Note sulla versione di GrabCAD Print
Versione di GrabCAD Print 1.98, Gennaio 2025
Numero di build 1.98.6.50666 rilasciata il 21 Gennaio 2025
  • Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
  • Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
  • Print Pro: The Assembly created while using the Split tool is now optional.
  • An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
  • For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
  • The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
  • When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
  • Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
  • The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
  • If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
Versione di GrabCAD Print 1.97, Dicembre 2024
Numero di build 1.97.10.49657 rilasciata il 17 Dicembre 2024
  • Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
  • Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
  • Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
  • Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
  • Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
  • F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
  • For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
  • The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
  • ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
  • Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
  • RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
  • A new material profile has been added to the Validated O2 collections.
    30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
    • Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
    • N3D-FR512 for FR-rating with higher elongation at break
    • FL300 from Forward AM for low Shore hardness elastomers in a clear color
    • MED414 for elastomeric applications requiring biocompatible capability such as ear bud
Versione di GrabCAD Print 1.96, Novembre 2024
Numero di build 1.96.8.49045 rilasciata il 20 Novembre 2024
  • Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
  • Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
  • Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
  • Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
  • GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
  • The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
  • Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
  • PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
  • ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
  • For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
  • Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
  • A new material profile has been added to both the Validated O2 and Open AM collections for P3.
  • New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
  • The History report in GrabCAD Print now includes material consumption per-job for P3.
Versione di GrabCAD Print 1.95, Ottobre 2024
Numero di build 1.95.11.47649 rilasciata il 21 Ottobre 2024
  • Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
  • A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
  • A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
  • A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
  • Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
  • The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
Versione di GrabCAD Print 1.94, Settembre 2024
Numero di build 1.94.18.46867 rilasciata il 18 Settembre 2024
  • New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
  • The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
  • When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
  • If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
  • A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
  • The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
  • The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
  • Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
  • Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
  • We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
    • Advanced Color Assignment: designed to produce more accurate and consistent shades
    • 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
    • 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
    • New TrueDent Clear Appliances: for fully translucent models and try-ins
    • Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
  • VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
  • When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
Versione di GrabCAD Print 1.93, Agosto 2024
Numero di build 1.93.14.46038 rilasciata il 29 Agosto 2024
  • Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
  • Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
  • The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
  • Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
  • VeroContactClear is now treated as a transparent material for all transparency-related features.
  • Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
  • When WSS is the selected support material, "No Grid" becomes the only available support grid type.
  • The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
  • A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
  • Additional dental applications for Origin printers are now supported.
Versione di GrabCAD Print 1.92, Luglio 2024
Numero di build 1.92.17.44384 rilasciata il 16 Luglio 2024
  • Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
  • Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
  • Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
  • Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
  • Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
  • Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
  • A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
  • Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
  • The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
  • For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
Versione di GrabCAD Print 1.91, Giugno 2024
Numero di build 1.91.16.43213 rilasciata il 22 Giugno 2024
  • Print Pro: una nuova azione, Esporta modelli come STL. Selezionate un singolo assieme, parte o corpo ed esportatelo come file STL dal menu del tasto destro del mouse. I modelli esportati conterranno le correzioni effettuate in modalità Analisi e le etichette applicate.
  • Print Pro: le funzioni Print Pro di stampa su vassoio, su oggetto e inserimento intelligente, precedentemente disponibili solo sulle stampanti della serie J7/J8, sono ora disponibili anche sulle stampanti della serie J3/J5.
  • GrabCAD Print ora supporta l'importazione dei formati FBX (.fbx) e GLTF (.gltf, .glb).
  • L'opzione di stampa visiva in fibra di carbonio è una nuova altezza di sezione per ABS-CF10 che produce una finitura superficiale più liscia, perfetta per quando l'aspetto visivo di una parte è importante per la sua applicazione. L'altezza slice (0.0050 pollici, 0.1270 mm) è disponibile sulle stampanti serie F123 e F123CR che utilizzano una testina T14H (richiede la versione firmware 2.7).
  • OpenAM è ora supportato per la stampante Stratasys F900. I pacchetti di materiali vengono creati quando i materiali vengono ottimizzati utilizzando OpenAM™, compilati e distribuiti su GrabCAD Print e una stampante F900. I materiali preferenziali e convalidati Stratasys possono essere ottimizzati e inclusi nei pacchetti, nonché materiali aperti di terze parti (richiede la versione del firmware della stampante 4.23).
  • VICTREX AM™ 200 viene aggiunto al portafoglio di materiali convalidati per le stampanti Fortus 450mc e Stratasys F900. VICTREX AM™ 200 è un polimero a base PEEK ad alta resistenza e proprietà meccaniche, resistente alla temperatura, alla corrosione e agli agenti chimici. VICTREX AM™ 200 è supportato per un'altezza di taglio di 0.0100 pollici (0.2540 mm) utilizzando una punta T14F, con supporto sia breakaway (SUP4000B) che solubile (supporto SR-100) (richiede la versione firmware 6.9).
  • Aggiornato il comportamento di restringimento del nylon 12CF. Quando il materiale per un vassoio è Nylon 12CF e il vassoio include sia modelli con riempimento sparso che con riempimento solido, verrà utilizzato il tasso di restringimento in Z per il riempimento solido. Un messaggio informerà l'utente della modifica. Quando tutti i modelli sul vassoio passano al riempimento solido o al riempimento sparso, verrà utilizzato il tasso di restringimento in Z per lo stile di riempimento selezionato.
  • GrabCAD Print supporta gli indirizzi IPv6 durante la comunicazione con le stampanti Stratasys F123 Series, esclusa Stratasys F770 (richiede la versione firmware 2.7).
  • J5 DentaJet™ XL con le cartucce da 4 kg è l'ultima innovazione nella linea di prodotti della serie DentaJet. Realizzata per la produzione in grandi volumi, questa stampante soddisfa le esigenze dei produttori di allineatori, modelli e impianti C&B, offrendo una precisione senza pari. È la soluzione definitiva per realizzare prodotti impeccabili su larga scala, fornendo allo stesso tempo una soluzione economicamente vantaggiosa che rivoluziona i flussi di lavoro.
  • La stampante J5 Digital Anatomy consente la stampa di materiali Digital Anatomy esclusivi sulla piattaforma J5, tra cui TissueMatrix, BoneMatrix, GelMatrix e RadioMatrix. È disponibile un'ampia varietà di preimpostazioni anatomiche per stampare modelli anatomici con comportamento biomeccanico simile ai tessuti umani. Per ulteriori informazioni, fare clic qui.
  • Ora è possibile selezionare il profilo colore di input per la stampa di modelli di colore su PolyJet. In Impostazioni vassoio > Avanzate, scegliere tra sRGB (predefinito) e il nuovo profilo Adobe RGB 1998. Il profilo Adobe fornisce colori più saturi (verdi/gialli/rossi) e consigliamo di utilizzare un monitor altamente saturo per avere un'idea migliore di quale sarà il risultato stampato.
  • Lo stile della griglia di supporto, che in precedenza era bloccato per le stampanti J3/serie 5, ora può essere modificato. Nota: rimarrà bloccato se la stampante è caricata con materiali TrueDent.
  • Per le stampanti PolyJet applicabili, le seguenti operazioni sono ora disponibili sul pannello delle ricette UV LED:
    • Salvare le modifiche su una ricetta privata
    • Salvare una ricetta (sia SSYS che privata) come nuova ricetta privata
    • Rinominare una ricetta privata
    • Eliminare una ricetta privata
  • Il polipropilene (PP) è ora supportato nell’3interfaccia utente delle impostazioni D Nest per SAF.
  • La convalida ora riporta la distanza tra gli oggetti coinvolti nelle collisioni leggere, consentendo all'utente di decidere se è consentito procedere e stampare.
  • Per la stampa P3, ora si può definire il materiale predefinito e il profilo di supporto da selezionare automaticamente all'avvio di un nuovo progetto.
  • Per la stampa P3, quando si modifica il supporto di un modello specifico, verrà visualizzata un'icona di avviso accanto al modello nel pannello del progetto con la descrizione comando "I parametri di supporto del modello differiscono da quelli predefiniti del vassoio".
  • Per la stampa P3, quando tutti i modelli selezionati hanno lo stesso profilo di supporto, i relativi punti di ancoraggio e/o strutture di supporto possono essere generati automaticamente tramite un singolo pulsante.
Versione di GrabCAD Print 1.90, Maggio 2024
Numero di build 1.90.16.41968 rilasciata il 22 Maggio 2024
  • Print Pro: una nuova azione, Separa, è disponibile nel menu del tasto destro del mouse quando si selezionano i file STL su un vassoio. Separa converte un file STL con più gusci in un assieme con più corpi. Le impostazioni del modello possono quindi essere applicate a ciascun corpo. Il modello non viene modificato se viene identificato un solo guscio.
  • Print Pro: il font Allerta Stencil può essere selezionato per l'uso nelle etichette. Per scegliere questo font, espandere il menu a discesa Etichette e selezionare Allerta Stencil. Il font Atkinson Hyperlegible rimane il font predefinito.
  • Print Pro: l'attributo del modello Nome dell'assieme può ora essere incluso nei modelli di etichetta. Il nome dell'assieme ha gli stessi modificatori del nome della parte (da inizio/fine, salto e lunghezza). Quando non esiste una struttura di assieme, il comportamento di Nome assieme e Nome parte è lo stesso.
  • Print Pro: Support-as-Material, un'impostazione di PolyJet che consente di creare finiture strutturate sui progetti stampando una doppia superficie lucida e opaca, è stata resa disponibile per tutte le stampanti della Serie J.
  • Sono state aggiunte nuove viste alla barra degli strumenti Visualizza. Oltre alla Modalità standard, che visualizza i modelli come ombreggiati, sono state aggiunte le nuove opzioni Modalità wireframe e Modalità wireframe ombreggiata, che visualizzano i modelli rispettivamente come mesh wireframe trasparente o ombreggiata. Le nuove viste non sono compatibili con l'anteprima delle superfici supportate.
  • In GrabCAD Labs è stata aggiunta un'opzione per stampare in FDM senza strutture di supporto. Dopo aver attivato la funzione (File > Preferenze > GrabCAD Labs), si troverà "Nessun supporto" come opzione di stile di supporto nel pannello Impostazioni supporto. Il modello verrà stampato con una base ma senza altre strutture di supporto.
  • È stato risolto un problema che impediva di riorientare un modello quando era presente una torre sacrificale a tutta altezza.
  • Per la stampa SAF, è ora possibile scegliere il sotto-nido per creare un nido in una regione definita del pacchetto con il controllo delle dimensioni X, Y, Z e la posizione X, Y, Z dell'origine della regione specificata da qualsiasi angolo scelto del pacchetto.
  • La dimensione minima del testo per le etichette SAF è stata ridotta a 10 pt.
  • Per la stampa P3, i punti di ancoraggio aggiunti o spostati manualmente saranno presentati con un colore diverso rispetto ai punti di ancoraggio generati automaticamente.
Versione di GrabCAD Print 1.89, Aprile 2024
Numero di build 1.89.16.40685 rilasciata il 16 Aprile 2024
  • Ottenete preventivi e ordinate parti da Stratasys Direct all'interno di GrabCAD Print nella nuova modalità Parts on Demand. Disponibile per una gamma di materiali FDM e con spedizione negli Stati Uniti.
    Per la stampa FDM, è stato risolto un problema per cui il rettangolo di selezione generato per un modello con stabilizzatori era più grande del necessario, causando una violazione del volume di costruzione.
  • Nuova funzionalità di moda: Stampa su capo. L'interfaccia semplificata include la compatibilità con il nuovo e innovativo kit Direct to Garment Trays, che consente ai designer di incorporare intricati elementi 3D direttamente sui capi finiti.
  • Un nuovo pulsante nel pannello di annidamento H350, denominato Riempi selezionati, consente di inserire nel pacchetto il numero di duplicati di un singolo pezzo.
  • Per la stampa P3, è ora possibile generare punti di ancoraggio e/o supporti per più modelli in un'unica operazione, quando tutti i modelli condividono lo stesso profilo di supporto.
  • Per la stampa P3, alcuni materiali (soprattutto elastomeri) richiedono un rafforzamento supplementare del supporto quando vengono generate impalcature elevate. È possibile controllare il tipo di rinforzo per profilo di supporto, per vassoio o per modello specifico. Il profilo SSYS Elastomeric è già stato modificato per avere questa opzione.
  • Per la stampa P3, la definizione del materiale fornisce parametri di disposizione predefiniti per ogni materiale: Distanza tra i modelli e Distanza dai confini di stampa. Gli utenti di OpenAM possono modificare questi valori per i loro materiali privati. Ogni utente può modificare questi parametri per vassoio (tramite il pannello Disposizione).
Versione di GrabCAD Print 1.88, Marzo 2024
Numero di build 1.88.14.39413 rilasciata il 19 Marzo 2024
  • Print Pro: GrabCAD Print Pro include ora funzioni per PolyJet! Si tratta di funzioni che in precedenza erano disponibili solo tramite il pacchetto di ricerca PolyJet...
      • Stampa direttamente sul vassoio (solo Serie J7/8): consente di stampare su materiali come il vetro o la fibra di carbonio, creando una finitura superficiale perfetta sul lato inferiore del pezzo ed eliminando la necessità di una post-elaborazione sul lato inferiore.
      • Aria come materiale (solo serie J7/8): consente di utilizzare aria anziché resina per ridurre significativamente il peso delle parti, consentendo un risparmio di materiale fino al 30%.
      • Smart Insert™ (solo serie J7/8): consente di incorporare vari elementi funzionali/decorativi direttamente nella stampa.
      • Stampa su oggetto (solo serie J7/8): consente la personalizzazione del modello con la stampa diretta sull'oggetto su un'ampia varietà di substrati.
      • App Voxel Print (solo serie J7/8): strumento per la stampa di dati di slice definiti da altri software, che consente di controllare ogni dettaglio del modello, compresi colore, trasparenza e durezza a livello di voxel.
    • ...altre nuove funzionalità...
      • Supporto come materiale (solo J750 e J850 Prime): consente di creare finiture strutturate sui disegni stampando una doppia superficie lucida e opaca.
      • Liquido come materiale (solo serie J7/8): permette di creare cavità cave come strutture microfluidiche, tubi cavi, parti idrauliche, ecc.
      • Modalità High-Speed (solo J55) - Mantiene lo stesso spessore dello strato ma opera al doppio della velocità quando si utilizzano i materiali 2.
    • ... oltre ad alcune funzioni già disponibili in Print Pro per FDM e SAF:
      • Etichette
      • Analisi spessore
      • Assemblaggio/Dissoluzione
      • Plugin di 3° parti
  • Print Pro: i risultati delle stime esportate utilizzano ora il formato orario hh:mm per facilitare l'inserimento nei calcoli.
  • GrabCAD Print supporta ora le seguenti versioni CAD:
    • SOLIDWORKS 2024
    • Inventor 2024
    • Serie NX 2306
    • Bordo solido 2024
    • .X_T 36
    • .JT 10.9
  • I materiali digitali (DM) che sono miscele di Agilus CMY e VeroUltraWhite, VeroPureWhite o VeroClear sono ora disponibili su tutte le stampanti della serie J7/8 in tutte le modalità di stampa consentite per questi materiali. I nomi dei DM hanno il prefisso FLXAC.
Versione di GrabCAD Print 1.87, Febbraio 2024
Numero di build 1.87.18.38549 rilasciata il 28 Febbraio 2024
  • Print Pro: i risultati delle stime per i progetti Pro includono ora le stime dei costi in entrambe le schede Riepilogo vassoio/nido e Rapporto di costruzione (per parte). I tassi di costo sono configurabili in una nuova scheda della finestra dei risultati di stima o da Impostazioni stampante.
  • Alla striscia di controllo in alto nel visualizzatore è stata aggiunta la vista Sezione. Questa funzione consente di vedere le caratteristiche dei modelli che altrimenti potrebbero essere oscurate e può essere utilizzata insieme allo strumento di misura o allo strumento di generazione dei supporti di Origin. Dopo aver abilitato la vista Sezione, i pulsanti sottostanti vi permettono di selezionare un piano di sezionamento e una direzione, oppure potete utilizzare le maniglie di trascinamento per sezionare con altri angoli.
  • Il testo nella finestra dei risultati della stima è ora selezionabile e può essere copiato negli appunti con Ctrl+C.
  • Lo strumento Posizione, che in precedenza era disponibile solo per i progetti PolyJet e Print Pro, è ora disponibile per tutte le tecnologie in Print Standard.
  • L'impostazione predefinita per aumentare lo spessore delle pareti sottili sulle stampanti della serie F123 è stata modificata in Off.
  • È stato risolto un problema a causa del quale non veniva generato un contorno nello guscio della parte e, in alcuni casi, il suo riempimento adiacente.
  • La Stratasys F3300, una nuova stampante FDM industriale di grande formato, è ora disponibile per la selezione in GrabCAD Print. Qui sono indicate le caratteristiche e le prestazioni della Stratasys F3300, oppure è possibile selezionarla dall'elenco dei modelli di stampante per vedere i materiali e le impostazioni disponibili.
  • La visualizzazione del supporto PolyJet, disponibile nella striscia di controllo della vista nella parte superiore del visualizzatore, ha migliorato la visibilità mostrando le aree supportate in blu, anziché con un motivo a scacchiera.
  • Questa opzione colloca la parte sulla posizione effettiva del vassoio come illustrato nella schermata, senza ottimizzare il processo di stampa. Con la Posizione assoluta, la qualità di stampa dei pezzi piccoli potrebbe essere compromessa.
  • Lo strumento di misurazione, che è stato aggiunto per altre tecnologie nell’aggiornamento 1.83, è ora disponibile per la preparazione alla stampa PolyJet.
  • Per i progetti SAF è ora disponibile una versione potente e dinamica del Rapporto di costruzione. Dai risultati della stima, selezionare Build Report e scegliere "HTML" dal menu a tendina di esportazione nell'angolo in alto a destra. Il file risultante può essere aperto in qualsiasi browser web e contiene le stime del nido e dei singoli pezzi, oltre ad anteprime interattive 3D del nido e di ciascun pezzo, che ne mostrano la posizione nel nido. È disponibile anche uno strumento di ricerca per trovare parti specifiche in base al nome.
  • L'etichetta per la Scatola di sinterizzazione viene ora visualizzata in anteprima, in modo che sia chiaro se l'etichetta si adatta allo spazio disponibile.
  • Per i progetti P3, il bug che impediva l'accettazione dei valori di compensazione Z è stato risolto. Si noti che esiste ancora la regola secondo cui la compensazione Z non può superare il valore di Penetrazione della parte di supporto.
  • For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
    • Raggio supportato dell'isola: il raggio intorno alla prima evidenza di un'isola che riceverà punti di ancoraggio extra.
    • Spaziatura interna dell'isola: la distanza tra questi punti di ancoraggio aggiuntivi.
  • Additional updates for P3 support parameters:
    • Per il modello industriale, il diametro massimo del piede è stato aumentato da 10 a 30 mm.
    • Per i modelli dentali, la penetrazione della parte può essere 0.
Versione di GrabCAD Print 1.86, Gennaio 2024
Numero di build 1.86.24.37111 rilasciata il 29 Gennaio 2024
  • È stato risolto un problema per cui il calcolo del percorso utensile FDM comportava la violazione del volume di costruzione da parte di una parte di grandi dimensioni o l'interferenza di parti piccole tra loro.
  • Il visualizzatore 3D è stato aggiornato per la preparazione alla stampa PolyJet. L'aggiornamento era necessario per le funzioni che verranno presto introdotte, ma per il momento non si dovrebbero notare cambiamenti. Tuttavia, se necessario, è possibile tornare al vecchio visualizzatore in File > Preferenze > PolyJet.
  • I file creati con l'applicazione Voxel Print di GrabCAD (file .gcvf) possono ora essere importati da chiunque abbia una stampante della Serie J. L'uso dell'applicazione Voxel Print per creare i file .gcvf richiede ancora una licenza, ma l'importazione dei file è ora consentita a tutti.
  • L'opzione di lavorare con materiali inferiori al modello 7 in modalità di stampa Alta combinazione (utilizzando Detergente per gli altri canali) è stata estesa per includere la modalità di stampa Alta qualità.
  • Tre aggiornamenti per gli utenti di J5 DentaJet
    • Le IFU (Istruzioni per l'uso) per i materiali TrueDent appaiono ora quando si seleziona una stampante J5 DentaJet con materiali TrueDent.
    • Il pannello delle impostazioni del modello per la stampa TrueDent è stato rivisto per garantire l'usabilità. È possibile scegliere facilmente i materiali preferiti e predefiniti per le tonalità di gengiva e denti.
    • Gli utenti di J5 DentaJet possono ora utilizzare un flusso di lavoro end-to-end, dalla scansione intraorale al modello stampato a colori, utilizzando Exocad Model Creator. Un nuovo profilo di colore in GrabCAD Print consente la corrispondenza dei colori con Exocad.
  • Il processo di polimerizzazione della stampa Origin può causare l'accumulo di materiale extra sulle superfici rivolte verso il basso, chiamato sovrapolimerizzazione. Un nuovo parametro chiamato Compensazione Z risolve questo problema spostando queste superfici verso l'alto.
  • Per gli utenti di Origin Dental, l'opzione "Filtra supporto in cavità" mostrerà un nuovo messaggio di avvertimento, per informare che alcuni supporti necessari potrebbero essere stati rimossi.
  • Quando i puntoni P2P non sono fattibili a causa di limiti di lunghezza o di altezza, la generazione del supporto utilizzerà automaticamente le impalcature P2P.
Versione di GrabCAD Print 1.85, Dicembre 2023
Numero di build 1.85.10.35841 rilasciata il 4 Gennaio 2024
  • Print Pro. Due aggiornamenti per le etichette
    • Ora è possibile eliminare tutte le etichette in un'unica operazione tramite un pulsante nel pannello etichette.
    • Quando si crea un'etichetta modello, ora è disponibile un'anteprima del testo dell'etichetta sulla parte, che fornisce aiuto visivo durante la regolazione delle dimensioni, della posizione e della rotazione.
  • Le stampanti della serie J8 ora possono utilizzare cartucce di liquido detergente in sostituzione dei materiali del modello nella modalità di stampa materiale 7. Utilizzando questa funzione, è possibile caricare il liquido detergente in un massimo di 4 canali di stampa e continuare a stampare, consentendo di stampare scambiando materiali.
  • Ora puoi inviare un lavoro di stampa a una stampante Connex3 caricata con materiali 2, nota come modalità DM2. (Nota: è necessario disabilitare Advanced Slicer in File > Preferenze > PolyJet)
  • L'opzione di utilizzare una lampada UV durante la stampa in modalità HQ è diventata l'impostazione predefinita su J850 Prime, J850 Prime Fabrix, J850 Pro, J835 e J750.
  • Il rapporto dei materiali anatomici all'interno delle miscele con altri modelli o materiali di supporto è limitato. La convalida di queste limitazioni è stata aggiunta ad ogni fase di modulazione del rumore. La limitazione di SUP706 è stata corretta: SUP706 deve essere inferiore a 50% negli strati esterni durante la miscelazione con BoneMatrix, qualsiasi materiale Agilus30 o qualsiasi materiale Vero.
  • Miglioramenti alle opzioni Fashion
    • La ricetta UV LED può essere selezionata senza aprire il pannello Ricetta.
    • Il pannello Ricette si apre mediante il pulsante Gestisci ricette.
    • Slice totali include il livello di adesione definito.
  • È stato aggiunto un pulsante Annulla alla barra di avanzamento dei processi di generazione dei punti di ancoraggio e dei supporti per le stampanti Origin. Se sono stati generati punti di ancoraggio o strutture di supporto, verranno rimossi.
  • Quando si modifica un parametro nei pannelli Punti di ancoraggio e Supporto, il nome del profilo di supporto ora mostra un asterisco (*) vicino al nome del profilo di supporto per indicare le modifiche non salvate. Utilizzare il pulsante Ripristina profilo per ripristinare i parametri modificati.
Versione di GrabCAD Print 1.84, Novembre 2023
Numero di build 1.84.12.35248 rilasciata il 30 Novembre 2023
  • Print Pro: presentazione di Analisi distanza. Lo strumento Analisi spessore è stato migliorato per consentire all'utente di rilevare spazi vuoti, per esempio tasche, nei modelli, che scendono sotto la risoluzione della stampante; disponibile in una nuova scheda Distanza nel pannello Analisi spessore.
  • Print Pro: ora la funzione WAM di Centro di precisione offre un miglioramento della precisione ancora maggiore e consente agli utenti di effettuare iterazioni per migliorare la qualità anche nei progetti più impegnativi.
  • I materiali convalidati introdotti per Fortus 450mc in 1.75 sono ora disponibili per F900. Questi materiali vengono convalidati utilizzando test di affidabilità di base prima di essere resi disponibili per lavori di programmazione e stampa. I materiali convalidati richiedono la versione firmware 4.22 installata in F900 e sono disponibili solo per altezze di slice di 0.0100 pollici/0.2540 mm.
  • Per PolyJet è stato migliorato il livello di adesione per le stampanti Fashion. In precedenza, quando si stampava un modello opaco con uno strato adesivo, lo strato adesivo veniva stampato sotto il modello e il supporto circostante. Una volta rimosso il supporto, intorno al modello poteva restare il livello di adesione. Dopo l'ultimo aggiornamento, il livello di adesione viene aggiunto solo sotto il modello, evitando il problema del livello di adesione rimanente quando si rimuove il supporto.
  • Abbiamo risolto un problema per le stampanti PolyJet Objet30V3 e V5 per cui i processi di stampa iniziavano a non funzionare dopo l'aggiornamento a GrabCAD Print 1.83.
  • Per SAF, il pannello 3D Nest ora riporta ulteriori informazioni sullo stato di avanzamento nel modulo X/Y in modo che l'utente possa vedere chiaramente quanti modelli sono stati selezionati e quanti sono attualmente inclusi nel nido.
  • Per P3 è stata introdotta la funzionalità di correzione automatica dei parametri. Ogni volta che l'utente immette un valore non valido in un parametro con un intervallo valido, il valore viene ora corretto automaticamente al valore valido più vicino e viene visualizzata una descrizione comando per l'intervallo valido corretto automaticamente.
Versione di GrabCAD Print 1.83, Ottobre 2023
Numero di build 1.83.10.33362 rilasciata il 24 Ottobre 2023
  • Print Pro: ora Report costruzione stima il materiale eliminato per le stampanti che utilizzano una parte di spurgo o una torretta sacrificabile.
  • Print Pro: ora Report costruzione include le stime del tempo necessario per stampare le singole parti come parte di un'esportazione Excel o CSV.
  • Print Pro: quando si esportano le stime in un file Excel, Report costruzione e Riepilogo vassoio vengono inclusi come fogli separati dello stesso documento.
  • Nuovo strumento Misura: ora è possibile misurare le distanze da punto a punto, da piano a punto o da punto a piano con un'opzione di aggancio ai vertici. La misura è supportata per i progetti FDM, SAF e P3.
  • Ora è possibile rinominare parti, insiemi e corpi nel Pannello dei progetti o nel Visualizzatore modello evidenziando il modello e selezionando il comando Rinomina nel menu di scelta rapida.
  • Sono state aggiunte nuove opzioni di selezione al menu di scelta rapida. Ora è possibile applicare Seleziona tutto all'intero progetto o solo al vassoio corrente. Una nuova opzione, Inverti selezione, inverte la selezione sulle parti non selezionate, nel vassoio corrente o nell'intero progetto.
  • Per la stampa H350, sono disponibili due nuove opzioni nella striscia di controllo della visualizzazione:
    • Colora aggiunge colori casuali alle parti del nido per visualizzare meglio i raggruppamenti densi.
    • Visualizzazione linea strato mostra le linee sulle superfici rivolte verso l'alto o verso il basso dove gli strati possono essere visibili nella stampa risultante.
  • Per P3 è stato aggiunto un nuovo strumento per generare una struttura di sostegno in GrabCAD Print. Ora puoi utilizzare GrabCAD Print per preparare completamente i file CAD e inviarli alla stampa, senza necessità di software aggiuntivo.
Versione di GrabCAD Print 1.82, Settembre 2023
Numero di build 1.82.7.32244 rilasciata il 19 Settembre 2023
  • Print Pro: una nuova funzionalità nella modalità Analisi chiamata Analisi spessore consente all'utente di accertare rapidamente se la sua parte contiene geometrie inferiori alla risoluzione della stampante. La risoluzione è impostata per impostazione predefinita in base alla tecnologia della stampante, l'utente può impostare il proprio valore. La visualizzazione può essere binaria, rosso non superato/verde superato o un gradiente continuo giallo-rosso. Il cursore fornisce inoltre una "sonda" per mostrare il valore specifico in qualsiasi punto della parte.
  • Print Pro: ora è possibile utilizzare valori di spaziatura inferiori e negativi per il comando Matrice 3D FDM, consentendo una disposizione molto più vicina delle parti sul vassoio.
  • Ora è possibile nascondere il vassoio, consentendo una migliore vista della parte inferiore di parti ravvicinate.
  • GrabCAD Print supporta gli indirizzi IPv6 durante la comunicazione con le stampanti Stratasys H350, Fortus 450mc, Stratasys F900 e Fortus 900mc. IPv6 per Fortus 450mc richiede la versione firmware 6.8. Stratasys F900 e Fortus 900mc richiedono la versione firmware 4.22 per supportare IPv6.
  • Presentazione di TrueDent™, resine approvate dalla FDA (Classe II) sviluppate per la stampa 3D di protesi dentali, corone e ponti temporanei sulla piattaforma J5 DentaJet. Consente la produzione in lotto di apparecchi dentali multicolore, monolitici ed estremamente estetici su un unico vassoio misto. Sebbene attualmente sia disponibile in regioni specifiche, TrueDent™ offre una soluzione promettente per i laboratori odontotecnici che cercano maggiore produttività e risultati migliori.
  • Nella versione 1.81 è stata aggiunta una preferenza per attivare/disattivare l'elaborazione Texture avanzata. Questa casella di controllo è stata spostata in Impostazioni del vassoio (nella sezione Avanzate), consentendo all'utente di determinare il valore per ciascun lavoro. La casella di controllo è deselezionata per impostazione predefinita per J55 Prime e J850 Prime, che stampano vassoi pesanti con texture.
  • È stato aggiunto il rivestimento in gel nei modelli Cuore strutturale su una stampante DAP (come definito nei modelli Vasi sanguigni).
  • Per la stampa SAF, ora le scatole di sinterizzazione possono avere un'etichetta definita dall'utente come parte della geometria della scatola, consentendo di suddividere la torta per sapere quali parti sono contenute nella scatola di sinterizzazione. Le etichette lunghe vengono allineate automaticamente all'asse più lungo della scatola di sinterizzazione.
  • Per la stampa SAF, il valore di spaziatura minima per l’annidamento può essere ignorato per parti selezionate specifiche che necessitano di spazio aggiuntivo per una migliore gestione termica.
  • Per la stampa SAF, ora è possibile scegliere se un'operazione di annidamento aggiunge al contenuto esistente del nido o cancella il nido e ricomincia.
  • Per la stampa P3, l'opzione Adatta a vassoio avvia un miglioramento dell'orientamento che ruota gradualmente il modello fino a quando entra nell'area di stampa.
  • Per la stampa P3, tutti i profili di supporto odontoiatrico devono avere un nuovo parametro per filtrare i punti di ancoraggio sull'intaglio per i modelli Stecca orientati in 90°.
  • Per la stampa P3, durante la creazione dei punti di ancoraggio, le aree supportabili vengono colorate secondo l'angolo auto-portante specificato nel profilo di supporto selezionato.
  • Gli utenti di GrabCAD Print con cloud P3 On-Prem possono eseguire GrabCAD Print con un account non amministratore.
Versione di GrabCAD Print 1.81, Agosto 2023
Numero di build 1.81.9.30921 rilasciata il 16 Agosto 2023
  • Print Pro: ora Centro di precisione utilizza schede per le visualizzazioni Originale e Convalida. La scheda Originale visualizza i risultati di precisione (mappa termica e punteggio precisione stampante (PAS)) per la parte stampata originale. La scheda Convalida consente agli utenti di caricare una scansione della stampa WAM per vedere esattamente quanto è migliorata la precisione. Visualizza il nuovo PAS rispetto al punteggio originale e il nuovo istogramma viene mostrato con un contorno grigio dell'originale sovrapposto, in modo da mostrare facilmente la riduzione di bande di errore specifiche.
  • Print Pro. Nuovi controlli WAM nel Centro di precisione per risultati migliori con superfici orizzontali:
    • Preserva (ora l'impostazione predefinita) consente solo la regolazione verticale uniforme delle superfici orizzontali per preservare l'estetica ed evitare di aggiungere linee di contorno alle aree orizzontali uniformi.
    • Perno impedisce qualsiasi movimento delle superfici orizzontali.
    • Regolazione libera consente la deformazione libera delle superfici orizzontali, inclusa l'aggiunta di contorni nelle superfici orizzontali per la massima precisione dove l'adattamento è prioritario rispetto all'estetica.
  • Print Pro: aggiunta un'anteprima rapida del file di scansione selezionato nel Centro di precisione per aiutare gli utenti a scegliere il file di scansione corretto.
  • Print Pro: ora l'asse Y dell'istogramma del Centro di precisione mostra la percentuale della parte totale per ciascuna barra del livello di errore, quindi ora è possibile vedere quale percentuale della parte si trova al di sopra, al di sotto o all'interno della tolleranza scelta.
  • Print Pro: quando si confronta una scansione nel Centro di precisione, la disparità locale tra la parte stampata e quella scansionata (per esempio, l'errore rispetto al progetto in quel punto) viene ora visualizzata in modo dinamico quando si sposta il mouse sui risultati del confronto.
  • Per gli utenti P3 con licenze Local Hub e OpenAM, il problema durante il caricamento di un file "Impostazioni per strato" è stato risolto.
  • Per gli utenti P3, la preferenza "Crea automaticamente vassoi quando i modelli non si adattano alla piattaforma corrente" in Impostazioni di inserimento del modello ora funziona per le stampanti P3 come su altre piattaforme.
Versione di GrabCAD Print 1.80, Luglio 2023
Numero di build 1.80.10.30098 rilasciata il 19 Luglio 2023
  • Le versioni 2023 di file CAD sono supportate in GrabCAD Print come segue: SOLIDWORKS 2023, SolidEdge 2023, Siemens NX 2212.
  • Print Pro: ora è possibile aggiungere etichette di testo ad hoc alle parti FDM (STL e CAD); possono essere in rilievo o incise ed è possibile controllare le dimensioni, la profondità e la spaziatura del testo. È inoltre possibile creare modelli riutilizzabili per le etichette, che possono incorporare testo, nome della parte e generare un numero di serie univoco. Fai clic qui per ulteriori informazioni GrabCAD Print Pro.
  • Per l’annidamento SAF, i nomi dei metodi di annidamento sono stati modificati da Standard e Avanzato a Nessun interblocco e Compatto per rendere più chiara all'utente la loro funzione. Il metodo predefinito ora è Compatto (in precedenza Avanzato) che generalmente risulta in un nido più denso.
  • Per SAF, in alcuni casi la convalida può essere molto lenta, quindi ora è possibile annullare il processo di convalida se è necessario apportare ulteriori modifiche al nido.
  • La nuova famiglia di materiali semi-flessibili VeroEcoFlex è ora disponibile per gli utenti J850 TechStyle. Ulteriori informazioni qui.
  • La maggior parte delle stampanti PolyJet utilizza lampade UV al mercurio, ma J850 TechStyle le sostituisce con LED UV. I nuovi LED UV consentono una polimerizzazione più accurata, fondamentale per i piccoli modelli per la moda con elementi sottili. La funzione Combinazione LED UV in GrabCAD Print fornisce un meccanismo per controllare la funzione UV fino a una slice o intervallo di slice specifico. È possibile controllare quali LED utilizzare e l'intensità di ciascun LED in qualsiasi parte del processo di stampa.
  • Abbiamo risolto un problema in GrabCAD Print per cui le macchine P3 non venivano salvate come preferite. Questo problema è stato risolto e ora gli utenti possono assegnare le macchine come preferite.
  • In precedenza era presente un problema per cui le stime dei lavori lunghi per i lavori P3 non erano visualizzate correttamente. Il risultato sono tempi di completamento molto più brevi. Abbiamo risolto questo problema.
  • Abbiamo risolto un problema per P3 che si verificava quando alcuni materiali con impostazioni specifiche non riuscivano ad avviare la stampa. Gli utenti non riscontrano più questo problema e i lavori iniziano a essere stampati come previsto.
  • Per gli utenti P3 con licenze OpenAM, l'intervallo di scala nel profilo Materiale è stato esteso e ora varia da +2% a -1%, consentendo una migliore regolazione della scala per compensare il restringimento della resina.
  • Per gli utenti P3 con licenze OpenAM, abbiamo risolto un problema con la funzione "Carica impostazioni per strato", che non funzionava in modo ottimale in determinate circostanze.
  • Per gli utenti P3 con licenze OpenAM, abbiamo risolto un problema per cui i processi con materiali appena realizzati non venivano stampati.
Versione di GrabCAD Print 1.79, Giugno 2023
Numero di build 1.79.18.29310 rilasciata il 20 Giugno 2023
  • Lo strumento Avvolgi Modello è disponibile per i Gruppi, dove i corpi membri possono avere impostazioni uniche. È attivo per impostazione predefinita. L'involucro racchiude i corpi del modello in un guscio comune. Il guscio aggiunge forza quando i giunti tra i corpi del modello non sono progettati per resistere ai carichi applicati. Se i giunti tra i corpi sono progettati per resistere ai carichi, l'involucro non è necessario e può essere disattivato.
  • I conflitti relativi all'importazione di CMB ora descrivono chiaramente in che modo come il file da aggiungere non corrisponde al progetto.
  • ASA è ora disponibile per la stampante Stratasys F770 nei seguenti colori: bianco, nero, grigio chiaro, blu, rosso, giallo.
  • L'altezza del piedistallo su J3/J5 DentaJet è stata aumentata a 1 mm per una migliore adesione.
  • L'opzione "Ottimizza per packaging" è stata aggiunta a J850 Prime FabriX. Questa opzione migliora i risultati di stampa degli oggetti per packaging trasparenti (come le bottiglie).
  • Nello strumento Scala, sotto le impostazioni del vassoio per le stampanti P3, l'unità di misura è stata migliorata da una a tre posizioni decimali. Questo miglioramento consente misurazioni più precise e regolazioni più fini della funzione.
  • L'importazione di una pila di slice-per le stampanti P3 ora supporta i nomi dei file slice con qualsiasi prefisso, per esempio layer_xxx, slice_xxx, ecc.
  • Per gli utenti di P3 con licenza OpenAM, è disponibile una nuova funzione di download delle impostazioni del materiale. Consente di scaricare un file CSV contenente informazioni sui primi + strati di transizione del materiale. Per accedere a queste informazioni, vai alla Libreria dei materiali, seleziona un materiale e premi il pulsante "Scarica impostazioni" che si trova sopra la tabella delle impostazioni per livello.
  • Il pannello del progetto ora mostra un'icona accanto a qualsiasi modello creato con il comando specchio.
  • Per la stampa SAF, la barra di avanzamento del nesting ora indica all'utente quando sta avvenendo il nesting e quando sta avvenendo la convalida.
Versione di GrabCAD Print 1.78, Maggio 2023
Numero di build 1.78.18.27879 rilasciata il 16 Maggio 2023
  • GrabCAD Print Pro Ora è realtà. Le funzioni includono modellazione adattata alla curvatura, stime per parte, modelli di produzione e altro.
    • Leggi l'elenco completo delle funzioni Pro
    • Richiedi una prova gratuita
      Il software utilizzato internamente a GrabCAD Print per il rendering della grafica a video per i lavori FDM è stato aggiornato, poiché molte delle nuove funzioni lo richiedono. Il vecchio visualizzatore è ancora disponibile nel menu delle preferenze, anche se in futuro verrà abbandonato.
      Per FDM, il comportamento di collegamento dei contorni esterni è stato aggiornato in modo da utilizzare sempre il comportamento definito per il materiale del modello e l'altezza della fetta. In precedenza, i contorni esterni si collegavano per alcuni casi d'uso, ignorando il comportamento di collegamento del materiale.
      Nylon-CF10 è ora disponibile con supporto breakaway per le stampanti Stratasys F370CR e F190CR. Il materiale di supporto SUP4000B offre una soluzione per la rimozione del supporto senza bisogno di ricorrere al supporto e un tempo di produzione più rapido grazie alla facilità di rimozione dei supporti breakaway. SUP4000B utilizza la stessa testa di supporto di QSR e le stesse altezze slice (0.0130 pollici/0.3302 mm; 0.0100 pollici/0.2504 mm; 0.0070 pollici/0.1778 mm) come
      Nylon-CF10. Nylon-CF10 con supporto breakaway richiede l'aggiornamento del firmware della stampante alla versione 2.6.
      La definizione del materiale Nylon-CF10 con supporto QSR è stata aggiornata per migliorare il comportamento del riempimento per altezze slice 0.0100 pollici (0.2504 mm) e 0.0130 pollici (0.3302 mm).
      Migliorare l'accuratezza delle stime dei tempi di costruzione e dei volumi di materiale per:
    • 0.0200 pollici (0.5040 mm) ASA utilizzando una punta T40A sulla stampante Fortus 900mc
    • 0.0200 in (0.5040 mm) Nylon CF12 (nero) utilizzando una punta T40C sulla stampante Stratasys F900.
    • 0.0200 pollici (0.5040 mm) ULTEM 9085 Resin Black utilizzando una punta T40A sulle stampanti Stratasys F900 e Fortus 900mc.
  • Dopo aver cliccato sul pulsante "Stampa" per un lavoro P3, nella finestra di riepilogo della stampa, può facilmente ingrandire il livello 1 o l'anteprima del vassoio premendovi sopra. Questo le consentirà di osservare più da vicino i dettagli della prima slice prima della stampa.
  • Se un modello è posizionato fuori dal volume di costruzione per un lavoro P3, nella finestra Pannello dei progetti viene visualizzata una notifica con un punto esclamativo arancione; passandoci sopra con il cursore viene descritto il problema.
  • Per gli utenti P3 con licenze OpenAM, GrabCAD Print ora supporta il caricamento di un'impostazione per livello che include un valore "edgeBuildingCompensation". Dopo il caricamento, la colonna sarà visualizzata nella tabella Impostazione per livello.
Versione di GrabCAD Print 1.77, Aprile 2023
Numero di build 1.77.13.26873 rilasciata il 18 Aprile 2023
  • È stata ripristinata la possibilità di cambiare tecnologia di stampa senza avviare un nuovo progetto.
  • PolyJet: quando si cambia un colore di gengiva per un assemblaggio specifico, l'assemblaggio e i suoi gusci sono stati duplicati e contrassegnati come nascosti nell'albero del vassoio (l'assemblaggio nascosto è stato creato per semplificare l'operazione "Annulla", che è estremamente complicata). D'ora in poi, questi assiemi non saranno visibili nell'albero e l'operazione di annullamento continuerà a funzionare normalmente.
  • SAF: ora puoi selezionare le parti e creare una scatola di sinterizzazione per contenere e proteggere le parti, specificando le dimensioni del foro, lo spessore del fascio e la spaziatura.
  • P3: i parametri dei livelli di transizione sono ottimizzati e ora vengono gestiti automaticamente sui materiali convalidati. In precedenza questa funzione era visualizzata sotto Proprietà del materiale, ma ora è nascosta.
  • P3: c'era un problema per cui i modelli definiti in pollici si trasformavano in millimetri prima della stampa; questo problema è stato risolto.
Versione di GrabCAD Print 1.76, Marzo 2023
Numero di build 1.76.10.25761 rilasciata il 21 Marzo 2023
  • Un problema per cui Stack (*.zip) appariva come tipo di file durante l’importazione di una CMB è stato ripristinato in File CMB (*.cmb, *.cmb.gz).
  • Per la stampa P3, in "Impostazioni del vassoio"/"Proprietà materiale" è presente un nuovo parametro Scala. In questo modo, se la parte stampata è influenzata dal restringimento del materiale, puoi modificare e ottimizzare i valori di scala del materiale a livello di lavoro.
  • Per la stampa P3, in "Impostazioni del vassoio"/"Proprietà materiale" si trova un nuovo parametro Livelli di base aggiuntivi. Risulta utile se la parte ha un'altezza Z inferiore rispetto al progetto CAD. L'aggiunta di livelli di base aggiuntivi duplica il primo livello per compensare la perdita di altezza su di essi.
  • Per gli utenti di P3 con licenze OpenAM, la stampa di una "Impostazione per livello" modificata tramite CSV ora funziona correttamente.
Versione di GrabCAD Print 1.75, Febbraio 2023
Numero di build 1.75.13.24793 rilasciata il 21 Febbraio 2023
  • Per rendere il software più robusto, il passaggio a una stampante di una tecnologia diversa (per esempio da FDM a PolyJet) richiede l'avvio di un nuovo file di progetto. Puoi passare liberamente da una tecnologia di stampa all'altra prima di aggiungere modelli a un progetto.
  • I Materiali Validati sono ora disponibili in GrabCAD Print quando si programmano i lavori per la stampante Fortus 450mc. Questi materiali vengono convalidati mediante test di affidabilità di base prima di essere resi disponibili per la programmazione e la stampa dei lavori. I materiali convalidati richiedono l'installazione di una versione del firmware 6.7 sulla stampante 450mc.
Materiale convalidato Altezza della slice disponibile Puntina modello Materiale del supporto Puntina supporto
FDM HIPS (Polistirene ad alto impatto) 0.0100 pollici (0.2540 mm) T16 SUP1500B T12
Kimya PC-FR (ritardante di fiamma)
0.0100 pollici (0.2540 mm) T16 SR-100 T12SR100
Nuovi colori di ULTEM™ 9085 Resin (Rosso, Grigio aeronautico, Grigio cannoniera, Grigio sogno, Bianco 7362 e Bianco Jana) 0.0100 pollici (0.2540 mm) T16 SUP8500B T16
Nuovi colori di PC (rosso e nero) 0.0100 pollici (0.2540 mm) T16 SR-100 T12SR100
Nuovo colore di PC-ABS (rosso) 0.0100 pollici (0.2540 mm) T16 SR-100 T12SR100
(BETA) VICTREX AM™ 200 PAEK (a bassa fusione)
0.0100 pollici (0.2540 mm) T14E SR-100 T12SR100
(BETA) Covestro Addigy® PA6/66-GF20 FR LS (Nylon caricato a vetro, ritardante di fiamma)
0.0100 pollici (0.2540 mm) T20G SUP4000B T16
  • Ora i pacchetti di materiali sono supportati in GrabCAD Print. I pacchetti di materiali vengono creati quando i materiali vengono messi a punto in OpenAM™, compilati e distribuiti a GrabCAD Print e a una stampante Fortus 450mc abilitata con una licenza OpenAM. I materiali preferiti e convalidati Stratasys possono essere regolati e inclusi nei pacchetti, così come i materiali aperti di terze parti.I pacchetti di materiali richiedono la versione del firmware della stampante 6.7.
  • È stato risolto un bug per cui i duplicati di una CMB (o copia/incolla) non avevano lo stesso percorso strumento della CMB originale.
  • Basata sulla piattaforma J35, la J3 DentaJet™ è la nostra stampante PolyJet entry-level per i laboratori odontotecnici di piccole e medie dimensioni. Può produrre vassoi misti di tre materiali biocompatibili, compresa una grande quantità di modelli di impianti, guide chirurgiche e maschere gengivali, tutti sullo stesso vassoio e con una precisione senza pari. Veda il nuovo J3 DentaJet™ qui.
  • Ora l'avviso che richiede un aggiornamento di Job Manager per le stampanti PolyJet appare solo quando le versioni di GrabCAD Print e di Job Manager non sono allineate. In precedenza, l'avviso appariva non appena era disponibile una nuova versione.
  • Ora è possibile aggiungere uno strato di rivestimento a un modello VRML con texture per la stampa su PolyJet .
  • Per le stampanti SAF, è ora disponibile il materiale PA12 (beta). Ulteriori informazioni qui
  • Per le stampanti SAF, una nuova opzione con il tasto destro del mouse consente di selezionare i modelli non validi dopo la stima o la convalida.
  • Per le stampanti SAF, in alcuni casi le parti angolate presentavano piccoli artefatti superficiali dovuti allo slicing; l'algoritmo di slicing è stato reso più preciso per evitare questo problema.
  • Per la stampa P3 senza accesso a Internet, ora è supportata la connessione alla stampante Origin One Local tramite Origin Local Hub (i dettagli sono riportati nella guida di riferimento Origin One Local alla voceCentro di assistenza Stratasys). Consultare le istruzioni per la connessione qui.
  • Per le stampanti P3, ora può importare le fette create da applicazioni come Netfabb utilizzando: File > Importa Slice Stack.
Versione di GrabCAD Print 1.74, Gennaio 2023
Numero di build 1.74.8.23921 rilasciata il 17 Gennaio 2023
  • L'impostazione di sicurezza Windows per l'utilizzo della crittografia conforme a FIPS bloccava in precedenza la connettività delle stampanti per i prodotti GrabCAD ; questo problema è stato risolto per GrabCAD Print e Print Server. Il FIPS deve essere ancora disattivato sui sistemi in cui è installato il Job Manager PolyJet.
  • 3Il supporto DConnexion Spacemouse, che era stato introdotto in 1.55, è stato ripristinato.
  • L'input CMYK per i materiali VeroFlex è stato abilitato per tutte le stampanti J7xx/8xx quando il vassoio materiali contiene tutti i materiali VeroFlex a colori.
  • La compensazione dei bordi è stata aggiunta ai parametri del materiale per le stampanti Origin. Questo nuovo strumento le consente di aggiungere o sottrarre micron dai bordi del modello in ciascuna slice. Questo la aiuterà se vede delle caratteristiche, come i fori, che sono leggermente troppo grandi o troppo piccoli, ma non vuole modificare la scala del suo modello.
Versione di GrabCAD Print 1.73, Dicembre 2022
Numero di build 1.73.5.23276 rilasciata il 20 Dicembre 2022
  • L'aggiunta di modelli da Workbench non è più possibile. Per saperne di più sulla deprecazione di GrabCAD Workbench, consulti il post del blog qui.
  • Per le stampanti dentali PolyJet, il file che elenca i nomi dei colori dentali & gengiva per l'integrazione con 3Shape è stato aggiornato con i nuovi colori aggiunti nella versione 1.72. Inoltre, quando si apre un vecchio progetto o lavoro che contiene nomi di tonalità che non esistono, il nome della tonalità sarà vuoto con la presentazione della notifica. Se l'utente seleziona un preset che utilizza una tonalità che non esiste, la tonalità predefinita verrà impostata automaticamente.
  • Le note sulla produzione di GrabCAD Print sono ora disponibili per H350, consentendo agli utenti di annotare i propri modelli e creare un rapporto PDF contenente le schermate dei modelli e le note in un documento traveler PDF.
  • Anche per H350 è stato risolto un bug e ora l'anteprima delle etichette viene visualizzata con le dimensioni corrette.
Versione di GrabCAD Print 1.72, Novembre 2022
Numero di build 1.72.6.22542 rilasciata il 16 Novembre 2022
  • Sulla stampante Stratasys F900, viene aggiunta un'altezza slicing di 0.0200 pollici (0.508 mm) per il Nylon 12 CF, che consente una produttività più rapida su parti di grandi dimensioni. Questa altezza slicing utilizza la puntina di modellazione T40C.
  • Sulle stampanti Stratasys F900 e Fortus 900mc, viene aggiunta un'altezza slicing di 0.0200 pollici (0.508 mm) per ULTEM™ 9085 Resin, ULTEM™ 9085 CG Resin e ULTEM™ 9085 Resin Black. La nuova altezza slicing consente una produzione più rapida su parti di grandi dimensioni. Questa altezza slicing utilizza la puntina di modellazione T40A.
  • I modelli selezionati in 3D Nest di H350 possono essere isolati visivamente, in modo da nascondere tutti i modelli non selezionati; quando l'utente ha finito di lavorare sui modelli isolati, può visualizzare di nuovo tutti i modelli. Tenere presente che queste operazioni non modificano la posizione di alcuna parte in 3D Nest.
  • Per H350, è possibile selezionare qualsiasi assieme da CAD creato con il comando Assembla o un 3D Array raggruppato e scomporre la struttura dell'assieme lasciando i singoli modelli.
  • Le stime per H350 ora riportano la massa per l'intera nidificazione e per i modelli, nonché il fluido HAF per l'intera nidificazione.
  • Il comando etichetta per H350 ora ricorda le impostazioni tra un utilizzo e l'altro del comando, rendendo molto più rapida la creazione di una sequenza di etichette manuali quando rilievo/impressione, dimensione del testo ecc. rimangono invariati.
  • Per il J5 DentaJet, alcune tonalità di denti sono state ottimizzate con un colore più accurato e sono state aggiunte due nuove tonalità.
  • Per J5 DentaJet, le tonalità gengivali sono state ottimizzate con texture migliori. Sono state aggiunte quattro nuove tonalità.
Versione di GrabCAD Print 1.71, Ottobre 2022
Numero di build 1.71.7.21930 rilasciata il 18 Ottobre 2022
  • Gli utenti di J5 DentaJet ora possono utilizzare un flusso di lavoro end-to-end, che va dalla scansione intra-orale al modello stampato a colori, utilizzando il software Dental System di 3Shape e GrabCAD Print. Il Color Model Profile (Profilo modello colore) di 3Shape è stato aggiunto a J5 DentaJet per la stampa con VeroDent PureWhite e Vero CMYK. Tenere presente che richiede la versione 2022 del software Dental System di 3Shape.
  • Quando si inviano lavori alle stampanti Connex con Advanced Slicer (Slicer avanzato) abilitato, nella schermata di conferma della stampa comparirà una notifica.
  • I lavori stampati sulle stampanti delle serie J7/J8 in modalità Super High Speed (Altissima velocità) non comparivano nella visualizzazione della pianificazione; questo problema ora è stato risolto.
  • L’area 3D Nest per H350 può essere rinominata facendo clic sull'anteprima nel pannello del progetto, in modo analogo alla procedura per rinominare un vassoio per FDM o PolyJet; l’azione consente di cambiare il nome del lavoro inviato alla stampante.
  • I contenuti del report generato per le stime su H350 ora possono essere copiati e incollati in altri file, come fogli di calcolo, o scaricati in formato .XLSX o .CSV.
  • Gli utenti di P3 senza una licenza OpenAM ora possono ottenere risultati di stima accurati tramite GrabCAD Print. Per ulteriori informazioni, consultare il nostro ultimo post sul blog disponibile qui.
Versione di GrabCAD Print 1.70, Settembre 2022
Numero di build 1.70.12.21501 rilasciata il 21 Settembre 2022
  • GrabCAD Print ora supporta i sistemi operativi Windows 11. Per consultare tutti i requisiti di sistema, cliccare qui.
  • GrabCAD Print ora supporta i file delle versioni più recenti dei software CAD, tra cui Creo9, Inventor 2023, NX2206 e Parasolid 34.1.
  • GrabCAD Print ora supporta le stampanti Origin One e Origin One Dental. Dopo aver effettuato l'accesso al proprio account Origin in File > Preferenze > DLP P3, è possibile impostare e inviare i lavori alle proprie stampanti. Per ulteriori informazioni, consultare questo articolo.
  • Per i progetti FDM, GrabCAD Print ora mantiene le impostazioni del lavoro quando un progetto viene recuperato ma non è possibile trovare la stampante selezionata. In precedenza, alle impostazioni venivano applicati i valori predefiniti per la stampante; il problema è stato risolto.
  • La testina di estrusione temprata T14H ora è supportata sulle stampanti Stratasys F370, F270 e F170. Con la sua durata di 1500 ore, la testina è la selezione predefinita per la programmazione dei lavori che utilizzano il materiale ABS-CF10.
  • Per le stampanti dentali PolyJet, ora è possibile assegnare la tonalità alla gengiva nella selezione multipla. Tuttavia, la funzione è limitata a una singola shell per assieme.
  • Sia in J850 Prime Fabrix che in TechStyle, lo spessore valido dello strato adesivo è stato aumentato a 3 mm.
  • Correzioni di bug in PolyJet:
    • In J850 Prime Fabrix e TechStyle, i progetti salvati con un'interruzione pianificata vengono aperti senza l'interruzione pianificata.
    • Su J5 DentaJet, la convalida va in errore quando si apre un progetto valido.
    • Su J5 DentaJet, in modalità SHS, la stima totale del modello e dei materiali del supporto è errata.
  • Sono stati aggiunti i seguenti comandi alla vista 3D Nest di H350 per consentire all'utente di lavorare esclusivamente nella vista 3D Nest: Modalità di analisi, Unità, Scala, Aggiungi modelli, Trascinamento libero nei piani X, Y.
  • La creazione con H350 di una costruzione di più modelli, contenente modelli troppo grandi per essere annidati, non causerà più l’errore dell'intera operazione di annidamento. I modelli che si adattano verranno nidificati e un avviso indicherà se sono presenti modelli troppo grandi che non si adattano.
  • Per H350, quando si crea un'etichetta modello utilizzando l'automazione del nome o del numero, il sistema verifica automaticamente la sintassi; se non risulta corretta, viene evidenziata in rosso e una descrizione comando specifica l'errore.
Versione di GrabCAD Print 1.69, Agosto 2022
Numero di build 1.69.12.20542 rilasciata il 16 Agosto 2022
  • Ora su J5MediJet™ sono supportate due nuove resine
    • L'ABS Plus™ digitale biocompatibile è progettato per simulare le plastiche ABS standard, abbinando la resistenza alle alte temperature con la tenacità. Il materiale migliora in modo significativo le prestazioni meccaniche delle parti biocompatibili per varie applicazioni medicali.
    • WSS™150 è un materiale del supporto solubile in acqua, che consente una rapida rimozione del supporto. Il materiale diventa solubile quando viene posto in un recipiente riempito con normale acqua di rubinetto. È possibile ottenere capacità di rimozione del supporto più rapide utilizzando una lavastoviglie standard o da banco.
      Per ulteriori informazioni, cliccare qui.
  • Quando i materiali di un vassoio J750/850 Digital Anatomy includono RadioMatrix, quest’ultimo non deve essere selezionato come materiale predefinito quando il modello viene inserito.
  • Quando si ha accesso sia al PolyJet Research Package che alla stampante 3DFashion, è necessario scegliere solo una delle due opzioni per il progetto corrente, poiché alcune funzionalità sono in conflitto.
  • Nelle stampanti delle serie J7 e J8, l’esperienza utente è stata migliorata per l'impostazione di modelli con materiali colorati Agilus con comportamento flessibile. Le impostazioni pertinenti sono state spostate dalla sezione delle opzioni avanzate a quella delle impostazioni principali e sono stati aggiunti descrizioni comandi dettagliate a tutte le opzioni di impostazione.
  • L'aggiornamento 1.67 ha introdotto per le stampanti Connex3 l'opzione che consente di utilizzare Advanced Slicer con una casella di controllo in File > Preferenze > PolyJet, attiva per impostazione predefinita. Advanced Slicer è più rigoroso per quanto riguarda i requisiti grafici e alcuni utenti hanno riscontrato un errore relativo ai driver grafici. A causa di un bug, dopo la disattivazione della preferenza Advanced Slicer, l'errore persisteva e impediva l'accodamento dei lavori. Con l'aggiornamento 1.69, questo problema è stato risolto e la deselezione della preferenza cancella l'errore.
  • Per H350, ora è possibile specificare un'altezza per il raggruppamento, sia come tempo (utile per preparare un lavoro su misura per il tempo disponibile nel turno) o come altezza del raggruppamento; qualunque sia il parametro inserito dall'utente, l’altro viene aggiornato.
  • La stima per l'H350 ora fornisce un rapporto di costruzione, con pagine di riepilogo e dettagli. Elenchi di riepilogo: tempo di stampa, volume totale, modelli nidificati, modelli non nidificati, densità, restringimento e altezza nidificazione. Elenchi di dettaglio: singole parti, quante copie di ogni parte e volume di ogni parte.
Versione di GrabCAD Print 1.68, Luglio 2022
Numero di build 1.68.10.19783 rilasciata il 19 Luglio 2022
  • Gli assiemi di più file 3MF, OBJ e VRML ora possono essere tutti importati nella stessa modalità utilizzata per STL utilizzando File > Importa come assieme.
  • Il materiale del supporto per ULTEM™ 9085 Resin è stato rinominato supporto SUP8500B e ULTEM™ 1010 Resin è stato rinominato supporto SUP9000B.
  • Per le etichette (solo su H350) ora è possibile specificare l'altezza del rilievo o la profondità dell’impressione del testo dell'etichetta.
  • Per le Matrici 3D (solo su H350) ora è possibile selezionare più modelli e creare una matrice di tali modelli.
  • Sia per J850 TechStyle che per J850 Prime Fabrix, quando si collega una stampante, il tipo di vassoio per il lavoro corrente viene automaticamente sincronizzato con il vassoio installato sulla stampante.
  • Nelle stampanti delle serie J7 e J8 per cui è stato ricevuto e installato l'ordine di modifica sul campo del condotto d'aerazione della lampada UV di destra, la finestra di dialogo delle impostazioni della stampante verrà ampliata con la dichiarazione "Il condotto dell'aria aggiornato è stato installato".
  • Ora su J5 DentaJet, in modalità di stampa HQHS, sono disponibili i materiali DM ASR-620, che sono miscele di MED620 e SUP711.
  • I materiali Color Agilus sono disponibili nell'app Voxel Print.
  • È opportuno definire un Flex-Touch (sia Smart che Full) per ciascun modello, piuttosto che un Flex-Touch comune a tutti i modelli sul vassoio.
Versione di GrabCAD Print 1.67, Giugno 2022
Numero di build 1.67.10.19143 rilasciata il 22 Giugno 2022
  • Advanced PolyJet Slicer, precedentemente disponibile solo per le stampanti della serie J, ora è supportato per le stampanti Connex3. Advanced Slicer consente una migliore qualità e offre funzionalità aggiuntive, tra cui:
    • Scala di grigi con profili in bianco e nero in trasparenza
    • Gestione di angoli/aree sottili
    • Maggiore accuratezza di offset e stime
    • Migliore controllo della griglia
      Se è necessario replicare esattamente una stampa precedente, è possibile tornare allo slicer legacy utilizzando File > Preferenze > PolyJet.
  • Il FabriX™ Innovation Kit per J850™ Prime consente di ampliare le capacità CMF e di prototipazione PolyJet™ in un nuovo mondo di stampa diretta su tessuti e substrati flessibili. Ora è possibile testare diversi design per applicazioni contenenti materiali in mesh, prototipi di abbigliamento funzionale e persino la visualizzazione di sistemi di filtrazione.
  • Presentazione di RadioMatrix™, il primo materiale per stampa 3D radiopaco disponibile sulla Digital Anatomy Printer per modelli anatomici. Il nuovo materiale consente di realizzare modelli anatomici stampati in 3D con caratteristiche di radiopacità a contrasto variabile, che possono comparire in una scansione TC o radiografica. Le impostazioni del materiale RadioMatrix™ sono state aggiunte al software Digital Anatomy Printer che offre modelli anatomici stampati in 3D radiopachi con un valore Hounsfield desiderato.
  • La nuova funzione Netting-Fabric Insert consente agli utenti di pianificare un'interruzione durante la stampa per l'inserimento dei supporti su cui stampare durante il lavoro. La funzione è abilitata sui sistemi J850 TechStyle e J850 Prime FabriX.
  • Il Rigid Core (componente di base rigido) per i modelli AgilusCMY consente di stampare un modello rigido "soft touch" in una sola volta utilizzando il profilo colori Agilus. Il risultato è un modello rigido con una texture sottile a colori (1 mm full-color Shore A 30) e superficie esterna morbida.
  • L'input CMYK per i materiali AgilusCMY consente di definire la specifica tonalità di colore desiderata tramite l’input del valore numerico CMYK per i materiali AgilusCMY puri.
  • Con la modalità ad alta velocità e alta qualità su J5 DentaJet, gli utenti ora possono stampare modelli odontoiatrici, guide chirurgiche e altre applicazioni con la stessa qualità, in metà tempo. In GrabCAD Print, è possibile selezionare la modalità ad alta velocità e alta qualità dopo aver scelto la corretta configurazione del materiale e aver eseguito la procedura guidata per la sostituzione del materiale sulla stampante.
  • Per H350, ora è possibile creare un assieme da più modelli di livello superiore caricati in GrabCAD Print. I modelli vengono posizionati nello spazio 3D utilizzando il widget di trascinamento 3D o lo strumento di posizione, quindi trasformati in un assieme che successivamente può essere nidificato.
  • Lo strumento Matrice 3D per H350 ora supporta gli assiemi come origine per la matrice.
  • Ora è possibile utilizzare l'altezza del raggruppamento come criterio di arresto per lo strumento 3D Nest per H350. Se il processo di annidamento raggruppa correttamente tutti i modelli selezionati, tenterà poi di ridurre l'altezza del raggruppamento fino a raggiungere l'altezza specificata.
  • Il valore predefinito per la spaziatura minima del modello nel comando 3D Nest per H350 ora è stato ridotto da 3mm a 2mm; questo consente di creare in sicurezza un annidamento più denso.
Versione di GrabCAD Print 1.66, Maggio 2022
Numero di build 1.66.7.17878 rilasciata il 17 Maggio 2022
  • Presentazione dei nuovi membri della serie F123, Stratasys F370 CR e Stratasys F190 CR. Queste stampanti composite ready (CR) sono progettate per l'uso con materiali riempiti, tra cui il nuovissimo materiale composito FDM di Stratasys, il Nylon-CF10 e l'attuale materiale ABS-CF10. Ciò semplifica la produzione interna di robusti dispositivi di fissaggio del pezzo, utensili e parti, in una frazione del tempo necessario utilizzando tecnologie e materiali di fabbricazione tradizionali. Le stampanti supportano 8 materiali di qualità ingegneristica e sono programmate utilizzando l'interfaccia intuitiva di GrabCAD Print e le funzioni FDM avanzate facili da usare. Ulteriori informazioni sulle stampanti Composite Ready F123 sono disponibili qui.
  • La stampante 3D J850 TechStyle è alimentata dalla tecnologia 3DFashion™ e offre funzionalità a colori e multimateriale per progetti che possono essere stampati direttamente su tessuti, pelli e indumenti, nonché per la stampa di piccoli accessori di moda con risultati che non è possibile ottenere con i metodi tradizionali. Maggiori informazioni sono disponibili qui.
  • GrabCAD Print ora supporta la stampante con tecnologia SAF H350. Gli utenti con licenza possono stampare, gli utenti senza licenza possono esplorare la funzionalità per apprenderne e valutarne il potenziale. Maggiori informazioni sono disponibili qui.
  • Ora è possibile specchiare un modello in GrabCAD Print usando il menu che appare facendo clic con il tasto destro del mouse. Questa funzione supporta: specchiatura di maglie e parti CAD per tutte le tecnologie di stampa, modelli con colori delle facce, trame, modelli all'interno di assiemi e interi assiemi. Attualmente questa funzionalità non supporta la funzionalità di specchio di modelli con funzionalità FDM avanzate e modelli con etichette.
  • Il nylon-CF10, una miscela di nylon rinforzato con carbonio, è disponibile per le stampanti Stratasys F370 CR e Stratasys F190 CR. Il materiale include 10% di fibra di carbonio tritata in peso, risultando in modelli stampati in 3D più rigidi e resistenti con una migliore resistenza chimica rispetto all'ABS-CF10. Il nylon-CF10 è supportato per altezze slice di 0.0070 pollici (0.1778 mm), 0.0100 pollici (0.2540 mm) e 0.0130 pollici (0.3302 mm) e richiede una nuova testina temprata (T20H) per permettere la stampa. Ulteriori informazioni su Nylon-CF10 sono disponibili qui.
  • È disponibile una nuova testina temprata (T14H) per la stampa di ABS-CF10, con una durata di stampa di 1500 ore. La testina T14H è opzionale; la testina T14 può continuare a essere utilizzata con ABS-CF10, con una durata della testina ridotta.
  • Le nuove resine colorate Agilus30™ (ciano, magenta e giallo) consentono la prototipazione di prodotti testurizzati in gomma o silicone per parti a colori simili alla gomma, con un'elevata qualità della superficie e livelli di flessibilità in grado di resistere a ripetute flessioni e piegature. Maggiori informazioni sono disponibili qui.
  • I materiali WSS (Water Soluble Support, Supporto idrosolubile) VeroUltraClearS e VeroUltraClear possono ora essere utilizzati in VoxelPrint.
  • Per l'H350, aggiungere testo in rilievo o impresso sulla superficie del modello con lo strumento Etichette. È inoltre possibile creare modelli di etichette che possono essere applicati più volte o automaticamente durante la duplicazione di parti e possono includere automaticamente nomi di parti o generare numeri di serie.
  • Per l'H350, è possibile creare una matrice rettangolare in X, Y, Z. La matrice può essere raggruppata in modo tale da comportarsi come un singolo oggetto o creata come singoli modelli.
Versione di GrabCAD Print 1.65, Aprile 2022
Numero di build 1.65.13.17318 rilasciata il 21 Aprile 2022
  • Presentazione della J850 Digital Anatomy Printer. La J850 Digital Anatomy Printer dà vita ai modelli medici con un realismo incredibile che rappresenta accuratamente sia l'aspetto che la risposta del tessuto umano. Questi modelli offrono versatilità clinica, ripetibilità e precisione senza pari per gli operatori sanitari e le aziende di dispositivi medici. Maggiori informazioni sono disponibili qui.
  • Abbiamo aggiornato i formati di file supportati per includere SOLIDWORKS 2022, Inventor 2022 e altro ancora. Fare clic qui per vedere la lista completa: Elenco dei formati di file supportati
  • Alcuni utenti hanno riscontrato problemi di connettività di rete a causa di proxy o certificati autofirmati. Una nuova opzione in File > Preferenze > Privacy consente ai certificati nell'archivio certificati di Windows di essere considerati attendibili da GrabCAD Print, il che dovrebbe risolvere molti di questi problemi. L'applicazione imposterà automaticamente la preferenza se rileva queste configurazioni.
  • Presentazione di Digital Anatomy Creator, un nuovo modulo software aggiuntivo per la stampante Digital Anatomy. Utilizzando sofisticate funzioni matematiche, il software Creator offre agli utenti una libertà senza precedenti di personalizzare le strutture interne dei modelli anatomici. Permette di creare oltre le preimpostazioni anatomiche esistenti e di calibrare i materiali digitali per soddisfare specifiche esatte. Permette di manipolare facilmente la formazione del materiale e di personalizzare le microstrutture interne per ottenere un risultato anatomico specifico. Maggiori informazioni sono disponibili qui.
  • Nuove resine sono ora supportate in Voxel Print sui sistemi PolyJet: VeroUltraWhite e VeroUltraBlack su tutte le stampanti supportate e DraftWhite su J5 MediJet
Versione di GrabCAD Print 1.64, Marzo 2022
Numero di build 1.64.9.16414 rilasciata il 17 Marzo 2022
  • La qualità delle parti per Diran 410MF07 è migliorata sulla stampante Stratasys F370 nei seguenti modi:
    • Per l'altezza della slice di 0.0070 pollici (0.1778 mm), vi è una migliore densità di riempimento per le superfici visibili rivolte verso l'alto e verso il basso e una migliore adesione tra la superficie inferiore di una parte e la superficie superiore della base.
    • Per l'altezza della slice di 0.0130 pollici (0.3302 mm), la qualità della giuntura, le superfici verticali e la densità di riempimento sono migliorate.
      Questi miglioramenti richiedono l'aggiornamento del firmware della stampante alla versione 2.4:
Versione di GrabCAD Print 1.63, Febbraio 2022
Numero di build 1.63.8.15371 rilasciata il 16 Febbraio 2022
  • WSS™150 è un materiale di supporto solubile in acqua per la rimozione rapida del supporto sui sistemi J55 Prime e J35 Pro PolyJet. WSS150 diventa solubile quando viene posto in un recipiente riempito con normale acqua di rubinetto. È possibile ottenere capacità di rimozione del supporto più rapide utilizzando una lavastoviglie standard o da banco. Inoltre, la polvere L2S™ può essere utilizzata per smaltire in sicurezza le acque reflue senza la necessità di inviarle al trattamento successivo, secondo le normative locali.
  • Il pannello Anteprima dello slicing è stato aggiornato:
    • Ora mostra il nome, l'altezza della slice e la puntina utilizzati per il modello e i materiali di supporto
    • I filtri per la visualizzazione delle caratteristiche (Stabilizzatori, Ancoraggi, Giunture, Pause) vengono riorganizzati
    • I controlli per l'animazione (Riproduci animazione, Seleziona strato e Movimenti testina) e la pausa Z (Aggiungi/Rimuovi pausa Z, elenco di pause) sono raggruppati
      L'accesso al pannello Impostazioni modello viene rimosso da Anteprima dello slicing poiché le informazioni sul materiale e l'altezza della slice vengono ora presentate nel pannello Anteprima dello slicing.
  • Quando si utilizza la funzione Ottimizza per packaging in J55 Prime o J8 Prime, ora è possibile regolare con precisione il colore trasparente utilizzando l'input CMYK che supporta VeroUltraClear, conferendo eccezionale trasparenza e saturazione a qualsiasi bottiglia o liquido.
  • La stampante J5 DentaJet PolyJet ora utilizza un nuovo e migliore set di parametri per stampe dentali più rapide e accurate.
  • Nuove resine sono ora supportate in VoxelPrint sui sistemi PolyJet:
    • VeroUltraWhite e VeroUltraBlack su tutte le stampanti supportate
    • DraftWhite su J5 MediJet
Versione di GrabCAD Print 1.62, Gennaio 2022
Numero di build 1.62.8.14676 rilasciata il 19 Gennaio 2022
  • La puntina del modello T16A è stata aggiunta per l'uso con ULTEM™ 9085 e materiali per modelli CG ULTEM™ 9085 di grado certificato sulla stampante Fortus 450mc. Fornisce proprietà meccaniche altamente ripetibili e una qualità migliorata rispetto alla puntina T16 standard per l'uso in applicazioni che richiedono la certificazione di parti, compresi gli interni aerospaziali. Lo spessore dello strato per la puntina del modello T16A è di 0.010 pollici (0.2540 mm). Per utilizzare la puntina del modello T16A, il software del controller per Fortus 450mc deve essere aggiornato alla versione 6.6.6906.
  • L'altezza della slice 0.0130 pollici (0.3302 mm) è ora supportata per ULTEM™ 9085 Black utilizzando la puntina del modello T20 sulla stampante Fortus 450mc. La slice più spessa consente di creare parti più rapide e di ottenere una maggiore produttività. La nuova altezza della slice richiede l'aggiornamento del software del controller alla versione 6.6.6906.
  • Alcuni piccoli bug sono stati corretti e sono stati aggiunti altri miglioramenti.
Versione di GrabCAD Print 1.61, Dicembre 2021
Numero di build 1.61.12.14139 rilasciata il 22 Dicembre 2021
  • Con le stampe PolyJet a colori, "Aspetto corpo" è ora il nucleo predefinito per i corpi con texture quando si cambiano i colori con il selettore colore. Questo va di pari passo con l'opzione "Sovrascrivi texture" rilasciata di recente, che è disattivata per impostazione predefinita e permette di modificare il colore e la trasparenza di un corpo con texture mediante un flusso di lavoro semplice e intuitivo.
  • Quando si imposta un'ora di inizio ritardata per un lavoro su una stampante serie J5, è disponibile una nuova opzione di impostazione dell'ora, oltre all'ora di inizio o di fine esistente. Quando un materiale si esaurisce durante il lavoro, è possibile impostare l'ora in cui si desidera cambiare il contenitore del materiale e la stampante avvierà il lavoro al momento opportuno.
  • Per la stampante Digital Anatomy: le nuove preimpostazioni "Parete del vaso suturabile" offrono prestazioni e durata migliorate per i modelli di vasi sanguigni destinati alla sutura.
  • È stato risolto un problema per cui non era possibile creare ancoraggi e stabilizzatori sullo stesso modello.
Versione di GrabCAD Print 1.60, Novembre 2021
Numero di build 1.60.9.13125 rilasciata il 17 Novembre 2021
  • Si noterà un aspetto rivisto sul lato destro di GrabCAD Print. Le icone sono leggermente più piccole e sono fissate a lato della finestra. Vengono aggiunti continuamente più strumenti, quindi abbiamo ridotto leggermente l'ingombro per ospitare schermi più piccoli.
  • Le stampanti PolyJet ora possono stampare modelli che includono mappe di rilievo (bump). Dopo aver abilitato la funzione in File > Preferenze > GrabCAD Labs, le mappe di rilievo incluse con i modelli Keyshot .3MF o .OBJ standard si tradurranno nella finitura superficiale della parte stampata. In precedenza, le mappe di rilievo dovevano essere scritte nella mesh 3D del file, creando file inutilmente grandi. Ora le mappe di rilievo possono essere lette direttamente. L'altezza dello spostamento può essere regolata in Impostazioni modello o impostare 0 per disabilitare. Come con qualsiasi funzione di Labs, il feedback è sempre benaccetto.
  • È disponibile una nuova modalità per J35 Pro chiamata Material Utilization Mode, ovvero Modalità di utilizzo materiale. La nuova modalità offre la possibilità di lasciare che la stampante decida automaticamente il mix di colori per utilizzare completamente i materiali rimanenti. La parte stampata avrà un aspetto diverso dalla visualizzazione in GrabCAD Print, poiché qualsiasi materiale esistente al momento della stampa determinerà il colore finale. Questa opzione è disponibile nella finestra "Stampa riepilogo".
  • Capacità di mantenere la texture mentre si cambiano i colori del corpo. In precedenza, quando si applicava un nuovo colore a un modello con texture, la texture veniva sovrascritta. Ora, il nuovo colore aggiornerà il colore del corpo della parte sotto la texture, con l'opzione di sovrascrittura. L'opzione "Base e nucleo" selezionata sovrascriverà il colore nel caso in cui non corrispondano.
  • Nuova ottimizzazione per la stampa di un lavoro PolyJet con molti modelli pesanti. Quando si riempie il vassoio con modelli pesanti, utilizzare questa funzione per ottimizzarli automaticamente. Questa funzione riduce automaticamente la complessità del modello senza perdere qualità o accuratezza del modello.
  • Si è verificato un problema con gli ultimi driver grafici NVIDIA che impediva la stima e la stampa di alcuni lavori PolyJet e questo è stato risolto.
  • È stato risolto un problema per cui l'anteprima della sezione mostrava un modello con uno stabilizzatore dello stesso colore dello stabilizzatore.
Versione di GrabCAD Print 1.59, Ottobre 2021
Numero di build 1.59.11.12349 rilasciata il 25 Ottobre 2021
  • Sul modello J55 Prime, quando si imposta una configurazione del materiale in cui gli unici colori disponibili sono bianco e nero, è disponibile un nuovo cursore della scala di grigi. Inoltre, durante il caricamento delle trame, utilizzeranno il profilo B/N.
  • È stato risolto un problema per cui le modifiche allo spessore del corpo di un modello non venivano salvate quando veniva salvato un progetto.
  • È stato risolto un problema per cui le impostazioni del corpo e della faccia per un progetto non venivano salvate quando un modello includeva un foro autoportante.
Versione di GrabCAD Print 1.58, Settembre 2021
Numero di build 1.58.9.11590 rilasciata il 23 Settembre 2021
  • L’opzione "Mantieni impostazioni progetto" consente ai progetti per stampanti FDM di mantenere le proprie impostazioni quando il progetto viene passato a una stampante dello stesso tipo (ad es. da Stratasys F370 a Stratasys F370). È possibile scegliere di mantenere le impostazioni correnti di stampa anche se non corrispondono alla nuova stampante o di aggiornare le impostazioni in base alla nuova stampante.
  • È stato corretto un bug presente su alcune stampe PolyJet a colori, in cui il nucleo bianco veniva stampato anche quando è selezionato "Aspetto del corpo". I progetti salvati in 1.56 o 1.57 in cui l'impostazione principale è stata modificata manualmente devono essere ricreati.
Versione di GrabCAD Print 1.57, Agosto 2021
Numero di build 1.57.8.10644 rilasciata il 19 Agosto 2021
  • Presentazione di Stratasys® J55™ Prime, un aggiornamento rivoluzionario per J55™. La stampante J55 Prime 3D introduce tutti i colori, l'alta fedeltà con capacità tattili, funzionali e sensoriali, rendendo l'efficienza e la qualità della tecnologia PolyJet più conveniente e adatta all'ufficio che mai. Include capacità di stampa all'avanguardia con la combinazione di shore simile alla gomma (Elastico™), ad alto impatto (Digital ABS), Rigid Ultra Visual (VeroUltra™, DraftGrey), semitrasparente (VeroUltra™ClearS) e biocompatibile (Vero™ContactClear). È possibile creare di tutto, da iterazioni di progettazione rapide a prototipi finali di alta qualità, il tutto in un processo compatto, silenzioso e inodore. Guarda il nuovo J55 Prime qui.
  • Presentazione di Stratasys® J35™ Pro. Basato sulla piattaforma del vassoio rotante J55™ Prime, J35™ Pro è una soluzione di stampa PolyJet 3D a basso costo adatta per l'ambiente di ufficio condiviso con funzionalità multi-materiale per il design funzionale e la modellazione concettuale. La nuova stampante 3D include capacità di stampa all'avanguardia con la combinazione di shore simile alla gomma (Elastico™), High Impact (Digital ABS), Rigid Ultra Visual (VeroUltra™, DraftGrey), Translucent (VeroUltra ™ClearS) e materiali biocompatibili (Vero™ContactClear). Le dimensioni compatte della stampante consentono una facile installazione in ufficio e con il sistema di filtrazione ProAero l'ambiente di lavoro è completamente privo di odori. Guarda il nuovo modello J35 Pro qui.
  • Per la prima volta, abbiamo effettuato un aggiornamento a metà ciclo del supporto delle versioni CAD di Print.
  • L'anteprima della sezione ora fornisce il controllo sulla visualizzazione di ancoraggi e stabilizzatori.
    • Gli ancoraggi e gli stabilizzatori vengono visualizzati con il proprio colore, pertanto è facile distinguerli dal modello e dai supporti
    • Disattiva la visualizzazione di ancoraggi e stabilizzatori utilizzando le opzioni nell'elenco Visualizza, consentendo una più semplice ispezione del modello.
    • Le opzioni per la visualizzazione di ancoraggio e stabilizzatore vengono visualizzate solo se il lavoro include queste funzioni
    • Le impostazioni per la visualizzazione di ancoraggio e stabilizzatore vengono ricordate per il successivo accesso all'anteprima dello slicing.
    • Inoltre, il colore per Evidenziazione strato è ora un bianco trasparente, pertanto è più facile capire quali parti di una slice sono modelli, supporti, ancoraggi e stabilizzatori.
  • Due aggiornamenti per la stampante di anatomia digitale:
    1. Stampa modelli di tessuto adiposo sottocutaneo ultrarealistici con un totale di 6 nuove preimpostazioni utilizzando una combinazione di TissueMatrix e GelMatrix. Le caratteristiche principali del modello che variano in termini di morbidezza sono il grasso sottocutaneo contrattile (molto morbido) e il grasso sottocutaneo altamente contrattile (il più morbido) con le seguenti opzioni di rivestimento:
      • Rivestito rigido – Rivestito con 2mm di Agilus per creare un modello autonomo più durevole.
      • Rivestito morbido – Rivestito con 2mm di una miscela Agilus e GelMatrix per conferire al campione autonomo un aspetto morbido e viscido realistico.
      • Non incapsulato – Non rivestito per l'uso in applicazioni in cui il tessuto adiposo sarà incorporato come parte di un modello di organo.
    2. Le funzionalità avanzate GelMatrix offrono più opzioni di modellazione anatomica e richiedono una post-elaborazione più semplice e più breve. Sono disponibili due nuove funzionalità nel menu Impostazioni modello di anatomia:
      • Stampa varie anatomie utilizzando GelMatrix come materiale di supporto
      • Stampa utilizzando materiale GelMatrix puro senza altri materiali
Versione di GrabCAD Print 1.56, Luglio 2021
Numero di build 1.56.11.9996 rilasciata il 20 Luglio 2021
  • Il pannello delle impostazioni del modello PolyJet ora include una sezione chiamata Preimpostazioni. È già presente una sezione per i preferiti che sono solo per la selezione del colore, ma i predefiniti includono il colore e tutte le altre impostazioni del modello. Fare clic con il pulsante destro del mouse su una parte nel vassoio per salvare una preimpostazione. Una volta aggiunta la preimpostazione, è possibile fare clic con il pulsante destro del mouse e impostarla come predefinita. I modelli aggiunti successivamente al vassoio avranno la preimpostazione applicata.
  • Novità sulla serie J8 Prime: "Ottimizza per packaging ì" conferisce un aspetto eccezionale ai prototipi di packaging con un semplice flusso di lavoro. Utilizzando una traduzione della trasparenza da RGB ai colori stampati, prima nel suo genere, gli utenti possono ora ottenere trasparenze più accurate per volumi come liquidi o un vetro colorato. Oltre a ciò, dietro le etichette viene creata una sottostampa bianca automatica, che conferisce alla grafica un aspetto eccezionale con un'elevata opacità. Questa opzione è disponibile sulle stampanti J8 a colori che utilizzano i colori Vero Vivid, UltraWhite+UltraBlack e UltraClear e per i 3file MF di Keyshot. (Contattare print@grabcad.com per abilitare questa funzione.)
  • Miglioramenti alla funzione di ancoraggio:
    • Per semplificare la creazione e la modifica degli ancoraggi tra il modello e il vassoio (il caso d'uso più frequente), la Vista modello viene automaticamente impostata sulla Vista dal basso quando viene aperto il riquadro Ancoraggio.
    • Il vassoio passa a un'anteprima sottile quando vengono modificati gli ancoraggi e la vista modello è anteriore, posteriore, sinistra o destra, facilitando l'ispezione della geometria di anteprima degli ancoraggi in un set. Quando il riquadro Ancoraggi è chiuso, viene ripristinata la vista del vassoio più spessa.
  • La punta del modello T20F è stata aggiunta per Antero 800NA sulle piattaforme Stratasys F900 e Fortus 450mc e per Antero 840CN03 sulla piattaforma F900. La punta del modello T20F offre prestazioni meccaniche migliorate fino al 20% rispetto all'attuale punta del modello T20D con qualità e precisione delle parti equivalenti. Per utilizzare la punta del modello T20F, selezionare 0.0100 in | T20f (0.2540 mm | T20F) nel menu a discesa Altezza slicing dopo aver selezionato il materiale supportato.
  • La versione del firmware 4.11.0 è disponibile per le stampanti Stratasys F900 e Fortus 900mc. Questo aggiornamento non è disponibile mediante il file di aggiornamento scaricato standard (.upg). Contatta un rappresentante dell'assistenza o l'Assistenza clienti Stratasys per informazioni su questo importante aggiornamento.
Versione di GrabCAD Print 1.55, Giugno 2021
Numero di build 1.55.8.8912 rilasciata il 16 Giugno 2021
  • SpaceMouse 3D è ora supportato per la manipolazione della vista in GrabCAD Print. Cercare un tutorial qui.
  • Per i modelli corti e larghi che possono arricciarsi quando si raffreddano, la funzione di ancoraggio consente di fissare il modello al vassoio di costruzione durante la stampa. La funzione di ancoraggio è una colonna realizzata con il materiale del modello che fissa le superfici orizzontali rivolte verso il basso di un modello al vassoio di costruzione. Gli ancoraggi possono essere cilindrici o conici, creati individualmente o in set e che condividono uno stile e un diametro. Clicca qui per saperne di più sulla configurazione degli ancoraggi. (Supportato per le stampanti della serie Stratasys F770, F370, F270, F170, F900 e Fortus.)
  • Gli stabilizzatori ora richiedono di selezionare una curva di riferimento prima della generazione. Ciò impedisce la creazione istantanea di uno stabilizzatore quando il pannello viene aperto per la prima volta e consente di regolare le impostazioni prima di generare lo stabilizzatore.
  • Ti presentiamo J5 MediJet™, la nuovissima stampante medica all-in-one progettata per modelli anatomici, guide chirurgiche e strumenti medici utilizzando materiali sterilizzabili e biocompatibili. La J5 MediJet sta definendo un nuovo standard per le applicazioni di stampa 3D in campo medico. Con più materiali e funzionalità multicolori, puoi creare modelli anatomici chiari, guide di perforazione e taglio e strumenti medici sterilizzabili e biocompatibili, il tutto su un sistema certificato. Inoltre, è abbastanza economico e compatto per i piccoli spazi di laboratorio. Per saperne di più vedi qui.
  • Un nuovo strumento nel menu di destra per le stampanti PolyJet consente di impostare la posizione esatta sul vassoio utilizzando le unità definite nelle Preferenze.
  • Attenzione: nella prossima versione, la mezza tinta avanzata sulle stampanti J-Series a colori verrà selezionata per impostazione predefinita per i nuovi vassoi quando si utilizza VeroPureWhite con tutti i colori.
Versione di GrabCAD Print 1.54, Maggio 2021
Numero di build 1.54.6.7969 rilasciata il 18 Maggio 2021
  • La stampante Stratasys F770™ 3D è dotata della camera di costruzione completamente riscaldata più lunga sul mercato: 46 pollici in diagonale. L'ampio involucro di costruzione che supera i 13 piedi cubi (372 litri) apre a nuove opportunità per la produzione, la prototipazione e le applicazioni di parti di produzione che semplicemente non sono disponibili con stampanti più piccole.  Scopri di più su Stratasys F770 qui.
  • Per i modelli alti e sottili che non richiedono molto supporto tradizionale, la nuova funzione Stabilizzatore consente di aggiungere impalcature per il modello durante la costruzione. Lo stabilizzatore è una struttura di supporto alta che si attacca al lato del modello a intervalli regolari, fornendo un supporto extra e riducendo al minimo le vibrazioni. Clicca qui per saperne di più sulla configurazione degli stabilizzatori. (Supportato per le stampanti della serie Stratasys F770, F370, F270, F170, F900 e Fortus.)
  • È stato risolto un problema per cui la casella di controllo "Utilizza riempimento di larghezza variabile" era disabilitata per le stampanti della serie F123.
  • Per la chiusura delle superfici di un modello FDM, sono stati risolti questi problemi del percorso utensile:
    • Le piccole superfici di chiusura non ricevono più il doppio del riempimento raster necessario.
    • I piccoli fori nelle superfici di chiusura non vengono più ignorati.
  • La funzione GrabCAD Labs introdotta in 1.48 che consente di assegnare diverse finiture PolyJet (opache o lucide) ai componenti di un’unità è stata rilasciata. Non è più un'opzione facoltativa, ma è sempre disponibile.
Versione di GrabCAD Print 1.53, Aprile 2021
Numero di build 1.53.15.7152 rilasciata il 20 Aprile 2021
  • Quando è selezionata l'anteprima della slice, il valore predefinito per l'intervallo dello strato è ora "Tutti gli strati". Le modifiche all'intervallo dello strato verranno memorizzate per la volta successiva in cui verrà selezionata l'anteprima della slice.
  • Questi nuovi materiali opachi consentono di stampare modelli in plastica sottili e realistici, offrono una gamma cromatica più accurata, testo nitido per la stampa di etichette per imballaggi e tonalità uniformi e ad alta risoluzione.
Versione di GrabCAD Print 1.52, Marzo 2021
Numero di build 1.52.8.6136 rilasciata il 16 Marzo 2021
Fare clic qui per un video sull'aggiornamento 1.52.
  • L'ABS rinforzato con fibra di carbonio è disponibile sulle stampanti Stratasys F370, Stratasys F270 e Stratasys F170. Stratasys ABS-CF10 combina materiale ABS standard (acrilonitrile butadiene stirene) con 10% di fibra di carbonio tritata a peso. Il risultato è un materiale termoplastico FDM® poco sensibile all'umidità oltre il 50% più rigido e il 15% più resistente del materiale di stampa ABS 3D standard. Le applicazioni tipiche includono strumenti di produzione, maschere, dispositivi di fissaggio e terminali che beneficiano della combinazione di maggiore rigidità e peso ridotto. ABS-CF10 è supportato per altezze di sezione di 0.0070 pollici (0.1778 mm), 0.0100 pollici (0.2540 mm) e 0.0130 pollici (0.3302 mm). Scopri di più sul nuovo materiale ABS-CF10 qui.
  • Presentazione del modello J5 DentaJet™. Basata sulla piattaforma J55, la stampante J5 DentaJet 3D è l'ultima arrivata nella nostra linea multimateriale di stampanti dentali 3D, che consente ai tecnici di caricare vassoi misti di componenti dentali. La nuova stampante 3D può produrre almeno cinque volte più parti dentali su un singolo vassoio misto rispetto alle stampanti 3D della concorrenza, ma il suo ingombro compatto occupa solo 4.6 piedi quadrati (.43m2) di spazio a pavimenti. Il nuovo J5 DentaJet è disponibile qui.
  • I livelli di base e i livelli di interfaccia tra le strutture di supporto e i modelli realizzati in Antero 840CN03 sono migliorati, aumentando così la qualità delle superfici del modello rivolte verso il basso. Anche le strutture di supporto vengono modificate per aumentarne la stabilità.
  • Per Diran 410MF07, altezza slice 0.0010 in (0.2540 mm), lo spessore minimo del corpo è stato ridotto a 0.0200 pollici (0.5080 mm) per il riempimento solido, l'angolo autoportante predefinito è stato ridotto a 45 gradi e altre impostazioni di stampa vengono aggiornate per migliorare la qualità di stampa complessiva dei modelli.
  • La nuova anatomia del fegato è ora disponibile sulla stampante di anatomia digitale. 4 nuovi pre-set di anatomie epatiche con diversi valori di compressione, tutti convalidati con i dati disponibili su un referto completo Bio-Mechanical. Variazione da altamente contrattile a moderatamente rigido con uno strato di rivestimento variabile. Ulteriori dati sul test eseguito sono disponibili qui.
Versione di GrabCAD Print 1.51, Febbraio 2021
Numero di build 1.51.18.5360 rilasciata il 22 Febbraio 2021
Fare clic qui per un video sull'aggiornamento 1.51.
  • Ora è possibile stampare file dalle ultime versioni della maggior parte dei pacchetti CAD, inclusi SOLIDWORKS 2021, Inventor 2021 e Creo 7. Vedere qui per l'elenco completo dei file supportati.GrabCAD Print version 1.50, Gennaio 2021
  • Presentazione del modello J850 Pro, una stampante PolyJet in 7materiali creata appositamente per la prototipazione rapida. Il J850 Pro ha lo stesso volume di costruzione e capacità del materiale del J850 Prime - precedentemente noto come J850 - ma dove il J850 Prime eccelle nella prototipazione CMF, il J850 Pro è costruito per velocità e prestazioni con ABS digitale, materiali flessibili Agilus, DraftGrey, e la modalità Altissima velocità. La nuova gamma della serie J8 è disponibile qui.
  • Una nuova finestra di riepilogo della stampa raccoglierà comodamente le impostazioni, le stime, le opzioni di avvio ritardato e qualsiasi avviso o notifica che è necessario visualizzare quando si preme "Stampa" per un lavoro PolyJet.
  • Quando i modelli vengono riparati in modalità di analisi, tutti i corpi vuoti, a volume zero, come pareti di scarto o shell in superficie, verranno automaticamente nascosti, poiché questi corpi non possono essere interpretati e possono provocare errori di stima o di stampa.
  • La rappresentazione grafica dei file CMB nella vista vassoio è migliorata. Il display CMB fornisce maggiori dettagli sulla forma effettiva del modello. Le tasche precedentemente ignorate vengono ora identificate e visualizzate. Con la visualizzazione CMB migliorata, un utente non deve accedere a Slice Preview per comprendere il modello che risulta da una stampa CMB.
  • Le barre dei menu e i menu in GrabCAD Print possono cambiare colore per seguire il tema di Windows.
Versione di GrabCAD Print 1.50, Gennaio 2021
Numero di build 1.50.14.4357 rilasciata il 19 Gennaio 2021
  • Quando è disponibile un aggiornamento per GrabCAD Print, una preferenza (introdotta nella versione 1.22) determina se l'aggiornamento verrà installato automaticamente al successivo avvio dell'applicazione. Era attiva per impostazione predefinita, ma ora questa preferenza sarà disattivata per tutti. Gli aggiornamenti futuri verranno installati solo facendo clic sul pulsante Aggiorna ora e, se si desidera, è possibile riattivare gli aggiornamenti automatici in File> Preferenze> Aggiornamenti.
  • Il rilevamento delle interferenze al caricamento del modello ora consente di rilevare e segnalare le situazioni in cui i modelli si sovrappongono. Per la stampa PolyJet, questo contribuirà a determinare dove è possibile cambiare la priorità della parte. Nota: il rilevamento delle interferenze è disattivato per impostazione predefinita ed è abilitato in Preferenze> Impostazioni di inserimento del modello> Rileva automaticamente le interferenze all'interno degli assiemi
  • Quando si inserisce un assieme con una struttura piatta su una stampante serie J, la priorità predefinita è ora visibile immediatamente nell'elenco dei file. In precedenza, era necessario apportare una modifica alla priorità della parte per visualizzarla.
  • Quando si utilizza Nero + Bianco sulle stampanti della serie J, ora sarà disponibile un dispositivo di scorrimento in scala di grigi che funziona con il profilo colore in bianco e nero, sostituendo il selettore di colori a colori esistente.
  • DraftGrey, che in precedenza era esclusivo per la nuova versione V5 della stampante Objet30, è ora disponibile sulle stampanti V3 (indicato come VeroGrey). Fare clic qui per ulteriori informazioni. Inoltre, questo aggiornamento abilita la modalità Alta qualità con i materiali Vero.
  • Nella versione 1.49, alcune stampanti Connex segnalavano erroneamente una versione del driver grafico errata. Questo problema è stato risolto con la versione 1.50
Versione di GrabCAD Print 1.49, Dicembre 2020
Numero di build 1.49.12.3309 rilasciata il 16 Dicembre 2020
  • Il kit di aggiornamento J4100 è disponibile per la stampante Objet1000. Il kit migliora le capacità della stampante Objet1000 con la nuova tecnologia delle testine di stampa e le offerte di materiali più avanzate. Le nuove testine di stampa offrono un canale di modello aggiuntivo (3) per aumentare la velocità effettiva e la produttività fino al 90%. L'offerta di materiali ora include la famiglia Agilus, UltraClear e VeroPureWhite. La J4100 rende ora possibile stampare materiali flessibili su ABS digitale (sovrastampaggio).
  • Alcuni utenti della serie J riscontravano un problema per cui non erano in grado di stampare con le stampanti della serie J perché i lavori si bloccavano durante l'elaborazione. Ciò era causato da driver grafici obsoleti sul PC della stampante, ma GCP non riusciva a rilevare il problema. Il problema è stato risolto e, se si è in questa situazione, ora sarà visualizzato un messaggio che segnala il collegamento per aggiornare i driver.
  • Correzioni software relative a CMB
    • Ripristinata l'opzione per includere/escludere la parte di spurgo/torretta sacrificabile nell'esportazione CMB.
    • Ripristinata la possibilità di includere un'ulteriore torretta sacrificabile su un vassoio che contiene una CMB.
Versione di GrabCAD Print 1.48, Novembre 2020
Numero di build 1.48.14.2323 rilasciata il 17 Novembre 2020
Fare clic qui per un video sull'aggiornamento 1.48.
  • GrabCAD Print ora supporta le stampanti desktop Objet30. Oltre alle stampanti Objet30 V3 esistenti (note come Objet30, Objet30 Pro o Objet30 Prime), viene lanciata una nuova generazione: la Objet30 V5 Pro e Prime. I modelli V5 sono stampanti monocromatiche facili da usare con un ingombro ridotto e una qualità di stampa imbattibile. Offrono 3 modalità di stampa e una varietà di 13 materiali per modelli tra cui DraftGrey e materiali flessibili e biocompatibili (solo Prime). Per utilizzare GrabCAD Print con Objet30, seguire questa guida: Configurazione delle stampanti PolyJet per GrabCAD Print
    L'opzione Stile di base è ora disponibile nel pannello Impostazioni supporto per le stampanti FDM
    • Modello e supporti: le basi vengono aggiunte sotto il modello e le impronte di supporto. Quando le basi si sovrappongono si fondono in una base comune. Quando le basi formano anelli chiusi, il ciclo viene riempito, creando una base ampia e stabile.
    • Solo modello: le basi vengono aggiunte solo sotto l'impronta del modello. I supporti si estendono al vassoio e gli anelli non vengono riempiti.
  • Una nuova opzione in File> Preferenze> GrabCAD Labs consente di combinare finiture tra opache e lucide sui corpi negli assiemi per le stampanti PolyJet.
  • Una nuova modalità di stampa, Super High Speed, è ora disponibile nelle stampanti J826. Questa nuova modalità offre il doppio della produttività della modalità ad alta velocità ed è pratica per molte applicazioni, come la stampa di modelli rapidi.
  • Per lavori che utilizzano materiale del modello ASA con punta per estrusione T40 (0.0200 pollici, 0.5080 mm di altezza slicing) sui modellatori Stratasys F900 e Fortus 900 mc che utilizzano materiali di supporto SR30 o SR35, le proprietà di costruzione degli strati di base sotto il primo strato della parte per migliorare la qualità del primo strato della parte e prevenire la delaminazione.
  • Per i lavori su Stratasys F900 con materiale del modello ASA utilizzando la puntina di modellazione T40 (0.0200 pollici, 0.5080 mm di altezza slicing), la precisione della stima del tempo e del volume è stata migliorata. Questa modifica è destinata all'uso con il nuovo firmware di sistema 4.10.0. Notare che questo aggiornamento del firmware non sarà disponibile tramite il file di aggiornamento standard scaricato (.upg). Per informazioni su questo importante aggiornamento del software di sistema, contattare un rappresentante dell'assistenza o l'assistenza clienti Stratasys.
Versione di GrabCAD Print 1.47, Ottobre 2020
Numero di build 1.47.20.1644 rilasciata il 20 Ottobre 2020
Fare clic qui per un video sull'aggiornamento 1.47.
  • L'aspetto e la densità della superficie delle superfici rivolte verso l'alto sono migliorati per ABS e ASA quando si utilizza l'altezza slicing di 0.0100 pollici (0.2540 mm) sulla stampante Stratasys F370.
  • Riempimento residui migliorato grazie a una migliore rilevazione di aree sottili e corte per il riempimento con percorsi utensile residui di larghezza variabile.
  • È ora possibile selezionare modelli con diversi stati di semplificazione della visualizzazione e impostare globalmente tutti i modelli selezionati su Piena risoluzione o Semplificata.
  • Le texture impostate come trasparenti in SolidWorks vengono ora importate correttamente in GrabCAD Print con la trasparenza corretta.
  • UltraclearS simula l'acrilico, raggiungendo il 95% di trasmissione della luce di quel materiale ed è utile per prototipi di vetro, polimeri trasparenti o imballaggi trasparenti. VeroUltraClear migliora le prestazioni passate di VeroClear con un livello più elevato di chiarezza, trasparenza e un indice di giallo inferiore.
  • L'opzione nucleo del supporto è ora disponibile anche nella stampante J55. Il nucleo del supporto (precedentemente noto come "Vuoto") consente di stampare il nucleo dal materiale di supporto. Prima di utilizzare l'opzione, attivarla in Preferenze> GrabCAD Labs.
  • Il sezionamento osseo per la stampante digitale per modelli anatomici consente di sezionare un modello osseo in sezioni per simulare fratture o per rimuovere parti sul vassoio che sono irrilevanti per l'applicazione.
  • Le opzioni del profilo di colore e texture precedentemente all'interno della finestra "Cambia materiali" sono state spostate nella sezione Avanzate nel pannello degli strumenti Impostazioni del vassoio.
Versione di GrabCAD Print 1.46, Settembre 2020
Numero di build 1.46.21.661 rilasciata il 15 Settembre 2020
Numero di build 1.46.22.826 rilasciata il 18 Settembre 2020
Fare clic qui per un video sull'aggiornamento 1.46.
  • L'impostazione "Vuoto" che in precedenza era una casella di controllo nelle impostazioni del modello PolyJet è ora disponibile come opzione "Supporto" in Opzioni di base e nucleo. Inoltre, la preferenza "Componente di base misto" rilasciata nella versione 1.42 è ora attiva per impostazione predefinita.
  • Nuove funzionalità per la stampante digitale per modelli anatomici
    • Anteprima osso: consente un'anteprima slice per slice della struttura interna di un osso per verificare che la struttura corrisponda alle proprie intenzioni.
    • Apri/Chiudi estremità - Crea una "finestra" nella struttura interna di un osso. È possibile contrassegnare una sezione trasversale piatta di un osso, quindi scegliere di rivestirlo con un materiale trasparente o lasciarlo così com'è, cioè esposto all'aria aperta.
  • Il supporto per i file 3MF, introdotto come funzionalità di Labs nella versione 1.40, è ora disponibile al pubblico.
  • I file SOLIDWORKS con texture con sfondi trasparenti verranno ora caricati correttamente in GrabCAD Print, mostrando l'aspetto sottostante attraverso lo sfondo trasparente.
  • Antero™ 840CN03 è ora supportato su Fortus 450mc. Antero 840CN03 è una combinazione del materiale del modello Stratasys® Antero 800NA con proprietà di scarica elettrostatica (ESD) ed è compatibile per l'uso in applicazioni di produzione che contengono parti e componenti elettronici sensibili al contatto. È disponibile una sola altezza slicing per Antero 840CN03: 0.010 pollici (0.2540 mm). Per informazioni su questo materiale leggere qui.
Versione di GrabCAD Print 1.45, Agosto 2020
Numero di build 1.45.21.65369 rilasciata il 25 Agosto 2020
Fare clic qui per un video sull'aggiornamento 1.45.
  • La modalità di stampa PolyJet può essere selezionata in anticipo durante la preparazione dei lavori di stampa. Vengono visualizzate solo le funzioni e le impostazioni disponibili per la modalità di stampa selezionata, semplificando la preparazione del lavoro. In base alla modalità di stampa selezionata, le funzioni e le impostazioni non disponibili verranno comunque disabilitate con una spiegazione del motivo per cui non sono disponibili.
  • Presentazione dello stile Adaptive Slice per FDM! Lo stile slice adattivo utilizza l'altezza selezionata per le funzioni che richiedono più dettagli (come cupole, raccordi e smussi) e un'altezza slicing più spessa dove i dettagli non sono necessari. Il risultato è una stampa più veloce (a seconda della geometria e dell'altezza slicing, fino al 24% più veloce). Stile slice è una nuova opzione che imposta il modo in cui un modello verrà suddiviso in slice. Leggere di più qui.
  • La preferenza per Impostazioni di visualizzazione> Qualità della grafica ora controlla il livello di semplificazione applicato ai modelli utilizzati per la visualizzazione grafica. Nota: il modello stampato rimane a piena risoluzione. È disponibile un'opzione del menu di scelta rapida Risoluzione grafica che consente di alternare la visualizzazione dei modelli selezionati tra visualizzazione semplificata e risoluzione piena.
  • Ora è disponibile una preferenza che si applica a tutti i tipi di file per scegliere lo stato di caricamento degli assiemi, assemblati o disassemblati.
Versione di GrabCAD Print 1.44, Luglio 2020
Numero di build 1.44.22.64105 rilasciata il 22 Luglio 2020
Fare clic qui per un video sull'aggiornamento 1.44.
  • Le assegnazioni Nucleo/Base possono essere personalizzate per fornire la migliore corrispondenza per il design di un modello.
  • La funzione di disposizione automatica per le stampanti J720 offre un migliore annidamento delle parti, rendendo la produzione più efficiente.
  • GrabCAD Print Server precedente alla versione 2.0 non sarà più in grado di connettersi a GrabCAD Cloud a partire da Luglio 21. Per continuare a connettersi alle stampanti tramite GrabCAD Print Server, disinstallare manualmente la versione precedente e installare Print Server 2.0. È possibile scaricare l'ultima versione qui.
  • GrabCAD Print Server 2.0 sarà supportato solo su Microsoft Windows 10 (64 bit) e Windows Server 2016 e versioni successive. Le istanze in esecuzione su versioni precedenti di Windows che non ricevono il supporto mainstream da Microsoft non verranno aggiornate automaticamente né potranno connettersi a GrabCAD Cloud a partire da Luglio 21. Sarà necessario aggiornare il sistema operativo sull'istanza del server di stampa o installare il server di stampa su una macchina con un sistema operativo supportato.
  • GrabCAD Print sta passando a un'installazione a livello di sistema (per macchina). Se si è interessati da questo passaggio, si riceverà una notifica quando sarà disponibile un aggiornamento e la migrazione (di solito) non richiederà alcuno sforzo da parte dell’utente. Dopo la v1.47, sarà necessario eseguire la migrazione alla nostra installazione per macchina per continuare a ricevere gli aggiornamenti.
  • GrabCAD Print ora consente di inviare file diagnostici dalla stampante al contatto dell'assistenza Stratasys. In caso di problemi di hardware, materiale, altre stampanti o persino software, ora è possibile andare su Guida -> Ottieni supporto stampante, dove è possibile aggiungere dettagli sul problema. GrabCAD Print genererà quindi un modello di posta elettronica insieme a tutti i dettagli e ai file pertinenti, che è possibile inviare all'indirizzo di posta elettronica fornito al momento della vendita.
  • I file 3MF con una struttura di assieme profonda (multi-livello) ora mostreranno l'intera struttura ad albero nel pannello Progetto.
Versione di GrabCAD Print 1.43, Giugno 2020
Numero di build 1.43.17.62943 rilasciata il 17 Giugno 2020
Fare clic qui per un video sull'aggiornamento 1.43.
  • Ora che le funzionalità FDM avanzate sono disponibili in GrabCAD Print, la creazione di progetti FDM avanzati non è più necessaria. L'opzione "Abilita FDM avanzato" è stata rimossa dal menu Preferenze e l'azione per creare un nuovo progetto FDM avanzato è stata rimossa dalla barra degli strumenti a sinistra.
  • Nell’ambito del trasferimento della funzionalità FDM avanzato nel core GrabCAD Print, i progetti creati in FDM avanzato verranno aperti in GrabCAD Print, con ogni modello su un vassoio separato. I gruppi vengono mantenuti, così come le impostazioni del corpo, le impostazioni della faccia, le proprietà del vassoio, l'orientamento e le note sulla produzione.
  • L'algoritmo che traduce i file VRML, OBJ e 3MF in oggetti stampabili è stato riscritto per evitare errori di slicing.
  • Se si seleziona il corpo di un VRML con un colore a tinta unita, il selettore del colore ora visualizzerà direttamente il colore e consentirà di apportare lievi modifiche.
  • Due nuove funzionalità per la stampante digitale per modelli anatomici
    • Lo strumento Long Bone Axis consente all'utente di definire le regioni prossimali e distali di un osso lungo. Ciò consente di stampare parti con densità variabile per approssimare la struttura delle ossa lunghe.
    • Molteplici procedure ortopediche richiedono la realizzazione di fori e l'inserimento di viti nei modelli stampati. In alcune occasioni, questo può portare a rotture indesiderate. Per evitare ciò, lo strumento Strain Relief consente di impostare un perimetro progettato per contenere eventuali incrinature prevenendo così incrinature più ampie nella parte stampata.
  • Presentazione di Stratasys J55. Creare senza compromessi in ogni fase del processo. Dai modelli concettuali veloci ai modelli ad alta fedeltà di qualità, la stampante J55 3D per l'ufficio è un'opzione conveniente per la massima resa dei designer. Ulteriori informazioni qui.
Versione di GrabCAD Print 1.42, Maggio 2020
Numero di build 1.42.19.62279 rilasciata il 20 Maggio 2020
Fare clic qui per un video sull'aggiornamento 1.42.
  • Posizionare e orientare i modelli più facilmente utilizzando il nuovo manipolatore. Fare clic sul pulsante più a destra nella striscia di controllo della vista per abilitarlo, quindi i modelli selezionati mostreranno le frecce che è possibile trascinare per spostare e ruotare la selezione liberamente o lungo un asse preciso.
  • Per le stampanti FDM, la spaziatura tra i modelli su un vassoio ora può essere regolata da un minimo di 0.2500 pollici (6.35 mm) a un massimo di 2.0000 pollici (50.8 mm) con un cursore nel pannello dello strumento Prepara. Ciò consentirà di ravvicinare maggiormente i modelli sul vassoio o di tenerli più distanziati per migliorare il flusso d'aria.
  • I nuovi profili colore CMYKW e CMYW aggiunti in 1.41 sono ora i profili colore predefiniti quando nella stampante vengono caricati materiali CMYKW e CMYW vivaci. Il nome del profilo è X-Rite i1Profiler CMYKW o CMYK.
  • In precedenza, il nucleo di una parte PolyJet veniva stampato con strati alternati di materiale bianco e nero, ma una nuova preferenza "Componente di base misto" in File> Preferenze> PolyJet consente di stampare il nucleo con una combinazione di tutti i materiali disponibili. Ciò riduce significativamente la probabilità di problemi di intasamento degli ugelli, poiché ciascuna testina di stampa verrà utilizzata più frequentemente, ma richiede che ciascuna cartuccia di materiale caricata disponga di materiale sufficiente per completare il lavoro.
Versione di GrabCAD Print 1.41, Aprile 2020
Numero di build 1.41.31.61723 rilasciata il 27 Aprile 2020
Fare clic qui per un video sull'aggiornamento 1.41.
  • Le ultime versioni dei pacchetti CAD sono ora supportate in GrabCAD Print. Sono inclusi SOLIDWORKS 2020, Inventor 2020, Creo 6.0 e altro. Leggere l'elenco completo qui.
  • È ora possibile modificare il materiale utilizzato nella griglia di supporto delle stampe della serie J per salvare i materiali utilizzati più comunemente. Tutte le strutture di supporto sul vassoio verranno stampate con i materiali selezionati. La selezione del materiale può essere eseguita in Impostazioni del vassoio> Avanzate> Materiale utilizzato per rafforzare il supporto.
  • Nel tentativo di introdurre funzionalità FDM avanzato in Stampa, è ora possibile applicare diverse impostazioni dei materiali ai corpi all'interno di Gruppi. Facendo clic con il pulsante destro del mouse sul gruppo, è possibile alternare tra:
    • Separa corpi - I corpi e le facce possono avere impostazioni applicate indipendentemente da altri corpi e facce. Simile al funzionamento di FDM avanzato.
    • Corpi combinati - Tutti i corpi nel Gruppo agiscono come un corpo unico, con una sola impostazione del corpo che si applica all'intero Gruppo e i confini interni rimossi. È simile al normale funzionamento degli assiemi quando si sceglie "Assemblato" senza creare un gruppo.
  • Quando per un gruppo assemblato è selezionato "Separa corpi", lo spessore della superficie, il posizionamento della giunzione e gli inserimenti sono disponibili nel pannello Impostazioni del modello, nella scheda Faccia. In precedenza questa funzionalità era disponibile solo in FDM avanzato.
  • Le funzioni minori che necessitano di supporto sulle stampe FDM generano un supporto che si accresce sotto la funzione. Questo ora può essere controllato dall'impostazione Accresci supporti, che consente di cambiare l'impostazione predefinita da "Accresci solo supporti piccoli" a "Non accrescere i supporti" o "Accresci tutti i supporti". Disattivare l’accrescimento del supporto può essere utile per ridurre l'utilizzo di materiale e il tempo di stampa per alcune parti.
  • I nuovi profili colore Vivid 2.0 sono stati aggiunti a GrabCAD Print, che offre una resa cromatica migliorata. I profili colore predefiniti non sono cambiati e rimangono Vivid 1.1.
  • Gli assiemi SOLIDWORKS con i colori delle facce ora possono essere caricati direttamente in GrabCAD Print senza il passaggio aggiuntivo di salvarli come parte multicorpo.
  • Per le stampanti FDM, i file 3MF con struttura di assieme verranno ora caricati con la loro struttura.
  • Quando si modifica un'impostazione FDM su un cursore, un rombo nero indicherà il valore predefinito. Facendo clic su di esso si ripristina il valore predefinito.
  • Con questa versione di GrabCAD Print, è possibile aprire facilmente i file da Ordini in GrabCAD Shop sul vassoio in GrabCAD Print. Ciò consente di risparmiare tempo, evitare il download di file CAD da e-mail o altri software di gestione delle richieste e aiuta a pianificare in modo efficiente i vassoi. Se non è stato già fatto, registrarsi a GrabCAD Shop qui.
  • Una casella di immissione "Aggiungi tramite IP" è stata aggiunta a GrabCAD Print Server per connettersi facilmente alle stampanti in cui il rilevamento automatico non è disponibile.
Versione di GrabCAD Print 1.40, Marzo 2020
Numero di build 1.40.28.60898 rilasciata il 24 Marzo 2020
Fare clic qui per un video sull'aggiornamento 1.40.
  • I file di parti SOLIDWORKS, inclusi i file multicorpo, ora includeranno i dati del colore applicati a livello di faccia per la stampa PolyJet. In precedenza, in GrabCAD Print erano inclusi solo i colori applicati a livello del corpo.
  • Provare come appariranno i colori nel modello stampato sulla stampante PolyJet creando un campione di colori selezionati dall'utente. Accedere allo strumento Campione colore andando su App> Strumento Campione colore.
  • GrabCAD Print ora consente agli utenti di stampare vassoi PolyJet più grandi ottimizzando il consumo di memoria GPU del computer. La funzione può essere abilitata in Preferenze> PolyJet> Ottimizzazione vassoio pesante.
  • Advanced Slicer è ora l'unico slicer disponibile per Stratasys J750 e Stratasys J735. Il filtro dei dati legacy non è più disponibile per queste stampanti. Non sono state apportate modifiche ad altre stampanti PolyJet.
  • Quando si invia un lavoro da Insight standalone a GrabCAD Print, la versione standalone deve essere la stessa o successiva alla versione Insight disponibile con GrabCAD Print altrimenti il lavoro non verrà inviato.
  • Abbiamo aggiornato il componente principale di GrabCAD Print all'ultima versione disponibile. Questo non solo risolve alcuni problemi in sospeso, come il caricamento di file da una cartella OneDrive, ma migliora anche le prestazioni generali e il tempo di avvio.
  • GrabCAD Print ora può importare file 3MF da molti strumenti CAD, nel caso di file 3MF creati da SOLIDWORKS, tra cui: colore del viso, colore del corpo e texture. Per le stampanti PolyJet gli assiemi avranno una struttura piatta e per le stampanti FDM non ci sarà alcuna struttura di assieme.
  • Miglioramenti specifici di FDM
    • Per fornire una migliore qualità complessiva delle parti quando si utilizza TPU 92A sulla stampante Stratasys F370, l'intervallo di larghezza per il riempimento residuo di larghezza variabile è stato ridotto.
    • L'angolo per i fori autoportanti è stato aumentato a 55 gradi per adattarsi all'angolo autoportante per il materiale Diran 410mf07.
    • Risolto un problema per cui poteva essere generato un supporto incompleto per alcuni modelli e orientamenti.
  • Il nome predefinito assegnato a un gruppo, introdotto in GrabCAD Print 1.36, può ora essere rinominato in un altro più logico per l'utente.
Versione di GrabCAD Print 1.39, Febbraio 2020
Numero di build 1.39.14.59507 rilasciata il 18 Febbraio 2020
Fare clic qui per un video sull'aggiornamento 1.39.
  • Il nuovo pannello Impostazioni modello PolyJet offre un design e flussi di lavoro utente migliorati, la possibilità di salvare materiali e colori preferiti e di creare i propri colori e materiali digitali utilizzando la nuova funzione di input CMYK. Ulteriori informazioni qui.
  • Quando si crea un gruppo da un assieme a cui è stata applicata la scala o l'orientamento, il gruppo appena creato erediterà queste proprietà dall'assieme.
  • Ora è possibile eliminare una stampante disconnessa dall'elenco delle stampanti. Basta fare clic con il tasto destro sulla stampante da rimuovere e selezionare "elimina stampante".
  • Ora è disponibile una visualizzazione più chiara e intuitiva dello stato del contenitore scarti per le stampanti PolyJet situata nel pannello dei materiali.
  • Avviso su Advanced PolyJet Slicer: Nell'aggiornamento di marzo, GrabCAD Print versione 1.40, l'opzione per disabilitare Advanced PolyJet Slicer per J750 e J735 non sarà più disponibile.
Versione di GrabCAD Print 1.38, Gennaio 2020
Numero di build 1.38.21.59019 rilasciata il 28 Gennaio 2020
Fare clic qui per un video sull'aggiornamento 1.38.
  • Se si dispone di stampanti PolyJet, è possibile provare il nuovo pannello delle impostazioni del modello, in cui sono stati migliorati il design e la possibilità di salvare i preferiti. Andare su File> Preferenze> PolyJet e selezionare la casella di controllo per utilizzare il nuovo pannello Impostazioni modello PolyJet.
  • Il nuovo materiale VeroUltraClear, introdotto per J850 e J835 in 1.36, è ora disponibile su J750 e J735. VeroUltraClear simula l'acrilico, raggiungendo il 95% di trasmissione della luce di quel materiale ed è utile per prototipi di vetro, polimeri trasparenti o imballaggi trasparenti. Ulteriori informazioni sul materiale VeroUltraClear qui.
  • È possibile sostituire le parti VRML/OBJ con una nuova assegnazione di colore e materiale dal pannello Impostazioni modello e, se necessario, ripristinarle all'originale, con una nuova opzione di menu di scelta rapida sui corpi VRML/OBJ selezionati.
  • Lo stato predefinito della preferenza di struttura VRML/OBJ è stato modificato da off a on.
  • Gli schemi di riempimento per Diran 410MF07 su Advanced FDM ora includono denso singolo, denso doppio e solido. Inoltre, il materiale del primo strato è stato cambiato dal supporto al materiale del modello per migliorare l'adesione del vassoio.
  • È stato risolto un problema che causava la visualizzazione di nomi di modello errati per le stampanti Stratasys nella vista Programma.
Versione di GrabCAD Print 1.37, Dicembre 2019
Numero di build 1.37.15.57828 rilasciata il 18 Dicembre 2019
Fare clic qui per un video sull'aggiornamento 1.37.
  • La funzione di avvio ritardato per le stampanti PolyJet introdotta nella versione 1.20 è ora supportata da Advanced PolyJet Slicer. NOTA: la stampante deve essere nello stato "inattivo" affinché la selezione sia disponibile.
  • Una nuova impostazione di stampa PolyJet per la post-elaborazione consente di aggiungere un sottile strato di materiale trasparente per la lucidatura. La lucidatura del livello trasparente si traduce in un modello con una superficie liscia e colori e trame ad alta fedeltà.
  • Ora è possibile visualizzare in anteprima e creare un documento traveler PDF contenente le note di fabbricazione e le schermate dei modelli per il vassoio attualmente attivo.
Versione di GrabCAD Print 1.36, Novembre 2019
Numero di build 1.36.17.57117 rilasciata il 20 Novembre 2019
Fare clic qui per un video sull'aggiornamento 1.36.
  • La nuova stampante J750™ Digital Anatomy™ 3D è ora supportata, pre-programmata con una serie di applicazioni anatomiche sviluppate in collaborazione con produttori di dispositivi medici, istituti di ricerca di livello mondiale, ospedali e personale medico. Accurata, realistica e funzionale, si può ottenere la sensazione, il comportamento e le dimensioni del soggetto reale. Ulteriori informazioni sulla stampante J750 Digital Anatomy 3D qui.
  • I nuovi J850 e J835 sono ora supportati. Design e creatività non hanno limiti. Ora, con Stratasys J850/J835, lo stesso vale per i prototipi. La nostra tecnologia collaudata semplifica l'intero processo di progettazione, ottimizzando i flussi di lavoro in modo da poter dedicare più tempo a ciò che conta: creare, perfezionare e progettare il miglior prodotto possibile. Ulteriori informazioni su Stratasys J850 qui.
  • I modelli selezionati possono ora essere raggruppati tramite un nuovo pulsante nella parte superiore del pannello Progetto o un comando del pulsante destro del mouse. Quando viene creato un nuovo gruppo, l'assieme esistente verrà compresso e nascosto. Il nuovo gruppo può essere impostato su assemblato o disassemblato. È possibile creare gruppi aggiuntivi dall'assieme originale.
  • Esiste una nuova opzione nelle impostazioni di PolyJet Advanced Slicer per mostrare la struttura dell'assieme per i file VRML e OBJ. Con questa opzione abilitata, GrabCAD Print determina la struttura geometrica dei file VRML o OBJ e visualizza la struttura come un assieme di corpi nel pannello del progetto. Ogni corpo può essere multicolore (ovvero testurizzato, con colori del vertice, della faccia o composto da più fogli di diverso colore) o monocolore (ovvero tutti i fogli del corpo condividono un unico colore diffuso). L'utente può modificare le assegnazioni di materiale per qualsiasi corpo monocolore all'interno di tale assieme.
  • Quando si importa un file SOLIDWORKS (.sldprt o .sldasm), gli attributi di trasparenza associati ai corpi SOLIDWORKS vengono convertiti automaticamente in valori alfa nel pannello dei materiali PolyJet se viene caricato un materiale trasparente.
  • Le licenze dei materiali per le stampanti Stratasys e Fortus che richiedono licenze possono essere aggiornate da GrabCAD Print. L'aggiornamento di una licenza materiale richiede che un utente disponga dei privilegi di amministratore locale.
  • Il pannello di progetto è stato rinnovato per migliorare l'usabilità. Le modifiche includono icone riprogettate, migliore allineamento, evidenziazione della selezione più chiara, menu a tendina anziché casella di controllo per lo stato assemblato/disassemblato e un'indicazione più chiara dello stato mostra/nascondi.
  • La selezione tangente delle facce è ora disponibile come comando con il pulsante destro del mouse quando Stampa è in modalità Selezione facce. Ciò può essere utile quando si aggiungono note di produzione a una catena di superfici.
  • A corpi e facce possono essere aggiunte annotazioni, note come Note di produzione. Il comando per aggiungere una nota è disponibile con il tasto destro del mouse, in questo modo si aggiunge un callout che può essere attivato facendo clic per mostrare la nota e consentirne la modifica.
  • Nuovo materiale VeroUltraClear per le stampanti Stratasys J850 e Stratasys J835 3D. VeroUltraClear simula l'acrilico, raggiungendo il 95% di trasmissione della luce di quel materiale ed è utile per prototipi di vetro, polimeri trasparenti o imballaggi trasparenti. Ulteriori informazioni sul materiale VeroUltraClear qui .
  • ABS ESD7 è ora supportato sulla stampante Stratasys F370 per GrabCAD Print. ABS ESD7 è un materiale per utensili progettato per applicazioni sensibili all'elettricità statica, per prevenire scariche o attrazione di altri materiali come polveri, polvere o particelle fini. Ulteriori informazioni sul materiale ABS ESD7 qui.
Versione di GrabCAD Print 1.35, Ottobre 2019
Numero di build 1.35.21.56592 rilasciata il 24 Ottobre 2019
Fare clic qui per un video sull'aggiornamento 1.35.
  • Abbiamo migliorato il comportamento sia del pulsante Stampa sia dell'elenco delle stampanti quando è richiesto un aggiornamento di Gestione processi per la stampante PolyJet. Il pulsante di stampa mostrerà un pop-up e quando si fa clic sull'elenco delle stampanti, si verrà reindirizzati direttamente alla schermata Impostazioni in cui è possibile eseguire l'aggiornamento.
  • È stata aggiunta una casella di controllo nella sezione Avanzate delle Impostazioni vassoio per controllare le lampade UV per le stampanti della serie J. Se si verificano problemi di sovraesposizione nelle stampe, rivolgersi al rivenditore o al supporto tecnico di Stratasys per vedere se questa impostazione può essere d'aiuto.
  • Quando si stampa con i colori Pantone sulla stampante serie J, solo alcuni dei colori richiedono VeroBlackPlus. In precedenza, l'intero selettore di colori Pantone veniva disabilitato se non era stato caricato mentre ora solo i colori specifici sono disabilitati. Pantone richiede ancora tutti e tre i materiali Vivid Vero e VeroPureWhite.
  • Il caricamento del modello è ora un'azione annullabile. In precedenza, se veniva commesso un errore e si selezionava il file sbagliato, era necessario attendere che si caricasse prima di poterlo rimuovere, mentre ora è possibile annullarlo subito.
  • Quando si applicano le impostazioni a una faccia specifica in Advanced FDM, ora è possibile rimuoverle tramite il menu di scelta rapida. In precedenza, era necessario usare Annulla per ripristinare le impostazioni della faccia.
  • Supporto per nuovi materiali FDM:
    • Antero 840CN03 è ora supportato sulla stampante Stratasys F900 per GrabCAD Print. Ulteriori informazioni sul nuovo materiale Antero 840CN03 qui.
    • Diran 410MF07 è ora supportato sulla stampante Stratasys F370 per GrabCAD Print. Diran è il materiale ideale per le applicazioni di utensili. Ulteriori informazioni sul nuovo materiale Diran 410MF07 qui .
  • TPU 92A ora supporta slice di 0.0070 pollici (0.1778 mm) sulla stampante Stratasys F370. La qualità di stampa è migliorata per la slice 0.0070 e la slice 0.0100 pollici (0.2540 mm). Il software del controller F123 deve essere aggiornato alla versione 2.1 per sfruttare questi miglioramenti.
  • L'eliminazione della Cronologia stampante richiede ora che un utente disponga dei privilegi di amministratore locale.
Versione di GrabCAD Print 1.34, Settembre 2019
Numero di build 1.34.16.55783 rilasciata il 19 Settembre 2019
Fare clic qui per un video sull'aggiornamento 1.34.
  • PolyJet Advanced Slicer, introdotto come opzione in 1.31, è ora attivo per impostazione predefinita. Ha migliorato la precisione delle stime e abilita alcune funzioni elencate qui. Può essere disattivato da Preferenze > PolyJet se è necessario utilizzare lo slicer precedente per qualsiasi motivo.
  • Ora è possibile accedere ai tutorial e ai file di esempio di GrabCAD nel menu Guida di GrabCAD Print relativo alla stampante selezionata. I nostri ingegneri applicativi aggiungono costantemente nuovi contenuti per agevolare l'utilizzo delle macchine; il contenuto sarà disponibile tramite il menu Guida.
  • Usando l'interruttore nella barra di visualizzazione etichettata "Anteprima superfici supportate" è possibile vedere rapidamente dove verranno generati i supporti sui modelli. Questa funzione è stata introdotta per le stampanti PolyJet in 1.24 ed è ora disponibile anche per le stampanti FDM. Ciò fornisce un'alternativa più rapida all'anteprima della slice FDM per facilitare la preparazione del vassoio, in quanto mostra in che modo le impostazioni di orientamento e supporto (come l'angolo autoportante) influiranno sulla superficie della stampa.
  • Quando si visualizza un lavoro PolyJet in corso nella vista Programma o nell'app mobile GrabCAD Print, la precisione della previsione "Ora fine" è stata notevolmente migliorata. La previsione verrà aggiornata periodicamente durante il processo per tenere conto delle pause di stampa e di altri errori nella stima iniziale.
  • Il controllo dell'opzione Ritardo slice nel pannello delle impostazioni del vassoio PolyJet riduce il verificarsi di depressioni sul modello. L'opzione dovrebbe essere utilizzata solo dopo aver parlato con il supporto tecnico di Stratays. L'utilizzo dell'opzione aumenta il tempo di stampa del lavoro.
  • L'elenco dei materiali mostrato nel pannello Impostazioni vassoio per le stampanti PolyJet ora include il materiale di supporto.
  • Ora GrabCAD Print invierà le notifiche degli aggiornamenti per stampanti selezionate come la serie F123 e J750. Possono includere informazioni su nuovi materiali, contenuti di apprendimento e altro. Quando viene selezionata una di queste stampanti ed è disponibile un aggiornamento, sarà visualizzata una confezione regalo nella parte inferiore sinistra dello schermo.
Versione di GrabCAD Print 1.33, Agosto 2019
Numero di build 1.33.10.54793 rilasciata il 20 Agosto 2019
Fare clic qui per un video sull'aggiornamento 1.33.
  • Sulle stampanti supportate da Advanced FDM, alcune funzioni avanzate sono ora disponibili nella scheda Impostazioni modello. Queste includono densità di riempimento, angolo di riempimento e spessore del corpo e, quando vengono utilizzati file CAD, la possibilità di trasformare un foro cilindrico in un diamante autoportante.
  • Analogamente alla modifica apportata al pannello delle impostazioni FDM nell'ultimo aggiornamento, il pannello delle impostazioni PolyJet è ora suddiviso in impostazioni del vassoio e impostazioni del modello per consentire spazio per ulteriori funzionalità negli aggiornamenti futuri.
  • Ora è possibile scegliere di esportare un CMB senza la parte di spurgo o la torretta sacrificabile. Ciò consente di impedire la stampa di più parti di spurgo durante la stampa di più file CMB in un processo. Per impostazione predefinita, la parte di spurgo/torretta sacrificabile è inclusa.
  • Per i modelli di stampanti Stratasys F900, Fortus 900mc e Fortus 400mc, l'ABS è ora il materiale predefinito. Per le stampanti live, il materiale continuerà a utilizzare la configurazione corrente come impostazione predefinita.
  • Avviso per gli utenti J750 e J735: Advanced Slicer, introdotto in 1.31, sarà *ON* per impostazione predefinita nell'aggiornamento dei prossimi mesi, versione 1.34.
Versione di GrabCAD Print 1.32, Luglio 2019
Numero di build 1.32.19.54065 rilasciata il 22 Luglio 2019
Fare clic qui per un video sull'aggiornamento 1.32.
  • Il pannello Impostazioni stampa per la preparazione della stampa FDM è stato suddiviso in 3 pannelli: Impostazioni vassoio, Impostazioni modello e Impostazioni supporto. Sono state aggiunte anche nuove icone.
  • La modalità Analisi ora può riparare i file VRML e OBJ con i colori dei vertici e la riparazione dei file con colori e texture dei volti è stata migliorata.
  • Gli utenti J750 e J735 possono ora stampare modelli opachi con materiali Vivid e Advanced Slicer. Deselezionare la casella di controllo "Traslucido" nel pannello Impostazioni di stampa per stampare i corpi con una base bianca. Questo funziona attualmente solo per file/assiemi di mesh non strutturati.
  • Un problema per alcuni lavori Fortus e F123 stava causando uno strano comportamento per la parte di spurgo/torretta sacrificabile, portando a guasti. Questo è stato risolto.
  • Quando si seleziona Agilus 30 Clear, il modello viene visualizzato al livello di trasparenza associato al valore Shore A impostato.
Versione di GrabCAD Print 1.31, Giugno 2019
Numero di build 1.31.52720.53058 rilasciata il 20 Giugno 2019
Fare clic qui per un video sull'aggiornamento 1.31.
  • Advanced FDM, introdotto in 1.24 per le stampanti F900, F370 e Fortus, è ora disponibile per F170 e F270. Advanced FDM consente di personalizzare il riempimento in diverse sezioni del modello utilizzando la geometria CAD effettiva, nonché di modificare la geometria del foro per la stampabilità. Leggi di più qui.
  • Advanced Slicer, ora disponibile in File> Preferenze> Polyjet, offre agli utenti J750 e J735 tutta una serie di miglioramenti e nuove funzionalità:
    • Colori Pantone® convalidati nel selettore colori.
    • I VRML con trasparenza nella texture useranno una base trasparente.
    • Stime e precisione di stampa migliorate per funzioni e testo di piccole dimensioni.
    • Opzioni di supporto personalizzate che correggono l'effetto "ombra supporto" su pareti verticali con fori.
    • Priorità delle parti personalizzate quando i componenti dell'assieme si sovrappongono.
    • Pieno controllo sul posizionamento delle parti sul vassoio.
  • La nuova versione di GrabCAD Print Server funziona come un servizio Windows, continuerà a funzionare anche se l'utente Windows è disconnesso. Inoltre, è compatibile con Windows Server 2012 e può essere installata insieme alla versione per macchina di GrabCAD Print. Questo aggiornamento non è automatico, è necessario scaricare la nuova versione qui. Per assistenza con l'installazione, fare clic qui.
  • La modalità Analisi consente ora di correggere gli errori di mesh nei file VRML strutturati.
  • Il messaggio di errore quando si tenta di aggiungere un modello da un pacchetto CAD non ancora supportato, come Inventor 2020, sarà ora più informativo di un errore generico.
  • Per le stampanti FDM, i supporti vengono generati ovunque l'angolo della superficie della parte scenda al di sotto di un valore specificato, noto come angolo autoportante, e ora tale valore è regolabile nel pannello Impostazioni di stampa. È possibile aumentare o ridurre la quantità di supporti generati e ripristinare il valore sulla raccomandazione predefinita, che varia a seconda delle stampanti e dei materiali.
  • L'aggiunta di un file CAD o CMB che non corrisponde al file o alle impostazioni nel progetto GrabCAD Print corrente genera un conflitto anziché un errore, un nuovo avviso consente di salvare le modifiche e aprire un nuovo progetto.
Versione di GrabCAD Print 1.30, Maggio 2019
Numero di build 1.30.28.52238 rilasciata il 22 Maggio 2019
Fare clic qui per un video sull'aggiornamento 1.30 .
  • La cronologia della stampante può essere eliminata dalla pagina Cronologia della stampante dell'applicazione GrabCAD Print. L'opzione è abilitata da una preferenza; la preferenza è attiva solo per la sessione GrabCAD. Le stampanti devono essere inattive quando la cronologia viene eliminata, sebbene possano avere lavori in coda.
  • Abbiamo esaminato le traduzioni in GrabCAD Print e corretto errori in 6 punti.
Versione di GrabCAD Print 1.29, Aprile 2019
Numero di build 1.29.6.51061 rilasciata il 16 Aprile 2019
Fare clic qui per un video sull'aggiornamento 1.29.
  • Le ultime versioni dei pacchetti CAD sono ora supportate in GrabCAD Print. Sono inclusi SOLIDWORKS 2019, Inventor 2019, Creo 5.0, NX 12.0 e altro. Leggere di più qui.
  • Accedere facilmente alle stampanti con il nuovo pannello delle stampanti. Qui sono presenti stampanti preferite, ricerca e filtro avanzati e molti altri miglioramenti. E desideriamo un feedback al riguardo! Attivarlo da File> Preferenze> GrabCAD Labs e inviare le proprie opinioni.
  • La versione Beta dell'ultimo membro della serie Stratasys F123, la F120, è supportata da GrabCAD Print. Leggere qui.
  • Ora è possibile utilizzare il materiale del modello nelle strutture di supporto per la stampa FDM quando si selezionano gli stili di supporto SMART, Sparse o Box. Poiché la stampante impiega alcuni secondi per passare dal materiale del modello a quello di supporto, questa funzione consente di utilizzare solo il materiale del modello per molti strati, risparmiando tempo sulla stampa.
  • I modelli Insight ora possono essere inviati a GrabCAD Print da Insight con il clic di un pulsante. Selezionando l'icona "Crea lavoro in GrabCAD Print" sulla barra degli strumenti di Insight si crea un file CMB e si trasferisce il file da Insight a GrabCAD Print e si selezionerà automaticamente il tipo di stampante corretto.
Versione di GrabCAD Print 1.28, Marzo 2019
Numero di build 1.28.16.50383 rilasciata il 21 Marzo 2019
Fare clic qui per un video sull'aggiornamento 1.28.
  • Manca la tecnologia o la capacità di stampare più parti? Andare su App> "Crea il mio pezzo con Stratasys Direct Manufacturing" per accedere alla home page di SDM. (Solo per clienti USA/Canada.)
  • L'orientamento automatico è ora disponibile nella scheda Advanced FDM. Sia i corpi standard che quelli uniti possono essere auto-orientati, per ridurre al minimo il supporto e diminuire il tempo di costruzione.
  • I file OBJ con texture di immagini sono ora supportati. Quando si stampa su stampanti PolyJet, verranno letti e visualizzati i file di texture delle immagini associati al file OBJ e verrà stampato il risultato unito.
  • È stato risolto un problema di qualità della parte quando si utilizza il riempimento di esagrammi su stampanti serie F123. Per i materiali F123 ASA e F123 ABS, sull'altezza slice da 0.005 pollici (0.127 mm) e 0.007 pollici (0.178 mm), la densità del riempimento viene ridotta per evitare il riempimento eccessivo.
  • I pannelli Impostazioni di stampa, Orientamento e Scala sono stati aggiornati per contare solo i modelli o i corpi sul vassoio attivo.
  • Si è verificato un errore nella cronologia della stampante che si esporta dall'app desktop in cui la "Durata" mostrava 00:00:00 per tutti i lavori. Questo è stato risolto.
  • L'app genera alcuni file nella directory temporanea e in precedenza si sono accumulati nel tempo. Ora vengono cancellati automaticamente alla chiusura dell'app.
  • Alcuni utenti stavano riscontrando un bug per cui non erano in grado di avviare GrabCAD Print, visualizzando un errore "Troppe istanze ...". Ciò era causato dal componente aggiuntivo GrabCAD Print per SOLIDWORKS che ora è stato sospeso.
Versione di GrabCAD Print 1.27, Febbraio 2019
Numero di build 1.27.17.49710 rilasciata il 25 Febbraio 2019
Fare clic qui per un video sull'aggiornamento 1.27.
  • Il riempimento a larghezza variabile, introdotto in 1.24 per la serie F123 e Fortus 900mc, è ora disponibile su Fortus 380mc, 380mc CFE e 450mc. Questa funzione richiede la versione 6.1 del firmware della stampante (disponibile da 13 Marzo 2019). Seguire le istruzioni qui per aggiornare il firmware sulla macchina.
  • Quando si importa un file CMB da stampare su una stampante FDM, verrà automaticamente selezionata la stampante corretta. Inoltre, sarà ora possibile ruotare quel modello attorno all'asse Z.
  • Alcune combinazioni di materiali non sono consentite in un lavoro di stampa PolyJet, come Vero e VeroFlex, o utilizzando solo uno dei due materiali RGD per Digital ABS. In precedenza, se la stampante era stata caricata con questa combinazione di materiali non supportata, la stampante mostrava uno stato di errore e la stampa era disabilitata, anche se il lavoro stesso non utilizzava la combinazione non supportata. Ora, gli utenti saranno in grado di stampare i loro lavori indipendentemente dai materiali attualmente caricati nella stampante, a condizione che la combinazione non supportata non venga utilizzata nel lavoro.
Versione di GrabCAD Print 1.26, Gennaio 2019
Numero di build 1.26.13.48725 rilasciata il 28 Gennaio 2019
  • Il riempimento a larghezza variabile, introdotto in GrabCAD Print 1.24 come parte del pannello Impostazioni di stampa, è ora disponibile in Advanced FDM.
  • La parte di spurgo (serie F123) e la torretta sacrificabile (alcune stampanti Fortus) si posizionano automaticamente nella posizione ottimale sul vassoio, sebbene possa essere spostata manualmente. Ora, in questo caso, rimarrà in quella posizione finché non si utilizzerà lo strumento Disponi vassoio o Disponi progetto. È possibile anche spostare solo la parte di spurgo/torretta sacrificabile facendo clic con il pulsante destro del mouse su di essa e selezionando "Ricerca automaticamente".
  • Il ripristino è ora disponibile per l'orientamento in GrabCAD Print e Advanced FDM. Selezionando un modello e selezionando Ripristina, il modello verrà riportato all'orientamento che aveva quando è stato inizialmente aggiunto al vassoio.
  • È stato risolto un problema che bloccava l'installazione di GrabCAD Print in determinate situazioni. Contattare print@grabcad.com se i problemi nell'installazione persistono.
Versione di GrabCAD Print 1.25, Dicembre 2018
Numero di build 1.25.17.47934 rilasciata il 4 Gennaio 2019
  • Il programma di installazione per macchina che è stato rilasciato per il beta test in 1.16 è ora disponibile al pubblico da print.grabcad.com. Oltre ad essere molto più stabile dell'attuale programma di installazione per utente, consente l'implementazione presso le scuole e le organizzazioni aziendali dagli amministratori del sistema IT. Per ulteriori informazioni e istruzioni sul passaggio, leggere il nostro articolo di assistenza.
  • I file OBJ e VRML con autointersezioni, problemi di tenuta/facce aperte e normali invertite possono ora essere riparati da GrabCAD Print prima di essere stampati su tecnologie PolyJet. Per provarlo, contattare print@grabcad.com .
  • I suggerimenti sul pannello Impostazioni di stampa spiegano il comportamento del riempimento a larghezza variabile, dello stile di costruzione della parte, del tipo di parte di spurgo o di torretta sacrificabile, della modalità di sistema e del materiale del primo strato. Il contenuto del suggerimento consente di mostrare solo il contenuto per le opzioni disponibili per l'azione.
Versione di GrabCAD Print 1.24, Novembre 2018
Numero di build 1.24.15.46944 rilasciata il 20 Novembre 2018
  • GrabCAD Print Advanced FDM offre un set di strumenti potenti e intuitivi per ottenere le caratteristiche desiderate dei pezzi, controllando automaticamente gli attributi di costruzione FDM.  Assegnando gli attributi direttamente alla geometria del suo file CAD, può specificare le aree di resistenza e rigidità, controllare i riempimenti, garantire un materiale sufficiente intorno ai fori con inserti ed evitare le cuciture.  Tutti i percorsi utensile necessari vengono poi calcolati automaticamente, senza richiedere la manipolazione manuale dei singoli strati; in definitiva, si riduce il tempo necessario per preparare un lavoro, migliorando la qualità complessiva del pezzo. L'FDM avanzato è disponibile per alcune stampanti selezionate (F370, 380mc, 380mc CFE, 400mc, 450mc, 900mc e F900) ed è disponibile in File > Preferenze > FDM.
  • Ora i file OBJ possono essere aggiunti a GrabCAD Print con i colori, il file .mtl associato e le texture visive, per la stampa PolyJet. Questa funzione deve essere abilitata in File> Preferenze> GrabCAD Labs. Per sapere cosa è supportato, andare qui.
  • I materiali di nuova disponibilità sono supportati in GrabCAD Print, tra cui VeroCyan Vivid, VeroFlex Cyan/Magenta/Yellow Vivid & Agilus 30 White su J750/J735, MedABS e Med615 su Connex3, Antero 800NA su F900 e un nuovissimo materiale flessibile per la serie F123 denominato FDM TPU 92A. I nuovi materiali per Connex3 e J750/J735 richiedono un aggiornamento del software integrato.
  • Quando viene selezionata una stampante PolyJet, una nuova modalità di visualizzazione disponibile nella riga superiore dei pulsanti sopra il visualizzatore 3D consentirà all'utente di vedere dove verrà posizionato il materiale di supporto sulla superficie del modello. Questo determina il limite per la finitura lucida.
  • Alcune stampanti FDM ora offrono un'impostazione facoltativa per utilizzare il riempimento a larghezza variabile per le build di parti interne. Quando sono impostati, i percorsi utensili a larghezza variabile vengono posizionati automaticamente dove rimangono spazi tra i percorsi utensili a larghezza predefinita inferiori alla larghezza predefinita e superiori alla larghezza minima per la dimensione puntina suggerita. Questo è supportato per le serie F123 e F900 e Fortus 900mc dopo l'installazione dell'ultimo aggiornamento firmware (rispettivamente versioni 1.8 e 3.26 o successive).
  • Aggiornamenti al pannello dei dettagli del lavoro in Vista programma per indicare visivamente la quantità di materiale stimata per il lavoro selezionato. I suggerimenti mostrano agli utenti la stima del materiale che rimarrà nel contenitore o nella cartuccia al termine del lavoro. Per FDM, il primo lavoro in coda indica la quantità di materiale nel contenitore/cartuccia all'avvio del lavoro.
  • Il pannello dei dettagli del lavoro in Visualizza programma elenca ora le dimensioni puntina e la risoluzione di costruzione richiesta per il lavoro per le stampanti FDM. Questo è utile agli utenti per verificare cosa è richiesto per il lavoro rispetto a ciò che è attualmente caricato sulla stampante.
Versione di GrabCAD Print 1.23, Ottobre 2018
Numero di build 1.23.20.45529 rilasciata il 17 Ottobre 2018
  • Sono disponibili diversi miglioramenti al rapporto Cronologia:
    • L'esportazione per Cronologia lavori è ora disponibile in entrambi i formati .XLSX e .CSV, con .XLSX come predefinito.
    • Per distinguere i tempi di stampa dal riscaldamento e da altri tempi trascorsi durante il lavoro, la colonna "Durata" è ora divisa in "Tempo lavoro totale", il tempo trascorso totale tra inizio e fine, e "Tempo di stampa totale" che esclude il tempo di pausa o riscaldamento della stampante.
    • Una nuova colonna nella Vista cronologia mostra l'elenco delle parti nel lavoro. Le quantità della stessa parte verranno visualizzate con un (#) dopo il nome della parte. Ad esempio "HingePin (3)". Attualmente questa funzione è disponibile solo per le stampanti FDM. (Nota: i lavori stampati con GrabCAD Print 1.22 e versioni precedenti mostreranno qui i nomi delle parti criptati.)
    • Per le stampanti FDM, la Cronologia lavori esportata ora include due colonne per le dimensioni puntina per supporto e modello.
  • Le parti possono essere stampate utilizzando ULTEM™ 9085 con una risoluzione di 0,013" sulla stampante Fortus 450mc
  • I modelli sono visualizzati in Opaco o Lucido in base alle proprietà del materiale impostate
Versione di GrabCAD Print 1.22, Settembre 2018
Numero di build 1.22.24.44746 rilasciata il 26 Settembre 2018
  • Esiste una nuova opzione di preferenza per disabilitare gli aggiornamenti automatici di GrabCAD Print. i riceverà comunque una notifica quando è disponibile un aggiornamento.
  • È disponibile una nuova opzione di preferenza per rendere l'importazione dei file CAD più precisa, aggiungendo più triangoli alla mesh che rappresenta il file CAD. Tuttavia questa opzione influirà sulle prestazioni.
  • Con questa versione, abbiamo risolto alcuni problemi relativi al modo in cui le stampanti si collegano a GrabCAD Print (incluso l'elenco delle stampanti che scompare dopo un aggiornamento) e migliorato la segnalazione degli errori per risolvere meglio i potenziali problemi di connettività in futuro.
  • I modelli possono ora essere orientati automaticamente per tutte le stampanti FDM, che orientano i modelli per generare il minimo materiale di supporto.
  • Ora i lavori possono essere stampati utilizzando il materiale di supporto come strato di base sulle stampanti F123 sia per ABS che per ASA quando si utilizza la risoluzione .005". Ciò aumenta il rischio di problemi di adesione del vassoio, ma consente di rimuovere più facilmente le parti piccole.
  • Sulle stampanti FDM in cui è disponibile un riempimento a doppia densità, lo stile di riempimento di esagrammi è ora un'opzione. Questo modello è molto efficace ed efficiente da costruire.
  • L'orario di ufficio e l'avvio ritardato della stampa potrebbero consentire a una coda di apparire vuota in Vista programma quando non lo è, pertanto è disponibile un nuovo pulsante che viene visualizzato quando è necessario scorrere verso destra per visualizzare i lavori in coda.
  • Quando si fa clic su un lavoro attualmente in stampa in Vista programma, si vedrà ora una stima di quanto materiale rimarrà al termine del lavoro. Per le stampanti FDM, è anche possibile visualizzare una stima dei livelli del materiale di partenza per il lavoro successivo.
  • La giuntura (dove inizia e finisce il percorso utensili per le stampanti FDM) è ora visibile nell'anteprima slice.
  • Le parti possono essere stampate usando Antero 800NA sulla stampante 450mc.
Versione di GrabCAD Print 1.20, Luglio 2018
Numero di build 1.20.50.42688 rilasciata il 18 Luglio 2018
  • È ora disponibile l'avvio ritardato per le stampanti PolyJet! Quando la stampante PolyJet è inattiva e la coda è vuota, è ora possibile pianificare l'inizio della stampa in un momento specifico dopo aver premuto il pulsante Stampa. Questa funzione non è ancora disponibile se si è connessi in remoto alla stampante tramite GrabCAD Print Server.
  • Nella Vista programma è ora possibile fare clic su un pulsante sull'immagine della fotocamera per le stampanti della serie F123 per ingrandirla a piena risoluzione. La stessa funzione è disponibile per l'immagine di anteprima del lavoro per tutte le stampanti.
  • Dopo 3 mesi di test, i sistemi Connex3 sono completamente supportati da GrabCAD Print. Leggere la guida di installazione per iniziare.
  • GrabCAD Print ora supporta la nuova stampante Fortus 380mc Carbon Fiber Edition.
  • La sessione di accesso per GrabCAD Print scadrà solo dopo 2 mesi di inattività. Precedentemente la scadenza era di 1 settimana.
  • Se sono stati acquistati i nuovi materiali Vivid Vero per la tua stampante PolyJet, sono ora disponibili per la selezione in GrabCAD Print.
Versione di GrabCAD Print 1.19, Giugno 2018
Numero di build 1.19.14.41748 rilasciata il 15 Giugno 2018
  • Quando si fa clic su Stampa per inviare un lavoro alla stampante PolyJet, verrà visualizzato un avviso se la stampante non ha caricato abbastanza materiale o se il contenitore scarti è pieno.
  • I lavori contenenti un numero elevato di file duplicati verranno elaborati più rapidamente di prima. Inoltre, i tempi di caricamento dei file VRML complessi o multi-corpo sono migliorati del 60-80%.
  • È ora possibile esportare il file di configurazione della stampante durante una connessione alla stampante locale o remota tramite GrabCAD Print Server.
  • GrabCAD Print ora supporta il nuovo tipo di sistema Stratasys F900. Stratasys F900 è la sostituzione del sistema Fortus 900mc e include un sistema di controllo dell'umidità aggiornato e miglioramenti generali del sistema.
Versione di GrabCAD Print 1.18, Maggio 2018
Numero di build 1.18.19.40241 rilasciata il 10 Maggio 2018
  • Alcuni miglioramenti per gli utenti PolyJet, tra cui:
    • Nuova funzionalità di copia e incolla per le impostazioni di stampa.
    • Barra di avanzamento per convalida, stima e accodamento dei vassoi.
    • Stabilità dello slicer migliorata per la stampa di STL duplicati pesanti.
    • I materiali Agilus possono ora essere stampati con il materiale di supporto SUP706B. Utilizzare questa combinazione solo se è stata ricevuta la nuova formula di supporto (nota anche come 706B).
  • Il componente aggiuntivo GrabCAD Print per SOLIDWORKS è ora supportato in SOLIDWORKS 2018. Dopo l'aggiornamento a GrabCAD Print 1.18, modificare l'installazione nel Pannello di controllo per installare il componente aggiuntivo.
Versione di GrabCAD Print 1.17, Aprile 2018
Numero di build 1.17.14.39209 rilasciata il 12 Aprile 2018
  • I sistemi Connex3 (inclusi Objet260, Objet350 e Objet500) saranno presto supportati e ora è possibile partecipare al nostro beta test pubblico! Inoltre, installare l'ultimo aggiornamento software integrato disponibile per il download ora. Non è necessario firmare un accordo beta ufficiale, basta andare qui per i link di download e le istruzioni complete.
  • Le stime per i vassoi Polyjet ora mostreranno una vera barra di progressione.
  • I profili di colore e di texture torneranno ai valori predefiniti quando si modificano i materiali del vassoio per le stampanti PolyJet, per impedire agli utenti di lasciare accidentalmente i profili su uno non consigliato.
Versione di GrabCAD Print 1.16, Marzo 2018
Numero di build 1.16.29.38429 rilasciata il 20 Marzo 2018
  • Per GrabCAD Print è disponibile un programma di installazione completamente nuovo per le installazioni per macchina. Ciò consentirà di installare facilmente GrabCAD Print sui computer da laboratorio, nonché agli amministratori di sistema di distribuirlo a livello aziendale. Leggi più notizie qui e invia un'email print@grabcad.com per richiedere l'accesso.
  • Ora sono supportate le ultime versioni dei pacchetti CAD. Inclusi SOLIDWORKS 2018, Creo 4.0, Inventor 2018 e molti altri. Controlla l'elenco completo qui.
  • Nell'ultimo aggiornamento abbiamo inserito una nuova funzione, che consente di sincronizzare le impostazioni della stampante con la configurazione corrente della stampante selezionata. In questo aggiornamento abbiamo reso automatico questo comportamento, proprio al lancio della app.
  • Il materiale utilizzato nella griglia di supporto per le stampe delle stampanti PolyJet (di solito VeroPureWht) ora è specificato nella finestra dei risultati delle stime invece che dire "Altri".
Versione di GrabCAD Print 1.15, Febbraio 2018
Numero di costruzione 1.15.13.37334 Pubblicato il 19 Febbraio 2018.
  • Il pannello Impostazioni di stampa per le stampanti FDM ha un nuovo aspetto. Vedrai un'indicazione se le tue impostazioni sono diverse dalla configurazione attuale della stampante e con un solo clic potrai aggiornarle tutte perché corrispondano. Inoltre le impostazioni dei vassoi di nuova creazione corrisponderanno sempre a quelle che starai visualizzando al momento, per velocizzare la preparazione della stampa per i progetti con più vassoi.
  • È disponibile un nuovo cursore nello strumento Prepara, che controlla la casella di controllo "Ottimizza" per gli utenti PolyJet. Puoi controllare se la preparazione è ottimizzata per tempi di stampa ridotti o per l'uso minimo di materiali di supporto.
  • CORRETTO: se la vista Programma resterà a schermo per un po', la linea "Ora" rimarrà al suo posto, invece che spostarsi lentamente fuori dalla vista.
Versione di GrabCAD Print 1.14, Gennaio 2018
Numero di build 1.14.20.36110 rilasciata 17 Gennaio 2018
  • La schermata dei dettagli nel pannello della stampante ora mostra il modello e gli odometri delle puntine per supporti, nonché il volume e le temperature della testina dei sistemi FDM.
  • Se il tuo sistema FDM ha più alloggiamenti per i materiali, le nuove icone sul pannello della stampante indicano quali alloggiamenti sono caricati al momento nelle testine di stampa.
  • Ora apparirà un avviso quando si farà clic sul pulsante Stampa, se nel lavoro sono selezionati materiali o puntine non corrispondenti alla configurazione attuale della stampante.
  • Ora è possibile scaricare singoli registri dettagliati dei lavori di stampa in formato XML per le stampanti Fortus 900mc. Vai alla Visualizzazione dei rapporti e utilizza il tasto di download nella colonna "Opzioni".
  • GrabCAD Print now supports the Stratasys J700 Dental printer.
  • CORRETTO: i rapporti etichettavano le unità dei materiali in cm³ a prescindere dalle preferenze per le stesse. Questo problema è stato risolto.
Versione di GrabCAD Print 1.13, Dicembre 2017
Numero di build 1.13.21.34870 rilasciata 12 Dicembre 2017
Numero di build 1.13.23.35192 rilasciata 19 Dicembre 2017
  • Se hai configurato GrabCAD Print Server, in precedenza hai sfruttato solo alcune delle funzioni di accesso remoto per i sistemi PolyJet, come la connessione con app mobile e i rapporti online. Ora abbiamo reso disponibile anche il resto: l'invio di lavori da GrabCAD su un computer remoto.
  • Vari miglioramenti
    • La visualizzazione dei rapporti in GrabCAD Print ora include un tasto di esportazione e funziona sia per i sistemi FDM, sia per quelli PolyJet.
    • È stato corretto un bug della vista Rapporti per cui alcuni utenti non riuscivano a selezionare una stampante.
    • È stato risolto un problema con i rapporti online su Internet Explorer.
  • Non devi più fare clic su "Visualizza stime" quando i risultati delle stime sono pronti, essi appariranno automaticamente.
  • I dettagli del lavoro nella app GrabCAD Print per iOS ora includeranno l'ora di fine prevista.
Versione di GrabCAD Print 1.12, Novembre 2017
Numero di build 1.12.26.33454 rilasciata 13 Novembre 2017
  • Ora puoi accedere alla cronologia lavori per le tue stampanti locali dalla vista Rapporti nell'applicazione desktop GrabCAD Print. Ciò sarà di enorme aiuto per gli utenti in modalità Offline, dato che questo rapporto in precedenza era disponibile solo sulla pagina Rapporti online dopo la configurazione di GrabCAD Print Server. (Cronologia per sistemi PolyJet, stampanti remote ed esportazione CSV export non ancora disponibili.)
  • Stratasys ha appena lanciato nuovi materiali PolyJet avanzati, ora supportati da GrabCAD Print. Scopri di più su Agilus, VeroFlex e DABS2 Plus.
  • La app Android a volte riferiva un errore nel trovare le stampanti, se l'account aveva molte stampanti collegate. Abbiamo aumentato il timeout, quindi questo non dovrebbe più verificarsi.
  • Piccoli miglioramenti alla fruibilità
    • Il limite di 2 GB delle dimensioni dei singoli file e delle dimensioni del vassoio è stato eliminato.
    • Il passaggio alla vista Programma mentre è in corso un'altra operazione non è più bloccato.
Versione di GrabCAD Print 1.11, Ottobre 2017
Numero di build 1.11.17.31736 rilasciata 11 Ottobre 2017
  • Visualizzazione del nuovo vassoio, dotato di...
    • Forma realistica del vassoio e linee di griglia per la stampante uPrint, Dimension, Serie F123 e sistemi Fortus più piccoli.
    • Linee di griglia in centimetri o pollici (a seconda dell'unità di visualizzazione da te preferita) per i sistemi Fortus più grandi.
    • Touchpoint di calibrazione per le stampanti applicabili.
    • Fortus 900mc mostrerà il profilo delle dimensioni del vassoio più piccolo.
  • Ora puoi utilizzare GrabCAD Print per aggiungere una pausa al tuo lavoro di stampa FDM da Anteprima dello slicing. In precedenza questa funzionalità era disponibile solo in Catalyst e Insight.
  • Ora è possibile preparare i lavori per ULTEM™ 9085 CG utilizzando GrabCAD Print. In precedenza questo materiale era disponibile solo tramite Insight e Control Center. Gli utenti hanno anche la possibilità di utilizzare la puntina T16A con il Fortus 900mc.
  • È stato risolto un problema che impediva ad alcuni utenti di lanciare il componente aggiuntivo di GrabCAD Print in SOLIDWORKS.
Versione di GrabCAD Print 1.10, Settembre 2017
Numero di build 1.10.19.30507 rilasciata 13 Settembre 2017
  • Ora puoi aggiungere modelli a GrabCAD Print direttamente dai tuoi progetti Workbench. Fai clic qui per ulteriori informazioni sull'utilizzo di Workbench insieme a Print.
  • Se utilizzi GrabCAD Print Server, tu e il tuo team potrete ricevere una notifica e-mail quando il lavoro di stampa è terminato o richiede attenzione. Modifica le impostazioni dal tuo profilo GrabCAD.
  • Ora puoi aprire un file .PRINT facendo doppio clic su di esso o trascinandolo e rilasciandolo.
  • GrabCAD Print ora supporta la stampante Objet1000 Plus. Leggi la guida alla configurazione.
  • Si verificava un problema per cui i file CAD contenenti caratteri non ASCII nel nome file o nel percorso non potevano essere caricati in GrabCAD Print. Questo problema è stato risolto.
  • L'importazione di file CAD è stata migliorata. In precedenza alcune parti potevano mostrare rugosità sulle superficie curve, ma le migliorie forniranno superfici molto più lisce.
  • Ora è disponibile un collegamento a "Insight per GrabCAD Print" nel menu Start. Il collegamento conduce alla versione complementare di Insight che in passato era disponibile solo dal menu App di GrabCAD Print.
Versione di GrabCAD Print 1.9, Agosto 2017
Numero di build 1.9.27.701 rilasciata 9 Agosto 2017
  • Ora puoi aggiungere una torre sacrificabile ai lavori di stampa Fortus. Ciò contribuisce a migliorare la qualità delle giunture ed è necessario per la stampa con nylon 12 CF.
  • I materiali in nylon sono ora disponibili per le stampanti Fortus in GrabCAD Print.
  • I lavori che richiedono attenzione (ad esempio, se il materiale si esaurisce durante o prima del lavoro) mostreranno un'icona nella vista Programma. Il numero totale di stampanti con avvertenze verrà mostrato come conteggio sull'icona della vista Programma, a sinistra nell'applicazione.
  • Gli utenti possono esportare un file CSV contenente la cronologia lavori delle loro stampanti dal pannello della stampante (solo per le stampanti FDM). In questo modo, i clienti offline possono esportare i dati della loro cronologia lavori senza attivare la creazione di rapporti.
  • Le versioni precedenti di GrabCAD Print richiedevano privilegi di amministratore del sistema alla prima installazione. Con la versione 1.9, qualsiasi utente può eseguire l'installazione senza bisogno delle credenziali di amministratore del sistema (salvo il caso in cui il componente aggiuntivo SW opzionale sia incluso).
Versione di GrabCAD Print 1.8, Luglio 2017
Numero di build 1.8.16.652 rilasciata 12 Luglio 2017
NUOVE FUNZIONI:
  • GrabCAD Print ora supporta la stampa con ULTEM™ 9085 e ULTEM™ 1010. Ciò significa anche che i file CMB preparati in Insight con questi materiali possono ora essere stampati con GrabCAD Print. Per modificare i parametri o utilizzare funzionalità come perni di ancoraggio o stabilizzatori a parete, è possibile utilizzare Insight dal menu App. Sarà comunque necessario usare Control Center per aggiungere torrette sacrificabili. (ULTEM™ 9085 CG non è ancora supportato in GrabCAD Print.)
  • Gli utenti ora possono ottimizzare la preparazione dell'intero progetto (tutti i vassoi contemporaneamente) sulle loro stampanti FDM. Ciò consente di includere più di un vassoio con quante più parti è possibile.
  • Quando si inseriscono i pezzi per le stampanti FDM, questi vengono disposti dal centro del vassoio per una migliore qualità di stampa.
  • Per le stampanti serie F123, migliore levigatezza della base con funzionalità supportate e non supportate.
BUG CORRETTI:
  • I caratteri speciali nel nome utente Windows non causano più problemi quando si stabilisce una connessione con una stampante J750.
  • Quando si visualizza un lavoro PolyJet nel programma, “Modalità di stampa” e “Slice stampata” sono di nuovo disponibili.
  • È stato corretto un bug per cui le trasformazioni su un pezzo davano come risultato strati superiori parziali.
  • È stato corretto un bug per cui l'alternanza tra determinate stampanti FDM causava la scomparsa di un CMB importato.
Versione di GrabCAD Print 1.7, Giugno 2017
Numero di build 1.7.28.633 rilasciata 14 Giugno 2017
  • Ora puoi disporre sul vassoio più file CMB importati. In passato, gli utenti che lavoravano con più file CMB dovevano utilizzare il Control Center per il flusso di lavoro. Per le prestazioni, i file CMB sono semplificati nella vista Modello, ma puoi visualizzare la forma effettiva nell'Anteprima dello slicing. Inizia con un progetto vuoto, quindi vai a File > Importa CMB...
  • Abbiamo aggiunto "File recenti" al menu File. Puoi accedere ai tuoi 5 file aggiunti di recente (in qualsiasi formato CAD, CMB o OBJZF) e ai tuoi ultimi 5 progetti di stampa.
  • Ora puoi modificare la disposizione dei lavori nella vista Programma trascinandoli e rilasciandoli.
  • Il componente aggiuntivo SOLIDWORKS per GrabCAD Print è ora incluso nel programma di installazione di GrabCAD Print. Il componente aggiuntivo SolidWorks ti consente di preparare i tuoi file CAD per la stampa direttamente da SOLIDWORKS. Per le istruzioni di installazione, vai al menu App in GrabCAD Print.
  • I tuoi lavori di stampa ora appaiono con il tuo nome reale anziché con il nome del profilo del tuo computer per i lavori locali.
  • GrabCAD Print ora supporta il tipo di file .JT
  • CORRETTO: le parti contenenti caratteri non ascii (ad esempio, é oppure à) possono ora essere stampate sulla stampante J750.
  • CORRETTO: si verificava un problema di ridimensionamento per le parti di J750 quando Tango+ veniva caricato sul vassoio ma non utilizzato e questo problema è stato risolto.
Versione di GrabCAD Print 1.6, Maggio 2017
Numero di build 1.6.19.601 rilasciata 9 Maggio 2017
  • Aggiunta delle ore di funzionamento! Una volta abilitate dall'amministratore della società, la coda di stampa visualizzata nella vista Programma viene modificata automaticamente in modo da indicare che i lavori di stampa vengono avviati solo durante le ore di lavoro, consentendo una più precisa previsione del programma.
  • Per selezionare più modelli nel pannello dei progetti, tieni premuto il tasto Maiusc. Questa procedura, insieme al riquadro di selezione (funzione aggiunta in 1.5), rende molto più veloce modificare contemporaneamente le impostazioni di più modelli.
  • Puoi riordinare facilmente i lavori trascinandoli nella coda del pannello della stampante.
  • Per velocizzare le prestazioni del visualizzatore, in Visualizzazione modello viene visualizzata una versione "semplificata" dei modelli. Potresti osservare la presenza di più triangoli sulle superfici curve. Ciò non influisce sulla qualità di stampa. Per vedere esattamente cosa verrà inviato alla stampante, vai in Anteprima dello slicing o imposta Qualità della grafica su "Alta" in Preferenze di sistema > Impostazioni di visualizzazione.
  • Per le stampanti serie F123, è ora disponibile lo stile di costruzione Brick Mode. È utile quando vengono stampate parti di grandi dimensioni, dense e con riempimento uniforme per evitare che la parte si arricci. Solo se utilizzi un'altezza delle sezioni di 0.005” con ABS, ASA o PC-ABS.
  • CORRETTO: per le stampanti J750, abbiamo risolto diversi problemi che potevano causare errori durante la stampa. Per usufruire di queste correzioni, aggiorna GrabCAD Print e Job Manager.
  • CORRETTO: gli utenti che utilizzano le unità del sistema metrico possono ora visualizzare l'altezza delle sezioni nelle unità selezionate.
Versione di GrabCAD Print 1.5, Aprile 2017
Numero di build 1.5.15.549 rilasciata 18 Aprile 2017
  • La nuova modalità Offline 2 è arrivata! Ora, alla prima installazione, puoi evitare di effettuare l'accesso se non sei connesso a Internet. Si tratta di un'aggiunta alle funzionalità della modalità Offline introdotte in GrabCAD Print 1.3 (per informazioni, leggi qui).
  • GrabCAD Print ora supporta le versioni più recenti dei pacchetti CAD, inclusi SOLIDWORKS 2017, Inventor 2017, NX 11.0 e Solid Edge ST9. Controlla l'elenco completo qui.
  • Puoi assegnare nomi personalizzati ai vassoi nell'anteprima del vassoio del pannello dei progetti. I lavori ereditano il nome quando fai clic su Stampa.
  • Tutti i lavori inviati con la versione 1.5 includono un'anteprima del vassoio nei dettagli del lavoro della vista Programma sia online che nell'applicazione desktop. Puoi disabilitare l'anteprima in Preferenze di sistema > Privacy.
  • Il riquadro di selezione in Visualizzazione modello consente di modificare contemporaneamente le impostazioni di stampa di più modelli. Fai clic col pulsante sinistro del mouse e trascina. Quando trascini verso destra, vengono selezionati solo i modelli completamente all'interno del riquadro. Quando trascini verso sinistra, vengono selezionati anche i modelli parzialmente all'interno del riquadro.
  • Puoi modificare le impostazioni dei tasti di scelta rapida di visualizzazione e della prospettiva utilizzando comodi pulsanti nella parte superiore del visualizzatore.
  • Puoi scegliere le unità dei materiali visualizzate nelle applicazioni per dispositivi mobili e nelle viste online Rapporti e Programma. Modifica le impostazioni qui (l'applicazione per dispositivi mobili si aggiorna dopo l'accesso).
  • Abbiamo migliorato la modalità con cui ti viene notificato che è necessario aggiornare Job Manager per la stampante J750.
  • Per migliorare l'aderenza del vassoio, per le stampanti serie F123, lo strato della base sarà costituito del materiale per modelli per le stampe che utilizzano ABS o ASA e un'altezza delle sezioni di 0.005".
  • Sono state apportate alcune modifiche ai processi core e alle funzioni di stampa per migliorare la qualità di stampa delle stampanti Stratasys serie 123.
Versione di GrabCAD Print 1.4, Marzo 2017
Numero di build 1.4.20.531 rilasciata 14 Marzo 2017
NUOVE FUNZIONI:
  • GrabCAD Print supporta ora tutte le stampanti uPrint, Fortus e Dimension. Controlla l'elenco completo qui.
  • Nella versione 1.3 abbiamo notevolmente migliorato il popolamento per le stampanti FDM se premi "Prepara vassoio" dopo aver eseguito la stima del vassoio. Ora è ancora più facile grazie alla casella di controllo "Ottimizza" dello strumento Prepara. In alcuni casi, ciò ti consente di posizionare fino al doppio delle parti per ciascun vassoio!
  • Presentazione dei nomi personalizzati delle stampanti. Rinomina una stampante nel pannello Impostazioni stampante e il nome personalizzato verrà visualizzato da tutti i membri del tuo account societario nelle applicazioni desktop, per dispositivi mobili e online. Trovi ulteriori informazioni qui.
  • Con l'aggiornamento più recente di GrabCAD Print Server (versione 0.144.0318), la stampante Stratasys J750 è ora supportata nell'applicazione per dispositivi mobili GrabCAD Print e nei rapporti e programmi online. Presto sarà disponibile l'accesso remoto.
  • Inoltre, ora puoi connettere per la prima volta la stampante J750 utilizzando l'opzione "Aggiungi una stampante di rete" se stai già eseguendo GrabCAD PolyJet Job Manager.
  • Abbiamo migliorato il modo in cui le stampanti vengono elencate in "Le mie stampanti" del pannello della stampante:
    • Se la connessione a una stampante viene interrotta, la stampante non viene eliminata dall'elenco ma lo stato diventa "Disconnessa".
    • Le "stampanti offline" vengono ora chiamate "Modelli della stampante" e vengono visualizzate in una sezione separata sotto le stampanti di rete.
  • Piccoli aggiornamenti alle impostazioni di stampa per le stampanti F370:
    • La stampa PLA viene ora chiamata Modalità bozza.
    • Lo stile delle parti per gli scarti utilizza per impostazione predefinita l'altezza totale.
BUG CORRETTI:
  • Alcuni utenti delle stampanti J750 hanno segnalato problemi di stime errate o errori di stampa quando il materiale Tango+ è stato caricato sul vassoio ma non utilizzato e questi problemi sono stati risolti.
  • La vista Programma mostra ora le stime del tempo e dei materiali per i lavori successivi con la stampante J750.
  • Alcuni utenti della stampante J750 hanno segnalato un errore di stampa accompagnato dal messaggio poco chiaro "error.0". Il problema che causa l'errore di stampa è stato risolto e se il problema si verifica di nuovo il testo del messaggio di errore è ora comprensibile.
  • Due piccoli bug del pannello Allinea corretti: uno relativo a valori decimali negativi e l'altro relativo ai pulsanti + e -.
  • Alcuni utenti della stampante F370 potrebbero aver notato strati errati nella parte per gli scarti e il problema è stato risolto.
Versione di GrabCAD Print 1.3, Febbraio 2017
Numero di build 1.3.25.508 rilasciata 21 Febbraio 2017
Numero di build 1.3.23.503 rilasciata 7 Febbraio 2017
  • Presentazione della stampante Stratasys serie F123! L'ultimo modello di stampante funziona solo con GrabCAD Print. Trovi ulteriori informazioni qui.
  • Il supporto della stampante J750 in GrabCAD Print è uscito dalla fase beta! Grazie a tutti gli utenti che hanno partecipato al programma beta. Se utilizzi una stampante J750, consulta questo manuale per iniziare a stampare con GrabCAD Print.
  • Disponiamo ora di un componente aggiuntivo per SOLIDWORKS che consente di stampare i file .SLDPRT direttamente dall'ambiente CAD. Leggi altre informazioni o scaricale qui.
  • Poiché molti utenti avevano richiesto la possibilità di procedere con l'installazione e iniziare a stampare senza effettuare l'accesso a GrabCAD,
    • Nel caso di un'interruzione della connessione a Internet, GrabCAD Print ti consente di continuare a lavorare con le stampanti locali.
    • Se questa situazione si presenta di frequente, puoi disabilitare gli avvisi passando in modalità offline in Preferenze di sistema > Privacy.
    • Quando avvii l'applicazione per la prima volta, devi effettuare almeno un accesso. Se la connessione a Internet è disponibile ma riscontri problemi di accesso, consulta la guida Risoluzione dei problemi.
    • Sarà possibile anche lavorare "completamente offline", una soluzione che consente di non effettuare l'accesso iniziale. Questa opzione sarà disponibile entro la fine dell'anno.
  • Se pensavi che le funzionalità dello strumento Prepara non fossero all'altezza di quelle di Insight o Catalyst, dai un'occhiata ai notevoli miglioramenti di questo aggiornamento! Prova a premere "Stima" per eseguire lo slicing del vassoio, quindi premi "Prepara vassoio" e noterai che il vassoio viene popolato molto più densamente.
  • Gli utenti che hanno partecipato al programma beta per la stampante J750 noteranno alcuni miglioramenti in questo aggiornamento:
    • È possibile aggiornare Job Manager dal pannello della stampante in GrabCAD Print, allo stesso modo di un aggiornamento del firmware.
    • Sono stati risolti i problemi con il cursore per l'opacità in Impostazioni di stampa.
  • Insight fa ora parte del pacchetto di GrabCAD Print e ciò consente di utilizzare più funzioni avanzate, ad esempio la modifica di gruppi o percorsi utensile per i sistemi F370 o Fortus. Trovi ulteriori informazioni qui.
Versione di GrabCAD Print 1.2, Gennaio 2017
Numero di build 1.2.11.469 rilasciata 24 Gennaio 2017
Numero di build 1.2.9.464 rilasciata 16 Gennaio 2017
  • Nel caso non li abbia visti, i rapporti sono qui! Guarda la cronologia dei lavori e l'utilizzo dei materiali a destra del browser Internet.
  • È disponibile una nuova preferenza di sistema che consente di scegliere se creare automaticamente nuovi vassoi quando vengono aggiunte troppe parti a un vassoio.
  • Le icone degli strumenti sono più grandi e più spesse. Diamo un'occhiata: Strumenti.
  • Nello strumento Ruota, puoi personalizzare i gradi di rotazione con un click rendendo più facile ottenere l'orientamento ottimale.
  • I file VRML vengono ora inclusi in modalità Analisi sebbene per riparare i modelli senza interrompere la mappatura della texture devi utilizzare un altro software.
  • Abbiamo risolto alcuni problemi con il lettore di file CAD, in particolare per i modelli a forma di anello.
Versione di GrabCAD Print 1.1, Dicembre 2016
Numero di build 1.1.28.454 rilasciata 16 Dicembre 2016
  • Miglioramenti ai colori e alle icone nella navigazione principale e nel pannello dei progetti.
  • È stato corretto un bug per cui le preferenze dell'unità non venivano visualizzate nella vista Programma.
  • Altri piccoli miglioramenti e correzioni.
Versione di GrabCAD Print 1.0, Novembre 2016
Numero di build 1.0.32.424 rilasciata 15 Novembre 2016
  • Più stampanti! Ora puoi utilizzare GrabCAD Print con le stampanti Fortus 380/450 e Fortus 900 (supporto limitato*) mentre le stampanti Fortus 360/400 e J750 sono attualmente in fase beta. Invia una e-mail print@grabcad.com per richiedere l'accesso.
  • Possibilità di visualizzare i volumi di materiale in centimetri cubi. Vai in File > Preferenze di sistema > Controlli unità > Unità di visualizzazione e modifica le unità metriche.
  • Possibilità di importare file .CMB.GZ.
  • Per impostazione predefinita, il programma di installazione utilizza la stessa lingua del sistema operativo. Puoi cambiare la lingua selezionando il pulsante Indietro nella prima schermata del programma di installazione o in Preferenze di sistema.
  • Più comandi con il mouse predefiniti intuitivi per i nuovi utenti. Controlla la configurazione aggiornata qui. Non riguarda gli utenti esistenti.
  • Lo stile del riempimento e del supporto e l'altezza delle sezioni vengono aggiornati automaticamente alle impostazioni consigliate per il materiale per modelli e di supporto selezionati.
  • Piccoli miglioramenti e correzioni di bug all'interfaccia utente.
*Supporto limitato significa che è supportata la preparazione di stampa di base (simile alla "bandiera verde" in Insight), tuttavia alcune funzionalità avanzate, come l'utilizzo di una torre sacrificale durante la stampa di ULTEM™ o Nylon 12, non sono ancora disponibili.
Continua a leggere le note sulla versione delle versioni precedenti qui.
Non trovi quello che ti serve? Send us a message Send us a message
