GrabCAD Print 출시 정보
GrabCAD Print 버전 1.98, 1월 2025
빌드 번호 1.98.6.50666 출시: 21 1월 2025
- Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
- Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
- Print Pro: The Assembly created while using the Split tool is now optional.
- An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
- For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
- The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
- When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
- Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
- The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
- If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
GrabCAD Print 버전 1.97, 12월 2024
빌드 번호 1.97.10.49657 출시: 17 12월 2024
- Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
- Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
- Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
- Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
- Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
- F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
- For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
- The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
- ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
- Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
- RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
A new material profile has been added to the Validated O2 collections.
30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
- Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
- N3D-FR512 for FR-rating with higher elongation at break
- FL300 from Forward AM for low Shore hardness elastomers in a clear color
- MED414 for elastomeric applications requiring biocompatible capability such as ear bud
GrabCAD Print 버전 1.96, 11월 2024
빌드 번호 1.96.8.49045 출시: 20 11월 2024
- Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
- Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
- Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
- Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
- GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
- The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
- Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
- PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
- ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
- For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
- Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
- A new material profile has been added to both the Validated O2 and Open AM collections for P3.
- New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
- The History report in GrabCAD Print now includes material consumption per-job for P3.
GrabCAD Print 버전 1.95, 10월 2024
- Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
- A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
- A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
- A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
- Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
- The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
GrabCAD Print 버전 1.94, 9월 2024
- New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
- The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
- When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
- If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
- A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
- The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
- The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
- Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
- Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
- We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
- Advanced Color Assignment: designed to produce more accurate and consistent shades
- 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
- 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
- New TrueDent Clear Appliances: for fully translucent models and try-ins
- Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
- VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
- When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
GrabCAD Print 버전 1.93, 8월 2024
- Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
- Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
- The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
- Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
- VeroContactClear is now treated as a transparent material for all transparency-related features.
- Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
- When WSS is the selected support material, "No Grid" becomes the only available support grid type.
- The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
- A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
- Additional dental applications for Origin printers are now supported.
GrabCAD Print 버전 1.92, 7월 2024
- Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
- Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
- Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
- Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
- Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
- Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
- A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
- Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
- The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
- For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
GrabCAD Print 버전 1.91, 6월 2024
- Print Pro: 새로운 작업인 모델을 STL로 내보내기. 단일 어셈블리, 파트 또는 본체를 선택하고 마우스 오른쪽 버튼 클릭 메뉴에서 STL 파일로 내보냅니다. 내보낸 모델에는 분석 모드에서 수정된 사항과 적용된 레이블이 모두 포함됩니다.
- Print Pro: Print Pro는 이전에 J7/J8-Series 프린터에서만 사용할 수 있었던 트레이에 인쇄, 개체에 인쇄 및 스마트 삽입 기능을 이제 J3/J5-Series 프린터에서도 사용할 수 있습니다.
- 이제 GrabCAD Print는 FBX(.fbx) 및 GLTF(.gltf, .glb) 파일 형식 가져오기를 지원합니다.
- 탄소 섬유 시각적 인쇄 옵션은 더욱 매끄러운 표면 마감을 생성하는 ABS-CF10의 새로운 슬라이스 높이로, 파트의 시각적 외관이 작업에 중요한 경우 적합합니다. 슬라이스 높이(0.0050인치, 0.1270mm)는 T14H 헤드를 사용하는 F123 및 F123CR Series 프린터에서 사용할 수 있습니다(펌웨어 버전 2.7 필요).
- 이제 Stratasys F900 프린터에서 OpenAM이 지원됩니다. 재료 패키지는 OpenAM™을 사용하여 재료를 조정하고 컴파일하여 GrabCAD Print 및 F900 프린터에 배포할 때 생성됩니다. Stratasys 선호 및 검증 재료는 조정되어 패키지 및 타사 공개 자료에 포함될 수 있습니다(프린터 펌웨어 버전 필요 4.23).
- VICTREX AM™ 200은 Fortus 450mc 및 Stratasys F900 프린터용 검증 재료 포트폴리오에 추가되었습니다. VICTREX AM™ 200은 온도, 부식, 내화학성을 갖춘 고강도, 기계적 특성이 뛰어난 PEEK 기반 폴리머입니다. VICTREX AM™ 200은 T14F 팁을 사용하여 0.0100인치(0.2540mm) 슬라이스 높이를 지원하며 분리(SUP4000B) 및 용해성(SR-100 Support) 서포트(펌웨어 버전 필요 6.9)를 모두 지원합니다.
- 나일론 12CF 수축 동작이 업데이트되었습니다. 트레이의 재료가 나일론 12CF이고 트레이에 스파스 채우기 및 솔리드 채우기 모델이 모두 포함된 경우 솔리드 채우기에 대한 Z 수축률이 사용됩니다. 메시지가 사용자에게 변경 사항을 알려줍니다. 트레이의 모든 모델이 솔리드 채우기 또는 스파스 채우기로 전환되면 선택한 채우기 스타일에 대한 Z 수축률이 사용됩니다.
- GrabCAD Print는 Stratasys F770을 제외하고 Stratasys F123 Series 프린터와 통신할 때 IPv6 주소를 지원합니다(펌웨어 버전 필요 2.7).
- 4kg 카트리지가 포함된 J5 DentaJet™ XL은 DentaJet Series 제품 라인의 최신 혁신 제품입니다. 이 프린터는 대량 생산을 위해 제작되었으며 정렬 장치 제조업체와 C&B 모델 및 임플란트의 요구 사항을 충족하고 탁월한 수준의 정확도를 제공합니다. 규모에 따라 완벽한 제품을 제작하면서 워크플로를 혁신하는 비용 효율적인 솔루션을 제공하는 최고의 솔루션입니다.
- J5 Digital Anatomy 프린터를 사용하면 TissueMatrix, BoneMatrix, GelMatrix 및 RadioMatrix를 포함하여 J5 플랫폼에서 다양한 Digital Anatomy 재료를 인쇄할 수 있습니다. 인간 조직과 유사한 생체 역학적 동작을 갖는 해부학적 모델을 인쇄하기 위해 다양한 해부학적 사전 설정을 사용할 수 있습니다. 자세한 내용을 보려면 여기를 클릭하세요.
- 이제 PolyJet에서 색상 모델을 인쇄하기 위해 입력 색상 프로파일을 선택할 수 있습니다. 트레이 설정 > 고급에서 sRGB(기본값)와 새로운 Adobe RGB 1998 프로파일 중에서 선택합니다. Adobe 프로파일은 채도가 더 높은 색상(녹색/노란색/빨간색)을 제공하므로 인쇄 결과를 더 잘 이해하려면 채도가 높은 모니터를 사용하는 것이 좋습니다.
- 이전에 J3/5-Series 프린터에 대해 잠겨 있던 서포트 그리드 스타일을 이제 변경할 수 있습니다. 참고: 프린터에 TrueDent 재료가 로드된 경우 잠긴 상태로 유지됩니다.
- 해당 PolyJet 프린터의 경우 이제 UV LED 레시피 패널에서 다음 작업을 사용할 수 있습니다.
- 비공개 레시피에 대한 변경 사항 저장
- 레시피(SSYS 또는 비공개 모두)를 새로운 비공개 레시피로 저장
- 비공개 레시피 이름 바꾸기
- 비공개 레시피 삭제
- 이제 폴리프로필렌(PP)이 SAF용 3D Nest 설정 UI에서 지원됩니다.
- 이제 유효성 검사를 통해 소프트 충돌과 관련된 객체 사이의 거리가 보고되므로 사용자가 인쇄해도 괜찮은지 결정할 수 있습니다.
- P3 인쇄의 경우 이제 새 프로젝트를 시작할 때 자동으로 선택되도록 기본 재료 및 서포트 프로파일을 정의할 수 있습니다.
- P3 인쇄의 경우 특정 모델 지원을 수정하면 "모델의서포트 매개변수가 트레이 기본값과 다릅니다."라는 도구 설명과 함께 프로젝트 패널의 모델 옆에 경고 아이콘이 나타납니다.
- P3 인쇄의 경우 선택한 모든 모델이 동일한 서포트 프로파일을 가지면 단일 버튼으로 앵커 포인트 및/또는 서포트 구조를 자동으로 생성할 수 있습니다.
GrabCAD Print 버전 1.90, 5월 2024
- Print Pro: 트레이의 STL 파일을 선택하면 마우스 오른쪽 클릭 메뉴에서 새로운 작업인 분리를 사용할 수 있습니다. 분리는 여러 셸이 있는 STL 파일을 여러 본체가 있는 어셈블리로 변환합니다. 그런 다음 모델 설정을 각 본체에 적용할 수 있습니다. 하나의 셸만 식별되면 모델이 변경되지 않습니다.
- Print Pro: 레이블에 사용하기 위해 Allerta Stencil 글꼴을 선택할 수 있습니다. 이 글꼴을 선택하려면 레이블 드롭다운 메뉴를 확장하고 Allerta Stencil을 선택하세요. Atkinson Hyperlegible 글꼴은 여전히 기본 글꼴입니다.
- Print Pro: 이제 어셈블리 이름 모델 속성이 레이블 템플릿에 포함될 수 있습니다. 어셈블리 이름에는 파트 이름과 동일한 수정자가 있습니다(시작/끝에서, 건너뛰기, 길이). 어셈블리 구조가 없는 경우 어셈블리 이름과 파트 이름의 동작은 동일합니다.
- Print Pro: 이중 광택 및 무광택 표면을 인쇄하여 디자인에 질감 있는 마감을 생성할 수 있는 PolyJet 설정인 서포트(재료)가 모든 J-Series 프린터에 제공되었습니다.
- 보기 도구 모음에 새로운 보기가 추가되었습니다. 모델을 음영처리로 표시하는 표준 모드 외에도 새로운 옵션은 모델을 각각 투명 또는 음영처리된 와이어프레임 메시로 표시하는 와이어프레임 모드 및 와이어프레임 음영처리 모드입니다. 새로운 보기는 지원되는 표면 미리 보기와 호환되지 않습니다.
- 서포트 구조 없이 FDM으로 인쇄하는 옵션이 GrabCAD Labs에 추가되었습니다. 기능을 켜면(파일 > 기본 설정 > GrabCAD Labs) 서포트 설정 패널의 서포트 스타일 옵션으로 "서포트 없음"이 표시됩니다. 모델은 베이스만 있고 다른 서포트 구조 없이 인쇄됩니다.
- 전체 높이 희생 타워가 있을 때 모델의 방향을 바꿀 수 없는 문제가 해결되었습니다.
- SAF 인쇄의 경우 이제 X, Y, Z 크기 치수와 팩의 선택된 모서리에서 지정된 영역 원점의 X, Y, Z 위치를 제어하여 팩의 정의된 영역에 중첩을 생성하기 위해 하위 중첩을 선택할 수 있습니다.
- SAF 레이블의 최소 텍스트 크기가 10pt로 줄었습니다.
- P3 인쇄의 경우 수동으로 추가하거나 이동한 앵커 포인트는 자동으로 생성된 앵커 포인트와 다른 색상으로 표시됩니다.
GrabCAD Print 버전 1.89, 4월 2024
새로운 주문형 파트 모드의 GrabCAD Print 내 Stratasys Direct에서 견적을 받고 파트를 주문하세요. 다양한 FDM 재료 및 미국 배송이 가능합니다.
FDM 인쇄의 경우 안정 장치가 있는 모델에 대해 생성된 경계 상자가 필요한 것보다 커서 빌드 볼륨을 위반하게 되는 문제가 해결되었습니다.
- 비공개 레시피 이름 바꾸기
- 비공개 레시피 삭제
- 새로운 패션 기능: 의류에 인쇄. 단순화된 인터페이스에는 디자이너가 복잡한 3D 요소를 완성된 의류에 직접 통합할 수 있는 새롭고 혁신적인 Direct to Garment Trays 키트와의 호환성이 포함되어 있습니다.
- 선택된 항목 채우기라는 H350 배열 패널의 새로운 버튼을 사용하면 팩에 들어갈 수 있는 만큼 단일 파트의 복제본을 맞출 수 있습니다.
- P3 인쇄의 경우 이제 모든 모델이 동일한 서포트 프로파일을 공유하면 단일 작업으로 여러 모델에 대한 앵커 포인트 및/또는 서포트를 생성할 수 있습니다.
- P3 인쇄의 경우 특정 재료(주로 엘라스토머)의 경우 높은 비계가 생성될 때 추가 서포트 강화가 필요합니다. 서포트 프로파일, 트레이 또는 특정 모델별로 강화 유형을 제어할 수 있습니다. SSYS 탄성 프로파일은 이 옵션을 설정하도록 이미 수정되었습니다.
- P3 인쇄의 경우 재료 정의는 재료별 기본 배열 매개변수(모델 간 간격 및 인쇄 경계와의 간격)를 제공합니다. OpenAM 사용자는 개인 재료에 대해 이러한 값을 수정할 수 있습니다. 모든 사용자는 정렬 패널을 통해 트레이별로 이러한 매개변수를 수정할 수 있습니다.
GrabCAD Print 버전 1.88, 3월 2024
- Print Pro: GrabCAD Print Pro에는 이제 PolyJet용 기능이 포함되어 있습니다. 이는 이전에 PolyJet Research Package를 통해서만 사용할 수 있었던 기능으로 구성됩니다.
- 트레이에 직접 인쇄(J7/8-Series만 해당) — 유리 또는 탄소 섬유와 같은 재료에 인쇄할 수 있어 파트 밑면에 완벽한 표면 마감을 생성하고 밑면에서 후처리가 필요하지 않습니다.
- 공기(재료)(J7/8-Series만 해당) — 수지 대신 공기를 사용하여 파트 무게를 크게 줄여 최대 30%의 재료 절감이 가능합니다.
- Smart Insert™(J7/8-Series만 해당) - 다양한 기능/장식 요소를 인쇄물에 직접 삽입할 수 있습니다.
- 개체 위에 인쇄(J7/8-Series만 해당) — 다양한 재료에 직접 개체 인쇄를 통한 모델 맞춤화 및 개인화가 가능합니다.
- Voxel Print 앱(J7/8-Series만 해당) — 다른 소프트웨어에서 정의한 슬라이스 데이터를 인쇄하는 도구로, 복셀 수준에서 색상, 투명도, 해안 경도를 포함하여 모델의 모든 세부 사항을 제어할 수 있습니다.
- ...다른 새로운 기능...
- 서포트(재료)(J750 및 J850 Prime만 해당) — 이중 광택 및 무광택 표면을 인쇄하여 디자인에 질감 있는 마감을 생성할 수 있습니다.
- 액체(재료)(J7/8-Series만 해당) - 미세유체 구조, 중공 튜브, 유압 부품 등과 같은 중공 공간을 생성할 수 있습니다.
- 고속 모드(J55만 해당) — 동일한 레이어 두께를 유지하지만 2 재료를 사용할 때 속도가 두 배로 증가합니다.
- ...FDM 및 SAF용 Print Pro에서 이미 사용할 수 있는 일부 기능은 다음과 같습니다.
- 레이블
- 두께 분석
- 조립/해체
- 타사 플러그인
- Print Pro: 내보낸 추정 결과는 이제 계산에 더 쉽게 포함할 수 있도록 hh:mm 시간 형식을 사용합니다.
- GrabCAD Print는 이제 다음 CAD 버전을 지원합니다.
- 솔리드 웍스 2024
- Inventor 2024
- NX 2306 시리즈
- 솔리드 엣지 2024
- .X_T 36
- .JT 10.9
- Agilus CMY와 VeroUltraWhite, VeroPureWhite 또는 VeroClear가 혼합된 디지털 재료(DM)는 이제 모든 J7/8-Series 프린터에서 이러한 재료에 허용되는 모든 인쇄 모드로 사용할 수 있습니다. DM 이름에는 접두사 FLXAC가 있습니다.
GrabCAD Print 버전 1.87, 2월 2024
- Print Pro: 이제 Pro 프로젝트의 견적 결과에는 트레이/중첩 요약 및 빌드 보고서(파트별) 탭 모두에 비용 견적이 포함됩니다. 비용 요율은 견적 결과 창의 새 탭이나 프린터 설정에서 구성할 수 있습니다.
- 뷰어 상단의 컨트롤 스트립에 섹션 보기가 추가되었습니다. 이 보기를 통해 다른 경우에는 가려졌을 수 있는 모델의 기능을 볼 수 있으며 측정 도구 또는 Origin의 서포트 생성 도구와 함께 사용할 수 있습니다. 단면 보기를 활성화한 후 아래 버튼을 사용하면 단면화 평면과 방향을 선택하거나 드래그 핸들을 사용하여 다른 각도로 단면화할 수 있습니다.
- 이제 추정 결과 창의 텍스트를 선택할 수 있으며 Ctrl+C를 사용하여 클립보드에 복사할 수 있습니다.
- 이전에는 PolyJet 및 Print Pro 프로젝트에만 사용할 수 있었던 위치 도구를 이제 Print Standard의 모든 기술에 사용할 수 있습니다.
- F123 Series 프린터의 얇은 벽을 두껍게에 대한 기본 설정이 꺼짐으로 변경되었습니다.
- 파트 쉘의 윤곽선과 경우에 따라 인접한 채우기가 생성되지 않는 문제가 해결되었습니다.
- 이제 새로운 대형 산업용 FDM 프린터인 Stratasys F3300을 GrabCAD Print에서 선택할 수 있습니다. 여기에서 Stratasys F3300의 기능과 성능에 대해 알아보거나 프린터 템플릿 목록에서 선택하여 사용 가능한 재료와 설정을 확인하세요.
- 뷰어 상단의 보기 컨트롤 모음에서 사용할 수 있는 PolyJet 서포트 시각화는 서포트되는 영역을 체커보드 패턴이 아닌 파란색으로 표시하여 가시성을 향상했습니다.
- 이 옵션은 인쇄 프로세스를 최적화하지 않고 화면에 표시된 대로 트레이의 실제 위치에 파트를 배치합니다. 절대 위치를 사용하면 작은 파트의 인쇄 품질이 영향을 받을 수 있습니다.
- 1.83 업데이트의 다른 기술에 추가된 측정 도구를 이제 PolyJet 인쇄 준비에 사용할 수 있습니다.
- SAF 프로젝트의 경우 이제 강력하고 동적인 버전의 빌드 보고서를 사용할 수 있습니다. 추정 결과에서 빌드 보고서를 선택하고 오른쪽 상단의 내보내기 드롭다운에서 "HTML"을 선택합니다. 결과 파일은 모든 웹 브라우저에서 열 수 있으며 배열 및 파트별 추정치뿐만 아니라 배열 및 각 파트의 대화형 3D 미리 보기가 포함되어 배열 내 위치를 보여줍니다. 이름으로 특정 파트를 찾는 데 도움이 되는 검색 도구도 있습니다.
- 이제 Sinter Box의 레이블을 미리 볼 수 있으므로 레이블이 사용 가능한 공간에 맞는지 확실하게 알 수 있습니다.
- P3 프로젝트의 경우 Z-보상 값이 허용되지 않는 버그를 수정했습니다. Z-보상이 서포트 파트 관통 값을 초과할 수 없다는 규칙이 여전히 있습니다.
- For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
- 아일랜드의 서포트 반경: 추가 앵커 포인트를 받게 될 아일랜드의 첫 번째 증거 주변 반경입니다.
- 아일랜드의 내부 간격: 이러한 추가 앵커 포인트 사이의 간격입니다.
- Additional updates for P3 support parameters:
- 산업 모델의 경우 최대 발 지름이 10에서 30mm로 증가되었습니다.
- 치과 모델의 경우 파트 관통은 0일 수 있습니다.
GrabCAD Print 버전 1.86, 1월 2024
- FDM 툴패스 계산으로 인해 큰 파트가 제작 볼륨을 위반하거나 작은 파트가 서로 간섭하는 문제가 해결되었습니다.
- PolyJet 인쇄 준비를 위해 3D 뷰어가 업데이트되었습니다. 이 업데이트는 곧 제공될 기능에 필요하지만 현재로서는 변경 사항이 없습니다. 그러나 필요한 경우 파일 > 기본 설정 > PolyJet에서 이전 뷰어로 다시 전환할 수 있습니다.
- 이제 J-Series 프린터를 사용하는 사람은 누구나 GrabCAD Voxel Print 앱(.gcvf 파일)으로 생성된 파일을 가져올 수 있습니다. Voxel Print 앱을 사용하여 .gcvf 파일을 생성하려면 여전히 라이센스가 필요하지만 이제 파일 가져오기는 모든 사람에게 허용됩니다.
- (다른 채널에 대해 세척액을 사용하여) 고혼합 인쇄 모드에서 7 미만의 모델 재료로 작업하는 옵션이 고품질 인쇄 모드를 포함하도록 확장되었습니다.
- J5 DentaJet 사용자를 위한 세 가지 업데이트
- 이제 TrueDent 재료를 사용하는 J5 DentaJet 프린터를 선택하면 TrueDent 재료에 대한 IFU(사용 지침)가 나타납니다.
- TrueDent 인쇄를 위한 모델 설정 패널이 유용성을 위해 개정되었습니다. 치은과 치아 쉐이드에 대해 선호하는 재료와 기본 재료를 쉽게 선택할 수 있습니다.
- J5 DentaJet 사용자는 이제 Exocad Model Creator를 사용하여 구강 내 스캔부터 풀 컬러 인쇄 모델까지 엔드투엔드 워크플로를 활용할 수 있습니다. GrabCAD Print의 새로운 색상 프로파일을 사용하면 Exocad와 색상을 일치시킬 수 있습니다.
- Origin 인쇄의 경화 프로세스로 인해 아래쪽 표면에 추가 재료가 쌓일 수 있습니다(과잉 경화 현상). Z-보상이라는 새로운 매개변수는 해당 표면을 위쪽으로 오프셋하여 이 문제를 해결합니다.
- Origin Dental 사용자의 경우 "캐비티 내 서포트 필터링" 옵션에 새로운 경고 메시지가 표시되어 일부 필수 서포트가 제거되었을 수도 있음을 알려줍니다.
- 길이나 높이 제한으로 인해 P2P 버팀목을 사용할 수 없는 경우 서포트 생성 시 자동으로 P2P 비계를 사용합니다.
GrabCAD Print 버전 1.85, 12월 2023
- 인쇄 프로: 라벨에 대한 두 가지 업데이트
- 이제 라벨 패널의 버튼을 통해 단일 작업으로 모든 라벨을 삭제할 수 있습니다.
- 템플릿 라벨을 생성할 때 이제 파트의 라벨 텍스트 미리 보기가 제공되어 크기, 위치 및 회전을 조정하는 동안 시각적인 도움을 제공합니다.
- J8 Series 프린터는 이제 7 재료 조형 모드에서 모델 재료 대신 세척액 카트리지를 사용할 수 있습니다. 이 기능을 사용하면 최대 4개의 인쇄 채널에 세척액을 넣고 계속 인쇄할 수 있으므로 재료를 교체하면서 인쇄할 수 있습니다.
- 이제 DM2 모드로 알려진 2 재료가 로드된 Connex3 프린터로 인쇄 작업을 보낼 수 있습니다. (참고: 파일 > 기본 설정 > PolyJet에서 고급 슬라이서를 비활성화해야 함)
- HQ 모드에서 인쇄할 때 하나의 UV 램프를 사용하는 옵션이 J850 Prime, J850 Prime Fabrix, J850 Pro, J835 및 J750에서는 기본값이 되었습니다.
- 다른 모델 또는 서포트 재료와의 혼합물 내 해부체 재료의 비율은 제한되어 있습니다. 이러한 제한 사항에 대한 검증이 각 노이즈 모듈레이션 단계에 추가되었습니다. SUP706의 제한 사항이 수정되었습니다. BoneMatrix, Agilus30 재료 또는 Vero 재료와 혼합할 때 SUP706은 외부 레이어에서 50% 미만이어야 합니다.
- 패션 옵션 개선
- 레시피 패널을 열지 않고도 UV LED 레시피를 선택할 수 있습니다.
- 레시피 관리 버튼을 사용하여 레시피 패널을 엽니다.
- 총 슬라이스에는 접착 레이어가 정의되어 있습니다.
- Origin 프린터의 앵커 포인트 및 서포트 생성 프로세스에 대한 진행률 표시줄에 취소 버튼이 추가되었습니다. 앵커 포인트나 서포트 구조가 생성된 경우 제거됩니다.
- 앵커 포인트 및 서포트 패널에서 매개변수를 수정할 때 이제 서포트 프로파일 이름 옆에 별표(*)가 표시되어 저장되지 않은 변경 사항을 나타냅니다. 수정된 매개변수를 재설정하려면 프로파일 재설정 버튼을 사용하세요.
GrabCAD Print 버전 1.84, 11월 2023
- Print Pro: 간격 분석을 소개합니다! 두께 분석 도구가 향상되어 사용자가 모델에서 프린터 해상도보다 낮은 간격(예: 포켓)을 감지할 수 있습니다. 이 기능은 두께 분석 패널의 새로운 간격 탭에서 사용할 수 있습니다.
- Print Pro: 정확도 센터 WAM 기능은 이제 훨씬 더 높은 정확도 향상을 제공하고 이 기능을 통해 사용자는 가장 까다로운 프로젝트에서도 품질을 개선하기 위해 반복할 수 있습니다.
- Fortus 450mc에 추가된 검증된 자료 1.75 이제 F900에서 사용할 수 있습니다. 이러한 재료는 프로그래밍 및 인쇄 작업에 사용하기 전에 기본 신뢰성 테스트를 통해 검증됩니다. 검증된 재료는 F900에 펌웨어 버전 4.22이 설치되어 있어야 하며 슬라이스 높이가 0.0100인치/0.2540mm인 경우에만 사용할 수 있습니다.
- FDM HIPS(고충격 폴리스티렌)
- KimyaPC-FR(난연성)
- ULTEM™ 9085 Resin의 새로운 색상(Red, Aircraft Gray, Gunship Gray, Dream Gray, White 7362, Jana White)
- PC의 새로운 색상(빨간색)
- PC-ABS의 새로운 색상(Red)
- (베타) VICTREX AM™ 200 PAEK(저융점)
- PolyJet의 경우 패션 프린터용 접착층이 개선되었습니다. 이전에는 접착층이 있는 무광택 모델을 인쇄할 때 접착층이 모델과 주변 서포트 아래에 인쇄되었습니다. 서포트를 제거했을 때 모델 주변에 접착층이 남아 있을 수 있습니다. 최신 업데이트 이후에는 접착층이 모델 아래에만 추가되어 서포트 제거 시 접착층이 남아 있는 문제가 발생하지 않습니다.
- GrabCAD Print 1.83로 업데이트한 후 인쇄 작업이 실패하기 시작한 PolyJet Objet30V3 및 V5 프린터의 문제를 해결했습니다.
- SAF의 경우 이제 3D 네스트 패널에서 X/Y 형식으로 추가 진행 정보를 보고하므로 사용자는 선택된 모델 수와 현재 네스트에 포함된 모델 수를 명확하게 확인할 수 있습니다.
- P3에는 매개변수 자동 수정 기능이 도입되었습니다. 사용자가 유효한 범위가 있는 매개변수에 잘못된 값을 입력할 때마다 값은 이제 가장 가까운 유효 값으로 자동 수정되고 자동 수정된 유효 범위에 대한 툴팁이 표시됩니다.
GrabCAD Print 버전 1.83, 10월 2023
- Print Pro: 이제 빌드 보고서는 퍼지 부품 또는 희생 타워를 사용하는 프린터에 대한 퍼지 재료를 추정합니다.
- Print Pro: 이제 빌드 보고서에는 Excel 또는 CSV 내보내기의 일부로 개별 부품을 인쇄하는 데 필요한 예상 시간이 포함됩니다.
- Print Pro: 견적을 Excel 파일로 내보낼 때 빌드 보고서와 트레이 요약이 이제 동일한 문서의 별도 시트로 포함됩니다.
- 측정 도구를 소개합니다! 이제 정점에 스냅하는 옵션을 사용하여 점 대 점, 평면 대 점 또는 점 대 평면을 측정할 수 있습니다. 측정은 FDM, SAF 및 P3 프로젝트에서 지원됩니다.
- 이제 프로젝트 패널이나 모델 뷰어에서 모델을 강조 표시하고 마우스 오른쪽 버튼 메뉴에서 이름 바꾸기 명령을 선택하여 파트, 어셈블리 및 본체의 이름을 바꿀 수 있습니다.
- 마우스 오른쪽 버튼 클릭 메뉴에 새로운 선택 옵션이 추가되었습니다. 이제 모두 선택을 전체 프로젝트 또는 현재 트레이에만 적용할 수 있습니다. 그리고 새로운 옵션인 선택 반전은 현재 트레이나 전체 프로젝트에서 선택되지 않은 부분으로 선택을 뒤집습니다.
- H350 인쇄의 경우 보기 컨트롤 모음에서 다음의 두 가지 새로운 옵션을 사용할 수 있습니다.
- 색상화는 밀도가 높은 팩을 더 잘 시각화하기 위해 네스트의 부품에 임의의 색상을 추가합니다.
- 레이어 선 시각화는 결과 인쇄물에서 레이어를 볼 수 있는 위쪽 또는 아래쪽 표면에 선을 표시합니다.
- P3의 경우 GrabCAD Print에서 서포트 구조를 생성하기 위한 새로운 도구가 추가되었습니다. 이제 GrabCAD Print를 사용하여 CAD 파일을 완전히 준비하고 인쇄용으로 보낼 수 있으며 추가 소프트웨어가 필요하지 않습니다.
GrabCAD Print 버전 1.82, 9월 2023
- Print Pro: 두께 분석이라는 분석 모드의 새로운 기능을 사용하면 부품에 프린터 해상도보다 낮은 형상이 포함되어 있는지 빠르게 확인할 수 있습니다. 해상도는 기본적으로 프린터 기술에 따라 설정되며, 사용자가 원하는 값을 설정할 수 있습니다. 디스플레이는 이진 빨간색 실패/녹색 통과 또는 연속 노란색-빨간색 그라데이션일 수 있습니다. 커서는 또한 부품 위의 어느 지점에서나 특정 값을 표시하는 '프로브'를 제공합니다.
- Print Pro: 이제 FDM 3D Array 명령에 더 작은 음수 간격 값을 사용하여 트레이에 부품을 훨씬 더 촘촘하게 배열할 수 있습니다.
- 이제 트레이를 숨길 수 있어 촘촘하게 포장된 파트의 아래쪽을 더 잘 볼 수 있습니다.
- GrabCAD Print는 Stratasys H350, Fortus 450mc, Stratasys F900 및 Fortus 900mc 프린터와 통신할 때 IPv6 주소를 지원합니다. Fortus 450mc용 IPv6에는 펌웨어 버전 6.8이 필요합니다. Stratasys F900 및 Fortus 900mc에서는 IPv6을 지원하려면 펌웨어 버전 4.22이 필요합니다.
- J5 DentaJet 플랫폼에서 의치, 임시 크라운 및 브리지의 3D 인쇄를 위해 개발된 FDA 승인(클래스 II) 레진인 TrueDent™를 소개합니다. 단일 혼합 트레이에서 심미성이 뛰어난 모놀리식 다색 치과 장치를 일괄 생산할 수 있습니다. 현재 특정 지역에서 사용 가능하지만 TrueDent™는 향상된 생산성과 탁월한 결과를 추구하는 치과 기공소에 유망한 솔루션을 제공합니다.
- 버전 1.81에서는 고급 텍스처 처리 활성화/비활성화를 위한 기본 설정이 추가되었습니다. 이 확인란은 트레이 설정(고급 섹션 아래)으로 이동되어 사용자가 작업당 값을 결정할 수 있습니다. 텍스처가 있는 무거운 트레이를 인쇄하는 J55 Prime 및 J850 Prime의 경우 기본적으로 확인란이 선택 취소되어 있습니다.
- DAP 프린터의 구조적 심장 모델에 젤 코팅이 추가되었습니다(혈관 모델에 정의된 대로).
- SAF 인쇄의 경우 소결 상자에는 이제 상자 형상의 일부로 사용자 정의 라벨이 있을 수 있으므로 케이크를 분해하여 소결 상자에 어떤 부품이 포함되어 있는지 알 수 있습니다. 긴 라벨은 소결 상자의 가장 긴 축에 자동으로 정렬됩니다.
- SAF 인쇄의 경우 열 관리 개선을 위해 추가 공간이 필요한 특정 선택 파트에 대해 중첩을 위한 최소 간격 값을 재정의할 수 있습니다.
- SAF 인쇄의 경우 이제 네스팅 작업이 네스트의 기존 내용에 추가되는지 아니면 네스트를 지우고 다시 시작할지 선택할 수 있습니다.
- P3 인쇄의 경우 트레이에 맞춤 옵션은 인쇄 영역에 맞을 때까지 모델을 단계적으로 회전하는 방향 개선을 시작합니다.
- P3 인쇄의 경우 모든 치과 서포트 프로필에는 90°방향의 스프린트 모델에 대한 음각의 앵커 포인트를 필터링하는 새로운 매개변수가 있어야 합니다.
- P3 인쇄의 경우 앵커 포인트를 생성할 때 선택한 서포트 프로필에 지정된 자체 서포트 각도에 따라 서포트 가능한 영역의 색상이 지정됩니다.
- P3 온프레미스 클라우드를 사용하는 GrabCAD Print 사용자는 관리자가 아닌 계정으로 GrabCAD Print를 실행할 수 있습니다.
GrabCAD Print 버전 1.81, 8월 2023
- Print Pro: Accuracy Center는 이제 원본 및 검증 보기에 대한 탭을 사용합니다. 원본 탭에는 원본 인쇄 부품에 대한 정확도 결과(히트맵 및 인쇄 정확도 점수(PAS))가 표시됩니다. 검증 탭을 통해 사용자는 WAM 인쇄 스캔을 업로드하여 정확도가 얼마나 향상되었는지 정확하게 확인할 수 있습니다. 새로운 PAS 대 원본 점수를 표시하고 새로운 히스토그램은 원본의 회색 윤곽선과 함께 표시되므로 특정 오류 대역의 감소를 쉽게 확인할 수 있습니다.
- 인쇄 프로: 수평 표면에서 더 나은 결과를 얻기 위한 정확도 센터의 새로운 WAM의 제어:
- 유지(현재 기본값)를 사용하면 수평 표면의 균일한 수직 조정만 허용하여 미적 아름다움을 유지하고 부드러운 수평 영역에 등고선을 추가하지 않습니다.
- 고정은 수평 표면의 움직임을 방지합니다.
- 자유 조정을 사용하면 미적 측면보다 핏이 우선시되는 위치에서 정확성을 극대화하기 위해 수평 표면 내에 윤곽을 추가하는 등 수평 표면의 뒤틀림 현상을 자유롭게 없앨 수 있습니다.
- Print Pro: 사용자가 올바른 스캔 파일을 선택하는 데 도움이 되도록 Accuracy Center에서 선택한 스캔 파일의 빠른 미리 보기를 추가했습니다.
- Print Pro: 이제 정확도 센터 히스토그램의 Y축에 각 오류 수준 막대에 대한 전체 부품의 백분율이 표시되므로 부품의 몇 퍼센트가 선택한 허용 오차보다 높거나 낮거나 허용 오차 내에 있는지 확인할 수 있습니다.
- Print Pro: 정확도 센터에서 스캔을 비교할 때 인쇄된 부분과 스캔한 부분의 로컬 차이(예: 오류 대 해당 지점의 디자인)가 이제 비교 결과 위로 마우스를 이동할 때 동적으로 표시됩니다.
- 로컬 허브 및 OpenAM 라이센스가 있는 P3 사용자의 경우 "레이어별 설정" 파일을 업그레이드할 때 발생하는 문제가 해결되었습니다.
- P3 사용자의 경우 모델 삽입 설정 아래의 "모델이 현재 트레이에 맞지 않으면 자동으로 트레이 만들기" 기본 설정이 이제 다른 플랫폼에서와 마찬가지로 P3 프린터에서도 작동합니다.
GrabCAD Print 버전 1.80, 7월 2023
- CAD 파일의 2023 버전은 GrabCAD Print에서 SOLIDWORKS 2023, SolidEdge 2023, Siemens NX 2212을 지원합니다.
- Print Pro: 이제 임시 텍스트 라벨을 FDM 부품(STL, CAD)에 추가할 수 있고 엠보싱 또는 디보싱 처리가 가능하며 텍스트 크기, 깊이 및 간격을 제어할 수 있습니다. 또한 재사용 가능한 라벨용 템플릿을 생성할 수 있으며, 여기에 텍스트, 부품 이름을 포함하고 고유한 일련 번호를 생성할 수 있습니다. GrabCAD Print Pro에 대해 자세히 알아보려면 여기를 클릭하세요.
- SAF 네스팅의 경우 네스팅 방법의 이름이 표준 및 고급에서 인터록 없음 및 컴팩트로 변경되어 기능을 사용자에게 더 명확하게 했습니다. 이제 기본 방법은 컴팩트(이전의 고급)이며 일반적으로 더 조밀한 네스팅이 발생합니다.
- SAF에서는 경우에 따라 검증이 매우 느릴 수 있으므로 이제 배열을 추가로 편집해야 하는 경우 검증 프로세스를 취소할 수 있습니다.
- 이제 J850 TechStyle 사용자는 반유연성 재료의 새로운 VeroEcoFlex 제품군을 사용할 수 있습니다. 자세한 정보.
- 대부분의 PolyJet 프린터는 UV 수은 램프를 사용하지만 J850 TechStyle은 이 램프를 UV LED로 대체합니다. 새로운 UV LED는 더욱 정확한 경화를 가능하게 하며, 얇은 형상을 가진 소형 패션 모델에 매우 중요합니다. GrabCAD Print의 UV LED 레시피 기능은 특정 슬라이스 또는 슬라이스 범위까지 UV 기능을 제어하는 메커니즘을 제공합니다. 인쇄 프로세스의 어느 부분에서나 사용할 LED와 각 LED의 강도를 제어할 수 있습니다.
- P3 시스템이 즐겨찾기로 저장되지 않는 GrabCAD Print의 문제를 해결했습니다. 이 문제는 해결되었으며 이제 사용자는 컴퓨터를 즐겨찾기로 할당할 수 있습니다.
- 이전에는 P3 작업에 대한 장기 작업 추정이 올바르게 표시되지 않는 문제가 있었습니다. 이로 인해 완료까지 걸리는 시간이 훨씬 단축되었습니다. 이 문제를 해결했습니다.
- 특정 설정의 재료가 인쇄를 시작하지 못할 때 발생하는 P3 문제를 해결했습니다. 사용자에게는 더 이상 이 문제가 발생하지 않으며 예상대로 작업이 인쇄되기 시작합니다.
- OpenAM 라이센스가 있는 P3 사용자의 경우 재료 프로필 아래의 배율 범위가 확장되어 이제 +2%~-1%가 되므로 레진 수축을 보상하기 위해 배율을 더 잘 조정할 수 있습니다.
- OpenAM 라이센스가 있는 P3 사용자의 경우 특정 상황에서 최적으로 수행되지 않는 "레이어별 설정 업로드" 기능 문제를 해결했습니다.
- OpenAM 라이센스가 있는 P3 사용자의 경우 새로 만든 재료가 포함된 작업이 인쇄를 시작하지 않는 문제를 해결했습니다.
GrabCAD Print 버전 1.79, 6월 2023
- 랩 모델 도구는 멤버 바디가 고유한 설정을 가질 수 있는 그룹에서 사용할 수 있습니다. 기본적으로 켜져 있습니다. 랩은 모델 바디를 공통 셸로 둘러싸고 있습니다. 셸은 모델에서 바디 사이의 조인트가 적용된 하중에 견딜 수 있도록 설계되지 않은 경우 강도를 추가합니다. 바디 사이의 조인트가 하중을 견딜 수 있도록 설계된 경우 랩 기능이 필요하지 않으므로 꺼도 됩니다.
- CMB 가져오기와 관련된 충돌은 이제 추가되는 파일이 프로젝트와 어떻게 일치하지 않는지 명확하게 설명합니다.
- ASA는 이제 흰색, 검은색, 밝은 회색, 파란색, 빨간색, 노란색의 Stratasys F770 프린터에서 사용할 수 있습니다.
- 접착력 향상을 위해 J3/J5 DentaJet의 받침대 높이를 1mm로 높였습니다.
- “패키징 최적화” 옵션이 J850 Prime FabriX에 추가되었습니다. 이 옵션은 병과 같은 투명한 패키징 개체의 인쇄 결과를 개선합니다.
- P3 프린터의 트레이 설정 아래에 있는 배율 도구에서 측정 단위가 소수점 이하 1자리에서 소수점 이하 3자리로 개선되었습니다. 이 기능 개선으로 더욱 정밀한 측정과 기능의 세밀한 조정이 가능해졌습니다.
- P3 프린터용 슬라이스 스택 가져오기는 이제 layer_xxx, slice_xxx 등과 같은 접두사가 있는 슬라이스 파일 이름을 지원합니다.
- OpenAM 라이선스가 있는 P3 사용자의 경우, 새로운 재료 설정 다운로드 기능이 있습니다. 재료의 첫 번째 + 전환 레이어에 대한 정보가 포함된 CSV 파일을 다운로드할 수 있습니다. 이 정보에 액세스하려면 재료 라이브러리로 이동하여 재료를 선택하고 레이어별 설정 테이블 위에 있는 "설정 다운로드" 버튼을 누르십시오.
- 이제 프로젝트 패널에는 미러 명령으로 생성한 모델 옆에 아이콘이 표시됩니다.
- SAF 인쇄의 경우 이제 네스팅 진행률 표시줄은 네스팅이 발생하는 시점과 유효성 검사가 발생하는 시점을 사용자에게 알려줍니다.
GrabCAD Print 버전 1.78, 5월 2023
빌드 번호 1.78.18.27879 출시: 16 5월 2023
- GrabCAD Print Pro 여기 있습니다! Warp-Adjusted Modeling, 부품별 견적, 제조 템플릿 등의 기능을 제공합니다.
- Pro 기능의 전체 목록 읽기
FDM 작업의 화면 그래픽을 렌더링하기 위해 GrabCAD Print 내부에서 사용되는 소프트웨어가 업데이트되었습니다. 많은 새로운 기능에 이 소프트웨어가 필요하기 때문입니다. 이전 뷰어는 기본 설정 메뉴에서 계속 사용할 수 있지만 향후에는 더 이상 사용되지 않을 예정입니다.
FDM의 경우 외부 윤곽선에 대한 연결 동작이 항상 모델 재료 및 슬라이스 높이에 대해 정의된 동작을 사용하도록 업데이트되었습니다. 이전에는 일부 사용 사례에 외부 윤곽선이 연결되어 재료 연결 동작이 무시되었습니다.
이제 나일론-CF10을 Stratasys F370CR 및 F190CR 프린터에 대한 획기적인 지원을 통해 사용할 수 있습니다. SUP4000B 서포트 재료는 탱크리스 서포트 제거 솔루션을 제공하고 분리 서포트를 쉽게 제거할 수 있어 파트 제작 시간을 단축합니다. SUP4000B는 QSR과 동일한 서포트 헤드 및 동일한 슬라이스 높이(0.0130인치/0.3302mm, 0.0100인치/0.2504mm, 0.0070인치/0.1778mm)를 사용합니다.
나일론-CF10. 획기적인 지원을 제공하는 나일론-CF10을 사용하려면 프린터 펌웨어를 버전 2.6으로 업데이트해야 합니다.
QSR을 지원하는 나일론-CF10의 재료 정의가 업데이트되어 0.0100인치(0.2504mm) 및 0.0130인치(0.3302mm) 슬라이스 높이에 대한 채우기 동작을 개선했습니다.
다음에 대한 제작 시간 및 재료 볼륨 예측의 정확성을 개선합니다.
- 0.0200in(0.5040mm) Fortus 900mc 프린터에서 T40A 팁을 사용하는 ASA
- 0.0200in(0.5040mm) Stratasys F900 프린터에서 T40C 팁을 사용하는 나일론 CF12(Black)
- 0.0200in(0.5040mm) ULTEM 9085 Stratasys F900 및 Fortus 900mc 프린터에서 T40A 팁을 사용하는 Resin Black
- P3 작업에 대해 “인쇄” 버튼을 클릭한 후 인쇄 요약 창에서 1번째 레이어 또는 트레이 미리보기 썸네일을 눌러 쉽게 확대할 수 있습니다. 이렇게 하면 인쇄하기 전에 첫 번째 슬라이스의 세부 사항을 자세히 살펴볼 수 있습니다.
- 모델이 P3 작업을 위한 빌드 볼륨 외부에 배치된 경우 프로젝트 패널 창에 주황색 느낌표 알림이 표시되고 해당 알림 위로 마우스를 가져가면 문제가 설명됩니다.
- OpenAM 라이선스를 보유한 P3 사용자의 경우, GrabCAD Print는 이제 "edgeBuildingCompensation" 값을 포함하는 레이어별 설정 업로드를 지원합니다. 업로드 후 레이어별 설정 테이블에 해당 열이 표시됩니다.
GrabCAD Print 버전 1.77, 4월 2023
빌드 번호 1.77.13.26873 출시: 18 4월 2023
- 새 프로젝트를 시작하지 않고 인쇄 기술을 전환할 수 있는 기능이 복원되었습니다.
- PolyJet: 특정 어셈블리에 대한 치은 쉐이드를 변경할 때 어셈블리와 해당 쉘이 복제되고 트레이 트리에서 숨겨진 것으로 표시되었습니다.(숨겨진 어셈블리는 매우 복잡한 "실행 취소" 작업을 단순화하기 위해 생성되었습니다.) 이제부터 이러한 어셈블리는 트리에 표시되지 않으며 실행 취소 작업은 계속 정상적으로 작동합니다.
- SAF: 이제 구멍 크기, 빔 두께 및 간격을 지정하여 파트를 선택하고 신터 박스를 생성하여 파트를 포함하고 보호할 수 있습니다.
- P3: 전환 레이어 매개변수가 최적화되었으며 이제 검증된 재료에서 자동으로 처리됩니다. 이전에는 이 기능이 재료 속성 아래에 표시되었지만 지금은 숨겨져 있습니다.
- P3: 인치로 정의된 모델이 인쇄 전에 밀리미터 단위로 변경되는 문제가 있었는데, 이 문제가 해결되었습니다.
GrabCAD Print 버전 1.76, 3월 2023
빌드 번호 1.76.10.25761 출시: 21 3월 2023
- CMB를 가져올 때 스택(*.zip)이 파일 형식으로 표시되던 문제가 CMB 파일(*.cmb, *.cmb.gz)로 복원되었습니다.
- P3 인쇄의 경우 "트레이 설정"/"재료 속성"에 새로운 배율 매개변수가 표시됩니다. 이렇게 하면 인쇄된 파트가 재료 수축의 영향을 받는 경우 작업 수준에서 재료의 배율 값을 편집하고 최적화할 수 있습니다.
- P3 인쇄의 경우 "트레이 설정"/"재료 속성"에 새로운 추가 기본 레이어 매개변수가 표시됩니다. 부품의 Z 높이가 CAD 설계보다 낮은 경우 유용합니다. 추가 기본 레이어를 추가하면 첫 번째 레이어를 복제하여 높이 손실을 보정합니다.
- OpenAM 라이선스를 보유한 P3 사용자의 경우 CSV를 사용하여 수정된 “레이어별 설정”을 인쇄하는 것이 이제 정상적으로 작동합니다.
GrabCAD Print 버전 1.75, 2월 2023
빌드 번호 1.75.13.24793 출시: 21 2월 2023
- 소프트웨어를 더욱 강력하게 만들기 위해 다른 기술의 프린터(예: FDM에서 PolyJet)로 전환하려면 새 프로젝트 파일을 시작해야 합니다. 프로젝트에 모델을 추가하기 전에 프린터 기술 간에 자유롭게 전환할 수 있습니다.
- 이제 Fortus 450mc 프린터용 작업을 프로그래밍할 때 GrabCAD Print에서 검증된 재료를 사용할 수 있습니다. 이러한 재료는 프로그래밍 및 인쇄 작업에 사용하기 전에 기본적인 신뢰성 테스트를 통해 검증됩니다. 검증된 재료에는 6.7펌웨어 버전이 450mc에 설치되어 있어야 합니다.
검증된 재료 | 사용 가능한 슬라이스 높이 | 모델 팁 | 서포트 재료 | 서포트 팁 |
FDM HIPS(고충격 폴리스티렌) | 0.0100in(0.2540mm) | T16 | SUP1500B | T12 |
KimyaPC-FR(난연성) |
0.0100in(0.2540mm) | T16 | SR-100 | T12SR100 |
ULTEM™ 9085 Resin의 새로운 색상(Red, Aircraft Gray, Gunship Gray, Dream Gray, White 7362, Jana White) | 0.0100in(0.2540mm) | T16 | SUP8500B | T16 |
PC의 새로운 색상(Red, Black) | 0.0100in(0.2540mm) | T16 | SR-100 | T12SR100 |
PC-ABS의 새로운 색상(Red) | 0.0100in(0.2540mm) | T16 | SR-100 | T12SR100 |
(베타) VICTREX AM™ 200 PAEK(저융점) |
0.0100in(0.2540mm) | T14E | SR-100 | T12SR100 |
(베타) Covestro Addigy® PA6/66-GF20 FR LS(유리 충진 나일론, 난연성) |
0.0100in(0.2540mm) | T20G | SUP4000B | T16 |
- 재료 패키지는 이제 GrabCAD Print에서 지원됩니다. 재료 패키지는 재료가 OpenAM™에서 조정되고 컴파일되어 GrabCAD Print 및 OpenAM 라이선스로 활성화된 Fortus 450mc 프린터에 배포될 때 생성됩니다. Stratasys 선호 및 검증된 재료는 조정되어 패키지 및 타사 공개 자료에 포함될 수 있습니다. 재료 패키지에는 프린터 펌웨어 버전 6.7이 필요합니다.
- CMB 복제본(또는 복사/붙여넣기)의 툴패스가 원본 CMB와 동일하지 않았던 버그가 수정되었습니다.
- J35플랫폼을 기반으로 하는 J3 DentaJet™은 중소규모 치과 기공소를 위한 엔트리급 PolyJet 프린터입니다. 대량의 임플란트 모델, 수술용 가이드, 치은 마스크 등 세 가지 생체 적합성 재료의 혼합 트레이를 모두 동일한 트레이에서 탁월한 정확도로 제작할 수 있습니다. 새로운 J3 DentaJet™를 참조하십시오.
- PolyJet 프린터에 대한 작업 관리자 업그레이드를 요청하는 경고는 이제 GrabCAD Print와 작업 관리자의 버전이 일치하지 않는 경우에만 나타납니다. 이전에는 새 버전이 출시되는 즉시 경고가 표시되었습니다.
- 이제 PolyJet 인쇄를 위해 텍스처 VRML 모델에 코팅 레이어를 추가할 수 있습니다.
- SAF 프린터의 경우, 이제 PA12 재료(베타)를 사용할 수 있습니다. 여기에서 자세히 알아보기.
- SAF 프린터의 경우, 새로운 마우스 오른쪽 클릭 옵션을 사용하면 추정 또는 유효성 검사 후 유효하지 않은 모델을 선택할 수 있습니다.
- SAF 프린터의 경우, 각진 파트가 슬라이싱으로 인해 작은 표면 아티팩트를 나타내기도 하므로 슬라이싱 알고리즘이 이 문제를 방지하기 위해 더 정확해졌습니다.
- 인터넷에 액세스하지 않고 P3 인쇄를 하는 경우, 이제 Origin 로컬 허브를 통해 Origin One 로컬 프린터에 연결할 수 있습니다(자세한 내용은 Stratasys 지원 센터의 Origin One 로컬 참조 가이드에서 확인). 여기서 연결 지침을 참조하십시오.
- P3 프린터의 경우, 이제 Netfabb 등의 애플리케이션에서 만든 슬라이스를 파일 > 슬라이스 스택 가져오기를 사용하여 가져올 수 있습니다.
GrabCAD Print 버전 1.74, 1월 2023
빌드 번호 1.74.8.23921 출시: 17 1월 2023
- FIPS 호환 암호화를 사용하기 위한 Windows 보안 설정은 이전에 GrabCAD 제품에 대한 프린터 연결을 차단했으며 GrabCAD Print 및 인쇄 서버에 대해 해결되었습니다. PolyJet 작업 관리자가 설치된 시스템에서는 여전히 FIPS를 비활성화해야 합니다.
- 3 1.55에 소개된 DConnexion Spacemouse 지원이 이제 복원되었습니다.
- 트레이 재료에 모든 컬러 VeroFlex 재료가 포함된 경우 모든 J7xx/8xx 프린터에서VeroFlex 재료에 대한 CMYK 입력이 활성화되었습니다.
- 가장자리 보상이 Origin 프린터의 재료 매개변수에 추가되었습니다. 이 새로운 도구를 사용하면 각 슬라이스의 모델 가장자리에서 미크론을 추가하거나 뺄 수 있습니다. 이렇게 하면 약간 크거나 작은 구멍과 같은 피처가 표시되지만 모델의 배율을 변경하고 싶지 않은 경우에 도움이 됩니다.
GrabCAD Print 버전 1.73, 12월 2022
빌드 번호 1.73.5.23276 출시: 20 12월 2022
- Workbench에서 모델을 더 이상 추가할 수 없습니다. GrabCAD Workbench 사용 중단에 대한 자세한 내용은 여기 블로그 게시물을 참조하십시오.
- PolyJet 치과용 프린터의 경우 3모양과의 통합을 위해 치아 및 치은 쉐이드 이름을 나열하는 파일이 버전 1.72에 추가된 새 쉐이드로 업데이트되었습니다. 또한 존재하지 않는 셰이드 이름이 포함된 이전 프로젝트 또는 작업을 열 때 셰이드 이름이 비어 있고 알림이 표시됩니다. 사용자가 존재하지 않는 셰이드를 사용하는 사전 설정을 선택하면 기본 셰이드가 자동으로 설정됩니다.
- 이제 GrabCAD Print 제조 메모를 H350에서 사용할 수 있습니다. 이를 통해 사용자는 모델에 주석을 달고 모델의 스크린샷과 PDF 여행자 문서의 메모가 포함된 PDF 보고서를 만들 수 있습니다.
- 또한 H350의 경우 버그가 수정되어 이제 레이블 미리보기가 올바른 크기로 표시됩니다.
GrabCAD Print 버전 1.72, 11월 2022
빌드 번호 1.72.6.22542 출시: 16 11월 2022
- 0.0200인치(0.508mm) 슬라이스 높이가 Stratasys F900 프린터의 Nylon 12 CF에 대해 추가되어 대형 부품의 처리 속도를 높일 수 있습니다. 이 슬라이스 높이는 T40C 모델 팁을 사용합니다.
- 0.0200인치(0.508mm) 슬라이스 높이가 ULTEM™ 9085 Resin, ULTEM™ 9085 CG Resin 및 Stratasys F900 및 Fortus 900mc 프린터의 ULTEM™ 9085 Resin Black에 추가되었습니다. 새로운 슬라이스 높이는 대형 부품에서 처리 속도를 높입니다. 이 슬라이스 높이는 T40A 모델 팁을 사용합니다.
- H350 3D Nest에서 선택한 모델은 시각적으로 격리할 수 있으므로 선택하지 않은 모든 모델은 숨겨집니다. 사용자가 격리된 모델에 대한 작업을 마치면 모든 모델을 다시 표시할 수 있습니다. 이러한 작업은 3D Nest에서 부품의 위치를 변경하지 않습니다.
- H350의 경우 조립 명령 또는 그룹화된 3D 어레이로 생성된 CAD의 모든 어셈블리를 선택할 수 있으며 어셈블리 구조를 분해하여 개별 모델을 남길 수 있습니다.
- H350에 대한 추정치는 이제 전체 네스트 및 모델에 대한 질량과 전체 네스트에 대한 HAF 유체를 보고합니다.
- H350용 레이블 명령은 이제 명령 사용 간의 설정을 기억하므로 엠보싱/디보싱, 텍스트 크기 등이 동일하게 유지되어 수동 레이블 시퀀스를 훨씬 빠르게 생성할 수 있습니다.
- J5 DentaJet의 경우 일부 치아 쉐이드가 더 정확한 색상으로 개선되었고 두 가지 새로운 쉐이드가 추가되었습니다.
- J5 DentaJet의 경우 치은 쉐이드가 더 나은 텍스처로 개선되었습니다. 네 가지 새로운 쉐이드가 추가되었습니다.
GrabCAD Print 버전 1.71, 10월 2022
빌드 번호 1.71.7.21930 출시: 18 10월 2022
- J5 DentaJet 사용자는 이제 3Shape의 Dental System 소프트웨어와 GrabCAD Print를 사용하여 구강 스캔에서 풀 컬러 프린팅 모델에 이르기까지 엔드 투 엔드 워크플로를 활용할 수 있습니다. VeroDent PureWhite 및 Vero CMYK로 인쇄할 때 3Shape Color Model Profile이 J5 DentaJet에 추가되었습니다. 이 작업에는 3Shape Dental System 소프트웨어의 2022 릴리스가 필요합니다.
- 고급 슬라이서가 활성화된 상태에서 Connex 프린터로 작업을 보낼 때 인쇄 확인 화면에 알림이 나타납니다.
- 초고속 모드에서 J7/J8-Series 프린터에 인쇄된 작업은 일정 보기에 나타나지 않았으며, 이제 이 문제가 해결되었습니다.
- H350의 3D Nest 영역은 FDM 또는 PolyJet의 트레이 이름을 바꾸는 것과 유사하게 프로젝트 패널의 미리보기를 클릭하여 이름을 바꿀 수 있으며, 이렇게 하면 프린터로 전송되는 작업의 이름이 변경됩니다.
- H350에 대한 추정치를 위해 생성된 보고서의 내용을 복사하여 스프레드시트와 같은 다른 파일에 붙여넣거나 .XLSX 또는 .CSV 파일로 다운로드할 수 있습니다.
- OpenAM 라이센스가 없는 P3 사용자는 이제 GrabCAD Print를 통해 정확한 추정 결과를 얻을 수 있습니다. 여기 최신 블로그 게시물에서 자세히 알아보십시오.
GrabCAD Print 버전 1.70, 9월 2022
빌드 번호 1.70.12.21501 출시: 21 9월 2022
- GrabCAD Print는 이제 Windows 11 운영 체제를 지원합니다. 전체 시스템 요구 사항은 여기를 클릭하십시오.
- GrabCAD Print는 이제 Creo9, Inventor 2023, NX2206 및 Parasolid 34.1를 비롯한 최신 버전의 CAD 소프트웨어 파일을 지원합니다.
- GrabCAD Print는 이제 Origin One 및 Origin One Dental 프린터를 지원합니다. 파일 > 기본 설정 > P3 DLP에서 Origin 계정에 로그인하면 작업을 설정하고 프린터로 보낼 수 있습니다. 자세히 알아보기.
- FDM 프로젝트의 경우 이제 GrabCAD Print는 프로젝트를 검색하고 선택한 프린터를 찾을 수 없는 경우 작업 설정을 유지합니다. 설정에 적용된 프린터의 기본값이 있는 문제가 해결되었습니다.
- 이제 T14H 강화 압출 헤드가 Stratasys F370, F270 및 F170 프린터에서 지원됩니다. 수명이 1500시간인 헤드는 ABS-CF10 재료를 사용하는 프로그래밍 작업의 기본 선택입니다.
- 치과용 PolyJet 프린터의 경우 이제 치은에 쉐이드를 할당하는 것이 다중 선택에서 허용됩니다. 그러나 어셈블리당 단일 셸로 제한됩니다.
- J850 Prime Fabrix 및 TechStyle 모두에서 접착층의 유효한 두께가 3mm로 증가했습니다.
- PolyJet 버그 수정:
- J850 Prime Fabrix 및 TechStyle에서 계획된 중지와 함께 저장된 프로젝트는 계획된 중지 없이 열립니다.
- J5 DentaJet에서 유효한 프로젝트를 열 때 유효성 검사가 실패합니다.
- SHS 모드의 J5 DentaJet에서 모델 및 서포트 재료의 전체 추정이 잘못되었습니다.
- 다음 명령이 3H350용 D Nest 보기에 추가되어 사용자가 3D Nest 보기에서만 작업할 수 있습니다: 분석 모드, 단위, 배율, 모델 추가, X, Y 평면에서 자유롭게 드래그.
- 네스팅하기에 너무 큰 일부 모델이 포함된 여러 모델의 H350 빌드를 생성해도 더 이상 전체 네스트 작업이 실패하지 않습니다. 적합한 모델은 네스팅되고, 너무 커서 적합하지 않는 모델을 나열하는 경고가 표시됩니다.
- H350의 경우 이름 또는 번호 자동화를 사용하여 템플릿 레이블을 생성할 때 구문이 자동으로 검사되고 잘못된 경우 빨간색으로 강조 표시되며 툴팁에 오류가 자세히 표시됩니다.
GrabCAD Print 버전 1.69, 8월 2022
빌드 번호 1.69.12.20542 출시: 16 8월 2022
- 이제 J5MediJet™에서 두 가지 새로운 레진이 지원됩니다.
- 생체 적합성 Digital ABS Plus™는 고온 저항성과 인성을 결합하여 표준 ABS 플라스틱을 시뮬레이션하도록 설계되었습니다. 이 소재는 다양한 의료 응용 분야에서 생체 적합 부품의 기계적 성능을 크게 향상합니다.
WSS™150는 신속한 서포트 제거를 위한 수용성 서포트 재료입니다. 이 재료는 일반 수돗물로 채워진 용기에 넣으면 용해됩니다. 표준 또는 조리대 식기 세척기를 사용하여 더 빠른 서포트 제거 기능에 도달할 수 있습니다.
여기서 자세히 알아보기.
- J750/850 Digital Anatomy 트레이 재료에 RadioMatrix가 포함된 경우 모델 삽입 시 기본 재료로 선택되지 않습니다.
- PolyJet 연구 패키지와 3DFashion 프린터에 모두 액세스할 수 있는 경우 일부 기능이 충돌하므로 현재 프로젝트에 사용할 하나를 선택해야 합니다.
- J7-Series 및 J8-Series 프린터에서 유연한 동작으로 Agilus 색상 재료로 모델을 설정하기 위해 사용자 환경이 개선되었습니다. 관련 설정이 고급 옵션에서 기본 설정 항목으로 이동되었으며, 모든 설정 옵션에 자세한 툴팁이 추가되었습니다.
- 1.67 업데이트에서는 파일 > 기본 설정 > PolyJet 아래의 확인란이 기본적으로 설정되어 있는 고급 슬라이서를 사용하는 Connex3 프린터용 옵션을 도입했습니다. 고급 슬라이서는 그래픽 요구 사항이 더 엄격하며 일부 사용자의 경우 그래픽 드라이버와 관련된 오류가 발생하고 있었습니다. 고급 슬라이서 기본 설정을 해제한 후에도 오류가 지속되어 모든 작업이 대기하지 않는 버그가 있었습니다. 1.69 업데이트로 이 문제가 수정되었으며 기본 설정을 선택 해제하면 오류가 해결됩니다.
- H350의 경우 이제 팩의 높이를 시간(교대 근무 시간에 맞춰 작업을 준비하는 데 유용함) 또는 팩의 높이로 지정할 수 있습니다. 사용자가 입력한 매개변수가 다른 쪽을 업데이트했습니다.
- H350에 대한 추정치는 이제 요약 및 세부 정보 페이지가 포함된 빌드 보고서를 제공합니다. 요약 목록: 인쇄 시간, 총 볼륨, 네스트팅된 모델, 네스팅되지 않은 모델, 밀도,네스트 높이 및 축소. 세부 목록: 개별 부품, 각 부품의 사본 수 및 각 부품의 볼륨.
GrabCAD Print 버전 1.68, 7월 2022
빌드 번호 1.68.10.19783 출시: 19 7월 2022
- 다중 파일 3MF, OBJ 및 VRML 어셈블리는 이제 파일 > 어셈블리로 가져오기를 사용하여 STL과 동일한 방식으로 가져올 수 있습니다.
- ULTEM™ 9085 Resin용 서포트 재료는 SUP8500B 서포트로 리브랜딩되고 ULTEM™ 1010 Resin은 SUP9000B 서포트로 리브랜딩됩니다.
- 레이블(H350만 해당)의 경우 이제 레이블 텍스트의 엠보싱 높이 또는 디보싱 깊이를 지정할 수 있습니다.
- 3D 배열(H350만 해당)의 경우 이제 여러 모델을 선택하고 이러한 모델의 배열을 만들 수 있습니다.
- J850 TechStyle 및 J850 Prime Fabrix 모두 프린터를 연결할 때 현재 작업의 트레이 유형이 프린터에 설치된 트레이와 자동으로 동기화됩니다.
- 오른쪽 UV 램프 에어 덕트 필드 변경 명령을 받고 설치한 J7-Series 및 J8-Series 프린터에서 프린터 설정 대화 상자가 "업데이트된 에어 덕트가 설치되었습니다"라는 문구로 확장됩니다.
- MED620과 SUP711이 혼합된 ASR-620 DM은 이제 HQHS 인쇄 모드의 J5 DentaJet에서 사용할 수 있습니다.
- Color Agilus 재료는 Voxel Print 앱에서 사용할 수 있습니다.
- Flex-Touch(Smart 및 Full 모두)는 트레이의 모든 모델에 대한 공통 Flex-Touch가 아니라 모델별로 정의되어야 합니다.
GrabCAD Print 버전 1.67, 6월 2022
빌드 번호 1.67.10.19143 출시: 22 6월 2022
- 이전에는 J-Series 프린터에서만 사용할 수 있었던 고급 PolyJet 슬라이서가 이제 Connex3 프린터에서 지원됩니다. 고급 슬라이서는 다음과 같은 향상된 품질 및 추가 기능을 제공합니다.
- 투명한 흑백 프로파일의 그레이스케일
- 얇은 영역/코너 처리
- 보다 정확한 추정 및 오프셋
더 나은 그리드 제어
이전 인쇄를 정확하게 복제해야 하는 경우 파일 > 기본 설정 > PolyJet을 사용하여 레거시 슬라이서로 다시 전환할 수 있습니다.
- J850™ Prime용 FabriX™ Innovation Kit를 사용하면 PolyJet™ 프로토타이핑 및 CMF 기능을 섬유와 유연한 기판에 직접 인쇄하는 새로운 세계로 확장할 수 있습니다. 이제 메시 소재, 기능성 의류 프로토타입, 그리고 여과 시스템 시각화가 포함된 애플리케이션에서도 다양한 디자인을 테스트할 수 있습니다.
- Digital Anatomy Printer에서 사용할 수 있는 최초의 방사선 불투과성 3D 인쇄 재료인 RadioMatrix™를 소개합니다. 새로운 재료는 CT 또는 X-레이 스캔에 나타날 수 있는 다양한 대비의 방사선불투과성 특성을 가진 3D 인쇄된 해부학적 모델을 가능하게 합니다. RadioMatrix™ 재료 설정이 원하는 Hounsfield 값으로 방사선 불투과성 3D 인쇄 해부학 모델을 제공하는 Digital Anatomy Printer 소프트웨어에 추가되었습니다.
- 새로운 Netting-Fabric Insert 기능을 통해 사용자는 작업 중에 인쇄할 미디어를 삽입하기 위해 인쇄 도중 중지를 계획할 수 있습니다. J850 TechStyle 및 J850 Prime FabriX 시스템에서 활성화된 기능입니다.
- AgilusCMY 모델용 Rigid Core를 사용하면 Agilus 색상 프로파일을 사용하여 "부드러운 터치"의 강성 모델을 한 번 인쇄할 수 있습니다. 그 결과 부드러운 외부 표면으로 얇은 풀 컬러 텍스처(1mm 풀 컬러 Shore A 30)를 가진 강성 모델이 생성됩니다.
- AgilusCMY 재료에 대한 CMYK 입력을 사용하면 순수 AgilusCMY 재료에 대한 CMYK 숫자 값 입력으로 원하는 특정 색상 톤을 정의할 수 있습니다.
- 사용자는 J5 DentaJet의 고품질 고속 모드를 통해 이제 절반의 시간에 동일한 품질로 치과 모델, 수술 가이드 및 기타 애플리케이션을 인쇄할 수 있습니다. 적절한 재료 구성을 선택하고 프린터에서 재료 교체 마법사를 실행하면 GrabCAD Print에서 고품질 고속 모드를 선택할 수 있습니다.
- H350의 경우 이제 GrabCAD Print에 로드된 여러 최상위 모델에서 어셈블리를 생성할 수 있습니다. 모델은 3D 드래그 위젯 또는 위치 도구를 사용하여 3D 공간에 배치된 다음 네스팅될 수 있는 어셈블리로 만들어집니다.
- H350용 3D 어레이 도구는 이제 어셈블리를 어레이의 소스로 지원합니다.
- 이제 팩 높이를 H350용 3D Nest 도구의 중지 기준으로 사용할 수 있습니다. 네스트 프로세스가 선택한 모든 모델을 성공적으로 압축하면 지정된 높이에 도달할 때까지 팩 높이를 줄이려고 시도합니다.
- H350용 3D Nest 명령에서 최소 모델 간격의 기본값은 이제 2mm이며 3mm에서 줄었습니다. 즉, 더 조밀한 네스트를 안전하게 만들 수 있습니다.
GrabCAD Print 버전 1.66, 5월 2022
빌드 번호 1.66.7.17878 출시: 17 5월 2022
- F123 Series의 최신 제품인 Stratasys F370 CR 및 Stratasys F190 CR을 소개합니다. 이 복합용(CR) 프린터는 Stratasys의 최신 FDM 복합 재료인 나일론-CF10 및 현재 재료인 ABS-CF10을 비롯한 충진 재료와 함께 사용하도록 설계되었습니다. 이를 통해 기존 제작 기술 및 재료를 사용하는 데 소요되는 시간의 극히 일부로도 강력한 워크홀딩 고정 장치, 압형, 파트를 내부에서 더 쉽게 생산할 수 있습니다. 프린터는 8 엔지니어링 등급 재료를 지원하며 GrabCAD Print의 직관적인 인터페이스와 사용하기 쉬운 Advanced FDM 기능을 사용하여 프로그래밍됩니다. 여기에서 F123 복합용 프린터에 대해 자세히 알아보십시오.
- J850 TechStyle 3D 프린터는 3DFashion™ 기술로 구동되며 직물, 가죽, 의류에 직접 인쇄할 수 있는 디자인과 작은 패션 액세서리 인쇄를 위한 풀 컬러, 다중 재료 기능을 제공하여 기존의 방식으로는 달성할 수 없는 결과를 제공합니다. 여기에서 자세히 알아보십시오.
- GrabCAD Print가 이제 H350 SAF 기술 프린터를 지원합니다. 라이센스가 있는 사용자는 인쇄를 할 수 있고 라이센스가 없는 사용자는 기능을 탐색하여 가능성을 학습하고 평가할 수 있습니다. 여기에서 자세히 알아보십시오.
- 이제 마우스 오른쪽 버튼 클릭 메뉴를 사용하여 GrabCAD Print에서 모델을 미러링할 수 있습니다. 이 기능은 모든 인쇄 기술을 위한 메시 및 CAD 파트, 표면 색상 및 질감이 있는 모델, 어셈블리 내 모델, 전체 어셈블리의 미러링을 지원합니다. 현재 고급 FDM 기능이 있는 모델 및 레이블이 있는 모델의 미러링은 지원하지 않습니다.
- 나일론-CF10(탄소 강화 나일론 혼방)은 Stratasys F370 CR 및 Stratasys F190 CR 프린터에 사용할 수 있습니다. 재료에는 중량 기준으로 10% 절단된 탄소 섬유가 포함되어 있어 ABS-CF10보다 더 강하고 내화학성이 우수한 3D 프린팅 모델이 만들어집니다. 나일론-CF10은 0.0070인치(0.1778mm), 0.0100인치(0.2540mm), 0.0130인치(0.3302mm) 슬라이스 높이에 지원되며 인쇄를 위해 새로운 경화 헤드(T20H)가 필요합니다. 여기에서 나일론-CF10에 대해 자세히 알아보십시오.
- 새로운 경화 헤드(T14H)는 ABS-CF10 인쇄에 사용할 수 있으며 인쇄 수명은 1500시간입니다. T14H 헤드는 선택 사항입니다. T14 헤드는 ABS-CF10과 함께 계속 사용할 수 있지만 헤드 수명이 단축됩니다.
- 새로운 Agilus30™ 컬러 레진(청록색, 마젠타색, 노란색)을 사용하면 반복적인 휨과 굽힘을 견딜 수 있는 고품질의 표면 및 높은 유연성으로 풀 컬러의 고무형 파트를 위한 고무 또는 실리콘 질감의 제품 프로토타이핑이 가능합니다. 여기에서 자세히 알아보십시오.
- WSS(수용성 서포트), VeroUltraClearS 및 VeroUltraClear 재료를 이제 VoxelPrint에서 사용할 수 있습니다.
- H350의 경우 레이블 도구를 사용하여 모델 표면에 엠보싱 또는 디보싱된 텍스트를 추가합니다. 또한 파트를 복제할 때 여러 차례 적용하거나 자동으로 적용할 수 있는 레이블 템플릿을 만들 수 있습니다. 여기에는 파트 이름이 자동으로 포함되거나 일련 번호가 생성될 수 있습니다.
- H350의 경우 X, Y, Z에 직사각형 어레이를 만들 수 있습니다. 어레이를 단일 개체로 동작하도록 그룹화하거나 개별 모델로 만들 수 있습니다.
GrabCAD Print 버전 1.65, 4월 2022
빌드 번호 1.65.13.17318 출시: 21 4월 2022
- J850 Digital Anatomy Printer를 소개합니다. J850 Digital Anatomy Printer는 인체 조직의 모양과 반응을 모두 정확하게 나타내는 놀라운 사실감으로 의료 모델을 생생하게 묘사합니다. 이러한 모델은 의료 전문가와 의료 기기 회사에 비교할 수 없는 수준의 임상적 다양성, 반복성, 정확성을 제공합니다. 여기에서 자세히 읽어보십시오.
- SOLIDWORKS 2022, Inventor 2022 등을 포함하도록 지원되는 파일 형식을 업데이트했습니다. 전체 목록은 지원되는 파일 형식 목록에서 확인하십시오.
- 일부 사용자에게 프록시 또는 자체 서명된 인증서로 인해 네트워크 연결 문제가 발생했습니다. '파일' > '기본 설정' > '개인 정보'의 새로운 옵션을 사용하면 Windows 인증서 저장소의 인증서를 GrabCAD Print에서 신뢰할 수 있는 인증서로 설정하여 이러한 많은 문제를 해결할 수 있습니다. 애플리케이션은 이러한 구성을 감지하면 자동으로 기본 설정을 지정합니다.
- Digital Anatomy 프린터를 위한 새로운 추가 기능 소프트웨어 모듈인 Digital Anatomy Creator를 소개합니다. 정교한 수학적 함수를 사용하는 Creator 소프트웨어는 사용자에게 해부학 모델의 내부 구조를 사용자 지정할 수 있는 전례 없는 자유도를 제공합니다. 기존 해부학적 사전 설정에 더해 추가적인 설정을 만들고 디지털 재료를 보정하여 정확한 사양을 충족합니다. 쉽게 재료 형성을 조작하고 내부 미세 구조를 사용자 지정하여 특정 해부학적 결과를 얻을 수 있습니다. 여기에서 자세히 알아보십시오.
- 이제 새로운 레진이 PolyJet 시스템의 Voxel Print에서 지원됩니다. 지원되는 모든 프린터의 VeroUltraWhite 및 VeroUltraBlack, J5 MediJet의 DraftWhite
GrabCAD Print 버전 1.64, 3월 2022
빌드 번호 1.64.9.16414 출시: 17 3월 2022
- Diran 410MF07의 파트 품질은 다음과 같은 방식으로 Stratasys F370 프린터에서 개선되었습니다.
- 0.0070인치(0.1778mm) 슬라이스 높이의 경우 위쪽 및 아래쪽을 가리키는 가시 표면에 대한 채우기 밀도가 향상되고 파트의 바닥 표면과 베이스 위쪽 표면 사이의 접착력이 향상됩니다.
0.0130인치(0.3302mm) 슬라이스 높이의 경우 이음매 품질, 수직 표면, 채우기 밀도가 향상됩니다.
이러한 개선을 위해서는 프린터 펌웨어를 2.4 릴리스로 업데이트해야 합니다.
GrabCAD Print 버전 1.63, 2월 2022
빌드 번호 1.63.8.15371 출시: 16 2월 2022
- WSS™150는 J55 Prime 및 J35 Pro PolyJet 시스템에서 빠른 서포트 제거를 위한 수용성 서포트 재료입니다. WSS150은 일반 수돗물로 채워진 용기에 넣으면 용해됩니다. 일반 또는 조리대용 식기세척기를 사용하면 더 빠르게 서포트를 제거할 수 있습니다. 또한 L2S™ 파우더는 현지 규정에 따라 후속 처리를 위해 보낼 필요 없이 폐수를 안전하게 처리하는 데 사용할 수 있습니다.
- 슬라이스 미리 보기 패널이 업데이트되었습니다.
- 이제 모델 및 서포트 재료에 사용된 이름, 슬라이스 높이, 팁을 표시합니다.
- 기능 표시 필터(안정기, 앵커, 이음매, 일시 중지)가 재구성되었습니다.
애니메이션(애니메이션 재생, 레이어 선택, 헤드 이동) 및 Z 일시 중지(Z 일시 중지 추가/제거, 일시 중지 목록)에 대한 컨트롤이 그룹화됩니다.
이제 재료 및 슬라이스 높이에 대한 정보가 슬라이스 미리 보기 패널에 표시되므로 모델 설정 패널에 대한 액세스가 슬라이스 미리 보기에서 제거됩니다.
- J55 Prime 또는 J8 Prime에서 포장 최적화 기능을 사용하면 VeroUltraClear를 지원하는 CMYK 입력을 사용하여 투명 색상을 미세 조정할 수 있습니다. 이를 통해 모든 병이나 액체에 뛰어난 투명도와 채도가 제공됩니다.
- J5 DentaJet PolyJet 프린터는 더 빠르고 정확한 치과 인쇄를 위해 새롭고 개선된 매개 변수 세트를 사용합니다.
- 이제 PolyJet 시스템의 VoxelPrint에서 새로운 레진이 지원됩니다.
- 지원되는 모든 프린터의 VeroUltraWhite 및 VeroUltraBlack
- J5 MediJet의 DraftWhite
GrabCAD Print 버전 1.62, 1월 2022
빌드 번호 1.62.8.14676 출시: 19 1월 2022
- Fortus 450mc 프린터에 ULTEM™ 9085 및 인증 등급의 ULTEM™ 9085 CG 모델 재료에 사용할 수 있는 T16A 모델 팁이 추가되었습니다. 이는 우주 항공기 내부를 비롯하여 파트 인증이 필요한 분야에 사용할 수 있도록 표준 T16 팁에 비해 반복성이 높은 기계적 특성과 향상된 품질을 제공합니다. T16A 모델 팁의 레이어 두께는 0.010인치(0.2540mm)입니다. T16A 모델 팁을 사용하려면 Fortus 450mc용 컨트롤러 소프트웨어를 6.6.6906 릴리스로 업데이트해야 합니다.
- 이제 Fortus 450mc 프린터에서 T20 모델 팁을 사용하는 ULTEM™ 9085 Black에 슬라이스 높이 0.0130인치(0.3302mm)가 지원됩니다. 더 두꺼운 슬라이스는 더 빠른 파트 빌드와 처리량 증가를 가능하게 합니다. 새 슬라이스 높이를 사용하려면 컨트롤러 소프트웨어를 6.6.6906 릴리스로 업데이트해야 합니다.
- 다른 개선 사항과 함께 몇 가지 사소한 버그가 수정되었습니다.
GrabCAD Print 버전 1.61, 12월 2021
빌드 번호 1.61.12.14139 출시: 22 12월 2021
- 풀 컬러 PolyJet 인쇄를 사용하면 이제 '바디 모양'이 색상 선택기로 색상을 변경할 때 텍스처 바디의 기본 코어가 됩니다. 이는 최근 출시된 '텍스처 덮어쓰기' 옵션(기본적으로 비활성화되어 있음)과 관련이 있어 간단하고 직관적인 워크플로로 텍스처 바디의 색상과 투명도를 변경할 수 있습니다.
- J5-Series 프린터에서 작업의 지연된 시작 시간을 설정하는 경우 기존 시작 시간 또는 종료 시간 외에도 새 시간 설정 옵션을 사용할 수 있습니다. 작업 중에 재료가 소진되면 재료 캐니스터를 교체할 시간을 설정할 수 있습니다. 그러면 프린터가 적절한 시간에 작업을 시작합니다.
- Digital Anatomy Printer의 경우 새로운 '봉합 가능 혈관 벽' 사전 설정은 봉합용 혈관 모델에 대해 향상된 성능과 내구성을 제공합니다.
- 동일한 모델에 앵커와 안정기를 만들 수 없는 문제가 수정되었습니다.
GrabCAD Print 버전 1.60, 11월 2021
빌드 번호 1.60.9.13125 출시: 17 11월 2021
- GrabCAD Print의 오른쪽에서 수정된 모양을 확인할 수 있습니다. 아이콘은 약간 더 작으며 창 측면에 고정되어 있습니다. 도구가 상시 추가되므로, 작은 화면을 사용하는 분들을 위해 설치 공간을 약간 줄였습니다.
- 이제 PolyJet 프린터로 변위(범프) 맵이 포함된 모델을 인쇄할 수 있습니다. 파일 > 환경설정 > GrabCAD Labs에서 이 기능을 활성화하면 Keyshot.3MF 또는 표준 .OBJ 모델에 포함된 범프 맵이 인쇄된 부품의 표면 마감으로 변환됩니다. 이전에는 범프 맵을 파일의 3D 메시에 작성해야 했으므로 불필요하게 큰 파일이 생성되었습니다. 이제 범프 맵을 직접 읽을 수 있습니다. 변위 높이는 모델 설정에서 조정하거나 0로 설정하여 비활성화할 수 있습니다. 여느 Labs 기능과 마찬가지로 Stratasys는 이 기능에 대한 고객의 피드백을 소중하게 생각합니다.
- J35 Pro에서 재료 사용률 모드라는 새로운 모드를 사용할 수 있습니다. 새 모드에서는 남은 재료를 최대한 활용하기 위해 프린터가 색상 혼합을 자동으로 결정하게 할 수 있습니다. 인쇄 시점에 남은 재료에 따라 최종 색상이 결정되므로, 인쇄된 부품은 GrabCAD Print의 시각화와 다르게 보입니다. 이 옵션은 ‘인쇄 요약’ 창에서 사용할 수 있습니다.
- 바디 색상을 바꾸면서 질감을 유지하는 기능입니다. 이전에는 텍스처 모델에 새 색상을 적용하면 텍스처가 덮어쓰기되었습니다. 이제 새 색상을 적용하면 텍스처 아래의 바디 색상이 업데이트되며, 덮어쓰기도 가능합니다. 선택한 ‘기반 및 코어 옵션’은 색상이 일치하지 않는 경우 이를 덮어쓰기합니다.
- 헤비 모델이 많이 포함된 PolyJet 작업 인쇄를 위한 새로운 최적화입니다. 헤비 모델로 트레이를 채우는 경우 이 기능을 사용하여 모델을 자동으로 최적화하십시오. 이 기능을 사용하면 품질이나 모델 정확도의 저하 없이 모델의 복잡성을 자동으로 줄일 수 있습니다.
- 최신 NVIDIA 그래픽 드라이버에서 있었던 일부 PolyJet 작업의 추정 및 인쇄를 방해하는 문제를 해결했습니다.
- 조각 미리 보기에서 안정기와 같은 색상의 안정기가 있는 모델이 표시되던 문제를 해결했습니다.
GrabCAD Print 버전 1.59, 10월 2021
빌드 번호 1.59.11.12349 출시: 25 10월 2021
- 이제 J55 Prime에서 사용 가능한 색상이 검정색과 흰색 뿐인 재료 구성을 설정할 때 새로운 그레이스케일 슬라이더를 사용할 수 있습니다. 또한 텍스처를 로드하면 텍스처가 흑백 프로파일을 사용합니다.
- 프로젝트를 저장할 때 모델의 바디 두께에 대한 변경 사항이 저장되지 않던 문제를 해결했습니다.
- 자체 서포트 구멍이 포함된 모델의 경우 프로젝트의 바디 및 얼굴 설정이 저장되지 않는 문제를 해결했습니다.
GrabCAD Print 버전 1.58, 9월 2021
빌드 번호 1.58.9.11590 출시: 23 9월 2021
- ‘프로젝트 설정 유지’를 사용하면 프로젝트를 동일한 유형의 프린터(예: Stratasys F370에서 Stratasys F370)로 전환할 때 FDM 프린터용 프로젝트의 설정을 유지할 수 있습니다. 새 프린터와 일치하지 않는 경우에도 현재의 인쇄 설정을 유지하거나 새 프린터를 기반으로 설정을 업데이트하도록 선택할 수 있습니다.
- ‘바디 모양’을 선택한 경우에도 흰색 코어가 인쇄되는 일부 풀 컬러 PolyJet 인쇄 버그가 수정되었습니다. 코어 설정이 수동으로 변경된 1.56 또는 1.57에 저장된 프로젝트는 다시 생성해야 합니다.
GrabCAD Print 버전 1.57, 8월 2021
빌드 번호 1.57.8.10644 출시: 19 8월 2021
- J55™의 획기적인 업데이트인 Stratasys® J55™ Prime을 소개합니다. J55 Prime 3D 프린터는 촉각, 기능 및 감각 기능을 갖춘 풀 컬러 고해상도 사양을 도입하여 PolyJet 기술의 효율성과 품질을 그 어느 때보다도 저렴하고 사무실 친화적으로 만듭니다. 고무와 비슷한 쇼어(Elastico™), High Impact(디지털 ABS), Rigid Ultra Visual(VeroUltra™, DraftGrey), Translucent(VeroUltra™ClearS) 및 Bio-Compatible(Vero™ContactClear) 재료의 조합과 최첨단 인쇄 기능을 포함합니다. 빠른 설계 반복부터 고품질 최종 프로토타입에 이르기까지 모두 짧고 조용하며 냄새 없는 프로세스를 통해 신속하게 제작 가능합니다. 여기서 새로운 J55 Prime을 확인하십시오.
- Stratasys® J35™ Pro를 소개합니다. J55™ Prime의 회전 트레이 플랫폼을 기반으로 하는 J35™ Pro는 기능적 설계 및 개념 모델링을 위한 다중 재료 기능을 갖춘, 공유 사무실 환경에 적합한 저비용 PolyJet 3D 프린팅 솔루션입니다. 새로운 3D 프린터는 고무와 비슷한 쇼어(Elastico™), High Impact(디지털 ABS), Rigid Ultra Visual(VeroUltra™, DraftGrey), Translucent(VeroUltra™ClearS) 및 Bio-Compatible(Vero™ContactClear) 재료의 조합과 최첨단 인쇄 기능을 포함합니다. 프린터 크기가 작아 사무실에 쉽게 설치할 수 있으며, ProAero 여과 시스템 덕분에 작업 환경에서 냄새가 전혀 없습니다. 여기서 새로운 J35 Pro를 확인하십시오.
- 최초로 Print의 CAD 버전 지원에 대한 주기 중 업데이트를 수행했습니다. 이제
- 이제 조각 미리 보기에서 앵커 및 안정기의 표시를 제어할 수 있습니다.
- 앵커와 안정기는 고유한 색상으로 표시되어 모델 및 서포트와 쉽게 구분할 수 있습니다.
- 표시 목록의 옵션을 사용하여 앵커 및 안정기 표시를 끄면 모델을 더 쉽게 점검할 수 있습니다.
- 앵커 및 안정기 표시 옵션은 이러한 기능이 작업에 포함된 경우에만 나타납니다.
- 앵커 및 안정기 표시 설정은 저장되어 다음에 조각 미리 보기로 이동하면 동일하게 표시됩니다.
- 또한 이제 레이어 강조 표시의 색상이 투명한 흰색으로 변경되어 각각 모델, 서포트, 앵커 및 안정기에 해당하는 조각이 무엇인지 더 쉽게 알아볼 수 있습니다.
- Digital Anatomy Printer의 두 가지 업데이트:
- TissueMatrix와 GelMatrix를 혼합하여 활용하는 총 6개의 새로운 사전 설정으로 매우 사실적인 피하지방조직 모델을 인쇄합니다. 연성이 서로 다른 기본 모델 기능은 수축성 피하지방(매우 부드러움)과 고도로 수축성인 피하지방(가장 부드러움)이며, 코팅 옵션은 다음과 같습니다.
- 강성 코팅 – 2mm의 Agilus로 코팅하여 보다 내구성 있는 독립형 모델을 만듭니다.
- 연성 코팅 – 독립형 샘플에 사실적인 부드럽고 끈적한 모양과 느낌을 주기 위해 2mm의 Agilus와 GelMatrix 혼합물로 코팅합니다.
- 비캡슐화 – 지방 조직이 장기 모델의 일부로 포함되는 용도로 사용하기 위해 코팅을 하지 않습니다.
- GelMatrix Enhanced Capabilities는 더 많은 해부학 모델링 옵션을 제공하며, 필요한 후처리가 더욱 간단하고 짧습니다. 해부학 모델 설정 메뉴에서 새로운 기능 두 가지를 찾아보십시오.
- GelMatrix를 서포트 재료로 사용하여 다양한 해부체 인쇄
- 다른 재료 없이 순수한 GelMatrix 재료만 사용하여 인쇄
GrabCAD Print 버전 1.56, 7월 2021
빌드 번호 1.56.11.9996 출시: 20 7월 2021
- 이제 PolyJet 모델 설정 패널에 사전 설정이라는 섹션이 포함됩니다. 색상 선택 전용 섹션인 즐겨찾기 섹션이 이미 있지만, 사전 설정에는 색상뿐 아니라 다른 모델 설정도 모두 포함됩니다. 사전 설정을 저장하려면 트레이 부분을 마우스 오른쪽 버튼으로 클릭합니다. 사전 설정이 추가되면 마우스 오른쪽 버튼을 클릭하여 기본값으로 설정할 수 있습니다. 나중에 트레이에 추가된 모델에는 사전 설정이 적용됩니다.
- J8 시리즈 Prime의 새로운 기능: ‘포장 최적화’를 사용하면 간단한 작업흐름으로 포장 프로토타입의 외관을 멋지게 꾸밀 수 있습니다. 이제 사용자는 RGB에서 인쇄된 색상으로 투명도를 변환하는 최초의 기능을 활용하여 액체나 유색 유리와 같은 볼륨의 투명도를 더욱 정확하게 구현할 수 있습니다. 또한 라벨 뒤에 자동 흰색 언더프린트가 생성되어 그래픽이 높은 불투명도로 그래픽이 멋지게 완성됩니다. 이 옵션은 Vero Vivid 색상, UltraWhite+UltraBlack 및 UltraClear를 사용하는 풀 컬러 J8 프린터와 Keyshot의 3MF 파일에서 사용할 수 있습니다(이 기능을 활성화하려면 print@grabcad.com에 문의하십시오).
- 앵커 기능 개선:
- 모델과 트레이 간 앵커 생성 및 편집(가장 빈번한 사용 사례)을 단순화하기 위해 앵커 창이 열리면 모델 보기가 자동으로 아래쪽 보기로 설정됩니다.
- 앵커가 편집되고 모델 보기가 앞, 뒤, 왼쪽 또는 오른쪽일 때 트레이가 얇은 미리 보기로 전환되어 세트에 포함된 앵커의 미리 보기 형상을 더 쉽게 검사할 수 있습니다. 앵커 창을 닫으면 더 두꺼운 트레이 보기가 복원됩니다.
- Stratasys F900 및 Fortus 800mc 플랫폼의 Antero 450NA와 F900 플랫폼의 Antero 840CN03에 T20F 모델 팁이 추가되었습니다. T20F 모델 팁은 동일한 부품 품질과 정확도로 현재 T20D 모델 팁에 비해 최대 20% 향상된 기계적 성능을 제공합니다. T20F 모델 팁을 사용하려면 지원되는 재료를 선택한 후 슬라이스 높이 드롭다운 메뉴의 | T20F(0.2540mm | T20F)에서 {4}을(를) 선택하십시오.
- 펌웨어 버전 4.11.0은(는) Stratasys F900 및 Fortus 900mc 프린터에 사용할 수 있습니다. 이 업데이트는 일반적인 다운로드된 업그레이드(.upg) 파일으로는 사용할 수 없습니다. 이 중요 업데이트에 대한 정보는 서비스 담당자 또는 Stratasys 고객 지원팀에 문의하십시오.
GrabCAD Print 버전 1.55, 6월 2021
빌드 번호 1.55.8.8912 출시: 16 6월 2021
- SpaceMouse 3D 마우스는 이제 GrabCAD Print의 보기 조작에 지원됩니다. 여기서 튜토리얼을 확인하십시오.
- 냉각 시 말릴 수 있는 짧고 넓은 모델의 경우, 앵커 기능을 사용하면 인쇄 중에 모델을 빌드 트레이에 고정할 수 있습니다. 앵커 기능은 모델의 바닥을 향하는 수평 표면을 빌드 트레이에 고정하는 모델 재료로 만들어진 기둥입니다. 앵커는 개별적으로 생성되거나 스타일과 직경을 공유하는 세트로 생성된 원통 또는 원뿔일 수 있습니다. 여기를 클릭하여 앵커 구성에 대해 자세히 알아보십시오.(Stratasys F770, F370, F270, F170, F900 및 Fortus 시리즈 프린터에서 지원됩니다.)
- 이제 안정기를 생성하기 전에 참조 곡선을 선택해야 합니다. 이렇게 하면 패널을 처음 열 때 안정기가 즉시 생성되는 것을 방지하고 안정기를 생성하기 전에 설정을 조정할 수 있습니다.
- 살균 및 생체 적합성 재료를 사용하여 해부학적 모델, 수술 가이드 및 의료 도구를 위해 설계된 완전히 새로운 올인원 의료용 프린터 J5 MediJet™을 소개합니다. J5 MediJet은 의료 3D 프린팅 응용 분야의새로운 표준을 설정하고 있습니다. 여러 재료 및 여러 색상 기능을 사용하여 인증된 시스템에서 놀랍도록 생생한 해부학 모델, 드릴링 및 절단 가이드, 멸균 및 생체 적합성이 있는 의료 도구를 만들 수 있습니다. 또한 경제적이고 작은 실험실 공간에 적합합니다. 여기서 자세히 알아보십시오.
- PolyJet 프린터용 오른쪽 메뉴의 새로운 도구를 사용하면 기본 설정에 정의된 단위를 사용하여 트레이에서 정확한 위치를 설정할 수 있습니다.
- 알림: 다음 릴리스에서는 풀 컬러로 VeroPureWhite를 사용할 때 풀 컬러 J-Series 프린터의 고급 컬러 하프톤이 기본적으로 새 트레이에 대해 선택됩니다.
GrabCAD Print 버전 1.54, 5월 2021
빌드 번호 1.54.6.7969 출시: 18 5월 2021
- Stratasys F770 ™ 3D 프린터는 시장에서 가장 긴 완전 가열 빌드 챔버(대각선 46인치)를 갖추고 있습니다. 넓은 제작 범위는 13입방 피트({3\}리터) 이상이므로, 더 작은 프린터로는 불가능한 제조, 프로토타이핑 및 생산 부품 응용 분야를 위한 새로운 기회를 열어줍니다. Stratasys F770 자세히 알아보기.
- 기존 서포트가 많이 필요하지 않은 높고 얇은 모델의 경우 새로운 안정기 기능을 사용하면 모델을 빌드할 때 스캐폴딩을 추가할 수 있습니다. 안정기는 일정한 간격으로 모델 측면에 부착되는 높은 서포트 구조로, 추가 서포트를 제공하고 진동을 최소화합니다. 안정기 구성에 대해 자세히 알아보려면 여기를 클릭하십시오.(Stratasys F770, F370, F270, F170, F900 및 Fortus 시리즈 프린터에서 지원됩니다.)
- F123 Series 프린터에서 "가변 폭 채우기 사용" 확인란이 비활성화된 문제가 수정되었습니다.
- FDM 모델의 캡 표면에 대해 다음과 같은 툴패스 문제가 수정되었습니다.
- 작은 캡 표면은 더 이상 필요한 래스터 채우기의 두 배를 받지 않습니다.
- 캡 표면의 작은 구멍은 더 이상 무시되지 않습니다.
- 어셈블리의 구성 요소에 다양한 PolyJet 마감(무광택 또는 광택)을 할당할 수 있도록 GrabCAD Labs 기능이 1.48에 도입되었습니다. 더 이상 옵션이 아니며 항상 사용할 수 있습니다.
GrabCAD Print 버전 1.53, 4월 2021
빌드 번호 1.53.15.7152 출시: 20 4월 2021
- 슬라이스 미리보기를 선택한 경우 이제 레이어 범위의 기본값은 "모든 레이어"입니다. 레이어 범위에 대한 변경 사항은 다음에 슬라이스 미리보기를 선택할 때 저장됩니다.
- 이 새로운 불투명 소재를 사용하면 얇고 사실적인 플라스틱 모델을 인쇄할 수 있고, 높은 정확도의 색 재현율, 포장 라벨 인쇄를 위한 선명한 텍스트, 부드러운 고해상도 피부톤을 제공할 수 있습니다.
GrabCAD Print 버전 1.52, 3월 2021
빌드 번호 1.52.8.6136 출시: 16 3월 2021
1.52업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 탄소 섬유 강화 ABS는 Stratasys F370, Stratasys F270 및 Stratasys F170 프린터에서 사용할 수 있습니다. Stratasys ABS-CF10은 표준 ABS(아크릴로 니트릴 부타디엔 스티렌) 재료와 중량 기준으로 10% 절단된 탄소 섬유를 결합합니다. 그 결과 습기에 민감하지 않은 FDM® 열가소성 수지가 표준 ABS 3D 인쇄 재료보다 50% 더 견고하고 15% 더 강합니다. 일반적인 응용 분야에는 증가된 강성과 감소된 무게의 조합으로 이익을 얻는 제조 도구, 지그, 고정 장치 및 엔드 이펙터가 포함됩니다. ABS-CF10은 0.0070인치 (0.1778mm), 0.0100인치(0.2540mm) 및 0.0130인치(0.3302mm) 슬라이스 높이에서 지원됩니다. 여기서 새로운 ABS-CF10 소재에 대해 자세히 알아보십시오.
- J5 DentaJet™을 소개합니다. J55 플랫폼 기반의 J5 DentaJet 3D 프린터는 치과용 3D 프린터의 다중 재료 라인에 새로 추가된 제품으로, 기술자는 치과용 부품의 혼합 트레이를 로드할 수 있습니다. 새로운 3D 프린터는 경쟁사 3D 프린터보다 단일 혼합 트레이에서 최소 5배 더 많은 치과용 부품을 생산할 수 있지만 설치 면적은 겨우 4.6평방 피트(.43m2)입니다. 새로운 J5 DentaJet를 확인해 보십시오.
- Antero 840CN03으로 제작된 모델과 서포트 구조 사이의 기본 레이어와 인터페이스 레이어가 개선되어 아래쪽을 향하는 모델 표면의 품질이 향상됩니다. 안정성을 높이기 위해 서포트 구조도 변경되었습니다.
- Diran 410MF07의 경우 슬라이스 높이 0.0010(0.2540mm), 솔리드 채우기의 경우 최소 바디 두께가 0.0200인치(0.5080mm)로 낮아지고 기본 자체 서포트 각도가 45도로 감소했습니다. 모델의 전체적인 인쇄 품질을 개선하기 위해 기타 인쇄 설정이 업데이트되었습니다.
- 디지털 해부학 프린터에서 새로운 간 해부학을 사용할 수 있습니다. 다른 압축 값을 가진 4개의 새로운 사전 설정 간 해부학은 모두 전체 생체역학 보고서에서 사용할 수 있는 데이터로 검증되었습니다. 높은 수축성에서 중간 정도의 강성까지 다양한 코팅층으로 다양합니다. 수행된 테스트에 대한 더 많은 데이터가 여기에서 제공됩니다.
GrabCAD Print 버전 1.51, 2월 2021
빌드 번호 1.51.18.5360 출시: 22 2월 2021
1.51업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 이제 SOLIDWORKS 2021, Inventor 2021 및 Creo 7를 비롯한 대부분의 최신 CAD 패키지 버전에서 파일을 인쇄할 수 있습니다. 지원되는 파일의 전체 목록은 여기를 확인하십시오. GrabCAD Print 버전 1.50, 1월 2021
- 신속한 프로토타이핑을 위해 특별히 제작된 7 소재 PolyJet 프린터 J850 Pro를 소개합니다. J850 Pro는 J850 Prime(이전에는 J850으로 알려짐)과 동일한 빌드 볼륨 및 재료 용량을 갖습니다. J850 Prime은 CMF 프로토타이핑에서 탁월한 성능을 발휘하지만 J850 Pro는 Digital ABS, Agilus flexible 재료, DraftGrey, 초고속 모드를 사용하여 속도와 성능 개선을 위해 제작되었습니다. 새로운 J8-Series 라인업을 여기서 확인해 보십시오.
- 새로운 인쇄 요약 창은 설정, 예상치, 지연된 시작 옵션 및 PolyJet 작업에 대해 "인쇄"를 누를 때 확인해야 하는 모든 경고 또는 알림을 편리하게 통합합니다.
- 해석 모드에서 모델을 복구하면 시트 바디 및 노이즈 쉘과 같이 볼륨이 0인 바디는 자동으로 숨겨집니다. 이러한 바디는 해석할 수 없고 추정 또는 인쇄 오류를 유발할 수 있기 때문입니다.
- 트레이 보기에서 CMB 파일의 그래픽 표현이 향상되었습니다. CMB 디스플레이는 모델의 실제 모양에 대한 자세한 정보를 제공합니다. 이전에 무시되었던 포켓이 이제 식별되고 표시됩니다. 개선된 CMB 디스플레이를 통해 사용자는 CMB 인쇄 결과 모델을 이해하기 위해 슬라이스 미리보기를 입력할 필요가 없습니다.
- GrabCAD Print의 메뉴 표시줄과 메뉴는 Windows 테마에 설정된 색상을 따르도록 색상이 변경될 수 있습니다.
빌드 번호 1.50.14.4357 출시: 19 1월 2021
- GrabCAD Print에 대한 업데이트를 사용할 수 있는 경우 기본 설정(버전 1.22에 도입됨)에 따라 다음에 앱을 시작할 때 업데이트가 자동으로 설치되는지 여부가 결정됩니다. 기본적으로 설정되어 있었지만 이제는 모든 사람이 이 기본 설정을 해제할 것입니다. 향후 업데이트는 지금 업데이트 버튼을 클릭할 때만 설치되며, 원하는 경우 파일 > 기본 설정 > 업데이트에서 자동 업데이트를 다시 선택할 수 있습니다.
- 모델 하중에 대한 간섭 감지는 이제 모델이 겹치는 상황을 감지하고 경고할 수 있습니다. PolyJet 인쇄의 경우 파트 우선순위를 변경하는 위치를 결정하는 데 도움이 됩니다. 참고: 간섭 감지는 기본적으로 해제되어 있으며 기본 설정 > 모델 삽입 설정 > 어셈블리 내에서 자동으로 간섭 감지에서 활성화됩니다.
- J-Series 프린터에 평면 구조의 어셈블리를 삽입하면 이제 기본 우선순위가 파일 목록에 즉시 표시됩니다. 이전에는 파트 우선순위를 확인하기 위해 변경해야 했습니다.
- J-Series 프린터에서 흑백을 사용할 때 이제 흑백 색상 프로필과 함께 작동하는 그레이스케일 슬라이더가 있습니다. 기존 풀 컬러 색상 선택기를 대체합니다.
- 이전에 Objet30 프린터의 새로운 V5 버전에서만 사용 가능했던 DraftGrey를 이제 V3 프린터(VeroGrey로 표시)에서 사용할 수 있습니다. 자세한 내용을 보려면 여기를 클릭하세요. 또한 이 업데이트를 통해 Vero 재료를 사용한 고품질 모드가 활성화됩니다.
- 1.49 릴리스에서 일부 Connex 프린터는 잘못된 그래픽 드라이버 버전을 잘못 보고했습니다. 이 문제는 1.50 릴리스에서 해결되었습니다.
GrabCAD Print 버전 1.49, 12월 2020
빌드 번호 1.49.12.3309 출시: 16 12월 2020
- J4100 업그레이드 키트는 Objet1000 프린터에 사용할 수 있습니다. 이 키트는 새로운 프린트 헤드 기술과 최신 재료 오퍼링으로 Objet1000 프린터 기능을 개선합니다. 새로운 프린트 헤드는 추가 모델 채널(3)을 제공하여 처리량과 생산성을 최대 90%까지 향상시킵니다. 이제 재료 오퍼링에는 Agilus 제품군, UltraClear, VeroPureWhite가 포함됩니다. J4100을 사용하면 이제 디지털 ABS(오버 몰딩)를 통해 유연한 재료를 인쇄할 수 있습니다.
- 일부 J-Series 사용자는 작업이 처리 중에 멈춰서 J-Series 프린터로 인쇄할 수 없는 문제가 발생했습니다. 이것은 프린터 PC의 오래된 그래픽 드라이버로 인해 발생했지만 GCP에서 문제를 감지하지 못했습니다. 이 문제가 해결되었으며, 사용자가 이러한 상황에 있는 경우 이제 드라이버 업데이트 링크를 가리키는 메시지가 표시됩니다.
- CMB 관련 소프트웨어 수정
- CMB 내보내기에서 퍼지 파트/희생 타워를 포함/제외하는 옵션을 복원했습니다.
- CMB가 포함된 트레이에 추가 희생 타워를 포함하는 기능을 복원했습니다.
GrabCAD Print 버전 1.48, 11월 2020
빌드 번호 1.48.14.2323 출시: 17 11월 2020
1.48업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
GrabCAD Print는 이제 Objet30 데스크탑 프린터를 지원합니다. 기존 Objet30 V3 프린터(Objet30, Objet30 Pro 또는 Objet30 Prime으로 알려짐) 외에도 새로운 세대 Objet30 V5 Pro 및 Prime이 출시되고 있습니다. V5 모델은 설치 공간이 작고 인쇄 품질이 뛰어난 단색의 사용하기 쉬운 프린터입니다. 3 인쇄 모드와 DraftGrey를 포함한 다양한 13 모델 재료, 유연하고 생체 적합성 재료(Prime 전용)를 제공합니다. Objet30에서 GrabCAD Print를 사용하려면 GrabCAD Print용 PolyJet 프린터 설정 가이드를 따라야 합니다.
이제 FDM 프린터의 서포트 설정 패널에서 기본 스타일 옵션을 사용할 수 있습니다.
- 모델 및 서포트: 베이스는 모델 아래에 추가되고 설치 공간을 지원합니다. 베이스가 겹치면 공통 베이스로 병합됩니다. 베이스가 폐쇄 루프를 형성하면 루프가 채워져 크고 안정적인 베이스가 생성됩니다.
- 모델만 해당: 베이스는 모델 설치 공간 아래에만 추가됩니다. 서포트가 트레이까지 확장되고 루프가 채워지지 않습니다.
- 파일 > 기본 설정 > GrabCAD Labs의 새로운 옵션을 사용하면 PolyJet 프린터용 어셈블리에서 바디의 무광택과 광택 사이의 마감재를 혼합할 수 있습니다.
- 이제 J826 프린터에서 새로운 인쇄 모드인 초고속을 사용할 수 있습니다. 이 새로운 모드는 고속 모드 처리량의 두 배를 제공하며 빠른 개념 모델 인쇄와 같은 많은 애플리케이션에 실용적입니다.
- SR30 또는 SR35 서포트 재료를 사용하는 Stratasys F900 및 Fortus 900mc 모델러에서 T40 압출 팁(0.0200인치, 0.5080mm 슬라이스 높이)이 있는 ASA 모델 재료를 사용하는 작업의 경우, 첫 번째 레이어 파트 아래에 있는 베이스 레이어의 빌드 속성을 통해 첫 번째 레이어 파트의 품질을 개선하고 박리를 방지합니다.
- T40 모델 팁(0.0200인치, 0.5080mm 슬라이스 높이)을 사용하는 ASA 모델 재료가 있는 Stratasys F900 작업의 경우, 시간 및 부피 추정의 정확성이 향상되었습니다. 이 변경 사항은 새로운 4.10.0 시스템 펌웨어와 함께 사용하기 위한 것입니다. 이 펌웨어 업데이트는 표준 다운로드 업그레이드(.upg) 파일을 통해 제공되지 않습니다. 이 중요한 시스템 소프트웨어 업데이트에 대한 내용은 서비스 담당자 또는 Stratasys 고객 지원에 문의하십시오.
GrabCAD Print 버전 1.47, 10월 2020
빌드 번호 1.47.20.1644 출시: 20 10월 2020
1.47업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- Stratasys F370 프린터에서 0.0100인치(0.2540mm) 슬라이스 높이를 사용할 때 ABS 및 ASA에서 위쪽을 향하는 표면의 모양과 표면 밀도가 향상되었습니다.
- 가변 폭 잔여 툴패스로 채우기 위한 짧은 얇은 영역을 더 잘 감지하여 잔여 채우기를 개선했습니다.
- 이제 디스플레이 단순화 상태가 다른 모델을 선택하고 선택한 모든 모델을 전체 해상도 또는 단순화로 전체적으로 설정할 수 있습니다.
- 이제 SolidWorks에서 투명으로 설정된 텍스처를 올바른 투명도로 GrabCAD Print에 올바르게 가져옵니다.
- UltraclearS는 아크릴을 시뮬레이션하여 해당 재료의 95 % 광 투과율을 달성하며 유리, 투명 폴리머 또는 투명 포장의 프로토타입에 유용합니다. VeroUltraClear는 더 높은 수준의 선명도 및 투명도, 더 낮은 노란색 인덱스로 VeroClear의 과거 성능을 향상합니다.
- 서포트 코어 옵션은 이제 J55 프린터에서도 사용할 수 있습니다. 서포트 코어(이전의 '중공')를 사용하면 서포트 재료에서 코어를 인쇄할 수 있습니다. 옵션을 사용하기 전에 기본 설정 > GrabCAD Labs에서 설정하십시오.
- Digital Anatomy Printer의 뼈 섹션 분할 기능을 사용하면 골절을 모방하거나 애플리케이션과 관련이 없는 트레이의 부분을 제거하기 위해 뼈 모델을 섹션으로 해부할 수 있습니다.
- 이전에 "재료 변경" 창에 있던 색상 및 텍스처 프로필 옵션이 트레이 설정 도구 패널의 고급 섹션으로 이동되었습니다.
GrabCAD Print 버전 1.46, 9월 2020
빌드 번호 1.46.21.661 출시: 15 9월 2020
빌드 번호 1.46.22.826 출시: 18 9월 2020
1.46업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 이전에 PolyJet 모델 설정의 확인란이었던 "중공" 설정을 이제 기본 및 코어 옵션 아래의 "서포트" 옵션으로 사용할 수 있습니다. 또한 1.42 버전에서 출시된 “혼합 코어” 설정이 기본적으로 켜져 있습니다.
- Digital Anatomy Printer의 새로운 기능
- 뼈 미리 보기 — 뼈의 내부 구조에 대한 슬라이스별 미리 보기를 활성화하여 구조가 의도와 일치하는지 확인합니다.
- 끝 열기/닫기 — 뼈의 내부 구조에 "창"을 만듭니다. 뼈의 평평한 단면을 표시한 다음 투명한 재료로 코팅하거나 그대로 두도록 선택할 수 있습니다(야외에 노출시킴).
- 1.40 버전에서 Labs 기능으로 도입된 3MF 파일에 대한 지원이 일반적으로 제공됩니다.
- 투명한 배경이 있는 텍스처가 포함된 SOLIDWORKS 파일이 이제 GrabCAD Print에 올바르게 로드되어 투명한 배경을 통해 기본 모양이 표시됩니다.
- Antero™ 840CN03은 이제 Fortus 450mc에서 지원됩니다. Antero 840CN03은 정전기 방전(ESD) 특성을 갖고 있으며 접촉에 민감한 전자 부품 및 구성 요소를 제조하는 응용 제품에 사용할 수 있는 Stratasys® Antero 800NA 모델 재료의 혼합물입니다. Antero 840CN03: 0.010인치(0.2540mm)에 대해 하나의 슬라이스 높이를 사용할 수 있습니다. 이 재료에 대한 정보를 보려면 여기를 참조하십시오.
GrabCAD Print 버전 1.45, 8월 2020
빌드 번호 1.45.21.65369 출시: 25 8월 2020
1.45업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- PolyJet 인쇄 모드는 인쇄 작업을 준비할 때 미리 선택할 수 있습니다. 선택한 인쇄 모드에서 사용할 수 있는 기능과 설정만 표시되므로 작업 준비가 더 쉬워집니다. 선택한 인쇄 모드를 기반으로 사용할 수 없는 기능 및 설정은 사용할 수 없는 이유에 대한 설명과 함께 여전히 비활성화됩니다.
- FDM을 위한 적응형 슬라이스 스타일을 소개합니다! 적응형 슬라이스 스타일은 더 많은 세부 사항(돔, 모깎기 및 모따기 등)이 필요한 피쳐와 세부 사항이 필요하지 않은 더 두꺼운 슬라이스 높이에 대해 선택한 높이를 사용합니다. 그 결과 인쇄 속도가 빨라집니다(형상 및 슬라이스 높이에 따라 최대 24% 더 빠름). 슬라이스 스타일은 모델을 슬라이싱하는 방법을 설정하는 새로운 옵션입니다. 자세히 알아보기.
- 디스플레이 설정 > 그래픽 품질에 대한 기본 설정은 이제 그래픽 디스플레이에 사용되는 모델에 적용되는 단순화 수준을 제어합니다. 참고: 인쇄된 모델은 전체 해상도로 유지됩니다. 선택한 모델의 디스플레이를 단순화 및 전체 해상도 디스플레이 간에 전환할 수 있는 마우스 오른쪽 클릭 메뉴 옵션인 그래픽 해상도가 있습니다.
- 이제 모든 파일 형식에 적용되는 기본 설정이 어셈블리의로드 상태(조립됨 또는 분해됨)를 선택합니다.
GrabCAD Print 버전 1.44, 7월 2020
빌드 번호 1.44.22.64105 출시: 22 7월 2020
1.44업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 코어/베이스 할당은 모델의 설계에 가장 잘 맞는 것을 제공하도록 사용자 지정할 수 있습니다.
- J720 프린터의 자동 정렬 기능은 파트 배열을 개선하여 생산을 보다 효율적으로 만듭니다.
- GrabCAD Print Server의 이전 버전 2.0은 7월 21부터 GrabCAD Cloud에 연결할 수 없습니다. GrabCAD Print Server를 통해 프린터에 계속 연결하려면 이전 버전을 수동으로 제거하고 Print Server 2.0를 설치하십시오. 여기에서 최신 버전을 다운로드할 수 있습니다.
- GrabCAD Print Server 2.0는 Microsoft Windows 10(64비트) 및 Windows Server 2016 이상에서만 지원됩니다. Microsoft에서 일반 지원되지 않는 이전 버전의 Windows에서 실행되는 인스턴스는 7월 21부터 자동 업데이트되지 않거나 GrabCAD Cloud에 연결할 수 없습니다. Print Server 인스턴스에서 OS를 업그레이드하거나 지원되는 OS가 있는 장비에 Print Server를 설치해야 합니다.
- GrabCAD Print는 시스템 전체(장비별) 설치로 이전하고 있습니다. 이로 인해 영향을 받는 경우 업데이트를 사용할 수있을 때 알림을 받게 되며 (일반적으로) 마이그레이션에는 사용자의 작업이 필요하지 않습니다. v1.47 이후 업데이트를 계속 받으려면 장비별 설치로 마이그레이션해야 합니다.
- 이제 GrabCAD Print를 사용하여 프린터에서 Stratasys 지원 연락처로 진단 파일을 보낼 수 있습니다. 하드웨어, 재료, 기타 프린터 또는 소프트웨어 문제의 경우 도움말 -> 프린터 지원 받기로 이동하여 문제에 대한 세부 정보를 추가할 수 있습니다. GrabCAD Print는 모든 세부 정보 및 관련 파일과 함께 이메일 템플릿을 생성하여 판매 시 제공된 이메일 주소로 보낼 수 있습니다.
- 깊은 (다단계) 어셈블리 구조를 가진 3MF 파일은 이제 프로젝트 패널에 전체 트리 구조를 표시합니다.
GrabCAD Print 버전 1.43, 6월 2020
빌드 번호 1.43.17.62943 출시: 17 6월 2020
1.43업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 이제 GrabCAD Print에서 Advanced FDM 기능을 사용할 수 있으므로 Advanced FDM 프로젝트 생성이 더 이상 필요하지 않습니다. "Advanced FDM 활성화" 옵션이 기본 설정 메뉴에서 제거되었으며 새로운 Advanced FDM 프로젝트를 만드는 작업이 왼쪽 도구 모음에서 제거되었습니다.
- Advanced FDM 기능을 핵심 GrabCAD Print로 이동하는 과정에서 Advanced FDM에서 생성된 프로젝트는 GrabCAD Print에서 열리며 각 모델은 별도의 트레이에 있습니다. 바디 설정, 표면 설정, 트레이 속성, 방향 및 제조 메모와 같이 그룹이 유지됩니다.
- 슬라이싱 실패를 방지하기 위해 VRML, OBJ 및 3MF 파일을 인쇄 가능한 개체로 변환하는 알고리즘이 다시 작성되었습니다.
- 단색이 있는 VRML 바디를 선택하면 색상 선택기에 색상이 직접 표시되고 약간의 조정이 가능합니다.
- Digital Anatomy Printer의 두 가지 새로운 기능
- Long Bone Axis Tool을 사용하면 긴 뼈의 근위 및 원위 영역을 정의할 수 있습니다. 이를 통해 다양한 밀도로 파트를 인쇄하여 긴 뼈의 구조를 근사하게 만들 수 있습니다.
- 많은 정형 외과 시술에서는 구멍을 뚫고 인쇄된 모델에 나사를 삽입해야 합니다. 경우에 따라 이로 인해 원치 않는 균열이 발생할 수 있습니다. 이를 방지하기 위해 Strain Relief Tool을 사용하면 균열을 포함하도록 설계된 경계를 설정할 수 있으므로 인쇄된 부분에서 더 넓은 균열을 방지할 수 있습니다.
- Stratasys J55를 소개합니다. 모든 단계에서 타협 없이 만드십시오. 빠른 개념 모델에서 고품질의 고품질 모델에 이르기까지 사무실 친화적인 J55 3D 프린터는 디자이너 출력을 극대화할 수 있는 경제적인 옵션입니다. 여기서 자세히 알아보기.
GrabCAD Print 버전 1.42, 5월 2020
빌드 번호 1.42.19.62279 출시: 20 5월 2020
1.42업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 새로운 조작기를 사용하여 모델을 보다 쉽게 배치하고 방향을 지정하십시오. 뷰 컨트롤 스트립에서 가장 오른쪽 버튼을 클릭하여 활성화하면 선택한 모델에는 클릭하고 드래그하여 선택 항목을 자유롭게 또는 정확한 축을 따라 이동 및 회전할 수 있는 화살표가 표시됩니다.
- FDM 프린터의 경우 정렬 도구 패널의 슬라이더를 사용하여 트레이의 모델 간 간격을 최소 0.2500인치(6.35mm)에서 최대 2.0000인치(50.8mm)까지 조정할 수 있습니다. 이렇게 하면 모델을 트레이에 더 단단하게 패킹하거나 공기 흐름을 개선하기 위해 더 멀리 떨어뜨릴 수 있습니다.
- 1.41에 추가된 새로운 CMYKW 및 CMYW 색상 프로필은 이제 CMYKW 및 CMYW Vivid 재료가 프린터에 로드될 때 기본 색상 프로필입니다. 프로필 이름은 X-Rite i1Profiler CMYKW 또는 CMYK입니다.
- 이전에는 PolyJet 파트의 코어가 흑백 재료의 교대 레이어로 인쇄되었지만 파일 > 기본 설정> PolyJet의 새로운 "혼합 코어" 기본 설정을 통해 사용 가능한 모든 재료를 혼합하여 코어를 인쇄할 수 있습니다. 이렇게 하면 각 프린트 헤드가 더 자주 사용되기 때문에 노즐 막힘 문제가 발생할 가능성이 크게 줄어들지만 작업을 완료하려면 로드된 각 재료 카트리지에 충분한 재료가 있어야 합니다.
GrabCAD Print 버전 1.41, 4월 2020
빌드 번호 1.41.31.61723 출시: 27 4월 2020
1.41업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 이제 최신 버전의 CAD 패키지가 GrabCAD Print에서 지원됩니다. 여기에는 SOLIDWORKS 2020, Inventor 2020, Creo 6.0 등이 포함됩니다. 여기에서 전체 목록 읽기.
- 이제 J-Series 인쇄물의 서포트 그리드에 사용된 재료를 변경하여 더 일반적으로 사용되는 재료를 저장할 수 있습니다. 트레이의 모든 서포트 구조는 선택한 재료로 인쇄됩니다. 재료 선택은 트레이 설정 > 고급 > 서포트를 강화하는 데 사용된 재료에서 수행할 수 있습니다.
- 더 많은 Advanced FDM 기능을 Print로 가져오기 위해 이제 그룹 내의 바디에 다른 재료 설정을 적용할 수 있습니다. 그룹을 마우스 오른쪽 버튼으로 클릭하면 다음 설정 간에 전환할 수 있습니다.
- 바디 분리 — 바디 및 표면에는 다른 바디 및 표면과 독립적으로 적용되는 설정이 있을 수 있습니다. 이는 Advanced FDM이 작동하는 방식과 유사합니다.
- 바디 결합 — 그룹의 모든 바디가 단일 바디로 작동하며 하나의 바디 설정이 전체 그룹에 적용되고 내부 경계가 제거됩니다. 이는 그룹을 생성하지 않고 "조립됨"을 선택할 때 어셈블리가 일반적으로 작동하는 방식과 유사합니다.
- 조립된 그룹에 "바디 분리"가 선택되어 있으면 모델 설정 패널의 표면 탭 아래에서 표면 두께, 이음새 배치 및 삽입을 사용할 수 있습니다. 이전에 이 기능은 Advanced FDM에서만 사용할 수 있었습니다.
- FDM 인쇄물에 대한 서포트가 필요한 작은 기능은 기능 아래에서 더 넓게 확장되는 서포트를 생성합니다. 이제 서포트 증가 설정으로 제어할 수 있으며, 기본값인 "소규모 서포트만 증가"에서 "서포트 증가 안 함" 또는 "모든 서포트 증가"로 변경할 수 있습니다. 서포트 증가를 끄면 재료 사용량과 일부 파트의 인쇄 시간을 줄이는 데 유용할 수 있습니다.
- 향상된 색상 렌더링을 제공하는 새로운 Vivid 2.0 색상 프로필이 GrabCAD Print에 추가되었습니다. 기본 색상 프로필은 변경되지 않았으며 Vivid 1.1를 유지합니다.
- 이제 표면 색상이 있는 SOLIDWORKS 어셈블리를 멀티 바디 파트로 저장하는 추가 단계 없이 GrabCAD 인쇄에 직접 로드할 수 있습니다.
- FDM 프린터의 경우 어셈블리 구조가 있는 3MF 파일이 이제 구조와 함께 로드됩니다.
- 슬라이더에서 FDM 설정을 변경하면 검은색 다이아몬드가 기본값을 나타냅니다. 이것을 클릭하면 기본값으로 복원됩니다.
- 이번 GrabCAD Print 릴리스를 사용하면 GrabCAD Shop의 주문에서 GrabCAD Print의 트레이로 파일을 쉽게 열 수 있습니다. 이렇게 하면 시간을 절약하고 이메일 또는 기타 요청 관리 소프트웨어에서 CAD 파일을 다운로드하지 않으며 트레이를 효율적으로 계획할 수 있습니다. 아직 등록하지 않은 경우 여기서 GrabCAD Shop에 등록하십시오.
- 자동 검색을 사용할 수 없는 프린터에 쉽게 연결할 수 있도록 "IP로 추가" 입력 상자가 GrabCAD Print Server에 추가되었습니다.
GrabCAD Print 버전 1.40, 3월 2020
빌드 번호 1.40.28.60898 출시: 24 3월 2020
1.40업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 멀티 바디 파일을 포함한 SOLIDWORKS 파트 파일에는 이제 PolyJet 인쇄를 위해 표면 수준에서 적용된 색상 데이터가 포함됩니다. 이전에는 GrabCAD Print에 바디 수준에서 적용된 색상만 포함되었습니다.
- 사용자가 선택한 색상 견본을 만들어 PolyJet 프린터에서 인쇄된 모델에 색상이 어떻게 나타나는지 테스트합니다. 앱 > 색상 견본 툴로 이동하여 색상 견본 툴에 액세스합니다.
- 이제 GrabCAD Print를 사용하면 컴퓨터의 GPU 메모리 소비를 최적화하여 더 큰 PolyJet 트레이를 인쇄할 수 있습니다. 이 기능은 기본 설정 > PolyJet> 헤비 트레이 최적화에서 활성화할 수 있습니다.
- Advanced Slicer는 이제 Stratasys J750 및 Stratasys J735에 사용할 수 있는 유일한 슬라이서입니다. 레거시 슬라이서는 더 이상 해당 프린터에서 사용할 수 없습니다. 다른 PolyJet 프린터에는 변경 사항이 없습니다.
- 독립형 Insight에서 GrabCAD Print로 작업을 전송할 때 독립형 버전은 GrabCAD Print에서 사용할 수 있는 Insight 버전과 동일하거나 이후 버전이어야 합니다. 그렇지 않으면 작업이 전송되지 않습니다.
- GrabCAD Print의 핵심 구성 요소를 최신 버전으로 업그레이드했습니다. 이렇게 하면 OneDrive 폴더에서 파일을로드하는 것과 같은 몇 가지 문제가 해결될 뿐만 아니라 전반적인 성능과 시작 시간이 향상됩니다.
- GrabCAD Print는 여러 CAD 툴에서 3MF 파일을 가져올 수 있습니다. SOLIDWORKS에서 만든 3MF 파일의 경우에는 표면 색상, 바디 색상 및 텍스처가 포함됩니다. PolyJet 프린터의 경우 어셈블리는 평면 구조를 가지며 FDM 프린터의 경우 어셈블리 구조가 없습니다.
- FDM 관련 개선 사항
- Stratasys F370 프린터에서 TPU 92A를 사용할 때 개선된 전체 파트 품질을 제공하기 위해 가변 폭 잔여 채우기의 너비 범위가 축소되었습니다.
- Diran 410mf07 재료의 자체 서포트 각도를 수용하기 위해 자체 서포트 구멍의 각도가 55도로 증가되었습니다.
- 일부 모델 및 방향에 대해 불완전한 서포트가 생성될 수 있는 문제를 해결했습니다.
- 그룹에 할당된 기본 이름(GrabCAD Print 1.36에 도입)은 이제 사용자에게 더 논리적인 이름으로 변경될 수 있습니다.
GrabCAD Print 버전 1.39, 2월 2020
빌드 번호 1.39.14.59507 출시: 18 2월 2020
1.39업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 새로운 PolyJet 모델 설정 패널은 개선된 디자인 및 사용자 작업흐름, 새로운 CMYK 입력 기능을 사용하여 재료 및 색상 즐겨찾기를 저장하고 자신만의 색상 및 디지털 재료를 만들 수 있는 기능을 제공합니다. 여기서 자세히 알아보기.
- 축척 또는 방향이 적용된 어셈블리에서 그룹을 작성할 때 새로 작성된 그룹은 어셈블리에서 이러한 특성을 상속합니다.
- 이제 프린터 목록에서 연결이 끊어진 프린터를 삭제할 수 있습니다. 제거하려는 프린터를 마우스 오른쪽 버튼으로 클릭하고 "프린터 삭제"를 선택하십시오.
- 재료 패널에 있는 PolyJet 프린터의 폐기물 컨테이너 상태를 보다 명확하고 직관적으로 시각화했습니다.
- 미리 알림: 고급 PolyJet 슬라이서 정보: 3월 업데이트에서 GrabCAD Print 버전 1.40에서는 J750 및 J735용 고급 PolyJet 슬라이서를 비활성화하는 옵션을 더 이상 사용할 수 없습니다.
GrabCAD Print 버전 1.38, 1월 2020
빌드 번호 1.38.21.59019 출시: 28 1월 2020
1.38업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- PolyJet 프린터를 사용하는 경우 디자인이 개선되고 즐겨찾기를 저장할 수 있는 새로운 모델 설정 패널을 사용해 볼 수 있습니다. 파일 > 기본 설정> PolyJet으로 이동하고 확인란을 선택하여 새로운 PolyJet 모델 설정 패널을 사용하십시오.
- J850 및 J835 1.36에 도입된 새로운 VeroUltraClear 재료는 이제 J750 및 J735에서 사용할 수 있습니다. VeroUltraClear는 아크릴을 시뮬레이션하여 재료의 95% 광 투과율을 달성하며 유리, 투명 폴리머 또는 투명 포장의 프로토타입에 유용합니다. VeroUltraClear 재질에 대한 자세한 내용은 여기에서 확인하십시오.
- 모델 설정 패널에서 새로운 색상 및 재료 할당을 사용하여 VRML/OBJ 부품을 재지정하고 필요한 경우 선택한 VRML/OBJ 바디의 새로운 마우스 오른쪽 버튼 메뉴 옵션을 사용하여 원래대로 복원할 수 있습니다.
- VRML/OBJ 구조 환경 설정의 기본 상태가 꺼짐에서 켜짐으로 변경되었습니다.
- 고급 FDM에서 Diran 410MF07의 채우기 패턴에는 이제 단일 밀도, 이중 밀도 및 솔리드가 포함됩니다. 또한 용지함 접착력을 개선하기 위해 첫 번째 레이어 재료가 지지대에서 모델 재료로 변경되었습니다.
- Stratasys 프린터의 잘못된 모델 이름이 일정 보기에 표시되던 문제가 해결되었습니다.
GrabCAD Print 버전 1.37, 12월 2019
빌드 번호 1.37.15.57828 출시: 18 12월 2019
1.37업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 버전 1.20에 도입된 PolyJet 프린터의 지연된 시작 기능은 이제 고급 PolyJet 슬라이서에서 지원됩니다. 참고: 선택을 하려면 프린터가 "유휴" 상태여야 합니다.
- 후처리를 위한 새로운 PolyJet 인쇄 설정을 사용하면 연마를 위해 얇은 투명 재료 층을 추가할 수 있습니다. 투명 레이어를 연마하면 표면이 매끄럽고 고해상도 색상과 질감의 모델이 만들어집니다.
- 현재 활성 트레이에 대한 모델의 제조 메모 및 스크린샷이 포함된 PDF 트래블러 문서를 미리 보고 작성할 수 있습니다.
GrabCAD Print 버전 1.36, 11월 2019
빌드 번호 1.36.17.57117 출시: 20 11월 2019
1.36업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 새로운 J750™ Digital Anatomy™ 3D 프린터가 지원되며, 의료 기기 제조업체, 세계적 수준의 연구 기관, 병원 및 의료진과 협력하여 개발된 일련의 해부학적 애플리케이션으로 사전 프로그래밍되어 있습니다. 정확하고 사실적이며 기능적이며 실제 느낌, 동작 및 치수를 달성할 수 있습니다. J750 Digital Anatomy 3D 프린터에 대한 내용은 여기서 확인하십시오.
- 새로운 J850 및 J835가 지원됩니다. 디자인과 창의성에는 한계가 없습니다. 이제 Stratasys J850/J835에서 프로토타입도 마찬가지입니다. 당사의 검증된 기술은 전체 설계 프로세스를 개선하여 작업흐름을 간소화하여 최상의 제품을 제작, 정제 및 설계하는 데 더 많은 시간을 할애할 수 있습니다. Stratasys J850에 대한 자세한 내용은 여기서 확인하십시오.
- 선택한 모델은 이제 프로젝트 패널 상단의 새 버튼 또는 마우스 오른쪽 버튼 명령을 통해 그룹화할 수 있습니다. 새 그룹을 만들면 기존 어셈블리가 축소되고 숨겨집니다. 그룹은 조립 또는 분해로 설정할 수 있습니다. 원래 어셈블리에서 추가 그룹을 만들 수 있습니다.
- VRML 및 OBJ 파일의 어셈블리 구조를 표시하기 위한 PolyJet 고급 슬라이서 설정에 새로운 옵션이 있습니다. 이 옵션을 활성화하면 GrabCAD Print는 VRML 또는 OBJ 파일의 기하학적 구조를 결정하고 구조를 프로젝트 패널에 바디 어셈블리로 표시합니다. 각 바디는 멀티 색상(즉, 텍스처, 정점별 색상, 얼굴별 색상 또는 다수의 상이한 색상 시트로 구성됨) 또는 단일 색상(즉, 바디의 모든 시트가 단일 확산 색상을 공유함)일 수 있습니다. 사용자는 이러한 어셈블리 내에서 단색 바디에 대한 재료 할당을 변경할 수 있습니다.
- SOLIDWORKS 파일(.sldprt 또는 .sldasm)을 가져올 때 투명 재료가 로드되면 SOLIDWORKS 바디에 부착된 투명도 속성이 PolyJet 재료 패널에서 자동으로 알파 값으로 변환됩니다.
- 라이센스가 필요한 Stratasys 및 Fortus 프린터의 재료 라이센스는 GrabCAD Print에서 업데이트할 수 있습니다. 재료 라이센스를 업데이트하려면 사용자에게 로컬 관리자 권한이 있어야합니다.
- 사용성 향상을 위해 프로젝트 패널의 스타일이 변경되었습니다. 변경 사항에는 재설계된 아이콘, 개선된 정렬, 보다 명확한 선택 강조 표시, 조립/분해 상태에 대한 확인란 대신 풀다운 및 표시/숨기기 상태의 명확한 표시가 포함됩니다.
- 인쇄가 표면 선택 모드에 있을 때 표면 접선 선택을 마우스 오른쪽 버튼으로 사용할 수 있습니다. 이것은 표면 체인에 제조 메모를 추가할 때 유용할 수 있습니다.
- 바디와 표면에 제조 메모라고 하는 주석이 추가될 수 있습니다. 마우스 오른쪽 버튼으로 메모를 추가하는 명령을 사용할 수 있습니다. 그러면 메모를 표시하고 편집할 수 있도록 클릭하여 활성화할 수 있는 설명 선이 추가됩니다.
- Stratasys J850 및 Stratasys J835 3 D 프린터를 위한 새로운 VeroUltraClear 재료. VeroUltraClear는 아크릴을 시뮬레이션하여 재료의 95% 광 투과율을 달성하며 유리, 투명 폴리머 또는 투명 포장의 프로토타입에 유용합니다. VeroUltraClear 재료에 대해 자세히 알아보려면 여기를 확인하십시오.
- ABS ESD7은 이제 GrabCAD Print용 Stratasys F370 프린터에서 지원됩니다. ABS ESD7은 분말, 먼지 또는 미세 입자와 같은 다른 재료로의 배출 또는 인력을 방지하기 위해 정전기에 민감한 응용 분야를 위해 설계된 툴링 재료입니다. ABS ESD7 재료에 대한 자세한 내용은 여기에서 확인하십시오.
GrabCAD Print 버전 1.35, 10월 2019
빌드 번호 1.35.21.56592 출시: 24 10월 2019
1.35업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- PolyJet 프린터에서 Job Manager 업데이트가 필요한 경우 인쇄 버튼과 프린터 목록의 동작을 모두 개선했습니다. 인쇄 버튼에 팝업이 표시되고 프린터 목록을 클릭하면 업그레이드를 수행할 수 있는 설정 화면으로 바로 이동합니다.
- J 시리즈 프린터의 UV 램프를 제어하기 위해 트레이 설정의 고급 섹션에 확인란이 추가되었습니다. 인쇄물에 노출 과다 문제가 있는 경우 리셀러 또는 Stratasys 기술 지원에 문의하여 이 설정이 도움이 되는지 확인하십시오.
- J Series 프린터에서 팬톤 색상으로 인쇄할 때는 일부 색상에만 VeroBlackPlus가 필요합니다. 이전에는 팬톤 색상 피커를 로드하지 않은 경우 전체 색상 피커가 비활성화되었으며 특정 색상만 비활성화되었습니다. 팬톤에는 여전히 3개의 Vivid Vero 재료와 VeroPureWhite가 필요합니다.
- 모델 로딩은 이제 취소 가능한 작업입니다. 이전에 잘못된 파일을 선택한 경우, 파일을 제거하기 전에 로드되기를 기다려야 했습니다. 이제는 즉시 취소할 수 있습니다.
- 고급 FDM에서 특정 얼굴에 설정을 적용하면 마우스 오른쪽 버튼 클릭 메뉴를 통해 설정을 제거할 수 있습니다. 이전에는 실행 취소를 사용하여 얼굴 설정을 되돌려야 했습니다.
- 새로운 FDM 재료 지원:
- TPU 92A는 이제 Stratasys F370 프린터에서 0.0070인치(0.1778mm) 슬라이스를 지원합니다. 0.0070 슬라이스 및 0.0100인치(0.2540mm) 슬라이스의 인쇄 품질이 향상되었습니다. 이러한 개선 사항을 활용하려면 F123 컨트롤러 소프트웨어를 버전 2.1으로 업그레이드해야 합니다.
- 프린터 기록을 삭제하려면 사용자에게 로컬 관리자 권한이 있어야 합니다.
GrabCAD Print 버전 1.34, 9월 2019
빌드 번호 1.34.16.55783 출시: 19 9월 2019
1.34업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 1.31에 옵션으로 도입된 PolyJet 고급 슬라이서가 기본적으로 켜져 있습니다. 추정의 정확도가 향상되었으며 여기에 나열된 몇 가지 기능을 사용할 수 있습니다. 이전 슬라이서를 사용해야 하는 경우 기본 설정 > PolyJet에서 이 옵션을 끌 수 있습니다.
- 선택한 프린터와 관련된 GrabCAD Print의 도움말 메뉴에서 GrabCAD Tutorials 및 예제 파일에 액세스할 수 있습니다. 당사의 응용 엔지니어들은 기계를 더 잘 활용할 수 있도록 지속적으로 새로운 내용을 추가하고 있습니다. 해당 내용은 도움말 메뉴를 통해 볼 수 있습니다.
- "지원되는 표면 미리 보기"로 표시된 뷰 막대의 토글을 사용하면 모델에서 지원되는 표면이 생성되는 위치를 신속하게 확인할 수 있습니다. 이 기능은 1.24의 PolyJet 프린터 용으로 도입되었으며 이제 FDM 프린터에서도 사용할 수 있습니다. 이렇게 하면 FDM 조각 미리 보기를 대신하여 용지함 준비에 도움이 되는 방향과 지원 설정(예: 자체 서포트 각도)이 인쇄 표면에 미치는 영향을 보여주는 빠른 방법이 제공됩니다.
- 일정 보기 또는 GrabCAD Print 모바일 앱에서 진행 중인 PolyJet 작업을 볼 때 예측된 "종료 시간"의 정확도가 크게 향상되었습니다. 초기 추정에서 인쇄 일시 중지 및 기타 오류를 설명하기 위해 작업 전체에서 예측이 정기적으로 업데이트됩니다.
- PolyJet 트레이 설정 패널에서 슬라이스 지연 옵션을 확인하면 모델에서 함몰이 줄어듭니다. 이 옵션은 Stratays의 기술 지원에 문의한 후에만 사용해야 합니다. 이 옵션을 사용하면 작업 인쇄 시간이 늘어납니다.
- PolyJet 프린터의 트레이 설정 패널에 표시된 재료 목록에 이제 서포트 재료가 포함됩니다.
- GrabCAD Print는 이제 F123 시리즈 및 J750과 같은 일부 프린터의 업데이트에 대해 알려줍니다. 여기에는 새로운 자료, 학습 내용 및 기타 정보가 포함될 수 있습니다. 이 프린터 중 하나를 선택하고 업데이트를 사용할 수 있는 경우 화면의 왼쪽 하단에 선물 상자가 표시됩니다.
GrabCAD Print 버전 1.33, 8월 2019
빌드 번호 1.33.10.54793 출시: 20 8월 2019
1.33업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 고급 FDM에서 지원하는 프린터의 경우 모델 설정 탭에서 일부 고급 기능을 사용할 수 있습니다. 여기에는 채우기 밀도, 채우기 각도 및 바디 두께가 포함되며 CAD 파일을 사용할 때 원통형 구멍을 자체 서포트 다이아몬드로 변경할 수 있습니다.
- 마지막 업데이트에서 FDM 설정 패널을 변경 한 것과 유사하게 PolyJet 설정 패널은 이제 트레이 설정과 모델 설정으로 분할되어 향후 업데이트 시 더 많은 기능을 위한 공간을 제공합니다.
- 퍼지 파트 또는 희생 타워 없이 CMB를 내보내도록 선택할 수 있습니다. 이렇게 하면 작업에서 여러 CMB 파일을 인쇄할 때 여러 퍼지 파트가 인쇄되는 것을 방지할 수 있습니다. 기본적으로 퍼지 파트/희생 타워가 포함됩니다.
- Stratasys F900, Fortus 900mc 및 Fortus 400mc 프린터 템플릿의 경우 ABS가 기본 재료입니다. 라이브 프린터의 경우 재료는 현재 구성을 기본값으로 계속 사용합니다.
- J750 및 J735 사용자를 위한 미리 알림: 1.31에 도입된 고급 슬라이서는 다음 달 업그레이드 버전 1.34에서 기본적으로 *지원*됩니다.
GrabCAD Print 버전 1.32, 7월 2019
빌드 번호 1.32.19.54065 출시: 22 7월 2019
1.32업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- FDM 인쇄 준비를 위한 인쇄 설정 패널이 3 패널(용지함 설정, 모델 설정, 지원 설정)로 분할되었습니다. 새로운 아이콘도 추가되었습니다.
- 분석 모드는 이제 정점 색상으로 VRML 및 OBJ 파일을 복구할 수 있으며 표면 색상과 질감으로 파일 복구가 향상되었습니다.
- J750 및 J735 사용자는 이제 Vivid 재료와 고급 슬라이서를 사용하여 불투명 모델을 인쇄할 수 있습니다. 흰색 코어로 본문을 인쇄하려면 인쇄 설정 패널에서 "반투명" 확인란을 선택 취소하십시오. 이것은 현재 텍스처되지 않은 메시 파일/어셈블리에만 작동합니다.
- 일부 Fortus 및 F123 작업의 문제로 퍼지 파트/희생 타워에 이상한 동작이 발생하여 빌드 오류가 발생했습니다. 이 문제는 해결되었습니다.
- Agilus 30 Clear를 선택하면 설정한 Shore A 값과 관련된 투명도 수준으로 모델이 표시됩니다.
GrabCAD Print 버전 1.31, 6월 2019
빌드 번호 1.31.52720.53058 출시: 20 6월 2019
1.31업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- F900, F370 및 Fortus 프린터용으로 1.24에 도입된 고급 FDM을 이제 F170 및 F270에서 사용할 수 있습니다. 고급 FDM을 사용하면 실제 CAD 형상을 사용하여 모델의 다른 섹션에서 채우기를 사용자 정의할 수 있으며 인쇄를 위해 구멍 형상을 수정할 수 있습니다. 자세히 알아보기.
- 현재 파일 > 기본 설정> Polyjet에서 제공되는 고급 슬라이서는 J750 및 J735 사용자에게 다양한 개선 사항과 새로운 기능을 제공합니다.
- 색상 선택기의 Pantone® 검증 색상.
- 텍스처에 투명성이 있는 VRML은 명확한 코어를 사용합니다.
- 작은 기능 및 텍스트에 대한 향상된 추정 및 인쇄 정확도.
- 구멍이 있는 수직 벽에서 "서포트 그림자" 효과를 수정하는 사용자 정의 지원 옵션.
- 조립품 구성 요소가 겹칠 때 사용자 부품 우선 순위.
- 트레이의 부품 배치를 완벽하게 제어합니다.
- GrabCAD Print Server의 새 버전은 Windows 서비스로 실행되며, Windows 사용자가 로그아웃하더라도 계속 실행됩니다. 또한 Windows Server 2012과(와) 호환되며 시스템별 버전의 GrabCAD Print와 함께 설치할 수 있습니다. 이 업그레이드는 자동이 아니므로 새 버전을 여기서 다운로드해야 합니다. 설치에 도움이 필요하면 여기를 클릭하십시오.
- 해석 모드는 이제 텍스처 VRML 파일에서 메시 오류를 복구할 수 있습니다.
- Inventor 2020과 같이 아직 지원되지 않는 CAD 패키지에서 모델을 추가하려고 할 때 발생하는 오류 메시지는 일반 오류보다 더 많은 정보를 제공합니다.
- FDM 프린터의 경우, 부품 표면의 각도가 자체 서포트 각도라고 하는 지정된 값 아래로 떨어질 때마다 지지대가 생성되며 이제 인쇄 설정 패널에서 해당 값을 조정할 수 있습니다. 생성되는 지지대의 양을 늘리거나 줄일 수 있으며 프린터 및 재료에 따라 달라지는 기본 권장 사항으로 값을 복원할 수도 있습니다.
- 현재 GrabCAD Print 프로젝트의 파일 또는 설정과 일치하지 않는 CAD 또는 CMB 파일을 추가하면 오류 대신 충돌이 발생합니다. 새로운 경고를 통해 변경 사항을 저장하고 새 프로젝트를 열 수 있습니다.
GrabCAD Print 버전 1.30, 5월 2019
빌드 번호 1.30.28.52238 출시: 22 5월 2019
1.30 업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 프린터 기록은 GrabCAD Print 애플리케이션의 프린터 기록 페이지에서 삭제될 수 있습니다. 이 옵션은 기본 설정에 의해 활성화됩니다. 기본 설정은 GrabCAD 세션에 대해서만 활성화됩니다. 기록이 삭제되면 대기열에 작업이 있을 수 있지만 프린터는 유휴 상태여야 합니다.
- GrabCAD Print의 번역을 검토하고 6개 위치의 오류를 수정했습니다.
GrabCAD Print 버전 1.29, 4월 2019
빌드 번호 1.29.6.51061 출시: 16 4월 2019
1.29업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- GrabCAD Print에서 최신 버전의 CAD 패키지가 지원됩니다. 여기에는 SOLIDWORKS 2019, Inventor 2019, Creo 5.0, NX 12.0 등이 포함됩니다. 자세히 알아보기.
- 새로운 프린터 패널을 사용하여 프린터에 쉽게 액세스할 수 있습니다. 즐겨찾기 프린터, 고급 검색 및 필터링 및 기타 여러 개선 기능이 있습니다. 그리고 이 개선 사항에 대한 여러분의 의견을 듣고 싶습니다! 파일 > 기본 설정 > GrabCAD Labs를 통해 의견을 보내주십시오.
- Stratasys F123 Series의 최신 멤버인 F120의 베타 릴리스는 GrabCAD Print에서 지원됩니다. 자세히 알아보기.
- SMART, Sparse 또는 Box 지원 스타일을 선택할 때 FDM 인쇄를 위한 지원 구조에서 모델 재료를 사용할 수 있습니다. 프린터가 모델과 서포트 재료를 전환하는 데 몇 초가 걸리기 때문에 이 기능을 사용하면 여러 작업 계층에서 모델 재료만 사용할 수 있어 인쇄 시간이 절약됩니다.
- 버튼을 클릭하면 Insight 모델이 Insight에서 GrabCAD Print로 전송될 수 있습니다. Insight 도구 모음에서 "GrabCAD Print에서 작업 작성" 아이콘을 선택하면 CMB 파일이 생성되고 Insight에서 GrabCAD Print로 파일이 전달되고 올바른 프린터 유형이 자동으로 선택됩니다.
GrabCAD Print 버전 1.28, 3월 2019
빌드 번호 1.28.16.50383 출시: 21 3월 2019
1.28업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- 더 많은 부품을 인쇄할 기술이나 용량이 부족합니까? SDM 홈 페이지로 이동하려면 앱 > "Statasys Direct Manufacturing으로 부품 제조"로 이동하십시오(미국/캐나다 고객만 해당)
- 이제 고급 FDM 탭에서 자동 방향 지정을 사용할 수 있습니다. 표준 바디와 병합된 바디는 모두 자동 방향 지정이 가능하므로 지원을 최소화하고 빌드 시간을 단축할 수 있습니다.
- 이미지 텍스처가 있는 OBJ 파일이 지원됩니다. PolyJet 프린터에서 인쇄할 때 OBJ 파일과 관련된 이미지 텍스처 파일을 읽고 표시하며 병합된 결과를 인쇄합니다.
- F123 시리즈 프린터에서 6선 선형 주입을 사용할 때 부품 품질 문제가 해결되었습니다. 재료 F123 ASA 및 F123 ABS의 경우, 0.005 인치(0.127mm) 및 0.007 인치(0.178mm) 슬라이스 높이에서 과충진을 방지하기 위해 채우기 밀도가 감소합니다.
- 인쇄 설정, 방향 및 배율 패널이 활성 트레이의 모델 또는 바디만 계산하도록 업데이트되었습니다.
- 프린터 기록에 "Duration"이 모든 작업에 대해 00:00:00을 표시한 데스크탑 앱에서 내보내는 버그가 있었습니다. 이 버그는 수정되었습니다.
- 이 앱은 temp 디렉토리에 일부 파일을 생성하며 이전에는 시간이 지남에 따라 축적되었습니다. 이제는 앱 종료 시 자동으로 지워집니다.
- 일부 사용자에게 GrabCAD Print를 시작할 수 없는 경우 “너무 많은 인스턴스...”오류가 표시되는 버그가 나타납니다. 이것은 중단된 GrabCAD Print for SOLIDWORKS 추가 기능으로 인해 발생했습니다.
GrabCAD Print 버전 1.27, 2월 2019
빌드 번호 1.27.17.49710 출시: 25 2월 2019
1.27업데이트에 대한 비디오를 보려면 여기를 클릭하십시오.
- F123 시리즈 및 Fortus 900mc에 대해 1.24에 도입된 가변 폭 채우기는 이제 Fortus 380mc, 380mc CFE 및 450mc에서 사용 가능합니다. 이 기능을 사용하려면 프린터 펌웨어의 버전 6.1이 필요합니다(13 3월 2019부터 사용 가능). 여기 지침에 따라 컴퓨터의 펌웨어를 업데이트합니다.
- FDM 프린터에서 인쇄할 CMB 파일을 가져오면 올바른 프린터가 자동으로 선택됩니다. 또한 이제 Z 축에 대해 해당 모델을 회전할 수 있습니다.
- Vero 및 VeroFlex와 같은 PolyJet 인쇄 작업에서는 특정 재료 조합을 사용할 수 없으며 Digital ABS용으로는 두 가지 RGD 재료 중 하나만 사용합니다. 이전에는 지원되지 않는 이러한 재료 조합이 프린터에 로드된 경우 작업 자체가 지원되지 않는 조합을 사용하지 않더라도 프린터에 오류 상태가 표시되고 인쇄가 비활성화되었습니다. 이제 지원되지 않는 조합이 작업에 사용되지 않는 한 사용자는 프린터에 현재 로드된 재료에 관계없이 작업을 인쇄할 수 있습니다.
GrabCAD Print 버전 1.26, 1월 2019
빌드 번호 1.26.13.48725 출시: 28 1월 2019
- GrabCAD Print 1.24에서 인쇄 설정 패널의 일부로 도입된 가변 폭 채우기를 이제 고급 FDM에서 사용할 수 있습니다.
- 퍼지 파트(F123 시리즈) 및 희생 타워(일부 Fortus 프린터)는 자동으로 트레이의 최적 위치에 배치되지만 수동으로 이동할 수도 있습니다. 이제 이렇게 하면 용지함 정렬 또는 프로젝트 정렬 도구를 사용할 때까지 해당 위치에 남아 있습니다. 퍼지 파트/희생 타워를 마우스 오른쪽 버튼으로 클릭하고 "자동 위치"를 선택하여 퍼지 파트/희생 타워를 재배치할 수도 있습니다.
- 이제 GrabCAD Print 및 고급 FDM에서 방향 재설정을 사용할 수 있습니다. 모델을 선택하고 재설정을 선택하면 초기에 트레이에 추가되었을 때 모델이 원래 방향으로 되돌아갑니다.
- 특정 상황에서 GrabCAD Print의 설치를 차단 한 문제를 해결했습니다. 설치 문제가 계속 발생하는 경우 print@grabcad.com에 문의하십시오.
GrabCAD Print 버전 1.25, 12월 2018
빌드 번호 1.25.17.47934 출시: 4 1월 2019
- 1.16의 베타 테스트를 위해 출시된 컴퓨터별 설치 관리자는 이제 print.grabcad.com에서 일반 제공됩니다. 현재 사용자별 설치 관리자보다 훨씬 안정적일 뿐만 아니라 IT 시스템 관리자가 학교 및 기업 조직에 배포할 수 있습니다. 전환 방법에 대한 자세한 내용은 도움말 문서를 확인하십시오.
- PolyJet 기술로 인쇄하기 전에 자체 교차점, 수밀/열린 표면 문제 및 반전 법선이 있는 OBJ 및 VRML 파일을 이제 GrabCAD Print로 복구할 수 있습니다. 사용해 보려면 print@grabcad.com에 문의하십시오.
- 인쇄 설정 패널의 툴팁은 가변 폭 채우기, 부품 빌드 스타일, 퍼지 파트 또는 희생 타워 유형, 시스템 모드 및 첫 번째 레이어 재료의 동작을 설명합니다. 팁 내용은 작업에 사용할 수 있는 옵션의 내용만 표시하도록 조정됩니다.
GrabCAD Print 버전 1.24, 11월 2018
빌드 번호 1.24.15.46944 출시: 20 11월 2018
- GrabCAD Print Advanced FDM은 FDM 빌드 속성을 자동으로 제어하여 원하는 부품 특성을 얻을 수 있는 강력하면서도 직관적인 툴 세트를 제공합니다. CAD 파일의 형상을 직접 할당하여 강도과 강성 영역을 지정하고, 채우기를 제어하며, 인서트로 구멍 주변에 충분한 재료를 확보하고, 이음새를 피할 수 있습니다. 필요한 모든 툴패스가 개별 레이어의 수동 조작을 필요로 하지 않고 자동으로 계산되므로, 궁극적으로 작업 준비에 소요되는 시간을 줄이면서 전반적인 부품 품질을 향상할 수 있습니다. 고급 FDM은 일부 프린터(F370,380mc,380mc CFE,400mc,450mc,900mc 및F900)에서 지원되며 파일 > 기본 설정 > FDM에서 사용할 수 있습니다.
- OBJ 파일은 이제 PolyJet 인쇄용 색상, 관련 .mtl 파일 및 시각 텍스처가 있는 GrabCAD Print에 추가할 수 있습니다. 이 기능은 파일 > 기본 설정 > GrabCAD Labs에서 활성화해야 합니다. 지원되는 항목을 확인하려면 여기로 이동하십시오.
- 새로 사용 가능한 재료는 GrabCAD Print에서 지원됩니다. J750/J735에서는 VeroCyan Vivid, VeroFlex Cyan/Magenta/Yellow Vivid 및 Agilus 30 White, Connex3에서는 MedABS 및 Med615, F900에서는 Antero 800NA, FDM TPU 92A라고 하는 F123 시리즈용 새로운 유연한 재료 등을 사용할 수 있습니다. Connex3 및 J750/J735의 새로운 재료를 사용하려면 포함된 소프트웨어를 업데이트해야 합니다.
- PolyJet 프린터를 선택하면 3D 뷰어 상단의 맨 위 버튼에 있는 새로운 디스플레이 모드를 통해 사용자는 모델 표면에 서포트 소재가 배치되는 위치를 볼 수 있습니다. 이것은 광택 마감의 경계를 결정합니다.
- 일부 FDM 프린터는 이제 내부 부품 빌드에 가변 폭 채우기를 사용하도록 선택적 설정을 제공합니다. 설정된 경우 가변 폭 툴패스는 기본 폭보다 작고 지정된 폭의 최소 폭보다 큰 기본 폭 툴패스 사이에 간격이 있는 모든 위치에 자동으로 배치됩니다. 이 기능은 최신 펌웨어 업데이트(버전 1.8 및 3.26)가 설치된 후 F123 시리즈 및 F900 및 Fortus 900mc에서 지원됩니다.
- 일정 보기의 작업 상세 정보 패널로 업데이트하여 선택한 작업에 사용되는 재료의 양을 시각적으로 나타냅니다. 도구 설명은 작업 완료 시 캐니스터 또는 카트리지에 남은 것으로 예상되는 재료의 양을 사용자에게 보여줍니다. FDM의 경우, 대기 중인 첫 번째 작업은 작업이 시작될 때 캐니스터/카트리지에 얼마나 많은 재료가 있는지를 나타냅니다.
- 일정 보기의 작업 세부 정보 패널에는 이제 FDM 프린터의 작업에 필요한 팁 크기 및 빌드 해상도가 나열됩니다. 이 기능은 사용자가 작업에 필요한 항목과 현재 프린터에 로드된 항목을 확인하는 데 유용합니다.
GrabCAD Print 버전 1.23, 10월 2018
빌드 번호 1.23.20.45529 출시: 17 10월 2018
- 내역 보고서에는 몇 가지 개선 사항이 있습니다.
- 작업 기록 내보내기는 이제 .XLSX 및 .CSV 형식으로 모두 사용 가능하며 .XLSX가 기본값입니다.
- 예열 시간과 작업 중에 사용된 다른 시간을 구별하기 위해 "지속 시간" 열이 시작과 끝 사이의 총 경과 시간인 "총 작업 시간"과 해당 시간을 제외한 "총 조형 시간"으로 나뉩니다. 프린터가 일시 중지되었거나 예열되었습니다.
- 기록 보기의 새 열은 작업의 부품 목록을 표시합니다. 동일한 부품의 수량은 부품 이름 뒤에 (#)와 함께 표시됩니다. 예를 들어, "HingePin(3)"입니다. 현재 이 기능은 FDM 프린터에서만 사용할 수 있습니다.(참고: GrabCAD Print 1.22 및 이전 버전으로 인쇄된 작업에는 여기에 암호화된 부품 이름이 표시됩니다.)
- FDM 프린터의 경우, 내보낸 작업 기록에는 이제 지원 및 모델 팁 크기에 대한 두 개의 열이 포함됩니다.
- Fortus 450mc 프린터의 ULTEM™ 9085. 013" 해상도로 파트를 인쇄할 수 있습니다
- 모델은 설정된 재료 특성에 따라 무광 또는 광택으로 표시됩니다.
GrabCAD Print 버전 1.22, 9월 2018
빌드 번호 1.22.24.44746 출시: 26 9월 2018
- GrabCAD Print의 자동 업데이트를 비활성화하는 새로운 기본 설정 옵션이 있습니다. 업데이트가 제공되면 알림을 받게 됩니다.
- CAD 파일을 더 정확하게 가져오는 새로운 기본 설정 옵션이 있습니다. 이 옵션을 사용하면 CAD 파일을 나타내는 메시에 삼각형이 추가되지만 성능에 영향을 미칩니다.
- 이 릴리스에서는 프린터가 GrabCAD Print에 연결하는 방법(업데이트 후 사라지는 프린터 목록 포함)에 대한 특정 문제를 수정하고 향후 잠재적 인 연결 문제를보다 잘 처리 할 수 있도록 오류보고를 개선했습니다.
- 이제 모델은 모든 FDM 프린터에 대해 자동 방향이 지정되므로, 최소한의 서포트 재료를 생성하게 됩니다.
- .005" 해상도를 사용할 때 ABS 및 ASA용 F123 프린터의 기본 레이어로 서포트 재료를 사용하여 작업을 인쇄할 수 있습니다. 이렇게 하면 트레이 접착 문제의 위험이 증가하지만 작은 부품을 더 쉽게 제거할 수 있습니다.
- 밀도가 두 배인 충전물이 있는 FDM 프린터에서는 이제 hexagram 충전 스타일이 옵션입니다. 이 패턴은 매우 강력하고 효율적으로 빌드할 수 있습니다.
- 근무 시간과 인쇄 시작이 지연되면 일정 보기에서 대기열이 비어 있는 것처럼 보이기 때문에 대기 중인 작업을 보기 위해 오른쪽으로 스크롤해야 할 때 나타나는 새로운 버튼이 있습니다.
- 현재 일정 보기에서 인쇄 중인 작업을 클릭하면 작업이 완료될 때 남은 재료의 예상치를 볼 수 있습니다. 또한 FDM 프린터의 경우 다음 작업의 시작 재료 수준을 추정할 수 있습니다.
- 조각 미리 보기에서 이음새(FDM 프린터의 경우 툴패스가 시작되고 끝나는 지점)가 표시됩니다.
- 부품은 Antero 800NA를 사용하여 450mc 프린터에서 인쇄할 수 있습니다.
GrabCAD Print 버전 1.20, 7월 2018
빌드 번호 1.20.50.42688 출시: 18 7월 2018
- PolyJet 프린터의 지연된 시작 기능을 이제 사용할 수 있습니다! PolyJet 프린터가 유휴 상태이고 대기열이 비어 있는 경우 인쇄 버튼을 누른 후 지정된 시간에 인쇄가 시작되도록 예약할 수 있습니다. 이 기능은 GrabCAD Print Server를 통해 프린터에 원격으로 연결한 경우 아직 사용할 수 없습니다.
- 일정 보기에서 이제 F123 시리즈 프린터의 카메라 이미지에서 버튼을 클릭하여 전체 해상도로 확대할 수 있습니다. 모든 프린터의 작업 미리 보기 이미지에 동일한 기능을 사용할 수 있습니다.
- 3개월 테스트 후 Connex3 시스템은 GrabCAD Print에서 완벽하게 지원됩니다. 시작하려면 설치 안내서를 확인하십시오.
- GrabCAD Print는 새로운 Fortus 380mc Carbon Fiber Edition 프린터를 지원합니다.
- GrabCAD Print의 로그인 세션은 2개월 동안 사용하지 않으면 만료됩니다. 이전에는 만료일이 1주였습니다.
- PolyJet 프린터용 Vivid Vero 재료를 새로 구입하면 해당 재료를 GrabCAD Print에서 선택할 수 있습니다.
GrabCAD Print 버전 1.19, 6월 2018
빌드 번호 1.19.14.41748 출시: 15 6월 2018
- 인쇄를 클릭하여 PolyJet 프린터로 작업을 보내면 프린터에 충분한 재료가 적재되지 않았거나 휴지통이 가득차면 경고가 표시됩니다.
- 많은 수의 중복 파일을 포함하는 작업은 이전보다 빠르게 처리됩니다. 또한 복합 또는 다중 본문 VRML 파일의 파일로드 시간이 60-80% 향상되었습니다.
- GrabCAD Print Server를 통해 프린터에 로컬로 연결되어 있거나 원격으로 연결된 프린터 구성 파일을 내보낼 수 있습니다.
- GrabCAD Print는 이제 새로운 Stratasys F900 시스템 유형을 지원합니다. Stratasys F900은 Fortus 900mc 시스템의 대체품이며 업그레이드된 수분 조절 시스템 및 일반 시스템 기능 향상을 포함합니다.
GrabCAD Print 버전 1.18, 5월 2018
빌드 번호 1.18.19.40241 출시: 10 5월 2018
- PolyJet 사용자를 위한 향상된 몇 가지 기능은 다음과 같습니다.
- 인쇄 설정을 위한 새로운 복사하여 붙여넣기 기능.
- 트레이 유효성 검사, 평가 및 대기열 처리를 위한 진행 막대.
- 복제된 무거운 STL을 인쇄할 때 향상된 슬라이서 안정성.
- 이제 Agilus 재료는 SUP706B 서포트 재료로 인쇄할 수 있습니다. 새 서포트 공식(706B라고도 함)을 받은 경우에만 이 조합을 사용하십시오.
- SOLIDWORKS용 GrabCAD Print 추가 기능은 이제 SOLIDWORKS 2018에서 지원됩니다. GrabCAD Print 1.18를 업데이트한 후 제어판에서 설치를 수정하여 추가 기능을 설치하십시오.
GrabCAD Print 버전 1.17, 4월 2018
빌드 번호 1.17.14.39209 출시: 12 4월 2018
- Connex3 시스템(Objet260, Objet350 및 Objet500 포함)은 곧 지원될 예정이며 지금 바로 공개 베타 테스트에 참여할 수 있습니다! 또한 지금 다운로드할 수 있는 최신 포함된 소프트웨어 업데이트를 설치하십시오. 공식 베타 계약에 서명할 필요가 없습니다. 다운로드 링크와 전체 설명서에 대한 내용은 여기에서 확인하십시오.
- 이제 PolyJet 트레이 예측 시 실제 진행률 표시줄이 표시됩니다.
- 색상 및 텍스처 프로파일은 PolyJet 프린터의 용지함을 변경할 때 기본값으로 되돌아가 사용자가 실수로 권장되지 않는 프로파일을 프로파일에 남기는 것을 방지합니다.
GrabCAD Print 버전 1.16, 3월 2018
빌드 번호 1.16.29.38429 출시: 20 3월 2018
- 장비별 설치를 위해 GrabCAD Print에 완전히 새로운 설치 관리자를 사용할 수 있습니다. 이렇게 하면 GrabCAD Print를 컴퓨터 랩 PC에 쉽게 설치하고, 시스템 관리자가 기업 차원에서 배포할 수 있습니다. 액세스를 요청하려면 여기에서 자세히 읽고 print@grabcad.com(으)로 이메일을 보내십시오.
- 이제 CAD 패키지의 최신 버전이 지원됩니다. 여기에는 SOLIDWORKS 2018, Creo 4.0, Inventor 2018 등이 포함됩니다. 여기서 전체 목록을 확인하십시오.
- 최근 업데이트에서 당사는 선택한 프린터의 현재 구성과 인쇄 설정을 동기화할 수 있는 새로운 기능을 도입했습니다. 이 업데이트에서 당사는 앱을 시작할 때 바로 이 동작을 자동으로 실행되도록 만들었습니다.
- PolyJet 인쇄물(일반적으로 VeroPureWht)의 서포트 그리드에 사용되는 재료는 이제 '기타' 대신 예측 결과 창에 지정됩니다.
GrabCAD Print 버전 1.15, 2월 2018
빌드 번호: 1.15.13.37334 출시 날짜: 19 2월 2018.
- FDM 프린터의 인쇄 설정 패널이 새로운 모양과 느낌으로 새로 단장되었습니다. 설정이 현재 프린터 구성과 다른 경우 관련 표시가 나타나며, 클릭 한 번으로 모든 설정이 일치되도록 업데이트할 수 있습니다. 또한 새로 생성된 트레이의 설정은 현재 보고 있는 트레이의 설정과 항상 일치하므로, 여러 트레이가 있는 프로젝트의 인쇄 준비 속도를 높일 수 있습니다.
- PolyJet 사용자를 위한 '최적화' 확인란을 제어하는 정렬 도구에 새 슬라이더가 추가되었습니다. 정렬이 조형 시간을 최소화하거나 최소한의 서포트 재료 사용으로 최적화되는지 여부를 제어할 수 있습니다.
- 수정: 일정 보기가 화면에 남아 있는 경우 '지금' 라인은 천천히 시야에서 사라지지 않고 그대로 유지됩니다.
GrabCAD Print 버전 1.14, 1월 2018
빌드 번호 1.14.20.36110, 출시: 17 1월 2018
- 이제 프린터 패널의 세부 정보 화면에 모델과 서포트 팁 사용기록, FDM 시스템의 헤드 온도와 엔벨로프가 표시됩니다.
- FDM 시스템에 여러 재료 베이가 있는 경우 프린터 패널의 새 아이콘이 현재 프린트 헤드에 로드되어 있는 재료 베이를 나타냅니다.
- 이제 작업에 현재 프린터 구성과 맞지 않은 재료나 팁이 선택되어 있는 경우 조형 버튼을 클릭하면 팝업 경고가 나타납니다.
- 이제 Fortus 900mc 프린터에 사용할 수 있는 XML 형식으로 자세한 개별 조형 작업 로그를 다운로드할 수 있습니다. 보고서 보기로 이동하여 '옵션' 열의 다운로드 버튼을 사용하십시오.
- 이제 GrabCAD Print가 Stratasys J700 Dental 프린터를 지원합니다.
- 수정: 보고서는 사용자의 선호 단위와 관계 없이 재료 단위를 cm³로 표시했습니다. 이 문제는 수정되었습니다.
GrabCAD Print 버전 1.13, 12월 2017
빌드 번호 1.13.21.34870, 출시: 12 12월 2017
빌드 번호 1.13.23.35192, 출시: 19 12월 2017
- GrabCAD Print Server가 설치된 경우 이전에는 모바일 앱 연결, 온라인 보고서와 같은 PolyJet 시스템의 원격 액세스 기능 중 일부만 사용할 수 있었습니다. 이제 마지막 부분인 GrabCAD Print에서 원격 PC로 작업 보내기 기능을 사용할 수 있습니다.
- 여러 가지 개선 기능
- 이제 GrabCAD Print의 보고서 보기에 내보내기 버튼이 포함되었으며, 이 버튼은 FDM 시스템과 PolyJet 시스템 모두에 사용됩니다.
- 일부 사용자가 프린터를 선택할 수 없었던 보고서 보기의 버그가 수정되었습니다.
- Internet Explorer의 온라인 보고서에 발생한 일부 문제가 수정되었습니다.
- 예측 결과가 준비되어 있을 때 더 이상 '예측 보기'를 클릭할 필요가 없습니다. 자동으로 표시됩니다.
- 이제 iOS용 GrabCAD Print 앱의 작업 세부 정보에 예상 종료 시간이 포함됩니다.
GrabCAD Print 버전 1.12, 11월 2017
빌드 번호 1.12.26.33454, 출시: 13 11월 2017
- 이제 GrabCAD Print 데스크탑 앱의 보고서 보기에서 로컬 프린터의 작업 기록에 액세스할 수 있습니다. 이전에는 이 보고서가 GrabCAD Print Server를 설정한 후 온라인 보고서 페이지에서만 사용할 수 있었기 때문에 이것은 오프라인 모드의 사용자에게 큰 도움이 됩니다. (PolyJet 시스템, 원격 프린터, CSV 내보내기 기록은 아직 제공되지 않습니다.)
- 새 첨단 PolyJet 재료가 Stratasys에 의해 출시되었으며, 이제 GrabCAD Print에서 지원됩니다. Agilus, VeroFlex, DABS2 Plus에 대하여 자세히 알아보세요.
- Android 앱은 종종 계정에 연결된 프린터가 많은 경우 프린터를 찾지 못하는 경우가 있습니다. 이 제한 시간을 증가시켜서, 이제 이 문제가 발생하지 않습니다.
- 작은 가용성 개선 기능
- 2 GB 개별 파일 크기와 트레이 크기 한도가 제거되었습니다.
- 다른 작업이 진행되는 동안 더 이상 일정 보기로 전환되지 않습니다.
GrabCAD Print 버전 1.11, 10월 2017
빌드 번호 1.11.17.31736, 출시: 11 10월 2017
- 새 트레이 디스플레이, 특징:
- uPrint, Dimension, F123 시리즈 그리고, 이보다 소형인 Fortus 시스템의 실제 트레이 모양과 그리드 선.
- 대형 Fortus 시스템의 cm 또는 인치 단위 그리드 선(표시 단위 기본 설정을 따름).
- 적용 가능한 프린터의 보정 터치 포인트.
- Fortus 900mc는 더 작은 트레이 크기의 윤곽선을 표시합니다.
- 이제 GrabCAD Print를 사용하여 슬라이스 미리 보기에서 FDM 조형 작업에 일시 중지를 추가할 수 있습니다. 이전에는 이 기능을 Catalyst와 Insight에서만 사용할 수 있었습니다.
- 이제 GrabCAD Print를 사용하여 ULTEM™ 9085 CG 작업을 준비할 수 있습니다. 이전에는 이 재료를 Insight and Control Center를 통해서만 사용할 수 있었습니다. 사용자는 Fortus 900mc와 함께 T16A 팁을 사용할 수도 있습니다.
- 일부 사용자들이 SOLIDWORKS에서 GrabCAD Print 추가 기능을 실행할 수 없게 했던 원인인 문제가 해결되었습니다.
GrabCAD Print 버전 1.10, 9월 2017
빌드 번호 1.10.19.30507, 출시: 13 9월 2017
- 이제 Workbench 프로젝트에서 바로 모델을 GrabCAD Print에 추가할 수 있습니다. 여기로 이동하여 Workbench와 Print를 함께 사용하는 방법을 자세히 알아보십시오.
- GrabCAD Print Server를 사용하는 경우 조형 작업이 완료되거나 주의가 필요할 때 이메일로 알림을 받을 수 있습니다. GrabCAD 프로파일에서 설정을 조정하십시오.
- 이제 두 번 클릭 또는 끌어 놓기로 .PRINT 파일을 열 수 있습니다.
- 이제 GrabCAD Print가 Objet1000 Plus 프린터를 지원합니다. 설치 가이드를 읽으십시오.
- 파일 이름 또는 경로에 비 ASCII 문자가 있는 CAD 파일을 GrabCAD Print에서 로드할 수 없는 문제가 있었습니다. 이 문제는 수정되었습니다.
- CAD 파일 가져오기가 개선되었습니다. 이전에는 일부 파트에서 거칠거나 굽은 표면이 나타났지만 이것이 개선되어 표면이 훨씬 부드러워졌습니다.
- 이제 시작 메뉴에 'Insight for GrabCAD Print'에 대한 바로 가기가 생겼습니다. 이 기능을 사용하면 이전에는 GrabCAD Print의 앱 메뉴에서만 사용할 수 있었던 Insight의 동료 버전에 액세스할 수 있습니다.
GrabCAD Print 버전 1.9, 8월 2017
빌드 번호 1.9.27.701, 출시: 9 8월 2017
- 이제 Sacrificial Tower를 Fortus 조형 작업에 추가할 수 있습니다. 이렇게 하면 이음매 품질을 개선할 수 있으며, 이것은 나일론 12 CF로 조형할 때 필요합니다.
- 이제 GrabCAD Print에서 나일론 재료를 Fortus 프린터에 사용할 수 있습니다.
- 주의가 필요한 작업(예: 작업 전이가 작업 중에 재료가 다 떨어짐)에는 일정 보기의 해당 작업에 아이콘이 표시됩니다. 경고가 있는 총 프린터 수는 애플리케이션 왼쪽의 일정 보기 아이콘에 개수로 표시됩니다.
- 사용자는 프린터 패널에서 프린터의 작업 기록이 들어 있는 CSV를 내보낼 수 있습니다(FDM만 해당). 이렇게 하면 오프라인 고객들이 보고서를 활성화할 필요 없이 자신의 작업 기록 데이터를 내보낼 수 있습니다.
- 이전 버전 GrabCAD Print에서는 처음 설치 시 시스템 관리자 권한이 필요했습니다. 버전 1.9에서는 모든 사용자가 시스템 관리자의 자격 증명 없이 설치할 수 있습니다(선택적 SW 추가 기능이 포함되지 않은 경우).
GrabCAD Print 버전 1.8, 7월 2017
빌드 번호 1.8.16.652, 출시: 12 7월 2017
새 기능:
- GrabCAD Print에서 이제 ULTEM™ 9085 및 ULTEM™ 1010을 사용한 인쇄를 지원합니다. 따라서 이제 이러한 재료로 Insight에서 준비된 CMB 파일을 GrabCAD Print로 인쇄할 수 있습니다. 매개 변수를 수정하거나 앵커 핀 또는 벽 안정기와 같은 기능을 사용하려면 앱 메뉴에서 Insight를 사용하면 됩니다. 희생 타워를 추가하려면 Control Center를 사용해야 합니다. (ULTEM™ 9085 CG는 아직 GrabCAD Print에서 지원되지 않습니다.)
- 이제 사용자들이 FDM 프린터에 전체 프로젝트 정렬을 최적화할 수 있습니다(모든 트레이를 동시에). 이렇게 하면 사용자들이 가급적 많은 파트로 둘 이상의 트레이를 최적으로 패킹할 수 있습니다.
- FDM 프린터용 파트를 삽입할 때 파트는 조형 품질을 개선하기 위해 트레이 가운데로부터 정렬됩니다.
- F123 시리즈 프린터의 경우 지원되는 기능과 지원되지 않는 기능으로 하단 표면 부드러움이 개선되었습니다.
버그 수정 사항:
- J750 프린터 연결을 설정할 때 Windows 사용자 이름의 특수 문자가 더 이상 문제를 일으키지 않습니다.
- 일정에서 PolyJet 작업을 볼 때 '조형 모드'와 '조형된 슬라이스'를 다시 사용할 수 있습니다.
- 파트를 변환하면 부분 상단 레이어가 만들어지는 버그가 수정되었습니다.
- 일부 FDM 프린터 간 전환 시 가져온 CMB가 사라지는 버그가 수정되었습니다.
GrabCAD Print 버전 1.7, 6월 2017
빌드 번호 1.7.28.633, 출시: 14 6월 2017
- 이제 가져온 여러 CMB 파일을 트레이에 정렬할 수 있습니다. 이전에는 여러 CMB를 사용하는 사용자가 작업흐름에 Control Center를 사용해야 했습니다. 성능을 위해 CMB는 모델 보기로 단순화되지만, 슬라이스 미리 보기로 실제 모양을 볼 수 있습니다. 빈 프로젝트로 시작한 후 파일 > CMB 가져오기...로 이동하십시오.
- 파일 메뉴에 '최근 파일'이 추가되었습니다. 5개의 최근에 추가된 파일(아무 CAD 형식, CMB 또는 OBJZF)과 최근 5개 조형 프로젝트에 액세스할 수 있습니다.
- 이제 일정 보기에서 끌어 놓기를 사용하여 작업을 다시 정렬할 수 있습니다.
- 이제 GrabCAD Print용 SOLIDWORKS 추가 기능이 GrabCAD Print 설치 관리자에 함께 포함되었습니다. SolidWorks 추가 기능을 사용하면 CAD 파일을 SOLIDWORKS에서 바로 조형하도록 준비할 수 있습니다. 설치 지침을 확인하려면 GrabCAD Print의 앱 메뉴로 이동하십시오.
- 이제 조형 작업이 로컬 작업의 컴퓨터 프로파일 이름 대신 사용자의 실제 이름으로 표시됩니다.
- 이제 GrabCAD Print가 .JT 파일 유형을 지원합니다.
- 수정: 이제 비 ascii 문자(예: é 또는 à)가 들어 있는 파트를 J750에서 조형할 수 있습니다.
- 수정: Tango+가 로드되었지만 트레이에서 사용하지 않았을 때 J750 파트에 배율 문제가 있었는데, 이 문제가 해결되었습니다.
GrabCAD Print 버전 1.6, 5월 2017
빌드 번호 1.6.19.601, 출시: 9 5월 2017
- 작동 시간 소개! 회사 관리자가 이를 활성화하면 작동 시간 중에만 조형 작업이 정상적으로 시작되도록 일정 보기가 자동으로 프린터 대기열 디스플레이를 조정하여, 일정을 더욱 정확하게 예측할 수 있게 해줍니다.
- Shift-Select를 사용하여 신속하게 프로젝트 패널의 여러 모델을 선택할 수 있습니다. 이 기능과 box-select( 1.5)를 사용하면 여러 모델의 설정을 동시에 변경하는 것이 훨씬 빠릅니다.
- 클릭하여 끌어 놓기로 프린터 패널의 대기열 목록에 있는 작업의 순서를 손쉽게 바꿉니다.
- 뷰어의 성능을 높이기 위해 모델 보기에 모델의 '단순화된' 버전이 표시됩니다. 굽은 표면의 삼각형이 더 잘 보는 것을 확인할 수 있습니다. 이것이 조형 품질에는 영향을 미치지 않습니다. 프린터에 정확히 무엇이 전송되는지를 확인하려면 슬라이스 미리 보기로 이동하거나 시스템 기본 설정 > 디스플레이 설정에서 그래픽 품질을 '높음'으로 변경하십시오.
- F123 시리즈 프린터의 경우 이제 벽돌 모드 빌드 스타일이 추가되었습니다. 이것은 크고 조밀하며 단단하게 채워진 파트를 조형하여 파트의 말림을 줄일 때 유용합니다. 이것은 슬라이스 높이 0.005"과(와) ABS, ASA 또는 PC-ABS를 사용하는 경우에만 한합니다.
- 수정: J750 프린터의 경우 조형 시 오류를 유발할 수 있는 여러 가지 문제가 수정되었습니다. GrabCAD Print와 Job Manager를 이러한 수정 사항으로 업데이트하십시오.
- 수정 사항: 이제 표시 단위를 미터식으로 설정한 사용자에게는 슬라이스 높이가 선택한 단위로 표시됩니다.
GrabCAD Print 버전 1.5, 4월 2017
빌드 번호 1.5.15.549, 출시: 18 4월 2017
- 오프라인 모드 파트 2이(가) 여기 있습니다! 이제, 처음으로 설치할 때 인터넷 연결이 없는 경우 로그인을 건너뛸 수 있습니다. 이것은 GrabCAD Print 1.3에 장착된 오프라인 모드 기능의 후속 기능입니다. 여기에서 확인하세요.
- 이제 GrabCAD Print가 SOLIDWORKS 2017, Inventor 2017, NX 11.0, Solid Edge ST9를 포함한 최신 CAD 패키지 버전을 지원합니다. 여기서 전체 목록을 확인하십시오.
- 이제 프로젝트 패널의 트레이 미리 보기에서 트레이에 사용자 지정 이름을 지정할 수 있습니다. 조형을 클릭하면 작업이 이 이름을 상속합니다.
- 버전이 1.5인 전송된 모든 작업에는 온라인과 데스크탑 앱에 있는 일정 보기 작업 세부 정보의 트레이 미리 보기가 포함됩니다. 이것은 시스템 기본 설정 > 개인 정보에서 비활성화할 수 있습니다.
- 모델 보기의 Box select를 사용하면 많은 모델의 조형 설정을 한 번에 변경할 수 있습니다. 왼쪽 마우스 버튼으로 클릭하여 끌어 놓으십시오. 오른쪽으로 끄는 경우 상자에 완전히 들어 있는 모델만 선택됩니다. 왼쪽으로 끄는 경우 상자 경계 안애 부분적으로 포함되어 있는 모델도 선택됩니다.
- 이제 뷰어 상단의 버튼을 사용하여 보기 바로 가기와 원근감 설정을 간편하게 관리할 수 있습니다.
- 이제 재료 단위를 모바일 앱과, 보고서 그리고 온라인 일정 보기에 표시하는 방법을 선택할 수 있습니다. 여기서 설정을 변경하십시오. (로그인 후 모바일 앱이 업데이트됩니다.)
- 사용자에게 J750에 맞게 Job Manager를 업데이트해야 한다는 메시지를 표시하는 방법이 개선되었습니다.
- F123 시리즈 프린터의 경우 기본 레이어는 트레이 부착력을 높이기 위해 ABS 또는 ASA와 0.005" 슬라이스 높이를 사용하는 조형 모델 재료로 구성됩니다.
- 코어 프로세스와 조형 기능에 대한 다양한 조정을 거쳐 Stratasys F123 시리즈 프린터의 조형 품질이 개선되었습니다.
GrabCAD Print 버전 1.4, 3월 2017
빌드 번호 1.4.20.531, 출시: 14 3월 2017
새 기능:
- 이제 GrabCAD Print가 모든 uPrint, Fortus, Dimension 프린터를 지원합니다. 전체 목록을 확인하십시오.
- 1.3에서 트레이를 예측한 후 '트레이 정렬'을 누르면 FDM 조형을 위한 패킹이 크게 개선되었습니다. 이제 정렬 도구의 '최적화' 확인란을 이용하여 더욱 쉽게 작업할 수 있습니다. 일부의 경우 이를 통해 이전보다 트레이당 2배의 파트를 수용할 수 있습니다.
- 사용자 지정 프린터 이름 소개! 프린터 설정 패널에서 프린터의 이름을 바꾸십시오. 그러면 회사 계정의 모든 구성원에 대해 사용자 지정 이름이 데스크탑, 웹, 모바일에 표시됩니다. 여기서 자세히 알아보십시오.
- 이제 GrabCAD Print Server(버전 0.144.0318)의 최신 업데이트를 통해 Stratasys J750이 GrabCAD Print 모바일 앱���, 온라인 일정 그리고 보고서에서 지원됩니다. 원격 액세스 조형은 곧 구현됩니다.
- 또한, GrabCAD PolyJet Job Manager가 이미 실행 중인 경우 이제 '네트워크 프린터 추가' 옵션을 사용하여 처음으로 J750에 연결할 수 있습니다.
- 프린터가 프린터 패널의 '내 프린터'에 표시되는 방법이 개선되었습니다.
- 프린터 연결이 끊어지면 목록에서 사라지지 않습니다. 그 대신, 상태가 '연결 끊어짐'으로 표시됩니다.
- 이제 '오프라인 프린터'가 '프린터 템플릿'으로 불리며, 네트워크 프린터 아래 별도의 섹션에 표시됩니다.
- F370 조형 설정에 대한 작은 업데이트:
- 이제 PLA 조형을 초안 모드라고 합니다.
- 퍼지 파트 스타일은 기본적으로 '전체 높이'를 사용합니다.
버그 수정 사항:
- 일부 J750 사용자가 Tango+ 재료가 로드되었지만 트레이에 사용되지 않은 경우 예측이 정확하지 않거나 조형에 실패하는 문제를 보고했는데, 이러한 문제가 해결되었습니다.
- 이제 일정 보기에 향후의 J750 작업에 대한 시간과 재료 예측이 표시됩니다.
- 일부 J750 사용자들이 'error.0' 실패 메시지와 관련한 조형 실패 문제를 보고했습니다. 조형 실패를 야기한 문제가 수정되었으며, 동일한 문제가 다시 발생할 경우 이제 실패 메시지에 유용한 텍스트가 포함됩니다.
- 방향 지정 패널의 작은 2가지 버그가 수정되었습니다. 하나는 음수 십진수 값과 관련된 것이고, 하나는 +와 - 버튼에 관한 것입니다.
- 일부 F370 사용자에게 잘못된 레이어가 일부 들어 있는 퍼지 파트가 발생할 수 있었는데, 이 문제가 수정되었습니다.
GrabCAD Print 버전 1.3, 2월 2017
빌드 번호 1.3.25.508, 출시: 21 2월 2017
빌드 번호 1.3.23.503, 출시: 7 2월 2017
- Stratasys F123 시리즈 소개! 당사의 최신 프린터는 GrabCAD Print에서만 작동합니다. 여기서 자세히 알아보십시오.
- GrabCAD Print의 J750 지원은 베타 테스트가 완료되었습니다! 베타 프로그램에 참여해 주신 모든 분들께 감사 드립니다. J750을 가진 경우 이 가이드에 따라 GrabCAD Print로 조형을 시작할 수 있습니다.
- 현재 당사는 .SLDPRT 파일을 CAD 환경에서 직접 조형할 수 있게 해주는 SOLIDWORKS에 대한 추가 기능을 보유하고 있습니다. 여기에 대하여 자세히 읽어보거나 여기에서 다운로드하십시오.
- 많은 사용자가 GrabCAD에 로그인할 필요 없이 바로 설치하여 조형할 수 있는 기능을 원하고 있습니다. 이제 당사는
- 인터넷 연결이 끊어진 경우 GrabCAD Print를 통해 로컬 프린터를 계속 사용할 수 있습니다.
- 이것이 주로 이용하는 방식인 경우 시스템 기본 설정 > 개인 정보에서 오프라인 모드로 전환하여 경고 메시지를 끌 수 있습니다.
- 여전히 애플리케이션을 처음 실행할 때 최소 한 번은 로그인을 해야 합니다. 인터넷에 연결되어 있지만 로그인에 문제를 겪는 경우 문제 해결 가이드를 참조하십시오.
- 오프라인 기능의 두 번째 부분은 초기 로그인을 건너뛸 수 있는 '완전 오프라인' 솔루션입니다. 이것은 연말이면 출시될 것으로 예상됩니다.
- 정렬 도구가 Insight 또는 Catalyst만큼 만족스럽지 않은 경우 이 업데이트로 구현되는 대폭적인 개선을 확인할 수 있습니다! 먼저, '예측'을 눌러서 트레이를 슬라이스로 나누십시오. 그러면 '트레이 정렬'이 파트들을 더욱 가깝게 함께 패킹합니다.
- J750 베타 프로그램에 참여한 사용자의 경우 이 업데이트에 따른 일부 개선 기능을 확인할 수 있습니다.
- 이제 펌웨어 업데이트처럼 GrabCAD Print의 프린터 패널에서 Job Manager를 업데이트할 수 있습니다.
- 조형 설정 패널의 불투명도 슬라이더 문제가 수정되었습니다!
- 이제 Insight가 GrabCAD Print에 함께 포함되어, F370 또는 Fortus 시스템을 위한 그룹 또는 툴패스 편집과 같은 더 많은 고급 기능을 사용할 수 있습니다. 여기서 자세히 알아보십시오.
GrabCAD Print 버전 1.2, 1월 2017
빌드 번호 1.2.11.469, 출시: 24 1월 2017
빌드 번호 1.2.9.464, 출시: 16 1월 2017
- 이것을 놓친 경우 여기에 보고서가 있습니다! 웹 브라우저의 오른쪽에서 작업 기록과 재료 사용량을 확인하십시오.
- 한 트레이에 너무 많은 파트를 추가하는 경우 새 트레이를 자동으로 만들 것인지 여부를 결정하는 시스템 기본 설정이 새로 생겼습니다.
- 도구 아이콘이 더 커지고 더 진해졌습니다. 다음에서 확인하십시오. 도구.
- 이제 회전 도구에서 클릭당 회전 정도를 사용자 지정하여, 더욱 쉽게 정확한 방향을 지정할 수 있습니다.
- 이제 VRML 파일이 분석 모드에 포함됩니다. 그러나 텍스처 매핑을 분리하지 않고 모델을 수리하려면 다른 소프트웨어를 사용해야 합니다.
- 일부 CAD 파일 판독기 문제 특히, 도넛 모양 모델 주위의 문제가 수정되었습니다.
GrabCAD Print 버전 1.1, 12월 2016
빌드 번호 1.1.28.454, 출시: 16 12월 2016
- 기본 네비게이션과 프로젝트 패널의 색상과 아이콘 개선 사항.
- 단위 기본 설정이 일정 보기에 반영되지 않은 버그가 있었는데, 이것이 수정되었습니다.
- 기타 수정 및 개선 사항.
GrabCAD Print 버전 1.0, 11월 2016
빌드 번호 1.0.32.424, 출시: 15 11월 2016
- 다른 프린터! 이제 GrabCAD Print와 함께 Fortus 380/450와 Fortus 900(제한 지원*)을(를) 사용할 수 있으며, Fortus 360/400과(와) J750은 현재 베타 테스트 중입니다. 액세스를 요청하려면 print@grabcad.com(으)로 이메일을 보내 주십시오.
- 재료량을 입방 센티미터로 확인할 수 있는 기능. 파일 > 시스템 기본 설정 > 단위 컨트롤 > 표시 단위로 이동하여 미터식 단위로 변경하십시오.
- .CMB.GZ 파일을 가져올 수 있는 기능.
- 이제 설치 관리자의 기본값은 운영 체제와 동일한 언어를 사용하여 설치하는 것입니다. 시스템 기본 설정 또는 설치 관리자의 첫 번째 화면에 있는 뒤로 버튼을 선택하여 언어를 변경할 수 있습니다.
- 새로운 사용자를 위한 더욱 직관적인 기본 마우스 제어. 여기서 업데이트된 구성을 확인하십시오. 기존 사용자는 영향을 받지 않습니다.
- 이제 채우기, 슬라이스 높이, 서포트 스타일이 선택된 모델과 서포트 재료에 대한 권장 설정으로 자동으로 업데이트됩니다.
- 기타 UI 개선 및 버그 수정.
*제한된 지원이란 기본 인쇄 준비가 지원되지만(Insight의 '녹색 플래그'와 유사), ULTEM™ 또는 나일론 12를 인쇄할 때 희생 타워를 사용하는 등의 일부 고급 기능은 아직 사용할 수 없다는 의미입니다.
