Примечания к выпуску GrabCAD Print
GrabCAD Print версии 1.98, январь 2025
Номер сборки 1.98.6.50666 выпуск 21 январь 2025.
  • Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
  • Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
  • Print Pro: The Assembly created while using the Split tool is now optional.
  • An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
  • For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
  • The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
  • When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
  • Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
  • The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
  • If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
GrabCAD Print версии 1.97, декабрь 2024
Номер сборки 1.97.10.49657 выпуск 17 декабрь 2024.
  • Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
  • Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
  • Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
  • Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
  • Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
  • F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
  • For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
  • The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
  • ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
  • Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
  • RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
  • A new material profile has been added to the Validated O2 collections.
    30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
    • Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
    • N3D-FR512 for FR-rating with higher elongation at break
    • FL300 from Forward AM for low Shore hardness elastomers in a clear color
    • MED414 for elastomeric applications requiring biocompatible capability such as ear bud
GrabCAD Print версии 1.96, ноябрь 2024
Номер сборки 1.96.8.49045 выпуск 20 ноябрь 2024.
  • Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
  • Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
  • Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
  • Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
  • GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
  • The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
  • Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
  • PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
  • ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
  • For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
  • Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
  • A new material profile has been added to both the Validated O2 and Open AM collections for P3.
  • New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
  • The History report in GrabCAD Print now includes material consumption per-job for P3.
GrabCAD Print версии 1.95, октябрь 2024
Номер сборки 1.95.11.47649 выпуск 21 октябрь 2024.
  • Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
  • A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
  • A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
  • A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
  • Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
  • The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
GrabCAD Print версии 1.94, сентябрь 2024
Номер сборки 1.94.18.46867 выпуск 18 сентябрь 2024.
  • New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
  • The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
  • When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
  • If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
  • A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
  • The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
  • The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
  • Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
  • Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
  • We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
    • Advanced Color Assignment: designed to produce more accurate and consistent shades
    • 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
    • 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
    • New TrueDent Clear Appliances: for fully translucent models and try-ins
    • Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
  • VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
  • When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
GrabCAD Print версии 1.93, август 2024
Номер сборки 1.93.14.46038 выпуск 29 август 2024.
  • Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
  • Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
  • The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
  • Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
  • VeroContactClear is now treated as a transparent material for all transparency-related features.
  • Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
  • When WSS is the selected support material, "No Grid" becomes the only available support grid type.
  • The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
  • A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
  • Additional dental applications for Origin printers are now supported.
GrabCAD Print версии 1.92, июль 2024
Номер сборки 1.92.17.44384 выпуск 16 июль 2024.
  • Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
  • Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
  • Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
  • Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
  • Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
  • Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
  • A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
  • Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
  • The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
  • For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
GrabCAD Print версии 1.91, июнь 2024
Номер сборки 1.91.16.43213 выпуск 22 июнь 2024.
  • Print Pro: Новое действие «Экспорт моделей в формате STL». Выберите одну сборку, деталь или тело и экспортируйте как файл STL из контекстного меню. Экспортированные модели будут содержать все исправления, сделанные в режиме анализа, а также все примененные подписи.
  • Print Pro: Функции Print Pro «Печать на лотке», «Печать на объекте» и «Смарт-вставка», которые раньше были доступны только на принтерах серии J7/J8, теперь доступны также на принтерах серии J3/J5.
  • GrabCAD Print теперь поддерживает импорт файлов форматов FBX (.fbx) и GLTF (.gltf, .glb).
  • Функция визуальной печати из углеродного волокна позволяет выполнять срезы более оптимальной высоты с помощью ABS-CF10, что обеспечивает более гладкую поверхность, и идеально подходит для тех случаев, когда внешний вид детали важен для области ее применения. Высота среза (0.0050 дюймов, 0.1270 мм) доступна на принтерах серий F123 и F123CR с головкой T14H (требуемая версия прошивки —  2.7).
  • OpenAM теперь поддерживается принтером Stratasys F900. Пакеты материалов создаются при тонкой настройке материалов с помощью OpenAM™, компилируются и распространяются для GrabCAD Print и принтера F900. Рекомендуемые и проверенные материалы Stratasys можно настроить и включить в пакеты, также как и доступные материалы других производителей (требуемая версия прошивки принтера —  4.23).
  • VICTREX AM™ 200 добавлен в линейку проверенных материалов для принтеров Fortus 450mc и Stratasys F900. VICTREX AM™ 200 — это высокопрочный полимер на основе ПЭЭК с отличными механическими свойствами, устойчивый к коррозии, воздействию температуры и химических веществ. VICTREX AM™ 200 подходит для высоты среза 0.0100 дюйма (0.2540 мм) с наконечником T14F, как для отрывных (SUP4000B), так и для растворимых (поддержка SR-100) опор (требуемая версия прошивки —  6.9).
  • Изменены свойства Nylon 12CF при усадке. Если в лотке используется Nylon 12CF и в нем есть модели как с разреженным, так и со сплошным заполнением, будет использоваться коэффициент усадки по оси Z для сплошного заполнения. Пользователи получат сообщение об этом изменении. В случае применения для всех моделей в лотке сплошного или разреженного заполнения будет использоваться коэффициент усадки по оси Z для выбранного варианта заполнения.
  • GrabCAD Print поддерживает адреса IPv6 при обмене данными с принтерами серии Stratasys F123, за исключением Stratasys F770 (требуемая версия прошивки —  2.7).
  • J5 DentaJet™ XL с картриджами весом 4кг — это последняя инновация в линейке продуктов серии DentaJet. Предназначенный для крупносерийного производства, этот принтер отвечает требованиям производителей кап, моделей C&B и имплантатов, и обеспечивает непревзойденную точность. Это оптимальное и экономически эффективное решение для крупносерийного производства безупречных продуктов, которое коренным образом меняет рабочие процессы.
  • Принтер J5 Digital Anatomy позволяет печатать на платформе J5 уникальные анатомические материалы Digital Anatomy, включая TissueMatrix, BoneMatrix, GelMatrix и RadioMatrix. Доступны различные анатомические элементы для печати анатомических моделей с биомеханическими свойствами, как у тканей человека. Для получения дополнительной информации нажмите здесь.
  • Теперь вы можете выбрать исходный цветовой профиль для печати цветных моделей на PolyJet. В разделе «Настройки лотка» > «Дополнительно» выберите sRGB (по умолчанию) и новый профиль Adobe RGB 1998. Профиль Adobe обеспечивает более насыщенные цвета (зеленый / желтый / красный), и мы рекомендуем использовать монитор с высокой насыщенностью цветов, чтобы лучше представить результат печати.
  • Стиль сетки опор, который ранее был заблокирован для принтеров серии J3/5, теперь можно изменить. Примечание. Этот стиль не будет разблокирован, если в принтер загружены материалы TrueDent.
  • Для соответствующих принтеров PolyJet на панели «Набор параметров УФ-светодиода» теперь доступны следующие операции:
    • Сохранить изменения в личном наборе параметров
    • Сохранить набор параметров (SSYS или частный) как новый личный набор параметров.
    • Переименовать личный набор параметров
    • Удалить личный набор параметров
  • Полипропилен (ПП) теперь поддерживается в пользовательском интерфейсе настроек 3D Nest для SAF.
  • При проверке теперь отображается сообщение о расстоянии между объектами с незначительными взаимными пересечениями, чтобы пользователь мог решить, можно ли продолжать печать.
  • При печати на принтерах P3 теперь можно выбрать материал по умолчанию и профиль опор, которые будут выбираться автоматически при запуске нового проекта.
  • При печати на принтерах P3 при изменении опор конкретной модели рядом с моделью на панели проекта появится значок предупреждения с подсказкой «Параметры опор модели отличаются от значений для лотка по умолчанию».
  • При печати на принтерах P3, если для всех выбранных моделей установлен одинаковый профиль опоры, их точки крепежа и/или опорные конструкции можно создавать автоматически нажатием одной кнопки.
GrabCAD Print версии 1.90, май 2024
Номер сборки 1.90.16.41968 выпуск 22 май 2024.
  • Print Pro: Новое действие «Разделить» доступно в контекстном меню при выборе файлов STL на лотке. Разделение преобразует файл STL с несколькими оболочками в сборку с несколькими телами. Параметры модели затем можно применить к каждому телу. Модель не изменяется, если идентифицирована только одна оболочка.
  • Print Pro: Для подписей можно выбрать шрифт Allerta Stencil. Чтобы выбрать этот шрифт, разверните раскрывающееся меню «Подписи» и выберите Allerta Stencil. Шрифт Atkinson Hyperlegible по-прежнему является шрифтом по умолчанию.
  • Print Pro: Атрибут модели «Имя сборки» теперь можно включать в шаблоны подписи. Имя сборки имеет те же модификаторы, что и имя детали («С начала/конца», «Пропустить» и «Длина»). При отсутствии структуры сборки поведение имени сборки и имени детали одинаково.
  • Print Pro: Опора в качестве материала — настройка PolyJet, позволяющая создавать текстурированную отделку конструкций путем печати двойной глянцевой и матовой поверхности, — теперь доступна для всех принтеров серии J.
  • На панель инструментов «Вид» добавлены новые виды. В дополнение к стандартному режиму, в котором модели отображаются с тенями, появились новые опции — «Каркасный режим» и «Каркасный режим с тенями», в которых модели отображаются как прозрачная каркасная сетка или каркасная сетка с тенями соответственно. Новые виды несовместимы с Предварительным просмотром поддерживаемых поверхностей.
  • В GrabCAD Labs добавлена возможность печати в FDM без вспомогательных структур. После включения этой функции (Файл > Настройки > GrabCAD Labs) в качестве параметра «Стиль опоры» на панели «Параметры опор» будет задано «Без опор». Модель будет напечатана с основой, но без других вспомогательных структур.
  • Решена проблема, из-за которой модель не могла переориентироваться при наличии жертвенной башни полной высоты.
  • Для печати SAF теперь можно выбрать подвложение, чтобы создать вложение в определенной области пакета с контролем размера по оси X, Y, Z и положения по оси X, Y, Z источника области, заданного из любого выбранного угла пакета
  • Наименьший размер текста для подписей SAF уменьшен до 10 пт.
  • При печати P3 точки крепежа, добавленные или перемещенные вручную, будут отображаться другим цветом по сравнению с точками крепежа, которые были созданы автоматически.
GrabCAD Print версии 1.89, апрель 2024
Номер сборки 1.89.16.40685 выпуск 16 апрель 2024.
  • Получайте расценки и заказывайте детали в Stratasys Direct в GrabCAD Print в новом режиме «Детали по запросу». Доступно для широкого спектра материалов FDM, доставляется по США.
    Для печати FDM решена проблема, из-за которой создаваемая для модели со стабилизаторами ограничительная рамка оказывалась больше, чем необходимо, что приводило к нарушению объема сборки.
  • Новая возможность для индустрии моды: Печать на одежде. Упрощенный интерфейс включает совместимость с новым инновационным комплектом лотков Direct to Garment, который позволяет дизайнерам внедрять сложные 3D-элементы непосредственно в готовую одежду.
  • Новая кнопка «Заполнить выбранные» на панели создания вложений H350 позволяет разместить столько дубликатов одной детали, сколько поместится в пакете.
  • Для печати P3 теперь можно создавать точки крепежа и/или опору для нескольких моделей за одну операцию, если все модели имеют один и тот же профиль опоры.
  • Для печати P3 некоторые материалы (в основном эластомеры) требуют дополнительного усиления опоры при создании высоких каркасов. Вы можете контролировать тип усиления для каждых профиля опоры, лотка или конкретной модели. Эта опция уже добавлена в профиль эластомерных материалов SSYS.
  • Для печати P3 определение материала предусматривает параметры размещения по умолчанию для каждого материала: «Зазор между моделями» и «Зазор от границ печати». Пользователи OpenAM могут изменять эти значения для своих личных материалов. Любой пользователь может изменить эти параметры для каждого лотка (через панель «Разместить»).
GrabCAD Print версии 1.88, март 2024
Номер сборки 1.88.14.39413 выпуск 19 март 2024.
  • Print Pro: GrabCAD Print Pro теперь включает в себя функции для PolyJet, которые ранее были доступны только через Пакет исследования PolyJet...
      • Печать непосредственно на лотке (только для серии J7/8) — позволяет печатать на таких материалах, как стекло или углеродное волокно, обеспечивая идеальную гладкость поверхности на нижней стороне деталей и устраняя необходимость в последующей обработке на нижней стороне.
      • Воздух в качестве материала (только для серии J7/8) — позволяет использовать воздух вместо смолы, что значительно снижает вес деталей, обеспечивая экономию материала до 30%.
      • Smart Insert™ (только для серии J7/8) — позволяет встраивать различные функциональные/декоративные элементы непосредственно в отпечаток.
      • Печать на объекте (только для серии J7/8) — позволяет настраивать и персонализировать модель с помощью прямой печати на объекте на различных подложках.
      • Приложение Voxel Print (только для серии J7/8) — инструмент для печати данных срезов, определенных другим программным обеспечением, позволяющий контролировать каждую деталь модели, включая цвет, прозрачность и твердость по Шору на уровне вокселей.
    • ...другие новые функциональные возможности...
      • Опора в качестве материала (только для J750 и J850 Prime) — позволяет создавать текстурированную отделку конструкций путем печати двойной глянцевой и матовой поверхности.
      • Жидкость в качестве материала (только для серии J7/8) — позволяет создавать полости, например микрофлюидные конструкции, полые трубки, гидравлические детали и т. д.
      • Высокоскоростной режим (только для J55) — сохраняет ту же толщину слоя, но работает с удвоенной скоростью при использовании материалов 2.
    • ...а также некоторые функции, уже доступные в Print Pro для FDM и SAF:
      • Подписи
      • Анализ толщины
      • Сборка/Разборка
      • Сторонние плагины
  • Print Pro: В экспортированных результатах оценок теперь используется формат времени чч:мм для упрощения их включения в расчеты.
  • GrabCAD Print теперь поддерживает следующие версии САПР:
    • СОЛИДВОРС 2024
    • Inventor 2024
    • NX серии 2306
    • Солид Эдж 2024
    • .X_T 36
    • .JT 10.9
  • Цифровые материалы (DM), представляющие собой смесь Agilus CMY и VeroUltraWhite, VeroPureWhite или VeroClear, теперь доступны на всех принтерах серии J7/8 во всех режимах печати, разрешенных для этих материалов. Имена DM имеют префикс FLXAC.
GrabCAD Print версии 1.87, февраль 2024
Номер сборки 1.87.18.38549 выпуск 28 февраль 2024.
  • Print Pro: Результаты оценки для проектов Pro теперь содержат смету затрат на вкладках «Сводка по лотку/вложению» и «Отчет о сборке» (для каждой детали). Расчет стоимости можно настроить на новой вкладке в окне результатов оценки или в настройках принтера.
  • Вид сечения добавлен на панель управления в верхней части средства просмотра. В нем можно просмотреть особенности моделей, которые в иных случаях могли бы быть скрыты. Его можно использовать в сочетании с инструментом измерения или инструментом создания опоры Origin. После активации вида сечения следующими кнопками можно выбрать плоскость и направление секционирования, или же можно использовать маркеры перетаскивания для секционирования под другими углами.
  • Текст в окне результатов оценки теперь можно выбирать и копировать в буфер обмена сочетанием клавиш Ctrl+C.
  • Инструмент «Позиционирование», ранее доступный только для проектов PolyJet и Print Pro, теперь доступен для всех технологий Print Standard.
  • Значение по умолчанию параметра «Утолщение тонких стенок» в принтерах серии F123 изменено на «Деактивировано».
  • Исправлена проблема, из-за которой не создавался контур в оболочке детали и в некоторых случаях в прилегающем к ней заполнении.
  • Stratasys F3300, новый широкоформатный промышленный принтер FDM, теперь доступен для выбора в GrabCAD Print. Чтобы ознакомиться со сведениями о функциях и производительности Stratasys F3300, щелкните здесь, или выберите Stratasys F3300 из списка шаблонов принтеров, чтобы просмотреть доступные материалы и настройки.
  • Визуализация поддержки PolyJet, доступная на полосе управления видом в верхней части средства просмотра, обеспечивает улучшенный обзор за счет отображения поддерживаемых областей синим цветом, а не в виде шахматной доски.
  • При выборе этого параметра деталь располагается в фактическом положении лотка, как показано на экране, без оптимизации процесса печати. Использование параметра «Абсолютное положение» может привести к снижению качества печати мелких деталей.
  • Инструмент измерения, добавленный для других технологий в обновлении 1.83, теперь доступен для подготовки к печати PolyJet.
  • Для проектов SAF теперь доступна мощная и динамичная версия отчета о сборке. В результатах оценки выберите «Отчет о сборке», затем выберите «HTML» в раскрывающемся списке экспорта в правом верхнем углу. Полученный файл можно открыть в любом веб-браузере. Он содержит оценки вложения и каждой детали, а также интерактивные предварительные 3D-просмотры вложения и каждой детали, показывающие ее расположение во вложении. Доступен также инструмент поиска, который поможет найти конкретные детали по названию.
  • Подпись для камеры для спекания теперь отображается в предварительном просмотре, что позволяет понять, поместится ли она в доступное пространство.
  • Для проектов P3 исправлена ошибка, не позволявшая принимать значения компенсации по оси Z. Обратите внимание, что по-прежнему действует правило, согласно которому компенсация по оси Z не может превышать значение проникновения детали поддержки.
  • For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
    • Поддерживаемый радиус островка: радиус вокруг первого признака островка, который получит дополнительные точки крепежа.
    • Внутреннее расстояние островка: расстояние между этими дополнительными точками крепежа.
  • Additional updates for P3 support parameters:
    • Для промышленной модели максимальный диаметр основания был увеличен с 10 до 30 мм.
    • Для стоматологических моделей Проникновение детали может быть равно 0.
GrabCAD Print версии 1.86, январь 2024
Номер сборки 1.86.24.37111 выпуск 29 январь 2024.
  • Исправлена ошибка, из-за которой при вычислении траектории инструмента FDM крупные детали могли нарушать объем сборки или мелкие детали могли задевать друг за друга.
  • Обновлено средство просмотра 3D для подготовки к печати PolyJet. Это обновление было необходимо для работы функций, которые появятся в ближайшее время, но на данный момент никакие из этих изменений не заметны. Однако при необходимости вы можете вернуть старое средство просмотра в меню Файл > Настройки > PolyJet.
  • Файлы, созданные с помощью приложения GrabCAD Voxel Print (файлы .gcvf), теперь может импортировать любой пользователь принтеров серии J. При использовании приложения Voxel Print для создания файлов .gcvf по-прежнему требуется лицензия, но импорт файлов теперь доступен всем пользователям.
  • Усовершенствована возможность работать с менее чем 7 материалами модели в режиме печати High Mix (с использованием очищающего материала для других каналов); теперь она включает в себя режим печати высокого качества.
  • Три обновления для пользователей J5 DentaJet
    • Инструкции по использованию (ИИ) материалов TrueDent теперь отображаются, если выбран принтер J5 DentaJet с материалами TrueDent.
    • Панель настроек модели для печати TrueDent была переработана для большего удобства использования. Легко выбирайте избранные материалы и материалы по умолчанию для оттенков десен и зубов.
    • В средстве создания моделей Exocad пользователи J5 DentaJet теперь могут применять комплексный рабочий процесс — от сканирования полости рта до полноцветной печати модели. Новый цветовой профиль в GrabCAD Print позволяет сопоставлять цвета с Exocad.
  • В процессе отверждения напечатанных деталей Origin лишний материал может скапливаться на обращенных вниз поверхностях (так называемое переотверждение). С помощью нового параметра «Компенсация по оси Z» это можно исправить за счет обращения этих поверхностей вверх.
  • Для пользователей Origin Dental для параметра «Фильтровать опору в полости» теперь отображается новое сообщение с предупреждением о том, что некоторые необходимые опоры могли быть удалены.
  • Если использование распорных конструкций P2P невозможно из-за ограничений по длине или высоте, при создании опор автоматически будут использоваться распорные конструкции P2P.
GrabCAD Print версии 1.85, декабрь 2023
Номер сборки 1.85.10.35841 выпуск 4 январь 2024.
  • Print Pro. Два обновления для подписей
    • Теперь можно удалить все подписи одним действием, нажав кнопку на панели подписей.
    • При создании подписи шаблона теперь доступен предварительный просмотр текста подписи на детали, что упрощает настройку размера, положения и поворота.
  • В принтерах серии J8 теперь можно использовать картриджи с чистящей жидкостью в качестве замены материалов модели в режиме печати с использованием 7-материала. Используя эту функцию, вы можете заливать чистящую жидкость в каналы печати (максимум 4), продолжая печатать, благодаря чему теперь можно печатать при замене материалов.
  • Теперь вы можете отправить задание на печать на принтер Connex3, в который загружены материалы 2 —так называемый режим DM2. (Примечание: для этого необходимо отключить расширенную программу разбиения на слои в меню Файл > Настройки > PolyJet).
  • Возможность использования одной УФ-лампы при печати в режиме высокого качества (HQ) теперь доступна по умолчанию в принтерах J850 Prime, J850 Prime Fabrix, J850 Pro, J835 и J750.
  • Соотношение анатомических материалов в комбинациях с другими материалами моделей или опор ограничено. Проверка этих ограничений добавлена на каждом этапе модуляции шума. Исправлено ограничение для SUP706: содержание SUP706 во внешних слоях должно быть менее 50% в комбинации с BoneMatrix, любым материалом Agilus30 или любым материалом Vero.
  • Улучшения параметров 3D-формы
    • Набор параметров УФ-светодиода можно выбрать, не открывая панель набора параметров.
    • Панель набора параметров открывается кнопкой «Управление набором параметров».
    • Определено общее количество срезов, включая адгезионный слой.
  • Для принтеров Origin на индикатор хода выполнения добавлена кнопка «Отмена» для процессов «Точки крепежа» и «Создание опор». Созданные ранее точки крепежа или опорные конструкции будут удалены.
  • При изменении параметра на панелях «Точки крепежа» и «Опора» в имени «Профиль опоры» теперь отображается звездочка (*) рядом с именем профиля опоры, указывая на то, что изменения не сохранены. Для отмены изменений параметров нажмите кнопку «Вернуться к профилю».
GrabCAD Print версии 1.84, ноябрь 2023
Номер сборки 1.84.12.35248 выпуск 30 ноябрь 2023.
  • Print Pro. Представляем инструмент «Gap Analysis» (Анализ зазоров)! Инструмент «Thickness Analysis» (Анализ толщины) был усовершенствован и теперь позволяет обнаруживать в моделях промежутки, например карманы, разрешение которых ниже разрешения принтера. Этот инструмент доступен на новой вкладке «Gap» (Зазор) на панели «Thickness Analysis» (Анализ толщины).
  • Print Pro. Функция WAM Центра обеспечения точности теперь еще больше увеличивает точность и позволяет выполнять итерации для улучшения качества даже в самых сложных проектах.
  • Проверенные материалы, предложенные для Fortus 450mc в 1.75 теперь доступны для F900. Прежде чем эти материалы можно будет использовать для программирования и печати, они проверяются с помощью базовых тестов на надежность. Для использования проверенных материалов на F900 должна быть установлена версия встроенного ПО 4.22; кроме того, они доступны только для высоты среза 0.0100 дюйм./0.2540 мм.
    • FDM HIPS (очень компактный полистирол)
    • Kimya PC-FR (огнестойкий)
    • Новые цвета полимера ULTEM™ 9085 (красный, серый Aircraft, серый Gunship, серый Dream, белый 7362 и белый Jana).
    • Новый цвет ПК (красный)
    • Новый цвет PC-ABS (красный)
    • (BETA) VICTREX AM™ 200 PAEK (легкоплавкий)
  • В PolyJet улучшен адгезионный слой для принтеров Fashion. Раньше при печати матовой модели с адгезионным слоем он печатался под моделью и окружающей ее опоры. После удаления опоры вокруг модели мог оставаться адгезионный слой. После последнего обновления адгезионный слой добавляется только под моделью, что позволяет избежать проблемы с остатками адгезионного слоя при удалении опоры.
  • Мы решили проблему с принтерами PolyJet Objet30V3 и V5, из-за которой происходил сбой заданий печати после обновления до GrabCAD Print 1.83.
  • Для SAF на панели 3D-вложений теперь отображается дополнительная информация о ходе выполнения в форме X/Y, так что пользователь может видеть, сколько моделей было выбрано и сколько в настоящее время включено во вложение.
  • Для P3 реализована возможность автокоррекции параметров. Теперь, если пользователь вводит недопустимое значение для любого параметра, имеющего допустимый диапазон, значение автоматически корректируется до ближайшего допустимого значения, и для автоматически исправленного допустимого диапазона отображается всплывающая подсказка.
GrabCAD Print версии 1.83, октябрь 2023
Номер сборки 1.83.10.33362 выпуск 24 октябрь 2023.
  • Print Pro. В отчете о сборке теперь оценивается удаляемый материал для принтеров, использующих удаляемую деталь или жертвенную башню.
  • Print Pro. Отчет о сборке теперь включает оценку времени, необходимого для печати отдельных деталей, в виде экспорта Excel или CSV.
  • Print Pro. При экспорте оценок в файл Excel отчет о сборке и сводные данные лотка теперь включаются как отдельные листы одного документа.
  • Представляем инструмент измерения! Расстояния теперь можно измерять от точки к точке, от плоскости к точке или от точки к плоскости с возможностью привязки к вершинам. Инструмент измерения поддерживается для проектов FDM, SAF и P3.
  • Теперь можно переименовывать детали, сборки и фигуры на Панели проекта или в Средстве просмотра моделей, выделив модель и применив команду «Переименовать» в меню, которое открывается правой кнопки мыши.
  • В контекстное меню добавлены новые возможности выбора. Теперь параметр «Выбрать все» можно применить ко всему проекту или только к текущему лотку. А новая опция «Инвертировать выбор» позволяет вместо текущих выбрать детали, которые не были выбраны, либо в текущем лотке, либо во всем проекте.
  • Для печати H350 на полосе управления видом доступны две новые опции.
    • Опция «Colorize» (Раскрасить) добавляет случайные цвета к деталям во вложении, чтобы лучше визуализировать плотные блоки.
    • Опция «Layer Line Visualization» (Визуализация линии слоя) показывает линии на поверхностях, обращенных вверх или вниз, где слои могут быть видны в результатах печати.
  • Для печати на принтерах P3 добавлен новый инструмент для создания опорной конструкции в GrabCAD Print. Теперь вы можете использовать GrabCAD Print для полноценной подготовки файлов САПР и отправки на печать — для этого теперь не требуется никакого дополнительного программного обеспечения.
GrabCAD Print версии 1.82, сентябрь 2023
Номер сборки 1.82.7.32244 выпуск 19 сентябрь 2023.
  • Print Pro. Новая возможность в режиме анализа под названием «Thickness Analysis» (Анализ толщины) позволяет быстро определить, содержит ли деталь геометрию, разрешение которой ниже разрешения используемого принтера. Разрешение устанавливается по умолчанию в зависимости от технологии принтера; пользователь может установить собственное значение. Показатели могут отображаться бинарном формате (красный ошибка / зеленый ОК) или в виде непрерывного желто-красного градиента. Курсор также представляет собой «зонд», позволяющий узнать конкретное значение в любой точке детали.
  • Print Pro. Теперь для команды FDM «3D-массив» можно использовать меньшие и отрицательные значения интервала, что позволяет более плотно располагать детали на лотке.
  • Теперь лоток можно скрыть, что позволяет лучше видеть нижнюю сторону плотно размещенных деталей.
  • GrabCAD Print поддерживает адреса IPv6 при обмене данными с принтерами Stratasys H350, Fortus 450mc, Stratasys F900 и Fortus 900mc. Чтобы использовать IPv6 с Fortus 450mc, требуется версия встроенного ПО 6.8. Чтобы использовать IPv6 с Stratasys F900 и Fortus 900mc, потребуется версия встроенного ПО 4.22.
  • Представляем смолы TrueDent™, одобренные FDA (класс II), разработанные для 3D-печати зубных протезов, временных коронок и мостовидных протезов на платформе J5 DentaJet. Они используются для серийного производства высокоэстетичных монолитных цветных зубных протезов на одном смешанном лотке. Хотя в настоящее время TrueDent™ доступен не во всех регионах, данный материал является многообещающим решением для зуботехнических лабораторий, стремящихся повысить производительность и достичь превосходных результатов.
  • В версии 1.81 была добавлена настройка для активации/деактивации расширенной обработки текстур. Этот флажок был перенесен в «Настройки лотка» (в разделе «Дополнительно»), позволяя определять значение для каждого задания. По умолчанию флажок снят для J55 Prime и J850 Prime, которые печатают тяжелые лотки с текстурами.
  • Гелевое покрытие добавлено в модели Structural Heart для принтера DAP (как определено в моделях кровеносных сосудов).
  • Для печати SAF к коробкам для спекания теперь может добавляться определяемая пользователем метка как часть геометрии коробки, что позволяет разбить осадок, чтобы узнать, какие детали содержатся в коробке для спекания. Длинные метки автоматически выравниваются по самой длинной оси коробки для спекания.
  • При печати SAF минимальное значение промежутка для вложения можно переопределить для конкретных выбранных деталей, которым требуется дополнительное пространство для улучшенного управления температурным режимом.
  • Для печати SAF теперь можно добавлять операцию вложения к существующему содержимому вложения или очищать вложение и начинать заново.
  • Для печати P3 опция «По размеру лотка» запускает улучшение ориентации, которое будет постепенно поворачивать модель до тех пор, пока она не впишется в область печати.
  • Для печати P3 все профили зубной опоры должны иметь новый параметр для фильтрации опорных точек на глубокой печати для моделей Splint, ориентированных под углом 90°.
  • Для печати P3 при создании опорных точек поддерживаемые области окрашиваются в соответствии с самонесущим углом, указанным в выбранном профиле опоры.
  • Пользователи GrabCAD Print с облаком P3 On-Prem могут запускать GrabCAD Print с учетной записью без прав администратора.
GrabCAD Print версии 1.81, август 2023
Номер сборки 1.81.9.30921 выпуск 16 август 2023.
  • Print Pro. В Центре обеспечения точности теперь есть вкладки для представлений «Оригинал» и «Проверка». На вкладке «Оригинал» отображаются результаты точности (тепловая карта и показатель точности печати (PAS)) для исходной напечатанной детали. Вкладка «Проверка» позволяет пользователям загружать скан отпечатка WAM, чтобы точно увидеть, насколько улучшилась точность. На ней отображается новый PAS по сравнению с исходным показателем, а новая гистограмма отображается с наложенным серым контуром оригинала, что позволяет легко увидеть уменьшение определенных интервалов ошибок.
  • Print Pro. Новые элементы управления WAM в Центре обеспечения точности для улучшения результатов при работе с горизонтальными поверхностями:
    • «Preserve» (Сохранить) (теперь значение по умолчанию) позволяет выполнять только единообразное регулирование горизонтальных поверхностей по вертикали, чтобы сохранить эстетику и избежать добавления контурных линий для сглаживания горизонтальных областей.
    • «Pin» (Закрепить) предотвращает любое перемещение горизонтальных поверхностей.
    • «Free Adjust» (Свободная корректировка) позволяет свободно устранять деформации горизонтальных поверхностей, включая добавление контуров внутри горизонтальных поверхностей для максимальной точности там, где размер имеет приоритет над эстетикой.
  • Print Pro. Добавлен быстрый предварительный просмотр выбранного файла сканирования в Центре обеспечения точности, помогающий выбрать правильный файл сканирования.
  • Print Pro. Ось Y гистограммы Центра обеспечения точности теперь показывает процент общей детали для каждой планки погрешности, что позволяет видеть, какой процент детали находится выше, ниже или в пределах выбранного допуска.
  • Print Pro. При сопоставлении скана в Центре обеспечения точности локальное несоответствие напечатанной и сканированной детали (например, ошибка по сравнению с проектом в этой точке) теперь отображается динамически при наведении указателя мыши на результаты сопоставления.
  • Для пользователей P3 с лицензиями Local Hub и OpenAM была исправлена проблема при отправке файла «Послойные настройки».
  • Для пользователей P3 настройка «Автоматически создавать лотки, когда модели не помещаются на текущей платформе» в разделе «Параметры вставки модели» теперь доступна для принтеров P3, как и на других платформах.
GrabCAD Print версии 1.80, июль 2023
Номер сборки 1.80.10.30098 выпуск 19 июль 2023.
  • В GrabCAD Print поддерживаются следующие 2023 версии файлов САПР: SOLIDWORKS 2023, SolidEdge 2023, Siemens NX 2212.
  • Print Pro. Теперь к деталям FDM (STL и CAD) можно добавлять специальные текстовые метки, они могут быть рельефными или тиснеными, а размер, глубина и интервал текста можно контролировать. Кроме того, можно создавать повторно используемые шаблоны меток, куда можно вставлять текст, название детали и генерировать уникальный серийный номер. Нажмите здесь, чтобы узнать больше о GrabCAD Print Pro.
  • Для вложений SAF названия методов вложения были изменены со «Стандартный» и «Расширенный» на «Без взаимных пересечений» и «Компактный», чтобы их функция была более понятна пользователю. Методом по умолчанию теперь является «Компактный» (ранее «Расширенный»), позволяющий создавать более плотное вложение.
  • Для SAF проверка в некоторых случаях может быть очень медленной, поэтому теперь можно отменить процесс проверки, если требуется внести дальнейшие изменения во вложение.
  • Теперь пользователям J850 TechStyle доступно новое семейство полугибких материалов VeroEcoFlex. Подробнее здесь.
  • В большинстве принтеров PolyJet используются ртутные УФ-лампы, но в J850 TechStyle они заменены УФ-светодиодами. Новые УФ-светодиоды обеспечивают более точное отверждение, что крайне важно для небольших образцов с тонкими деталями. Функция UV LED Recipe в GrabCAD Print предоставляет механизм для управления функцией УФ-излучения до определенного среза или диапазона срезов. Можно контролировать, какие светодиоды будут использоваться, а также регулировать интенсивность каждого светодиода на любом этапе процесса печати.
  • Мы решили проблему в GrabCAD Print, из-за которой принтеры P3 не сохранялись в избранном. Эта проблема исправлена, и теперь пользователи могут назначать принтеры в качестве избранных.
  • Ранее существовала проблема, из-за которой результаты расчета длительных заданий P3 отображались неправильно. Эта проблема приводила к отображению значительно более короткого срока выполнения. Теперь она устранена.
  • Мы решили проблему для P3, связанную с тем, что при использовании некоторых материалов с определенными настройками не начиналась печать. Пользователи больше не столкнутся с этой проблемой, и печать заданий будет начинаться как положено.
  • Для пользователей P3 с лицензиями OpenAM диапазон масштабирования в профиле «Материал» был расширен и теперь составляет от +2% до –1%, что позволяет точнее настраивать масштабирование для компенсации усадки смолы.
  • Для пользователей P3 с лицензиями OpenAM исправлена проблема с функцией «Передача настроек по слоям», которая при определенных обстоятельствах работала неоптимально.
  • Для пользователей P3 с лицензиями OpenAM устранена проблема, из-за которой не запускалась печать заданий с новыми материалами.
GrabCAD Print версии 1.79, июнь 2023
Номер сборки 1.79.18.29310 выпуск 20 июнь 2023.
  • Инструмент «Заключение модели в оболочку» доступен для Групп, в которых фигуры элементов могут иметь уникальные настройки. По умолчанию он активирован. При этом фигуры модели заключаются в общую оболочку. Оболочка увеличивает прочность, когда соединения между фигурами в группе не рассчитаны на сопротивление приложенным нагрузкам. Если соединения между фигурами рассчитаны на сопротивление нагрузкам, функция «Заключение модели в оболочку» не требуется и ее можно отключить.
  • В случае связанных с импортом CMB конфликтов теперь четко указано, почему добавляемый файл не подходит для данного проекта.
  • Теперь в принтере Stratasys F770 можно использовать материал ASA следующих цветов: белый, черный, светло-серый, синий, красный, желтый.
  • Высота основания J3/J5 DentaJet была увеличена до 1 мм для улучшения сцепления.
  • В J850 Prime FabriX добавлена функция «Оптимизировать для упаковки». Использование этой функции повышает качество печати прозрачной упаковки (например, бутылок).
  • В настройках лотка инструмента «Масштабирование» в принтерах P3 число десятичных знаков единиц измерения увеличено с одного до трех. Это улучшение позволяет проводить более точные измерения и более тонкую настройку функциональных возможностей функции.
  • В импорте стопки срезов в принтерах P3 теперь поддерживаются имена файлов срезов с любым префиксом, например, слой_xxx, срез_xxx и т. д.
  • Для пользователей P3 с лицензиями OpenAM добавлена новая функция «Загрузить настройки материала». Теперь можно загрузить CSV-файл, содержащий информацию о первом и переходном слоях материала. Для доступа к этой информации перейдите в Библиотеку материалов, выберите материал и нажмите кнопку «Загрузить настройки», которая расположена над таблицей «Настройки по слоям».
  • На панели проекта теперь отображается значок рядом с любой моделью, созданной с помощью команды «Зеркальное отображение модели».
  • При печати SAF теперь индикатор создания вложения указывает пользователю, когда создается вложение и когда выполняется проверка.
GrabCAD Print версии 1.78, май 2023
Номер сборки 1.78.18.27879 выпуск 16 май 2023.
  • GrabCAD Print Pro Уже доступно! Среди функций — моделирование с коррекцией деформации, оценки деталей, шаблоны для изготовления и многое другое.
    • Ознакомьтесь с полным списком функций версии Pro
    • Запросить бесплатную пробную версию
      Программное обеспечение, используемое в GrabCAD Print для визуализации экранной графики при выполнении заданий FDM, было обновлено, так как это необходимо для работы многих новых функций. Старая версия средства просмотра все еще доступна в меню настроек, но в будущем она будет удалена.
      При печати FDM обновлены свойства связей для внешних контуров — теперь всегда используются свойства, определенные для материала модели и высоты среза. Ранее внешние контуры связывались в некоторых случаях использования, при этом игнорировались свойства связей материала.
      Nylon-CF10 теперь доступен с поддержкой отрыва для принтеров Stratasys F370CR и F190CR. Материал для опор SUP4000B обеспечивает безрезервуарное решение для удаления опор и ускоряет удаление легко удаляемых отрывных опор. Для SUP4000B используется такая же головка для материала опор, что и для QSR, а срезы имеют такую же высоту (0.0130 дюймов/0.3302 мм; 0.0100 дюймов/0.2504 мм; 0.0070 дюймов/0.1778 мм), что и
      Nylon-CF10. Для использования Nylon-CF10 с поддержкой отрыва необходимо обновить прошивку принтера до версии 2.6.
      Обновлено определение материала Nylon-CF10 с поддержкой QSR для улучшения свойств заполнения для срезов высотой 0.0100 дюймов (0.2504 мм) и 0.0130 дюймов (0.3302 мм).
      Повышение точности оценки времени сборки и объема материалов для:
    • 0.0200 дюйм. (0.5040 мм) ASA при использовании наконечника T40A в принтере Fortus 900mc
    • 0.0200 дюйм. (0.5040 мм) Nylon CF12 (черный) при использовании наконечника T40C в принтере Stratasys F900
    • 0.0200 дюйм. (0.5040 мм) ULTEM 9085 Resin Black при использовании наконечника T40A в принтерах Stratasys F900 и Fortus 900mc.
  • При нажатии кнопки «Печать» для задания P3 в окне «Сводные данные о печати» можно легко увеличить 1-й слой или эскиз предварительного просмотра лотка, нажав на него. Эта функция позволяет подробнее рассмотреть свойства первого среза перед печатью.
  • Если модель расположена вне объема сборки в задании P3, в окне «Панель проекта» отобразится оранжевое уведомление с восклицательным знаком, при наведении курсора на которое появится описание проблемы.
  • Для пользователей P3 с лицензиями OpenAM в GrabCAD Print теперь поддерживается загрузка настроек по слоям, которые включают значение edgeBuildingCompensation. После загрузки в таблице «Настройки по слоям» будет отображаться соответствующий столбец.
GrabCAD Print версии 1.77, апрель 2023
Номер сборки 1.77.13.26873 выпуск 18 апрель 2023.
  • Восстановлена возможность переключения технологий печати, не начин��я новый проект.
  • PolyJet: при изменении оттенка десны для определенной сборки, эта сборка и ее оболочки дублировались и помечались как скрытые в дереве лотка. (Скрытая сборка создавалась для упрощения операции «Отменить последнее действие», выполнение которой является чрезвычайно сложным процессом). Теперь эти сборки не отображаются на дереве, а операция отмены последнего действия по-прежнему будет работать нормально.
  • SAF: теперь вы можете выбрать детали и создать синтербокс для размещения и защиты деталей, указав размер отверстия, толщину балки и расстояние между ними.
  • P3: параметры переходных слоев оптимизированы и теперь автоматически обрабатываются на проверенных материалах. Ранее эта функция находилась в «Свойствах материала», но теперь она скрыта.
  • P3: исправлена известная проблема изменения перед печатью единиц измерения для моделей с дюймов на миллиметры.
GrabCAD Print версии 1.76, март 2023
Номер сборки 1.76.10.25761 выпуск 21 март 2023.
  • Устранена проблема, при которой при импорте CMB тип файла стопки был *.zip, — теперь файлы имеют расширение CMB (*.cmb, *.cmb.gz).
  • При печати P3 в разделе «Настройки лотка» / «Свойства материала» теперь есть новый параметр «Масштабирование». Его полезно использовать, если на вашу напечатанную деталь влияет усадка материала. Вы можете редактировать и оптимизировать величину масштабирования материала на уровне задания.
  • При печати P3 в разделе «Настройки лотка» / «Свойства материала» теперь есть новый параметр «Дополнительные базовые слои». Его полезно использовать, если высота вашей детали по оси Z меньше, чем в проекте CAD. Добавление дополнительных базовых слоев дублирует первый слой, чтобы компенсировать уменьшение высоты слоев.
  • Для пользователей P3 с лицензиями OpenAM печать с измененными настройками по слоям с помощью CSV теперь работает правильно.
GrabCAD Print версии 1.75, февраль 2023
Номер сборки 1.75.13.24793 выпуск 21 февраль 2023.
  • Для повышения надежности программного обеспечения при использовании принтера с другой технологией (например, FDM в PolyJet) необходимо выполнить файл нового проекта. Вы можете легко переключаться между принтерами с разными технологиями до момента добавления модели в проект.
  • «Проверенные материалы» теперь доступны в GrabCAD Print при программировании заданий для принтера Fortus 450mc. Эти материалы проверяются с помощью базовых тестов на надежность до их использования при программировании и печати. Для использования функции «Проверенные материалы» необходимо установить прошивку версии 6.7 на 450mc.
Проверенный материал Доступная высота среза Наконечник материала для печати модели Материал опоры Наконечник вспомогательного материала
FDM HIPS (очень компактный полистирол) 0.0100 дюйм. (0.2540 мм) T16 SUP1500B T12
0.0100 дюйм. (0.2540 мм) T16 SR- 100 T12SR100
Новые цвета полимера ULTEM™ 9085 (красный, серый Aircraft, серый Gunship, серый Dream, белый 7362 и белый Jana). 0.0100 дюйм. (0.2540 мм) T16 SUP8500B T16
Новые цвета PC (красный и черный) 0.0100 дюйм. (0.2540 мм) T16 SR- 100 T12SR100
Новый цвет PC-ABS (красный) 0.0100 дюйм. (0.2540 мм) T16 SR- 100 T12SR100
0.0100 дюйм. (0.2540 мм) T14E SR- 100 T12SR100
(BETA) Covestro Addigy® PA6/66-GF20 FR LS (стеклонаполненный нейлон, огнестойкий)
0.0100 дюйм. (0.2540 мм) T20G SUP4000B T16
  • В GrabCAD Print теперь поддерживаются комплекты материалов. Комплекты материалов создаются, когда материалы настраиваются в OpenAM™, компилируются и передаются в GrabCAD Print и на принтер Fortus 450mc с лицензией OpenAM. Рекомендованные и Проверенные материалы Stratasys можно настроить и включить в комплекты, также как и доступные материалы сторонних производителей. Для комплектов материалов требуется версия прошивки принтера 6.7.
  • Исправлена ошибка, при которой путь инструмента дубликатов CMB (или операций копирования/вставки) отличался от пути инструмента оригинального CMB.
  • Реализованный на платформе J35 принтер J3 DentaJet™ — это принтер PolyJet начального уровня для малых и средних зуботехнических лабораторий. Он обеспечивает непревзойденную точность, а на одном лотке можно использовать комбинации трех биосовместимых материалов, включая большое количество моделей имплантатов, хирургических шаблонов и слепков десны. Узнать подробнее о новом J3 DentaJet™ можно по этой ссылке.
  • Предупреждение, предлагающее обновить Диспетчер заданий для принтеров PolyJet, теперь будет отображаться только в том случае, если версии GrabCAD Print и Диспетчера заданий не совпадают. Ранее предупреждение отображалось сразу после выхода новой версии.
  • Теперь при печати на PolyJet к текстурированной VRML-модели можно добавить слой покрытия.
  • В принтерах SAF теперь можно использовать материал PA12 (бета-версия). Подробнее можно узнать по этой ссылке.
  • В принтерах SAF новая вызываемая правой кнопкой мыши функция позволяет выбрать любые отнесенные к неверным модели после их оценки или проверки.
  • В принтерах SAF в некоторых случаях при выполнении срезов деталей с углами отмечались незначительные артефакты на поверхности, и для устранения этой проблемы повышена точность алгоритма выполнения срезов.
  • При печати P3 без доступа в Интернет теперь поддерживается подключение к принтеру Origin One Local через локальный центр Origin (подробнее см. в Справочном руководстве по Origin One Local в разделеЦентр поддержки Stratasys). Ознакомьтесь с инструкциями по подключениюпо этой ссылке.
  • Для принтеров P3 теперь можно импортировать срезы, созданные в таких приложениях, как Netfabb, выполнив команду Файл > Импортировать стопку срезов.
GrabCAD Print версии 1.74, январь 2023
Номер сборки 1.74.8.23921 выпуск 17 январь 2023.
  • Настройки безопасности Windows при использовании FIPS-совместимого шифрования ранее блокировали подключение принтера для использования с продуктами GrabCAD. Эта проблема устранена для GrabCAD Print и Print Server. FIPS по-прежнему необходимо отключать в системах с установленным Диспетчером заданий PolyJet.
  • Восстановлена поддержка 3DConnexion Spacemouse, реализованная в 1.55.
  • Ввод значений CMYK для материалов VeroFlex активирован для всех принтеров J7xx/8xx в случае, когда в лотке находятся все цветные материалы VeroFlex.
  • Функция «Компенсация кромок» добавлена в параметры материала в принтерах Origin. Этот новый инструмент позволяет уменьшать или увеличивать кромки модели на несколько микрон в каждом срезе. Это полезно в случае, если имеются какие-либо особенности, например, отверстия немного большего или меньшего размера, чем требуется, когда необходимо сохранить масштаб модели.
GrabCAD Print версии 1.73, декабрь 2022
Номер сборки 1.73.5.23276 выпуск 20 декабрь 2022.
  • Добавление моделей из Workbench больше невозможно. Узнайте подробнее о нежелательности применения GrabCAD Workbench в блоге по этой ссылке.
  • Для принтеров PolyJet для стоматологии в файл, содержащий названия оттенков зубов и десен для интеграции с 3Shape, добавлены новые оттенки в версии 1.72. Кроме того, при открытии старого проекта или задания, содержащего несуществующие названия оттенков, их названия будут пустыми и отобразится соответствующее уведомление. Если пользователем выбраны предустановленные настройки, в которых используется несуществующий оттенок, автоматически будет установлен оттенок по умолчанию.
  • В GrabCAD Print примечания для изготовления теперь доступны для H350, благодаря чему пользователи могут снабжать примечаниями свои модели и создавать отчет в формате PDF, содержащий скриншоты моделей и примечания в документе PDF traveler.
  • Также для H350 исправлена ошибка, и теперь предварительный просмотр надписей отображается в правильном масштабе.
GrabCAD Print версии 1.72, ноябрь 2022
Номер сборки 1.72.6.22542 выпуск 16 ноябрь 2022.
  • Добавлена высота среза 0.0200 дюйма(-ов) (0.508 мм) для Nylon 12 CF на принтере Stratasys F900, что обеспечивает увеличение производительности при работе с крупными деталями. Для этой высоты среза используется наконечник модельного материала T40C.
  • Добавлена высота среза 0.0200 дюйма(-ов) (0.508 мм) для ULTEM™ 9085 Resin, ULTEM™ 9085 CG Resin и ULTEM™ 9085 Resin Black на принтерах Stratasys F900 и Fortus 900mc. Новая высота среза обеспечивает увеличение производительности при работе с крупными деталями. Для этой высоты среза используется наконечник модельного материала T40A.
  • Выбранные модели в 3D-вложении H350 можно визуально изолировать, поэтому все невыбранные модели будут скрыты. Когда пользователь завершит работу с изолированными моделями, он сможет снова отобразить все модели. Обратите внимание, что эти операции не изменяют расположение деталей в 3D-вложении.
  • Для H350 можно выбрать любую сборку из САПР, созданную с помощью команды «Сборка» или сгруппированного 3D-массива, а структуру сборки можно разложить на составляющие, оставив отдельные модели.
  • Оценки для H350 теперь включают в себя массу для всего вложения и моделей, а также жидкость HAF для всего вложения.
  • Команда записи ярлыка для H350 теперь запоминает настройки в промежутках между использованием команды, что значительно ускоряет создание последовательности добавляемых вручную ярлыков, поскольку рельефный текст/тиснение, размер текста и т. д. остаются прежними.
  • Для J5 DentaJet некоторые оттенки зубов были улучшены за счет более точной цветопередачи, а также были добавлены два новых оттенка.
  • Для J5 DentaJet оттенки десны были улучшены за счет улучшения текстуры. Было также добавлено четыре новых оттенка.
GrabCAD Print версии 1.71, октябрь 2022
Номер сборки 1.71.7.21930 выпуск 18 октябрь 2022.
  • Пользователи J5 DentaJet теперь могут использовать полный рабочий процесс, от внутриротового сканирования до полноцветной печатной модели, за счет использования программного обеспечения 3Shape Dental System и GrabCAD Print. Профиль цветовой модели 3Shape добавлен в J5 DentaJet при печати с использованием VeroDent PureWhite и Vero CMYK. Обратите внимание, что для этого требуется версия 2022 программного обеспечения 3Shape Dental System.
  • При отправке заданий на принтеры Connex с включенной расширенной программой разбиения на слои на экране подтверждения печати отобразится уведомление.
  • Задания, напечатанные на принтерах серии J7/J8 в сверхскоростном режиме, не отображались в представлении расписания, и теперь это исправлено.
  • Область 3D-вложения для H350 можно переименовать, щелкнув предварительный просмотр на панели проекта, так же как при переименовании лотка для FDM или PolyJet, что вызовет изменение имени задания, отправляемого на принтер.
  • Содержимое отчета, созданного для оценок на H350, теперь можно копировать и вставлять в другие файлы, например электронные таблицы, или загружать в виде файла .XLSX или .CSV.
  • Пользователи P3 без лицензии OpenAM теперь могут получать точные результаты оценки через GrabCAD Print. Подробнее см. в последней записи нашего блога здесь.
GrabCAD Print версии 1.70, сентябрь 2022
Номер сборки 1.70.12.21501 выпуск 21 сентябрь 2022.
  • GrabCAD Print теперь поддерживает операционные системы Windows 11. Для просмотра всех системных требований щелкните здесь.
  • GrabCAD Print теперь поддерживает файлы из последних версий программного обеспечения САПР, включая Creo9, Inventor 2023, NX2206 и Parasolid 34.1.
  • GrabCAD Print теперь поддерживает принтеры Origin One и Origin One Dental. После входа в учетную запись Origin в разделе «Файл» > «Настройки» > «P3 DLP» можно настроить и отправить задания на свои принтеры. Дополнительные сведения.
  • Для проектов FDM GrabCAD Print теперь сохраняет настройки задания, когда при получении проекта не удается найти выбранный принтер. Устранена проблема, из-за которой к параметрам применялись значения по умолчанию принтера.
  • Закаленная экструзионная головка T14H теперь поддерживается принтерами Stratasys F370, F270 и F170. При сроке службы 1500 часов данная головка является выбором по умолчанию для заданий по программированию с использованием материала ABS-CF10.
  • Для стоматологических принтеров PolyJet теперь разрешено назначение оттенка десне с множественным выбором. Однако действует ограничение одна оболочка на сборку.
  • И в J850 Prime Fabrix, и в TechStyle допустимая толщина адгезионного слоя была увеличена до 3 мм.
  • Исправления ошибок PolyJet:
    • В J850 Prime Fabrix и TechStyle проекты, сохраненные с запланированной остановкой, открываются без запланированной остановки.
    • На J5 DentaJet не выполняется проверка при открытии действительного проекта.
    • На J5 DentaJet в режиме SHS общая оценка материалов модели и поддержки является неверной.
  • В представление 3D-вложения для H350 добавлены следующие команды, позволяющие пользователю работать исключительно в представлении 3D-вложения: Режим анализа, Единицы измерения, Масштаб, Добавить модели, Свободное перетаскивание в плоскости X, Y.
  • Создание сборки H350 из нескольких моделей, содержащей некоторые модели, которые слишком велики для вложения, больше не будет приводить к сбою всей операции вложения. Подходящие по размеру модели будут вложены, и будет выведено предупреждение со списком моделей, которые слишком велики для вложения.
  • Для H350 при создании шаблона ярлыка с использованием автоматизации имени или номера автоматически проверяется синтаксис; неверный синтаксис выделяется красным цветом, и отображается всплывающая подсказка с детализацией ошибки.
GrabCAD Print версии 1.69, август 2022
Номер сборки 1.69.12.20542 выпуск 16 август 2022.
  • Две новые смолы теперь поддерживаются в J5MediJet™.
    • Биосовместимый материал Digital ABS Plus™ предназначен для имитации стандартного АБС-пластика за счет сочетания стойкости к высоким температурам и прочности. Этот материал значительно улучшает механические характеристики биосовместимых деталей для различных типов медицинского применения.
    • WSS™150 – это водорастворимый вспомогательный материал для быстрого удаления поддержки. Материал становится растворимым при помещении в сосуд, наполненный обычной водопроводной водой. Опору можно удалить еще быстрее, используя стандартную или настольную посудомоечную машину.
      Дополнительные сведения см. здесь.
  • Если материалы лотка J750/850 Digital Anatomy содержат RadioMatrix, его не следует выбирать в качестве материала по умолчанию при вставке модели.
  • Если у вас есть доступ и к PolyJet Research Package, и к принтеру 3DFashion, вам нужно будет выбрать один из них для текущего проекта, поскольку некоторые их функции конфликтуют.
  • В принтерах серии J7 и J8 улучшен пользовательский интерфейс для настройки моделей с использованием цветных материалов Agilus с гибким поведением. Соответствующие настройки были перенесены из расширенных параметров в раздел основных настроек, и ко всем параметрам настройки добавлены подробные всплывающие подсказки.
  • В обновлении 1.67 для принтеров Connex3 появилась возможность использовать расширенную программу разбиения на слои с установленным по умолчанию флажком в разделе «Файл» > «Настройки» > «PolyJet». Расширенная программа разбиения на слои включает в себя более строгие требования к графике, и некоторые пользователи сталкивались с ошибкой, связанной с графическими драйверами. Была зафиксирована ошибка, и после отключения настройки расширенной программы разбиения на слои данная ошибка сохранялась, препятствуя постановке заданий в очередь. В обновлении 1.69 это было исправлено, и для устранения ошибки достаточно снять флажок с настройки.
  • Для H350 теперь можно указать высоту пакета, либо в виде времени (это полезно для подготовки задания с учетом времени, доступного в смене), либо в виде высоты пакета, в зависимости от того, какой параметр, вводимый пользователем, обновляет другой.
  • Estimate для H350 теперь предоставляет отчет о сборке со страницами сводки и подробных сведений. В сводке содержится следующая информация: время печати, общий объем, вложенные модели, невложенные модели, плотность, высота вложения и усадка. На странице подробных сведений содержится следующая информация: отдельные детали, количество копий каждой детали и объем каждой детали.
GrabCAD Print версии 1.68, июль 2022
Номер сборки 1.68.10.19783 выпуск 19 июль 2022.
  • Многофайловые 3сборки MF, OBJ и VRML теперь можно импортировать так же, как STL, используя «Файл» > «Импортировать как сборку».
  • Вспомогательный материал для смолы ULTEM™ 9085 переименован в поддержку SUP8500B, а смола ULTEM™ 1010 переименована в поддержку SUP9000B.
  • Для ярлыков (только H350) теперь можно указать высоту или глубину тиснения текста ярлыка.
  • Для 3D-массивов (только для H350) теперь можно выбрать несколько моделей и создать массив из этих моделей.
  • Как для J850 TechStyle, так и для J850 Prime Fabrix при подключении принтера тип лотка для текущего задания автоматически синхронизируется с лотком, установленным в принтере.
  • В принтерах серии J7 и J8, которые получили распоряжение о замене правого вентиляционного канала УФ-лампы в местах эксплуатации и установили его, в диалоговом окне «Настройки принтера» отобразится сообщение «Обновленный вентиляционный канал был установлен».
  • DM ASR-620, представляющие собой смесь MED620 и SUP711, теперь доступны на J5 DentaJet в режиме печати HQHS.
  • Цветные материалы Agilus доступны в приложении Voxel Print.
  • Flex-Touch (Smart и Full) должен быть определен для каждой модели, вместо общего Flex-Touch для всех моделей на лотке.
GrabCAD Print версии 1.67, июнь 2022
Номер сборки 1.67.10.19143 выпуск 22 июнь 2022.
  • Расширенная программа разбиения на слои PolyJet, ранее доступная только для принтеров серии J, теперь поддерживается для принтеров Connex3. Расширенная программа разбиения на слои обеспечивает улучшенное качество и дополнительные возможности, в том числе следующие:
    • Оттенки серого с прозрачными черно-белыми профилями
    • Обработка тонких участков/углов
    • Более точные оценки и смещение
    • Улучшенное управление сеткой
      Чтобы точно воспроизвести предыдущую печать, можно вернуться к устаревшей программе разбиения на слои в разделе «Файл» > «Настройки» > «PolyJet».
  • FabriX™ Innovation Kit для J850™ Prime расширяет возможности CMF и прототипирования PolyJet™, позволяя осуществлять прямую печать на текстильных и гибких носителях. Теперь вы можете тестировать различные дизайны для сетчатых материалов, прототипов профессиональной одежды и даже визуализации систем фильтрации.
  • Представляем RadioMatrix™ — первый в своем роде рентгеноконтрастный материал 3D-печати, доступный для цифрового анатомического принтера. Новый материал позволяет создавать 3D-анатомические модели с рентгеноконтрастными характеристиками различной контрастности, которые могут отображаться на КТ или рентгеновском снимке. Настройки материала RadioMatrix™ добавлены в программное обеспечение для цифрового анатомического принтера, что позволяет создавать рентгеноконтрастные 3D-анатомические модели с желаемым значением Хаунсфилда.
  • Новая функция «Вставка сетчатой ткани» позволяет пользователям запланировать остановку во время печати для вставки носителя для печати во время выполнения задания. Данная функция включена в системах J850 TechStyle и J850 Prime FabriX.
  • Жесткая основа для моделей AgilusCMY позволяет однократно печатать жесткую модель с мягкой поверхностью с использованием цветового профиля Agilus. В результате получается жесткая модель с полноцветной тонкой текстурой (полноцветный Shore A 30 1 мм) в качестве внешней мягкой поверхности.
  • Ввод данных CMYK для материалов AgilusCMY позволяет определить желаемый цветовой тон с помощью ввода числового значения CMYK для чистых материалов AgilusCMY.
  • Благодаря высокоскоростному режиму высокого качества на принтере J5 DentaJet пользователи теперь могут печатать стоматологические модели, хирургические шаблоны и другие модели с тем же качеством и в два раза быстрее. Высокоскоростной режим высокого качества можно выбрать в GrabCAD Print после выбора правильной конфигурации материала и запуска мастера замены материалов на принтере.
  • Для H350 теперь можно создать сборку из нескольких моделей верхнего уровня, загруженных в GrabCAD Print. Модели размещаются в 3D-пространстве либо с помощью виджета перетаскивания 3D, либо с помощью инструмента позиционирования, а затем превращаются в сборку, допускающую вложение.
  • Инструмент 3D Array для H350 теперь поддерживает сборки в качестве источника для массива.
  • Теперь можно использовать высоту пакета в качестве критерия остановки для инструмента 3D-вложения для H350. Если процесс вложения успешно упаковал все выбранные модели, будет выполнена попытка уменьшить высоту пакета, пока не будет достигнута указанная высота.
  • Значение по умолчанию для минимального расстояния между моделями в команде 3D-вложения для H350 теперь равно 2 мм, по сравнению с прежними 3 мм, что позволяет безопасно создавать более плотное вложение.
GrabCAD Print версии 1.66, май 2022
Номер сборки 1.66.7.17878 выпуск 17 май 2022.
  • Представляем новейшие модели серии F123: Stratasys F370 CR и Stratasys F190 CR. Эти принтеры для работы с композитными материалами (composite ready, CR) предназначены для использования с заполненными материалами, включая новейший композитный материал Stratasys FDM, Nylon-CF10 и современный материал ABS-CF10. Это упрощает производство прочных зажимных приспособлений для деталей, инструментов и деталей в домашних условиях за долю времени, которое требуется при использовании традиционных технологий изготовления и материалов. Принтеры поддерживают материалы 8 промышленного качества и программируются с использованием интуитивно понятного интерфейса GrabCAD Print и простых в использовании расширенных функций FDM. Подробнее о принтерах F123 Composite Ready см. здесь.
  • В принтере J850 TechStyle 3D используется технология 3DFashion™, обеспечивающая полноцветную печать на разных материалах для создания изображений, которые можно печатать непосредственно на текстиле, коже и одежде, а также для печати небольших модных аксессуаров, что невозможно при использовании традиционных методов. Подробнее см. здесь.
  • GrabCAD Print теперь поддерживает принтер H350 с технологией SAF. Лицензированные пользователи могут распечатывать детали, а нелицензированные — изучить функциональные возможности для ознакомления с ними и оценки их потенциала. Подробнее см. здесь.
  • Теперь можно зеркально отобразить модель в GrabCAD Print, используя контекстное меню. Эта функция поддерживает: зеркальное отображение деталей сетки и САПР для всех технологий печати, модели с цветами лицевой стороны, текстуры, модели в сборках и полные сборки. В настоящее время не поддерживаются: зеркальное отображение моделей с расширенными функциями FDM и модели с метками.
  • Nylon-CF10, смесь нейлона, армированного углеродом, доступна для принтеров Stratasys F370 CR и Stratasys F190 CR. Материал включает в себя 10% измельченного углеродного волокна по весу, в результате чего модели с 3D-печатью более жесткие и прочные, а также имеют лучшую химическую стойкость, чем ABS-CF10. Nylon-CF10 поддерживается для высоты среза 0.0070 дюйма(-ов) (0.1778 мм), 0.0100 дюйма(-ов) (0.2540 мм) и 0.0130 дюйма(-ов) (0.3302 мм) и требует новой закаленной головки (T20H ) для печати. Подробнее о нейлоне-CF10 см. здесь.
  • Новая закаленная головка (T14H) доступна для печати ABS-CF10 со сроком службы 1500 ч. Головка T14H не является обязательной; головку T14 можно продолжать использовать с ABS-CF10, однако в этом случае ее срок службы сократится.
  • Новые цветные смолы Agilus30™ (голубая, пурпурная и желтая) позволяют создавать полноцветные прототипы резиноподобных деталей с резиновой или силиконовой текстурой с высоким качеством обработки поверхности и чрезвычайной гибкостью, которые способны выдерживать многократные сгибания и изгибы. С подробной информацией можно ознакомиться здесь.
  • Материалы WSS (водорастворимая опора), VeroUltraClearS и VeroUltraClear теперь можно использовать в VoxelPrint.
  • Для H350 добавьте рельефный или тисненый текст на поверхность вашей модели с помощью инструмента меток. Можно также создавать шаблоны меток, которые можно применять несколько раз или автоматически при дублировании деталей: они могут автоматически включать в себя названия деталей или генерировать серийные номера.
  • Для H350 можно создать прямоугольный массив по осям X, Y, Z. Массив можно сгруппировать таким образом, чтобы он вел себя как единый объект, либо создать его как отдельные модели.
GrabCAD Print версии 1.65, апрель 2022
Номер сборки 1.65.13.17318 выпуск 21 апрель 2022.
  • Представляем цифровой анатомический принтер J850. Цифровой анатомический принтер J850 позволяет создавать медицинские модели с невероятной реалистичностью и точно передавать как внешний вид, так и реакцию тканей человека. Эти модели обеспечивают непревзойденную универсальность в клинической практике, воспроизводимость и точность для медицинских работников и производителей медицинского оборудования. Подробнее см. здесь.
  • Мы обновили поддерживаемые форматы файлов, включив в них SOLIDWORKS 2022, Inventor 2022 и др. Щелкните здесь для просмотра полного списка: Список поддерживаемых форматов файлов
  • У некоторых пользователей возникали проблемы с сетевым подключением из-за использования прокси-серверов или самозаверяющих сертификатов. Благодаря новому параметру в меню «Файл» > «Настройки» > «Конфиденциальность» GrabCAD Print доверят сертификатам в хранилище сертификатов Windows, что решает многие из этих проблем. Приложение автоматически установит предпочтительные настройки, если обнаружит эти конфигурации.
  • Представляем Digital Anatomy Creator — новый дополнительный программный модуль для принтера Digital Anatomy. Используя сложные математические функции, программное обеспечение Creator предоставляет пользователям непревзойденные возможности настройки внутренних структур анатомических моделей. Создавайте модели, используя не только существующие предварительные настройки анатомии, и калибруйте цифровые материалы точно в соответствии с вашими спецификациями. Легко управляйте созданием материала и настраивайте внутреннюю микроструктуру для достижения нужного анатомического результата. Подробнее см. здесь.
  • В Voxel Print в системах PolyJet теперь поддерживаются новые смолы: VeroUltraWhite и VeroUltraBlack на всех поддерживаемых принтерах и DraftWhite на J5 MediJet.
GrabCAD Print версии 1.64, март 2022
Номер сборки 1.64.9.16414 выпуск 17 март 2022.
  • Качество деталей для Diran 410MF07 на принтере Stratasys F370 улучшено следующим образом:
    • Для высоты среза 0.0070 дюйма(-ов) (0.1778 мм) повышена плотность заполнения видимых поверхностей, направленных вверх и вниз, а также улучшена адгезия между нижней поверхностью детали и верхней поверхностью основания.
    • Для высоты среза 0.0130 дюйма(-ов) (0.3302 мм) улучшено качество шва, вертикальных поверхностей и плотности заполнения.
      Для реализации этих улучшений встроенное ПО принтера необходимо обновить до версии 2.4.
GrabCAD Print версии 1.63, февраль 2022
Номер сборки 1.63.8.15371 выпуск 16 февраль 2022.
  • WSS™150 — это водораствор��мый вспомогательный материал для быстрого удаления опор в системах J55 Prime и J35 Pro PolyJet. WSS150 становится водорастворимым после помещения в сосуд с обычной водопроводной водой. Для ускоренного удаления опор можно использовать обычную или настольную посудомоечную машину. Кроме того, для безопасной утилизации сточных вод без необходимости их передачи для дальнейшей очистки в соответствии с местным законодательством можно использовать порошок L2S™.
  • Обновлена панель «Предварительный просмотр среза»:
    • Теперь отображаются имя, высота среза и наконечник, используемый для модели, а также вспомогательные материалы
    • Изменены фильтры для отображения функций (Стабилизаторы, Крепления, Швы, Паузы)
    • Сгруппированы элементы управления анимацией («Воспроизвести анимацию», «Выбрать слой» и «Перемещения головки») и пауза по оси Z («Добавить/удалить паузу по оси Z», список пауз).
      Доступ к панели «Настройки модели» удален из экрана «Предварительный просмотр слоя», так как сведения о материале и высоте среза теперь отображаются на панели «Предварительный просмотр среза».
  • При использовании функции «Оптимизировать для компоновки» в J55 Prime или J8 Prime теперь можно точно настроить пользовательский прозрачный цвет, используя поле ввода «CMYK» с поддержкой VeroUltraClear, для большей визуальной прозрачности и насыщенности любого флакона или жидкости.
  • В принтере J5 DentaJet PolyJet теперь используется новый улучшенный набор параметров для более быстрой и точной печати деталей для стоматологии.
  • Новые смолы теперь поддерживаются в VoxelPrint в системах PolyJet:
    • VeroUltraWhite и VeroUltraBlack на всех поддерживаемых принтерах
    • DraftWhite на J5 MediJet
GrabCAD Print версии 1.62, январь 2022
Номер сборки 1.62.8.14676 выпуск 19 январь 2022.
  • Наконечник модели T16A добавлен для использования с ULTEM™ 9085 и сертифицированными материалами уровня ULTEM™ 9085 CG на принтере Fortus 450mc. Он обеспечивает высокую воспроизводимость механических свойств и более высокое качество по сравнению со стандартным наконечником T16 для задач, требующих сертификации деталей, включая внутреннюю отделку авиационно-космической техники. Толщина слоя наконечника модели T16A составляет 0.010 дюйма(-ов) (0.2540 мм). Для использования наконечника модели T16A программное обеспечение контроллера Fortus 450mc необходимо обновить до версии 6.6.6906.
  • Высота среза 0.0130 дюйма(-ов) (0.3302 мм) теперь поддерживается для ULTEM™ 9085 Black с использованием наконечника модели T20 для принтера Fortus 450mc. Увеличенная толщина среза ускоряет сборку деталей и повышает производительность. Для применения новой высоты среза необходимо обновить программное обеспечение контроллера до версии 6.6.6906.
  • Вместе с другими улучшениями было исправлено несколько мелких ошибок.
GrabCAD Print версии 1.61, декабрь 2021
Номер сборки 1.61.12.14139 выпуск 22 декабрь 2021.
  • Для полноцветной печати PolyJet «Внешний вид модели» теперь является основным параметром по умолчанию для текстурированных объектов при изменении цветов с помощью палитры цветов. Этот параметр непосредственно связан с недавно выпущенным параметром «Переопределить текстуру» (по умолчанию отключен), который позволяет изменять цвет и прозрачность текстурированного объекта с помощью простого, интуитивно понятного рабочего процесса.
  • При установке отложенного времени начала выполнения задания на принтере серии J5, в дополнение к существующему времени начала или окончания доступен новый параметр настройки времени. Если во время работы заканчивается материал, можно установить время замены канистры с материалом, и принтер начнет выполнять задание в соответствующее время.
  • Для цифрового анатомического принтера — новые предварительные настройки «Сшиваемая стенка сосуда» обеспечивают повышение производительности и долговечность моделей кровеносных сосудов, предназначенных для сшивания.
  • Исправлена ошибка, из-за которой на одной и той же модели было невозможно создать крепления и стабилизаторы.
GrabCAD Print версии 1.60, ноябрь 2021
Номер сборки 1.60.9.13125 выпуск 17 ноябрь 2021.
  • Правая часть GrabCAD Print претерпела ряд изменений. Иконки стали немного меньше и закреплены сбоку от окна. В систему постоянно добавляются новые инструменты, поэтому занимаемое ими пространство немного уменьшено для корректного отображения на экранах меньшего размера.
  • На принтерах PolyJet теперь можно печатать модели с картами смещения (рельефа). После активации этой функции в меню «Файл» > «Настройки» > «GrabCAD Labs» карты рельефа формата Keyshot .3MF или стандартных моделей .OBJ будут преобразованы в шероховатость поверхности распечатываемой детали. Раньше карты рельефа было необходимо записывать в сетку 3D-файла, что приводило к излишнему увеличению размера файлов. Теперь карты рельефа можно считывать напрямую. Высота смещения изменяется в настройках модели или отключается путем установки значения параметра равным 0. Просим вас направлять свои отзывы об этой и других функциях Labs.
  • В машинах J35 Pro имеется новый режим — «Режим использования материала». В этом новом режиме принтер автоматически выбирает комбинацию цветов, чтобы полностью использовать оставшиеся материалы. Напечатанная деталь будет отличаться от визуализации в GrabCAD Print, так как окончательный цвет определяют любые используемые при печати материалы. Эта функция доступна в окне «Сводка печати».
  • Возможность сохранять текстуру при изменении цвета фигуры. До этого при добавлении нового цвета к текстурированной модели ее текстура также изменялась. Теперь в случае добавления нового цвета обновляется цвет фигуры детали под текстурой, при этом его можно изменить. При выборе опции «Основа и сердцевина» цвет будет изменен, если цвета не совпадают.
  • Дополнительная оптимизация печати задания PolyJet для различных тяжелых моделей. При заполнении лотка тяжелыми моделями используйте эту функцию для их автоматической оптимизации. Эта функция автоматически упрощает модель без ущерба для ее качества или точности.
  • В последних графических драйверах NVIDIA была обнаружена проблема, не позволявшая проводить оценку и печать некоторых заданий PolyJet. Эта проблема было устранена.
  • Исправлена ошибка, из-за которой в предварительном просмотре среза модель со стабилизатором отображалась тем же цветом, что и стабилизатор.
GrabCAD Print версии 1.59, октябрь 2021
Номер сборки 1.59.11.12349 выпуск 25 октябрь 2021.
  • В машинах J55 Prime в раздел настроек конфигурации материала только черного и белого цвета добавлен новый ползунок градации серого. Кроме того, при загрузке текстур используется черно-белый профиль.
  • Исправлена проблема, из-за которой при сохранении проекта не сохранялись изменения толщины фигуры модели.
  • Исправлена проблема, из-за которой для модели с самонесущим отверстием в проекте не сохранялись настройки фигуры и поверхности.
GrabCAD Print версии 1.58, сентябрь 2021
Номер сборки 1.58.9.11590 выпуск 23 сентябрь 2021.
  • «Сохранить настройки проекта» позволяет сохранять настройки проектов для принтеров FDM при передаче проекта на принтер того же типа (например, с принтера Stratasys F370 на Stratasys F370). Можно сохранить текущие настройки печати, даже если они не подходят для нового принтера, или изменить настройки в соответствии с параметрами нового принтера.
  • Исправлена ошибка для ряда полноцветных распечаток PolyJet, когда белая сердцевина могла печататься даже при выборе «Внешний вид фигуры». Проекты, сохраненные в 1.56 или 1.57, в которых настройки сердцевины изменены вручную, необходимо создать заново.
GrabCAD Print версии 1.57, август 2021
Номер сборки 1.57.8.10644 выпуск 19 август 2021.
  • Представляем Stratasys® J55™ Prime, революционное обновление серии J55™. Принтер J55 Prime 3D обеспечивает полноцветную печать, высокую точность воспроизведения, а также расширенные функциональные возможности и абсолютную реалистичность печати. Благодаря этому эффективная и обеспечивающая высокое качество технология PolyJet стала еще более доступной и удобной для использования в офисах. В том числе передовые технологии печати с использованием различных материалов: эластичные края (Elastico™), High Impact (Digital ABS), Rigid Ultra Visual (VeroUltra™, DraftGrey), Translucent (VeroUltra™ ClearS) и биосовместимых материалов (Vero™ ContactClear). Создавайте все, что вам нужно — от быстрой разработки вариантов моделей до высококачественных готовых прототипов — с помощью компактного бесшумного принтера, не выделяющего запахов. Узнайте больше о новом принтере J55 Prime.
  • Представляем Stratasys® J35™ Pro. J35™ Pro разработан на платформе вращающегося лотка J55™ Prime и представляет собой недорогое решение для печати PolyJet 3D, которое отличное подходит для многопользовательских офисных задач и позволяет использовать различные материалы для функционального проектирования и создания моделей. В новом принтере 3D реализованы самые передовые технологии печати и возможность применения различных материалов: эластичные края (Elastico™), High Impact (Digital ABS), Rigid Ultra Visual (VeroUltra™, DraftGrey), Translucent (VeroUltra™ ClearS) и биосовместимых материалов (Vero™ ContactClear). Благодаря компактным размерам принтер легко устанавливается в офисе, а система фильтрации ProAero полностью исключает неприятные запахи на рабочем месте. Узнайте больше о новом принтере J35 Pro.
  • Впервые обновлена поддержка версий CAD Print в середине цикла.
  • В предварительном просмотре среза теперь можно управлять отображением креплений и стабилизаторов.
    • Крепления и стабилизаторы отображаются соответствующим цветом, благодаря чему они легко различимы на фоне модели и опор.
    • Отключите отображение креплений и стабилизаторов с помощью соответствующих параметров в списке «Отображение», чтобы упростить проверку модели.
    • Параметры отображения крепления и стабилизатора отображаются только в том случае, если в задании имеются эти функции
    • Настройки отображения крепления и стабилизатора сохраняются и при следующем предварительном просмотре среза.
    • Кроме того, выделение слоя теперь отображается прозрачным белым цветом, что позволяет легче различать на срезе саму модель, опоры, крепления и стабилизаторы.
  • Два обновления цифрового анатомического принтера:
    1. Возможность печати сверхреалистичных моделей подкожной жировой ткани с использованием 6 новых предварительных установок на основе комбинации TissueMatrix и GelMatrix. Основные различающиеся по степени мягкости характеристики моделей — способный к сокращению подкожный жир (очень мягкий) и обладающий очень высокой способностью к сокращению подкожный жир (самый мягкий) со следующими вариантами покрытия:
      • Жесткое покрытие — Покрытие Agilus толщиной 2 мм для создания более прочной обособленной модели.
      • Мягкое покрытие — комбинированное покрытие Agilus и GelMatrix толщиной 2 мм для придания обособленному образцу реалистичной мягкой жироподобной текстуры и внешнего вида.
      • Неинкапсулированный — без покрытия, для задач, когда жировая ткань является частью модели органа.
    2. Расширенные возможности GelMatrix — еще больше вариантов моделирования анатомии, а также упрощение и сокращение продолжительности постобработки. Узнайте больше о двух новых функциях в меню «Настройки анатомической модели»:
      • Возможность печати различных анатомических структур благодаря использованию GelMatrix в качестве вспомогательного материала
      • Возможность печати с использованием чистого материала GelMatrix без добавления других материалов
GrabCAD Print версии 1.56, июль 2021
Номер сборки 1.56.11.9996 выпуск 20 июль 2021.
  • На панели настроек модели PolyJet теперь имеется раздел «Предварительные установки». На панели уже есть раздел «Избранное», предназначенный только для выбора цвета, но в предварительных установках кроме цвета также можно изменить все другие настройки модели. Щелкните правой кнопкой мыши на лотке, чтобы сохранить предварительные установки. После добавления предварительных установок можно щелкнуть на них правой кнопкой мыши, чтобы они применялись в качества установок по умолчанию. Они будут применены к моделям, впоследствии добавленным в лоток.
  • Новое в серии J8 Prime: «Оптимизировать для упаковки» улучшает внешний вид прототипов упаковки простым действием. Первая в своем роде функция преобразования прозрачности из RGB в цвета на печати теперь позволяет пользователям достигать большей точности степени прозрачности таких структур, как жидкости или цветное стекло. В дополнение к этому под ярлыками автоматически печатается белый фон, поэтому графические элементы выглядят очень отчетливо на таком непрозрачном фоне. Эта возможность реализована в полноцветных принтерах серии J8 с опциями «цвета Vero Vivid», «UltraWhite + UltraBlack» и «UltraClear», а также для файлов 3MF Keyshot. (Для получения сведений об активации этой функции обратитесь в print@grabcad.com)
  • Улучшения функции создания креплений:
    • С целью упрощения создания и изменения креплений между моделью и лотком (наиболее частый вариант использования) при открытии панели «Крепление» для вида «Просмотр модели» автоматически устанавливается вид снизу.
    • Во время редактирования креплений устанавливается более детализированный режим предварительного просмотра лотка, а режим просмотра модели — спереди, сзади, слева или справа, что упрощает проверку при предварительном просмотре геометрии набора креплений. После закрывания панели «Крепления» восстанавливается более общий режим просмотра лотка.
  • В Antero 800 NA на платформах Stratasys F900 и Fortus 450mc, а также в Antero 840 CN03 на платформе F900 добавлен наконечник модели T20F, который улучшает механические характеристики до 20% по сравнению с прежним наконечником модели T20D при аналогичном качестве и точности детали. Чтобы использовать наконечник модели T20F, выберите 0.0100 в | T20F ( мм | T20F) в раскрывающемся меню «Высота среза» после выбора совместимого материала.
  • Версия микропрограммы 4.11. 0 доступна для принтеров Stratasys F900 и Fortus 900 mc. Это обновление недоступно при использовании стандартного загружаемого файла обновления (.upg). Подробнее об этом важном обновлении можно узнать у специалиста по обслуживанию или в службе поддержки клиентов компании Stratasys.
GrabCAD Print версии 1.55, июнь 2021
Номер сборки 1.55.8.8912 выпуск 16 июнь 2021.
  • Мышь SpaceMouse 3 D теперь поддерживается для управления видом в GrabCAD Print. Руководство для этого см. здесь.
  • Для коротких и широких моделей, которые могут скручиваться при охлаждении, функция «Крепление» позволяет закрепить модель на сборочном лотке во время печати. Элемент «Крепление» — это столбик, сделанный из материала модели, который прикрепляет горизонтальные нижние поверхности модели к лотку. Крепления могут быть цилиндрами или конусами, создаваемыми индивидуально или в наборах с одинаковым стилем и диаметром(-ами). Щелкните здесь для получения дополнительных сведений о настройке креплений. (Поддерживается для принтеров серий Stratasys F770, F370, F270, F170, F900 и Fortus.)
  • Стабилизаторы теперь требуют от вас выбора контрольной кривой перед созданием. Это предотвращает мгновенное создание стабилизатора при первом открытии панели и позволяет настраивать параметры перед созданием стабилизатора.
  • Представляем J5 MediJet ™, новый универсальный медицинский принтер, разработанный для создания анатомических моделей, хирургических шаблонов и медицинского инструмента с использованием стерилизуемых и биосовместимых материалов. J5 MediJet задает новый стандарт применения 3D-печати в медицине. Благодаря использованию множества материалов и возможностям многоцветности вы можете создавать ярчайшие анатомические модели, руководства по сверлению и резке, а также биосовместимые медицинские инструменты, которые можно стерилизовать — и все это в сертифицированной системе. Кроме того, этот принтер экономичен и достаточно компактен для небольших лабораторных помещений. Дополнительные сведения здесь.
  • Новый инструмент в правом меню для принтеров PolyJet позволяет вам установить точное положение на лотке, используя единицы измерения, определенные в настройках.
  • Внимание! В следующем выпуске функция расширенной обработки полутонов цвета на полноцветных принтерах J-Series будет выставлена по умолчанию для новых лотков при использовании VeroPureWhite с полноцветным режимом.
GrabCAD Print версии 1.54, май 2021
Номер сборки 1.54.6.7969 выпуск 18 май 2021.
  • Принтер Stratasys F770™ 3D оснащен самой длинной камерой для печати с подогревом на рынке – 46 дюйм. по диагонали. Просторный корпус для сборки имеет объем более 13 куб. фут. (372 л), что открывает новые возможности для создания, прототипирования и производства деталей, которые просто недоступны для небольших принтеров. Здесь можно познакомиться поближе с Stratasys F770.
  • Для высоких и тонких моделей, которые не требуют много традиционных опор, новая функция «Стабилизатор» позволяет добавлять строительные леса для модели по мере ее построения. Стабилизатор — это высокая опорная конструкция, которая крепится к боковой части модели через равные промежутки, обеспечивая дополнительную поддержку и минимизируя вибрацию. Щелкните здесь, чтобы получить дополнительную информацию о настройке стабилизаторов. (Поддерживается для принтеров серий Stratasys F770, F370, F270, F170, F900 и Fortus.)
  • Исправлена проблема, из-за которой для принтеров серии F123 был отключен флажок «Использовать заливку переменной ширины».
  • Для покрывающих поверхностей модели FDM были исправлены следующие проблемы с траекторией инструмента:
    • Маленькие покрывающие поверхности больше не получают вдвое больше растрового заполнения, чем им требуется.
    • Небольшие отверстия в покрывающих поверхностях больше не игнорируются.
  • Выпущена функция GrabCAD Labs, представленная в 1.48 и позволяющая назначать различные покрытия PolyJet (матовые или глянцевые) компонентам сборки. Теперь она доступна всегда.
GrabCAD Print версии 1.53, апрель 2021
Номер сборки 1.53.15.7152 выпуск 20 апрель 2021.
  • Когда выбран предварительный просмотр среза, значением по умолчанию для диапазона теперь является «Все слои». Изменения в диапазоне слоев будут запомнены для следующего выбора предварительного просмотра среза.
  • Эти новые непрозрачные материалы позволяют печатать тонкие, реалистичные пластиковые модели, предлагают расширенную цветовую гамму с высокой точностью, четкий текст для печати упаковочных этикеток и гладкие телесные тона с высоким разрешением.
GrabCAD Print версии 1.52, март 2021
Номер сборки 1.52.8.6136 выпуск 16 март 2021.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.52.
  • ABS, армированный углеродным волокном, доступен для принтеров Stratasys F370, Stratasys F270 и Stratasys F170. Stratasys ABS-CF10 сочетает в себе стандартный материал ABS (акрилонитрил-бутадиен-стирол) с 10% измельченного углеродного волокна по весу. В результате получается термопласт FDM® с низкой чувствительностью к влаге, который на 50% жестче и на 15% прочнее, чем стандартный материал для 3D-печати ABS. Типичные области применения включают изготовление инструментов, зажимных устройств, приспособлений и концевых зажимов, которые выигрывают от сочетания повышенной жесткости и уменьшенного веса. ABS-CF10 поддерживается для высот среза 0.0070 дюйм. (0.1778 мм), 0.0100 дюйм. (0.2540 мм) и 0.0130 дюйм. (0.3302 мм). Узнайте больше о новом материале ABS-CF10 здесь.
  • Представляем J5 DentaJet ™. 3D-принтер J5 DentaJet, основанный на платформе J55, является новейшим дополнением к нашей линейке стоматологических 3D-принтеров для различных материалов, позволяющим техникам загружать смешанные лотки стоматологическими деталями. Этот новый 3D-принтер может производить как минимум в пять раз больше стоматологических деталей на одном смешанном лотке, чем конкурирующие 3D-принтеры, при этом он компактен, занимая всего 4.6 кв. фут. (43 м2) пола. Посмотреть новый J5 DentaJet можно здесь.
  • Слои основания и промежуточные слои между опорными конструкциями и моделями из Antero 840 CN03 улучшены, что повышает качество обращенных вниз поверхностей моделей. Опорные конструкции также изменены для повышения их устойчивости.
  • Для Diran 410MF07, высота среза 0.0010 дюйм. (0.2540 мм), минимальная толщина фигуры снижена до 0.0200 дюйм. (0.5080 мм) для сплошного заполнения, угол самонесущей конструкции по умолчанию был уменьшен до 45 град., а другие параметры печати обновлены для улучшения общего качества печати моделей.
  • Новая анатомия печени теперь доступна в цифровом анатомическом принтере. 4 новые предустановки анатомии печени с различными значениями компрессии, каждое из которых подтверждено данными в полном отчете Bio-Mechanical. Изменяются от высокосократимого до умеренно жесткого с изменяющимся слоем покрытия. Подробнее о проведенном тестировании можно узнать по этой ссылке.
GrabCAD Print версии 1.51, февраль 2021
Номер сборки 1.51.18.5360 выпуск 22 февраль 2021.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.51.
  • Теперь вы можете печатать файлы из последних версий большинства пакетов САПР, включая SOLIDWORKS 2021, Inventor 2021 и Creo 7. См. здесь полный список поддерживаемых файлов. Версия для печати GrabCAD 1.50, январь 2021.
  • Представляем J850 Pro, принтер PolyJet для материалов 7, созданный специально для быстрого прототипирования. J850 Pro имеет такой же объем сборки и емкость материала, что и J850 Prime — ранее известный как J850, — но если J850 Prime хорош в прототипировании CMF, J850 Pro создан для обеспечения скорости и производительности при использовании Digital ABS, гибких материалов Agilus, DraftGrey и режима сверхвысокой скорости. Новую линейку J8-Series можно посмотреть здесь.
  • В новом окне сводной информации о печати будут удобно собраны параметры, оценки, параметры отложенного запуска, а также любые предупреждения или уведомления, которые вам нужно видеть, когда вы нажимаете «Печать» для задания PolyJet.
  • Когда модели ремонтируются в режиме анализа, любые фигуры с нулевым объемом, такие как листовые фигуры и шумовые оболочки, будут автоматически скрыты, поскольку эти фигуры нельзя интерпретировать и они могут вызвать ошибки оценки или печати.
  • Улучшено графическое представление файлов CMB в области уведомлений. Дисплей CMB предоставляет более подробную информацию о фактической форме модели. Карманы, которые ранее игнорировались, теперь идентифицируются и отображаются. Благодаря улучшенному отображению CMB пользователю не нужно вводить предварительный просмотр среза, чтобы понять модель, полученную в результате печати CMB.
  • Строки меню и меню в GrabCAD Print могут менять цвет, чтобы соответствовать цветам, установленным вашей темой Windows.
GrabCAD Print версии 1.50, январь 2021
Номер сборки 1.50.14.4357 выпуск 19 январь 2021.
  • Когда доступно обновление для GrabCAD Print, настройка (введенная в версии 1.22) определяет, будет ли обновление установлено автоматически при следующем запуске приложения. По умолчанию автоматическое обновление было включено, но теперь оно будет отключено у всех. Будущие обновления будут устанавливаться только при нажатии кнопки «Обновить сейчас». При желании автоматические обновления можно снова включить в меню «Файл > Настройки > Обновления».
  • Обнаружение конфликтов при загрузке модели теперь может обнаруживать и предупреждать о ситуациях, когда модели перекрываются. Для печати PolyJet это поможет определить, где может быть необходимо изменить приоритет детали. Примечание. Обнаружение конфликтов по умолчанию отключено. Оно включается через «Установки > Параметры вставки модели > Автоматическое обнаружение конфликтов в сборках».
  • Когда вы вставляете сборку с плоской структурой в принтер серии J, приоритет по умолчанию теперь отображается в списке файлов сразу. Раньше вам нужно было изменить приоритет детали, чтобы ее увидеть.
  • При использовании режима «Черный + белый» на принтерах серии J теперь есть ползунок шкалы серого, который работает с цветовым профилем «Ч/Б», заменяя существующее средство выбора полноцветного цвета.
  • DraftGrey, который ранее был эксклюзивным для новой версии принтера Objet30 V5, теперь доступен на принтерах V3 (указанных как VeroGrey). Для получения дополнительной информации щелкните здесь. Кроме того, это обновление включает режим высокого качества с материалами Vero.
  • В версии 1.49 некоторые принтеры Connex некорректно сообщали о неправильной версии графического драйвера. Это было исправлено в выпуске 1.50
GrabCAD Print версии 1.49, декабрь 2020
Номер сборки 1.49.12.3309 выпуск 16 декабрь 2020.
  • Для принтера Objet1000 доступен комплект обновления J4100. Этот комплект расширяет возможности принтера Objet1000 за счет новой технологии печатающих головок и самых передовых материалов. Новые печатающие головки предоставляют дополнительный канал модели (3) для увеличения пропускной способности и производительности в пределах 90%. В число предлагаемых материалов теперь входят семейство Agilus, UltraClear и VeroPureWhite. J4100 позволяет печатать гибкие материалы поверх цифрового ABS (формование поверх).
  • Некоторые пользователи J-серии сталкивались с проблемой, из-за которой они не могли печатать на своих принтерах J-серии, потому что обработка заданий зависала. Это было вызвано устаревшими графическими драйверами на компьютерах управления принтером, но GCP удалось обнаружить проблему. Это было исправлено, и оказавшись в такой ситуации, вы увидите сообщение, указывающее на ссылку для обновления драйверов.
  • Исправления программного обеспечения, связанного с CMB
    • Восстановлена опция включения/исключения чистящей детали/чистящей башни в экспорте CMB.
    • Восстановлена возможность включения дополнительной чистящей башни на лоток, содержащий CMB.
GrabCAD Print версии 1.48, ноябрь 2020
Номер сборки 1.48.14.2323 выпуск 17 ноябрь 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.48.
  • GrabCAD Print теперь поддерживает настольные принтеры Objet30. В дополнение к существующим принтерам Objet30 V3 (известным как Objet30, Objet30 Pro и Objet30 Prime), запускается новое поколение: Objet30 V5 Pro и Prime. Модели V5 — это одноцветные, простые в использовании принтеры, занимающие мало места и обеспечивающие непревзойденное качество печати. Они предлагают несколько режимов печати (3) и различные материалы для моделей (13), включая DraftGrey, а также гибкие и биосовместимые материалы (только Prime). Чтобы использовать GrabCAD Print с Objet30, нужно будет следовать следующему руководству: Настройка принтеров PolyJet для GrabCAD Print.
    Параметр «Стиль основания» теперь доступен на панели «Параметры опор» для принтеров FDM.
    • Модель и опоры: Основания добавляются под моделью и подошвой опоры. Когда основания перекрываются, они сливаются в общее основание. Когда основания образуют замкнутые петли, петля заполняется, создавая большое устойчивое основание.
    • Только модель: Основания добавляются только под подошвой модели. Опоры доходят до лотка, а петли не заполняются.
  • Новая опция в меню «Файл > Настройки > GrabCAD Labs» позволяет смешивать матовую и глянцевую отделку фигур в сборках для принтеров PolyJet.
  • В принтерах J826 теперь доступен новый режим печати — режим сверхвысокой скорости. Этот новый режим предлагает вдвое большую пропускную способность по сравнению с высокоскоростным режимом и практичен для многих задач, таких как печать быстрых концептуальных моделей.
  • Для заданий, использующих материал модели ASA с экструзионным наконечником T40 (высота среза 0.0200 дюйм./0.5080 мм) на средствах моделирования Stratasys F900 и Fortus 900mc, использующих вспомогательные материалы SR30 или SR35, изменены свойства построения слоев основания ниже первого слоя детали для улучшения качества первого слоя детали и предотвращения расслоения.
  • Для заданий на Stratasys F900, использующих материал модели ASA с модельным наконечником T40 (высота среза 0.0200 дюйм./0.5080 мм) точность оценки времени и объема была улучшена. Это изменение предназначено для использования с новой прошивкой системы 4.10.0. Обратите внимание, что это обновление прошивки не будет доступно через стандартный загруженный файл обновления (.upg). Для получения информации об этом важном обновлении системного программного обеспечения обратитесь к представителю сервисной службы или в службу поддержки клиентов Stratasys.
GrabCAD Print версии 1.47, октябрь 2020
Номер сборки 1.47.20.1644 выпуск 20 октябрь 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.47.
  • Внешний вид и поверхностная плотность обращенных вверх поверхностей улучшаются для ABS и ASA при использовании высоты среза 0.0100 дюйм. (0.2540 мм) на принтере Stratasys F370.
  • Улучшенное остаточное заполнение за счет лучшего обнаружения коротких тонких областей для заполнения остаточными траекториями инструмента переменной ширины.
  • Теперь можно выбрать модели с различными состояниями упрощения отображения и глобально установить для всех выбранных моделей либо полное разрешение, либо упрощенное.
  • Текстуры, для которых в SolidWorks установлено значение прозрачности, теперь импортируются в GrabCAD Print с правильной прозрачностью.
  • UltraclearS имитирует акрил, достигая 95% светопропускания этого материала, и используется для прототипов стекла, прозрачных полимеров или прозрачной упаковки. VeroUltraClear улучшает прежние характеристики VeroClear за счет более высокого уровня ясности, прозрачности и более низкого индекса желтого цвета.
  • Опция опорного ядра теперь также доступна в принтере J55. Опорное ядро (ранее известное как «пустотелое») позволяет распечатать сердечник из вспомогательного материала. Прежде чем использовать эту опцию, включите ее в Настройки > GrabCAD Labs.
  • Разделение кости на цифровом анатомическом принтере позволяет разрезать модель кости на части, чтобы имитировать переломы или удалить детали на лотке, не относящиеся к этой области применения.
  • Параметры профиля цвета и текстуры, которые ранее находились в окне «Изменить материалы», были перемещены в раздел «Дополнительно» на панели инструментов «Параметры лотка».
GrabCAD Print версии 1.46, сентябрь 2020
Номер сборки 1.46.21.661 выпуск 15 сентябрь 2020.
Номер сборки 1.46.22.826 выпуск 18 сентябрь 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.46.
  • Параметр «Пустотелый», который раньше был флажком в параметрах модели PolyJet, теперь доступен как параметр «Опора» в разделе «Параметры основания и ядра». Кроме того, настройка «Смешанное ядро», появившаяся в версии 1.42, теперь включена по умолчанию.
  • Новые функции цифрового анатомического принтера
    • Предварительный просмотр кости — позволяет просматривать фрагмент за фрагментом внутренней структуры кости, чтобы убедиться, что структура соответствует вашим намерениям.
    • Открытые/закрытые концы — создает «окно» во внутреннюю структуру кости. Вы можете отметить плоское поперечное сечение кости, а затем покрыть его прозрачным материалом или оставить как есть, то есть незащищенным.
  • Поддержка файлов 3 MF, которая была представлена в качестве экспериментальной функции в версии 1.40, теперь общедоступна.
  • Файлы SOLIDWORKS с текстурами с прозрачным фоном теперь будут правильно загружаться в GrabCAD Print, показывая основной внешний вид через прозрачный фон.
  • Antero™ 840CN03 теперь поддерживается на Fortus 450 mc. Antero 840CN03 представляет собой смесь материала модели Stratasys® Antero 800NA, обладающего свойствами электростатического разряда (ESD) и пригодного для применения на производствах, где используются контактно-чувствительные электронные детали и компоненты. Для Antero 840CN03 доступна одна высота среза: 0.010 дюйм. (0.2540 мм). Для получения информации об этом материале прочтите следующее.
GrabCAD Print версии 1.45, август 2020
Номер сборки 1.45.21.65369 выпуск 25 август 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.45.
  • Режим печати PolyJet можно выбрать заранее при подготовке заданий на печать. Отображаются только функции и настройки, доступные для выбранного режима печати, что упрощает подготовку заданий. В зависимости от выбранного режима печати, недоступные функции и настройки будут по-прежнему отключены с объяснением причины, по которой они недоступны.
  • Представляем адаптивный стиль среза для FDM! Адаптивный срез использует выбранную высоту для элементов, которым требуется большая детальность, таких как купола, валики и канавки, и более толстую высоту среза для элементов, которым детальность не требуется. В результате печать выполняется быстрее (в зависимости от геометрии и высоты среза — выигрыш до 24%). Стиль среза — это новый параметр, который устанавливает способ срезания модели. Подробнее здесь.
  • Выбор, сделанный в «Параметры отображения > Качество графики», теперь управляет уровнем упрощения, применяемым к моделям, используемым для графического отображения. Примечание: печатаемая модель сохраняет полное разрешение. В контекстном меню есть параметр «Разрешение графики», с помощью которого можно переключать отображение выбранных моделей между упрощенным и полным разрешением.
  • Теперь есть параметр, который применяется ко всем типам файлов, чтобы выбрать статус загрузки сборок, собранных или разобранных.
GrabCAD Print версии 1.44, июль 2020
Номер сборки 1.44.22.64105 выпуск 22 июль 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.44.
  • Назначения ядра/основания можно настроить так, чтобы они наилучшим образом соответствовали дизайну модели.
  • Функция автоматической компоновки для принтеров J720 предлагает улучшенную раскладку деталей, повышая эффективность производства.
  • GrabCAD Print Server версий, более ранних, чем 2.0, больше не сможет подключаться к GrabCAD Cloud, начиная с июль 21. Чтобы продолжить подключение к своим принтерам через GrabCAD Print Server, вручную удалите старую версию и установите сервер печати 2.0. Последнюю версию можно загрузить здесь.
  • GrabCAD Print Server 2.0 будет поддерживаться только в Microsoft Windows 10 (64-разрядная) и Windows Server 2016 и новее. Экземпляры, работающие в более старых версиях Windows, не получающих базовой поддержки от Microsoft, не будут обновляться автоматически и не смогут подключаться к GrabCAD Cloud, начиная с июль 21. Вам потребуется обновить ОС на экземпляре Print Server или установить Print Server на компьютере с поддерживаемой ОС.
  • GrabCAD Print переходит на общесистемную установку (для компьютеров). Если это повлияет на вас, вы получите уведомление, когда станет доступно обновление. Миграция (обычно) не потребует каких-либо усилий с вашей стороны. После v1.47 нужно будет перейти на нашу установку для компьютеров, чтобы продолжать получать обновления.
  • GrabCAD Print теперь позволяет отправлять файлы диагностики с принтера контактному лицу службы поддержки Stratasys. В случае проблем с оборудованием, материалами, другим принтером или даже программным обеспечением теперь можно перейти в раздел «Справка > Получить поддержку по принтеру» и добавить там подробную информацию о проблеме. Тогда GrabCAD Print сгенерирует шаблон электронной почты вместе со всеми деталями и необходимыми файлами, которые можно отправить на адрес электронной почты, предоставленный во время продажи.
  • 3Файлы MF с глубокой (многоуровневой) структурой сборки теперь будут отображать всю древовидную структуру на панели «Проект».
GrabCAD Print версии 1.43, июнь 2020
Номер сборки 1.43.17.62943 выпуск 17 июнь 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.43.
  • Теперь, когда функции расширенного FDM доступны в GrabCAD Print, создание проектов расширенного FDM больше не требуется. Параметр «Включить расширенный FDM» был удален из меню «Настройки». Действие по созданию нового расширенного проекта FDM удалено с левой панели инструментов.
  • В рамках переноса функциональности расширенного FDM в ядро GrabCAD Print проекты, созданные в расширенном FDM, будут открываться в GrabCAD Print, причем каждая модель будет находиться на отдельном лотке. Группы сохранятся, как и настройки фигуры, настройки граней, свойства лотка, ориентация и производственные примечания.
  • Алгоритм, преобразующий файлы VRML, OBJ и 3MF в печатаемые объекты, был переписан, чтобы предотвратить сбои при срезах.
  • Если вы выберете фигуру VRML, имеющую сплошной цвет, палитра цветов теперь будет отображать цвет напрямую и позволит вам внести небольшие изменения.
  • Две новые функции цифрового анатомического принтера
    • Средство Long Bone Axis Tool позволяет пользователю определять проксимальную и дистальную области длинной кости. Это позволяет печатать детали с различной плотностью, чтобы приблизительно имитировать структуру длинных костей.
    • Многие ортопедические процедуры требуют сверления отверстий и установки винтов в распечатанные модели. В некоторых случаях это может привести к нежелательному растрескиванию. Чтобы предотвратить это, средство Strain Relief Tool позволяет установить периметр, предназначенный для ограничения любых трещин и предотвращения более широкого растрескивания распечатанной части.
  • Представляем Stratasys J55. Никаких компромиссов во всем процессе творчества. Удобный для офиса принтер J55 3D — от быстрых концептуальных до качественных высокоточных моделей — доступен по цене и позволяет дизайнеру работать с максимальной отдачей. Дополнительные сведения здесь.
GrabCAD Print версии 1.42, май 2020
Номер сборки 1.42.19.62279 выпуск 20 май 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.42.
  • Располагайте и ориентируйте модели с помощью нового манипулятора. Нажмите крайнюю правую кнопку на полосе управления видом, чтобы включить его. Тогда на выбранных моделях появятся стрелки, которые можно перетаскивать, чтобы перемещать и вращать выбранный объект свободно или вдоль точно заданной оси.
  • Для принтеров FDM расстояние между моделями на лотке теперь можно отрегулировать от минимального в 0.2500 дюйм. (6.35 мм) до максимального в 2.0000 дюйм. (50.8 мм) с помощью ползунка на панели инструментов упорядочивания. Это позволит плотнее упаковать модели на лотке или держать их дальше друг от друга для улучшения воздушного потока.
  • Новые цветовые профили CMYKW и CMYW, добавленные в 1.41, теперь являются цветовыми профилями по умолчанию при загрузке в принтер ярких материалов CMYKW и CMYW. Имя профиля — X-Rite i1Profiler CMYKW или CMYK.
  • Раньше ядро детали PolyJet печаталось с чередующимися слоями черного и белого материала, но новая настройка «Смешанное ядро» в меню «Файл > Настройки > PolyJet» позволяет печатать ядро из смеси всех доступных материалов. Это значительно снижает вероятность проблем с засорением сопел, поскольку каждая печатающая головка будет использоваться чаще, но требует, чтобы в каждом загруженном картридже с материалом было достаточно материала для выполнения задания.
GrabCAD Print версии 1.41, апрель 2020
Номер сборки 1.41.31.61723 выпуск 27 апрель 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.41.
  • Последние версии пакетов САПР теперь поддерживаются в GrabCAD Print. Сюда входят SOLIDWORKS 2020, Inventor 2020, Creo 6.0 и другие. Полный список читайте здесь.
  • Теперь можно изменить материал, используемый в опорной решетке печати J-Series, чтобы сохранить наиболее часто используемые материалы. Все опорные элементы в лотке будут печататься из выбранных материалов. Материал можно выбрать в «Настройки лотка > Дополнительно > Материал, используемый для укрепления опоры».
  • В рамках переноса в Print еще некоторых функций расширенного FDM, теперь можно применять различные параметры материалов к фигурам в группах. Щелкая правой кнопкой мыши на группе, можно переключаться между следующим:
    • Разделение фигур — настройки фигур и граней могут применяться независимо от других фигур и граней. Это похоже на то, как работает расширенный FDM.
    • Совмещение фигур — все фигуры в группе действуют как единая фигура, при этом одна настройка фигуры применяется ко всей группе, а внутренние границы удалены. Это похоже на то, как обычно работают сборки, когда выбирается «Собрано» без создания группы.
  • Когда в собранной группе выбрано «Разделение фигур», толщина поверхности, размещение швов и вставки доступны на вкладке «Грань» панели «Параметры модели». Ранее эта функция была доступна только в расширенном FDM.
  • Небольшие детали, требующие опор в печатных элементах FDM, создают опоры, становящиеся шире под деталью. Теперь это можно контролировать с помощью параметра «Наращивание опор», который позволяет вам изменить значение по умолчанию «Наращивание только небольших опор» на «Без наращивания опор» или «Наращивание всех опор». Отключение наращивания опор может быть полезно для сокращения использования материала и времени печати некоторых деталей.
  • В GrabCAD Print были добавлены новые цветовые профили Vivid 2.0, которые обеспечивают улучшенную цветопередачу. Цветовые профили по умолчанию не изменились и остались Vivid 1.1.
  • Сборки SOLIDWORKS с цветами граней теперь можно загружать непосредственно в печать GrabCAD без отдельного действия по сохранению их как детали, состоящей из нескольких фигур.
  • Для принтеров FDM файлы 3MF со структурой сборки теперь будут загружаться вместе с их структурой.
  • При изменении настройки FDM на ползунке, черный ромб будет указывать значение по умолчанию. Щелчок по нему восстановит значение по умолчанию.
  • В этом выпуске GrabCAD Print можно легко открывать файлы из заказов в GrabCAD Shop на свой лоток в GrabCAD Print. Это экономит время, позволяет ��збежать загрузки файлов САПР из электронной почты или другого программного обеспечения для управления запросами и помогает эффективно планировать лотки. Если вы еще этого не сделали, зарегистрируйтесь для получения GrabCAD Shop здесь.
  • Поле ввода «Добавить по IP-адресу» было добавлено в GrabCAD Print Server, чтобы легко подключаться к принтерам, когда автоматическое обнаружение недоступно.
GrabCAD Print версии 1.40, март 2020
Номер сборки 1.40.28.60898 выпуск 24 март 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.40.
  • Файлы деталей SOLIDWORKS, включая файлы деталей, состоящих из нескольких фигур, теперь будут включать данные о цветах, применяемых на уровне граней для печати PolyJet. Ранее в GrabCAD Print включались только цвета, применяемые на уровне фигур.
  • Проверьте, как цвета будут отображаться на распечатанной модели в вашем принтере PolyJet, создав образец цветов, выбранных пользователем. Откройте средство «Настройка цвета», выбрав «Приложения > Настройка цвета».
  • GrabCAD Print теперь позволяет пользователям печатать более крупные лотки PolyJet, оптимизируя потребление памяти графическим процессором компьютера. Эту функцию можно включить в меню «Настройки > PolyJet > Оптимизация тяжелого лотка».
  • Расширенная программа разбиения на слои теперь является единственной доступной программой разбиения на слои для Stratasys J750 и Stratasys J735. Устаревшая программа разбиения больше не доступна для этих принтеров. Для других принтеров PolyJet изменений нет.
  • При отправке задания из автономного Insight в GrabCAD Print, автономная версия должна быть той же или более поздней версии, чем версия Insight, доступная в GrabCAD Print, иначе задание не будет отправлено.
  • Мы обновили основной компонент GrabCAD Print до последней доступной версии. Это не только устраняет некоторые нерешенные проблемы, такие как загрузка файлов из папки OneDrive, но также улучшает общую производительность и время запуска.
  • GrabCAD Print теперь может импортировать файлы 3MF из многих инструментов САПР. В случае файлов 3MF, созданных SOLIDWORKS, это включает в себя: цвет грани, цвет фигуры и текстуры. Для принтеров PolyJet сборки будут иметь плоскую структуру, а для принтеров FDM структуры сборки не будет.
  • Улучшения, относящиеся только к FDM
    • Чтобы обеспечить лучшее общее качество деталей при использовании TPU 92A на принтере Stratasys F370, диапазон ширины для остаточной заливки переменной ширины был уменьшен.
    • Угол для самонесущих отверстий был увеличен до 55 градусов, чтобы соответствовать самонесущему углу для материала Diran 410mf07.
    • Решена проблема, из-за которой для некоторых моделей и ориентаций могла создаваться неполная опора.
  • Имя по умолчанию, присвоенное Группе, представленное в GrabCAD Print 1.36, теперь может быть заменено на имя, более логичное для пользователя.
GrabCAD Print версии 1.39, февраль 2020
Номер сборки 1.39.14.59507 выпуск 18 февраль 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.39.
  • Новая панель настроек модели PolyJet предлагает улучшенный дизайн и рабочие процессы пользователей, возможность сохранять материалы и избранные цвета, а также создавать собственные цвета и цифровые материалы с помощью новой функции ввода CMYK. Узнайте больше здесь.
  • При создании группы из сборки, к которой применен масштаб или ориентация, вновь созданная группа наследует эти свойства из сборки.
  • Теперь вы можете удалить отключенный принтер из списка принтеров. Просто щелкните правой кнопкой мыши на принтере, который вы хотите удалить, и выберите «Удалить принтер».
  • Теперь появилась более четкая и интуитивно понятная визуализация состояния контейнера для отходов для принтеров PolyJet на панели материалов.
  • Предостережение, касающееся расширенной программы разбиения на слои PolyJet: в мартовском обновлении GrabCAD Print версии 1.40 опция отключения расширенной программы разбиения на слои PolyJet для J750 и J735 больше не будет доступна.
GrabCAD Print версии 1.38, январь 2020
Номер сборки 1.38.21.59019 выпуск 28 январь 2020.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.38.
  • Если у вас есть принтеры PolyJet, вы можете попробовать новую панель параметров модели, которая имеет улучшенный дизайн и возможность сохранять избранное. Перейдите в меню «Файл» > «Настройки» > PolyJet и установите флажок для использования новой панели настроек модели PolyJet.
  • Новый материал VeroUltraClear, представленный для J850 и J835 в версии 1.36, теперь доступен на J750 и J735. VeroUltraClear имитирует акрил, достигая 95% свойства пропускания света этого материала, и полезен для прототипов стекла, прозрачных полимеров или прозрачной упаковки. Узнайте больше о материале VeroUltraClear здесь.
  • Пользователь имеет возможность переопределить детали VRML/OBJ, назначив новый цвет или материал на панели «Параметры модели» и при необходимости восстановить исходные значения, выбрав новую опцию, доступную в меню по щелчку правой кнопки мыши на выбранном теле VRML/OBJ.
  • Состояние по умолчанию настройки структуры VRML/OBJ было изменено с выключенного на включенное.
  • Шаблоны заполнения для материала Diran 410MF07 для расширенного FDM теперь могут иметь одинарную плотность, двойную плотность или быть сплошными. Кроме того, первый слой материала был изменен со вспомогательного материала на материал модели для улучшения сцепления поддона.
  • Устранена проблема, из-за которой в представлении расписания отображались неправильные имена моделей принтеров Stratasys.
GrabCAD Print версии 1.37, декабрь 2019
Номер сборки 1.37.15.57828 выпуск 18 декабрь 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.37.
  • Функция отложенного запуска для принтеров PolyJet, представленная в версии 1.20, теперь поддерживается расширенной программой разбиения на слои PolyJet. ПРИМЕЧАНИЕ: для того чтобы этот выбор был доступен, принтер должен находиться в режиме ожидания.
  • Новый параметр печати PolyJet для постобработки позволяет добавить тонкий слой прозрачного материал для полировки. Полировка прозрачного слоя позволяет создать модель с гладкой поверхностью и высококачественными цветами и текстурами.
  • Теперь можно предварительно просмотреть и создать путевой документ в формате PDF, содержащий замечания производителя и снимки экрана моделей для текущего активного лотка.
GrabCAD Print версии 1.36, ноябрь 2019
Номер сборки 1.36.17.57117 выпуск 20 ноябрь 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.36.
  • Теперь поддерживается новый принтер J750™ Digital Anatomy™ 3D, который предварительно запрограммирован рядом анатомических приложений, разработанных в сотрудничестве с производителями медицинского оборудования, исследовательскими учреждениями мирового класса, больницами и медицинским персоналом. Благодаря точности, реалистичности и функциональности вы можете достичь тактильной реалистичности, а также поведения и размеров реальной вещи. Узнайте больше о цифровом анатомическом устройстве J750 Digital Anatomy 3D Printer здесь.
  • Новые принтеры J850 и J835 теперь поддерживаются. Дизайн и творческая реализация не имеют границ. Теперь с Stratasys J850/J835 то же самое относится и к прототипам. Наша прошедшая проверку и испытания технология упрощает весь процесс проектирования, оптимизируя рабочие процессы, поэтому вы можете уделять больше времени вопросам, связанным с созданием, совершенствованием и проектированием наилучшего продукта. Узнайте больше о Stratasys J850 здесь.
  • Выбранные модели теперь могут быть сгруппированы с помощью новой кнопки в верхней части панели проекта или команды правой кнопки мыши. Когда создается новая группа, она свернется и скроет существующую сборку. Для новой группы можно установить в собранный или разобранный вид. Из оригинальной сборки могут быть созданы также и дополнительные группы.
  • В настройках расширенной программы разбиения на слои PolyJet Advanced Slicer появилась новая опция для отображения структуры сборки для файлов VRML и OBJ. Если эта опция включена, GrabCAD Print определяет геометрическую структуру файлов VRML или OBJ и отображает структуру в виде сборки тел на панели проекта. Каждое тело может быть разноцветным (то есть текстурированным, окрашенным в вершину, окрашенным в лицо или составленным из нескольких листов разного цвета) или однотонным (т. е. все листы в теле имеют один размытый цвет). Пользователь может изменить назначения материалов для любого однотонного тела в такой сборке.
  • При импорте файла SOLIDWORKS (.sldprt или .sldasm) атрибуты прозрачности, прикрепленные к телам SOLIDWORKS, автоматически преобразуются в альфа-значения на панели материалов PolyJet, если загружен прозрачный материал.
  • Лицензии на материалы для принтеров Stratasys и Fortus, для которых требуются лицензии, могут быть обновлены из GrabCAD Print. Обновление лицензии на материал требует, чтобы у пользователя были права локального администратора.
  • Панель проекта была изменена, чтобы улучшить удобство использования. Среди изменений переработанные значки, лучшее выравнивание, более ясная подсветка выделения, разворачиваемое меню вместо флажка для собранного/разобранного состояния и более четкая индикация состояния отображения/скрытия.
  • Касательный выбор граней теперь доступен в виде команды правой кнопки мыши, когда программа находится в режиме выбора граней. Это может быть полезно при добавлении замечаний производителя к цепочке поверхностей.
  • К телам и граням могут быть добавлены аннотации, известные как «Замечания производителя». Команда для добавления заметки доступна по нажатию правой кнопки мыши — добавляется выноска, которую можно активировать нажатием, чтобы была показана заметка и разрешено ее редактирование.
  • Новый материал VeroUltraClear для принтеров Stratasys J850 и Stratasys J835 3D. VeroUltraClear имитирует акрил, достигая 95 % пропускания света этого материала, и полезен для прототипов стекла, прозрачных полимеров или прозрачной упаковки. Узнайте больше о материале VeroUltraClear здесь.
  • ABS ESD7 теперь поддерживается на принтере Stratasys F370 для GrabCAD Print. ABS ESD7 — это инструментальный материал, разработанный для тех случаев применения, где актуальна чувствительность к статическому электричеству, для предотвращения разряда или притяжения к другим материалам, таким как порошки, пыль или мелкие частицы. Узнать больше о материале ABS ESD7 вы можете здесь.
GrabCAD Print версии 1.35, октябрь 2019
Номер сборки 1.35.21.56592 выпуск 24 октябрь 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.35.
  • Мы улучшили поведение как кнопки «Печать», так и списка принтеров, когда требуется обновление диспетчера заданий для вашего принтера PolyJet. Кнопка печати покажет всплывающее окно, и при нажатии на список принтеров вы попадете прямо на экран «Настройки», где можете выполнить модернизацию.
  • В разделе «Дополнительные параметры» в настройках лотка добавлен флажок для управления УФ-лампами для принтеров серии J. Если у вас возникли проблемы с передержкой на отпечатках, обратитесь к своему торговому посреднику или в службу технической поддержки Stratasys, чтобы узнать, может ли этот параметр помочь.
  • При печати с использованием цветов Pantone на вашем принтере серии J VeroBlackPlus требуется только для некоторых цветов. Раньше вся палитра цветов Pantone была бы отключена, если бы она не была загружена, а теперь отключены только определенные цвета. Pantone по-прежнему требует все три материала Vivid Vero и VeroPureWhite.
  • Операцию загрузки модели теперь можно отменить. Ранее, если вы допустили ошибку и выбрали неправильный файл, вам пришлось бы ждать его загрузки, прежде чем вы сможете удалить его. Теперь вы можете сразу отменить загрузку.
  • Когда вы применяете настройки к определенному лицу в Advanced FDM, вы теперь можете удалить их через контекстное меню. Ранее вам приходилось использовать команду «Отмена», чтобы отменить настройки лица.
  • Поддержка новых материалов FDM:
    • Antero 840CN03 теперь поддерживается на принтере Stratasys F900 для GrabCAD Print. Узнайте больше о новом материале Antero 840CN03 здесь.
    • Материал Diran 410MF07 теперь поддерживается на принтере Stratasys F370 для GrabCAD Print. Diran является идеальным материалом для инструментов. Узнайте больше о новом материале Diran 410MF07 здесь.
  • ТПУ 92А теперь поддерживает срез в 0.0070 дюйма (0.1778 мм) на принтере Stratasys F370. Качество печати улучшено для среза 0.0070 и  0.0100 дюйма (0.2540 мм). Программное обеспечение контроллера F123 необходимо обновить до версии 2.1, чтобы воспользоваться этими улучшениями.
  • Удаление журнала принтера теперь требует, чтобы у пользователя были права локального администратора.
GrabCAD Print версии 1.34, сентябрь 2019
Номер сборки 1.34.16.55783 выпуск 19 сентябрь 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.34.
  • Расширенная программа разбиения на слои, представленная как опция в 1.31, теперь включена по умолчанию. Это улучшило точность в оценках и позволяет использовать несколько функций, которые перечислены здесь. Ее можно отключить в меню «Настройки» > PolyJet, если вам нужно по какой-либо причине использовать старую программу разбиения на слои.
  • Теперь вы можете получить доступ к учебным пособиям GrabCAD и файлам примеров в меню справки программы GrabCAD Print, связанной с выбранным вами принтером. Наши инженеры по прикладным задачам постоянно добавляют новый контент, чтобы помочь вам лучше использовать свои устройства; контент будет доступен через меню справки.
  • С помощью переключателя на панели просмотра «Предварительный просмотр поддерживаемых поверхностей» вы можете быстро посмотреть, где будут сгенерирована подложка для ваших моделей. Эта функция была представлена для принтеров PolyJet в  1.24 и теперь доступна и для принтеров FDM. Это обеспечивает более быструю альтернативу предварительному просмотру фрагментов FDM, помогая подготовить лоток, поскольку показывает, как настройки ориентации и поддержки (например, угол наклона) влияют на поверхность печатаемого изделия.
  • Когда вы просматриваете текущее задание PolyJet в представлении расписания или в мобильном приложении GrabCAD Print, прогнозируемое время окончания теперь значительно точнее. Прогноз будет регулярно обновляться на протяжении всей работы, чтобы учесть паузы в печати и другие ошибки в первоначальной оценке.
  • Проверка опции задержки среза на панели настроек лотка PolyJet снизит вероятность появления углублений на модели. Опцию следует использовать только после консультации со службой технической поддержки Stratasys. Использование этой опции увеличит время печати задания.
  • Список материалов, отображаемых на панели «Параметры лотка» для принтеров PolyJet, теперь включает вспомогательные материалы.
  • GrabCAD Print теперь будет уведомлять вас об обновлениях для некоторых принтеров, таких как устройства серии F123 и J750. Они могут включать информацию о новых материалах, учебном контенте и др. Когда выбран один из этих принтеров и доступно обновление, в левом нижнем углу экрана вы увидите подарочную коробку.
GrabCAD Print версии 1.33, август 2019
Номер сборки 1.33.10.54793 выпуск 20 август 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.33.
  • На принтерах, которые поддерживаются расширенным FDM, некоторые дополнительные функции теперь доступны на вкладке «Параметры модели». К ним относятся плотность заполнения, угол заполнения и толщина корпуса, а при использовании файлов САПР — возможность превращения цилиндрического отверстия в самонесущее ромбовидное.
  • Подобно изменению, внесенному в панель настроек FDM в последнем обновлении, панель настроек PolyJet теперь разделена на параметры лотка и модели, чтобы освободить место для большей функциональности в будущих обновлениях.
  • Теперь вы можете экспортировать CMB без продувочной части или жертвенной башни. Это позволяет предотвратить печать нескольких деталей продувки при печати нескольких файлов CMB в задании. По умолчанию продувочная часть/жертвенная башня включена.
  • Для шаблонов принтеров Stratasys F900, Fortus 900mc и Fortus 400mc ABS теперь является материалом по умолчанию. Для живых принтеров материал будет продолжать использовать текущую конфигурацию по умолчанию. couldn't find what that means
  • Вниманию пользователей принтеров серии J750 и J735: расширенная программа разбиения на слои, представленная в версии 1.31, будет *ВКЛЮЧЕНА* по умолчанию в обновлении следующих месяцев, версии 1.34.
GrabCAD Print версии 1.32, июль 2019
Номер сборки 1.32.19.54065 выпуск 22 июль 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.32.
  • Панель «Параметры печати» для подготовки к печати FDM разделена на 3 панели: «Параметры лотка», «Параметры модели» и «Параметры подложки». Также были добавлены новые иконки.
  • Режим анализа теперь может восстанавливать файлы VRML и OBJ с цветами вершин, а также улучшено восстановление файлов с цветами граней и текстурами.
  • Пользователи J750 и J735 теперь могут печатать непрозрачные модели с использованием материалов Vivid и расширенной программы разбиения на слои. Снимите флажок «Полупрозрачный» на панели «Параметры печати», чтобы печатать тела с белым сердечником. В настоящее время данная функция работает только для нетекстурированных файлов сеток/сборок.
  • Проблемой для некоторых заданий Fortus и F123 было странное поведение продувочной части/жертвенной башни, что приводило к сбоям в сборке. Эта проблема была разрешена.
  • Если выбран материал Agilus 30 Clear, модель отображается на уровне прозрачности, связанном с заданным пользователем значением ползунка Shore A.
GrabCAD Print версии 1.31, июнь 2019
Номер сборки 1.31.52720.53058 выпуск 20 июнь 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.31.
  • Расширенный FDM, который был представлен в версии 1.24 для принтеров F900, F370 и Fortus, теперь доступен для F170 и F270. Расширенный FDM позволяет настраивать заполнение в различных секциях модели, используя фактическую геометрию CAD, а также изменять геометрию отверстия для печати. Узнайте больше здесь.
  • Расширенная программа разбиения на слои, которая теперь доступна в меню «Файл» > «Настройки» > PolyJet, предоставляет пользователям J750 и J735 целый ряд улучшений и новых функций:
    • цвета в палитре цветов, утвержденные Pantone®;
    • модели VRML с прозрачностью текстуры будут использовать прозрачный сердечник;
    • улучшенные оценки и точность печати для мелких объектов и текста;
    • пользовательские параметры поддержки, которые фиксируют эффект «тени поддержки» на вертикальных стенах с отверстиями;
    • пользовательский приоритет детали при перекрытии компонентов сборки;
    • полный контроль над размещением деталей на лотке.
  • Новая версия GrabCAD Print Server работает как служба Windows, она будет продолжать работать, даже если пользователь Windows вышел из системы. Кроме того, она совместима с Windows Server 2012 и может быть установлена вместе с версией GrabCAD Print для каждой машины. Это обновление не является автоматическим, вы должны загрузить новую версию здесь. Для получения справки по установке нажмите здесь.
  • Режим анализа теперь способен исправить ошибки сетки в текстурированных файлах VRML.
  • Сообщение об ошибке при попытке добавить модель из пакета САПР, который еще не поддерживается, например Inventor 2020, теперь будет более информативным, нежели «общий сбой».
  • Для принтеров FDM опоры создаются там, где угол поверхности детали падает ниже заданного значения, известного как самонесущий угол, и теперь это значение настраивается на панели «Параметры печати». Вы можете увеличить или уменьшить количество создаваемых носителей, а также восстановить значение по умолчанию, которое варьируется для разных принтеров и материалов.
  • При добавлении файла CAD или CMB, который не соответствует файлу или настройкам в текущем проекте GrabCAD Print, вместо ошибки возникает конфликт, новое предупреждение позволяет сохранить изменения и открыть новый проект.
GrabCAD Print версии 1.30, май 2019
Номер сборки 1.30.28.52238 выпуск 22 май 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.30.
  • Журнал принтера можно удалить на странице «Журнал принтера» приложения GrabCAD Print. Опция активируется пользователем; выбранная настройка активна только для данного сеанса GrabCAD. Принтеры должны бездействовать при удалении журнала, хотя они могут иметь задания в своей очереди.
  • Мы просмотрели переводы в GrabCAD Print и исправили ошибки в 6 местах.
GrabCAD Print версии 1.29, апрель 2019
Номер сборки 1.29.6.51061 выпуск 16 апрель 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.29.
  • Последние версии пакетов САПР теперь поддерживаются в GrabCAD Print. Среди них SOLIDWORKS 2019, Inventor 2019, Creo 5.0, NX 12.0 и другие. Узнать больше можно здесь.
  • Легкий доступ к принтерам с помощью новой панели принтера. В ней имеется возможность добавить принтеры в избранное, осуществлять расширенный поиск и фильтрацию и много других улучшений. Мы хотим услышать ваши отзывы о них! Включите опцию в меню «Файл» > «Настройки» > «GrabCAD Labs» и сообщите нам, что вы думаете.
  • Бета-версия новейшего экземпляра серии Stratasys F123 — модели F120, поддерживается GrabCAD Print. Читайте об этом здесь.
  • Теперь можно использовать материал модели в опорных конструкциях для печати FDM при выборе стилей поддержки SMART, Sparse или Box. Поскольку принтеру требуется несколько секунд для переключения между материалом модели и вспомогательным материалом, эта функция позволяет многим слоям задания использовать только материал модели, что экономит время на печать.
  • Модели Insight теперь можно отправлять в GrabCAD Print из Insight одним нажатием кнопки. Выбор значка «Создать задание в GrabCAD Print» на панели инструментов Insight создает файл CMB и передает его из Insight в GrabCAD Print, а затем автоматически выбирает правильный тип принтера.
GrabCAD Print версии 1.28, март 2019
Номер сборки 1.28.16.50383 выпуск 21 март 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.28.
  • Не хватает технологических средств или емкости для печати большего количества деталей? Перейдите в меню «Приложения» > «Сделать с помощью Stratasys Direct Manufacturing», чтобы перейти на домашнюю страницу SDM. (Только для заказчиков из США и Канады.)
  • Автоматическая ориентация теперь доступна во вкладке Advanced FDM. Как стандартные, так и объединенные тела можно ориентировать автоматически, чтобы минимизировать объем подложки и сократить время сборки.
  • Теперь поддерживаются OBJ-файлы с текстурами изображений. При печати на принтерах PolyJet файлы текстуры изображения, связанные с файлом OBJ, будут считаны и отображены, а результат объединения будет напечатан.
  • Исправлена проблема с качеством детали при использовании заполнения гексаграммой на принтерах серии F123. Для материалов F123 ASA и F123 ABS на высоте среза 0.005 дюйма (0.127 мм) и 0.007 дюйма (0.178 мм) плотность заполнения уменьшается, чтобы предотвратить переполнение.
  • Параметры печати, ориентации и масштабных панелей были обновлены для учета только моделей или тел в активном лотке.
  • Существовала ошибка в журнале принтера при экспорте из настольного приложения, где в поле «Длительность» отображалось 00:00:00 для всех заданий. Она была исправлена.
  • Приложение генерирует некоторые файлы во временном каталоге, ранее они накапливались со временем. Теперь они автоматически очищаются при закрытии приложения.
  • Некоторые пользователи сталкивались с ошибкой, при которой они не могли запустить GrabCAD Print из-за сообщения «Слишком много экземпляров…». Это вызывалось надстройкой GrabCAD Print для SOLIDWORKS, которая больше не поддерживается.
GrabCAD Print версии 1.27, февраль 2019
Номер сборки 1.27.17.49710 выпуск 25 февраль 2019.
Нажмите здесь, чтобы посмотреть видео об обновлении 1.27.
  • Заполнение переменной ширины, введенное в версии 1.24 для принтеров F123 и Fortus 900mc, теперь доступно на Fortus 380mc, 380mc CFE и 450mc. Для этой функции требуется версия  6.1 прошивки принтера (доступно с 13 март 2019). Следуйте данным инструкциям, чтобы обновить прошивку на вашем компьютере.
  • При импорте файла CMB для печати на принтере FDM правильный принтер будет выбран автоматически. Кроме того, теперь вы сможете вращать эту модель вокруг оси Z.
  • Определенные комбинации материалов недопустимы в задании на печать PolyJet, например Vero и VeroFlex, так же как использование только одного из двух материалов RGD для Digital ABS. Ранее, если в принтер была загружена неподдерживаемая комбинация материалов, тот отображал состояние «Ошибка» и печать была невозможна, даже если само задание не использовало неподдерживаемую комбинацию. Теперь пользователи смогут печатать свои задания независимо от того, какие материалы загружены в принтер в данный момент, если в самом задании не используется неподдерживаемая комбинация.
GrabCAD Print версии 1.26, январь 2019
Номер сборки 1.26.13.48725 выпуск 28 январь 2019.
  • Заполнение переменной ширины, введенное в GrabCAD Print 1.24 как часть панели «Настройки печати», теперь доступно в расширенном FDM.
  • Продувочная часть (устройства серии F123) и жертвенная башня (некоторые принтеры Fortus) автоматически размещаются в оптимальном месте на лотке, хотя их можно перемещать вручную. Теперь, когда вы это сделаете, они останутся в этом месте до тех пор, пока вы не воспользуетесь инструментом «Упорядочить лоток» или «Упорядочить проект». Вы также можете переместить только часть продувочной части/жертвенной башни, щелкнув по ней правой кнопкой мыши и выбрав «Разместить автоматически».
  • Сброс ориентации теперь доступен в GrabCAD Print и расширенном FDM. Выбор модели и затем функции сброса вернет модель в ориентацию, в которой она была первоначально добавлена в лоток.
  • Устранена проблема, которая блокировала установку GrabCAD Print в определенных ситуациях. Обратитесь по адресу print@grabcad.com, если у вас все еще возникают проблемы с установкой.
GrabCAD Print версии 1.25, декабрь 2018
Номер сборки 1.25.17.47934 выпуск 4 январь 2019.
  • Программа установки для всех пользователей, выпущенная для бета-тестирования в версии 1.16, теперь доступна для загрузки на print.grabcad.com. Помимо того, что она намного более стабильна, чем текущая программа установки для одного пользователя, она позволяет администраторам ИТ-систем развертывать ее в школах и на предприятиях. Для получения дополнительной информации и инструкций по переходу прочитайте нашу справочную статью.
  • Файлы OBJ и VRML с самопересечениями, проблемами водонепроницаемости/открытых граней и инвертированными нормалями теперь могут быть восстановлены GrabCAD Print перед печатью в технологии PolyJet. Чтобы попробовать такой способ, свяжитесь с print@grabcad.com.
  • Всплывающие подсказки на панели «Параметры печати» объясняют поведение заливки переменной ширины, стиля сборки детали, типа продувочной части или жертвенной башни, режима системы и материала первого слоя. Содержимое подсказки адаптируется для отображения информации, касающейся только доступных параметров действия.
GrabCAD Print версии 1.24, ноябрь 2018
Номер сборки 1.24.15.46944 выпуск 20 ноябрь 2018.
  • Улучшенная печать FDM GrabCAD предоставляет мощный, интуитивно понятный набор инструментов для печати деталей с требуемыми характеристиками путем автоматического управления атрибутами сборки FDM. Назначая атрибуты непосредственно геометрии вашего CAD-файла, вы можете указать области прочности и жесткости, контролировать заполнение, обеспечить достаточное количество материала вокруг отверстий со вставками и исключить наличие швов. Все необходимые траектории инструмента затем автоматически рассчитываются, без необходимости ручных манипуляций с отдельными слоями, что в конечном итоге сокращает время подготовки задания и повышает общее качество детали. Улучшенная печать FDM доступна для некоторых принтеров (F370, 380mc, 380mc CFE, 400mc, 450mc, 900mc, и F900), и активируется в разделе Файл > Настройки > FDM.
  • Теперь файлы OBJ могут быть добавлены в GrabCAD Print с цветами, связанным файлом .mtl и визуальными текстурами для печати на принтере PolyJet. Эта функция должна быть включена в меню «Файл» > «Настройки» > «GrabCAD Labs». Чтобы узнать, какие устройства поддерживаются, перейдите сюда.
  • Новые материалы, которые стали доступны, теперь поддерживаются в GrabCAD Print, включая VeroCyan Vivid, VeroFlex Cyan/Magenta/Yellow Vivid и Agilus 30 White на принтерах J750/J735, MedABS и Med615 на Connex3, Antero 800 NA на F900 и совершенно новый эластичный материал для устройств серии F123 под названием FDM TPU 92A. Обратите внимание, что новые материалы для Connex3 и J750/J735 требуют обновления встроенного программного обеспечения.
  • Когда выбран принтер PolyJet, новый режим отображения, доступный в верхнем ряду кнопок над средством просмотра 3D, позволит пользователю увидеть, где вспомогательный материал будет размещен на поверхности модели. Так можно определить границу для глянцевого покрытия.
  • Некоторые принтеры FDM теперь предлагают дополнительную настройку для использования заполнения переменной ширины для сборок внутренних деталей. Когда она установлена, траектории с переменной шириной автоматически размещаются везде, где остаются промежутки между траекториями по умолчанию, которые меньше ширины по умолчанию и больше минимальной ширины для данного размера наконечника. Эта функция поддерживается для устройств серий F123 и F900 и Fortus 900mc после установки последнего обновления прошивки (версий 1.8 и  3.26 соответственно или более поздних).
  • Обновлена панель сведений о задании в представлении расписания, чтобы визуально указывать, сколько материала оценивается для использования в выбранном задании. Подсказки уведомляют пользователей о том, сколько материала, по оценкам, останется в канистре или картридже после завершения задания. В принтерах FDM для первого задания в очереди будет указано, сколько материала находится в канистре/картридже при запуске задания.
  • На панели сведений о задании в представлении расписания теперь отображаются размеры наконечников и разрешение сборки, необходимые для задания для принтеров FDM. Это полезно для пользователей, чтобы узнать, что требуется для задания по сравнению с тем, что в данный момент загружено в принтер.
GrabCAD Print версии 1.23, октябрь 2018
Номер сборки 1.23.20.45529 выпуск 17 октябрь 2018.
  • Есть несколько улучшений в отчете истории.
    • Экспорт журнала заданий теперь доступен в форматах .XLSX и .CSV, по умолчанию используется формат .XLSX.
    • Чтобы отличить время печати от времени прогрева и других процессов, на которые оно было потрачено при выполнении задания, столбец «Продолжительность» теперь разделен на два раздела: «Общее время работы», которое представляет собой общее время между началом и окончанием выполнения задания, и «Общее время печати», которое исключает время, когда принтер был приостановлен или прогревался.
    • Новый столбец в представлении журнала показывает список деталей в задании. Количества одной и той же детали будут отображаться с (#) после имени детали. Например: HingePin(3). В настоящее время эта функция доступна только для принтеров FDM. (Примечание: на заданиях, напечатанных с помощью GrabCAD Print 1.22 и более ранних версий, здесь будут показаны зашифрованные имена деталей.)
    • Для принтеров FDM экспортированный журнал заданий теперь включает в себя два столбца для размеров подложки и наконечника модельного материала.
  • Детали можно распечатать с помощью ULTEM™ 9085 с разрешением .013” на принтере Fortus 450mc.
  • Модели отображаются в матовом или глянцевом виде в соответствии с заданными свойствами материала.
GrabCAD Print версии 1.22, сентябрь 2018
Номер сборки 1.22.24.44746 выпуск 26 сентябрь 2018.
  • Для отключения автоматических обновлений GrabCAD Print появилась новая опция. Вы все равно будете уведомлены, когда будет доступно обновление.
  • Для более точного импорта файлов САПР существует новая опция настроек, которая добавит больше треугольников в сетку, представляющую файл САПР. Однако это повлияет на производительность.
  • В этом выпуске мы исправили некоторые проблемы с подключением принтеров к GrabCAD Print (в том числе список принтеров, исчезающий после обновления) и проработали отчеты об ошибках, чтобы лучше решать потенциальные проблемы с подключением в будущем.
  • Модели теперь могут быть автоматически ориентированы для всех принтеров FDM — модели ориентируются для создания наименьшего количества вспомогательного материала.
  • Задания теперь можно печатать с использованием вспомогательного материала в качестве базового слоя на принтерах F123 для ABS и ASA при использовании разрешения .005’’. Это увеличивает риск проблем со сцеплением поддона, но упрощает удаление мелких деталей.
  • На принтерах FDM, где доступно заполнение с двойной плотностью, теперь можно использовать стиль заполнения гексаграммой. Это очень мощный и эффективный для построения растр.
  • Рабочее время и отложенный запуск печати могут привести к тому, что очередь в представлении расписания может показаться пустой, даже если это не так, поэтому есть новая кнопка, которая появляется, когда вам нужно прокрутить вправо, чтобы увидеть задания в очереди.
  • При щелчке на задании, которое в данный момент печатается, в режиме просмотра расписания вы увидите приблизительный объем материала, который останется после завершения задания. Для принтеров FDM вы также можете увидеть оценку уровней исходного материала для следующей работы.
  • Шов (где начинается и заканчивается траектория для принтеров FDM) теперь виден в режиме предварительного просмотра среза.
  • Части могут быть напечатаны с использованием материала Antero 800NA на принтере 450mc.
GrabCAD Print версии 1.20, июль 2018
Номер сборки 1.20.50.42688 выпуск 18 июль 2018.
  • Отложенный запуск для принтеров PolyJet теперь доступен! Когда принтер PolyJet находится в режиме ожидания, а очередь пуста, вы можете запланировать печать в определенное время нажатием кнопки «Печать». Обратите внимание, что эта функция пока недоступна, если вы удаленно подключены к принтеру через сервер печати GrabCAD.
  • В представлении «Расписание» теперь вы можете нажать кнопку на изображении камеры для принтеров серии F123, чтобы увеличить его до полного разрешения. Эта же функция доступна для изображения предварительного просмотра задания для всех принтеров.
  • После 3 месяцев тестирования системы Connex3 полностью поддерживаются GrabCAD Print. Для начала прочитайте руководство по настройке.
  • GrabCAD Print теперь поддерживает новый принтер Fortus 380mc Carbon Fiber Edition.
  • Ваш сеанс входа в систему для GrabCAD Print истекает только после 2 месяцев бездействия. Ранее этот срок составлял 1 неделю.
  • Если вы приобрели новые материалы Vivid Vero для принтера PolyJet, они теперь доступны для выбора в GrabCAD Print.
GrabCAD Print версии 1.19, июнь 2018
Номер сборки 1.19.14.41748 выпуск 15 июнь 2018.
  • Когда вы нажмете «Печать», чтобы отправить задание на принтер PolyJet, появится предупреждение, если на принтере недостаточно загруженного материала или если корзина для мусора заполнена.
  • Задания, содержащие большое количество дубликатов файлов, будут обрабатываться быстрее, чем раньше. Кроме того, время загрузки файлов для сложных или многомерных файлов VRML улучшилось на 60-80%.
  • Теперь имеется возможность экспортировать конфигурационный файл принтера независимо от того, подключены ли вы к принтеру локально или удаленно, посредством сервера печати GrabCAD Print.
  • GrabCAD Print теперь поддерживает новый тип системы Stratasys F900. Stratasys F900 является заменой системы Fortus 900mc и включает обновленную систему контроля влажности и общие системные усовершенствования.
GrabCAD Print версии 1.18, май 2018
Номер сборки 1.18.19.40241 выпуск 10 май 2018.
  • Несколько улучшений для пользователей PolyJet, в том числе:
    • новая функция копирования и вставки для параметров печати;
    • полосы прогресса для проверки, оценки и управления очередностью лотка;
    • повышена стабильность программ разбиения на слои для печати дубликатов тяжелых STL;
    • материалы Agilus теперь могут быть напечатаны с использованием материала SUP706B. Используйте эту комбинацию только в том случае, если вы получили новую формулу подложки (также известную как 706B).
  • Надстройка GrabCAD Print для SOLIDWORKS теперь поддерживается в SOLIDWORKS2018. После обновления до GrabCAD Print 1.18 измените свою установку в панели управления, чтобы установить надстройку.
GrabCAD Print версии 1.17, апрель 2018
Номер сборки 1.17.14.39209 выпуск 12 апрель 2018.
  • Системы Connex3 (в том числе Objet260, Objet250 и Objet500) вскоре будут поддерживаться, а принять участие в процессе бета-тестирования вы можете прямо сейчас! Кроме того, установите последнее обновление встроенного программного обеспечения, которое можно загрузить уже сейчас. Не нужно подписывать официальное соглашение о бета-тестировании, просто нажмите здесь для получения загрузочных ссылок и полных инструкций.
  • При оценке лотков PolyJet теперь отображается ход выполнения оценки в реальном времени.
  • Профили цвета и текстуры возвращаются к значениям по умолчанию по мере изменения материалов лотка для принтеров PolyJet, чтобы пользователи случайно не оставляли профиль, который не рекомендуется.
GrabCAD Print версии 1.16, март 2018
Номер сборки 1.16.29.38429 выпуск 20 март 2018.
  • Появилась совершенно новая программа установки GrabCAD Print «для каждого компьютера». Это позволит с легкостью установить GrabCAD Print на компьютеры в компьютерном классе, а системные администраторы смогут развернуть приложение на корпоративном уровне. Более подробно читайте здесь, а для запроса доступа отправьте сообщение по адресу print@grabcad.com.
  • Теперь поддерживаются последние версии пакетов САПР. В их состав входят SOLIDWORKS 2018, Creo 4.0, Inventor 2018 и другие. Полный список см. здесь.
  • В последнее обновление мы включили новую функцию, позволяющую синхронизировать параметры печати с текущей конфигурацией выбранного принтера. В этом обновлении мы сделали это поведение автоматическим — сразу после запуска приложения.
  • Материал, используемый в опорной сетке для принтеров PolyJet (обычно VeroPureWht) теперь указывается в результатах оценки вместо пункта «Прочее».
GrabCAD Print версии 1.15, февраль 2018
Номер сборки 1.15.13.37334 выпуск 19 февраль 2018.
  • Панель «Параметры печати» для принтеров FDM приобрела новый внешний вид. Если ваши настройки не соответствуют текущей конфигурации принтера, вы увидите соответствующий индикатор и одним щелчком сможете исправить все настройки. Кроме того, параметры любого вновь созданного лотка всегда будут соответствовать параметрам просматриваемого в данный момент лотка, чтобы ускорить подготовку к печати проектов с несколькими лотками.
  • В инструменте «Разместить» появился новый ползунок, управляющий флажком «Оптимизировать» для пользователей PolyJet. Управление касается оптимизации размещения для минимального времени печати либо для минимального использования вспомогательного материала.
  • ИСПРАВЛЕНО. Если режим расписания остается на экране в течение определенного времени, линия «Сейчас» остается на месте, а не исчезает постепенно.
GrabCAD Print версии 1.14, январь 2018
Номер сборки 1.14.20.36110 выпуск 17 январь 2018
  • На экране сведений на Панели принтера теперь отображаются одометры наконечников модельного и вспомогательного материалов, а также температуры камеры и головки для систем FDM.
  • Если система FDM имеет несколько отсеков для материала, новые значки на Панели принтера указывают, какие отсеки для материала в настоящий момент загружены в печатающие головки.
  • Если в задании содержатся материалы или выбраны наконечники, не соответствующие текущей конфигурации принтера, то при нажатии на кнопку печати появляется всплывающее окно с предупреждением.
  • Подробные, индивидуальные журналы заданий печати теперь можно загрузить в формате XML для принтеров Fortus 900mc. Перейдите в раздел Просмотр отчетов и нажмите кнопку «Загрузить» в столбце «Параметры».
  • GrabCAD Print теперь поддерживает принтер Stratasys J700 Dental.
  • ИСПРАВЛЕНО. В отчетах материалы всегда отображались в см³, независимо от ваших предпочтений. Эта проблема была устранена.
GrabCAD Print версии 1.13, декабрь 2017
Номер сборки 1.13.21.34870 выпуск 12 декабрь 2017
Номер сборки 1.13.23.35192 выпуск 19 декабрь 2017
  • Если у вас настроен GrabCAD Print Server, ранее вы могли пользоваться только некоторыми из функций удаленного доступа для систем PolyJet, такими как возможность подключения мобильного приложения и онлайн-отчеты. Теперь мы активировали последнюю функцию — отправку задания из GrabCAD Print на удаленный ПК.
  • Отдельные усовершенствования
    • В разделе «Просмотр отчетов» в GrabCAD Print теперь есть кнопка экспорта, которая работает как для систем FDM, так и для PolyJet.
    • Исправлена ошибка в просмотре отчетов, когда некоторые пользователи не могли выбрать принтер.
    • Исправлены некоторые проблемы с отображением онлайн-отчетов в Internet Explorer.
  • Больше не нужно нажимать кнопку «Просмотреть оценки». Когда результаты оценивания готовы, они отображаются автоматически.
  • Информация о задании в приложении GrabCAD Print для iOS теперь включает предполагаемое время завершения.
GrabCAD Print версии 1.12, ноябрь 2017
Номер сборки 1.12.26.33454 выпуск 13 ноябрь 2017
  • Теперь в настольном приложении GrabCAD Print можно просмотреть журнал заданий локальных принтеров в разделе «Просмотр отчетов». Этот очень поможет пользователям в автономном режиме, поскольку ранее этот отчет был доступен только на онлайн-странице отчетов после настройки GrabCAD Print Server. (Журналы для систем PolyJet, удаленных принтеров и экспорт CSV пока не поддерживаются.)
  • Компания Stratasys выпускает новые усовершенствованные материалы PolyJet, которые теперь поддерживаются приложением GrabCAD Print. Ознакомьтесь с более подробными сведениями о Agilus, VeroFlex и DABS2 Plus.
  • Приложение для Android иногда сообщает о невозможности обнаружить принтеры, если к учетной записи подключено большое их количество. Мы увеличили время ожидания, так что этого больше не должно происходить.
  • Небольшие практичные усовершенствования
    • Было устранено ограничение на размер отдельных файлов и лотков в 2 ГБ.
    • Переход в режим расписания больше не блокируется, когда выполняется другая операция.
GrabCAD Print версии 1.11, октябрь 2017
Номер сборки 1.11.17.31736 выпуск 11 октябрь 2017
  • Новое отображение лотка со следующими особенностями...
    • Реалистичная форма лотка и сетки для uPrint, Dimension, серии F123 и небольших систем Fortus.
    • Отображение сетки в сантиметрах или дюймах (в зависимости от выбранных единиц измерения) для крупных систем Fortus.
    • Контактные точки калибровки для соответствующих принтеров.
    • На принтере Fortus 900mc отображается контур лотка небольшого размера.
  • GrabCAD Print теперь можно использовать для добавления паузы к заданию печати FDM из предварительного просмотра слоя. Ранее эта функция была реализована только в Catalyst и Insight.
  • Теперь вы можете подготовить задания для ULTEM™ 9085 CG с помощью GrabCAD Print. Ранее этот материал был доступен только в Insight и Control Center. Пользователи также могут использовать наконечник T16A с принтером Fortus 900mc.
  • Исправлена ошибка, препятствовавшая пользователям запускать GrabCAD Print из SOLIDWORKS.
GrabCAD Print версии 1.10, сентябрь 2017
Номер сборки 1.10.19.30507 выпуск 13 сентябрь 2017
  • Теперь можно добавлять модели в GrabCAD Print непосредственно из проектов Workbench. Для получения дополнительных сведений об использовании Workbench совместно с Print нажмите сюда.
  • Если вы используете GrabCAD Print Server, вы и ваши коллеги могут получать по электронной почте уведомления о завершении заданий печати или при возникновении каких-либо проблем. Настройки можно изменить в вашем профиле GrabCAD.
  • Теперь можно открыть файл .PRINT двойным щелчком или перетаскиванием.
  • GrabCAD Print теперь поддерживает принтер Objet1000 Plus. См. руководство по установке.
  • Существовала проблема, заключающаяся в том, что файлы САПР, имеющие в имени файла или пути к нему символы, отличные от ASCII, нельзя было загрузить в GrabCAD Print. Эта проблема была устранена.
  • Была улучшена процедура импорта файлов САПР. Ранее на изогнутых поверхностях некоторых деталей могли отображаться небольшие шероховатости, теперь поверхности стали намного более гладкими.
  • Теперь в меню «Пуск» появился ярлык для Insight for GrabCAD Print. При его выборе будет открыта дополнительная версия Insight, которая ранее была доступна только из меню приложений в GrabCAD Print.
GrabCAD Print версии 1.9, август 2017
Номер сборки 1.9.27.701 выпуск 9 август 2017
  • Теперь к заданиям печати Fortus можно добавлять жертвенную башню. Это может улучшить качество швов и является обязательным при печати материалом Nylon 12 CF.
  • Материалы Nylon теперь доступны для принтеров Fortus в GrabCAD Print.
  • Задания, требующие внимания (например, если в ходе задания или до его начала закончился материал), будут отображаться в режиме расписания со значком. На значке режима расписания в левой части приложения в виде счетчика будет отображаться общее количество принтеров с предупреждениями.
  • Пользователи не смогут экспортировать файл CSV, содержащий журнал заданий принтеров с панели принтера (только FDM). Это позволяет автономным пользователям экспортировать данные журнала заданий, не активируя функцию отчетов.
  • В предыдущих версиях GrabCAD Print при первой установке требовались права системного администратора. В версии 1.9 установку может выполнить любой пользователь. Права системного администратора при этом не требуются (за исключением тех случаев, когда в программу установки включена надстройка SW).
GrabCAD Print версии 1.8, июль 2017
Номер сборки 1.8.16.652 выпуск 12 июль 2017
НОВЫЕ ФУНКЦИИ:
  • GrabCAD Print теперь поддерживает печать с помощью ULTEM™ 9085 и ULTEM™ 1010. Это также означает, что файлы CMB, подготовленные в Insight с этими материалами, теперь можно распечатать с помощью GrabCAD Print. Чтобы изменить параметры или использовать такие функции, как крепежные штифты или стабилизирующие стенки, можно использовать Insight из меню приложений. Вам все равно придется использовать Центр управления, чтобы добавить жертвенные башни. (ULTEM™ 9085 CG пока не поддерживается в GrabCAD Print).
  • Пользователи теперь могут выполнять оптимизированное упорядочение всего проекта (всех лотков сразу) на своих принтерах FDM. Это позволяет пользователям оптимально заполнять несколько лотков, размещая на них как можно больше деталей.
  • При добавлении деталей для принтеров FDM детали располагаются от центра лотка для улучшения качества печати.
  • Для принтеров серии F123 улучшена гладкость нижней поверхности как для поддерживаемых, так и для неподдерживаемых деталей конструкции.
ИСПРАВЛЕНИЕ ОШИБОК:
  • Специальные символы в имени пользователя Windows больше не вызывают проблем при установке соединения с принтером J750.
  • При просмотре задания PolyJet в расписании снова отображаются параметры «Режим печати» и «Слой напечатан».
  • Исправлена ошибка, связанная с тем, что преобразование детали приводило к частичной печати верхних слоев.
  • Исправлена ошибка, связанная с тем, что при переключении между определенными принтерами FDM импортированный файл CMB исчезал.
GrabCAD Print версии 1.7, июнь 2017
Номер сборки 1.7.28.633 выпуск 14 июнь 2017
  • Несколько импортированных файлов CMB теперь можно упорядочить не лотке. Раньше пользователи, работающие с несколькими файлами CMB, использовали в своем рабочем процессе Control Center. В целях улучшения производительности файлы CMB при просмотре модели представлены в упрощенном виде, однако фактическую форму можно увидеть при предварительном просмотре среза. Начните с пустого проекта, затем выберите в меню Файл > Импорт CMB...
  • Мы добавили в меню «Файл» пункт «Последние файлы». Вы можете открыть 5 последних файлов (любой формат САПР, CMB или OBJZF) и 5 последних проектов Print.
  • Теперь можно изменить порядок заданий в режиме расписания путем перетаскивания.
  • Надстройка SOLIDWORKS для GrabCAD Print теперь включена в программу установки GrabCAD Print. Надстройка SolidWorks позволяет подготовить файлы САПР к печати непосредственно в SOLIDWORKS. Инструкции по установке см. в меню приложений в GrabCAD Print.
  • Локальные задания печати теперь отображаются под вашим реальным именем, а не под именем профиля компьютера.
  • GrabCAD Print теперь поддерживает файлы формата .JT
  • ИСПРАВЛЕНО. Детали, содержащие символы, отличные от ascii (например, é или à), теперь могут быть напечатаны на J750.
  • ИСПРАВЛЕНО. Существовала проблема масштабирования деталей J750, когда материал Tango+ был загружен, но не использовался на лотке. Эта проблема устранена.
GrabCAD Print версии 1.6, май 2017
Номер сборки 1.6.19.601 выпуск 9 май 2017
  • Понятие о рабочем времени! После того как администратор компании включит эту функцию, в расписании отображение очереди принтеров будет настраиваться автоматически, чтобы задания печати начинались в рабочее время, а расписание было спрогнозировано более точно.
  • Используйте shift-щелчок, чтобы быстро выбрать несколько моделей в панели проектов. Благодаря этой функции и выбору с помощью рамки (реализован в 1.5) одновременное изменение настроек для нескольких моделей выполняется намного быстрее.
  • Задания можно легко переупорядочить путем щелчка и перетаскивания их в списке очереди на панели принтера.
  • Для ускорения работы программы просмотра в режиме «Просмотр модели» отображается «упрощенная» версия модели. Треугольники стали более заметны на изогнутых поверхностях. Это не влияет на качество печати. Чтобы увидеть, что именно будет отправлено на принтер, откройте предварительный просмотр среза или измените качество графики на «Высокое» в разделе «Установки системы»> «Настройки дисплея».
  • В принтерах серии F123 теперь имеется стиль печати «Блочный режим». Он удобен при печати больших, плотных, сплошных моделей для уменьшения скручивания деталей. Используется только при высоте среза 0.005” с материалами ABS, ASA или PC-ABS.
  • ИСПРАВЛЕНО. Для принтеров J750 исправлены некоторые проблемы, вызывавшие ошибки в ходе процесса печати. Не забудьте обновить GrabCAD Print и Job Manager, чтобы в полной мере воспользоваться этими исправлениями.
  • ИСПРАВЛЕНО: Пользователи, выбравшие метрические единицы измерения, теперь будут видеть высоту среза в выбранных единицах.
GrabCAD Print версии 1.5, апрель 2017
Номер сборки 1.5.15.549 выпуск 18 апрель 2017
  • Автономный режим, часть 2, уже здесь! Теперь при первой установке вы сможете пропустить регистрацию, если у вас нет подключения к Интернету. Это продолжение возможностей автономного режима, появившихся в GrabCAD Print 1.3, о которых вы можете прочитать здесь.
  • GrabCAD Print теперь поддерживает последние версии САПР-пакетов, в том числе SOLIDWORKS 2017, Inventor 2017, NX 11.0 и Solid Edge ST9. Полный список см. здесь.
  • Теперь лоткам можно присваивать пользовательские имена из режима предварительного просмотра лотка на панели проектов. Задания унаследуют это имя после нажатия на кнопку «Печать».
  • Все задания, отправленные в версии 1.5, содержат предварительный просмотр лотка в режиме расписания, как в онлайн-представлении, так и в настольном приложении. Этот параметр можно отключить в меню Установки системы > Конфиденциальность.
  • Выбор с помощью рамки в режиме просмотра модели облегчает одновременное изменение настроек печати для нескольких моделей. Щелкните левой кнопкой мыши и перетащите курсор. При перетаскивании слева направо выделяются только те модели , которые полностью оказываются в пределах рамки. При перетаскивании справа налево выделяются те модели, которые частично оказываются в пределах границ рамки.
  • Ярлыки просмотра и настройки перспективы теперь доступны нажатием на удобные кнопки в верхней части программы просмотра.
  • Теперь можно выбирать способ отображения единиц материала в мобильных приложениях, отчетах и онлайн-расписании. Настройки можно изменить здесь. (Мобильное приложение обновляется после входа в систему)
  • Для принтера J750 мы улучшили уведомление о необходимости обновления Job Manager.
  • Для принтеров серии F123 базовый слой будет выполнен из модельного материала с использованием ABS или ASA и высотой среза 0.005" для улучшения сцепления слоев на лотке.
  • Ряд изменений был внесен в основные процессы и функции печати, для улучшения качества печати принтеров серии Stratasys F123.
GrabCAD Print версии 1.4, март 2017
Номер сборки 1.4.20.531 выпуск 14 март 2017
НОВЫЕ ФУНКЦИИ:
  • GrabCAD Print теперь поддерживает все принтеры uPrint, Fortus и Dimension. Полный список см. здесь..
  • В 1.3 мы значительно усовершенствовали компоновку деталей при печати FDM: нужно лишь нажать «Разместить лоток» после оценки лотка. Теперь сделать это еще легче, благодаря флажку «Оптимизировать» в параметрах инструмента «Разместить». В некоторых случаях это позволяет разместить на лотке вдвое больше деталей, чем раньше!
  • Представляем пользовательские имена принтеров! Переименуйте принтер на панели параметров принтера, и ваше пользовательское название появится на рабочем столе, в Интернете и на мобильном устройстве для всех членов вашей учетной записи. Подробнее здесь.
  • После последнего обновления GrabCAD Print Server (версия  0.144.0318) принтер Stratasys J750 теперь поддерживается в мобильном приложении GrabCAD Print, а также в онлайн-расписании и отчетах. В ближайшее время ожидается поддержка печати в режиме удаленного доступа.
  • Кроме того, теперь к принтеру J750 можно подключиться в первый раз, используя параметр «Добавить сетевой принтер», если уже запущен GrabCAD PolyJet Job Manager.
  • Мы усовершенствовали способ отображения принтеров в списке «Мои принтеры» на панели принтера:
    • В случае потери соединения с принтером он не исчезнет из списка. Вместо этого его состояние будет отображаться как «Отсоединен».
    • «Автономные принтеры» теперь получили наименование «Шаблоны принтеров» и появляются в отдельном разделе под сетевыми принтерами.
  • Небольшие обновления параметров печати F370:
    • Печать PLA теперь называется черновым режимом.
    • В стиле удаляемой продувочной детали по умолчанию используется параметр «Полная высота».
ИСПРАВЛЕНИЕ ОШИБОК:
  • Отдельные пользователи J750 сообщали о проблемах с неправильной оценкой или ошибками печати, когда материал Tango+ был загружен, но не использовался на лотке. Эти проблемы были устранены.
  • В режиме расписания теперь отображается расчетное время и расход материала для будущих заданий J750.
  • Отдельные пользователи J750 сообщали о таинственной ошибке «ошибка 0». Проблема, вызывавшая ошибку печати, была исправлена, а сообщение об ошибке в случае возникновения этой проблемы теперь будет представлять собой осмысленный текст.
  • Исправлены две небольшие ошибки на панели «Ориентация»: одна — связанная с отрицательными десятичными значениями, другая — с кнопками + и -.
  • Отдельные пользователи F370 могли заметить, что удаляемая продувочная деталь содержит неверные слои: эта проблема была исправлена.
GrabCAD Print версии 1.3, февраль 2017
Номер сборки 1.3.25.508 выпуск 21 февраль 2017
Номер сборки 1.3.23.503 выпуск 7 февраль 2017
  • Представляем серию Stratasys F123! Наш последний принтер работает исключительно с GrabCAD Print. Подробнее здесь.
  • В нашей бета-версии GrabCAD Print отсутствует поддержка J750! Благодарим всех, кто участвовал в бета-программе. Если у вас принтер J750, ознакомьтесь с этим руководством, чтобы начать печать с помощью GrabCAD Print.
  • Теперь у нас есть надстройка для SOLIDWORKS, которая позволяет печатать файлы .SLDPRT непосредственно из вашей среды САПР. Прочтите о ней больше или загрузите ее здесь.
  • Поскольку многие пользователи спрашивали о возможности установки и непосредственного перехода к печати без необходимости входа в GrabCAD, мы представляем
    • Если соединение с Интернетом обрывается, GrabCAD Print позволяет продолжать работу с локальными принтерами.
    • Если большую часть времени вы работаете именно таким образом, можно отключить сообщения с предупреждениями, перейдя в автономный режим в меню Установки системы > Конфиденциальность.
    • При первом запуске приложения все равно необходимо войти в систему хотя бы один раз. Если у вас есть доступ к Интернету, но возникают проблемы со входом в систему, обратитесь к руководству по устранению неполадок.
    • Следующим этапом автономных возможностей будет «полностью автономное» решение, когда вы сможете пропустить этот первоначальный вход в систему. Эту функцию предполагается реализовать позднее в этом году.
  • Если вы думали, что инструмент «Разместить» работает значительно хуже, чем в приложениях Insight и Catalyst, в этом обновлении вы наверняка заметите значительные улучшения! Сначала нажмите «Оценить», чтобы разбить лоток на слои, а затем нажмите «Разместить лоток», и детали будут располагаться значительно ближе друг к другу.
  • Пользователи, участвовавшие в программе бета-тестирования J750, заметят в этом обновлении определенные улучшения:
    • Обновление Job Manager теперь можно выполнить с панели принтера в GrabCAD Print, так же как обновление встроенного программного обеспечения.
    • Исправлены проблемы с ползунком прозрачности на панели «Параметры печати»!
  • Приложение Insight теперь входит в состав GrabCAD Print, поэтому в системах F370 или Fortus вы можете использовать более сложные функции, такие как редактирование групп или траекторий. Подробнее здесь.
GrabCAD Print версии 1.2, январь 2017
Номер сборки 1.2.11.469 выпуск 24 январь 2017
Номер сборки 1.2.9.464 выпуск 16 январь 2017
  • Если вы пропустили это, отчеты находятся здесь! Просматривайте журнал заданий и сведения об использовании материалов прямо в веб-браузере.
  • Появилась новая системная настройка, позволяющая выбрать, нужно ли автоматически создавать новые лотки, когда на один лоток добавлено слишком много деталей.
  • Значки инструментов больше и отчетливее. Посмотрите на них: Инструменты.
  • Для инструмента «Поворот» теперь можно настроить число градусов поворота при щелчке, что облегчает достижение нужной ориентации.
  • Файлы VRML теперь включены в режим анализа, хотя для восстановления моделей без нарушений сопоставления текстур необходимо использовать другое программное обеспечение.
  • Исправлены некоторые проблемы, возникавшие в программе чтения файлов САПР, в частности с моделями кольцеобразной формы.
GrabCAD Print версии 1.1, декабрь 2016
Номер сборки 1.1.28.454 выпуск 16 декабрь 2016
  • Улучшение цветов и значков в основной навигации и на панели проектов.
  • Ранее появлялась ошибка, когда настройки вашего модуля не отображались в расписании, однако теперь она исправлена.
  • Другие небольшие исправления и улучшения.
GrabCAD Print версии 1.0, ноябрь 2016
Номер сборки 1.0.32.424 выпуск 15 ноябрь 2016
  • Больше принтеров! Теперь вы можете использовать GrabCAD Print с принтерами Fortus 380/450, Fortus 900 (ограниченная поддержка*) и Fortus 360/400. Поддержка принтера J750 в настоящее время проходит бета-тестирование. Для запроса доступа отправьте сообщение электронной почты по адресу print@grabcad.com.
  • Возможность отображения объема материалов в кубических сантиметрах. Выберите Файл > Установки системы > Средства управления блоками > Единицы измерения и выберите метрические единицы измерения.
  • Возможность импорта файлов .CMB.GZ.
  • Программа установки теперь по умолчанию устанавливает приложение на языке вашей операционной системы. Изменить язык можно, нажав кнопку «назад» в первом окне программы установки или в настройках системы.
  • Более интуитивное управление мышью по умолчанию для новых пользователей. Обновленную конфигурацию см. здесь. На существующих пользователей это не повлияет.
  • Стиль заполнения, высота среза и стиль вспомогательного материала теперь автоматически обновляются до рекомендуемых настроек для выбранной модели и вспомогательного материала.
  • Небольшие улучшения пользовательского интерфейса и исправления ошибок.
*Ограниченная поддержка означает, что базовая подготовка к печати поддерживается (аналогично «зеленому флажку» в Insight), однако некоторые расширенные функции, такие как использование жертвенной башни при печати ULTEM™ или Nylon 12, пока недоступны.
Примечания к выпускам старых версий читайте здесь.
Не удается найти то, что нужно? отправьте нам сообщение отправьте нам сообщение
