡Presentación de las horas de servicio! Una vez que el administrador de la empresa las habilita, su Vista programar ajustará automáticamente la visualización de la cola de la impresora para reflejar que los trabajos de impresión solo se inician habitualmente durante sus horas de servicio, brindándole así una previsión más precisa de la programación.
- Utilice BloqMayús-Seleccionar para seleccionar rápidamente los modelos en el Panel de proyectos. Esta opción combinada con la selección por cuadro (liberada en 1.5), permite cambiar mucho más rápido la configuración de múltiples modelos al mismo tiempo.
- Haga clic y arrastrar para reordenar fácilmente los trabajos en la lista de la cola del Panel de impresora.
- Para mejorar el rendimiento del visor, la Vista del modelo mostrará una versión “simplificada” de sus modelos. Es posible que observe triángulos más visibles en las superficies curvas. Esto no repercute en la calidad de impresión. Para ver exactamente lo que se enviará a la impresora, vaya a la Vista previa del corte, o cambie su Calidad de gráficos a "Alta” en Preferencias del sistema > Configuraciones de pantalla.
- Para las impresoras de la Serie F123, ahora tenemos el estilo de construcción Modo de bloque. Resulta útil para imprimir piezas con relleno sólido grandes y densas para reducir la ondulación de la pieza. Sólo se aplica cuando se utiliza una altura del corte de 0.005” con ABS, ASA o PC-ABS.
- SOLUCIONADO: Para impresoras J750, hemos solucionado varios problemas que podrían provocar errores a la mitad de la impresión. Asegúrese de actualizar GrabCAD Print y el Administrador de tareas para aprovechar estas correcciones.
- SOLUCIONADO: Los usuarios que han establecido sus unidades de visualización en métrico, ahora verán la altura del corte en su unidad preferida.
Versión de GrabCAD Print 1.5, abril 2017
Número de compilación 1.5.15.549 liberado 18 abril 2017
- ¡Ya está aquí el Modo sin conexión Parte 2! Ahora, al instalar por primera vez, podrá omitir el inicio de sesión si no tiene una conexión a Internet. Esta es una continuación de las capacidades del Modo sin conexión que presentamos en GrabCAD Print 1.3, que podrá leer aquí.
- Ahora GrabCAD Print es compatible con las versiones más recientes de los paquetes de CAD, incluidos SOLIDWORKS 2017, Inventor 2017, NX 11.0, y Solid Edge ST9. Lea aquí la lista completa.
- Ahora puede asignar nombres personalizados a sus bandejas desde la vista previa de bandeja en el Panel de proyectos. Los trabajos heredarán este nombre cuando haga clic en Imprimir.
- Todos los trabajos enviados con la versión 1.5 incluirán una vista previa de la bandeja en los detalles del trabajo de la vista programar, tanto en línea como en la aplicación de escritorio. Esto se puede deshabilitar en Preferencias del sistema > Privacidad.
- La Selección por cuadro en la Vista del modelo facilita el cambio de la configuración de impresión de varios modelos a la vez. Haga clic y arrastre con el botón izquierdo del mouse. Cuando arrastre hacia la derecha, solo se seleccionan los modelos que están completamente dentro del cuadro. Cuando arrastre hacia la izquierda, también se seleccionan los modelos que están parcialmente dentro de los límites del cuadro.
- Los accesos directos de la vista y la configuración de la perspectiva son ahora botones convenientemente ubicados en la parte superior del visor.
- Ahora puede elegir cómo desea que se muestren las unidades de material en las aplicaciones móviles así como en los Informes y la Vista programar en línea. Cambiar las configuraciones aquí. (La aplicación móvil se actualiza después del inicio de sesión).
- Hemos mejorado la manera en que se le notifica que el Administrador de tareas debe actualizarse para su J750.
- En las impresoras de la Serie F123, la capa de base se creará con material para modelo para impresoras que utilizan ABS o ASA y una altura del corte de 0.005", para mejorar la adhesión de la bandeja.
- Se han realizado numerosos ajustes en los procesos principales y funciones de impresión para mejorar la calidad de impresión en las impresoras de la Serie F123 de Stratasys.
Versión de GrabCAD Print 1.4, marzo 2017
Número de compilación 1.4.20.531 liberado 14 marzo 2017
NEW FEATURES:
- Ahora GrabCAD Print admite todas las impresoras uPrint, Fortus y Dimension. Consulte la lista completa.
- En 1.3 mejoramos notablemente la compresión para impresiones de FDM si pulsa “Organizar bandeja" después de estimar la bandeja. Ahora incluso resulta más fácil, con la casilla “Optimizar” en la herramienta Organizar. ¡En algunos casos le permite ajustar hasta el doble de piezas por bandeja que antes!
- ¡Presentación de los nombres de impresora personalizados! Renombre una impresora desde el panel Configuración de la impresora, y su nombre personalizado aparecerá en el escritorio, la web y el móvil de todos los miembros de su cuenta de la empresa. Aprender más aquí.
- Con la actualización más reciente de GrabCAD Print Server (versión 0.144.0318), ahora la Stratasys J750 se admite en la aplicación móvil de GrabCAD Print, y la programación e informes en línea. Próximamente impresión de acceso remoto.
- Además, ahora puede conectarse a su J750 por primera vez mediante la opción "Agregar una impresora de red" si ya está ejecutando el GrabCAD Administrador de tareas PolyJet de GrabCAD.
- Mejoramos el modo en que las impresoras aparecen en “Mis impresoras” en el Panel de la impresora:
- Si pierde la conexión con una impresora, no desaparecerá de la lista. En su lugar, mostrará “Desconectada” en su estado.
- Ahora las “Impresoras fuera de línea” se conocen como “Plantillas de impresora” y aparecerán en una sección separada debajo de sus impresoras de red.
- Pequeñas actualizaciones en la configuración de la impresora F370:
- La impresión PLA ahora se denomina Modo borrador.
- El Estilo de pieza de purgado utiliza Altura completa de forma predeterminada.
- Algunos usuarios de J750 informaron problemas con estimaciones incorrectas o impresiones con errores cuando se cargaba el material Tango+ en la bandeja pero no se utilizaba, y estos problemas ya están resueltos.
- Ahora la vista Programar mostrará estimaciones de tiempo y material para futuros trabajos de J750.
- Algunos usuarios de J750 informaron un error de impresión con un misterioso mensaje "error.0". El problema que provocaba el error de impresión se ha solucionado, y el mensaje de error ahora tendrá un texto comprensible si vuelve a producirse el mismo problema.
- Se han solucionado dos pequeños errores en el panel Orientar: uno relacionado con valores decimales negativos y otro con los botones + y -.
- Algunos usuarios de F370 quizás hayan observado que la pieza de purgado contenía algunas capas incorrectas, y este problema ya se ha solucionado.
Versión de GrabCAD Print 1.3, febrero 2017
Número de compilación 1.3.25.508 liberado 21 febrero 2017
Número de compilación 1.3.23.503 liberado 7 febrero 2017
- ¡Introducción a la Serie F123 de Stratasys! Nuestra impresora más reciente funciona exclusivamente en GrabCAD Print. Lea más aquí.
- ¡La asistencia para J750 en GrabCAD Print superó la beta! Gracias a todos los que participaron en el programa beta. Si tiene una J750, puede seguir esta guía para comenzar a imprimir con GrabCAD Print.
- Ahora tenemos un complemento para SOLIDWORKS que le permite imprimir archivos .SLDPRT directamente desde el entorno de CAD. Conozca más sobre este tema o descárguelo aquí.
- Como muchos usuarios nos han solicitado la capacidad de instalar e ir directamente a imprimir sin tener que iniciar sesión en GrabCAD, presentamos la
- Si pierde su conexión a Internet, GrabCAD Print le permitirá seguir trabajando con sus impresoras locales.
- Si trabaja de esta manera la mayor parte del tiempo, puede desactivar los mensajes de advertencia pasando al modo sin conexión en Preferencias del sistema > Privacidad.
- Todavía deberá iniciar sesión por lo menos una vez cuando inicie la aplicación por primera vez. Si tiene un acceso a Internet pero tiene problemas para iniciar sesión, visite la Guía de resolución de problemas.
- La segunda parte de nuestras capacidades sin conexión será una solución “Fuera de línea", donde podrá omitir ese inicio de sesión inicial. Esperamos que esta característica esté lista este mismo año.
- Si siempre pensó que la herramienta Organizar no es tan buena como en Insight o Catalyst, ¡en esta actualización podrá observar grandes mejoras! Primero, pulse “Estimación” para seccionar la bandeja, y luego de pulsar “Organizar bandeja” las piezas se comprimirán acercándose mucho más.
- Los que participaron en el programa beta de J750, verán algunas mejoras con esta actualización:
- Ahora se puede actualizar el Administrador de tareas desde el Panel de impresora en GrabCAD Print, igual que en una actualización de firmware.
- ¡Se solucionaron los problemas con la opacidad del control deslizanteen la Configuración de impresión!
- Ahora Insight está agrupado con GrabCAD Print para que pueda utilizar características más avanzadas como grupos o edición de sendas para sus sistemas F370 o Fortus. Lea más aquí.
Versión de GrabCAD Print 1.2, enero 2017
Número de compilación 1.2.11.469 liberado 24 enero 2017
Número de compilación 1.2.9.464 liberado 16 enero 2017
- En caso de que se le pierdan, ¡los Informes están aquí! Revise su historial de trabajos y uso de material directamente desde el navegador.
- Hay nuevas preferencias del sistema para elegir si desea o no que las nuevas bandejas se creen automáticamente cuando agrega demasiadas piezas a una bandeja.
- Los iconos de herramientas son más grandes y llamativos. Revíselos: Herramientas.
- En la herramienta Girar, ahora puede personalizar los grados de rotación por clic, para que resulte mucho más fácil obtener la orientación perfecta.
- Ahora se incluyen archivos VRML en el Modo de análisis, pero para reparar los modelos sin separar los mapas de texturas deberá utilizar otro software.
- Solucionamos algunos problemas con nuestro lector de archivos CAD, específicamente con los modelos en forma de donas.
Versión de GrabCAD Print 1.1, diciembre 2016
Número de compilación 1.1.28.454 liberado 16 diciembre 2016
- Mejoras en los colores e iconos en la navegación principal y el Panel de proyectos.
- Se producía un error cuando las preferencias de unidades no se reflejaban en la vista Programar, y se ha solucionado.
- Otras pequeñas correcciones y mejoras.
Versión de GrabCAD Print 1.0, noviembre 2016
Número de compilación 1.0.32.424 liberado 15 noviembre 2016
- ¡Más impresoras! Ahora puede utilizar GrabCAD Print con su Fortus 380/450 y Fortus 900 (compatibilidad limitada*), y la Fortus 360/400 y J750 están en beta en este momento. Envíe un correo electrónico a print@grabcad.com para solicitar acceso.
- Capacidad de ver volúmenes de material en centímetros cúbicos. Vaya a Archivo > Preferencias del sistema > Controles de unidades > Unidades de visualización y cambie a cualquier unidad métrica.
- Capacidad de importar archivos .CMB.GZ.
- Ahora de forma predeterminada el instalador utiliza el mismo idioma que su sistema operativo. Puede cambiar el idioma seleccionando el botón Atrás en la primera pantalla del instalador o en las Preferencias del sistema.
- Controles de mouse más intuitivos para los nuevos usuarios. Consulte la configuración actualizada aquí. Los usuarios existentes no se verán afectados.
- El relleno interno, altura del corte y estilo de soporte ahora se actualizan automáticamente con sus configuraciones recomendadas para el modelo y material de soporte seleccionados.
- Pequeñas mejoras en la interfaz del usuario y correcciones de errores.
*Soporte limitado significa que se admite la preparación de impresión básica (similar a la "bandera verde" en Insight); sin embargo, algunas funciones avanzadas, como el uso de una torre de sacrificio al imprimir ULTEM™ o nylon 12, aún no está disponible.
Siga leyendo aquí las notas de la versión de las versiones anteriores.
