GrabCAD プリント リリース ノート
GrabCAD Print バージョン 1.98、1月 2025
ビルド番号 1.98.6.50666 リリース日 21 1月 2025
- Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
- Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
- Print Pro: The Assembly created while using the Split tool is now optional.
- An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
- For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
- The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
- When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
- Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
- The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
- If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
GrabCAD Print バージョン 1.97、12月 2024
ビルド番号 1.97.10.49657 リリース日 17 12月 2024
- Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
- Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
- Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
- Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
- Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
- F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
- For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
- The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
- ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
- Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
- RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
A new material profile has been added to the Validated O2 collections.
30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
- Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
- N3D-FR512 for FR-rating with higher elongation at break
- FL300 from Forward AM for low Shore hardness elastomers in a clear color
- MED414 for elastomeric applications requiring biocompatible capability such as ear bud
GrabCAD Print バージョン 1.96、11月 2024
ビルド番号 1.96.8.49045 リリース日 20 11月 2024
- Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
- Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
- Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
- Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
- GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
- The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
- Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
- PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
- ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
- For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
- Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
- A new material profile has been added to both the Validated O2 and Open AM collections for P3.
- New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
- The History report in GrabCAD Print now includes material consumption per-job for P3.
GrabCAD Print バージョン 1.95、10月 2024
- Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
- A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
- A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
- A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
- Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
- The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
GrabCAD Print バージョン 1.94、9月 2024
- New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
- The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
- When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
- If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
- A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
- The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
- The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
- Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
- Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
- We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
- Advanced Color Assignment: designed to produce more accurate and consistent shades
- 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
- 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
- New TrueDent Clear Appliances: for fully translucent models and try-ins
- Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
- VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
- When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
GrabCAD Print バージョン 1.93、8月 2024
- Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
- Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
- The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
- Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
- VeroContactClear is now treated as a transparent material for all transparency-related features.
- Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
- When WSS is the selected support material, "No Grid" becomes the only available support grid type.
- The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
- A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
- Additional dental applications for Origin printers are now supported.
GrabCAD Print バージョン 1.92、7月 2024
- Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
- Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
- Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
- Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
- Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
- Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
- A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
- Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
- The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
- For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
GrabCAD Print バージョン 1.91、6月 2024
- Print Pro: 新しいアクション、モデルを STL としてエクスポート。単一のアセンブリ、パーツ、またはボディを選択し、右クリック メニューから STL ファイルとしてエクスポートします。エクスポートされたモデルには、分析モードで行われた修正と、適用されたラベルが含まれます。
- Print Pro: これまで J7/J8 シリーズ プリンターでのみ利用可能だった Print Pro の Print-on-Tray、Print-on-Object、および Smart Insert 機能が、J3/J5 シリーズ プリンターでも利用できるようになりました。
- GrabCAD Print は、FBX(.fbx)および GLTF(.gltf、.glb)ファイル形式のインポートをサポートするようになりました。
- Carbon Fiber Visual Print オプションは、ABS-CF10 の新しいスライス高さで、より滑らかな表面仕上げを実現し、部品の外観が重要である場合に最適です。スライス高さ(0.0050 インチ、0.1270 mm)は、T14H ヘッド付きの F123 および F123CR シリーズ プリンターで使用できます(ファームウェア バージョン 2.7 が必要です)。
- OpenAM は、Stratasys F900 プリンターでサポートされるようになりました。材料パッケージは、材料が OpenAM™ で調整され、コンパイルされて、GrabCAD Print と F900 プリンターに配布されると作成されます。Stratasys の推奨材料および検証済み材料は、サードパーティのオープン材料と同様に調整され、パッケージに含まれる場合があります(プリンター ファームウェア バージョン 4.23 が必要です)。
- VICTREX AM™ 200 が、Fortus 450mc および Stratasys F900 プリンターの検証済み材料ポートフォリオに追加されました。VICTREX AM™ 200 は、温度、腐食、化学薬品への耐性のある、高強度、高機械的特性の PEEK ベースのポリマーです。VICTREX AM™ 200 は、T14F チップを使用した 0.0100 インチ(0.2540 mm)のスライス高さに対応しており、ブレークアウェイ(SUP4000B)と可溶性(SR-100 支持)の両方をサポートしています(ファームウェア バージョン 6.9 が必要です)。
- ナイロン 12CF の収縮挙動が更新されました。トレイの材料がナイロン 12CF で、トレイにスパース充填モデルとソリッド充填モデルの両方が含まれている場合、ソリッド充填の Z 方向の収縮率が使用されます。変更があったことをユーザーに通知するメッセージが表示されます。トレイ上のすべてのモデルが、ソリッド充填またはスパース充填に切り替わると、選択した充填スタイルの Z 方向の収縮率が使用されます。
- GrabCAD Print は、Stratasys F770 を除く、Stratasys F123 シリーズ プリンターと通信するときに、IPv6 アドレスをサポートします(ファームウェア バージョン 2.7 が必要です)。
- J5 DentaJet™ XL は、4 kg カートリッジを備え、DentaJet シリーズ製品ラインの最新のイノベーションです。量産用に設計されたこのプリンターは、アライナー メーカー、C&B モデル、インプラントの要求に応え、比類のない精度を提供します。理想的な製品を大規模に作成する究極のソリューションであると同時に、ワークフローに革命をもたらすコスト効率の高いソリューションでもあります。
- J5 Digital Anatomy プリンターは、TissueMatrix、BoneMatrix、GelMatrix、RadioMatrix などの J5 プラットフォーム上で独自のデジタル解剖学材料を印刷できます。人間の組織に似た生体力学的挙動のある解剖モデルを印刷できるよう、さまざまな解剖学的プリセットが用意されています。詳細は、こちらをクリックしてください。
- PolyJet でカラー モデルを印刷する際に、入力カラー プロファイルを選択できるようになりました。[トレイ設定] > [詳細] で、sRGB(デフォルト)と新しい Adobe RGB 1998 プロファイルのいずれかを選択します。Adobe プロファイルは、より彩度の高い色(緑 / 黄 / 赤)を提供するため、印刷結果がどうなるかを正確に把握するために、彩度の高いモニターを使用することをお勧めします。
- これまで J3/5 シリーズ プリンターでロックされていた支持体グリッド スタイルを、変更できるようになりました。注: プリンターに TrueDent 材料がロードされている場合は、ロックされたままになります。
- 該当する PolyJet プリンターでは、UV LED レシピ パネルで次の操作が利用できるようになりました。
- プライベートレシピの変更を保存する
- レシピ(SSYSまたはプライベート)を新しいプライベートレシピとして保存する
- プライベートレシピの名前を変更する
- プライベートレシピを削除する
- SAF の 3D ネスト設定 UI で、ポリプロピレン(PP)がサポートされるようになりました。
- 検証により、弱い衝突に関係するオブジェクト間の距離が報告されるようになり、印刷を続行してもよいかを判断できるようになりました。
- P3 印刷では、新しいプロジェクトを開始する際、自動的に選択されるデフォルトの材料と支持体プロファイルを定義できるようになりました。
- P3 印刷の場合、特定のモデルの支持体を変更すると、プロジェクト パネルのモデルの横に警告アイコンが表示され、ツールヒントに「モデルの支持体パラメータがトレイのデフォルトと異なります」と表示されます。
- P3 印刷の場合、選択したモデルすべての支持体プロファイルが同じであれば、ボタンを 1 つ押すだけでアンカー点や支持構造を自動的に生成できます。
GrabCAD Print バージョン 1.90、5月 2024
- Print Pro: トレイ上の STL ファイルを選択すると、右クリック メニューで新しいアクション「分離」が使用できるようになります。「分離」は、複数のシェルのある STL ファイルを複数の体のあるアセンブリに変換します。その後、各体にモデル設定を適用できます。1 つのシェルのみが識別された場合、モデルは変更されません。
- Print Pro: Allerta Stencil フォントは、ラベルで使用するために選択できます。このフォントを選択するには、[ラベル] ドロップダウン メニューを展開し、[Allerta Stencil] を選択します。Atkinson Hyperlegible フォントは、引き続きデフォルトのフォントです。
- Print Pro: 「アセンブリ名」モデル属性を、ラベル テンプレートに含めることができるようになりました。アセンブリ名には、部品名と同じ修飾子(開始/終了、スキップ、長さ)があります。アセンブリ構造がない場合、アセンブリ名と部品名の動作は同じです。
- Print Pro: 光沢のある表面とマットな表面の両方を印刷することでデザインにテクスチャ仕上げを施すことができる、 PolyJet 設定の「材料としての支持体」が、すべての J シリーズ プリンターで利用できるようになりました。
- ビュー ツールバーに、新しいビューが追加されました。モデルに濃淡をつけて表示する標準モードに加えて、新しいオプションがあります。モデルをそれぞれ透明または濃淡ありのワイヤフレーム メッシュとして表示する、ワイヤフレーム モードとワイヤフレーム濃淡モードです。新しいビューには、「サポートされている表面をプレビュー」との互換性がありません。
- GrabCAD Labs に、支持構造なしで FDM で印刷するオプションが追加されました。この機能をオンにすると([ファイル] > [環境設定] > [GrabCAD Labs])、支持設定パネルの支持スタイル オプションとして「支持体なし」が表示されます。モデルはベース付きで印刷されますが、その他の支持構造は印刷されません。
- 完全な高さの犠牲タワーが存在する場合に、モデルの方向を変更できない問題が、解決されました。
- SAF 印刷では、サブネストを選択して、パックの定義された領域にネストを作成できるようになりました。この領域の X、Y、Z 寸法を制御し、パックの任意のコーナーからその原点の X、Y、Z 位置を設定できます。
- SAF ラベルの最小テキスト サイズが、10 pt まで小さくなりました。
- P3 印刷の場合、手動で追加または移動したアンカー点は、自動的に生成されたアンカー点とは異なる色で表示されます。
GrabCAD Print バージョン 1.89、4月 2024
新しい Parts on Demand モードで、GrabCAD Print 内で Stratasys Direct から見積もりを取得し、部品を注文できます。さまざまな FDM 材料が利用可能で、米国への発送も可能です。
FDM 印刷では、スタビライザー付きのモデルに対して生成された境界ボックスが必要以上に大きくなり、造形体積を侵害する問題が解決されました。
- プライベートレシピの変更を保存する
- プライベートレシピの名前を変更する
- プライベートレシピを削除する
- 新しいファッション機能: 衣服への印刷。簡素化されたインターフェイスには、革新的な新しい Direct to Garment Trays キットとの互換性が含まれているため、デザイナーは複雑な 3D 要素を、完成品の衣服に直接採用することができます。
- H350 ネスト パネルの「選択項目を埋める」という新しいボタンを使用すると、パック内に収まる限り、単一の部品の複製をいくつでも収めることができます。
- P3 印刷の場合、すべてのモデルが同じ支持体プロファイルを共有すると、1 回の操作で複数のモデルのアンカー点や支持体を生成できるようになりました。
- P3 印刷の場合、高い台座を生成するときに、特定の材料(主にエラストマー)には追加の支持強化が必要です。支持体プロファイルごと、トレイごと、または特定のモデルごとに、強化タイプを制御できます。SSYS エラストマー プロファイルは、このオプションを設定するようにすでに変更されています。
- P3 印刷の場合、材料定義は、材料ごとにデフォルトの配置パラメータ(モデル間の隙間と印刷境界からの隙間)を提供します。OpenAM ユーザーは、プライベート材料に対してこの値を変更できます。どのユーザーも、トレイごとにこのパラメータを変更できます([配置] パネル経由)。
GrabCAD Print バージョン 1.88、3月 2024
- Print Pro: GrabCAD Print Pro に PolyJet の機能が追加されました!これは、以前は PolyJet Research パッケージでのみ利用可能だった機能、
- トレイに直接印刷(J7/8 シリーズのみ) — ガラスやカーボン ファイバーなどの材料に印刷できるため、部品の下側に理想的な表面仕上げが施され、下側の後処理が不要になります。
- 材料としての空気(J7/8 シリーズのみ) — 樹脂の代わりに空気を使用することで、部品の重量を大幅に削減し、最大 30% の材料を節約できます。
- Smart Insert™(J7/8 シリーズのみ) — さまざまな機能的/装飾的要素を印刷物に直接埋め込むことができます。
- オブジェクト上に印刷(J7/8 シリーズのみ) — さまざまな基材へのオブジェクトの直接印刷により、モデルのカスタマイズとパーソナライズが可能です。
- ボクセルプリント アプリ(J7/8 シリーズのみ) — 他のソフトウェアで定義されたスライス データを印刷するツール。ボクセル レベルでの色、透明度、ショア硬度など、モデルの詳細を制御できます。
- その他の新機能、
- 材料としての支持体(J750 および J850 Prime のみ) — 光沢のある表面とマットな表面の両方を印刷することで、デザインにテクスチャ仕上げを施すことができます。
- 材料としての液体(J7/8 シリーズのみ) — マイクロ流体構造、中空チューブ、油圧部品などの中空空洞を作成できます。
- 高速モード(J55 のみ) — 2 材料を使用する場合、同じ層の厚さを維持しながら 2 倍の速度で動作します。
- および Print Pro で FDM および SAF 用にすでに利用可能な機能の一部で構成されています。
- ラベル
- 厚さ解析
- 組立/分解
- サードパーティのプラグイン
- Print Pro: エクスポートされた見積結果では、計算に簡単に組み込めるように、hh:mm の時間形式が使用されるようになりました。
- GrabCAD Print は現在、次の CAD バージョンをサポートしています。
- SOLIDWORKS 2024
- Inventor 2024
- NX 2306 シリーズ
- ソリッドエッジ 2024
- .X_T 36
- .JT 10.9
- Agilus CMY と VeroUltraWhite、VeroPureWhite、または VeroClear の混合であるデジタル材料(DM)が、すべての J7/8 シリーズ プリンター、またこの材料で許可されているすべての印刷モードで、使用できるようになりました。DM 名には、接頭辞 FLXAC が付きます。
GrabCAD Print バージョン 1.87、2月 2024
- Print Pro: Pro プロジェクトの見積結果には、トレイ/ネストの概要と造形レポート(部品ごと)の両方のタブにコスト見積が含まれるようになりました。コスト率は、見積結果ウィンドウの新しいタブまたはプリンター設定から設定できます。
- ビューア上部のコントロール ストリップに断面ビューが追加されました。これにより、隠れてしまうモデルの機能を確認できるようになり、測定ツールや Origin の支持体生成ツールと組み合わせて使用できます。断面ビューを有効にすると、以下のボタンを使用して断面と方向を選択したり、ドラッグ ハンドルを使用して他の角度で断面を作成したりできるようになります。
- 見積結果ウィンドウ内のテキストが選択可能になり、Ctrl + C でクリップボードにコピーできるようになりました。
- これまで PolyJet および Print Pro プロジェクトでのみ使用可能だった位置ツールが、Print Standard のすべてのテクノロジーで使用できるようになりました。
- F123 シリーズ プリンターの「薄壁を厚くする」のデフォルト設定が「オフ」に変更されました。
- 部品のシェル内の輪郭と、場合によっては隣接する充填が生成されない問題が修正されました。
- 新しい大型産業用FDMプリンターである Stratasys F3300 が、GrabCAD Printで選択できるようになりました。Stratasys F3300 の機能と性能は、こちらでご覧ください。またはプリンター テンプレートのリストから選択して、使用可能な材料と設定をご覧ください。
- ビューア上部にあるビュー コントロール ストリップで利用できる PolyJet 支持体視覚化では、支持領域が市松模様ではなく青色で表示されるようになり、視認性が向上しました。
- このオプションでは、印刷プロセスを最適化せずに、画面に表示されているように部品をトレイの実際の位置に配置します。絶対位置を使用すると、小さな部品の印刷品質が影響を受ける可能性があります。
- 1.83 アップデートで他のテクノロジー用に追加された測定ツールが、PolyJet 印刷準備でも使用できるようになりました。
- SAF プロジェクトでは、強力で動的なバージョンの造形レポートが利用できるようになりました。見積結果から造形レポートを選択し、右上のエクスポート ドロップダウンから [HTML] を選択します。結果のファイルは任意の Web ブラウザで開くことができ、ネストと部品ごとの見積もり、およびネストと各部品のインタラクティブな 3D プレビュー(ネスト内の位置を表示)が含まれます。また、特定の部品を名前で検索するのに役立つ検索ツールもあります。
- 焼結箱のラベルがプレビューされるようになり、ラベルが使用可能なスペースに収まるかどうかが明確になりました。
- P3 プロジェクトでは、Z 補正値が受け入れられないバグが修正されました。Z 補正を支持体部品貫通値以下にするというルールは、残っています。
- For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
- 島の支持半径: 追加のアンカー点を受け取る島の最初のエビデンス周囲の半径。
- 島の内部間隔: この追加のアンカー点間の間隔。
- Additional updates for P3 support parameters:
- 産業用モデルでは、足の最大直径が 10 mm から 30 mm に増加しました。
- 歯科モデルの場合、部品貫通は 0 にできます。
GrabCAD Print バージョン 1.86、1月 2024
- FDM ツールパスの計算によって大きな部品が造形体積に違反したり、小さな部品が互いに干渉したりする問題が修正されました。
- PolyJet 印刷準備用の 3D ビューアは、今後の新機能をサポートするために更新されました。現時点では、変更はされていません。古いビューアに戻す場合は、[ファイル] > [環境設定] > [PolyJet] で可能です。
- GrabCAD Voxel Print アプリで作成されたファイル (.gcvf ファイル)は、J シリーズ プリンターをお持ちの方ならどなたでもインポートできるようになりました。Voxel Print アプリを使用して .gcvf ファイルを作成するには、ライセンスが必要ですが、ファイルのインポートはどなたでもできるようになりました。
- High Mix 印刷モードで7モデル材料よりも少ない材料を使用して作業するオプション(他のチャネルに Cleanser を使用)が、高品質印刷モードを含むように拡張されました。
- J5 DentaJet ユーザー向けの 3 つのアップデート
- TrueDent 材料が選択された J5 DentaJet プリンターがある場合、TrueDent 材料の IFU(使用説明書)が表示されるようになりました。
- TrueDent 印刷のモデル設定パネルが改良され、使いやすさが向上しました。歯肉と歯の濃淡の両方について、お気に入りとデフォルトの材料を簡単に選択できます。
- J5 DentaJet ユーザーは、Exocad Model Creator を使用して、口腔内スキャンからフルカラー印刷モデルまでのエンドツーエンドのワークフローを利用できるようになりました。GrabCAD Print の新しいカラー プロファイルにより、Exocad とのカラー マッチングが可能になります。
- Origin 印刷の硬化プロセスにより、下向きの表面に余分な材料が蓄積されることがあります。これを過剰硬化と呼びます。Z 補正と呼ばれる新しいパラメータは、これらの表面を上向きにオフセットすることでこれを修正します。
- Origin Dental ユーザーの場合、「キャビティ内の支持体をフィルター」オプションを選択すると、必要な支持体が削除されている可能性があることを知らせる新しい警告メッセージが表示されます。
- 長さや高さの制限により P2P ストラットが使用できない場合、支持体の生成では自動的に P2P スキャフォールドが使用されます。
GrabCAD Print バージョン 1.85、12月 2023
- Print Pro: ラベルの 2 つのアップデート
- ラベル パネルのボタンを使用して、1 回の操作ですべてのラベルを削除できるようになりました。
- テンプレート ラベルを作成するときに、部品上のラベル テキストのプレビューが表示されるようになり、サイズ、位置、回転を調整する際の視覚的な補助が提供されるようになりました。
- J8 シリーズ プリンターでは、7材料印刷モードでモデル材料の代わりに洗浄液カートリッジを使用できるようになりました。この機能を使用すると、最大4個の印刷チャネルに洗浄液をロードして印刷を続けられるため、材料を交換しながら印刷できます。
- DM2 モードと呼ばれる、2材料がロードされた Connex3 プリンターに印刷ジョブを送信できるようになりました(注: [ファイル] > [環境設定] > [PolyJet] で、高度なスライサーを無効にする必要があります)。
- HQ モードで印刷するときに 1 つの UV ランプを使用するオプションが、J850 Prime、J850 Prime Fabrix、J850 Pro、J835、J750 のデフォルトになりました。
- 他のモデルまたは支持体材料との混合における解剖学的材料の比率は、制限されています。この制限の検証が、各ノイズ変調ステップに追加されました。SUP706 の制限は修正されました。BoneMatrix、任意の Agilus30 材料、または任意の Vero 材料と混合する場合、SUP706 は外層で 50% 未満である必要があります。
- ファッション オプションの改善
- レシピ パネルを開かなくても、UV LEDレシピを選択できるようになりました。
- レシピ パネルは、[レシピの管理] ボタンで開きます。
- 合計スライスには、接着層が定義されています。
- Origin プリンターのアンカー点と支持体生成プロセスの進行状況バーに [キャンセル] ボタンが追加されました。アンカー点または支持構造が生成されている場合、それらは削除されます。
- アンカー点パネルと支持体パネルでパラメータを変更すると、支持体プロファイル名の近くにアスタリスク(*)が表示され、変更が保存されていないことが示されるようになりました。変更したパラメータをリセットするには、[プロファイルにリセット] ボタンを使用します。
GrabCAD Print バージョン 1.84、11月 2023
- Print Pro:ギャップ分析をご紹介!厚さ分析ツールが強化され、ユーザーがギャップを検出できるようになりました。例えば、プリンタの解像度を下回っているモデル内のポケットです。[厚さ分析] パネルの新しい [ギャップ] タブで利用できます。
- Print Pro:アキュラシーセンター WAM 機能により、さらに精度が上がり、ユーザーは困難なプロジェクトでも品質を上げていけるようになりました。
- Fortus 450mc で導入された検証済み材料 1.75 F900がGrabCAD Printで利用できるようになりました。これらの材料は、プログラミングや印刷作業に利用される前に、基本的な信頼性テストによって検証されます。検証済み材料を使用するには、F900 にファームウェア・バージョン 4.22 がインストールされている必要があり、 0.0100インチ /0.2540 mm のスライス高でのみ使用できます。
- FDM HIPS (ハイーインパクト・ポリスチレン)
- KimyaPC-FR(難燃剤)
- ULTEM™9085樹脂の新色(レッド、エアクラフト��レー、ガンシップグレー、ドリームグレー、ホワイト7362、ジャナホワイト)。
- PC の新色 (レッド)
- PC-ABS の新色(レッド)
- (BETA) VICTREX AM™200PAEK (低融点)
- PolyJet では、ファッションプリンタ用の接着層が改善されました。以前は、接着層のあるマットなモデルを印刷する場合、接着層はモデルとその周囲の支持体の下に印刷されていました。支持体を取り除いた際に、モデルの周囲に接着層が残っている可能性がありました。最新のアップデート後は、接着層はモデルの下にのみ追加されるため、支持体を取り除いた時に接着層は残りません。
- GrabCAD Print 1.83 への更新後、印刷ジョブに失敗する問題が出ていた、PolyJet Objet30V3 および V5 プリンタの問題が解決されました。
- SAF の場合、3D ネスト パネルで X / Y の形式で追加の進行状況情報がレポートされるようになり、選択したモデル数と現在ネストに含まれているモデル数をユーザーが明確に確認できるようになりました。
- P3 では、パラメータの自動修正機能が導入されました。有効な範囲のあるパラメータにユーザーが無効な値を入力すると、その値は最も近い有効な値に自動的に修正され、自動修正された有効範囲についてツールチップが表示されるようになりました。
GrabCAD Print バージョン 1.83、10月 2023
- Print Pro:ビルドレポートでは、パージ部位または犠牲タワーを使用するプリンタのパージさ���た材料が見積もられるようになりました。
- Print Pro:ビルドレポートでは、Excel または CSV エクスポートの一部として、個々の部位の印刷所要時間が見積もられるようになりました。
- Print Pro:見積もりを Excel ファイルにエクスポートすると、ビルドレポートとトレイ概要が同じドキュメントの個別のシートとして含まれるようになりました。
- 計測ツールのご紹介!点間の距離、平面から点、または点から平面までの距離を測定できるようになり、頂点と簡単に位置合わせするオプションが追加されました。この測定機能は、FDM、SAF、P3 プロジェクトで使用できます。
- モデルを強調表示し、マウスの右ボタンでメニューの [名前の変更] コマンドを選択することで、プロジェクト パネルまたはモデル ビューアで部位、アセンブリ、本体の名前を変更できるようになりました。
- 新しい選択オプションが、右クリックで表示されるメニューに追加されました。[すべて選択] をプロジェクト全体または現在のトレイに適用できるようになりました。新しいオプション [選択範囲を反転] は、現在のトレイまたはプロジェクト全体で、選択されていない部分に選択範囲を反転します。
- H350 印刷では、ビュー コントロール ストリップで 2 つの新しいオプションがあります。
- [色付け] は、ネスト内の部位にランダムな色を追加して、密なパックをわかりやすく視覚化します。
- レイヤーラインの視覚化では、印刷結果でレイヤーが見える上向きまたは下向きの表面に線を表示します。
- P3 では、GrabCAD Print で支持構造を生成するための新しいツールが追加されました。GrabCAD Print を使用して CAD ファイルを完全に準備し、印刷に送信できるようになりました。追加のソフトウェアは必要ありません。
GrabCAD Print バージョン 1.82、9月 2023
- Print Pro:厚さ解析と呼ばれる解析モードの新機能を使用すると、部位にプリンタの解像度を下回るジオメトリが含まれているかどうかを迅速に確認できます。解像度は、プリンタ技術に基づいてデフォルトで設定されますが、ユーザーは独自の値を設定できます。表示は、赤色不合格/緑色合格の 2 値表示、または連続的な黄色と赤色グラデーションで表示されます。カーソルは、部位上の任意の点で特定の値を表示する「プローブ」も提供します。
- Print Pro:FDM 3D 配列コマンドで、小さい負の間隔値を使用できるようになり、トレイ上で部位をさらに密に配置できるようになりました。
- トレイを非表示にできるようになり、密な部位の下側が見やすくなりました。
- GrabCAD Print は、Stratasys H350、Fortus 450mc、Stratasys F900、Fortus 900mc プリンタと通信するときに、IPv6 アドレスをサポートします。Fortus 450mc の IPv6 にはファームウェア バージョン 6.8が必要です。Stratasys F900 および Fortus 900mc では、IPv6 をサポートするファームウェア バージョン 4.22が必要です。
- J5 DentaJet プラットフォーム上の義歯、一時的な歯冠およびブリッジの 3D 印刷用に開発された FDA 認可 (クラス II) 樹脂である TrueDent™ をご紹介。これにより、1 つの混合トレイ上で審美性の高いモノリシックな多色の歯科器具のバッチ生産が可能になります。TrueDent™ は現在、特定地域でのみ利用可能ですが、生産性の向上と優れた成果を求める歯科技工所にとって有望なソリューションとなります。
- バージョン 1.81 では、アドバンスト テクスチャ処理をアクティブ化/非アクティブ化できる設定が追加されました。このチェックボックスは [トレイ設定] ([詳細設定] セクションの下) に移動し、ユーザーがジョブごとに値を決定できるようになりました。J55 Prime および J850 Prime では、チェックボックスはデフォルトでオフになっており、テクスチャ付きの重いトレイが印刷されます。
- ゲル コーティングは、DAP プリンタの構造的心臓モデルに追加されました (血管モデルの仕様に従い)。
- SAF 印刷の場合、焼結ボックスにボックスの形状の一部としてユーザー定義のラベルが付けられるようになりました。これにより、ケーキを分解して、焼結ボックスにどのような部位が含まれているかを確認できるようになります。長いラベルは、焼結ボックスの最長軸に自動的に位置合わせされます。
- SAF 印刷の場合、熱管理を改善するために追加のスペースが必要な、選択した部位に対して、ネストの最小間隔値をオーバーライドできます。
- SAF 印刷では、ネスト操作でネストの既存の内容を追加するか、ネストをクリアして最初からやり直すかを選択できるようになりました。
- P3 印刷の場合、「トレイに合わせる」オプションにより、印刷領域に合うまでモデルを段階的に回転させる、向きの改善が開始します。
- P3 印刷の場合、すべての歯科サポート プロファイルには、90°方向のスプリント モデルで凹版上アンカー ポイントをフィルタリングする新しいパラメータが必要です。
- P3 印刷では、アンカー ポイントを作成するときに、選択したサポート プロファイルで指定した自立角度に従ってサポート可能な領域が色付けされます。
- P3 オンプレミス クラウドを使用する GrabCAD Print ユーザーは、非管理者アカウントで GrabCAD Print を実行できます。
GrabCAD Print バージョン 1.81、8月 2023
- Print Pro:アキュラシーセンターに、オリジナル ビューと検証ビューのタブが加わりました。[オリジナル] タブには、元の印刷部位の精度結果 (ヒートマップおよび印刷精度スコア (PAS)) が表示されます。[検証] タブを使用すると、WAM プリントのスキャンをアップロードして、精度がどの程度上がったかを正確に確認できます。ここには、新しい PAS と元のスコアが表示され、新しいヒストグラムに、元のスコアが灰色の輪郭で重なり、特定のエラー バンドの減少を簡単に確認できます。
- Print Pro: 水平面での結果を向上させるアキュラシーセンターへの新しい WAM コントロール:
- [保持] (デフォルトになりました) では、美観を保持し、滑らかな水平領域に輪郭が追加されないよう、水平面の均一な垂直方向の調整のみが許可されます。
- ピンは水平面の動きを防ぎます。
- Free Adjust を使用すると、美観よりもフィット感が優先される場合に、水平面内に輪郭を追加するなど、水平面の反りを自由に修正でき、精度を最大限に高めることができます。
- Print Pro:ユーザーが正しいスキャン ファイルを選択できるように、選択したスキャン ファイルのクイック プレビューがアキュラシーセンターに追加されました。
- Print Pro:アキュラシーセンターのヒストグラムの Y 軸には、各誤差レベル バーの合計部位%が表示されるようになり、部位の何%が選択した許容値を超えている、下回っている、または範囲内にあるかを確認できるようになりました。
- Print Pro:アキュラシーセンターでスキャンを比較する場合、比較する結果の上にマウスを移動すると、印刷された部位とスキャンされた部位の局所的な差異 (その時点でのエラー対設計など) が動的に表示されるようになりました。
- ローカル ハブおよび OpenAM ライセンスを持つ P3 ユーザーの場合、「レイヤーごとの設定」ファイルをアップロードするときの問題が修正されました。
- P3 ユーザーの場合、モデル挿入設定の「モデルが現在のプラットフォームに合わない場合にトレイを自動的に作成する」設定が、他のプラットフォームと同様に P3 プリンタでも機能するようになりました。
GrabCAD Print バージョン 1.80、7月 2023
- GrabCAD Print では、SOLIDWORKS 2023、SolidEdge 2023、Siemens NX 2212 の CAD ファイルの 2023 バージョンがサポートされています。
- Print Pro:アドホック テキスト ラベルを FDM 部位 (STL および CAD) に追加できるようになりました。浮き出し加工または型押し加工が可能で、テキストのサイズ、深さ、間隔を制御できます。また、ラベルの再利用可能なテンプレートを作成でき、テキストや部位名を埋め込み、一意のシリアル番号を生成できます。GrabCAD Print Pro の詳細については、ここをクリックしてください。
- SAF ネスティングでは、機能がわかりやすいように、ネストのメソッドの名前が Standard および Advanced から No interlocks および Compact に変更されました。デフォルトの方法は現在、Compact (以前は Advanced) になっており、一般的により密なネストになります。
- SAF では、検証が非常に遅くなることがあるため、ネストをさらに編集する必要がある場合は検証プロセスをキャンセルできるようになりました。
- J850 TechStyle ユーザーは、セミフレキシブル素材の新しい VeroEcoFlex ファミリーを利用できるようになりました。詳細はこちらをご覧ください。
- 多くの PolyJet プリンタで UV 水銀ランプが使用されていますが、J850 TechStyle では代わりに UV LED が使用されています。新しい UV LED により、小型のファッションのモデルにとって重要な、より正確な硬化が可能になります。GrabCAD Print の UV LED レシピ機能は、特定のスライスまたはスライス範囲まで UV 機能を制御するメカニズムを提供します。印刷過程のどの部分でも、使用する LED と各 LED の強度を制御できます。
- GrabCAD Print で P3 機械がお気に入りとして保存されない問題が解決されました。この問題は修正され、ユーザーはマシンをお気に入りとして割り当てることができるようになりました。
- 以前は、P3 ジョブの長いジョブの見積もりが正しく表示されないという問題がありました。これにより、完了までの時間がかなり短くなっていました。この問題が解決されました。
- P3 で、特定の設定を行った特定の材料の印刷が開始できない時に発生する問題が解決されました。この問題が発生することなく、ジョブは期待どおりに印刷開始するようになりました。
- OpenAM ライセンスを持つ P3 ユーザーの場合、材料プロファイルの縮尺変更範囲が +2% から -1% までに拡張され、樹脂の収縮を補うために縮尺変更をより適切に調整できるようになりました。
- OpenAM ライセンスを持つ P3 ユーザーの場合、特定の状況下で最適に実行されなかった「層ごとの設定のアップロード」機能の問題が修正されました。
- OpenAM ライセンスを持つ P3 ユーザーの場合、新しく作成した材料を含むジョブの印刷が開始されない問題が修正されました。
GrabCAD Print バージョン 1.79、6月 2023
- ラップ・モデル・ツールはグループで使用でき、メンバーボディは独自の設定を持つことができます。デフォルトでオンになっています。ラップは、モデルのボディを共通のシェルで囲みます。モデル内のボディ間のジョイントが荷重に耐えるように設計されていない場合、シェルは強度を追加します。ボディ間のジョイントが荷重に耐えるように設計されている場合、ラップ機能は必要ないため、オフにすることができます。
- CMBインポートに関連するコンフリクトは、追加されるファイルがどのようにプロジェクトと一致しないかを明確に示しています。
- ASA は現在、Stratasys F770 プリンターで次の色をご利用いただけます: ホワイト、ブラック、ライトグレー、ブルー、レッド、イエロー。
- J3/J5DentaJetのペデスタルの高さは、接着力を向上させるために1 mm に増加しました。
- 「Optimize For Packaging」オプションがJ850 Prime FabriXに追加されました。このオプションにより、透明なパッケージオブジェクト(ボトルなど)の印刷結果が向上されます。
- P3プリンタのトレイ設定にあるスケーリングツールで、測定単位が小数点以下1桁から小数点以下3桁に拡張されました。この機能の拡張により、より正確な測定と機能の微調整が可能になります。
- P3プリンタ用のスライススタックのインポートで、layer_xxx、slice_xxxなど、任意のプレフィクスを持つスライスファイル名がサポートされるようになりました。
- OpenAMライセンスを持つ P3 ユーザー向けには、新しいダウンロード材料設定機能があります。材料の最初のレイヤーと遷移レイヤーに関する情報を含むCSV ファイルをダウンロードできます。この情報にアクセスするには、材料ライブラリに移動して材料を選択し、レイヤーごとの設定表の上にある 「設定をダウンロード」ボタンを押してください。
- プロジェクト・パネルに、ミラーコマンドで作成されたモデルの横にアイコンが表示されます。
- SAF 印刷のでは、ネスト・プログレス・バーにより、ネストが実行されるタイミングや検証が実行されるタイミングがユーザに通知されます。
GrabCAD Print バージョン 1.78、5月 2023
ビルド番号 1.78.18.27879 リリース日 16 5月 2023
- GrabCAD Print Pro こちらです!機能には、ワープ調整モデリング、部分単位の見積もり、製造テンプレートなどがあります。
- Pro の機能一覧を読む
GrabCAD Print で内部���に使用され、FDM ジョブの画面上のグラフィックをレンダリングするソフトウェアが更新されました。これは、多くの新機能で必要なためです。古いビューアは設定メニューから引き続き使用できますが、将来的には廃止される予定です。
FDM の場合、外部輪郭のリンク動作が更新され、モデル材料とスライス高さに定義された動作が常に使用されるようになりました。以前は、材料のリンク動作を無視して、外部輪郭がリンクされることがありました。
Nylon-CF10 は、Stratasys F370CR および F190CR プリンター用の取り外し可能な支持体付きで利用できるようになりました。SUP4000B 支持体材料はタンクを必要とせず、簡単に取り外すことができるため、取り外しがスピードアップします。SUP4000B は、QSR と同じ支持ヘッドを使用し、Nylon-CF10 と同じスライス高さ(0.0130 インチ/0.3302 mm、0.0100 インチ/0.2504 mm、0.0070 インチ/0.1778 mm)を使用します。
取り外し可能な支持体付きの Nylon-CF10 を使用するには、プリンターのファームウェアをバージョン 2.6に更新する必要があります。
QSR 支持体付き Nylon-CF10 の材料定義が更新され、 0.0100 インチ (0.2504 mm)および 0.0130 インチ(0.3302 mm) のスライス高さの充填動作が改善されました。
以下の造形時間と材料量の見積りの精度を向上します。
- Fortus900mc プリンタで T40A チップを使用した0.0200インチ(0.5040mm)ASA
- Stratasys F900プリンタのT40Cチップを使用した0.0200インチ(0.5040mm) ナイロンCF12(黒)
- Stratasys F900 および Fortus 900mc プリンタで T40A チップを使用した 0.0200 インチ (0.5040 mm) ULTEM9085 レジン・ブラック
- P3ジョブの 「Print 」ボタンをクリックした後、プリントサマリーウィンドウで、1stレイヤーまたはトレイプレビューサムネイルを押すと、簡単に拡大することができます。これにより、印刷前に最初のスライスの詳細を詳しく見ることができます。
- モデルがP3作業のビルドボリュームの外側にある場合、オレンジ色のビックリマークの通知がプロジェクト・パネル・ウィンドウに表示され、その上にマウスを置くと問題の説明が表示されます。
- OpenAM ライセンスを持つ P3 ユーザーの場合、GrabCAD Print は「edgeBuildingCompensation」値を含むレイヤーごとの設定のアップロードをサポートするようになりました。アップロード後、カラムはPer Layer Setting テーブルに表示されます。
GrabCAD Print バージョン 1.77、4月 2023
ビルド番号 1.77.13.26873 リリース日 18 4月 2023
- 新しいプロジェクトを開始せずに印刷技術を切り替える機能が復元されました。
- PolyJet: 特定のアセンブリの歯茎シェードを変更する場合、アセンブリとそのシェルが複製され、トレイツリーで非表示としてマークされていました。(非表示アセンブリは、非常に複雑な「元に戻す」操作を簡単にするために作成されました。)今後、これらのアセンブリはツリー上に表示されなくなり、元に戻す操作は引き続き正常に機能します。
- SAF: パートを選択し、穴のサイズ、ビームの厚さ、間隔を指定してパートを収容および保護するための焼結ボックスを作成できます。
- P3: トランジションレイヤーのパラメーターが最適化され、検証済みの材料で自動的に処理されるようになりました。以前はこの機能は「材料プロパティ」に表示されていましたが、現在は非表示になっています。
- P3: インチで定義されたモデルが印刷前にミリメートルに変更される問題がありましたが、修正されました。
GrabCAD Print バージョン 1.76、3月 2023
ビルド番号 1.76.10.25761 リリース日 21 3月 2023
- CMB のインポート時にファイルタイプとして Stack (*.zip) が表示された問題は、CMB ファイル(*.cmb, *.cmb.gz)に復元されました。
- P3印刷の場合、「トレイ設定」/「材料プロパティ 」の下に新しいスケーリング・パラメータが表示されます。印刷パートが材料の収縮の影響を受ける場合に役立ち、作業レベルで材料のスケール値を編集して最適化できます。
- P3 印刷の場合、「トレイ設定」/「マテリアル プロパティ」の下に、新しいエキストラ・ベース・レイヤー パラメータが表示されます。これは、パートの Z 高さが CAD 設計より低い場合に役立ちます。エキストラ・ベース・レイヤーを追加すると、最初のレイヤーが複製され、高さの損失が補われます。
- OpenAM ライセンスを持つ P3 ユーザーの場合、CSV を使用して変更された「レイヤーごとの設定」を印刷できます。
GrabCAD Print バージョン 1.75、2月 2023
ビルド番号 1.75.13.24793 リリース日 21 2月 2023
- ソフトウェアをより強固なものにするため、異なる技術のプリンタ(例えば、FDMからPolyJet)に切り替えるには、新しいプロジェクトファイルを開始する必要があります。プロジェクトにモデルを追加する前に、プリンタ技術を自由に切り替えることができます。
- Fortus450mc ププリンターのジョブをプログラミングするときに、検証済み材料がGrabCAD Printで利用できるようになりました。これらの材料は、プログラミングや印刷作業に利用される前に、基本的な信頼性テストによって検証されます。検証済み材料を使用するには、450mc にファームウェア・バージョン 6.7がインストールされている必要があります。
検証済み材料 | 利用可能なスライス高さ | モデルチップ | サポート材 | サポートチップ |
FDM HIPS (ハイーインパクト・ポリスチレン) | 0.0100インチ (0.2540mm) | T16 | SUP1500B | T12 |
KimyaPC-FR(難燃剤) |
0.0100インチ (0.2540mm) | T16 | SR100 | T12SR100 |
ULTEM™9085樹脂の新色(レッド、エアクラフト��レー、ガンシップグレー、ドリームグレー、ホワイト7362、ジャナホワイト)。 | 0.0100インチ (0.2540mm) | T16 | SUP8500B | T16 |
PC の新色(レッド、ブラック) | 0.0100インチ (0.2540mm) | T16 | SR100 | T12SR100 |
PC-ABS の新色(レッド) | 0.0100インチ (0.2540mm) | T16 | SR100 | T12SR100 |
(BETA) VICTREX AM™200PAEK (低融点) |
0.0100インチ (0.2540mm) | T14E | SR100 | T12SR100 |
(BETA)Covestro Addigy®PA6/66-GF20 FR LS(ガラス繊維入りナイロン、難燃剤) |
0.0100インチ (0.2540mm) | T20G | SUP4000B | T16 |
- 材料パッケージが GrabCAD Print でサポートされるようになりました。材料パッケージは、材料が OpenAM™ で調整され、コンパイルされて、OpenAM ライセンスで有効になっている GrabCAD Print および Fortus 450mc プリンタに配布されるときに作成されます。Stratasyの推奨材料および検証済み材料は、サードパーティのオープン材料と同様に、調整されてパッケージに含まれる場合があります。材料パッケージには、プリンタのファームウェアバージョン 6.7が必要です。
- CMBの複製(またはコピー/ペースト)が元のCMBと同じツールパスを持っていなかったバグが修正されました。
- J35プラットフォームをベースとしたJ3デンタジェット™は、中小規模の歯科技工所向けのエントリーレベルPolyJetプリンタです。大量のインプラントモデル、サージカルガイド、歯茎マスクを含む3種類の生体適合材料の混合トレイを、すべて同じトレイ上で最高の精度で作製できます。 J3デンタジェット™の新製品は、こちらをご覧ください。
- PolyJet プリンターのジョブマネージャのアップグレードを促すアラートは、GrabCAD Print とジョブマネージャのバージョンが一致していない場合にのみ表示されるようになりました。以前は、新しいバージョンが利用可能になるとすぐにアラートが表示されていました。
- PolyJet印刷用のテクスチャ付きVRMLモデルにコーティングレイヤーを追加できるようになりました。
- SAFプリンターでは、PA12材料(ベータ版)が利用可能になりました。詳細はこちら
- SAFプリンターでは、新しい右クリックオプションを使用すると、評価または検証後に無効なモデルを選択できます。
- SAFプリンターでは、角度のあるパートにスライスによる小さな表面アーティファクトが発生することがありましたが、この問題を回避するため、スライスアルゴリズムをより正確に作成しました。
- インターネットにアクセスせずに P3 印刷を行う場合は、Origin Local Hub 経由でOrigin One Local プリンタへの接続がサポートされるようになりました(詳細は、Stratasys サポートセンターの「Origin One Local」リファレンスガイドを参照してください。Stratasysサポートセンター)。 接続方法についてはこちらへ。
- P3 プリンタでは、Netfabb などのアプリケーションによって作成されたスライスを次の方法でインポートできます: [ファイル] > [インポート・スライス・スタック]。
GrabCAD Print バージョン 1.74、1月 2023
ビルド番号 1.74.8.23921 リリース日 17 1月 2023
- FIPS 準拠の暗号化を使用するための Windows セキュリティ設定により、以前は GrabCAD 製品のプリンタ接続がブロックされていましたが、この問題は GrabCAD Print および Print Server では解決されました。 PolyJet ジョブ・マネージャーがインストールされているシステムでは、引き続き FIPS を無効にする必要があります。
- 3導入された DConnexion Spacemouse のサポート 1.55が復元されました。
- トレイ材料にすべてのカラーの VeroFlex マテリアルが含まれている場合、VeroFlex 材料の CMYK 入力がすべての J7xx/8xx プリンタで有効になりました。
- Origin プリンタの材料パラメータにエッジ補正が追加されました。この新しいツールを使用すると、各スライスのモデルのエッジからミクロンを追加または削除できます。穴などのフィーチャがわずかに大きすぎたり小さすぎたとしても、モデルのスケーリングを変更したくない場合に役立ちます。
GrabCAD Print バージョン 1.73、12月 2022
ビルド番号 1.73.5.23276 リリース日 20 12月 2022
- Workbench からモデルを追加することはできません。 GrabCAD Workbenchの廃止については、こちらのブログ投稿をご覧ください。
- PolyJet歯科用プリンターでは、3Shape との統合のために、歯& の歯茎シェード名をリストしたファイルが、バージョン 1.72に追加された新しいシェードに更新されました。また、存在しないシェード名を含む古いプロジェクトやジョブを開くときは、シェード名が空になって通知が表示されます。 存在しないシェードを使用するプリセットを選択した場合、デフォルトのシェードが自動的に設定されます。
- GrabCAD Print Manufacturing ノートが H350 で利用できるようになりました。これにより、ユーザーはモデルに注釈を付け、モデルのスクリーンショットとノートを含む PDF レポートを PDF トラベラー ドキュメントに作成できます。
- またH350 についてもバグが修正され、ラベルのプレビューが正しいサイズで表示されるようになりました。
GrabCAD Print バージョン 1.72、11月 2022
ビルド番号 1.72.6.22542 リリース日 16 11月 2022
- 0.0200 インチ (0.508 mm) のスライスの高さが、Stratasys F900 プリンタのナイロン 12 CF に追加され、大型パーツのスループットが向上します。このスライスの高さは、T40C モデルのチップを使用しています。
- 0.0200 インチ (0.508 mm) のスライスの高さが、Stratasys F900 および Fortus 900mc プリンターの ULTEM™ 9085 Resin、ULTEM™ 9085 CG Resin、および ULTEM™ 9085 Resin Black に追加されます。新しいスライスの高さにより、大きなパーツのスループットが向上します。このスライス高は、T40A モデルのチップを使用しています。
- H350 3D Nest で選択したモデルは視覚的に分離できるため、選択されていないモデルはすべて非表示となり、ユーザーが分離されたモデルでの作業を終了すると、すべてのモデルを再び表示できます。これらの操作によって3D ネスト内のパーツの位置は変更されないためご注意ください。
- H350 の場合、アセンブリコマンドまたはグループ化された 3D 配列で作成された CAD からの任意のアセンブリを選択でき、アセンブリ構造を分解して個々のモデルを残すことができます。
- H350 の推定では、ネスト全体とモデルの質量、およびネスト全体の HAF 流体も���告されるようになりました。
- H350 のラベルコマンドは、コマンドを使用するたびに設定を記憶するようになり、エンボス/デボス、テキストサイズなどが同じままであるため、一連の手動ラベルの作成がより早く出来るようになりました。
- J5 DentaJet では、いくつかの歯の色合いがより正確な色に改善され、2 つの新しい色合いが追加されました。
- J5 DentaJet では歯肉の色合いが改善され、テクスチャが向上しました。 4つの新しい色合いが追加されました。
GrabCAD Print バージョン 1.71、10月 2022
ビルド番号 1.71.7.21930 リリース日 18 10月 2022
- J5 DentaJet ユーザーは、3Shape の Dental System ソフトウェアと GrabCAD Print を使用して、口腔内スキャンからフルカラー印刷モデルまで、エンドツーエンドのワークフローを利用できるようになりました。 VeroDent PureWhite および Vero CMYK で印刷する場合、3Shape Color Model Profile が J5 DentaJet に追加されました。これには、3Shape Dental System ソフトウェアの2022リリースが必要なためご注意ください。
- Advanced Slicer が有効になっている Connex プリンタにジョブを送信すると、印刷確認画面に通知が表示されます。
- 超高速モードで J7/J8 シリーズプリンタに印刷されたジョブがスケジュール ビューに表示されない問題が修正されました。
- H350 の 3Dネスト領域の名前は、FDM または PolyJet のトレイの名前を変更するのと同様に、プロジェクトパネルのプレビューをクリックして変更できます。これにより、プリンタに送信されるジョブの名前が変更されます。
- H350 の見積もり用に生成されたレポートの内容をコピーして、スプレッドシートなどの他のファイルに貼り付けたり、.XLSX または .CSV ファイルとしてダウンロードしたりできるようになりました。
- OpenAM ライセンスのない P3 ユーザーは、GrabCAD Print を介して正確な見積もり結果を取得できるようになりました。 こちらのブログ記事にて詳細をご確認ください。
GrabCAD Print バージョン 1.70、9月 2022
ビルド番号 1.70.12.21501 リリース日 21 9月 2022
- GrabCAD Print が Windows 11 オペレーティングシステムをサポートするようになりました。フルシステム要件については、 こちらをクリックして確認してください。
- GrabCAD Print は、Creo9、Inventor 2023、NX2206、Parasolid 34.1 など、CAD ソフトウェアの最新バージョンのファイルに対応するようになりました。
- GrabCAD Print は、オリジンワンおよびオリジンワンデンタルプリンタをサポートするようになりました。 [ファイル] > [環境設定] > [P3 DLP] で Originアカウントにログインすると、ジョブ設定とプリンターへの送信ができます。 詳細はこちら。
- FDM プロジェクトの場合、プロジェクトが取得され、選択されたプリンタが見つからない場合、GrabCAD Print はジョブ設定を保持するようになりました。設定にプリンタのデフォルト値が適用される問題が解決されました。
- T14H 硬化押出ヘッドが Stratasys F370、F270、および F170 プリンタでサポートされるようになりました。 1500 時間の寿命を持つヘッドは、ABS-CF10 材料を使用したプログラミングジョブのデフォルト選択です。
- 歯科用 PolyJet プリンタの場合、複数選択で歯肉にシェードを割り当てることができるようになりました。ただし、アセンブリごとに 1 つのシェルに制限されます。
- J850 Prime Fabrix と TechStyle の両方で、接着層の有効な厚さが 3 mm に増加しました。
- PolyJet のバグ修正:
- J850 Prime Fabrix および TechStyle では、計画停止で保存されたプロジェクトが、計画停止なしで開かれます。
- J5 DentaJet で、有効なプロジェクトを開くと検証が失敗します。
- SHS モードの J5 DentaJet で、モデルとサポート材料の合計見積もりは間違っています。
- 次のコマンドが H350 の 3Dネストビューに追加され、ユーザーが 3D ネストビューのみで作業できるようになりました: 解析モード、単位、スケール、モデルの追加、X、Y 平面でのフリー ドラッグ.
- ネストするには大きすぎるモデルを含む複数のモデルの H350 ビルドを作成しても、ネスト操作全体が失敗することはなくなりました。適合するモデルはネストされ、大きすぎて適合しないモデルの警告リストが表示されます。
- H350 の場合、名前または番号自動化を使用してテンプレートラベルを作成すると、構文が自動的にチェックされ、正しくない場合は赤で強調表示され、エラーの詳細がツールチップに示されます。
GrabCAD Print バージョン 1.69、8月 2022
ビルド番号 1.69.12.20542 リリース日 16 8月 2022
- J5MediJet™ で 2 つの新しい樹脂がサポートされるようになりました
- 生体適合性デジタル ABS プラス™ は、耐熱性と高靭性を組み合わせることで、標準の ABS プラスチックをシミュレートするように設計されています。この材料は、さまざまな医療用途の生体適合性部品の機械的性能を大幅に向上させます。
WSS™150 は、サポートをすばやく除去するための水溶性サポート素材です。通常の水道水で満たされた容器に入れると、材料は溶けます。標準またはカウンタートップ食器洗い機を使用すると、サポートをより迅速に除去できます。
詳細は こちら。
- J750/850 Digital Anatomy トレイの材料に RadioMatrix が含まれている場合、モデルの挿入時にデフォルト材料として選択されません。
- PolyJet Research Package と 3DFashion プリンタの両方にアクセスできる場合、一部の機能が競合しているため、現在のプロジェクトで使用するプリンタを 1 つ選択する必要があります。
- J7 シリーズおよび J8 シリーズプリンタで、Agilus カラー材料を使用して柔軟に動作するモデルを設定する際のユーザーエクスペリエンスが向上しました。関連する設定が詳細オプションからメイン設定セクションに移動され、詳細なツールチップがすべての設定オプションに追加されました。
- 1.67更新により、Connex3 プリンタに高度なスライサーを使用するためのオプションが導入され、[ファイル] > [環境設定] > [PolyJet] の下にあるチェックボックスがデフォルトでオンになりました。 Advanced Slicer はグラフィックス要件に関してより厳密であり、一部のユーザーはグラフィックスドライバに関するエラーを目にしていました。高度なスライサー設定をオフにした後エラーが持続し、ジョブがキューに入れられないというバグがありました。 1.69 の更新により、これは修正されました。設定をオフにすると、エラーが解消されます。
- H350 の場合、パックの高さを時間 (シフトで利用可能な時間に合わせたジョブを準備するのに便利です) またはパックの高さ (ユーザーが入力したパラメーターが更新されたもの) として指定できるようになりました。
- H350 の見積もりでは、概要ページと詳細ページを含むビルド レポートが提供されるようになりました。要約リスト: 印刷時間、総体積、ネストされたモデル、ネストされていないモデル、密度、ネストの高さ、および収縮。詳細リスト: 個々のパーツ、各パーツのコピー数、および各パーツのボリューム。
GrabCAD Print バージョン 1.68、7月 2022
ビルド番号 1.68.10.19783 リリース日 19 7月 2022
- マルチファイル 3MF、OBJ、および VRML アセンブリはすべて、[ファイル] > [アセンブリとしてインポート] を使用して、STL と同じ方法でインポートできるようになりました。
- ULTEM™ 9085 樹脂のサポート材は SUP8500B サポートとしてブランド変更され、ULTEM™ 1010 樹脂は SUP9000B サポートとしてブランド変更されました。
- ラベル (H350 のみ) の場合、ラベル テキストのエンボスの高さまたはデボスの深さを指定できるようになりました。
- 3D 配列 (H350 のみ) の場合、複数のモデルを選択して、それらのモデルの配列を作成できるようになりました。
- J850 TechStyle と J850 Prime Fabrix の両方でプリンタを接続すると、現在のジョブのトレイタイプが、プリンタにインストールされているトレイと自動的に同期されます。
- 右側の UV ランプエアダクトフィールド変更命令を受け取って取り付けた J7 および J8 シリーズプリンタでは、[プリンタ設定] ダイアログが拡張され、「更新されたエアダクトが取り付けられました」という文が表示されます。
- MED620 と SUP711 の混合物である ASR-620 DM は、HQHS 印刷モードの J5 DentaJet で利用できるようになりました。
- カラー Agilus素材は、ボクセルプリントアプリで利用できます。
- Flex-Touch (Smart と Full の両方) は、トレイ上のすべてのモデルに共通の Flex-Touch ではなく、モデルごとに定義する必要があります。
GrabCAD Print バージョン 1.67、6月 2022
ビルド番号 1.67.10.19143 リリース日 22 6月 2022
- 以前は J シリーズプリンタでのみ利用可能だった Advanced PolyJet Slicer が、Connex3 プリンタでサポートされるようになりました。 Advanced Slicer では、品質が向上し、次のような機能が追加されています
- 透明度のあるグレースケール B&W プロファイル
- 薄肉エリア・コーナーハンドリング
- より正確な見積もりとオフセット
グリッドコントロールの改善
以前の印刷を正確に複製する必要がある場合は、[ファイル] > [環境設定] > [PolyJet] を使用して従来のスライサーに戻すことができます。
- J850™ プライム用の FabriX™ イノベーションキットを使用すると、PolyJet™ プロトタイピングと CMF 機能をテキスタイルとフレキシブル素材への直接印刷の新しい世界に拡張できます。メッシュ素材、機能性アパレルのプロトタイプ、さらにはろ過システムの視覚化を含むアプリケーションのさまざまなデザインをテストできるようになりました。
- Digital Anatomy Printer で利用できる初めての放射線不透過性3D 印刷材料である RadioMatrix™ を紹介します。この新しい素材により、CT または X 線スキャンで表示されるさまざまなコントラストの放射線不透過性特性を備えた 3D プリント解剖モデルが可能になります。 Digital Anatomy Printer ソフトウェアに RadioMatrix™ 材料設定が追加され、希望するハウンズフィールド値を持つ放射線不透過性 3D プリント解剖モデルが提供されます。
- 新しい Netting-Fabric 挿入機能により、ユーザーは、ジョブ中に印刷するメディアを挿入するために、印刷中に停止を計画できます。 J850 TechStyle および J850 Prime FabriX システムで有効になっている機能。
- AgilusCMY モデルのジッド コアを使用すると、Agilus カラー プロファイルを使用して「ソフトタッチ」のリジッドモデルを一度印刷できます。その結果、外側の柔らかい表面としてフルカラーの薄いテクスチャ (1 mm フルカラーショア A 30) を持つ剛体モデルが作成されます。
- AgilusCMY素材の CMYK 入力により、純粋な AgilusCMY 素材の CMYK 数値入力によって特定の希望の色調を定義できます。
- J5 DentaJet の高品質高速モードにより、歯科模型、サージカルガイド、およびその他のアプリケーションを同じ品質で半分の時間で印刷できるようになりました。適切な材料構成が選択され、プリンタで材料交換ウィザードが実行されると、GrabCAD Print で高品質高速モードを選択できます。
- H350 では、GrabCAD Print にロードされた複数の最上位モデルからアセンブリを作成できるようになりました。モデルは、3D ドラッグ ウィジェットまたは配置ツールを使用して 3D 空間に配置され、ネスト可能なアセンブリに作成されます。
- 3H350 用の D 配列ツールは、配列のソースとしてアセンブリも対応するようになりました。
- H350 の 3D Nest ツールの停止基準としてパックの高さを使用できるようになりました。ネスティングプロセスで選択したすべてのモデルが正常にパックされると、指定された高さに達するまでパックの高さを下げようとします。
- H350 の 3D ネスト コマンドの最小モデル間隔のデフォルト値が 2 mm になり、3 mm から減少したため、より密なネストを安全に作成できます。
GrabCAD Print バージョン 1.66、5月 2022
ビルド番号 1.66.7.17878 リリース日 17 5月 2022
- F123シリーズの最新作、Stratasys F370 CRとStratasys F190 CRをご紹介します。これらのコンポジットレディ(CR)プリンタは、Stratasysの最新のFDM複合材料であるNylon-CF10や現在の材料ABS-CF10を含む、充填材で使用するように設計されています。これにより、従来の製作技術や材料を使用する場合にかかる時間の何分の1かで、強力な作業用固定具、工具、部品を社内で簡単に製造できます。プリンタは8エンジニアリンググレードの材料をサポートし、GrabCAD Printの直感的なインターフェイスと使いやすい高度なFDM機能を使用してプログラムされています。F123コンポジットレディプリンタの詳細は、こちらをご覧ください。
- J850 TechStyle 3Dプリンタには、3DFashion™技術が搭載されており、テキスタイル、レザー、衣服に直接印刷したり、小さなファッションアクセサリーを印刷したりできる、デザインのフルカラーの材料機能を活用して、従来の方法では不可能だった結果を出すことができます。詳細は、こちらをご覧ください。
- GrabCAD Printは、H350 SAF技術プリンタをサポートするようになりました。ライセンスを取得したユーザーは印刷でき、ライセンスを取得していないユーザーは機能を調べてその可能性を学習および評価できます。詳細は、こちらをご覧ください。
- 右クリックでメニューを開き、GrabCAD Printでモデルをミラーリングできるようになりました。この機能は、すべての印刷技術のメッシュおよびCAD部位のミラー、面の色、テクスチャ、アセンブリ内のモデル、およびアセンブリ全体をサポートします。現在、これは高度なFDM機能を備えたモデルおよびラベルを備えたモデルのミラーリングはサポートしていません。
- 炭素強化ナイロンブレンドであるNylon-CF10は、Stratasys F370 CRおよびStratasys F190 CRプリンタで使用できます。材料には、チョップドカーボンファイバーが重量で10%含まれているため、ABS-CF10よりも剛性と強度が高く、耐薬品性に優れた3Dプリントモデルを得られます。Nylon-CF10は、 0.0070インチ(0.1778mm)、0.0100インチ(0.2540mm)、および 0.0130インチ(0.3302mm)のスライス高でサポートされており、印刷には新しい硬化ヘッド(T20H)が必要です。Nylon-CF10の詳細は、こちらをご覧ください。
- 新しい硬化ヘッド(T14H)は、ABS-CF10の印刷に使用でき、印刷寿命は1500時間です。T14Hヘッドはオプションです。T14ヘッドはABS-CF10で引き続き使用できますが、ヘッドの寿命は短くなります。
- 新しいAgilus30™カラー樹脂(シアン、マゼンタ、イエロー)は、繰り返しの曲げに耐えることができる高い表面品質と柔軟性を備えた、フルカラーのゴムのような部位のゴムまたはシリコンテクスチャ製品のプロトタイピングを可能にします。詳細は、こちらをご覧ください。
- 材料WSS(水溶性サポート)、VeroUltraClearSおよびVeroUltraClearがVoxelPrintで使用できるようになりました。
- H350の場合、ラベルツールを使用してモデルの表面にエンボスまたはデボスのテキストを追加します。また、部位を複製するときに複数回または自動的に適用できるラベルテンプレートを作成することもできます。これらのテンプレートには、部位名を自動的に含めたり、シリアル番号を生成したりできます。
- H350の場合、X、Y、Zで長方形の配列を作成できます。配列をグループ化して、単一のオブジェクトとして動作させることも、個別のモデルとして作成することもできます。
GrabCAD Print バージョン 1.65、4月 2022
ビルド番号 1.65.13.17318 リリース日 21 4月 2022
- J850デジタル解剖学プリンタのご紹介。J850デジタル解剖学プリンタは、人間の組織の外観と反応の両方を正確に表現する、驚きのリアリズムで医療モデルを生き生きさせます。これらのモデルは、医療専門家や医療機器会社に比類のない臨床的多様性、再現性、精度を提供します。詳細はこちら。
- サポートされているファイル形式を更新して、SOLIDWORKS 2022、Inventor 2022などを追加しました。完全なリストを表示するには、サポートされているファイル形式のリストをクリックしてください。
- 一部のユーザーは、プロキシまたは自己署名証明書が原因で、ネットワーク接続の問題を経験していました。[ファイル]>[環境設定]>[プライバシー]の新しいオプションを使用すると、Windows証明書ストアの証明書をGrabCAD Printで信頼できるようになり、これらの問題の多くが解決されます。これらの構成を検出すると、アプリケーションは自動的に環境設定を行います。
- Digital Anatomyプリンタ用の新しいアドオンソフトウェアモジュールであるDigital Anatomy Creatorのご紹介。Creatorソフトウェアは、高度な数学関数を使用して、解剖学モデルの内部構造をカスタマイズするためのまったく新しい自由をユーザーに提供します。既存の解剖学的プリセットを越えて作成し、正確な仕様を満たすようにデジタル材料を調整します。材料の形成を簡単に操作し、内部の微細構造をカスタマイズして、特定の解剖学的結果を達成します。詳細は、こちらをご覧ください。
- 新しい樹脂がPolyJetシステムのVoxel Printでサポートされるようになりました。サポートされているすべてのプリンタで、VeroUltraWhiteおよびVeroUltraBlack、J5 MediJetでDraftWhiteです。
GrabCAD Print バージョン 1.64、3月 2022
ビルド番号 1.64.9.16414 リリース日 17 3月 2022
- Diran410MF07の部品品質は、Stratasys F370プリンタで次のように改善されています。
- 0.0070インチ(0.1778mm)のスライス高さでは、上向きおよび下向きの可視面の充填密度が向上し、部位の底面と基礎の上面の間の接着力が向上します。
0.0130インチ(0.3302mm)のスライス高さの場合、シーム品質、垂直面、および充填密度が向上します。
これらの改善には、プリンタファームウェアをリリース 2.4に更新する必要があります。
GrabCAD Print バージョン 1.63、2月 2022
ビルド番号 1.63.8.15371 リリース日 16 2月 2022
- WSS™150は、J55 PrimeおよびJ35 Pro PolyJetシステムで支持体をすばやく取り除くための水溶性支持体材料です。WSS150は、水道水の入った容器に入れると溶解します。標準またはカウンタートップの食洗機を使用すると、より早い支持体除去になります。さらに、L2S™粉末を使用すると、地域の規制に従って、先に処理する必要なく廃水を安全に処分できます。
- スライスプレビューパネルが更新されました。
- モデルと支持体材料に使用される名前、スライス高さ、チップが表示されるようになりました
- 機能表示用のフィルタ(スタビライザー、アンカー、シーム、一時停止)が再編成されました
アニメーション(アニメーションの再生、レイヤーの選択、ヘッドの移動)とZポーズ(Zポーズの追加/削除、一時停止のリスト)のコントロールがグループ化されます
材料とスライス高さの情報が[スライスプレビュー]パネルに表示されるようになったため、モデル設定パネルへのアクセスが[スライスプレビュー]から削除されました。
- J55 PrimeまたはJ8 Primeの[包装の最適化]機能では、VeroUltraClearをサポートするCMYK入力を使用して透明色を微調整できるようになりました。これにより、ボトルや液体に優れた透明度と彩度が与えられます。
- J5 DentaJet PolyJetプリンタは、より高速、より正確な歯科用プリントのために、新しく改良されたパラメータのセットを使用するようになりました。
- PolyJetシステムのVoxelPrintで新しい樹脂がサポートされるようになりました。
- サポートされているすべてのプリンタでVeroUltraWhiteおよびVeroUltraBlack
- J5 MediJetのDraftWhite
GrabCAD Print バージョン 1.62、1月 2022
ビルド番号 1.62.8.14676 リリース日 19 1月 2022
- T16Aモデルチップは、Fortus 450mcプリンタのULTEM™9085および認定グレードのULTEM™9085CGモデル材料で使用するために追加されました。航空宇宙の内装など、部品の認証が必要な応用での標準T16チップと比較して、反復性の高い機械的特性と向上した品質を提供します。T16Aモデルチップの層の厚さは 0.010インチ(0.2540mm)です。T16Aモデルチップを使用するには、Fortus 450mcのコントローラーソフトウェアをリリース 6.6に更新する必要があります。6906
- Fortus 450mcプリンタのT20モデルチップを使して、ULTEM™9085ブラックでスライス高さ 0.0130インチ(0.3302mm)がサポートされるようになりました。スライスを厚くすると、部位の造形が速くなり、スループットが上昇します。新しいスライス高さでは、コントローラーソフトウェアを、リリース 6.6.6906に更新する必要があります。
- いくつかの小さなバグが他の改善とともに修正されました。
GrabCAD Print バージョン 1.61、12月 2021
ビルド番号 1.61.12.14139 リリース日 22 12月 2021
- フルカラーのPolyJetプリントでは、カラーピッカーで色を変更するときに、「身体外観」がテクスチャボディのデフォルトコアになりました。これは、最近リリースされたデフォルトでオフになっている「テクスチャの上書き」オプションと密接に関連しています。これにより、シンプルで直感的なワークフローでテクスチャボディの色と透明度を変更できます。
- J5シリーズプリンタでジョブの遅延開始時間を設定する場合、既存の開始時間または終了時間に加えて、新しい時間設定オプションを使用できます。ジョブ中に材料がなくなると、材料キャニスターを変更する時間を設定でき、プリンタは適切な時間にジョブを開始します。
- Digital Anatomy Printerの場合 – 新しい「縫合可能な血管壁」プリセットは、縫合を目的とした血管モデルのパフォーマンスと耐久性を向上させます。
- アンカーとスタビライザーを同じモデルで作成できない問題が修正されました。
GrabCAD Print バージョン 1.60、11月 2021
ビルド番号 1.60.9.13125 リリース日 17 11月 2021
- GrabCAD Printの右側の外観が変更されていることに気付くでしょう。アイコンは少し小さくなり、ウィンドウの側面に固定されています。常にツールが追加されているため、小さな画面に対応するためにフットプリントをわずかに削減しました。
- PolyJetプリンターは、変位(バンプ)マップを含むモデルを印刷できるようになりました。 [ファイル]> [設定]> [GrabCAD Labs]で機能を有効にした後のKeyshotとともに含まれるバンプマップ。3 MFまたは標準の.OBJモデルに含まれているバンプマップが、印刷されたパーツの表面仕上げに変換されます。以前は、バンプマップをファイルの3 Dメッシュに書き込む必要があり、不必要に大きなファイルが作成されていました。これで、バンプマップを直接読み取ることができます。変位の高さは、モデル設定で調整するか、0を無効に設定できます。他のLabs機能と同様に、フィードバックをいただければ幸いです。
- J35 Proには、材料利用モードと呼ばれる新しいモードが用意されています。新しいモードでは、残りの材料を十分に活用するために、プリンターがカラーミックスを自動的に決定できるようにするオプションがあります。印刷時の既存の材料が最終的な色を決定するため、印刷されたパーツはGrabCAD Printでの視覚情報とは異なって見えます。このオプションは、「要約の印刷」ウィンドウで使用できます。
- 体の色を変えながら質感を保つ能力。以前は、テクスチャモデルに新しい色を適用すると、テクスチャが上書きされていました。これで、新しい色により、テクスチャの下のパーツのボディカラーが更新され、オーバーライドするオプションが追加されます。選択した「ベース&コアオプション」は、一致しない場合に色を上書きします。
- 多くの重いモデルでPolyJetジョブを印刷するための新しい最適化。重いモデルでトレイを埋めるときは、この機能を使用してモデルを自動的に最適化します。この機能は、品質やモデルの精度を失うことなく、モデルの複雑さを自動的に軽減します。
- 一部のPolyJetジョブの見積もりと印刷を妨げる最新のNVIDIAグラフィックスドライバーに問題があり、これは修正されました。
- スライスプレビューでスタビライザーと同じ色のスタビライザーが付いたモデルが表示される問題が修正されました。
GrabCAD Print バージョン 1.59、10月 2021
ビルド番号 1.59.11.12349 リリース日 25 10月 2021
- J55 Primeでは、使用可能な色が白黒のみである材料構成を設定する場合、新しいグレースケールスライダーを使用できます。さらに、テクスチャをロードするときは、白黒プロファイルを使用します。
- プロジェクトの保存時にモデルのボディの厚さへの変更が保存されなかった問題が修正されました。
- モデルに自立穴が含まれている場合に、プロジェクトのボディと面の設定が保存されない問題が修正されました。
GrabCAD Print バージョン 1.58、9月 2021
ビルド番号 1.58.9.11590 リリース日 23 9月 2021
- 「プロジェクト設定を保持」を使用すると、FDMプリンターのプロジェクトは、プロジェクトを同じタイプのプリンター(Stratasys F370からStratasys F370など)に切り替えるときに設定を保持できます。新しいプリンタと一致しない場合でも、現在の印刷設定を保持するか、新しいプリンタに基づいて設定を更新するかを選択できます。
- 「ボディアピアランス」を選択しても白い芯が印刷されるフルカラーのポリジェット印刷のバグを修正しました。コア設定が手動で変更された 1.56または 1.57に保存されたプロジェクトは再作成する必要があります。
GrabCAD Print バージョン 1.57、8月 2021
ビルド番号 1.57.8.10644 リリース日 19 8月 2021
- J55™の画期的なアップデートであるStratasys®J55™Primeのご紹介。 J55 Prime 3 Dプリンターは、フルカラー、触覚の再現性の高さ、機能的能力およびセンサー能力を導入し、PolyJetテクノロジーの効率と品質をこれまで以上に手頃な価格で提供し、オフィスで使いやすいものにしました。ラバーライクショア(Elastico™)、ハイインパクト(デジタルABS)、リジッドウルトラビジュアル(VeroUltra™、DraftGrey)、半透明(VeroUltra™ClearS)、および生体適合性(Vero™ContactClear)材料を組み合わせた最先端の印刷技術もご提供。コンパクトで静かな無臭のプロセスで、迅速な設計の反復的かつ実施から高品質の最終プロトタイプの作成まで、すべてを行います。新しいJ55プライム はこちらでご確認ください。
- Stratasys®J35™Proのご紹介。 J55™Prime回転トレイプラットフォームに基づくJ35™Proは、機能設計とコンセプトモデリングのためのマルチ材料機能を備えた共有オフィス環境に適した低コストのPolyJet 3 D印刷ソリューションです。新しい3 Dプリンターには、ラバーライクショア(Elastico™)、ハイインパクト(デジタルABS)、リジッドウルトラビジュアル(VeroUltra™、DraftGrey)、半透明(VeroUltra ™ClearS)および生体適合性(Vero™ContactClear)材料を組み合わせた最先端の印刷技術もご提供。コンパクトなプリンターサイズにより、オフィスに簡単に設置でき、ProAeroろ過システムにより、作業環境を完全に無臭に保ちます。新しい J35プロはこちらでご確認ください。
- 今回初めて、PrintのCADバージョンサポートの中間更新を行いました。
- スライスプレビューで、アンカーとスタビライザーの表示を制御できるようになりました。
- アンカーとスタビライザーは独自の色で表示されるため、モデルやサポートと簡単に区別できます。
- [表示]リストのオプションを使用してアンカーとスタビライザーの表示をオフにし、モデルの検査を容易にします。
- アンカーとスタビライザーの表示のオプションは、ジョブにこれらの機能が含まれている場合にのみ表示されます
- アンカーとスタビライザーの表示の設定は、次にスライスプレビューが入力されたときに記憶されます。
- さらに、レイヤーハイライトの色が透明な白になり、スライスのどの部分がモデル、サポート、アンカー、スタビライザーあるかがわかりやすくなりました。
- Digital Anatomy Printerの2つのアップデート:
- TissueMatrixとGelMatrixの混合物を利用して、6新しいプリセットを使用して超現実的な皮下脂肪組織モデルのすべてを印刷します。柔らかさが異なる主なモデルの特徴は、収縮性皮下脂肪(非常に柔らかい)と非常に収縮性の皮下脂肪(最も柔らかい)で、次のコーティングオプションがあります。
- 堅いコーティング–より耐久性のあるスタンドアロンモデルを作成するために2 mmのAgilusでコーティングされています。
- ソフトコーティング–スタンドアロンサンプルにリアルなソフトでぬるぬるした見た目と触感を与えるために、2 mmのAgilusとGelMatrixの混合物でコーティングされています。
- カプセル化されていない–脂肪組織が臓器モデルの一部として組み込まれるアプリケーションで使用するためにコーティングされていません。
- GelMatrix Enhanced Capabilitiesは、解剖学的モデリングオプションをより多く提供し、後処理は簡単かつ短時間で済みます。 Anatomy ModelSettingメニューで2つの新機能を検索してください。
- GelMatrixをサポート材料として使用してさまざまな解剖学的構造を印刷します
- 他の材料を使用せずに純粋なGelMatrix材料を使用して印刷する
GrabCAD Print バージョン 1.56、7月 2021
ビルド番号 1.56.11.9996 リリース日 20 7月 2021
- PolyJetモデル設定パネルに、プリセットと呼ばれるセクションが含まれるようになりました。色の選択専用のお気に入りのセクションがすでにありますが、プリ��ットには色と他のすべてのモデル設定が含まれています。トレイ上のパーツを右クリックして、プリセットを保存します。プリセットを追加したら、それを右クリックしてデフォルトとして設定できます。後でトレイに追加されたモデルには、プリセットが適用されます。
- J8シリーズPrimeの新機能:「OptimizeforPackaging」は、シンプルなワークフローでプロトタイプのパッケージングが素晴らしい外観となります。 RGBから印刷された色への透明度の最初の種類の変換を使用して-ユーザーは、液体や色付きガラスなどのボリュームの透明度がより正確となりまた。これに加えて、ラベルの後ろに自動の白いアンダープリントが作成され、不透明度の高いグラフィックの見栄えが良くなります。このオプションは、Vero Vividカラー、UltraWhite + UltraBlack、およびUltraClearを使用するフルカラーJ8プリンター、およびKeyshotの3 MFファイルで使用できます。 (この機能を有効にするには、print@grabcad.comに連絡してください。)
- アンカー機能の改善:
- モデルとトレイの間のアンカーの作成と編集を簡素化するために(最も頻繁な使用例)、アンカーペインを開くと、モデルビューは自動的に底面ビューに設定されます。
- アンカーが編集されていて、モデルビューが前面、背面、左、または右の場合、トレイは薄いプレビューに切り替わり、セット内のアンカーのプレビュージオメトリを簡単に検査できます。アンカーペインを閉じると、より厚いトレイビューが復元されます。
- T20Fモデルのヒントは、800StratasysF900およびFortus 450 mcプラットフォームのAntero NA、およびF900プラットフォームのAntero 840 CN03に追加されました。 T20Fモデルチップは、同等の部品品質と精度で、現在のT20Dモデルチップよりも最大20%改善された機械的性能を提供します。 T20Fモデルのヒントを使用するには、で 0.0100を選択します | T20F(0.2540 mm | サポートされいる材料を選択した後、[スライスの高さ]ドロップダウンメニューでT20F)。
- ファームウェアバージョン 4.11。0は、StratasysF900およびFortus 900 mcプリンターで使用できます。このアップデートは、標準のダウンロードされたアップグレード(.upg)ファイルを使用して利用することはできません。この重要なアップデートに関する情報は、サービス担当者またはStratasysカスタマーサポートにお問い合わせください。
GrabCAD Print バージョン 1.55、6月 2021
ビルド番号 1.55.8.8912 リリース日 16 6月 2021
- SpaceMouse 3 Dマウスが、GrabCAD Printでのビュー操作でサポートされるようになりました。これに関するチュートリアルはこちらをご覧ください。
- 冷却時にカールする可能性のある短く幅の広いモデルの場合、アンカー機能を使用すると、印刷中にモデルを造形トレイに固定できます。アアンカー機能とは、モデル材料で作られた柱で、モデルの水平な底面をビルドトレイに固定するものです。アンカーは円柱や円錐形で、個別に作成することも、スタイルと直径を共有するセットで作成することもできます。 アンカーの設定についてはこちらをご覧ください。(Stratasys F770, F370, F270, F170, F900, Fortus シリーズのプリンターでサポートされています。)
- スタビライザーを生成する前に、参照カーブを選択する必要があるようになりました。これにより、パネルを初めて開いたときにスタビライザーが即座に作成されるのを防ぎ、スタビライザーを作成する前に設定を調整することができます。
- J5MediJet™のご紹介。解剖学的モデル、手術ガイド、および滅菌可能で生体適合性のあるマテリアルを使用した医療用工具用に設計された、まったく新しいオールインワンの医療用プリンターです。 J5 MediJetは、医療用3D印刷アプリケーションの新しい標準を設定しています。複数のマテリアルとマルチカラー機能により、認定されたシステム上で、鮮やかで鮮やかな解剖学的モデル、ドリルおよびカッティングガイド、滅菌可能で生体適合性のある医療ツールを作成できます。さらに、経済的でコンパクトなサイズのため、小さなラボスペースにも対応できます。詳細はこちらをご覧ください。
- PolyJetプリンタの右側のメニューにある新しいツールを使用すると、[設定]で定義された単位を使用してトレイ上の正確な位置を設定できます。
- 注意:次のリリースでは、フルカラーのVeroPureWhiteを使用する場合、フルカラーJシリーズプリンターの高度なカラーハーフトーンがデフォルトで新しいトレイについてチェックされます。
GrabCAD Print バージョン 1.54、5月 2021
ビルド番号 1.54.6.7969 リリース日 18 5月 2021
- StratasysF770™3 Dプリンターは、市場で最長の完全加熱造形チャンバー(対角46インチ)を備えています。広々とした造形エンベロープは13立方フィート(372リットル)を超えており、小型のプリンターでは単純に利用できない製造、プロトタイピング、および製造部品アプリケーションの新しい機会を開きます。Stratasys F770の詳細については、こちらをご覧ください。
- 従来のサポートをあまり必要としない背の高い薄いモデル場合、新しいスタビライザー機能を使用すると、モデルの構築時に足場を追加できます。スタビライザーは、モデルの側面に一定の間隔で取り付けられる背の高いサポート構造であり、追加のサポートを提供し、振動を最小限に抑えます。 スタビライザーの構成の詳細については、こちらをご覧ください。 (Stratasys F770、F370、F270、F170、F900、およびFortusシリーズプリンターでサポートされています。)
- F123シリーズプリンタで[可変幅の塗りつぶしを使用する]チェックボックスが無効になっていた問題が修正されました。
- FDMモデルのキャッピングサーフェスで、次のツールパスの問題が修正されました。
- 小さなキャッピングサーフェスにおいて、必要なラスターインフィルの2倍が適用されなくなりました。
- キャッピング面の小さな穴が無視されなくなりました。
- 1.48で導入されたGrabCADLabs機能により、アセンブリのコンポーントにさまざまなPolyJet仕上げ(マットまたは光沢)を割り当てることができるようになりました。これはオプションではなくなり、いつでも利用できます。
GrabCAD Print バージョン 1.53、4月 2021
ビルド番号 1.53.15.7152 リリース日 20 4月 2021
- スライスプレビューを選択すると、レイヤー範囲のデフォルト値が「すべてのレイヤー」になります。レイヤー範囲への変更は、次にスライスプレビューが選択されたときに記憶されます。
- これらの新しい不透明なマテリアルにより、薄くてリアルなプラスチックモデルの印刷が可能になり、高精度の色域の拡大、パッケージラベルを印刷するためのシャープなテキスト、滑らかで高解像度の肌の色合いが実現します。
GrabCAD Print バージョン 1.52、3月 2021
ビルド番号 1.52.8.6136 リリース日 16 3月 2021
1.52更新に関するビデオについては、ここをクリックしてください。
- 炭素繊維強化ABSは、Stratasys F370、Stratasys F270、およびStratasysF170プリンターで使用できます。 Stratasys ABS-CF10は、標準のABS(アクリロニトリルブタジエンスチレン)マテリアルと10重量%のチョップドカーボンファイバーを組み合わせたものです。その結果、標準のABS 3 D印刷マテリアルよりも50%剛性が高く、15%強度以上の低水分感受性FDM®熱可塑性プラスチックが得られることになります。典型的なアプリケーションには、剛性の向上と軽量化の組み合わせから恩恵を受ける製造ツール、ジグ、フィクスチャ、エンドエフェクタが含まれます。 ABS-CF10は、 0.0070インチ(0.1778 mm)、0.0100インチ(0.2540 mm)、および 0.0130インチ(0.3302 mm)のスライス高さでサポートされています。新しいマテリアルであるABS-CF10については、こちらをご覧ください。
- J5 DentaJet™のご紹介です。J55プラットフォームをベースにしたJ5 DentaJet 3Dプリンターは、歯科用マルチマテリアル3Dプリンターの新製品で、技術者が歯科部品の混合トレイをセットすることができます。この新しい 3Dプリンターは、1つの混合トレイ上で、競合 3Dプリンターに比べて少なくとも5倍以上の歯科用パーツを生産することができますが、そのコンパクトな設置面積は、わずか 4.6平方ft(.43m2) に収まります。新製品J5 DentaJetはこちらからご覧いただけます。
- Antero 840 CN03で作られたサポート構造とモデル間のベースレイヤーとインターフェイスレイヤーが改善され、下向きのモデルサーフェスの品質が向上します。安定性を高めるためにサポート構造も変更されています。
- Diran 410MF07では、スライス高さ 0.0010インチ (0.2540 mm)、固体インフィルの最小ボディ厚さを 0.0200インチ (0.5080 mm)、デフォルトの自立角度を45度に変更するなど、印刷設定を更新し、モデル全体の印刷品質を向上させました。
- 新しい肝臓解剖学がデジタル解剖学プリンターで利用できるようになりました。4 異なる圧縮値を備えた肝臓の解剖学的構造の新しいプリセットは、すべて完全なバイオメカニカルレポートで利用可能なデータで検証されています。さまざまなコーティング層による、収縮性の高いものから中程度の硬さまでのバリエーションを実現しました。実施されたテストに関する詳細なデータはこちらをご覧ください。
GrabCAD Print バージョン 1.51、2月 2021
ビルド番号 1.51.18.5360 リリース日 22 2月 2021
1.51更新に関するビデオについては、ここをクリックしてください。
- SOLIDWORKS 2021、Inventor 2021、Creo 7などのほとんどのCADパッケージの最新バージョンからファイルを印刷できるようになりました。.GrabCADプリントバージョン 1.50, 1月 2021のサポートされているファイルの一覧はこちらをご覧ください。
- ラピッドプロトタイピング用に特別に構築された7マテリアルのPolyJetプリンターであるJ850Proのご紹介。 J850 Proは、J850 Prime(以前はJ850と呼ばれていました)と同じ造形ボリュームとマテリアル容量を備えていますが、J850 PrimeがCMFプロトタイピングに優れているのに対し、J850 ProはDigital ABS、Agilusフレキシブル素材、DraftGrey、スーパーハイスピードモードを備え、スピードとパフォーマンスを追求しています。J8シリーズの新しいラインナップはこちらからご覧いただけます。
- 新しい印刷概要ウィンドウは、設定、見積もり、遅延開始オプション、およびPolyJetジョブの「印刷」を押したときに表示する必要のある警告または通知を簡単にまとめます。
- モデルを解析モードで修復すると、シートボディやノイズシェルなど、体積がゼロのボディは自動的に非表示になります。これらのボディは解釈できず、推定または印刷エラーの原因となる可能性があるためです。
- トレイビューでのCMBファイルのグラフィック表現が改善されました。 CMBディスプレイは、モデルの実際の形状に関する詳細を提供します。以前は無視されていたポケットが識別され、表示されるようになりました。改善されたCMB表示により、ユーザーはCMB印刷の結果のモデルを理解するためにスライスプレビューを入力する必要がありません。
- GrabCAD Printのメニューバーとメニューは、Windowsテーマで設定されたものに従うように色が変わる場合があります。
GrabCAD Print バージョン 1.50、1月 2021
ビルド番号 1.50.14.4357 リリース日 19 1月 2021
- GrabCAD Printの更新が利用可能な場合、環境設定(バージョン 1.22で導入)によって、次にアプリを起動したときに更新が自動的にインストールされるかどうかが決まります。従来、デフォルトではオンでしたが、今ではこの設定はオフになっています。今後の更新は、「今すぐ更新」のボタンをクリックした場合にのみインストールされます。必要に応じて、「ファイル」> 「環境設定」> 「更新」で自動更新にオプトインできます。
- モデルロード時のクラッシュ検出で、モデルが重なっている状況を検出して警告することができるようになりました。PolyJetのプリンティングの場合、これは、パーツの優先順位を変更する必要がある場所を判断するのに役立ちます。注:クラッシュ検出はデフォルトではオフになっています。「環境設定」> 「モデル挿入設定」> 「アセンブリ内のクラッシュを自動的に検出」で有効にできます
- 平面構造のアセンブリをJシリーズプリンタに挿入すると、デフォルトの優先度がファイルリストにすぐに表示されるようになりました。従来は、パーツを表示するために、パーツの優先順位を変更する必要がありました。
- Jシリーズプリンタで白黒を使用する場合、既存のフルカラーの色選択ツールの代わりに、白黒カラープロファイルで動作するグレースケールスライダーが搭載されました。
- 従来は、Objet30 プリンターの新しい V5 バージョン専用だった DraftGrey が、V3 プリンターで使用できるようになりました(VeroGrey としてリスト)。こちらから詳細をご覧ください。さらに、この更新により、Vero 材料で高品質モードが有効になります。
- 1.49リリースでは、一部のConnexプリンタが誤ったグラフィックスドライバーバージョンを報告していました。この問題は 1.50リリースで修正されました
GrabCAD Print バージョン 1.49、12月 2020
ビルド番号 1.49.12.3309 リリース日 16 12月 2020
- Objet1000プリンタ用にJ4100アップグレードキットをご用意しています。このキットは、新しいプリントヘッド技術と最先端の材料製品で、Objet1000プリンタの機能を強化します。新しいプリントヘッドでは、モデルチャンネル(3)が追加され、処理能力と生産性が最大90%向上します。現在、Agilusファミリー、UltraClear、VeroPureWhiteなどの材料を提供しています。J4100のおかげで、デジタルABS(オーバーモールド)上に、柔軟な材料を造形できるようになりました。
- Jシリーズのユーザーの中には、ジョブが処理中に詰まってしまい、Jシリーズのプリンターに印刷できないという問題を抱えている人もいました。プリンターPCのグラフィックドライバーが古かったことが原因でしたが、GCPが問題を検出できていませんでした。この問題は修正されました。このような状況に直面した場合、ドライバーを更新するためのリンクを示すメッセージが表示されます。
- CMB関連のソフトウェア修正
- CMBエクスポートにパージパーツ/犠牲タワーを含める/除外するオプションを復活させました。
- CMBを含むトレイに、追加の犠牲タワーを含める機能を復活させました。
GrabCAD Print バージョン 1.48、11月 2020
ビルド番号 1.48.14.2323 リリース日 17 11月 2020
1.48更新に関するビデオについては、ここをクリックしてください。
GrabCAD Printが、Objet30デスクトッププリンタをサポートするようになりました。既存のObjet30V3プリンタ(Objet30、Objet30 Pro、またはObjet30 Primeとして知られています)に加えて、Objet30 V5ProおよびPrimeといった新世代が発売されています。V5モデルは、設置面積が小さく、最高の造形品質を誇ります。単色で使いやすいプリンタです。3DraftGreyを含むさまざまな13モデル材料、印刷モードおよび柔軟で生体適合性のある材料(Primeのみ)を提供します。Objet30でGrabCAD Printを使用するには、次のガイドに従う必要があります: GrabCAD Print用にPolyJetプリンタを設定する
基本スタイルオプションが、FDMプリンタの「サポート設定」パネルで使用できるようになりました
- モデルとサポート: モデルの下にベースが追加され、足元をサポートします。ベースが重なると、それらは共通ベースへと結合します。ベースが閉じたループを形成すると、ループが埋められ、大きくて安定したベースが作成されます。
- モデルのみ: ベースは、モデルの足元にのみ追加されます。サポートはトレイまで伸びており、ループは埋められません。
- ファイル > 環境設定 > GrabCAD Labsの新しいオプションでは、PolyJetプリンタ用のアセンブリで、ボディの仕上げをマットとグロスの間で混在させることができます。
- 新しい印刷モード「スーパー高速度」が、J826プリンタで利用できるようになりました。この新しいモードは、高速度モードの2倍の処理能力を発揮し、ラピッドコンセプトモデルの造形など、多くのアプリケーションで役立ちます。
- Stratasys F900およびFortus 0.0200mcモデラーでT40押出チップ(スライスの高さ0.5080インチ、900mm)を使用し、SR30またはSR35サポート材料とASAモデル材料を使用するジョブでは、層間剥離を防止するために、パーツの第1レイヤーの下のベースレイヤーのビルド特性を向上させました。
- Stratasys F900でT40モデルチップ(スライスの高さ0.0200インチ、0.5080mm)とASAモデル材料を使用したジョブでは、時間と体積の推定精度が向上しました。この変更は、新しい 4.10.0.システムファームウェアでの使用を目的としています。このファームウェア更新は、標準ダウンロードされたアップグレード(.upg)ファイルでは利用できませんのでご注意ください。この重要なシステムソフトウェアの更新に関する情報については、サービス担当者またはStratasysカスタマー・サポートにお問い合わせください。
GrabCAD Print バージョン 1.47、10月 2020
ビルド番号 1.47.20.1644 リリース日 20 10月 2020
1.47更新に関するビデオについては、ここをクリックしてください。
- Stratasys F370プリンタで、スライスの高さ 0.0100インチ(0.2540 mm)を使用すると、ABSとASAで上向きの表面の外観と面密度が向上します。
- 可変幅の残余ツールパスで充填するために、短くて薄い領域の検出を改善することにより、残余充填が向上しました。
- 表示の簡略化状態で異なるモデルを選択し、選択したすべてのモデルをフル解像度または簡略形式のいずれかに、グローバルに設定できるようになりました。
- SolidWorksで透明に設定されたテクスチャが、正しい透明度で、GrabCAD Printに正しくインポートされるようになりました。
- UltraclearSはアクリルをシミュレートし、その材料の光透過率を95%にすることができます。ガラス、透明ポリマー、透明パッケージの試作に役立ちます。VeroClearの性能を改良したVeroUltraClearは、より高い鮮明度、透明度、低い黄色度を実現しています。
- J55プリンタでも、サポートコアオプションが利用できるようになりました。サポートコア(以前は「ホロー」と呼ばれていました)を使用すれば、サポート材料からコアを造形できます。このオプションを使用する前に、「設定」> 「GrabCADLabs」で、この機能をオンにしてください。
- Digital Anatomy Printerの骨分割は、骨折を模倣するために骨モデルをセクションに分割したり、アプリケーションとは無関係なトレイ上の部品を削除したりすることができます。
- 以前は「材料の変更」ウィンドウ内にあった色とテクスチャプロファイルのオプションは、トレイ設定ツールパネルの「詳細」セクションに移動しました。
GrabCAD Print バージョン 1.46、9月 2020
ビルド番号 1.46.21.661 リリース日 15 9月 2020
ビルド番号 1.46.22.826 リリース日 18 9月 2020
1.46更新に関するビデオについては、ここをクリックしてください。
- 以前はPolyJetのモデル設定のチェックボックスだった「ホロ―」設定が、ベース&コアオプションの「サポート」オプションとして使用できるようになりました。さらに、バージョン 1.42でリリースされた「混合コア」設定が、デフォルトでオンになりました。
- Digital Anatomy Printerの新機能
- 骨のプレビュー — 骨の内部構造をスライスごとにプレビューして、その構造が意図したものに対応しているかどうかを確認できます。
- オープン/クローズエンド — 骨の内部構造に「ウィンドウ」を作成します。骨の平らな断面に印を付けてから、透明な材料でコーティングするか、そのままの状態にしておくかを選択できます。
- バージョン3でLabs機能として導入された 1.40MFファイルのサポートが、一般的に利用できるようになりました。
- 背景が透明なテクスチャを持つSOLIDWORKSファイルが、GrabCAD Printで正しくロードされるようになり、透明な背景を通してその下の外観が表示されるようになりました。
- Antero™840CN03が、Fortus 450mcでサポートされるようになりました。Antero 840CN03は、静電気放電(ESD)プロパティを持つStratasys® Antero 800NAのモデル材料のブレンドで、接触にセンシティブな電子部品やコンポーネントの製造アプリケーションに互換性があります。Antero 840CN03では、スライスの高さは0.010インチ(0.2540 mm)のみが利用可能です。この材料の詳細については、こちらをお読みください。
GrabCAD Print バージョン 1.45、8月 2020
ビルド番号 1.45.21.65369 リリース日 25 8月 2020
1.45更新に関するビデオについては、ここをクリックしてください。
- PolyJetの造形モードは、造形ジョブを準備するときに事前に選択できます。選択した造形モードで使用できる機能と設定のみが表示されるため、ジョブの準備が簡単になります。利用できない機能と設定は、選択した印刷モードに基づいて、利用できない理由の説明とともに無効化されます。
- FDMにアダプティブ・スライススタイルが登場!アダプティブ・スライススタイルは、詳細を必要とするパーツ(ドーム、フィレット、面取りなど)向けに選択したスライスの高さを使用し、垂直壁などの、詳細が不要なパーツ向けには、厚いスライスの高さを使用します。その結果、造形が速くなります(ジオメトリとスライスの高さに応じて、最大24%速くなります)。スライススタイルは、モデルのスライス方法を設定する新しいオプションです。詳細はこちらをご覧ください。
- 「ディスプレイ設定」> 「グラフィックの品質」の環境設定で、グラフィック表示に使用されるモデルに適用される簡略化のレベルを制御できるようになりました。注:造形されるモデルはフル解像度のままです。右クリックメニューオプションに「グラフィックス解像度」があります。これを使用すれば、選択したモデルの表示を簡易形式表示とフル解像度表示の間で切り替えることができます。
- アセンブリのロードステータス(アセンブリ済みまたはアセンブリ解除)を選択するために、すべてのファイルタイプに適用される設定があります。
GrabCAD Print バージョン 1.44、7月 2020
ビルド番号 1.44.22.64105 リリース日 22 7月 2020
1.44更新に関するビデオについては、ここをクリックしてください。
- モデルのデザインにベストマッチを提供するために、コア/ベースの割り当てをカスタマイズすることができます。
- J720プリンタのオートアレンジ機能は、部品のネスティングを改善し、生産効率を向上させます。
- バージョン 2.0より古いGrabCAD Printサーバーは、7月 21以降、GrabCADクラウドに接続できなくなります。GrabCAD Printサーバーを介してプリンタに接続し続けるには、古いバージョンを手動でアンインストールして、プリントサーバー 2.0をインストールしてください。こちらから最新バージョンをダウンロードしてください。
- GrabCAD Printサーバー 2.0は、Microsoft Windows 10(64ビット)およびWindows Server 2016以降でのみサポートされます。Microsoftのサポートを受けていない旧バージョンのWindows上で動作しているインスタンスは、7月 21以降自動更新されず、GrabCADクラウドにも接続できなくなります。プリントサーバーインスタンスのOSをアップグレードするか、サポートされているOSを搭載した機種にプリントサーバーをインストールする必要があります。
- GrabCAD Printは、システム全体(機器限定)のインストールに移行しています。あなたに影響がある場合は、更新が利用可能になった際に通知されます。移行に関して、(通常)あなたの側で何かをする必要はありません。v1.47以降、更新を引き続き受信するには、機器限定のインストールに移行する必要があります。
- GrabCAD Printで、プリンタからStratasysのサポート窓口に診断ファイルを送信できるようになりました。ハードウェア、材料、その他のプリンタ、ソフトウェアの問題に関しては、「ヘルプ」-> 「プリンタサポートの取得」に移動して、問題に関する詳細を追加してください。次に、GrabCAD Printは、すべての詳細と関連ファイルを含む電子メールテンプレートを生成します。これらのファイルは、販売時に提供された電子メールアドレスに送信することができます。
- 深い(マルチレベル)アセンブリ構造を持つ3MFファイルで、プロジェクトパネルにツリー構造全体が表示されるようになりました。
GrabCAD Print バージョン 1.43、6月 2020
ビルド番号 1.43.17.62943 リリース日 17 6月 2020
1.43更新に関するビデオについては、ここをクリックしてください。
- 高度なFDM機能がGrabCAD Printで利用できるようになったため、高度なFDMプロジェクトを作成する必要がなくなりました。「設定」メニューから「高度な FDM をアクティブ化」のオプションが削除され、新しい高度なFDMプロジェクトを作成するためのアクションが、左側のツールバーから削除されました。
- 高度なFDM機能が、コアGrabCAD Printに移行したため、高度なFDMで作成されたプロジェクトがGrabCAD Printで開くようになり、各モデルは別々のトレイに表示されます。グループは、ボディ設定、面の設定、トレイのプロパティ、方向、製造上の注意事項と同様に維持されます。
- スライスの失敗を防ぐために、VRML、OBJ、および3MFファイルを、印刷可能なオブジェクトに変換するアルゴリズムが書き直されました。
- 単色のVRMLのボディを選択すると、色選択ツールに直接色が表示されるようになり、微調整が可能になります。
- Digital Anatomy Printerの2つの新機能
- Long Bone Axis Toolで、長骨の近位部と遠位部を定義できます。これにより、さまざまな密度の部位を造形して、長骨の構造に近づけることができます。
- 複数の整形外科手術では、造形されたモデルに穴を開け、ネジを挿入する必要があります。このことにより、場合によっては、望ましくない亀裂が発生することがあります。Strain Relief Toolを使用すれば、ひび割れを含むように設計された境界線を設定することができるので、造形された部分のひび割れが広範囲に広がることを防ぐことができます。
- StratasysJ55をご紹介します。常に妥協を許しません。高速コンセプトモデルから高品質の高忠実度モデルまで、オフィス向けのJ55 3Dプリンタは、デザイナーの能力を最大化できる手頃なオプションです。詳細はこちらをご覧ください。
GrabCAD Print バージョン 1.42、5月 2020
ビルド番号 1.42.19.62279 リリース日 20 5月 2020
1.42更新に関するビデオについては、ここをクリックしてください。
- 新しいマニピュレーターを使用すれば、モデルの位置や方向をより簡単に設定することができます。ビューコントロールストリップの右端のボタンをクリックして有効化すると、選択したモデルに矢印が表示されます。これをクリック&ドラッグすれば、選択範囲を自由に移動・回転させたり、正確な軸に沿って移動・回転させることができます。
- FDMプリンタの場合は、アレンジツールパネルのスライダーを使用すれば、トレイ上のモデルの間隔を最小 0.2500インチ(6.35 mm)から最大 2.0000インチ(50.8 mm)まで調整できます。これにより、モデルをトレイ上でよりタイトに詰めたり、間隔を空けて空気の流れを改善することができます。
- 1.41に追加されたCMYKWとCMYWのカラープロファイルが、CMYKWとCMYWのビビッドな材料がプリンタにロードされた際のデフォルトのカラープロファイルになりました。プロファイル名は、X-Ritei1ProfilerCMYKWまたはCMYKです。
- 従来、 PolyJetパーツのコアは、黒と白の材料を交互に造形していましたが、「ファイル」> 「環境設定」> 「PolyJet」の新しい「混合コア」設定により、利用可能なあらゆる材料の混合でコアを造形できます。これにより、各プリントヘッドがより頻繁に使用されるようになるため、ノズルの目詰まりの問題が大幅に軽減されますが、ジョブを完了するには、ロードされた各材料カートリッジに十分な材料がなければいけません。
GrabCAD Print バージョン 1.41、4月 2020
ビルド番号 1.41.31.61723 リリース日 27 4月 2020
1.41更新に関するビデオについては、ここをクリックしてください。
- CADパッケージの最新バージョンが、GrabCAD Printでサポートされるようになりました。これには、SOLIDWORKS 2020、Inventor 2020、Creo 6.0などが含まれます。こちらで全リストをご覧になれます。
- Jシリーズプリントのサポートグリッドで使用する材料を変更して、より一般的に使用されている材料を保存できるようになりました。トレイ上のサポート構造は、すべて選択した材料で造形されます。材料の選択は、「トレイ設定」>「詳細」>「サポートの強化に使用される材料」で行うことができます。
- より高度なFDM機能を造形に取り入れるために、グループ内のボディに、さまざまな材料設定を適用できるようになりました。「グループ」を右クリックすると、次の操作を切り替えることができます:
- ボディを分離する — 他のボディや面とは独立した設定を、ボディや面に適用することができます。これは、高度なFDMの仕組みに似ています。
- 結合体 — グループ内のボディはすべて単一のボディとして機能し、1つのボディ設定がグループ全体に適用され、内側の境界が削除されます。これは、グループを作成せずに「アセンブリ済み」を選択した場合のアセンブリの通常の動作と似ています。
- アセンブリ済みのグループで「ボディを分離する」を選択すると、面タブの下のモデル設定パネルで、表面の厚さ、シームの配置、およびインサートが使用できるようになります。従来この機能は、高度FDMでのみ使用可能でした。
- FDMプリントでサポートを必要とする小さなパーツは、その作品の下で拡大するサポートを生成します。これが、「サポート拡大」設定で制御できるようになりました。デフォルトの「小さなサポート拡大のみ」から「サポートの拡大なし」または「すべてのサポートを拡大」に変更できます。サポートの拡大をオフにすると、パーツ材料の使用量と印刷時間の削減に役立つことがあります。
- 新しいVivid 2.0カラープロファイルが、GrabCAD Printに追加され、演色性が向上しました。デフォルトのカラープロファイルは変更されておらず、Vivid 1.1のままです。
- 面の色を使用したSOLIDWORKSアセンブリを、マルチボディパーツとして保存することなく、GrabCAD Printに直接ロードできるようになりました。
- FDMプリンタの場合、アセンブリ構造を持つ3MFファイルが、その構造とともにロードされるようになりました。
- スライダーのFDM設定を変更すると、デフォルト値を示す黒い菱形が表示されます。これをクリックするとデフォルト値に戻ります。
- GrabCAD Printのこのリリースでは、GrabCAD Shopで注文したファイルを、GrabCAD Printのトレイに簡単に開くことができます。これにより時間を節約し、電子メールやその他のリクエスト管理ソフトウェアからCADファイルをダウンロードする必要がなくなり、トレイを効率的に計画できます。まだ登録していない場合は、ここからGrabCAD Shopにサインアップしてください。
- 「IPで追加」入力ボックスが、GrabCAD Printサーバーに追加され、自動検出が利用できないプリンタに簡単に接続できるようになりました。
GrabCAD Print バージョン 1.40、3月 2020
ビルド番号 1.40.28.60898 リリース日 24 3月 2020
1.40更新に関するビデオについては、ここをクリックしてください。
- マルチボディファイルを含むSOLIDWORKSのパーツファイルに、PolyJetの造形に面レベルで適用されるカラーデータが含まれるようになりました。従来は、ボディレベルで適用された色のみが、GrabCAD Printに含まれていました。
- ユーザーが選択した色見本ツールを作成して、PolyJetプリンタの造形モデルに、色がどのように表示されるかをテストします。「アプリ」> 「カラー見本ツール」に移動して、色見本ツールにアクセスします。
- GrabCAD Printでは、コンピュータのGPUメモリ消費を最適化することで、より大きなPolyJetトレイをプリントできるようになりました。この機能は、「環境設定」> 「PolyJet」> 「重いトレイの最適化」で有効にできます。
- アドバンスドスライサーは、StratasysJ750およびStratasysJ735で使用できる唯一のスライサーになりました。従来のスライサーは、これらのプリンタでは使用できなくなりました。他のPolyJetプリンタに変更はありません。
- 独立型のInsightからGrabCAD Printにジョブを送信する場合、独立型バージョンは、GrabCAD Printで使用できるInsightバージョンと同じかそれ以降のバージョンである必要があります。そうでない場合、ジョブは送信されません。
- GrabCAD Printのコアコンポーネントを、最新バージョンにアップグレードしました。これにより、OneDriveフォルダーからのファイルの読み込みなど、いくつかの未解決の問題が修正されただけでなく、全体的なパォーマンスと起動時間が改善されました。
- GrabCAD Printで、多くのCADツールから3MF ファイルをインポートできるようになりました。SOLIDWORKSが作成した3MF ファイルの場合、これには面カラー、ボディーカラー、テクスチャが含まれます。PolyJetプリンタの場合、アセンブリは平面構造になり、FDMプリンタの場合はアセンブリ構造はありません。
- FDM固有の改善
- StratasysF370プリンタでTPU 92Aを使用する際の全体的なパーツ品質を向上させるために、可変幅の残余充填の幅範囲が縮小されました。
- Diran 55mf07の自立角度に対応するために、自立穴の角度が410度に拡大されました。
- 一部のモデルと方向によっては、不完全なサポートが生成される可能性があった問題を解決しました。
- GrabCAD Print 1.36で導入されたグループに割り当てられたデフォルトの名前を、ユーザーにとってより論理的な名前に変更できるようになりました。
GrabCAD Print バージョン 1.39、2月 2020
ビルド番号 1.39.14.59507 リリース日 18 2月 2020
1.39更新に関するビデオについては、ここをクリックしてください。
- 新しいPolyJetモデル設定パネルでは、デザインとユーザーのワークフローが改善され、材料と色のお気に入りを保存し、新しいCMYK入力機能を使用して独自の色とデジタル材料を作成できます。もっと詳しく知る ここに。
- スケールまたは方向が適用されたアセンブリからグループを作成する場合、新しく作成されたグループがアセンブリからこれらのプロパティを継承します。
- 切断されたプリンタをプリンタリストから削除できるようになりました。削除するプリンタを右クリックし、「プリンタの削除」を選択するだけです。
- マテリアルパネルにあるPolyJetプリンタの廃棄物コンテナのステータスを、より明確で直感的に視覚化できるようになりました。
- Advanced PolyJet Slicerについて: 3月の更新、GrabCAD造形バージョン 1.40では、J750およびJ735のAdvanced PolyJet Slicerを無効にするオプションは使用できなくなります。
GrabCAD Print バージョン 1.38、1月 2020
ビルド番号 1.38.21.59019 リリース日 28 1月 2020
1.38更新に関するビデオについては、ここをクリックしてください。
- PolyJetプリンタをお持ちの場合は、新しいモデル設定パネルをお試しください。デザインが改善され、お気に入りを保存できるようになりました。 [ファイル]> [設定]> [PolyJet]に移動し、チェックボックスをオンにして、新しいPolyJetモデル設定パネルを使用します。
- 1.36でJ850およびJ835に導入された新しいVeroUltraClearマテリアルは、J750およびJ735で利用可能になりました。 VeroUltraClearはアクリルをシミュレートし、その材料の95%の光透過率を達成し、ガラス、透明ポリマー、または透明包装のプロトタイプに有用です。 VeroUltraClearマテリアルの詳細はこちら。
- [モデル設定]パネルから新しい色とマテリアルの選択でVRML / OBJパーツをオーバーライドし、必要に応じて、選択したVRML / OBJボディの新しい右クリックニューオプションで元に戻すことができます。
- VRML / OBJ構造設定のデフォルト状態がオフからオンに変更されました。
- アドバンスドFDMのディラン410MF07のインフィルパターンには、シングルデンス、ダブルデンス、およびソリッドが含まれるようになりました。さらに、トレイの接着性を向上させるために、第1層の材料がサポートからモデル材料に変更されました。
- Stratasysプリンタの誤ったモデル名がスケジュールビューに表示される問題は解決されました。
GrabCAD Print バージョン 1.37、12月 2019
ビルド番号 1.37.15.57828 リリース日 18 12月 2019
1.37更新に関するビデオについては、ここをクリックしてください。
- バージョン 1.20で導入されたPolyJetプリンタの開始時間設定機能は、Advanced PolyJet Slicerでサポートされるようになりました。注:選択できるようにするには、プリンタを「アイドル」状態にする必要があります。
- 後処理用の新しいPolyJet造形設定により、研磨用の透明材料の薄い層を追加できます。透明レイヤーを研磨すると、滑らかな表面と忠実度の高い色とテクスチャを備えたモデルになります。
- 現在アクティブなトレイの製造ノートとモデルのスリーンショットを含むPDFトラベラー文書をプレビューして作成できるようになりました。
GrabCAD Print バージョン 1.36、11月 2019
ビルド番号 1.36.17.57117 リリース日 20 11月 2019
1.36更新に関するビデオについては、ここをクリックしてください。
- 新しいJ750™Digital Anatomy™3Dプリンタがサポートされるようになりました。これには、医療機器メーカー、世界クラスの研究機関、病院、医療関係者と共同で開発した一連の解剖学的アプリケーションが事前にプログラムされています。正確かつ現実的で機能的なプログラムで、実物の感触、動作、および寸法を実現できます。 J750 Digital Anatomy 3Dプリンタの詳細はこちら。
- 新しいJ850およびJ835がサポートされるようになりました。デザインと創造性に制限はありません。現在、Stratasys J850 / J835では、プロトタイプにも同じことが言えます。試行錯誤されたテクノロジーにより、設計プロセス全体が簡素化され、ワークフローが合理化されるため、可能な限り最高の製品の作成、改良、設計に時間をかけることができます。 Stratasys J850の詳細はこちら。
- 選択したモデルは、プロジェクトパネルの上部にある新しいボタンまたはマウスの右ボタンコマンドを使用してグループ化できるようになりました。新しいグループが作成されると、既存のアセンブリが折りたたまれて非表示になります。新しいグループは、アセンブルまたはディスアセンブルに設定できます。元のアセンブリから追加のグループを作成できます。
- PolyJet Advanced Slicerの設定には、VRMLおよびOBJファイルのアセンブリ構造を表示するための新しいオプションがあります。このオプションを有効にすると、GrabCAD PrintはVRMLまたはOBJファイルの幾何学的構造を決定し、構造をプロジェクトパネルにボディのアセンブリとして表示します。各ボディは、マルチカラー(テクスチャ、頂点カラー、フェイスカラー、または複数の異なる色のシートで構成される)またはシングルカラー(つまり、ボディ内のすべてのシートが単一の拡散色を共有する)にすることができます。ユーザーは、このようなアセンブリ内の任意の単色ボディのマテリアル割り当てを変更できます。
- SOLIDWORKSファイル(.sldprtまたは.sldasm)をインポートする場合、SOLIDWORKSボディにアタチされた透明度属性は、透明素材がロードされると、PolyJet素材パネルのアルファ値に自動的に変換されます。
- ライセンスを必要とするStratasysおよびFortusプリンタのマテリアルライセンスは、GrabCAD Printから更新できます。マテリアルライセンスを更新するには、ユーザーにローカル管理者権限が必要です。
- プロジェクトパネルは、使いやすさを改善するために再設計されました。変更には、アイコンの再設計、配置の改善、選択の強調表示の明確化、アセンブル/ディスアセンブル状態のチェックボックスの代わりのプルダウン、および表示/非表示状態の明確な表示が含まれます。
- 面の接線選択は、造形が面選択モードのときにマウスの右ボタンコマンドとして使用できるようになりました。これは、表面のチェーンに製造ノートを追加するときに役立ちます。
- ボディとフェースには、製造ノートと呼ばれる注釈を追加できます。メモを追加するコマンドは、マウスの右ボタンで使用できます。これにより、クリックでアクティブになり、メモを表示して編集できるようにするコールアウトが追加されます。
- Stratasys J850およびStratasys J835 3Dプリンター用の新しいVeroUltraClearマテリアル。 VeroUltraClearはアクリルをシミュレートし、その材料の95%の光透過率を達成し、ガラス、透明ポリマー、または透明包装のプロトタイプに役立ちます。 VeroUltraClearマテリアルの詳細は こちらをお読みください。
- ABS ESD7は、GrabCAD PrintのStratasys F370プリンタでサポートされるようになりました。 ABS ESD7は、静電気に敏感な用途向けに設計されたツール材料で、粉体、ほこり、微粒子などの他の材料への放電や引き付けを防ぎます。 ABS ESD7材料の詳細はこちら。
GrabCAD Print バージョン 1.35、10月 2019
ビルド番号 1.35.21.56592 リリース日 24 10月 2019
1.35更新に関するビデオについては、ここをクリックしてください。
- PolyJetプリンタにジョブマネージャの更新が必要な場合の[造形]ボタンとプリンタリストの両方の動作を改善しました。造形ボタンにポップアップが表示され、プリンタリストをクリックすると、アップグレードを実行できる[設定]画面に直接移動します。
- シリーズプリンタのUVランプを制御するために、[トレイ設定]の[詳細設定]セクションにチェックボックスが追加されました。造形物に露出過剰の問題がある場合は、販売店またはStratasysのテクニカルサポートに相談して、この設定が役立つかどうかを確認してください。
- JシリーズプリンターでPantoneカラーを使用して印刷する場合、VeroBlackPlusが必要なのは一部のカラーのみです。以前は、Pantoneカラーピッカー全体が読み込まれていないと無効になっていましたが、今は特定の色のみが無効になります。 Pantoneには、引き続き3つのVivid VeroマテリアルとVeroPureWhiteがすべて必要です。
- モデルの読み込みはキャンセル可能なアクションになりました。以前は、間違えて間違ったファイルを選択した場合、削除する前にロードされるのを待つ必要がありましたが、すぐにキャンセルできるようになりました。
- Advanced FDMで特定の面に設定を適用する場合、右クリックメニューから設定を削除できるようになりました。以前は、[元に戻す]を使用して面の設定を元に戻す必要がありました。
- 新しいFDM材料のサポート:
- TPU 92A Stratasys F370プリンタで 0.0070インチ(0.1778 mm)スライスをサポートするようになりました。 0.0070スライスおよび 0.0100インチ(0.2540 mm)スライスの造形品質が向上しました。これらの改善を利用するには、F123 Controller Softwareをバージョン 2.1にアップグレードする必要があります。
- プリンタ履歴を削除するには、ユーザーにローカル管理者権限が必要になりました。
GrabCAD Print バージョン 1.34、9月 2019
ビルド番号 1.34.16.55783 リリース日 19 9月 2019
1.34更新に関するビデオについては、ここをクリックしてください。
- 1.31のオプションとして導入されたPolyJet Advanced Slicerは、デフォルトでオンになりました。推定の精度が向上し、ここにリストされているいくつかの機能が有効になります。何らかの理由で古いスライサーを使用する必要がある場合は、[設定]> PolyJetからオフにすることができます。
- これで、選択したプリンタに関連するGrabCAD PrintのヘルプメニューのGrabCADチュートリアルとサンプルファイルにアクセスできます。当社のアプリケーションエンジニアは、新しいコンテンツを絶えず追加して、お客様の機器の活用を支援しています。コンテンツは[ヘルプ]メニューから利用できます。
- 「Preview Supported Surfaces」というラベルの付いたビューバーのトグルを使用すると、モデルのどこでサポートが生成されるかをすばやく確認できます。この機能は 1.24のPolyJetプリンターに導入され、FDMプリンターでも使用できるようになりました。これにより、方向とサポート設定(自立角度など)が印刷物の表面にどのように影響するかが示されるため、FDMスライスプレビューに代わる高速な代替手段となり、トレイの準備に役立ちます。
- スケジュールビューまたはGrabCAD Printモバイルアプリで進行中のPolyJetジョブを表示している場合、予測される「終了時刻」の精度が大幅に向上しました。予測は、ジョブ全体を通じて定期的に更新され、造形の一時停止や初期推定のその他のエラーに対応します。
- PolyJetトレイ設定パネルでスライス遅延オプションをチェックすると、モデルでのくぼみの発生が減少します。このオプションは、Strataysのテクニカルサポートに相談した後にのみ使用してください。このオプションを使用すると、ジョブの造形時間が長くなります。
- PolyJetプリンタの[トレイ設定]パネルに表示される材料のリストに、サポートマテリアルが含まれるようになりました。
- GrabCAD Printは、F123シリーズやJ750などの一部のプリンタの更新について通知します。これらには、新しい教材、学習コンテンツなどに関する情報が含まれる場合があります。これらのプリンタのいずれかが選択され、更新が利用可能になると、画面の左下にギフトボックスが表示されます。
GrabCAD Print バージョン 1.33、8月 2019
ビルド番号 1.33.10.54793 リリース日 20 8月 2019
1.33更新に関するビデオについては、ここをクリックしてください。
- Advanced FDMでサポートされているプリンタでは、一部の高度な機能が[モデル設定]タブで利用できるようになりました。これには、インフィル密度、インフィル角度、およびボディの厚さが含まれます。CADファイルを使用する場合、円筒形の穴を自己支持型のダイアモンドに変更できます。
- 前回のアップデートでFDM設定パネルに加えられた変更と同様に、PolyJet設定パネルは、トレイ設定とモデル設定に分割され、今後のアップデートでより多くの機能を使用できるようになりました。
- パージ部分または犠牲タワーなしでCMBをエクスポートすることを選択できるようになりました。これにより、ジョブで複数のCMBファイルを造形するときに、複数のパージパーツが造形されるのを防ぐことができます。デフォルトでは、パージパーツ/犠牲タワーが含まれています。
- Stratasys F900、Fortus 900mc、およびFortus 400mcプリンタテンプレートの場合、ABSがデフォルトの材料になりました。ライブプリンタの場合、材料はデフォルトとして現在の構成を引き続き使用します。
- J750およびJ735ユーザーの方へ: 1.31で導入されたAdvanced Slicerは、来月のアップグレードバージョン 1.34でデフォルトで* ON *になります。
GrabCAD Print バージョン 1.32、7月 2019
ビルド番号 1.32.19.54065 リリース日 22 7月 2019
1.32更新に関するビデオについては、ここをクリックしてください。
- FDM造形準備の造形設定パネルは、トレイ設定、モデル設定、サポート設定の3パネルに分割されました。新しいアイコンも追加されました。
- 分析モードでは、頂点色を使用してVRMLおよびOBJファイルを修復できるようになり、面の色とテクスチャを含むファイルの修復が改善されました。
- J750およびJ735ユーザーは、VividマテリアルとAdvanced Slicerを使用して不透明モデルを造形できるようになりました。 [造形設定]パネルの[半透明]チェックボックスをオフにして、白いコアでボディを造形します。現在、これはテクスチャ化されていないメッシュファイル/アセンブリに対してのみ機能します。
- 一部のFortusおよびF123ジョブの問題は、パージパーツ/犠牲タワーに奇妙な動作を引き起こし、造形の失敗につながりました。これは解決されました。
- Agilus 30 Clearを選択すると、設定したShore A値に関連付けられた透明度レベルでモデルが表示されます。
GrabCAD Print バージョン 1.31、6月 2019
ビルド番号 1.31.52720.53058 リリース日 20 6月 2019
1.31更新に関するビデオについては、ここをクリックしてください。
- F900、F370、およびFortusプリンタ用に 1.24で導入されたAdvanced FDMは、F170およびF270で利用可能になりました。 Advanced FDMを使用すると、実際のCADジオメトリを使用してモデルのさまざまなセクションのインフィルをカスタマイズしたり、造形可能なように穴の配置を変更したりできます。 詳細はこちら。
- [ファイル]> [設定]> Polyjetで利用できるAdvanced Slicerは、J750およびJ735ユーザーに多くの改善と新機能を提供します。
- Pantone®はカラーピッカーで色を検証しました。
- テクスチャに透明性があるVRMLは、クリアコアを使用します。
- 小さな機能とテキストの推定と造形の精度が向上しました。
- 穴のある垂直の壁の「サポートシャドウ」効果を修正するカスタムサポートオプション。
- アセンブリコンポーネントが重複する場合のカスタムパーツの優先順位。
- トレイ上のパーツ配置を完全に制御します。
- GrabCAD Print Serverの新しいバージョンはWindowsサービスとして実装され、Windowsユーザーがログアウトしても実装され続けます。さらに、Windows Server 2012と互換性があり、GrabCAD Printのマシンごとのバージョンと一緒にインストールできます。このアップグレードは自動ではありません。こちらで新しいバージョン (here)をダウンロードする必要があります。インストールのサポートについては、 ここをクリックしてください 。
- 分析モードで、テクスチャ付きVRMLファイルのメッシュエラーを修復できるようになりました。
- Inventor 2020など、まだサポートされていないCADパッケージからモデルを追加しようとする時のエラーメッセージは一般的な障害よりも有益です。
- FDMプリンタの場合、パーツ表面の角度が指定値(自己支持角度)を下回るとサポートが生成され、その値は[造形設定]パネルで調整可能になりました。生成されるサポートの量を増減したり、プリンタや材料によって異なるデフォルトの推奨値に戻したりすることができます。
- 現在のGrabCAD Printプロジェクトのファイルまたは設定と一致しないCADまたはCMBファイルを追加すると、エラーではなく競合が発生します。新しい警告により、変更を保存して新しいプロジェクトを開くことができます。
GrabCAD Print バージョン 1.30、5月 2019
ビルド番号 1.30.28.52238 リリース日 22 5月 2019
1.30アップデートに関するビデオを見るには、ここをクリックしてください。
- プリンタ履歴は、GrabCAD造形アプリケーションのプリンタ履歴ページから削除できます。このオプションは設定により有効になります。この設定は、GrabCADセッションに対してのみアクティブです。履歴が削除されると、プリンタはアイドル状態になりますが、キューにジョブがある場合があります。
- GrabCAD Printで翻訳を確認し、6の場所でエラーを修正しました。
GrabCAD Print バージョン 1.29、4月 2019
ビルド番号 1.29.6.51061 リリース日 16 4月 2019
1.29更新に関するビデオについては、ここをクリックしてください。
- CADパッケージの最新バージョンがGrabCAD Printでサポートされるようになりました。これには、SOLIDWORKS 2019、Inventor 2019、Creo 5.0、NX 12.0などが含まれます。 詳細はこちら。
- 新しいプリンタパネルでプリンタに簡単にアクセスできます。これには、お気に入りのプリンタ、高度な検索とフィルタリング、およびその他の多くの改善機能があります。是非、あなたのフィードバックを送ってください! [ファイル]> [設定]> [GrabCAD Labs]からオンにし、ご意見をお聞かせください。
- Stratasys F123シリーズの最新メンバーであるF120のベータリリースは、GrabCAD Printでサポートされています。 詳細はこちら。
- SMART、Sparse、またはBoxサポートスタイルを選択すると、FDM印刷のサポート構造でモデルマテリアルを使用できるようになりました。プリンターがモデルとサポート素材を切り替えるのに数秒かかるため、この機能により、ジョブの多くのレイヤーがモデルマテリアルのみを使用できるようになり、印刷時間を節約できます。
- Insightモデルは、ボタンをクリックするだけでInsightからGrabCAD Printに送信できるようになりました。 Insightツールバーの「GrabCAD Printでジョブを構築」アイコンを選択すると、CMBファイルが作成され、InsightからGrabCAD Printにファイルが渡され、正しいプリンタタイプが自動的に選択されます。
GrabCAD Print バージョン 1.28、3月 2019
ビルド番号 1.28.16.50383 リリース日 21 3月 2019
1.28更新に関するビデオについては、ここをクリックしてください。
- より多くのパーツを造形する技術や能力が不足していますか? [アプリ]> [Stratasys Direct Manufacturingで自分のパーツを作成]に移動して、SDMホームページにアクセスしましょう。 (米国/カナダのお客様のみ。)
- [高度なFDM]タブで自動方向付けが利用可能になりました。サポートを最小限に抑え、ビルド時間を短縮するために、標準ボディと結合ボディの両方を自動指向にすることができます。
- イメージテクスチャを含むOBJファイルがサポートされるようになりました。 PolyJetプリンタで造形する場合、OBJファイルに関連付けられた画像テクスチャファイルが読み取られて表示され、合併された結果が造形されます。
- F123シリーズプリンタで六角形のインフィルを使用する場合のパーツの品質の問題が修正されました。材料F123 ASAおよびF123 ABSの場合、 0.005インチ(0.127 mm)および 0.007インチ(0.178 mm)スライスの高さでは、インフィル量を減らして過剰充填を防ぎます。
- 造形設定、方向、スケールパネルが更新され、アクティブトレイ上のモデルまたはボディのみがカウントされるようになりました。
- プリンタの履歴にバグがあり、デスクトップアプリからエクスポートすると、「期間」がすべてのジョブに対して00:00:00を示していました。これは修正されました。
- アプリは一時ディレクトリにいくつかのファイルを生成しますが、以前は時間とともに蓄積されていました。現在は、アプリを閉じると自動的にクリアされます。
- 一部のユーザーは、GrabCAD Printを起動できず、「インスタンスが多すぎます...」エラーが表示されるバグを見つけていました。これは、GrabCAD Print for SOLIDWORKSアドインが現在廃止されていることが原因です。
GrabCAD Print バージョン 1.27、2月 2019
ビルド番号 1.27.17.49710 リリース日 25 2月 2019
1.27更新に関するビデオについては、ここをクリックしてください。
- F123シリーズおよびFortus 900mcの 1.24で導入された可変幅の塗りつぶしは、Fortus 380mc、380mc CFE、および450mcで利用可能になりました。この機能には、プリンタファームウェアのバージョン 6.1が必要です(13 3月 2019以降で利用可能)。こちらの指示に従って機器のファームウェアを更新します。
- FDMプリンタで造形するCMBファイルをインポートすると、正しいプリンタが自動的に選択されます。さらに、そのモデルを、Z軸を中心に回転させることができます。
- VeroやVeroFlexなどのPolyJet造形ジョブ、またはDigital ABS用の2つのRGD材料のうちの1つのみを使用するなど、特定の材料の組み合わせは許可されていません。以前は、このサポートされていない組み合わせの材料がプリンタにロードされていると、ジョブ自体がサポートされていない組み合わせを使用するものでなくても、プリンタはエラー状態で表示され、造形は無効になりました。サポートされていない組み合わせがジョブで使用されていない限り、ユーザーは現在プリンタにロードされている材料に関係なく、ジョブを造形できます。
GrabCAD Print バージョン 1.26、1月 2019
ビルド番号 1.26.13.48725 リリース日 28 1月 2019
- 造形設定パネルの一部としてGrabCADの造形 1.24で導入された可変幅のインフィルがAdvanced FDMで利用可能になりました。
- 手動で移動することもできますが、パージ部分(F123シリーズ)と犠牲タワー(一部のFortusプリンタ)は自動的にトレイ上の最適な位置に配置されます。これを行うと、[トレイの配置]または[プロジェクトの配置]ツールを使用するまでその場所に残ります。右クリックして[Locate Automatically]を選択すると、パージ部分/犠牲タワーだけを移動することもできます。
- GrabCADの造形およびAdvanced FDMで向きをリセットできるようになりました。モデルを選択してリセットを選択すると、モデルが最初にトレイに追加されたときのモデルの向きに戻ります。
- 特定の状況でGrabCADプリントのインストールをブロックする問題に対処しました。まだインストールの問題がある場合は、print@grabcad.comまでお問い合わせください。
GrabCAD Print バージョン 1.25、12月 2018
ビルド番号 1.25.17.47934 リリース日 4 1月 2019
- 1.16のベータテスト用にリリースされた機器ごとのインストーラーは現在print.grabcad.comから一般に入手可能です。現在のユーザーごとのインストーラーよりもはるかに安定していることに加えて、ITシステム管理者による学校や会社組織での展開が可能になります。切り替えの詳細および手順については、 ヘルプ説明をご覧ください。
- PolyJetテクノロジーに造形する前にGrabCAD Printで、自己交差、水密/開放面の問題、逆法線を含むOBJおよびVRMLファイルを修復できるようになりました。試用については、 print@grabcad.comに連絡してください 。
- [造形設定]パネルのツールのヒントでは、可変幅のインフィルの動き、パーツ構成スタイル、パージパーツまたは犠牲タワーの種類、システムモード、および最初のレイヤーの材料について説明します。ヒントの内容は、アクションに使用可能なオプションの内容のみを表示するようになっています。
GrabCAD Print バージョン 1.24、11月 2018
ビルド番号 1.24.15.46944 リリース日 20 11月 2018
- GrabCAD Print Advanced FDM は、FDMの ビルド属性を自動的に制御することによって、希望するパート特性を取得するための強力で直感的なツールセットを提供します。CADファイルのジオメトリに属性を割り当てることで、強度と剛性の領域を指定し、インフィルを制御し、インサートのある穴の周りに十分な材料を確保し、継ぎ目を避けることができます。個々のレイヤーを手作業で操作することなく、必要なすべてのツールパスが自動的に計算されるため、最終的にパート全体の品質を向上させながらジョブの準備にかかる時間が短縮されます。Advanced FDMは、[ファイル]>[環境設定]>[FDM]にて、一部のプリンタ(F370、380mc、380mc CFE、400mc、450mc、900mc、およびF900)で使用できます。
- OBJファイルは、PolyJet造形用の色、関連付けられた.mtlファイル、およびビジュアルテクスチャを使用してGrabCAD造形に追加できます。この機能は、ファイル>設定> GrabCAD Labsで有効になります。サポート内容を知るためには、こちらをご覧ください。
- 新しく追加された材料は、VeroCyan Vivid、J750 / J735ではVeroFlex Cyan / Magenta / Yellow Vivid、Agilus 30 White、Connex3ではMedABS、Med615、F900ではAntero 800NAを含むGrabCADプリントでサポートされており、すべての新しい柔軟な材料はFDM TPU 92Aと呼ばれるF123シリーズにサポートされています。 Connex3とJ750 / J735の新しい材料には、組み込みソフトウェアの更新が必要です。
- PolyJetプリンタを選択すると、3Dビューアの上にあるボタンの最上列に新しい表示モードを使用できるようになり、ユーザーはモデルの表面のどこにサポート材料が配置されるかを確認できます。これは光沢仕上げの境界を決定します。
- 一部のFDMプリンタは、内部パーツの作成に可変幅の塗りつぶしを使用するためのオプション設定を提供します。設定すると、可変幅ツールパスは、デフォルト幅より小さく、指定されたチップサイズの最小幅より大きいデフォルト幅ツールパスの間にギャップが残っている場所に自動的に配置されます。これは、最新のファームウェアアップデートのインストール後のF123シリーズ、F900、およびFortus 900mc(それぞれバージョン 1.8および 3.26以降)でサポートされています。
- スケジュールビューのジョブ詳細パネルが更新され、選択したジョブに使用されると推定される資料の量が視覚的に示されます。ツールチップは、作業完了時にキャニスターまたはカートリッジに残っていると推定され材料の量をユーザーに示します。 FDMの場合、最初にキューに入れられたジョブは、ジョブの開始時にキャニスター/カートリッジ上にある材料の量を示します。
- スケジュールビューのジョブ詳細パネルに、FDMプリンタのジョブに必要なチップサイズと造形解像度が一覧表示されます。これは、ユーザーがジョブに必要なものと現在プリンタに何がロードされているのかを確認するのに役立ちます。
GrabCAD Print バージョン 1.23、10月 2018
ビルド番号 1.23.20.45529 リリース日 17 10月 2018
- 履歴レポートにいくつかの改善があります。
- Job Historyのエクスポートは、.XLSXと.CSVの両方のフォーマットで利用可能になりました。.XLSXがデフォルトです。
- 造形時間とウォームアップおよびジョブの間に費やされた他の時間とを区別するために、「期間」列は、開始から終了までの合計経過時間である「合計ジョブ時間」と、プリンタが一時停止またはウォームアップ中である時間を除いた「合計造形時間」に分割されました。
- 履歴ビューの新しい列に、ジョブ内のパーツのリストが表示されます。同じパーツの数量は、パーツ名の後に(#)を付けて表示されます。たとえば、「HingePin(3)」のようになります。現在この機能はFDMプリンタでのみ利用可能です。 (注意: GrabCAD Print 1.22で造形されたジョブには、暗号化されたパーツ名が表示されます。)
- FDMプリンタの場合、エクスポートされたジョブ履歴に、サポートとモデルチップサイズの2つの列が含まれるようになりました。
- 部位は、Fortus 450mcプリンタで、ULTEM™9085を使用して013インチ解像度で印刷できます。
- 設定されている材料特性に応じて、モデルはマットまたは光沢のいずれかで表示されます。
GrabCAD Print バージョン 1.22、9月 2018
ビルド番号 1.22.24.44746 リリース日 26 9月 2018
- GrabCADプリントの自動更新を無効にする新しい設定オプションがあります。アップデートが利用可能になったときには通知されます。
- CADファイルのインポートをより正確にするための新しい設定オプションがあります。これにより、CADファイルを表すメッシュにより多くの三角形が追加されます。ただし、これはパフォーマンスに影響します。
- 今回のリリースでは、プリンタがGrabCADプリントに接続する方法に関する特定の問題(アップデート後に表示されなくなるプリンタリストを含む)が修正され、将来の潜在的な接続問題に対処するエラーレポートが改善されました。
- モデルは、すべてのFDMプリンターに対して自動指向できるようになりました。これにより、モデルのサポートマテリアルが最も少なくなります。
- .005”解像度を使用する場合、ABSとASAの両方のF123プリンタのベースレイヤとしてサポート材料を使用してジョブを造形できるようになりました。これによりトレイの接着力の問題のリスクが高まりますが、小さなパーツをより簡単に取り外すことができます。
- 倍密度インフィルが使用可能なFDMプリンターでは、ヘキサグラムインフィルスタイルがオプションになりました。このパターンは非常に強く効率的に構築できます。
- 営業時間と造形開始の遅延により、実際にはそうではないのにスケジュールビューではキューが空のように見えることがあります。そのため、キューに入っているジョブを見るために右にスクロールする必要があるときに新しいボタンが表示されます。
- スケジュールビューで現在造形中のジョブをクリックすると、ジョブの完了時に残っている材料の量の概算が表示されます。また、FDMプリンタの場合は、次の作業の出発材料レベルの見積もりも確認できます。
- 継ぎ目(ツールパスがFDMプリンタの開始位置と終了位置)がスライスプレビューに表示されるようになりました。
- Antero 800NA 450mcプリンタを使用してパーツを造形すことができます。
GrabCAD Print バージョン 1.20、7月 2018
ビルド番号 1.20.50.42688 リリース日 18 7月 2018
- PolyJetプリンタに、開始時間設定が可能となりました。PolyJetプリンタがアイドル状態で、キューが空の場合、プリントボタンを押した後、指定した時刻にプリントが開始されるようにスケジューリングできるようになりました。この機能は、GrabCADプリントサーバー経由でプリンタにリモート接続されている場合は、まだ使用できません。
- スケジュールビューで、F123シリーズプリンタのカメラ画像上のボタンをクリックすると、フル解像度で拡大表示されます。すべてのプリンタのジョブプレビュー画像に同じ機能を使用できます。
- 3ヶ月のテストの後、Connex3システムはGrabCAD Printによって完全にサポートされています。開始するには、セットアップガイドをご覧ください。
- GrabCAD Printは、新しいFortus 380mc Carbon Fiber Editionプリンタをサポートするようになりました。
- GrabCAD Printのログインセッションは、2ヶ月間使用しないと期限切れになります。以前の有効期限は1週間でした。
- PolyJetプリンターに新しいVivid Veroマテリアルを購入すると、GrabCAD Printで選択できるようになります。
GrabCAD Print バージョン 1.19、6月 2018
ビルド番号 1.19.14.41748 リリース日 15 6月 2018
- プリントをクリックしてPolyJetプリンタにジョブを送信すると、プリンタに十分なマテリアルが読み込まれていない場合や、ゴミ箱がいっぱいになった場合に警告が表示されます。
- 多数の重複ファイルを含むジョブは、以前より速く処理されます。さらに、複合またはマルチボディのVRMLファイルのファイル読み込み時間が60-80%向上しました。
- GrabCAD Print Serverを使用してプリンタにローカルまたはリモートで接続しているかどうかに関わらず、プリンタ設定ファイルをエクスポートできるようになりました。
- GrabCAD Printは、新しいStratasys F900システムタイプをサポートするようになりました。 Stratasys F900は、Fortus 900mcシステムの代替品であり、アップグレードされた水分制御システムと一般的なシステム拡張が含まれています。
GrabCAD Print バージョン 1.18、5月 2018
ビルド番号 1.18.19.40241 リリース日 10 5月 2018
- PolyJetユーザーのためのいくつかの拡張機能:
- 造形設定用の新しいコピー&ペースト機能。
- トレイの検証、見積もり、キューイングの進行バー。
- 複製された重いSTLを印刷するためのスライサーの安定性を改善しました。
- Agilusの材料は、SUP706Bサポート材料で造形できるようになりました。新しい組み合わせ式(706Bとも呼ばれます)を受け取った場合にのみ、この組み合わせを使用してください。
- SOLIDWORKSのGrabCADプリントアドイン SOLIDWORKS 2018でサポートされました。 GrabCAD Print 1.18に更新した後、コントロールパネルでインストールを変更してアドインをインストールします。
GrabCAD Print バージョン 1.17、4月 2018
ビルド番号 1.17.14.39209 リリース日 12 4月 2018
- Connex3 Systems(Objet260、Objet350、Objet500を含む)のサポートはすぐに開始される予定ですので、今すぐパブリックベータテストに参加できます!また、今すぐダウンロードできる最新の組み込みソフトウェアアップデートをインストールしてください。正式なベータ契約に署名する必要はなく、ただ、こちらに移動すれば、ダウンロードリンクと完全な説明を取得できます。
- PolyJet トレイのトレイ見積りに、実際の進捗バーが表示されるようになりました。
- カラーとテクスチャのプロファイルは、PolyJetプリンタのトレイの材質を変更したときにデフォルトに戻り、ユーザーが誤ってプロファイルを残しては問題があるところに残さないようにします。
GrabCAD Print バージョン 1.16、3月 2018
ビルド番号 1.16.29.38429 リリース日 20 3月 2018
- 刷新されたインストーラーは、GrabCAD Print のマシン限定インストール用に利用できます。これにより、GrabCAD Print をコンピュータ ラボ PC に簡単にインストールすることができます。また、システム管理者が企業レベルで導入することもできます。詳細はこちらと電子メールprint@grabcad.comでアクセスをリクエストしてください。
- 最新バージョンの CAD パッケージがサポートされるようになりました。これには、SOLIDWORKS 2018、Creo 4.0、Inventor 2018 などが含まれます。ここで完全なリストをご覧ください。
- 最後のアップデートでは、選択したプリンタの現在の設定とプリント設定を同期させることができる新しい機能を導入しました。今回のアップデートでは、アプリを起動した直後にこの動作を自動化しました。
- PolyJet プリント (通常は VeroPureWht) のサポート グリッドで使用されている材料が、「その他」を指定するのではなく、見積結果ウィンドウで指定できるようになりました。
GrabCAD Print バージョン 1.15、2月 2018
ビルド番号 1.15.13.37334にリリース19 2月 2018。
- FDM プリンタ用の印刷設定パネルの外観が新しくなっています。現在のプリンタ設定と異なる設定が表示され、1 回クリックするだけですべての設定を更新して一致させることができます。さらに、新しく作成されたトレイの設定は、現在表示されているものと常に一致し、複数のトレイがあるプロジェクトの印刷準備を高速化します。
- 整理ツールには、PolyJet ユーザーの「最適化」チェックボックスをコントロールする新しいスライダーがあります。印刷時間を最小限にするか、サポート材料の使用量を最小限に抑えるか、整理をどちらに合わせて最適化されるかコントロールできます。
- 修正済み:スケジュール ビューが画面上に一定時間残されていると、「今すぐ」行がゆっくりと移動するのではなく、そのまま残ります。
GrabCAD Print バージョン 1.14、1月 2018
ビルド番号 1.14.20.36110 リリース日 17 1月 2018
- プリンタ パネルの詳細画面に、FDM システムのエンベロープとヘッドの温度に加えて、モデルとサポートのヒントのオドメータが表示されるようになりました。
- FDM システムに複数のマテリアルベイがある場合、プリンタ パネルの新しいアイコンは、プリント ヘッドに現在ロードされているマテリアルベイを示します。
- ジョブに現在のプリンタ設定と一致しない材料またはヒントが選択されている場合は、[印刷] ボタンをクリックするとポップアップ警告が表示されます。
- Fortus 900mc プリンタ用の詳細な個別印刷ジョブのログを XML 形式でダウンロードできるようになりました。レポート ビューに移動して、「オプション」列で [ダウンロード] ボタンを使用します。
- GrabCAD Print が、Stratasys J700 Dental プリンタをサポートするようになりました。
- 修正済み:レポートは単位の環境設定に関わらず材料単位を cm³ でラベル付けしてきました。これは修正されました。
GrabCAD Print バージョン 1.13、12月 2017
ビルド番号 1.13.21.34870 リリース日 12 12月 2017
ビルド番号 1.13.23.35192 リリース日 19 12月 2017
- GrabCAD Print Server が設定されている場合は、以前はモバイル アプリの接続やオンラインのレポートなど、PolyJet システムのリモート アクセス機能の一部しか使用できませんでした。リモート PC 上の GrabCAD Print からジョブを送信することができるようになりました。
- Several improvements around
- GrabCAD Print のレポート ビューに、エクスポート ボタンが含まれるようになりました。これは、FDM と PolyJet の両方のシステムで動作します。
- 一部のユーザーがプリンタを選択できなかったレポート ビューのバグを修正しました。
- Internet Explorer のオンライン レポートに関するいくつかの問題を修正しました。
- 見積もり結果の準備が完了してから [見積もりの表示] をクリックする必要がなくなり、自動的にポップアップ表示されます。
- iOS 向けの GrabCAD Print アプリのジョブの詳細に予想終了時刻が追加されるようになりました。
GrabCAD Print バージョン 1.12、11月 2017
ビルド番号 1.12.26.33454 リリース日 13 11月 2017
- GrabCAD Print デスクトップ アプリケーションのレポート ビューから、ローカル プリンタのジョブ履歴にアクセスできます。これは、以前はこのレポートが GrabCAD Print Server を設定した後にオンラインのレポート ページでのみ利用可能だったため、オフライン モードのユーザーに非常に役立ちます。(PolyJet システム、リモートプリンタ、CSV エクスポートの履歴はまだありません。)
- 新しい高度な PolyJet の材料が Stratasys によって発売され、GrabCAD Print によってサポートされるようになりました。Agilus、VeroFlex、DABS2 Plus の詳細をご覧ください。.
- Android アプリは、アカウントに多数のプリンタが接続されていると、プリンタの検索に失敗したことを報告することがあります。タイムアウトを増やしたため、これはもう発生しません。
- 小さな操作性の改善
- 2 GB の個別ファイル サイズとトレイ サイズ制限が削除されました。
- 別の操作の進行中にスケジュール ビューに切り替えることができるようになりました。
GrabCAD Print バージョン 1.11、10月 2017
ビルド番号 1.11.17.31736 リリース日 11 10月 2017
- 次の機能を備えた新しいトレイ表示
- uPrint、Dimension、F123 シリーズ、およびより小型の Fortus システムの現実的なトレイ形状とグリッドライン。
- 大規模な Fortus システムでは、センチメートルまたはインチのグリッドライン (表示単位のユーザー設定に応じて異なります)。
- 適用されるプリンタのキャリブレーション タッチポイント。
- Fortus 900mc は小型トレイ サイズのアウトラインを表示します。
- これで、GrabCAD Print を使って、スライス プレビューから FDM 造形ジョブに一時停止を追加できるようになりました。これまでは、この機能は Catalyst および Insight でのみ使用できました。
- GrabCAD Printを使用して、ULTEM™ 9085 CGのジョブを準備できるようになりました。以前は、この材料は、Insight & Control Centerを使用してのみ利用可能でした。ユーザーは、Fortus 900mcでT16Aチップを使用することもできます。
- 一部のユーザーが SOLIDWORKS で GrabCAD Print アドインを起動できなくなる問題を解決しました。
GrabCAD Print バージョン 1.10、9月 2017
ビルド番号 1.10.19.30507 リリース日 13 9月 2017
- これで、Workbench プロジェクトから直接 GrabCAD Print にモデルを追加できます。ここに進むと、Print と Workbench を使用する方法の詳細を確認できます。
- GrabCAD Print Server を使用している場合、造形ジョブが終了したとき、または注意が必要なときに電子メールで通知を受けることができます。GrabCAD プロファイルから設定を調整します。
- ダブルクリックまたはドラッグ アンド ドロップして .PRINT ファイルを開くことができるようになりました。
- GrabCAD Print で、Objet1000 Plus プリンタがサポートされるようになりました。セットアップガイドを読む。
- ファイル名やパスに ASCII 文字以外の文字を含む CAD ファイルを GrabCAD Print に読み込めないという問題がありました。これは修正されました。
- CAD ファイルのインポートが改善されました。以前は、曲面上にある程度の粗さを示していたパーツもありましたが、その改善によってより滑らかな表面が得られます。
- [スタート] メニューの [Insight for GrabCAD Print] へのショートカットが表示されるようになりました。以前は GrabCAD Print の [アプリ] メニューからしか利用できなかった Insight のコンパニオン バージョンに移動します。
GrabCAD Print バージョン 1.9、8月 2017
ビルド番号 1.9.27.701 リリース日 9 8月 2017
- 犠牲タワーを Fortus 造形ジョブに追加できるようになりました。これは継ぎ目の品質を向上し、ナイロン 12 CF での造形では必須です。
- GrabCAD Print の Fortus プリンタでナイロン樹脂を使用できるようになりました。
- 注意が必要なジョブ (ジョブ中またはジョブの前に樹脂が不足する場合など) は、ジョブにスケジュール表示のアイコンが表示されます。警告のあるプリンタの合計数は、アプリケーションの左側にあるスケジュール表示アイコンの数として表示されます。
- ユーザーは、プリンタのジョブ履歴を含む CSV をプリンタ パネルからエクスポートすることができます (FDM のみ)。これにより、オフラインの顧客は、レポートを有効にすることなくジョブ履歴データをエクスポートできます。
- 以前のバージョンの GrabCAD Print では、初回インストール時にシステム管理者権限が必要でした。バージョン 1.9 では、(オプションの SW アドインが含まれていない限り) システム管理者の資格情報なしにユーザーがインストールできます。
GrabCAD Print バージョン 1.8、7月 2017
ビルド番号 1.8.16.652 リリース日 12 7月 2017
新機能:
- GrabCAD Printは、ULTEM™9085およびULTEM™1010での印刷をサポートするようになりました。これは、Insightでこれらの材料を使用して作成されたCMBファイルを、GrabCAD Printで印刷できることも意味します。パラメータを変更したり、アンカーピンや壁スタビライザーなどの機能を使用したりするには、[アプリ]メニューの[Insight]を使用できます。Sacrificial Towerを追加するには、引き続きControl Centerを使用する必要があります。(ULTEM™9085 CGは、GrabCAD Printではまだサポートされていません。)
- ユーザーは、FDM プリンタでプロジェクト全体 (一度にすべてのトレイ) を最適化して整理できるようになりました。これにより、ユーザーはできるだけ多くのパーツで複数のトレイを最適にパックすることができます。
- FDM プリンタのパーツを挿入する際に、造形品質を向上させるために、トレイの中央からパーツが配置されます。
- F123 シリーズ プリンタでは、サポートされている機能とサポートされていない機能の両方で底面の滑らかさが向上しました。
バグ修正:
- Windows ユーザー名の特殊文字は、J750 プリンタへの接続を確立する際に問題を引き起こさなくなりました。
- スケジュールで PolyJet ジョブを表示すると、「印刷モード」と「スライス印刷」が再度使用可能になります。
- パーツの変形が上部レイヤーの一部になったバグを修正しました。
- 特定の FDM プリンタを切り替えると、インポートされた CMB が消えるバグを修正しました。
GrabCAD Print バージョン 1.7、6月 2017
ビルド番号 1.7.28.633 リリース日 14 6月 2017
- 複数のインポートされた CMB ファイルをトレイに配置できるようになりました。以前は、複数の CMB で作業していたユーザーは、ワークフローにコントロール センターを使用する必要がありました。パフォーマンスのために、CMB はモデル表示では簡素化されていますが、スライス プレビューでは実際の形状を確認できます。空のプロジェクトから始めて、[ファイル] > [CMB のインポート...] の順に進みます。
- 「最近使ったファイル」を [ファイル] メニューに追加しました。5最も新しく追加されたファイル 'CAD 形式、CMB、または OBJZF) と最後の5 Print プロジェクトにアクセスできます。
- ドラッグ アンド ドロップを使用してスケジュール表示でジョブの並び替えを行うことができるようになりました。
- GrabCAD Print 用の SOLIDWORKS アドインが、GrabCAD Print のインストーラー内のパッケージに含まれるようになりました。SolidWorks アドインを使用すると、SOLIDWORKS 内から直接造形するための CAD ファイルを準備できます。インストール手順については、GrabCAD Print の [アプリ] に進んでください。
- 造形ジョブは、ローカル ジョブのコンピュータのプロファイル名ではなく、実際の名前で表示されるようになりました。
- GrabCAD Print は.JT ファイル タイプをサポートするようになりました
- 修正済み:ASCII 文字以外の文字 (é や à など) を含むパーツを J750 で造形できるようになりました。
- 修正済み:Tango+ をロードし、トレイで使用しなかったときの J750 のサイズ調整の問題がありましたが、これは解決されました。
GrabCAD Print バージョン 1.6、5月 2017
ビルド番号 1.6.19.601 リリース日 9 5月 2017
- 業務時間が導入されました会社の管理者が設定を有効にした場合、スケジュール表示は造形ジョブが通常業務時間中にのみ開始されることが反映されるように自動調整されるため、スケジュールをより正確に予測できるようになります。
- Shift キーを押したまま選択する方法で、プロジェクト パネルの複数のモデルをすばやく選択します。この機能とボックス選択( 1.5 でリリース)を使用することで、複数のモデルの設定変更がずっと短時間で行えるようになりました。
- プリンタ パネルのキュー リストで、クリックとドラッグを使用して簡単にジョブを並べ替えることができます。
- ビューアのパフォーマンス速度を高めるため、モデル表示には「簡易」バージョンのモデルが表示されます。曲面上の三角形が目立って表示されるかもしれません。これは、造形品質には影響しません。プリンタに送信された内容を確認するには、スライス プレビューに進むか、[システム設定] > [ディスプレイ設定] で [グラフィックの品質] を「高」に変更します。
- F123 シリーズのプリンタには、煉瓦モードの造形スタイルができました。これは大きくて密度が高く、固形の充填パーツを出力してパーツのカールを減らすのに役立ちます。これは ABS、ASA、または PC-ABS で 0.005 のスライス高さを使用している場合に限定されます。
- 修正済み:J750 プリンタでは、ミッドプリント エラーの原因になる可能性があるいくつかの問題を修正しました。これらの修正を活用するためにも、必ず GrabCAD Print と Job Manager を更新してください。
- 修正済み:表示単位をメートルに設定したユーザーは、選択した単位でスライス高さを表示できるようになりました。
GrabCAD Print バージョン 1.5、4月 2017
ビルド番号 1.5.15.549 リリース日 18 4月 2017
- オフライン モードのパート 2 はこちらです。今後は初めてインストールするときにインターネット接続がない場合も、ログインを省略することができます。これは GrabCAD Print 1.3 で導入したオフライン モード機能のフォローアップです。詳細についてはこちらをご覧ください。
- GrabCAD Print では、SOLIDWORKS 2017、Inventor 2017、NX 11.0、および Solid Edge St9 などの最新版の CAD パッケージをサポートしています。ここで完全なリストをご覧ください。
- [プロジェクト パネル] で、トレイ プレビューからトレイにカスタム名を付けることができるようになりました。[造形] をクリックすると、この名前がジョブで引き継がれます。
- バージョン 1.5 で送信されたジョブにはすべて、オンラインでもデスクトップ アプリでも、スケジュール表示のジョブの詳細にトレイのプレビューが表示されます。[システム設定] > [プライバシー] でこれを無効にすることができます。
- モデル表示のボックス選択を使うと、多数のモデルのプリント設定を同時に簡単に変更できます。左マウス ボタンでクリックしながらドラッグします。右側にドラッグするときは、ボックスに完全に含まれているモデルのみが選択されます。左側にドラッグすると、部分的にボックスの境界内に入っているモデルも選択されます。
- 表示のショートカットと視点設定は、利便性を考え、ビューア上部にボタンとして表示されるようになりました。
- モバイル アプリやオンラインでのレポートおよびスケジュール表示でも、樹脂単位の表示方法が選べるようになりました。設定はここで変更します。(モバイル アプリはサインイン後に更新されます)
- J750 のために Job Manager をアップデートする方法を改善しました。
- F123 シリーズのプリンタの場合、ベース レイヤーはトレイの密着を高めるために ABS または ASA および 0.005" のスライス高さを使用したモデル樹脂を使用して作られます。
- Stratasys F123 シリーズ プリンタの造形品質を改善するために、コア プロセスと造形機能に多数の調整が加えられました。
GrabCAD Print バージョン 1.4、3月 2017
ビルド番号 1.4.20.531 リリース日 14 3月 2017
新機能:
- GrabCAD Print で、すべての uPrint、Fortus、Dimension プリンタがサポートされるようになりました。全一覧をご覧ください。
- 1.3 では、トレイの推定を行った後で [トレイの整理] を押したときの FDM プリントのパックが大幅に改善されました。今回は [整理] ツールから [最適化] チェックボックスを選択するだけになり、操作がより簡単になりました。場合によっては、これによってトレイごとに以前の最大 2 倍ものパーツを収めることもできるようになりました。
- カスタム プリンタ名の概要[プリンタ設定] パネルでプリンタ名を変更すると、カスタム名は会社アカウントのすべてのメンバーのデスクトップ、Web、モバイルに表示されます。詳細情報はこちら
- GrabCAD Print Server(バージョン 0.144.0318)の最新アップデートにより、Stratasys J750 が GrabCAD Print モバイル アプリ、オンライン スケジュールおよびレポートでもサポートされるようになりました。リモート アクセスによる造形もまもなく提供される予定です。
- さらに GrabCAD PolyJet Job Manager が既に実行されている場合は、「ネットワーク プリンタの追加」オプションを使用して最初から J750 に接続することができるようになりました。
- [プリンタ パネル] の「マイ プリンタ」一覧にプリンタが表示される機能が改善されました。
- プリンタへの接続が失われても、リストから非表示になることはありません。代わりにステータスとして「接続解除」と表示されます。
- 「オフライン プリンタ」は「プリンタ テンプレート」となり、ネットワーク プリンタの下の別のセクションに表示されるようになりました。
- F370 プリント設定の若干の更新:
- PLA の造形の名称が「ドラフト モード」に変更になりました。
- パージ パーツ スタイルではデフォルトで最大限の高さが使用されます。
バグ修正:
- 一部の J750 ユーザーから、Tango+ 樹脂をロードし、トレイで使用しなかったときに、推定が正しくない、または造形が失敗するとの報告がありましたが、これらの問題は解決されました。
- スケジュール表示で、将来の J750 ジョブの時間と樹脂見積もりが表示されるようになりました。
- 一部の J750 ユーザーから、不明な「エラー 0」の不具合メッセージを出して造形が失敗するという報告がありました。造形の失敗の原因となる問題が修正され、同じ問題が再度起きたときにエラー メッセージには意味のあるテキストが表示されるようになりました。
- [向きの調整] パネルの 2 つのバグ(負の小数値に関するバグと「+」「-」ボタンに関するバグ)が修正されました。
- F370 ユーザーの中に、パージ パーツに間違ったレイヤーが含まれていることにお気づきになった方もいるかもしれませんが、この問題は修正されました。
GrabCAD Print バージョン 1.3、2月 2017
ビルド番号 1.3.25.508 リリース日 21 2月 2017
ビルド番号 1.3.23.503 リリース日 7 2月 2017
- Stratasys F123 シリーズのご紹介当社の最新プリンタは GrabCAD Print 専用として稼働します。次から詳細をご覧ください。
- GrabCAD Print の J750 サポートのベータ版は完了しました。ベータ プログラムの参加者の方々にお礼を申し上げます。J750 をお持ちの場合は、本ガイドに従って GrabCAD Print での造形を開始してください。
- SOLIDWORKS のアドインができ、お使いの CAD 環境から直接 .SLDPRT ファイルを出力できるようになりました。詳細を読むか、ここからダウンロードしてください。
- GrabCAD にログインすることなく、インストールしてすぐに造形できる機能をご希望のユーザーが多かったため、2 つのパーツで構成される
- インターネットに接続できなくなったときに、GrabCAD Print を使えばローカルプリンタを使って作業を続けることができます。
- ほとんどの作業をこの方法で続ける場合は、[システム設定] > [プライバシー] でオフライン モードに切り替えて警告メッセージをオフにすることができます。
- 初めてアプリケーションを起動した場合、最低 1 回はログインする必要があります。インターネット アクセスがあるのにログインできない場合は、『トラブルシューティング ガイド』をご覧ください。
- オフライン機能の 2 つ目のオプションは「完全オフライン」ソリューションで、これを使うと初回ログインも省略することができます。この機能は本年度の後半に使用可能になる見込みです。
- [整理] ツールが Insight や Catalyst ほど良くないと思ったことがある方は、この更新で大きな改善が行われたことをご確認ください。最初に、[推定] を押してトレイをスライスすると、[トレイの整理] によってパーツのパックがより綿密に行われます。
- J750 ベータ プログラムに参加された方々は、今回の更新で次のような改善が加えられたことにお気づきになるでしょう。
- Job Manager の更新は、ファームウェアの更新と同様、GrabCAD Print の [プリンタ パネル] で行えるようになりました。
- プリント設定パネルの不透明スライダの問題が修正されました。
- Insight が GrabCAD Print にバンドルされるようになったため、F370 や Fortus システムのグループやツールパス編集などの高度な機能を使用できるようになりました。ここから詳細をご覧ください。
GrabCAD Print バージョン 1.2、1月 2017
ビルド番号 1.2.11.469 リリース日 24 1月 2017
ビルド番号 1.2.9.464 リリース日 16 1月 2017
- 見逃した場合、レポートはこちらからご覧いただけます。Web ブラウザの右側で、ジョブ履歴と樹脂使用量をご確認ください。
- 1 つのトレイに追加するパーツが多すぎる場合に、新しいトレイを自動作成するかどうかを変更できる新しいシステム設定が追加されました。
- ツール アイコンが大きく、太字になりました。ご確認ください:ツール
- [回転] ツールでは、クリックごとの回転の度合いをカスタマイズして、完璧な角度で向きを整えるのが簡単になりました。
- VRML ファイルが解析モードに含まれるようになりました。ただしテクスチャ マッピングを壊さずにモデルを修復するには、他のソフトウェアを使用する必要があります。
- CAD ファイル リーダーの問題、特にドーナツ状のモデルに関する問題を解決しました。
GrabCAD Print バージョン 1.1、12月 2016
ビルド番号 1.1.28.454 リリース日 16 12月 2016
- メインのナビゲーションとプロジェクト パネルの色とアイコンの改良
- 単位設定がスケジュール表示に反映されないバグがありましたが、修正されました。
- 他の若干の修正と改善機能
GrabCAD Print バージョン 1.0、11月 2016
ビルド番号 1.0.32.424 リリース日 15 11月 2016
- 対応プリンタが増えました。GrabCAD Print を Fortus 380/450、Fortus 900(限定サポート*)、および Fortus 360/400 でご利用いただけるようになりました。また J750 は現在ベータ版が開発されています。アクセスをリクエストするには、print@grabcad.com までメールにてお問い合わせください。
- 樹脂の量を立法センチメートルで表示できるようになりました。[ファイル] > [システム設定] > [単位のコントロール] > [表示単位] に進み、任意のメートル単位に変更します。
- .CMB.GZ ファイルをインポートできるようになりました。
- インストーラーが、オペレーティング システムと同じ言語を使用してインストールされるようになりました。インストーラーの最初の画面か、[システム設定] から [戻る] ボタンを選択することにより、言語を変更することができます。
- 新規ユーザー向けの直感性の高いデフォルト マウス制御更新された設定はこちらで確認します。既存のユーザーへの影響はありません。
- インフィル、スライス高さ、サポート スタイルが、選択したモデル樹脂とサポート樹脂の推奨設定に自動更新されるようになりました。
- 若干の UI 改良とバグの修正。
*限定的なサポートとは、基本的な印刷準備がサポートされていることを意味します(Insightの「緑の旗」と同様)。ただし、ULTEM™またはNylon12の印刷時にSacrificial Towerを使用するなど、一部の高度な機能はまだ利用できません。
