GrabCAD Print 发行说明
GrabCAD Print 版本 1.98,一月 2025
构建号 1.98.6.50666 发布于 21 一月 2025
  • Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
  • Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
  • Print Pro: The Assembly created while using the Split tool is now optional.
  • An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
  • For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
  • The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
  • When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
  • Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
  • The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
  • If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
GrabCAD Print 版本 1.97,十二月 2024
构建号 1.97.10.49657 发布于 17 十二月 2024
  • Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
  • Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
  • Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
  • Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
  • Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
  • F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
  • For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
  • The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
  • ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
  • Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
  • RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
  • A new material profile has been added to the Validated O2 collections.
    30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
    • Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
    • N3D-FR512 for FR-rating with higher elongation at break
    • FL300 from Forward AM for low Shore hardness elastomers in a clear color
    • MED414 for elastomeric applications requiring biocompatible capability such as ear bud
GrabCAD Print 版本 1.96,十一月 2024
构建号 1.96.8.49045 发布于 20 十一月 2024
  • Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
  • Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
  • Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
  • Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
  • GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
  • The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
  • Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
  • PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
  • ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
  • For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
  • Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
  • A new material profile has been added to both the Validated O2 and Open AM collections for P3.
  • New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
  • The History report in GrabCAD Print now includes material consumption per-job for P3.
GrabCAD Print 版本 1.95,十月 2024
构建号 1.95.11.47649 发布于 21 十月 2024
  • Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
  • A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
  • A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
  • A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
  • Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
  • The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
GrabCAD Print 版本 1.94,九月 2024
构建号 1.94.18.46867 发布于 18 九月 2024
  • New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
  • The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
  • When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
  • If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
  • A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
  • The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
  • The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
  • Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
  • Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
  • We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
    • Advanced Color Assignment: designed to produce more accurate and consistent shades
    • 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
    • 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
    • New TrueDent Clear Appliances: for fully translucent models and try-ins
    • Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
  • VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
  • When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
GrabCAD Print 版本 1.93,八月 2024
构建号 1.93.14.46038 发布于 29 八月 2024
  • Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
  • Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
  • The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
  • Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
  • VeroContactClear is now treated as a transparent material for all transparency-related features.
  • Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
  • When WSS is the selected support material, "No Grid" becomes the only available support grid type.
  • The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
  • A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
  • Additional dental applications for Origin printers are now supported.
GrabCAD Print 版本 1.92,七月 2024
构建号 1.92.17.44384 发布于 16 七月 2024
  • Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
  • Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
  • Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
  • Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
  • Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
  • Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
  • A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
  • Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
  • The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
  • For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
GrabCAD Print 版本 1.91,六月 2024
构建号 1.91.16.43213 发布于 22 六月 2024
  • Print Pro:一项新操作,将模型导出为 STL。选择单个组件、零件或主体,然后从右键菜单中将其导出为 STL 文件。导出的模型将包含在分析模式中进行的任何修复以及应用的任何标签。
  • Print Pro:Print Pro 具有在托盘上打印、在对象上打印和智能插入等功能,这些功能以前仅在 J7/J8 系列打印机上可用,现在可在 J3/J5 系列打印机上使用。
  • GrabCAD Print 现在支持导入 FBX (.fbx) 和 GLTF(.gltf、.glb)文件格式。
  • 碳纤维视觉打印选项是 ABS-CF10 的新切片高度,可产生更平滑的表面光洁度,特别适合于零件的视觉外观对其应用至关重要的场合。切片高度(0.0050 英寸,0.1270 毫米)适用于使用 T14H 打印头的 F123 和 F123CR 系列打印机(需要固件版本 2.7)。
  • OpenAM 现在已支持 Stratasys F900 打印机。使用 OpenAM™ 调整材料、编译材料并将其分发到 GrabCAD Print 和 F900 打印机时,将创建材料包。可以调整 Stratasys 首选材料和经过验证的材料以及第三方的公开材料并包含在包中(需要打印机固件版本 4.23)。
  • VICTREX AM™ 200 已添加到 Fortus 450mc 和 Stratasys F900 打印机的经过验证的材料组合中。VICTREX AM™ 200 是一种高强度、高机械性能的 PEEK 基聚合物,具有耐高温、耐腐蚀和耐化学腐蚀的特性。VICTREX AM™ 200 支持使用 T14F 喷嘴以 0.0100 英寸(0.2540 毫米)的切片高度进行打印,同时支持可分离支撑 (SUP4000B) 和可溶性支撑(SR-100 支撑)(需要固件版本 6.9)。
  • 更新了 Nylon 12 CF 材料的收缩行为。当托盘上的材料为 Nylon 12 CF,并且托盘同时包含稀疏填充和实心填充模型时,将使用实心填充部���的 Z 轴收缩率。系统会通过消息通知用户这一变化。如果托盘上所有模型均切换为实心填充或稀疏填充,将采用所选填充样式对应的 Z 轴收缩率。
  • GrabCAD Print 支持通过 IPv6 地址与 Stratasys F123 系列打印机(不包括 Stratasys F770,它需要固件版本 2.7)通信。
  • J5 DentaJet™ XL 配备 4 公斤材料盒,是 DentaJet 系列的创新之作。这款打印机专为大规模生产设计,可满足牙齿矫正器制造商、冠桥模型和种植体的打印需求,提供无与伦比的精度。它是大规模制作完美产品的出色解决方案,同时还提供了能革新工作流程且兼具成本效益的解决方案。
  • J5 数字解剖打印机可在 J5 平台上打印独特的数字解剖材料,包括 TissueMatrix、BoneMatrix、GelMatrix 和 RadioMatrix。提供多种解剖预设,可打印出生物力学特性与人体组织相似的解剖模型。如需了解更多信息,请点击此处
  • 现在,您可以选择输入颜色配置文件,用于在 PolyJet 上打印颜色模型。在“托盘设置”>“高级”下,选择 sRGB(默认)或者新的 Adobe RGB 1998 配置文件。Adobe 配置文件提供更饱和的颜色(绿色/黄色/红色),我们建议使用饱和度较高的显示器,这样可以更好地了解打印结果。
  • 以前,J3/5 系列打印机的支撑网格样式是锁定的,现在可以更改了。注意:如果打印机装有 TrueDent 材料,则它会保持锁定状态。
  • 对于适用的 PolyJet 打印机,现在可以在 UV LED 配方面板上执行以下操作:
    • 保存私人配方的更改
    • 将配方(SSYS 或私人)保存为新的私人配方
    • 重命名私人配方
    • 删除私人配方
  • SAF 的 3D 嵌套设置用户界面现在支持聚丙烯 (PP) 材料。
  • 验证过程现在会报告发生软碰撞的物体之间的距离,让用户决定是否可以继续打印。
  • 对于 P3 打印,您现在可以定义在开始新项目时自动选择的默认材料和支撑配置文件。
  • 对于 P3 打印,当您修改特定模型的支撑时,项目面板中该模型旁边会显示一个警告图标,并带有工具提示“模型的支撑参数与托盘默认值不同”。
  • 对于 P3 打印,当所有选定的模型具有相同的支撑配置文件时,只需按一下按钮即可自动生成它们的锚点和/或支撑结构。
GrabCAD Print 版本 1.90,五月 2024
构建号 1.90.16.41968 发布于 22 五月 2024
  • Print Pro:当选择托盘上的 STL 文件时,右键单击菜单上会出现一个新操作“拆分”。拆分将具有多个外壳的 STL 文件转换为具有多个主体的组件。然后可以将模型设置应用于每个主体。如果仅识别出一个外壳,则模型不会更改。
  • Print Pro:可以选择 Allerta Stencil 字体用于标签。要选择此字体,请展开标签下拉菜单并选择 Allerta Stencil。Atkinson Hyperlegible 字体仍为默认字体。
  • Print Pro:现在,组件名称模型属性可以包含在标签模板中。组件名称具有与零件名称相同的修饰符(从开始/结束、跳过和长度开始均相同)。当没有组件结构时,组件名称和零件名称的行为相同。
  • Print Pro:所有 J 系列打印机均可使用“支撑即材料”这一 PolyJet 设置,通过打印双光泽和哑光表面,您可以在设计上创造具有纹理的表面。
  • 在视图工具栏中添加了新视图。除了以着色方式显示模型的标准模式外,新增了线框模式和线框着色模式,分别以透明或着色线框网格的形式展示模型。新视图与“预览受支持的表面”不兼容。
  • GrabCAD Labs 添加了不使用支撑结构在 FDM 中打印的选项。打开该功能(文件 > 首选项 > GrabCAD Labs)后,您会在“支撑设置”面板中找到“无支撑”这一支撑样式选项。模型将使用基座打印,但没有其他支撑结构。
  • 当存在全高牺牲塔时模型无法重新定位的问题已得到解决。
  • 对于 SAF 打印,您现在可以选择子嵌套,在包装的定义区域中创建嵌套,并控制 X、Y、Z 尺寸以及从包装的任意选定角落指定区域原点的 X、Y、Z 位置
  • SAF 标签的最小文本大小已减小至 10 pt。
  • 对于 P3 打印,手动添加或移动的锚点将以与自动生成的锚点不同的颜色显示。
GrabCAD Print 版本 1.89,四月 2024
构建号 1.89.16.40685 发布于 16 四月 2024
  • 在 GrabCAD Print 中的新“按需零件”模式下,从 Stratasys Direct 获取报价并订购零件。此服务适用于一系列 FDM 材料,并支持美国境内配送。
    解决了 FDM 打印的一个问题,即:带有稳定器的模型生成的边界框大于所需的范围,从而导致其超出构建体积。
    • 保存私人配方的更改
    • 重命名私人配方
    • 删除私人配方
  • 全新时尚功能:在服装上打印。简化的界面兼容全新创新的服装托盘直接打印套件,设计师可借此将复杂的 3D 元素直接融入成品服装中。
  • H350 嵌套面板中一个名为“已选择填充”的新按钮,它允许您在包中放入尽可能多的单个零件的重复项。
  • 对于 P3 打印,一旦所有模型共享相同的支撑配置文件,您现在可以在一次操作中为多个模型生成锚点和/或支撑。
  • 对于 P3 打印,某些材料(主要是弹性体)在生成高支架时需要额外的支撑加固。您可以控制每个支撑轮廓、每个托盘或每个特定模型的加固类型。SSYS 弹性轮廓已修改为设置此选项。
  • 对于 P3 打印,材料定义提供了每种材料的默认排列参数:模型之间的间隙和距打印边界的间隙。OpenAM 用户可以为他们自己的材料修改这些值。任何用户都可以修改每个托盘的这些参数(通过排列面板)。
GrabCAD Print 版本 1.88,三月 2024
构建号 1.88.14.39413 发布于 19 三月 2024
  • Print Pro:GrabCAD Print Pro 现在包含 PolyJet 的功能!这些功能以前只能通过 PolyJet 研究包获得…
      • 直接在托盘上打印(仅限 J7/8 系列)– 可允许在玻璃或碳纤维等材料上打印,在零件底部形成理想的表面效果,无需对底部进行后处理。
      • 空气即材料(仅限 J7/8 系列)– 可允许使用空气代替树脂,从而显著减轻零件重量,可节省高达 30% 的材料。
      • 智能插入™(仅限 J7/8 系列)– 可允许将各种功能/装饰元素直接嵌入到打印件中。
      • 在对象上打印(仅限 J7/8 系列)– 通过在多种基板上直接打印到物体上,实现模型定制和个性化。
      • 体素打印应用程序(仅限 J7/8 系列)– 用于打印由其他软件定义的切片数据的工具,可允许控制模型的每个细节,包括体素级别的颜色、透明度和邵氏硬度。
    • …其他新功能…
      • 支撑即材料(仅限 J750 和 J850 Prime)– 通过打印光面和哑光表面,可在设计上创建纹理效果。
      • 液体即材料(仅限 J7/8 系列)– 可允许创建空腔,例如微流体结构、空心管、液压零件等。
      • 高速模式(仅限 J55)– 使用 2 材料时,保持相同的图层厚度,但以两倍的速度运行。
    • …以及 Print Pro 中已经提供的 FDM 和 SAF 的一些功能:
      • 标签
      • 厚度分析
      • 组装/分解
      • 第 3 方插件
  • Print Pro:导出的估算结果现在使用 hh:mm 时间格式,以便于纳入计算。
  • GrabCAD Print 现在支持以下 CAD 版本:
    • 固体工程 2024
    • Inventor 2024
    • NX 2306 系列
    • 实心边缘 2024
    • .X_T 36
    • .JT 10.9
  • 数字材料 (DM) 由 Agilus CMY 和 VeroUltraWhite、VeroPureWhite 或 VeroClear 混合而成,现在可在所有 J7/8 系列打印机上使用所有打印模式打印这些材料。DM 名称带有前缀 FLXAC。
GrabCAD Print 版本 1.87,二月 2024
构建号 1.87.18.38549 发布于 28 二月 2024
  • Print Pro:Pro 项目的估算结果现在包括“托盘/嵌套摘要”和“构建报告”(每个零件)选项卡中的成本估算。成本费率可在估算结果窗口的新选项卡上或从“打印机设置”中配置。
  • “截面视图”已添加到查看器顶部的控制条中。通过该视图,您可以查看模型中可能被遮挡的特征,并可与测量工具或 Origin 的支撑生成工具结合使用。启用“截面视图”后,您可以通过下面的按钮选择剖切平面和方向,也可以使用拖动手柄以其他角度进行剖切。
  • 现在,您可以选择估计结果窗口中的文本,并使用 Ctrl+C 将其复制到剪贴板。
  • 位置工具之前仅适用于 PolyJet 和 Print Pro 项目,现在适用于 Print Standard 中的所有技术。
  • F123 系列打印机的“加厚薄壁”默认设置已更改为“关闭”。
  • 修复了零件外壳轮廓和某些情况下相邻填充物无法生成的问题。
  • Stratasys F3300 是一款新型大幅面工业 FDM 打印机,现可在 GrabCAD Print 中进行选择。单击此处了解 Stratasys F3300 的功能和性能,或从打印机模板列表中选择它,以查看可用材料和设置。
  • PolyJet 支持可视化功能,位于查看器顶部的视图控制条中,通过以蓝色而不是棋盘格图案显示支撑区域,提高了可视性。
  • 如果选择此选项,零件会定位在屏幕上显示的托盘实际位置,而不优化打印过程。使用“绝对位置”时,小零件的打印质量可能会受到影响。
  • 在 1.83 更新中为其他技术添加的测量工具现在可用于 PolyJet 打印准备。
  • 对于 SAF 项目,现在可以使用功能强大的动态版本“构建报告”。从估算结果中选择“构建报告”,然后从右上角的导出下拉菜单中选择“HTML”。生成的文件可以在任何网络浏览器中打开,其中包含嵌套和每个零件的估算,以及嵌套和每个零件的交互式 3D 预览,显示其在嵌套中的位置。此外,还提供了一个搜索工具,可帮助您按名称查找特定零件。
  • 现在可以预览 Sinter Box 的标签,因此可以清楚知道标签是否适合可用空间。
  • 对于 P3 项目,妨碍接受 Z 补偿值的错误现已修复。请注意,仍然有一条规则规定 Z 补偿值不能超过支撑零件渗透值。
  • For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
    • 岛的支撑半径:将获得额外锚点的岛的首个证据周围的半径。
    • 岛的内部间隔:这些额外锚点之间的间距。
  • Additional updates for P3 support parameters:
    • 对于工业模型,最大根部直径从 10mm 增加到 30mm。
    • 对于牙科模型,零件渗透可以是 0。
GrabCAD Print 版本 1.86,一月 2024
构建号 1.86.24.37111 发布于 29 一月 2024
  • 修复了 FDM 工具路径计算导致大部件超出构建体积或小部件相互干扰的问题。
  • 3D 查看器已针对 PolyJet 打印准备进行了更新。此更新是即将推出的功能所必需的,但目前您应该不会注意到任何变化。但是,如果需要,您可以在“文件”>“首选项”>“PolyJet”中切换回旧查看器。
  • 现在,任何拥有 J 系列打印机的用户都可以导入使用 GrabCAD Voxel Print 应用创建的文件(.gcvf 文件)。使用 Voxel Print 应用创建 .gcvf 文件仍需要许可证,但现在每个人都可以导入这些文件。
  • 在高混合打印模式下使用少于 7 个模型材料的选项(通过对其他通道使用清洁材料)已扩展为包括高质量打印模式。
  • 面向 J5 DentaJet 用户的三项更新
    • 当您选择了配置有 TrueDent 材料的 J5 DentaJet 打印机时,系统会显示 TrueDent 材料的使用说明。
    • 为了提升用户体验,TrueDent 打印的“模型设置”面板已经过修改。可轻松选择牙龈和牙齿色调的收藏材料和默认材料。
    • J5 DentaJet 用户现在可以使用 Exocad Model Creator 实现从口内扫描到全彩色打印模型的端到端工作流程。GrabCAD Print 中的新颜色配置文件允许与 Exocad 进行颜色匹配。
  • Origin 打印的固化过程可能会导致多余的材料堆积在朝下的表面上,这称为过度固化。名为 Z 补偿的新参数通过向上偏移这些表面来解决此问题。
  • 对于 Origin Dental 用户,“过滤腔体内的支撑”选项将显示一条新的警告消息,提醒您某些必要的支撑可能已被移除。
  • 当 P2P 支柱由于长度或高度限制而不可行时,支撑生成将自动使用 P2P 脚手架。
GrabCAD Print 版本 1.85,十二月 2023
构建号 1.85.10.35841 发布于 4 一月 2024
  • Print Pro: 标签的两项更新
    • 现在可以通过标签面板中的一个按钮一键删除所有标签。
    • 创建模板标签时,现在可以预览部件上的标签文本,在调整大小、位置和旋转时提供视觉帮助。
  • J8 系列打印机现在可以在 7 材料打印模式下使用清洁液盒替代模型材料。使用此功能,您可以在最多 4 个打印通道中装入清洁液并继续打印,这样您就可以在更换材料的同时打印。
  • 您现在可以将打印作业发送到装有 2 材料的 Connex3 打印机,即所谓的 DM2 模式。(注意:需要在“文件”>“首选项”>“PolyJet”中禁用“高级切片机”)
  • 在 HQ 模式下打印时使用一盏紫外线灯的选项已成为 J850 Prime、J850 Prime Fabrix、J850 Pro、J835 和 J750 的默认设置。
  • 与其他模型或支撑材料混合时,解剖材料的比例是有限的。这些限制的验证已添加到每一步的噪声调节过程中。SUP706 的限制已修复:与 BoneMatrix、任何 Agilus30 材料或任何 Vero 材料混合时,外层中的 SUP706 必须小于 50%。
  • 时尚选项改进
    • 无需打开配方面板即可选择紫外线 LED 配方。
    • 通过“管理配方”按钮可以打开“配方”面板。
    • 总切片包括定义的粘附层。
  • 在 Origin 打印机的锚点和支撑生成过程的进度条中添加了“取消”按钮。如果锚点或支撑结构已生成,会被删除。
  • 在“锚点”和“支撑”面板中修改参数时,支撑配置文件名称现在会在支撑配置文件名称旁边显示星号 (*),以指示未保存的更改。使用“重置为配置文件”按钮可重置修改后的参数。
GrabCAD Print 版本 1.84,十一月 2023
构建号 1.84.12.35248 发布于 30 十一月 2023
  • Print Pro:引入间隙分析!厚度分析工具已得到增强,允许用户检测模型中低于打印机分辨率的间隙(例如口袋)。这可以在“厚度分析”面板的新“间隙”选项卡上找到。
  • Print Pro:精度中心 WAM 功能现在可以提供更高的精度改进,允许用户迭代以提高(甚至是极具挑战性)项目的质量。
  • 在 1.75 中为 Fortus 450mc 引入的验证材料 1.75 现在可用于 F900。这些材料在用于编程和打印作业之前,会使用基本的可靠性测试进行验证。要使用验证材料,F900 必须安装固件版本 4.22,并且这些材料仅适用于 0.0100 英寸/0.2540 毫米切片高度。
  • 对于 PolyJet,Fashion 打印机的粘合层已得到改进。以前,当打印带粘合层的哑光模型时,粘合层会被打印在模型及其周围支撑的下方。当支撑被移除时,粘合层可能仍保留在模型周围。最近更新后,仅在模型下方添加粘合层,避免了移除支撑后粘合层残留的问题。
  • 我们解决了 PolyJet Objet30V3 和 V5 打印机的问题,即更新 GrabCAD Print 1.83 后打印作业开始失败。
  • 对于 SAF,“3D 嵌套”面板现在以 X/Y 形式报告其他进度信息,以便用户可以清楚地看到所选的模型数量以及嵌套中当前包含的模型数量。
  • 对于 P3,引入了参数自动校正功能。每当用户为有效范围内的参数输入无效值时,该值现在会自动更正为最接近的有效值,并为自动更正的有效范围显示工具提示。
GrabCAD Print 版本 1.83,十月 2023
构建号 1.83.10.33362 发布于 24 十月 2023
  • Print Pro:构建报告现在会预估使用清除零件或牺牲塔的打印机的已清除材料。
  • Print Pro:构建报告现在以 Excel 或 CSV 导出的一部分提供各个部件所需的预估打印时间。
  • Print Pro:将预估内容导出到 Excel 文件时,构建报告和托盘摘要现在以单独的工作表包含在同一个文档内。
  • 隆重推出测量工具!现在,您可以测量点到点、平面到点或点到平面的距离,并且可以选择捕捉到顶点。FDM、SAF 和 P3 项目支持测量工具。
  • 现在,在“项目面板”或“模型查看器”中,突出显示模型并选择鼠标右键菜单上的“重命名”命令,即可重命名零件、组件和主体。
  • 右键单击菜单中添加了新的选择选项。现在,“全选”可以应用于整个项目或仅应用于当前托盘。新选项“反选”可将选择翻转到当前托盘或整个项目上未选择的零件。
  • 对于 H350 打印,视图控制条中提供了两个新选项:
    • “着色”为嵌套中的零件添加随机颜色,以更好地可视化密度包装。
    • “图层线可视化”显示向上或向下表面上的线条,其中图层可能在最终打印中可见。
  • 对于 P3,添加了一个新工具,用于在 GrabCAD Print 中生成支撑结构。现在,您可以使用 GrabCAD Print 充分准备 CAD 文件并发送供打印,无需额外的软件。
GrabCAD Print 版本 1.82,九月 2023
构建号 1.82.7.32244 发布于 19 九月 2023
  • Print Pro:分析模式下有一项名为“厚度分析”的新功能,允许用户快速确定其零件是否包含低于打印机分辨率的几何形状。分辨率默认根据打印机技术而设置,但用户可以设置自己的值。显示可以由两部分组成,红色表示失败/绿色表示通过,也可以是连续的黄红渐变色。光标还提供“探针”来显示零件上任意点的特定值。
  • Print Pro:现在可以对 FDM 3D Array 命令使用更小的负间距值,从而使托盘上的零件排列更加紧密。
  • 现在可以隐藏托盘,从而更好地查看紧密包装的零件的底面。
  • 与 Stratasys H350、Fortus 450mc、Stratasys F900 和 Fortus 900mc 打印机通信时,GrabCAD Print 支持 IPv6 地址。Fortus 450mc 的 IPv6 需要固件版本 6.8。Stratasys F900 和 Fortus 900mc 需要固件版本 4.22,才能支持 IPv6。
  • 隆重推出 TrueDent™,这是一种经 FDA 批准的(II 类)树脂,专为在 J5 DentaJet 平台上进行义齿、临时牙冠和牙桥的 3D 打印而开发。它可以在单个混合托盘上批量生产高度美观、整体式、多色的牙科器具。虽然 TrueDent™ 目前在特定地区推出,但它为寻求提高生产力和出色成果的牙科实验室提供了有前景的解决方案。
  • 在版本 1.81 中,添加了用于激活/停用高级纹理工艺的首选项。该复选框已移至“托盘设置”(在“高级”部分下),允许用户确定每个作业的值。J55 Prime 和 J850 Prime 用于打印带纹理的重型托盘,因此会默认取消选中该复选框。
  • DAP 打印机上的结构性心脏模型中添加了凝胶涂层(如血管模型中所定义)。
  • 对于 SAF 打印,烧结箱现在支持用户定义的标签,构成烧结箱几何形状,让您能够分解蛋糕以了解烧结箱中包含哪些零件。长标签会自动与烧结箱的最长轴对齐。
  • 对于 SAF 打印,如果具体选定零件需要额外空间以改进热管理,可以覆盖嵌套的最小间距值。
  • 对于 SAF 打印,您现在可以选择嵌套操作是添加到嵌套的现有内容,还是清除嵌套并重新开始。
  • 对于 P3 打印,“适合托盘”选项应启动方向改进,逐步旋转模型,直到适合打印区域。
  • 对于 P3 打印,所有牙科支撑配置文件都应具有新参数,用于过滤出 90° 方向夹板模型凹版上的锚点。
  • 对于 P3 打印,创建锚点时,可支撑区域将根据所选支撑配置文件中指定的自支撑角度进行着色。
  • 拥有 P3 On-Prem 云的 GrabCAD Print 用户可以在非管理员帐户下运行 GrabCAD Print。
GrabCAD Print 版本 1.81,八月 2023
构建号 1.81.9.30921 发布于 16 八月 2023
  • Print Pro:精度中心现在为原始视图和验证视图使用选项卡。“原始”选项卡显示原始打印零件的精度结果(热图和打印精度分数 [PAS])。“验证”选项卡允许用户上传 WAM 打印的扫描件,以准确查看精度提高程度。它显示新 PAS 与原始分数的比较,并且显示新直方图,提供与原始分数叠加的灰色轮廓,以便您轻松了解特定误差带的减少情况。
  • Print Pro: 用于在水平表面获得更好结果的新精度中心 WAM 控件:
    • “保留”(现在是默认设置)仅允许对水平表面进行统一的垂直调整,以保持美观并避免添加轮廓线,让水平区域光滑平整。
    • “固定”防止水平表面发生任何移动。
    • “自由调整”允许水平表面自由变形,包括在水平表面内添加轮廓,在贴合性优先于美观的区域实现更大精度。
  • Print Pro:精度中心中添加了所选扫描文件的快速预览,以帮助用户选择正确的扫描文件。
  • Print Pro:精度中心直方图的 Y 轴现在显示每个误差级别条占总零件的百分比,因此您现在可以看到零件的百分比高于或低于所选容差或者在所选容差范围内。
  • Print Pro:在精度中心中比较扫描时,当您将鼠标移到比较结果上时,现在会动态显示打印和扫描部分的局部差异(例如,该点的错误与设计)。
  • 对于拥有 Local Hub 和 OpenAM 许可证的 P3 用户,上传“每层设置”文件时的问题已修复。
  • 对于 P3 用户,“模型插入设置”下的首选项“当模型不适合当前平台时自动创建托盘”现在适用于 P3 打印机,就像在其他平台上一样。
GrabCAD Print 版本 1.80,七月 2023
构建号 1.80.10.30098 发布于 19 七月 2023
  • GrabCAD Print 支持 2023 版本的 CAD 文件,如下所示:SOLIDWORKS 2023、SolidEdge 2023、Siemens NX 2212。
  • Print Pro:现在可以将临时文本标签添加到 FDM 零件(STL 和 CAD),它们可以是浮雕或凹雕,并且可以控制文本大小、深度和间距。此外,还可以创建可重复使用的标签模板,这些模板可以嵌入文本、零件名称并生成唯一的序列号。单击此处,了解关于 GrabCAD Print Pro 的更多信息。
  • 对于 SAF 嵌套,嵌套方法的名称已从“标准”和“高级”,更改为“无互锁”和“紧凑”,以便用户更清楚其功能。现在的默认方法是“紧凑”(以前称为“高级”),通常会产生更密集的嵌套。
  • 对于 SAF,验证在某些情况下可能非常慢,因此如果您需要对嵌套进行进一步编辑,您现在可以取消验证过程。
  • 新 VeroEcoFlex 系列半柔性材料现已可供 J850 TechStyle 用户使用。在此处了解更多信息
  • 大多数 PolyJet 打印机使用 UV 汞灯,但 J850 TechStyle 用 UV LED 取代了这些灯。新型 UV LED 能够实现更准确的固化,这对于具有轻薄特征的小型时装模特至关重要。GrabCAD Print 中的 UV LED 配方功能提供一种机制,旨在将 UV 功能控制到特定切片或切片范围。您可以在打印过程的任何部分控制要使用的 LED 以及每个 LED 的强度。
  • 我们解决了 GrabCAD Print 中的问题,即 P3 机器未保存为收藏夹。此问题已修复,用户现在可以将计算机指定为自己的最爱。
  • 此前,P3 作业的长期作业预估无法正确显示。该问题导致完成时间大大缩短。我们已经解决了这个问题。
  • 我们解决了 P3 中的一个问题,即某些具有特定设置的材料无法开始打印。用户将不再遇到此问题,作业将按预期开始打印。
  • 对于拥有 OpenAM 许可证的 P3 用户,“材料”配置文件下的“缩放”范围已扩大,现在为 +2% 至 -1%,从而可以更好地调整缩放以弥补树脂收缩。
  • 对于拥有 OpenAM 许可证的 P3 用户,我们修复了“按图层设置上传”功能存在的问题,即,该功能在某些情况下无法发挥最佳性能。
  • 对于拥有 OpenAM 许可证的 P3 用户,我们修复了新制作材料的作业无法开始打印的问题。
GrabCAD Print 版本 1.79,六月 2023
构建号 1.79.18.29310 发布于 20 六月 2023
  • 包裹模型工具可用于组,成员主体可以有独特的设置。默认情况下,包裹功能处于开启状态。包裹将模型的主体包围在一个通用外壳中。当模型中主体之间的连接点没有被设计成可以承载施加的载荷时,外壳就会增加强度。如果主体之间的连接点被设计成可以承载载荷,则不需要包裹功能,可以将其关闭。
  • 现在,与 CMB 导入相关的冲突清楚地描述了所添加的文件与项目不匹配的情况。
  • ASA 现在可用于 Stratasys F770 打印机,颜色如下所示:白色、黑色、浅灰色、蓝色、红色、黄色。
  • J3/J5 DentaJet 的基座高度增加到 1 mm,以获得更好的粘附性。
  • J850 Prime FabriX 增加了“为包装优化”选项。此选项可以改善透明包装物体(如瓶子)的打印效果。
  • 在 P3 打印机托盘设置下的缩放工具上,测量单位进一步精确,已经从小数点后一位更改为小数点后三位。这一改进可实现更精确的测量和对该功能进行更精细的调整。
  • 现在,为 P3 打印机导入切片堆栈支持带有任何前缀的切片文件名,例如,layer_xxx、slice_xxx 等。
  • 对于拥有 OpenAM 许可证的 P3 用户,我们提供了一个新的下载材料设置功能。借助该功能,您可以下载一个 CSV 文件,其中包含关于材料的第一层 + 过渡层的信息。要访问此信息,请转到“材料库”,选择材料,然后按下位于“每层设置”表上方的“下载设置”按钮。
  • 现在,项目面板会在使用镜像命令创建的任意模型旁边显示一个图标。
  • 对于 SAF 打印,嵌套进度条现在会告诉用户何时发生嵌套,何时发生验证。
GrabCAD Print 版本 1.78,五月 2023
构建号 1.78.18.27879 发布于 16 五月 2023
  • GrabCAD Print Pro 已推出!功能包括翘曲调整建模、每个零件的估计、制造模板,以及更多功能。
    • 阅读 Pro 功能的完整列表
    • 申请免费试用
      GrabCAD Print 内部使用的用于渲染 FDM 作业屏幕图形的软件已更新,因为许多新功能都需要它。旧查看器仍可通过首选项菜单使用,但将来会弃用。
      对于 FDM,外部轮廓的链接行为已更新为始终使用针对模型材料和切片高度定义的行为。在此之前,在某些应用场景中,外部轮廓会自动链接,而忽略材料本身的链接行为。
      Nylon-CF10 现在可在 Stratasys F370CR 和 F190CR 打印机上配合使用可剥离的支撑。SUP4000B 支撑材料提供了一种无需浸泡的支撑移除解决方案,通过易于剥离的支撑结构,加速零件制作过程。SUP4000B 使用与 QSR 相同的支撑头,切片高度(0.0130 英寸/0.3302 毫米;0.0100 英寸/0.2504 毫米;0.0070 英寸/0.1778 毫米)与
      Nylon-CF10 相同。使用具有可剥离的支撑的 Nylon-CF10 时,需要将打印机固件更新至版本 2.6。
      已更新 QSR 与 Nylon-CF10 支撑材料的定义,以改善切片高度为 0.0100 英寸(0.2504 毫米)和 0.0130 英寸(0.3302 毫米)时的填充行为。
      改进以下情况下的构建时间和材料体积估算的准确性:
    • 0.5040 毫米(0.0200 英寸)ASA,在 Fortus 900mc 打印机上使用 T40A 喷嘴
    • 0.5040 毫米(0.0200 英寸)Nylon CF12(黑色),在 Stratasys F900 打印机上使用 T40C 喷嘴
    • 0.5040 毫米(0.0200 英寸)ULTEM 9085 树脂黑,在 Stratasys F900 和 Fortus 900mc 打印机上使用 T40A 喷嘴。
  • 单击 P3 作业的“打印”按钮后,在“打印摘要”窗口,您可以通过按下该按钮,轻松放大第 1 层或托盘预览缩略图,以便您在打印前能更仔细地看清第一张切片的细节。
  • 如果模型被定位在 P3 作业的构建体积之外,项目面板窗口上将显示一个橙色的感叹号通知,将鼠标悬停在该通知上面可查看问题描述。
  • 对于拥有 OpenAM 许可证的 P3 用户,GrabCAD Print 现在支持上传包括“edgeBuildingCompensation”值的每层设置。上传后,该列将显示在每层设置表中。
GrabCAD Print 版本 1.77,四月 2023
构建号 1.77.13.26873 发布于 18 四月 2023
  • 已恢复在不启动新项目的情况下切换打印技术的功能。
  • PolyJet:当为特定组件改变齿龈阴影时,该组件及其外壳已被复制并在托盘树中标记为隐藏。(隐藏组件专为简化“撤消”操作而创建,此操作非常复杂。)从现在开始,这些组件在托盘树上将不可见,并且撤消操作将继续正常工作。
  • SAF:现在,您可以选择零件并创建一个烧结箱来容纳和保护零件,从而指定孔的大小、梁的厚度和间距。
  • P3:过渡层参数已优化,现在会针对经过验证的材料自动处理。以前,此功能显示在“材料属性”下,但现在是隐藏的。
  • P3:过去存在一个问题,即以英寸为单位定义的模型在打印前会变成毫米,这个问题已得到修复。
GrabCAD Print 版本 1.76,三月 2023
构建号 1.76.10.25761 发布于 21 三月 2023
  • 导入 CMB 时,堆栈 (*.zip) 作为文件类型出现的问题已解决,现已恢复为 CMB 文件(*.cmb、*.cmb.gz)。
  • 对于 P3 打印,在“托盘设置”/“材料属性”下,您会看到一个新的缩放参数。如果您的打印件受到材料收缩的影响,此参数将对您有所帮助,您可以在作业层面编辑和优化材料的缩放值。
  • 对于 P3 打印,在“托盘设置”/“材料属性”下,您会看到一个新的额外基础层参数。如果您的零件的 Z 轴高度比 CAD 设计更低,此参数将对您有所帮助。添加额外的基础层将复制第一层,以补偿它们的高度损失。
  • 现在,对于拥有 OpenAM 许可证的 P3 用户,使用 CSV 打印经修改的“每层设置”可以正常工作。
GrabCAD Print 版本 1.75,二月 2023
构建号 1.75.13.24793 发布于 21 二月 2023
  • 为使软件更加强大,切换到采用不同技术的打印机(如从 FDM 到 PolyJet)将需要启动一个新的项目文件。在向项目添加模型之前,您可以在打印机技术之间自由切换。
  • 现在,在为 Fortus 450mc 打印机编程作业时,GrabCAD Print 可以使用经过验证的材料。在提供这些材料以用于编程和打印作业之前,已使用基本的可靠性测试对这些材料进行了验证。经过验证的材料要求在 450mc 上安装固件版本 6.7。
验证材料 可用的切片高度 模型喷嘴 支撑材料 支撑喷嘴
FDM HIPS(高抗冲击聚苯乙烯) 0.2540 毫米(0.0100 英寸) T16 SUP1500B T12
Kimya PC-FR(阻燃剂)
0.2540 毫米(0.0100 英寸) T16 SR100 T12SR100
ULTEM™ 9085 树脂的新颜色(红色、飞机灰、军舰灰、梦幻灰、白色 7362,以及 Jana 白)。 0.2540 毫米(0.0100 英寸) T16 SUP8500B T16
PC 的新颜色(红色和黑色) 0.2540 毫米(0.0100 英寸) T16 SR100 T12SR100
PC-ABS 的新颜色(红色) 0.2540 毫米(0.0100 英寸) T16 SR100 T12SR100
(BETA) VICTREX AM™ 200 PAEK(低熔点)
0.2540 毫米(0.0100 英寸) T14E SR100 T12SR100
(BETA) Covestro Addigy® PA6/66-GF20 FR LS(玻璃填充尼龙,阻燃剂)
0.2540 毫米(0.0100 英寸) T20G SUP4000B T16
  • 现在,GrabCAD Print 支持材料包。当材料在 OpenAM™ 中进行调整、编译,并分发到 GrabCAD Print 且已启用带有 OpenAM 许可证的 Fortus 450mc 打印机时,将创建材料包。可以调整 Stratasys 首选材料和经过验证的材料以及第三方的公开材料并包含在包中。材料包需要打印机固件版本 6.7。
  • 已修复 CMB 副本(或复制/粘贴)与原始 CMB 的工具路径不同的错误。
  • J3 DentaJet™ 基于 J35 平台,是我们面向中小型牙科实验室的入门级 PolyJet 打印机。它可以生产包含三种生物相容性材料的混合托盘,包括大量的植入体模型、手术导板和牙龈遮盖物,所有这些都在同一个托盘上,并且具有无与伦比的准确性。单击此处查看新的 J3 DentaJet™
  • 现在,只有当 GrabCAD Print 和 Job Manager 的版本不一致时,才会出现警报,提醒为 PolyJet 打印机升级 Job Manager。以前,一旦有了新版本,就会出现警报。
  • 现在,可以为有纹理的 VRML 模型添加一个涂层,用于 PolyJet 打印。
  • 对于 SAF 打印机,现已推出 PA12 材料 (Beta)。单击此处了解更多内容
  • 在 SAF 打印机中,提供了一个新的右键选项,支持您选择任何在估计或验证后无效的模型。
  • 在 SAF 打印机中,在某些情况下,有角零件在切片时会呈现出小的表面伪影,现在切片算法已经变得更加精确,以免出现此问题。
  • 对于没有互联网接入的 P3 打印,现在支持通过 Origin Local Hub 连接到 Origin One Local 打印机(详情见 Stratasys 支持中心下的 Origin One Local 参考指南)。请单击此处以参阅连接说明。
  • 对于 P3 打印机,您现在可以使用以下方法导入由 Netfabb 等应用程序创建的切片:文件 > 导入切片堆栈。
GrabCAD Print 版本 1.74,一月 2023
构建号 1.74.8.23921 发布于 17 一月 2023
  • 用于使用 FIPS 合规加密的 Windows 安全设置以前会阻止 GrabCAD 产品连接打印机,这个问题在 GrabCAD Print 和 Print Server 上已得到解决。在安装了 PolyJet Job Manager 的系统上,仍必须禁用 FIPS。
  • 3在 1.55 中引入的 DConnexion Spacemouse 支持现已恢复。
  • 当托盘材料包含所有彩色 VeroFlex 材料时,所有 J7xx/8xx 打印机均启用 VeroFlex 材料的 CMYK 输入。
  • Origin 打印机的材料参数中添加了边缘补偿。此新工具支持您在每个切片中从模型边缘增加或减去微米。如果您看到的特征(如孔)略微过大或过小,但您不想改变模型的比例,此功能将有所帮助。
GrabCAD Print 版本 1.73,十二月 2022
构建号 1.73.5.23276 发布于 20 十二月 2022
  • 无法再从 Workbench 中添加模型。请单击此处阅读博文,详细了解 GrabCAD Workbench 的弃用。
  • 对于 PolyJet 牙科打印机,列出牙齿和齿龈色调名称的文件(用于与 3Shape 整合)已在 1.72 版本中新增了色调。另外,当打开一个包含不存在的色调名称的旧项目或作业时,色调名称应是空的,并显示一条通知。如果用户选择了一个使用不存在的色调的预设,系统将自动设置默认色调。
  • 现在,为 H350 提供了 GrabCAD Print 制造备注功能,支持用户为他们的模型添加备注,并在 PDF 旅行文档中创建一个包含模型截图和备注的 PDF 报告。
  • 另外,对于 H350,修复了一个错误,现在标签预览将以正确的尺寸显示。
GrabCAD Print 版本 1.72,十一月 2022
构建号 1.72.6.22542 发布于 16 十一月 2022
  • 在 Stratasys F900 打印机上为尼龙 12 CF 添加了 0.508 毫米( 0.0200 英寸)切片高度,从而增加了大型零件的吞吐量。此切片高度使用 T40C 模型喷嘴。
  • 在 Stratasys F900 和 Fortus 900mc 打印机上为 ULTEM™ 9085 树脂、ULTEM™ 9085 CG 树脂和 ULTEM™ 9085 黑色树脂添加了 0.508 毫米( 0.0200 英寸)切片高度。新的切片高度可增加大型零件的吞吐量。此切片高度使用 T40A 模型喷嘴。
  • H350 3D 嵌套中的选定模型可以在视觉上隔离,因此所有未选定的模型都被隐藏,当用户处理完隔离模型后,系统可以再次显示所有模型。请注意,这些操作不会更改 3D 嵌套中任何零件的位置。
  • 对于 H350,可以选择使用组装命令或分组的 3D 阵列从 CAD 创建的任何组件,并且可以分解组件结构,留下单独的模型。
  • H350 预算现在可报告整个嵌套和模型的质量,还有整个嵌套的 HAF 流体。
  • H350 的标签命令现在可以记住命令使用之间的设置值,以便更快地创建一系列手动标签,因为浮雕/凹雕、文本大小等保持不变。
  • 对于 J5 DentaJet,一些牙齿色调得到改进,颜色更准确,并添加了两种新色调。
  • 对于 J5 DentaJet,牙龈色调得到改善,质地更佳。添加了四种新色调。
GrabCAD Print 版本 1.71,十月 2022
构建号 1.71.7.21930 发布于 18 十月 2022
  • J5 DentaJet 用户现在可以使用 3Shape 的 Dental System 软件和 GrabCAD Print,利用从口腔内扫描到全彩打印模型的端到端工作流程。在使用 VeroDent PureWhite 和 Vero CMYK 打印时,3Shape Color Model Profile 已添加到 J5 DentaJet。请注意,这需要 2022 版本的 3Shape Dental System 软件。
  • 在将作业发送到启用了高级切片机的 Connex 打印机后,打印确认屏幕中会出现一条通知。
  • 在超高速模式下,J7/J8 系列打印机上打印的作业未出现在计划视图中,此问题现已修复。
  • 可以通过点击项目面板中的预览来重命名 H350 的 3D 嵌套区域,类似于为 FDM 或 PolyJet 重命名托盘,此操作也将更改发送到打印机的作业的名称。
  • 为 H350 上的预算生成的报告内容现在可以复制并粘贴到其他文件中,例如电子表格或下载为 .XLSX 或 .CSV 文件。
  • 没有 OpenAM 许可证的 P3 用户现在可以通过 GrabCAD Print 获得准确的估算结果。点击此处阅读我们最新的博文,了解更多信息。
GrabCAD Print 版本 1.70,九月 2022
构建号 1.70.12.21501 发布于 21 九月 2022
  • GrabCAD Print 现在支持 Windows 11 操作系统。有关完整的系统要求,请点击此处
  • GrabCAD Print 现在支持来自最新版 CAD 软件的文件,包括 Creo9、Inventor 2023、NX2206 和 Parasolid 34.1。
  • GrabCAD Print 现在支持 Origin One 和 Origin One Dental 打印机。通过访问“文件”>“首选项”>“P3 DLP”登录到您的 Origin 帐户后,您可以设置作业并将其发送到您的打印机。在此处阅读更多信息
  • 对于 FDM 项目,GrabCAD Print 现在会在检索到项目但未找到所选打印机时保留作业设置。解决了设置应用打印机默认值的问题。
  • Stratasys F370、F270 和 F170 打印机现在支持 T14H 硬化挤压头。该挤压头的使用寿命为 1500 小时,是使用 ABS-CF10 材料进行编程作业的默认选择。
  • 对于牙科 PolyJet 打印机,现在允许在多选中为牙龈分配色调。但是,每个组件仅限一个外壳。
  • 在 J850 Prime Fabrix 和 TechStyle 中,粘合剂层的有效厚度增加到 3 毫米。
  • PolyJet 错误修复:
    • 在 J850 Prime Fabrix 和 TechStyle 中,使用计划停止保存的项目在没有计划停止的情况下打开。
    • 在 J5 DentaJet 上,打开有效项目时验证失败。
    • 在 SHS 模式下的 J5 DentaJet 上,模型和支撑材料的总预算错误。
  • 以下命令已添加到 H350 的 3D 嵌套视图,使用户能够专门在 3D 嵌套视图中工作:分析模式、单位、比例、添加模型、在 X、Y 平面中自由拖动。
  • 创建多个模型的 H350 构建,其中包含一些太大而无法嵌套的模型将不再导致整个嵌套操作失败。适合的模型将被嵌套,并会发出警告,列出太大而不适合嵌套的模型。
  • 对于 H350,当使用名称或数字自动化创建模板标签时,会自动检查语法。如果不正确,它会以红色突出显示,并且工具提示会详细说明此错误。
GrabCAD Print 版本 1.69,八月 2022
构建号 1.69.12.20542 发布于 16 八月 2022
  • J5MediJet™ 现在支持两种新树脂
    • 生物相容 Digital ABS Plus™ 旨在通过结合利用耐高温性和韧性来模拟标准 ABS 塑料。该材料显著提高了各种医疗应用的生物相容性零件的机械性能。
    • WSS™150 是一种水溶性支撑材料,可快速去除支撑。当放入装满普通自来水的容器中时,该材料会变得可溶。使用标准或台面洗碗机可以更快地去除支撑材料。
      点击此处了解更多信息。
  • 当 J750/850 Digital Anatomy 托盘材料包含 RadioMatrix 时,插入模型时不应将其选为默认材料。
  • 当您可以同时使用 PolyJet Research Package 和 3DFashion 打印机时,您需要选择一个打印机以用于当前项目,因为某些功能存在冲突。
  • 在 J7 和 J8 系列打印机中,改进了使用具有灵活行为的 Agilus 彩色材料设置模型的用户体验。相关设置从高级选项移至主要设置部分,并在所有设置选项中添加了详细的工具提示。
  • 1.67 更新为 Connex3 打印机引入了使用高级切片机的选项,默认情况下,“文件”>“首选项”>“PolyJet”下有一个复选框。高级切片机对图形要求更为严格,一些用户看到了有关图形驱动程序的错误。有一个错误,在关闭高级切片机首选项后,错误仍然存在,且阻止任何作业排队。通过 1.69 更新,此问题已得到修复,取消选中首选项将清除此错误。
  • 对于 H350,现在可以指定包装的高度,可以是时间(这对于准备针对班次可用时间量身定制的工作很有用),也可以是包装的高度,无论用户输入哪个参数,系统将更新另一个。
  • H350 预算现在提供构建报告,其中包含摘要和详细信息页面。摘要列表:打印时间、总体积、嵌套模型、未嵌套模型、密度、嵌套高度和收缩率。详细清单:各个零件,每个零件的份数和每个零件的体积。
GrabCAD Print 版本 1.68,七月 2022
构建号 1.68.10.19783 发布于 19 七月 2022
  • 多文件 3MF、OBJ 和 VRML 组件现在都可以使用“文件”>“导入为组件”以与 STL 相同的方式导入。
  • ULTEM™ 9085 树脂的支撑材料更名为 SUP8500B 支撑,ULTEM™ 1010 树脂更名为 SUP9000B 支撑。
  • 对于标签(仅限 H350),现在可以指定标签文本的浮雕高度或凹雕深度。
  • 对于 3D 阵列(仅限 H350),现在可以选择多个模型并创建这些模型的阵列。
  • 对于 J850 TechStyle 和 J850 Prime Fabrix,连接打印机时,当前作业的托盘类型会自动与打印机上安装的托盘同步。
  • 在已收到并安装右 UV 灯风管现场变更单的 J7 和 J8 系列打印机中,打印机设置对话框应扩展为“已安装更新的风管”声明。
  • ASR-620 DM 兼具 MED620 和 SUP711 的特色,现在可以在 J5 DentaJet 上以 HQHS 打印模式使用。
  • Color Agilus 材料可在 Voxel Print 应用程序中使用。
  • Flex-Touch(智能和完整)应按模型定义,而不是托盘上所有模型通用的 Flex-Touch。
GrabCAD Print 版本 1.67,六月 2022
构建号 1.67.10.19143 发布于 22 六月 2022
  • Advanced PolyJet Slicer 以前仅适用于 J 系列打印机,现在支持 Connex3 打印机。高级切片机引入了改进的质量和附加功能,例如:
    • 具有透明黑白配置文件的灰度
    • 薄区域/角处理
    • 更准确的预算和偏移
    • 更好的网格控制
      如果您需要精确复制以前的打印件,您可以使用“文件”>“首选项”>“PolyJet”切换回旧版切片机。
  • 适用于 J850™ Prime 的 FabriX™ 创新套件可让您将 PolyJet™ 原型制作和 CMF 功能扩展到在纺织品和柔性基材上直接打印的新世界。现在,您可以针对包含网状材料、功能性服装原型以及过滤系统可视化的应用测试不同的设计。
  • 隆重推出 RadioMatrix™,这是 Digital Anatomy 打印机上可用的首款此类不透射线 3D 打印材料。这种新材料使 3D 打印的解剖模型具有不同对比度的不透射线特性,可以出现在 CT 或 X 射线扫描中。RadioMatrix™ 材料设置已添加到 Digital Anatomy 打印机软件中,提供具有所需亨斯菲尔德值的不透射线 3D 打印解剖模型。
  • 新的 Netting-Fabric Insert 功能允许用户在打印过程中计划停止,以便在作业期间插入要打印的介质。J850 TechStyle 和 J850 Prime FabriX 系统上启用了此功能。
  • 用于 AgilusCMY 模型的 Rigid Core 允许使用 Agilus 颜色配置文件打印一次“柔软触感”刚性模型。打印成品是一个刚性模型,外部软表面带有全彩薄纹理(1 毫米全彩邵氏硬度 A 30)。
  • AgilusCMY 材料的 CMYK 输入允许通过纯 AgilusCMY 材料的 CMYK 数值输入定义特定的所需色调。
  • 借助 J5 DentaJet 上的高质量高速模式,用户现在可以用一半的时间以相同的质量打印牙科模型、手术指南和其他应用。选择正确的材料配置后,可以在 GrabCAD Print 中选择高质量高速模式,并在打印机上执行材料更换向导。
  • 对于 H350,现在可以从 GrabCAD Print 中加载的多个顶级模型创建组件。使用 3D 拖动小工具或定位工具将模型定位在 3D 空间中,然后制成可以嵌套的组件。
  • H350 的 3D 阵列工具现在支持将组件作为阵列的来源。
  • 现在可以使用包装高度作为 H350 的 3D 嵌套工具的停止标准。如果嵌套过程成功包装了所有选定的模型,它将尝试降低包装的高度,直到达到指定的高度。
  • H350 的 3D 嵌套命令中最小模型间距的默认值从 3 毫米减少为现在的 2 毫米,这意味着您可以安全地创建更密集的嵌套。
GrabCAD Print 版本 1.66,五月 2022
构建号 1.66.7.17878 发布于 17 五月 2022
  • 介绍 F123 系列的最新成员 Stratasys F370 CR 和 Stratasys F190 CR。这些复合材料就绪 (CR) 打印机旨在用于填充材料,包括 Stratasys 最新的 FDM 复合材料 Nylon-CF10 和当前材料 ABS-CF10。这使得在内部生产坚固的工件夹具、工具和零件更容易,而时间只是使用传统制造技术和材料所需时间的一小部分。这些打印机支持 8 工程级材料,并使用 GrabCAD Print 的直观界面进行变成,并易于使用高级 FDM 功能。点击此处了解有关 F123 Composite Ready 打印机的更多信息。
  • J850 TechStyle 3D 打印机采用 3DFashion™ 技术,为各种设计提供全彩色、多材料功能,这些设计可以直接打印在纺织品、皮革和衣服上。此外,该打印机还能打印传统方法无法打印的小件时尚配饰。点击此处了解更多相关内容。
  • GrabCAD Print 目前支持 H350 SAF 技术打印机。已许可用户可以打印,非许可用户可以探索功能来了解和评估其潜力。点击此处了解详情。
  • 您现在可以使用右键菜单在 GrabCAD Print 中镜像模型。此功能支持:镜像适用于所有打印技术的网格和 CAD 零件、表面具有颜色的模型、纹理、组件中的模型以及整个组件。目前,还不支持镜像具有高级 FDM 功能的模型和带有标签的模型。
  • Nylon-CF10 是一种碳纤维增强尼龙复合材料,可用于 Stratasys F370 CR 和 Stratasys F190 CR 打印机。该材料由 10% 的短切碳纤维(按重量)组成,从而使 3D 打印模型比 ABS-CF10 的硬度和强度更高,耐化学性也更好。Nylon-CF10 支持 0.1778 毫米( 0.0070 英寸)、0.2540 毫米(0.0100 英寸)和 0.3302 毫米( 0.0130 英寸)的切片高度,并且打印时需要使用新的硬度经过强化的打印头 (T20H)。点击此处了解更多关于 Nylon-CF10 的信息。
  • 新的硬度经过强化的打印头 (T14H) 可用于打印 ABS-CF10,打印寿命可达 1500 小时。T14H 打印头是可选的;T14 头可与 ABS-CF10 搭配使用,但会缩短其寿命。
  • 新的 Agilus30™ 彩色树脂(青色、洋红色和黄色)可使橡胶或硅胶纹理产品用来制作全彩色橡胶材质零件的原型,具有高表面质量和柔韧性水平,可承受反复弯曲。点击此处了解详情。
  • VoxelPrint 中现在可以使用材料 WSS(水溶性支撑)、VeroUltraClearS 和 VeroUltraClear 了。
  • 对于 H350,使用标签工具在模型表面添加浮雕或凹雕文本。您还可以创建标签模板,这些模板可以多次应用,也可以在复制零件时自动应用,并且可以自动包含零件名称或生成序列号。
  • 对于 H350,您可以在 X 轴、Y 轴和 Z 轴上创建一个矩形阵列。可将阵列分组为单个对象,也可以创建为单个模型。
GrabCAD Print 版本 1.65,四月 2022
构建号 1.65.13.17318 发布于 21 四月 2022
  • 介绍 J850 Digital Anatomy Printer。J850 Digital Anatomy Printer 凭借令人难以置信的逼真度将医疗模型变为现实,精准地呈现了人体组织的外观和反应。这些模型为医护专业人员和医疗设备公司提供了无与伦比的临床多功能性、可重复性和精确性。点击此处了解详情
  • 我们更新了支持的文件格式,其中包括 SOLIDWORKS 2022、Inventor 2022 等。点击此处查看完整列表:支持的文件格式列表
  • 由于代理或自签名证书,部分用户遇到了网络连接问题。“文件 > 偏好设定 > 隐私”中的新选项允许 GrabCAD Print 信任 Windows 证书存储中的证书,这样可以解决许多此类问题。如果应用程序检测到这些配置,它将自动设置此偏好设定。
  • 引入“数字结构生成器”,这是数字结构打印机的一种附加软件模块。数字结构生成器软件运用复杂的数学函数,为用户提供了前所未有的自由空间,让用户能够自由定制解剖模型的内部结构。不局限于现有的解剖预设,随心创作和校准数字材料,满足您的确切规格要求。轻松操纵材料形成,定制内部微结构,以获得特定的解剖结果。点击此处了解详情。
  • PolyJet 系统中的 Voxel Print 目前支持新树脂:所有受支持的打印机上均支持 VeroUltraWhite 和 VeroUltraBlack,J5 MediJet 支持 DraftWhite。
GrabCAD Print 版本 1.64,三月 2022
构建号 1.64.9.16414 发布于 17 三月 2022
  • Stratasys F370 打印机中的零件 Diran 410MF07 通过以下方式得到提高:
    • 对于 0.1778 毫米( 0.0070 英寸)的切片高度,提高了向上和向下指向的可见表面的填充密度,还提高了零件底面和底座顶面之间的粘附性。
    • 对于 0.3302 毫米( 0.0130 英寸)的切片高度来说,接缝质量、垂直表面和填充密度都有所提高。
      这些改进要求打印机固件更新到版本 2.4。
GrabCAD Print 版本 1.63,二月 2022
构建号 1.63.8.15371 发布于 16 二月 2022
  • WSS™150 是一种水溶性支撑材料,可在 J55 Prime 和 J35 Pro PolyJet 系统上快速移除支撑。如果把 WSS150 放入装有普通自来水的容器中,WSS150 会变得具有可溶性。使用标准或台面清洗机可以实现更快的支撑移除能力。此外,根据当地法律法规,L2S™ 粉末可用于安全地处理废水,无需进行后续处理。
  • “切片预览”面板已更新:
    • 现在显示用于模型和支撑材料的名称、切片高度和喷嘴
    • 重新组织功能显示过滤器(稳定器、固定器、接缝、暂停)
    • 控制动画(播放动画、选择图层和打印头移动)和 Z 轴暂停(添加/移除 Z 轴暂停、暂停列表)已分组
      已从“切片预览”中移除对“模型设置”面板的访问权限,因为“切片预览”面板已显示有关材料和切片高度的相关信息。
  • 在 J55 Prime 或 J8 Prime 中使用“优化包装”功能时,您现在可以使用支持 VeroUltraClear 的 CMYK 输入微调透明颜色,从而为任何瓶子或液体提供出色的透明度和饱和度。
  • J5 DentaJet PolyJet 打印机是一款各项参数经过更新和改进的牙科打印机,可以更快、更准确地进行打印。
    • 在所有受支持打印机上支持 VeroUltraWhite 和 VeroUltraBlack
    • J5 MediJet 上支持 DraftWhite
GrabCAD Print 版本 1.62,一月 2022
构建号 1.62.8.14676 发布于 19 一月 2022
  • T16A 模型喷嘴已添加,可在 Fortus 450mc 打印机上与 ULTEM™ 9085 和认证级别的 ULTEM™ 9085 CG 模型材料搭配使用。与标准 T16 喷嘴相比,T16A 喷嘴具有高度可重复的机械性能和更高的质量,适用于需要零件认证的应用程序,其中包括航空航天内部。T16A 模型喷嘴的层厚度为 0.2540 毫米( 0.010 英寸)。要使用 T16A 模型喷嘴,Fortus 450mc 的控制器软件必须更新到版本 6.6.6906。
  • 现在,使用 Fortus 450mc 打印机上的 T20 模型喷嘴可支持 ULTEM™ 9085 Black 0.3302 毫米( 0.0130 英寸)的切片高度。较厚的切片能够更快地构建零件并增加吞吐量。新的切片高度要求控制器软件更新至版本 6.6.6906。
  • 在改进其他方面的同时还修复了一些小错误。
GrabCAD Print 版本 1.61,十二月 2021
构建号 1.61.12.14139 发布于 22 十二月 2021
  • 对于全彩色 PolyJet 打印,在使用颜色选择器更改颜色时,纹理主体的默认核心现在是“主体外观”。这与最近发布的默认关闭的“覆盖纹理”选项密切相关,让您可以利用简单、直观的工作流程来改变纹理主体的颜色和透明度。
  • 当在 J5 系列打印机上为作业设置延迟启动时间时,除了现有的开始时间或结束时间外,您还可以使用一个新的时间设置选项。如果材料会在运行作业期间用完,您可以设置您想要更换材料储罐的时间,并且打印机会在相应的时间开始作业。
  • 对于数字结构打印机 — 新的“可缝合血管壁”预设改进了血管模型缝合的性能和耐用性。
  • 无法在同一模型上创建固定器和稳定器的问题已解决。
GrabCAD Print 版本 1.60,十一月 2021
构建号 1.60.9.13125 发布于 17 十一月 2021
  • 您会注意到,GrabCAD Print 右侧的外观经过修改。图标略微变小,固定在窗口的一侧。我们一直在添加工具,数量将会越来越多,因此略微缩减了占用空间,以适应更小的屏幕。
  • PolyJet 打印机现在可以打印包含位移(凹凸)贴图的模型。在“文件”>“首选项”>“GrabCAD Labs”中启用该功能后,Keyshot .3MF 或标准 .OBJ 模型中包含的凹凸贴图将转换为打印零件的表面效果。以前,凹凸贴图需要写入文件的 3D 网格,导致创建不必要的大型文件。现在可以直接读取凹凸贴图。您可以在模型设置中调整位移高度或设置 0 以禁用。与任何 Labs 功能一样,欢迎您提供反馈。
  • J35 Pro 提供了一种新模式,称为材料利用模式。借助新模式,您可以选择让打印机自动决定颜色组合,以充分利用剩余材料。打印零件看起来与 GrabCAD Print 中的显示不同,因为打印时的任何现有材料将决定最终颜色。此选项在“打印摘要”窗口中可用。
  • 能够在改变主体颜色的同时保持纹理。以前,将新颜色应用于纹理模型时,纹理会被覆盖。现在,新颜色将更新纹理下方部分的主体颜色,并提供覆盖选项。如果它们不匹配,所选的“基本和核心选项”将覆盖该颜色。
  • 针对打印具有许多重型模型的 PolyJet 作业的新优化。使用重型模型填充托盘时,借助此功能可自动优化这些模型。此功能会自动降低模型复杂性,而不会降低质量或模型准确度。
  • 最新 NVIDIA 图形驱动程序曾存在一个问题,导致无法估计和打印某些 PolyJet 作业,现在此问题已得到修复。
  • 修复了一个问题,即切片预览以与稳定器相同的颜色显示包含稳定器的模型。
GrabCAD Print 版本 1.59,十月 2021
构建号 1.59.11.12349 发布于 25 十月 2021
  • 在 J55 Prime 上,当设置仅拥有黑色和白色的材料配置时,可以使用新的灰度滑块。此外,加载纹理时,这些纹理将使用黑白配置文件。
  • 修复了保存项目时无法保存对模型主体厚度所做更改的问题。
  • 修复了模型包含自支撑孔时无法保存项目的主体和表面设置的问题。
GrabCAD Print 版本 1.58,九月 2021
构建号 1.58.9.11590 发布于 23 九月 2021
  • “保留项目设置”允许 FDM 打印机的项目在切换到相同类型的打印机(例如 Stratasys F370 到 Stratasys F370)时保留其设置。您可以选择保留当前打印设置(即使与新打印机不匹配),也可以根据新打印机更新设置。
  • 修复了一些全彩 PolyJet 打印存在的错误,即,即使选择了“主体外观”,也会打印白色核心。必须重新创建 1.56 或 1.57 中保存的项目,其中的核心设置已手动更改。
GrabCAD Print 版本 1.57,八月 2021
构建号 1.57.8.10644 发布于 19 八月 2021
  • 推出 Stratasys® J55™ Prime,这是对 J55™ 的突破性更新。J55 Prime 3D 打印机提供全彩、高保真度以及触觉、机能和感觉功能,可提升 PolyJet 技术的效率和质量,使其比以往更加实惠并且适合办公室使用。包括先进的打印功能,整合橡胶类硬度 (Elastico™)、高强度 (Digital ABS)、刚性超可视(VeroUltra™、DraftGrey)、半透明 (VeroUltra ™ClearS) 和生物相容性 (Vero™ContactClear) 材料。创建从快速设计迭代到高质量最终原型的所有内容,一切均通过紧凑、静音且无味的流程完成。请在此处查看新的 J55 Prime
  • 推出 Stratasys® J35™ Pro。J35™ Pro 基于 J55™ Prime 旋转托盘平台,是一种低成本 PolyJet 3D 打印解决方案,适用于共享办公环境,具备适合实用设计和概念建模的多材料功能。新 3D 打印机具有先进的打印功能,整合橡胶类硬度 (Elastico™)、高强度 (Digital ABS)、刚性超可视(VeroUltra™、DraftGrey)、半透明 (VeroUltra ™ClearS) 和生物相容性 (Vero™ContactClear) 材料。打印机外型小巧,便于在办公室安装,并且借助 ProAero 过滤系统,工作环境完全无异味。请在此处查看新的 J35 Pro
  • 我们首次对 Print 的 CAD 版本支持进行了中期更新。
  • 切片预览现在允许控制锚和稳定器的显示。
    • 锚和稳定器以单独的颜色显示,便于与模型和支撑区分
    • 使用“显示”列表中的选项停止显示锚和稳定器,以便更轻松地检查模型。
    • 锚和稳定器的显示选项仅在作业包含这些功能时显示
    • 下次进入切片预览时,系统会记住锚和稳定器的显示设置。
    • 此外,图层高光的颜色现在是透明白色,有助于更轻松地分辨切片的哪些部分是模型、支撑、锚和稳定器。
  • Digital Anatomy 打印机的两项更新:
    1. 利用 TissueMatrix 和 GelMatrix 的混合物,打印总共有 6 个新预设的超逼真皮下脂肪组织模型。柔软度不同的主要模型特征是收缩性皮下脂肪层(非常柔软)和高度收缩性皮下脂肪层(最柔软),具有以下涂层选项:
      • 硬涂层 - 涂覆 2 毫米的 Agilus,打造更耐用的独立模型。
      • 软涂层 - 涂覆 2 毫米的 Agilus 与 GelMatrix 混合物,使独立样品的观感逼真、柔软、稠密。
      • 非封装 - 不涂覆,在脂肪组织将纳为器官模型的一部分的应用场景中使用。
    2. GelMatrix 增强功能提供更多解剖建模选项,并且需要更简单、更简短的后期处理。在解剖模型设置菜单中寻找以下两项新功能:
      • 使用 GelMatrix 作为支撑材料来打印各种解剖结构
      • 使用纯 GelMatrix 材料打印,无需任何其他材料
GrabCAD Print 版本 1.56,七月 2021
构建号 1.56.11.9996 发布于 20 七月 2021
  • PolyJet 模型设置面板现在包括一个名为“预设”的部分。已有一个仅用于颜色选择的“收藏夹”部分,但“预设”包括颜色以及所有其他模型设置。右键单击托盘上的某个部分以保存预设。添加预设后,您可以右键单击,将其设置为默认值。之后添加到托盘的模型将应用预设。
  • J8 系列 Prime 的新功能:“优化包装”通过简单的工作流程为包装原型提供出色的外观。使用先进的从 RGB 到印刷颜色的透明度转换,用户现在可以获得更准确的物体(例如液体或有色玻璃)透明度。除此之外,标签后面创建了一个自动白色底纹,使图形看起来非常出色,具有较高的不透明度。此选项适用于使用 Vero Vivid 颜色、UltraWhite+UltraBlack 和 UltraClear 的全彩 J8 打印机,以及来自 Keyshot 的 3MF 文件。(请联系 print@grabcad.com,启用此功能。)
  • 锚功能改进:
    • 为简化模型和托盘之间锚的创建和编辑(最常见的使用案例),当锚窗格打开时,“模型视图”会自动设置为“底部视图”。
    • 编辑锚且模型视图为前、后、左或右时,托盘会切换到瘦预览,方便用户更轻松地检查集合中锚的预览几何结构。当锚窗格关闭时,将恢复较胖的托盘视图。
  • 为 Stratasys F900 和 Fortus 450mc 平台上的 Antero 800NA 以及 F900 平台上的 Antero 840CN03 添加了 T20F 模型喷嘴。与当前的 T20D 模型喷嘴相比,T20F 模型喷嘴将机械性能提升高达 20%,同时具有相同的零件质量和精度。要使用 T20F 模型喷嘴,请在选择受支持的材料后在“切片高度”下拉菜单中选择 0.0100 英寸 | T20F(0.2540 毫米 | T20F)。
  • 固件版本 4.11.0 适用于 Stratasys F900 和 Fortus 900mc 打印机。使用已下载的标准升级 (.upg) 文件时,此更新不可用。请联系服务代表或 Stratasys 客户支持,了解有关此重要更新的信息。
GrabCAD Print 版本 1.55,六月 2021
构建号 1.55.8.8912 发布于 16 六月 2021
  • SpaceMouse 3D 鼠标现在支持 GrabCAD Print 中的视图操作。单击此处查看相关教程。
  • 对于冷却时可能会卷曲的短、宽模型,固定器特征允许您在打印期间将模型固定到构建托盘。固定器特征是由模型材料制成的柱,用于将模型的水平底面固定到构建托盘。固定器可能是圆柱体或圆锥体,可以单独创建,也可以按共享风格和直径的集创建。单击此处,详细了解如何配置固定器。(支持 Stratasys F770、F370、F270、F170、F900 和 Fortus 系列打印机。)
  • 现在您需要选择参考曲线,然后才能生成稳定器。这可以防止在首次打开面板时立即创建稳定器,并允许您在生成稳定器之前调整设置。
  • 推出 J5 MediJet™,这是一款全新的一体式医疗打印机,专用于结构模型、手术指南,以及使用可消毒和生物相容材料的医疗工具。J5 MediJet 为医疗 3D 打印应用设定了新标准。凭借多种材料和多色功能,您可以创建非常生动的结构模型、钻孔和切割指南以及可消毒和生物相容的医疗工具 - 所有这些都基于经过认证的系统。此外,它经济实惠且结构紧凑,适用于狭小的实验室空间。要了解更多信息,请单击此处
  • PolyJet 打印机右侧菜单上的新工具允许您使用“偏好设置”中定义的单位设置托盘上的确切位置。
  • 注意:在下一个版本中,当使用 VeroPureWhite 全彩时,默认情况下会检查全彩 J 系列打印机上的高级彩色半色调是否有新托盘。
GrabCAD Print 版本 1.54,五月 2021
构建号 1.54.6.7969 发布于 18 五月 2021
  • Stratasys F770™ 3D 打印机具有市场上最长的完全加热式构建室 - 对角线为 46 英寸。宽敞的构建空间超过 13 立方英尺(372 升),为制造、原型制作和生产零件应用开辟了新的机会,而这些功能是小型打印机根本无法实现的。单击此处了解有关 Stratasys F770 的更多信息
  • 对于不需要太多传统支撑的高而细的模型,新的稳定器功能允许您在构建模型时为其添加脚手架。稳定器是一个高大的支撑结构,定期固定在模型的侧面,提供额外的支撑并最大限度地减少振动。单击此处了解有关配置稳定器的更多信息。(支持 Stratasys F770、F370、F270、F170、F900 和 Fortus 系列打印机。)
  • 已修复 F123 系列打印机禁用“使用可变宽度填充”复选框的问题。
  • 对于 FDM 模型的封盖曲面,这些刀具路径问题已得到修复:
    • 小型封盖表面不再获得超过需求一倍的光栅填充。
    • 不再忽略封盖表面中的小孔。
  • 1.48 中引入的 GrabCAD Labs 功能允许您将不同的 PolyJet 饰面(哑光或光面)分配给装配体的组件。它不再是一种选项,而是始终可用。
GrabCAD Print 版本 1.53,四月 2021
构建号 1.53.15.7152 发布于 20 四月 2021
  • 选择“切片预览”后,图层范围的默认值现在为“所有图层”。下次选择“切片预览”时,将记住对图层范围的更改。
  • 这些新的不透明材料允许打印薄而逼真的塑料模型,提供更多的高精度色域、用于打印包装标签的清晰文本以及平滑、高分辨率的肤色。
GrabCAD Print 版本 1.52,三月 2021
构建号 1.52.8.6136 发布于 16 三月 2021
单击此处观看有关 1.52 更新的视频。
  • 碳纤维加固 ABS 适用于 Stratasys F370、Stratasys F270 和 Stratasys F170 打印机。Stratasys ABS-CF10 由标准 ABS(苯乙烯)材料与 10% 短切碳纤维(按重量)组成。结果,与标准 ABS 3D 打印材料相比,低湿度敏感性 FDM® 热塑性塑料在硬度上提高 50%,强度上提高 15%。典型应用包括制造工具、夹具、固定装置和末端执行器,这得益于硬度增加与重量减轻的结合。ABS-CF10 支持 0.0070 英寸(0.1778 毫米)、0.0100 英寸(0.2540 毫米)和 0.0130 英寸(0.3302 毫米)切片高度。要详细了解新 ABS-CF10 材料,请单击此处
  • 隆重推出 J5 DentaJet™。J5 DentaJet 3D 打印机基于 J55 平台,是我们多材料牙科 3D 打印机系列的最新成员,使技术人员能够装载牙科部件的混合托盘。与竞争对手的 3D 打印机相比,新型 3D 打印机可以在单个混合托盘上生产至少多出五倍的牙科零件,但其紧凑的占地面积仅占用 4.6 平方英尺 (.43m2) 的地板空间。在此参见新 J5 DentaJet
  • 由 Antero 840CN03 制成的支撑结构和模型之间的基础层和界面层得到改进,提高了朝下模型表面的质量。还更改了支撑结构以增加其稳定性。
  • 对于 Diran 410MF07,切片高度为 0.0010 英寸(0.2540 毫米),固体填充的最小主体厚度减少至 0.0200 英寸(0.5080 毫米),默认的自支撑角度已减小到 45 度,并更新其他打印设置以提高模型的整体打印质量。
  • 现在,可以在数字解剖打印机上使用新的肝脏解剖结构。4 新增具有不同压缩值的肝脏解剖结构预设值,所有值均通过完整的生物力学报告中的可用数据进行验证。从高度收缩到中等硬度的变化,涂层有所不同。有关所执行测试的更多数据,请单击此处
GrabCAD Print 版本 1.51,二月 2021
构建号 1.51.18.5360 发布于 22 二月 2021
单击此处观看有关 1.51 更新的视频。
  • 您现在可以使用大多数 CAD 软件包的最新版本打印文件,包括 SOLIDWORKS 2021、Inventor 2021 和 Creo 7。单击此处了解有关受支持文件的完整列表。GrabCAD Print 版本 1.50、一月 2021
  • 隆重推出 J850 Pro,这是一款 7 材料 PolyJet 打印机,专为快速原型制作而打造。J850 Pro 具有与 J850 Prime(以前称为 J850)相同的构建体积和材料容量,但 J850 Prime 在 CMF 原型制作方面表现出色,而 J850 Pro 专为速度和性能而打造,采用数字 ABS、Agilus 柔性材料、DraftGrey 和超高速模式。单击此处查看新的 J8 系列产品线。
  • 新打印总结窗口将轻松汇总设置、估算、延迟启动选项,以及您面向 PolyJet 作业单击“打印”时要查看的警告或通知。
  • 在分析模式下修复模型时,任何体积为零的实体(例如薄板实体和噪声壳),都将被自动隐藏,因为这些实体无法解释并可能导致估计或打印错误。
  • 托盘视图中 CMB 文件的图形表示得到改进。CMB 显示提供关于模型实际形状的更多细节。现在可以识别和显示之前被忽略的凹槽。借助经过改进的 CMB 显示,用户无需进入切片预览,即可了解由 CMB Print 生成的模型。
  • GrabCAD Print 中的菜单栏和菜单可能会更改颜色,以符合 Windows 主题中设置的颜色。
GrabCAD Print 版本 1.50,一月 2021
构建号 1.50.14.4357 发布于 19 一月 2021
  • 当有可用的 GrabCAD Print 更新时,偏好(版本 1.22 中已推出)确定下次启动该应用程序时是否自动安装该更新。默认情况下,偏好处于启用状态,但是现在每个人都将关闭此偏好。仅当您单击“立即更新”按钮时,将来的更新才会安装,并且如果您愿意,可以在“文件”>“偏好”>“更新”中恢复自动更新。
  • 现在,在模型加载时进行冲突检测可以检测到模型重叠的情况,并向您发出警告。对于 PolyJet 打印,这样可以帮助您确定可能需要更改零件优先级的位置。注意:冲突检测默认情况下处于关闭状态,可以在“偏好”>“模型插入设置”>“自动检测组件中是否存在冲突”中启用
  • 当您在 J 系列打印机上插入具有平面结构的组件时,现在可以在文件列表中立即看到默认优先级。之前,您必须更改零件优先级才能看到。
  • 在 J 系列打印机上使用黑白颜色时,您现在将拥有一个可与黑白颜色配置文件配合使用的灰度滑块 - 替代现有的全色颜色选择器。
  • DraftGrey 以前专用于新的 V5 版本 Objet30 打印机,现在可以在 V3 打印机(被列为 VeroGrey)上使用。单击此处可了解更多。此外,此更新还支持使用 Vero 材料的“高质量”模式。
  • 在 1.49 版本中,一些 Connex 打印机错误地报告了不正确的图形驱动程序版本。 1.50 版本已修复此问题
GrabCAD Print 版本 1.49,十二月 2020
构建号 1.49.12.3309 发布于 16 十二月 2020
  • J4100 升级套件已面向 Objet1000 打印机提供。该套件采用新的打印头技术和非常高级的材料产品,从而增强 Objet1000 打印机的功能。新的打印头提供额外的模型通道 (3),将吞吐量和生产率提高高达 90%。材料产品现在包括 Agilus 系列、UltraClear 和 VeroPureWhite。有了 J4100,通过数字 ABS(覆盖成型)打印柔性材料现在成为现实。
  • 一些 J 系列用户遇到以下问题:他们无法在其 J 系列打印机上进行打印,因为作业会卡在处理流程。这是因为打印机 PC 上的图形驱动程序已过期,但是 GCP 没有检测到该问题。此问题已修复,如果您遇到这种情况,您现在会看到一条消息,向您指明驱动程序的更新链接。
  • 与 CMB 相关的软件修复
    • 恢复了以下选项:在 CMB 导出中包括/排除清除零件/牺牲塔。
    • 恢复了以下功能:在包含 CMB 的托盘上包括其他牺牲塔。
GrabCAD Print 版本 1.48,十一月 2020
构建号 1.48.14.2323 发布于 17 十一月 2020
单击此处观看有关 1.48 更新的视频。
  • GrabCAD Print 现在支持 Objet30 台式打印机。除现有的 Objet30 V3 打印机(称为 Objet30、Objet30 Pro 或 Objet30 Prime)外,还推出了新一代产品:Objet30 V5 Pro 和 Prime。V5 模型是单色、易于使用的打印机,占用空间小且打印质量高。此类打印机提供 3 种打印模式和 13 种模型材料,包括 DraftGrey 以及柔性且生物相容的材料(仅限 Prime)。要将 GrabCAD Print 与 Objet30 一起使用,您需要遵循以下指南:为 GrabCAD Print 设置 PolyJet 打印机
    现在,FDM 打印机的“支撑设置”面板中提供“基本样式”选项
    • 模型与支撑:在模型和支撑范围下方均添加基础层。当基础层重叠时,它们会合并为一个通用基础层。当基础层形成闭合循环时,该循环会被填充,从而创建一个大而稳定的基础层。
    • 仅限模型:仅在模型范围下方添加基础层。支撑延伸到托盘,并且循环未填充。
  • “文件”>“偏好”>“GrabCAD Labs”中有个新选项,借此您可以在 PolyJet 打印机组件中的主体上混合哑光和光面之间的光洁度。
  • J826 打印机现在提供一种新的打印模式,即超高速。这种新模式在吞吐量上是高速模式的两倍,适用于许多应用,例如打印快速概念模型。
  • 对于使用带 T40 挤压喷嘴(0.0200 英寸 [0.5080 毫米] 的切片高度)的 ASA 模型材料在 Stratasys F900 上进行的作业以及使用 SR30 或 SR35 支撑材料的 Fortus 900mc 建模模块,零件第一层下面基础层的构建属性可提高零件第一层的质量,并且防止分层。
  • 对于使用带 T40 模型喷嘴(0.0200 英寸 [0.5080 毫米] 的切片高度)的 ASA 模型材料在 Stratasys F900 上进行的作业,时间和体积预估的准确性已提高。此更改旨在与新的 4.10.0 系统固件一起使用。请注意,此固件更新无法通过标准下载的升级 (.upg) 文件获得。请联系服务代表或 Stratasys 客户支持,了解有关此重要系统软件更新的信息。
GrabCAD Print 版本 1.47,十月 2020
构建号 1.47.20.1644 发布于 20 十月 2020
单击此处观看有关 1.47 更新的视频。
  • 在 Stratasys F370 打印机上使用 0.0100 英寸(0.2540 毫米)的切片高度时,朝上表面的外观和表面密度已针对 ABS 和 ASA 得到改善。
  • 通过更好地检测短而薄的区域以使用可变宽度的剩余刀具路径进行填充,从而改善了剩余填充。
  • 现在可以选择具有不同显示简化状态的模型,并将所有选定模型全面设置为“全分辨率”或“简化”。
  • 现在,SolidWorks 中设为透明的纹理将以正确的透明度正确导入 GrabCAD Print。
  • UltraclearS 模拟丙烯酸材料,透光率达到该材料的 95%,适合制造玻璃、透明聚合物或透明包装的原型。VeroUltraClear 以更高的清晰度、透明度和更低的黄色指数改进了 VeroClear 之前的性能。
  • 现在,J55 打印机中也提供支撑核心选项。支撑核心(以前称为“中空”)支持您从支撑材料中打印核心。在使用该选项之前,请先在“偏好”>“GrabCAD Labs”中将其启用。
  • 适用于 Digital Anatomy 打印机的骨骼分区支持您将骨骼模型解剖为多个部分,以模拟骨折或删除托盘上与应用程序无关的零件。
  • 之前在“更改材料”窗口中的颜色和纹理配置文件选项已移至“托盘设置”工具面板中的“高级”部分。
GrabCAD Print 版本 1.46,九月 2020
构建号 1.46.21.661 发布于 15 九月 2020
构建号 1.46.22.826 发布于 18 九月 2020
单击此处观看有关 1.46 更新的视频。
  • “中空”设置之前是 PolyJet 模型设置中的一个复选框,现在用作“基本和核心选项”下的“支撑”选项。此外,默认情况下,版本 1.42 中发布的“混合核心”偏好处于启用状态。
  • Digital Anatomy 打印机的新功能
    • 骨骼预览 - 逐切片预览骨骼的内部结构,以验证结构是否符合您的意图。
    • 打开/关闭末端 - 在骨骼的内部结构中创建一个“窗口”。您可以标记骨骼的扁平横截面,然后选择用透明材料涂覆或保留原样,即暴露在露天环境中。
  • 现在普遍支持 3MF 文件(在版本 1.40 中作为 Labs 功能推出)。
  • GrabCAD Print 现在可以正确加载具有透明背景纹理的 SOLIDWORKS 文件,从而通过透明背景显示底层外观。
  • Fortus 450mc 现在支持 Antero™ 840CN03。Antero 840CN03 是 Stratasys® Antero 800NA 模型材料的混合,具有静电放电 (ESD) 属性,可用于会接触敏感电子零件和部件的制造应用。Antero 840CN03 有一个切片高度:0.010 英寸(0.2540 毫米)。请单击此处了解有关此材料的信息。
GrabCAD Print 版本 1.45,八月 2020
构建号 1.45.21.65369 发布于 25 八月 2020
单击此处观看有关 1.45 更新的视频。
  • 准备打印作业时,可以预先选择 PolyJet 打印模式。只有适用于所选打印模式的功能和设置会显示,从而让作业准备更加轻松。根据您所选的打印模式,不可用的功能和设置仍禁用,并解释说明不可用的原因。
  • 推出适用于 FDM 自适应切片样式!自适应切片样式为需要更多详细信息(例如穹顶、圆角和倒角)的功能使用所选高度,而为无需详细信息的功能使用更厚的切片高度。结果,打印速度更快(具体取决于几何结构和切片高度,速度最快可提高 24%)。切片样式是一个新选项,用于设置模型的切片方式。请单击此处了解更多
  • 现在,“显示设置”>“图形质量”的偏好可控制图形显示所用模型的简化级别。注意:打印的模型保持全分辨率。有个右键单击菜单选项,即“图形分辨率”,可以在“简化”和“全分辨率”显示形式之间切换显示所选模型。
  • 现在有个适用于所有文件类型的偏好,可以选择(组装或拆卸)组件的加载状态。
GrabCAD Print 版本 1.44,七月 2020
构建号 1.44.22.64105 发布于 22 七月 2020
单击此处观看有关 1.44 更新的视频。
  • 核心/基础分配可以自定义,以提供模型设计的最佳匹配。
  • J720 打印机的自动排列功能可改善零件嵌套,从而提高生产效率。
  • 自 七月 21起,早于版本 2.0 的 GrabCAD Print Server 将无法再连接到 GrabCAD Cloud。为继续通过 GrabCAD Print Server 连接到您的打印机,请手动卸载旧版本并安装 Print Server 2.0。您可以单击此处下载最新版本
  • GrabCAD Print Server 2.0 仅在 Microsoft Windows 10(64 位)以及 Windows Server 2016 和更高版本上受支持。自 七月 21起,在未得到 Microsoft 主要支持的旧版 Windows 上运行的实例无法自动更新,也无法连接到 GrabCAD Cloud。您需要升级 Print Server 实例上的操作系统,或者在拥有受支持操作系统的机器上安装 Print Server。
  • GrabCAD Print 正在转向系统级(每机器)安装。如果这样会影响到您,则当有更新时您会收到通知,并且迁移(通常)无需您做任何工作。在 v1.47 之后,您需要迁移到我们的每机器安装,才能继续接收更新。
  • 现在,GrabCAD Print 允许您将诊断文件从打印机发送给 Stratasys 支持联系人。如果遇到硬件、材料、其他打印机甚至软件问题,您现在可以转到“帮助”->“获取打印机支持”,在此添加有关该问题的详细信息。然后,GrabCAD Print 将生成一个电子邮件模板以及所有详细信息和相关文件,您可以将其发送到您在购买时收到的电子邮件地址。
  • 具有深度(多级)组件结构的 3MF 文件将在“项目”面板中显示整个树结构。
GrabCAD Print 版本 1.43,六月 2020
构建号 1.43.17.62943 发布于 17 六月 2020
单击此处观看有关 1.43 更新的视频。
  • 既然 GrabCAD Print 中提供“高级 FDM”功能,就不再需要创建高级 FDM 项目了。选项“启用高级 FDM”已从“偏好”菜单中删除,并且用于创建新的高级 FDM 项目的操作也已从左侧工具栏中删除。
  • 随着“高级 FDM”功能迁移到核心 GrabCAD Print,“高级 FDM”中创建的项目将在 GrabCAD Print 中打开,并且每个模型使用单独的托盘。组保持不变,主体设置、面设置、托盘属性、方向和制造备注也是如此。
  • 为防止切片失败,已重写将 VRML、OBJ 和 3MF 文件转换为可打印对象的算法。
  • 如果您选择纯色 VRML 的主体,则颜色选择器现在将直接显示颜色,并允许您进行微调。
  • Digital Anatomy 打印机的两项新功能
    • 长骨轴工具支持用户定义长骨的近侧和远侧区域。这样的话,您可以打印具有可变密度的零件,以接近长骨的结构。
    • 多种骨科手术需要钻孔并将螺钉插入打印模型。在某些情况下,这样可能会导致意外裂纹。为防止这种情况,应力释放工具允许您设置可容纳任何裂纹的边界,从而防止打印零件出现较大的裂纹。
  • 推出 Stratasys J55。尽管创建,无需妥协。从快速概念模型到高质量的高保真模型,适合办公室使用的 J55 3D 打印机价格实惠,可更大限度地提高设计师的产量。请单击此处了解更多。
GrabCAD Print 版本 1.42,五月 2020
构建号 1.42.19.62279 发布于 20 五月 2020
单击此处观看有关 1.42 更新的视频。
  • 使用新的机械手可以更轻松地定位和定向模型。单击视图控制条最右边的按钮即可将其启用,然后所选模型将显示箭头,您可以单击并拖动该箭头以自由��沿精确轴移动和旋转您的选择。
  • 对于 FDM 打印机,现在可以使用“排列”工具面板中的滑块将托盘上模型之间的间距从最小 0.2500 英寸(6.35 毫米)调整为最大 2.0000 英寸(50.8 毫米)。这样的话,您可以将模型更紧地包装在托盘上,或者让它们保持更远的距离以改善气流。
  • 现在,当 CMYKW 和 CMYW Vivid 材料加载到打印机时, 1.41 中已添加的 CMYKW 和 CMYW 颜色配置文件是默认配置文件。配置文件名称是 X-Rite i1Profiler CMYKW 或 CMYK。
  • 之前,PolyJet 零件的核心使用黑白材料交替层进行打印,但是“文件”>“偏好”>“PolyJet”中的新“混合核心”偏好允许使用所有可用材料的混合来打印核心。这样可以大大降低喷嘴堵塞问题的可能性,因为每个打印头得到更频繁的使用,但是每个装载的材料盒都必须有足够的材料,才能完成作业。
GrabCAD Print 版本 1.41,四月 2020
构建号 1.41.31.61723 发布于 27 四月 2020
单击此处观看有关 1.41 更新的视频。
  • GrabCAD Print 现在支持最新版本的 CAD 软件包。其中包括 SOLIDWORKS 2020、Inventor 2020、Creo 6.0 等。请单击此处了解完整列表
  • 现在,您可以更改 J 系列打印的支撑网格中使用的材料,以保存您更常用的材料。托盘上的所有支撑结构都将使用所选材料进行打印。您可以在“托盘设置”>“高级”>“用于加强支撑的材料”中选择材料。
  • 要在打印中引入更多“高级 FDM”功能,您现在可以为组内的主体应用不同的材料设置。右键单击组,您可以在以下两项之间切换:
    • 拆分主体 - 主体和面可能会独立于其他主体和面应用设置。这类似于“高级 FDM”的工作方式。
    • 组合主体 - 组中的所有实体均作为单一实体,整个组应用一项实体设置,并且内部边界已删除。这类似于您在不创建组的情况下选择“组装”时组件的正常工作方式。
  • 当组装组已选择“拆分实体”时,“面”选项卡下的“模型设置”面板中会提供表面厚度、接缝位置和插入。之前,此功能仅在“高级 FDM”中可用。
  • FDM 打印上需要支撑的小功能会生成在功能下方变宽的支撑。现在,这点可以通过“改进支撑”设置进行控制,允许您从默认的“仅改进小支撑”更改为“不改进支撑”或“改进所有支撑”。禁用支持改进可能有助于减少某些零件的材料使用率和打印时间。
  • 新的 Vivid 2.0 颜色配置文件已添加到 GrabCAD Print,从而提供更好的颜色渲染。默认颜色配置文件没有更改,保持 Vivid 1.1。
  • 具有面颜色的 SOLIDWORKS 组件现在可以直接加载到 GrabCAD Print,无需额外将这些组件保存为多主体零件。
  • 对于 FDM 打印机,具有组件结构的 3MF 文件现在将以其结构加载。
  • 当您更改滑块上的 FDM 设置时,黑色菱形将指明默认值。单击该菱形可恢复默认值。
  • 使用此版本的 GrabCAD Print,您可以轻松地将文件从 GrabCAD 商店中的订单打开到 GrabCAD Print 中的托盘。这样可以节省时间,避免从电子邮件或其他请求管理软件下载 CAD 文件,并有助于有效规划您的托盘。如果您还没有这样做,请单击此处注册 GrabCAD 商店。
  • “按 IP 添加”输入框已添加到 GrabCAD Print Server,以轻松连接到无法使用自动发现的打印机。
GrabCAD Print 版本 1.40,三月 2020
构建号 1.40.28.60898 发布于 24 三月 2020
单击此处观看有关 1.40 更新的视频。
  • SOLIDWORKS 零件文件(包括多主体文件)现在包含在面级别为 PolyJet 打印应用的颜色数据。之前,GrabCAD Print 中仅包括在主体级别应用的颜色。
  • 创建用户所选颜色的色卡,从而测试颜色在 PolyJet 打印机上的打印模型中的显示情况。转到“应用程序”>“色卡工具”,可访问色卡工具。
  • 现在,GrabCAD Print 可优化计算机的 GPU 内存消耗,从而支持用户打印更大的 PolyJet 托盒。在“偏好”>“PolyJet”>“重型托盘优化”中可启用该功能。
  • 高级切片机现在是唯一适用于 Stratasys J750 和 Stratasys J735 的切片机。旧式切片机不再适用于这些打印机。其他 PolyJet 打印机没有任何变化。
  • 将作业从独立 Insight 发送到 GrabCAD Print 时,独立版本必须与 GrabCAD Print 可用的 Insight 版本相同或比其更高,否则无法发送作业。
  • 我们已经将 GrabCAD Print 的核心组件升级到可用的最新版本。这样不仅可以解决一些悬而未决的问题(例如从 OneDrive 文件夹加载文件),还可以提高整体性能并减少启动时间。
  • 对于 SOLIDWORKS 创建的 3MF 文件,GrabCAD Print 现在可以从许多 CAD 工具中导入 3MF 文件,其中包括:面颜色、主体颜色和纹理。对于 PolyJet 打印机,组件将拥有平面结构,而对于 FDM 打印机,没有任何组件结构。
  • 特定于 FDM 的改进
    • 为了在 Stratasys F370 打印机上使用 TPU 92A 时提供更好的整体零件质量,剩余可变宽度填充的宽度范围已减少。
    • 自我支撑孔的角度已增加到 55 度,以适应材料 Diran 410mf07 的自我支撑角度。
    • 解决了一些模型和方向可能会生成不完全支撑的问题。
  • GrabCAD Print 1.36 中引入的分配给组的默认名称现在可以重命名为更合乎用户逻辑的名称。
GrabCAD Print 版本 1.39,二月 2020
构建号 1.39.14.59507 发布于 18 二月 2020
单击此处观看有关 1.39 更新的视频。
  • 新的 PolyJet“模型设置”面板提供了改进的设计和用户工作流程,还能让您保存材料和颜色收藏夹,以及使用新的“CMYK 输入”功能创建自己的颜色和数字材料。详情请单击此处
  • 从应用了比例或方向的组件创建组时,新创建的组将从组件继承这些属性。
  • 现在,您可以从打印机列表中删除已断开连接的打印机。只需右键单击要删除的打印机,然后选择“删除打印机”。
  • 现在,可以在材料面板中更加清晰直观地看到 PolyJet 打印机的废料容器状态。
  • 有关 PolyJet 高级切片机的提醒:在作为 3 月更新发布的 GrabCAD Print 版本 1.40 中,禁用 J750 和 J735 的 PolyJet 高级切片机的选项将不再可用。
GrabCAD Print 版本 1.38,一月 2020
构建号 1.38.21.59019 发布于 28 一月 2020
单击此处观看有关 1.38 更新的视频。
  • 如果您有 PolyJet 打印机,则可以尝试新的模型设置面板,该面板改进了设计并能够保存收藏夹。转至“文件”>“偏好”>“PolyJet”,然后选中复选框以使用新的 PolyJet 模型设置面板。
  • 在 1.36 中为 J850 和 J835 引入的新型 VeroUltraClear 材料现在可用于 J750 和 J735。VeroUltraClear 模拟丙烯酸材料,透光率达到该材料的 95%,适合制造玻璃、透明聚合物或透明包装的原型。有关 VeroUltraClear 材料的更多信息,请单击此处
  • 您可以在“模型设置”面板中使用新的颜色和材料分配覆盖 VRML/OBJ 零件,并在必要时使用所选 VRML/OBJ 主体上的新右键菜单选项恢复到原始状态。
  • VRML/OBJ 结构偏好的默认状态已从“关闭”改为“打开”。
  • 现在,高级 FDM 上的 Diran 410MF07 的填充图案包括单密度、双密度和实心。另外,第一层材料已从支撑材料更改为模型材料,以改善托盘的附着力。
  • 导致在“安排视图”中显示错误 Stratasys 打印机型号名称的问题现已获得解决。
GrabCAD Print 版本 1.37,十二月 2019
构建号 1.37.15.57828 发布于 18 十二月 2019
单击此处观看有关 1.37 更新的视频。
  • PolyJet 高级切片机现在支持版本 1.20 中引入的 PolyJet 打印机的延迟启动功能。注意:打印机需要处于“空闲”状态,才能选择此功能。
  • 用于后期处理的新的 PolyJet 打印设置允许您添加一层薄薄的透明材料进行抛光。抛光透明层将使模型具有光滑的表面以及高保真度的颜色和纹理。
  • 现在可以预览和创建 PDF 过程卡文档,其中包含制造备注和当前活动托盘的模型屏幕截图。
GrabCAD Print 版本 1.36,十一月 2019
构建号 1.36.17.57117 发布于 20 十一月 2019
单击此处观看有关 1.36 更新的视频。
  • 现在支持新型 J750™ Digital Anatomy™ 3D 打印机,它经过预先编程,内置了与医疗器械制造商、世界一流的研究机构、医院和医务人员合作开发的一系列解剖学应用程序。它具有准确、贴合实际和实用的特点,能让您创造出真实事物的感觉、行为和尺寸。有关 J750 Digital Anatomy 3D 打印机的更多信息,请单击此处
  • 新型 J850 和 J835 现在获得支持。设计和创意无限。现在,借助 Stratasys J850/J835,原型制作同样无限。我们久经考验的技术简化了整个设计流程和工作流程,让您可以将更多时间花在重要的工作上 - 创造、改进和设计最佳产品。有关 Stratasys J850 的更多信息,请单击此处
  • 现在,可以通过“项目面板”顶部的新按钮或鼠标右键命令将选定的模型分组。创建新组时,它将折叠并隐藏现有组件。可以将新组设置为已组装或已拆卸。可以通过原始组件创建其他组。
  • PolyJet 高级切片机设置中有一个新选项,用于显示 VRML 和 OBJ 文件的组件结构。启用此选项后,GrabCAD Print 将确定 VRML 或 OBJ 文件的几何结构,并在项目面板中将该结构显示为主体的组件。每个主体可以为多色(即带纹理、顶点着色、面着色或由多个不同颜色的薄板组成)或单色(即主体中的所有薄板共用一种漫反射颜色)。用户可以更改此类组件中任何单色主体的材料分配。
  • 导入 SOLIDWORKS 文件(.sldprt 或 .sldasm)时,如果加载了透明材料,则附加到 SOLIDWORKS 实体的透明度属性会在 PolyJet 材料面板中自动转换为 alpha 值。
  • 可以从 GrabCAD Print 更新需要许可证的 Stratasys 和 Fortus 打印机的材料许可证。更新材料许可证需要用户具有本地管理员权限。
  • 重新设置了项目面板的样式,以提高可用性。更改包括重新设计的图标、更佳的对齐方式、更清晰的选择高亮显示、已组装/已拆卸状态的下拉菜单(而不是复选框)以及更清晰的显示/隐藏状态指示。
  • 现在,在“打印”处于“选择面”模式下时,可以使用鼠标右键命令来进行正切选择。在将制造备注添加到表面链时,这很有用。
  • 可以向主体和表面添加称为“制造备注”的注释。鼠标右键菜单提供了添加备注的命令,该命令将添加标注,单击即可激活该标注以显示备注并允许对其进行编辑。
  • 适用于 Stratasys J850 和 Stratasys J835 3D 打印机的新型 VeroUltraClear 材料。VeroUltraClear 模拟丙烯酸材料,透光率达到该材料的 95%,适合制造玻璃、透明聚合物或透明包装的原型。有关 VeroUltraClear 材料的更多信息,请单击此处
  • GrabCAD Print 的 Stratasys F370 打印机现在支持 ABS ESD7。ABS ESD7 是一种工具材料,专为静电敏感应用而设计,可防止排斥或吸附其他材料(如粉末、灰尘或微粒)。单击此处了解有关 ABS ESD7 材料的更多信息。
GrabCAD Print 版本 1.35,十月 2019
构建号 1.35.21.56592 发布于 24 十月 2019
单击此处观看有关 1.35 更新的视频。
  • 我们改善了在需要为 PolyJet 打印机更新 Job Manager 时“打印”按钮和打印机列表的行为。单击“打印”按钮会显示一个弹出窗口,而在单击打印机列表时,您将直接进入可以执行升级的“设置”屏幕。
  • 已在“托盘设置”的“高级”部分添加了一个复选框,用于控制 J 系列打印机的紫外线灯。如果您的打印件存在曝光过度问题,请联系您的经销商或 Stratasys 技术支持,了解此设置是否有帮助。
  • 在 J 系列打印机上使用 Pantone 颜色进行打印时,只有某些颜色需要 VeroBlackPlus。以前,如果您没有加载 VeroBlackPlus,则系统会禁用整个 Pantone 颜色选择器,但现在仅会禁用特定颜色。Pantone 仍然需要所有三种 Vivid Vero 材料和 VeroPureWhite。
  • 模型加载现在是可以取消的操作。以前,如果您犯下错误并选择了错误的文件,则必须等到其加载后才能将其删除,而现在您可以立即取消。
  • 现在,在“高级 FDM”中将设置应用到特定表面时,可以通过右键菜单删除这些设置。以前,您必须使用“撤销”来还原表面设置。
  • 支持新的 FDM 材料:
    • 现在,Stratasys F900 打印机可通过 GrabCAD Print 在 Antero 840CN03 上打印。有关新型 Antero 840CN03 材料的更多信息,请单击此处
    • 现在,Stratasys F370 打印机可通过 GrabCAD Print 在 Diran 410MF07 上打印。Diran 是模具应用的理想材料。有关新型 Diran 410MF07 材料的更多信息,请单击此处
  • TPU 92A 现在支持在 Stratasys F370 打印机上打印 0.0070 英寸(0.1778 毫米)切片。 0.0070 切片和 0.0100 英寸(0.2540 毫米)切片的打印质量得到了改善。F123 控制器软件必须升级到版本 2.1,才能利用这些改进。
  • 现在,删除打印机历史记录要求用户具有本地管理员权限。
GrabCAD Print 版本 1.34,九月 2019
构建号 1.34.16.55783 发布于 19 九月 2019
单击此处观看有关 1.34 更新的视频。
  • 在 1.31 中作为选项引入的 PolyJet 高级切片机现在默认为打开状态。它提高了估算精度,并启用了此处列出的一些功能。如果出于任何原因需要使用旧切片机,可以通过“偏好”>“PolyJet”关闭 PolyJet 高级切片机。
  • 现在,您可以在 GrabCAD Print 的“帮助”菜单中访问与所选打印机相关的 GrabCAD 教程和示例文件。我们的应用程序工程师会不断添加新内容,以帮助您更好地利用机器。这些新内容将通过“帮助”菜单提供。
  • 通过使用标记为“预览受支持的表面”的视图栏中的切换开关,可以快速查看将在模型上生成支撑材料的位置。此功能在 1.24 中引入,用于 PolyJet 打印机,但现在也可用于 FDM 打印机。它提供了更快速的方式来取代 FDM 切片预览,可帮助您准备托盘,因为它显示了方向和支撑设置(例如自我支撑角度)将如何影响打印表面。
  • 当您在计划视图或 GrabCAD Print 移动应用程序中查看正在进行的 PolyJet 作业时,预计的“结束时间”的准确性现已大大提高。该预测将在整个作业期间定期更新,以说明初始估计中的打印暂停和其他错误。
  • 在 PolyJet 托盘设置面板中选中“切片延迟”选项将能减少在模型上出现的凹陷。请在使用该选项之前联系 Stratasys 技术支持团队。使用该选项将会增加作业的打印时间。
  • PolyJet 打印机的“托盘设置”面板中显示的材料列表现在包括支撑材料。
  • GrabCAD Print 现在将会通知您部分打印机(例如 F123 系列和 J750)的最新动态。这些动态可能包括有关新材料、学习内容和其他方面的信息。选择这些打印机之一时,如果有最新动态,您将会在屏幕左下方看到一个礼品盒。
GrabCAD Print 版本 1.33,八月 2019
构建号 1.33.10.54793 发布于 20 八月 2019
单击此处观看有关 1.33 更新的视频。
  • 在“高级 FDM”支持的打印机上,“模型设置”选项卡现在提供一些高级功能。这些功能包括:填充密度、填充角度和主体厚度,以及在使用 CAD 文件时将圆柱体孔变为自我支撑菱形的功能。
  • 与上一次更新中对 FDM 设置面板所做的更改类似,PolyJet 设置面板现在被拆分为托盘设置和模型设置,以便在将来的更新中留出更多功能空间。
  • 您现在可以选择导出不带清除零件或牺牲塔的 CMB,这可以防止在打印作业中的多个 CMB 文件时打印多个清除零件。默认情况下,清除零件/牺牲塔将包括在内。
  • 对于 Stratasys F900、Fortus 900mc 和 Fortus 400mc 打印机模板,ABS 现在是默认材料。对于实时打印机,材料将继续使用当前配置作为默认配置。
  • J750 和 J735 用户须知: 1.31 中引入的高级切片机在未来几个月的升级版本 1.34 中默认为 *开*。
GrabCAD Print 版本 1.32,七月 2019
构建号 1.32.19.54065 发布于 22 七月 2019
单击此处观看有关 1.32 更新的视频。
  • 与 FDM 打印准备有关的“打印设置”面板已分为 3 个面板:托盘设置、模型设置、支持设置。另外还添加了新图标。
  • 现在,“分析模式”可以修复具有顶点颜色的 VRML 和 OBJ 文件,并且改进了具有面颜色和纹理的文件的修复。
  • J750 和 J735 用户现在可以使用 Vivid 材料和高级切片机打印不透明模型。取消选中“打印设置”面板中的“半透明”复选框以打印带有白色核心的主体。此功能目前仅适用于无纹理的网格文件/组件。
  • 某些 Fortus 和 F123 作业的问题导致清除零件/牺牲塔出现一些奇怪行为,进而导致构建失败。此问题已解决。
  • 选择 Agilus 30 Clear 时,模型将以与您设置的邵氏硬度值关联的透明度级别显示。
GrabCAD Print 版本 1.31,六月 2019
构建号 1.31.52720.53058 发布于 20 六月 2019
单击此处观看有关 1.31 更新的视频。
  • 在 1.24 中为 F900、F370 和 Fortus 打印机引入的“高级 FDM”现在可用于 F170 和 F270。“高级 FDM”允许您使用实际的 CAD 几何结构自定义模型不同部分中的填充,以及修改孔的几何结构以便能够打印。在此处阅读详细信息
  • 高级切片机现在可在“文件”>“偏好”>“Polyjet”中使用,为 J750 和 J735 用户带来了大量改进和新功能:
    • 颜色选择器中经过 Pantone® 验证的颜色。
    • 具有透明纹理的 VRML 模型将使用清晰的核心。
    • 提高了小特征和文本的估算和打印精度。
    • 自定义支撑选项,用于修复具有孔的垂直薄壁上的“支撑阴影”效果。
    • 装配组件重叠时的自定义零件优先级。
    • 完全控制零件在托盘上的放置。
  • GrabCAD Print Server 的新版本作为 Windows 服务运行。即使您的 Windows 用户帐户已注销,它也将继续运行。此外,它与 Windows Server 2012 兼容,并且可与 GrabCAD Print 的每机器版本一同安装。此升级不会自动进行,您必须在此处下载新版本。有关安装帮助,请单击此处
  • 分析模式现在可以修复带纹理的 VRML 文件中的网格错误。
  • 当您尝试从尚不支持的 CAD 软件包(例如 Inventor 2020)添加模型时,出现的错误消息现在将包含比一般故障更丰富的信息。
  • 对于 FDM 打印机,每当零件表面的角度低于指定值(称为自我支撑角度)时就会生成支撑材料,而且现在可以在“打印设置”面板中调整该值。您可以增加或减少生成的支撑材料数量,也可以将该值恢复为因打印机和材料而异的默认建议值。
  • 添加与当前 GrabCAD Print 项目中的文件或设置不匹配的 CAD 或 CMB 文件会产生冲突而不是错误,新的警告允许您保存更改并打开新项目。
GrabCAD Print 版本 1.30,五月 2019
构建号 1.30.28.52238 发布于 22 五月 2019
单击此处观看有关 1.30 更新的视频
  • 打印机历史记录可从 GrabCAD Print 应用程序的打印机历史记录页面中删除。该选项在偏好中启用,而偏好仅对 GrabCAD 会话处于活动状态。删除历史记录时,打印机必须处于空闲状态,尽管打印机队列中可能有作业。
  • 我们在 GrabCAD Print 中查看了翻译,并修复了 6 处错误。
GrabCAD Print 版本 1.29,四月 2019
构建号 1.29.6.51061 发布于 16 四月 2019
单击此处观看有关 1.29 更新的视频。
  • GrabCAD Print 现在支持最新版本的 CAD 软件包。其中包括 SOLIDWORKS 2019、Inventor 2019、Creo 5.0、NX 12.0 等。单击此处阅读更多信息
  • 通过新的打印机面板轻松访问打印机。该面板具有收藏打印机、高级搜索和过滤功能以及许多其他改进。我们希望收到您的反馈!从“文件”>“偏好”>“GrabCAD Labs”中打开,让我们知道您的想法。
  • GrabCAD Print 支持 Stratasys F123 系列最新成员的 Beta 版,即 F120。在此处了解其相关信息
  • 现在,当您选择 SMART、Sparse 或 Box 支持模式时,可以在支撑结构中使用模型材料进行 FDM 打印。由于打印机需要几秒钟时间在模型材料和支撑材料之间进行切换,因此,此功能允许很多作业层仅使用模型材料,从而节省打印时间。
  • 现在,只需单击按钮,即可将 Insight 模型发送到 GrabCAD Print。选择 Insight 工具栏上的“在 GrabCAD Print 中生成作业”图标可创建一个 CMB 文件,并将文件从 Insight 传送到 GrabCAD Print,并将自动选择正确的打印机类型。
GrabCAD Print 版本 1.28,三月 2019
构建号 1.28.16.50383 发布于 21 三月 2019
单击此处观看有关 1.28 更新的视频。
  • 缺乏打印更多零件的技术或能力?转至“应用程序”>“使用 Stratasys Direct Manufacturing 制作零件”以访问 SDM 主页。(仅适用于美国/加拿大客户。)
  • “高级 FDM”选项卡现在提供自动定向功能。标准主体和合并主体均可自动定向,以尽可能减少支撑材料并缩短构建时间。
  • 现在支持带有图像纹理的 OBJ 文件。在 PolyJet 打印机上打印时,系统将读取并显示与 OBJ 文件关联的图像纹理文件,并打印合并的结果。
  • 在 F123 系列打印机上使用六线形填充时出现的零件质量问题已得到解决。对于材料 F123 ASA 和 F123 ABS,在 0.005 英寸(0.127 毫米)和 0.007 英寸(0.178 毫米)的切片高度上,填充密度已减小以防止过度填充。
  • “打印设置”、“定向”和“比例”面板已更新,仅对活动托盘上的模型或主体进行计数。
  • 从桌面应用程序导出的打印机历史记录中存在一个错误,其中所有作业的“持续时间”显示为 00:00:00。此问题已解决。
  • 该应用程序会在临时目录中生成一些文件,以前随着时间的推移,也已生成文件。现在,应用程序关闭时会自动清除这些文件。
  • 一些用户遇到错误,导致他们无法启动 GrabCAD Print,并且看到“实例过多...”错误消息。这是由适用于 SOLIDWORKS 的 GrabCAD Print 增件引起的,该增件现已停用。
GrabCAD Print 版本 1.27,二月 2019
构建号 1.27.17.49710 发布于 25 二月 2019
单击此处观看有关 1.27 更新的视频。
  • 在 1.24 中为 F123 系列和 Fortus 900mc 引入的可变宽度的填充材料现在可在 Fortus 380mc、380mc CFE 和 450mc 上使用。此功能需要使用打印机固件 6.1 版(自 13 三月 2019起可用)。请按照此处的说明更新机器固件。
  • 导入要在 FDM 打印机上打印的 CMB 文件时,系统将自动选择合适的打印机。此外,您现在可以围绕 Z 轴旋转该模型。
  • PolyJet 打印作业中不允许使用某些材料组合,例如 Vero 和 VeroFlex,或仅使用两种 RGD 材料中的一种用于数字 ABS。以前,如果打印机加载了此类不受支持的材料组合,则打印机将显示错误状态并禁用打印,即使作业本身未使用不支持的材料组合也是如此。现在,只要不在作业中使用不支持的材料组合,用户就可以打印他们的作业,而无论打印机中当前加载了哪类材料。
GrabCAD Print 版本 1.26,一月 2019
构建号 1.26.13.48725 发布于 28 一月 2019
  • GrabCAD Print 1.24 中作为“打印设置”面板的一部分引入的可变宽度填充现在可用于高级 FDM。
  • 清除零件(F123 系列)和牺牲塔(某些 Fortus 打印机)会自动将自身置于托盘上的最佳位置,但您可以手动移动它。现在,当您这样做时,它将保留在该位置,直到您使用“排列托盘”或“排列项目”工具。您也可以右击清除零件/牺牲塔并选择“自动定位”,以重新定位清除零件/牺牲塔。
  • 重置现在可用于 GrabCAD Print 和高级 FDM 中的方向。选择模型并选择“重置”将使模型在最初添加到托盘时返回到其方向。
  • 解决了在某些情况下阻止安装 GrabCAD Print 的问题。如果您仍然遇到安装问题,请联系 print@grabcad.com
GrabCAD Print 版本 1.25,十二月 2018
构建号 1.25.17.47934 发布于 4 一月 2019
  • 1.16 版测试版测试中发布的每机器版本的安装程序现在一般可从 print.grabcad.com 获取。除了比当前的每用户版本的安装程序更稳定之外,它还允许 IT 系统管理员在学校和企业组织中进行部署。有关版本切换的更多信息和说明,请阅读我们的帮助文章
  • 现在,对于具有自相交、水密性/开口面问题和倒转法线的 OBJ 和 VRML 文件,GrabCAD Print 会在利用 PolyJet 技术打印之前修复这些文件。要试用此功能,请联系 print@grabcad.com
  • “打印设置”面板上的工具提示说明了可变宽度填充、零件构建样式、清除零件或牺牲塔类型、系统模式和第一层材料的行为。提示内容可调整,以仅显示操作可用选项的内容。
GrabCAD Print 版本 1.24,十一月 2018
构建号 1.24.15.46944 发布于 20 十一月 2018
  • GrabCAD Print 高级 FDM 提供功能强大且直观的工具集,通过自动控制 FDM 构建属性来获得所需的零件特征。通过将属性直接分配给 CAD 文件的几何图形,您可以指定强度和刚度区域,控制填充,确保带有插入的孔周围有足够的材料,并避免接缝。然后自动计算所有必要的工具路径,而无需手动操作各个层 - 最终减少准备作业所需的时间,同时提高整体零件质量。高级 FDM 适用于特定的打印机(F370、380mc、380mc CFE、400mc、450mc、900mc 和 F900),可在“文件”>“首选项”>“FDM”下找到。
  • 现在可以将 OBJ 文件添加到 GrabCAD Print 中,其中包含用于 PolyJet 打印的颜色、关联的 .mtl 文件和可视纹理。需要转至以下路径以启用此功能:“文件”>“偏好”>“GrabCAD Labs”。要了解支持的功能,请访问此处
  • GrabCAD Print 支持新推出的材料,包括 J750/J735 上的 VeroCyan Vivid、VeroFlex Cyan/Magenta/Yellow Vivid & Agilus 30 White 和 Connex3 上的 MedABS 和 Med615,以及 F900 上的 Antero 800NA 和为 F123 系列推出的全新柔性材料(称为 FDM TPU 92A)。请注意,用于 Connex3 和 J750/J735 的新材料需要更新嵌入式软件。
  • 选择 PolyJet 打印机后,3D 查看器上方的顶行按钮中的新显示模式将允许用户查看支撑材料将放置在模型表面的位置。这将确定光面的边界。
  • 某些 FDM 打印机现在提供了可选设置,以便为内部零件构建使用可变宽度填充功能。设置后,可变宽度工具路径会自动放置在默认宽度工具路径之间的间隙处,这些间隙小于默认宽度且大于给定尾孔锥度的最小宽度。安装最新固件更新后(分别为版本 1.8 和 3.26 或更高版本),F123 系列和 F900 和 Fortus 900mc 均支持此功能。
  • “计划视图”中作业详细信息面板的更新可直观地指示预计将用于该选定作业的材料数量。工具提示向用户显示在作业完成时估计储罐或碳粉盒中将剩余的材料量。对于 FDM,第一个排队作业将指示作业启动时储罐/碳粉盒中的材料量。
  • 现在,“计划视图”中的作业详细信息面板将列出 FDM 打印机作业所需的尾孔锥度和构建分辨率。这些信息对于用户检查作业所需的材料与打印机当前加载的材料非有用。
GrabCAD Print 版本 1.23,十月 2018
构建号 1.23.20.45529 发布于 17 十月 2018
  • 历史记录报告有以下几项改进:
    • 现在,可将作业历史记录导出为 .XLSX 和 .CSV 格式(默认为 .XLSX)。
    • 为了将打印时间与预热时间和作业期间花费的其他时间区分开来,“持续时间”列现在分为“作业总时间”和“打印总时间”两部分,前者是指开始和结束之间经过的总时间,而后者不包括打印机暂停或预热的时间。
    • 历史记录视图中的新列显示作业中的零件列表。相同零件的数量将在零件名称后显示 (#)。例如“HingePin(3)”。目前,此功能仅适用于 FDM 打印机。(注意:使用 GrabCAD Print 1.22 及更早版本打印的作业将在此处显示加密的零件名称。)
    • 对于 FDM 打印机,导出的作业历史记录现在包含与支撑材料和模型喷嘴大小对应的两列。
  • 可以使用 ULTEM™ 9085 以 0.013” 的分辨率在 Fortus 450m 打印机上打印零件
  • 根据设置的材料属性,模型显示为亚光或光面效果
GrabCAD Print 版本 1.22,九月 2018
构建号 1.22.24.44746 发布于 26 九月 2018
  • 有一个新的偏好选项可用于禁用 GrabCAD Print 的自动更新。有可用更新时,您仍会收到通知。
  • 有一个新的偏好选项可用于更精确地导入 CAD 文件,这将为代表 CAD 文件的网格添加更多三角形。但是这会影响性能。
  • 在此发行版中,我们修复了与打印机连接到 GrabCAD Print 的方式相关的一些问题(包括打印机列表在更新后消失),并改进了错误报告功能,以便将来更好地解决潜在的连接问题。
  • 现在,对于所有 FDM 打印机,模型都能自动定向,而且定向到生成最少支撑材料的方向。
  • 现在,当使用 .005” 分辨率时,可以使用支撑材料作为 ABS 和 ASA 的 F123 打印机上的基础层来打印作业。这会增加出现托盘附着问题的风险,但可以让您更轻松地拆卸小零件。
  • 在可以使用双密度填充的 FDM 打印机上,现在可以选择六线形填充样式。此样式非常坚固,而且能够高效构建。
  • 计划视图中的工作时间和延迟打印启动可能会使队列显示为空(若非如此),因此当您需要向右滚动以查看队列中排队的作业时,会出现一个新按钮。
  • 单击当前在“计划视图”中打印的作业时,您将看到在完成作业后将剩余材料量的估计值。对于 FDM 打印机,您还可以查看以下作业的起始材料量的估计值。
  • 现在,在切片预览中可以看到接缝(FDM 打印机的工具路径开始和结束的位置)。
  • 可以在 450mc 打印机上使用 Antero 800NA 打印零件。
GrabCAD Print 版本 1.20,七月 2018
构建号 1.20.50.42688 发布于 18 七月 2018
  • PolyJet 打印机的延迟启动现已可用!当您的 PolyJet 打印机处于空闲状态且队列为空时,您现在可以计划打印时间,以在按下“打印”按钮后的指定时间开始打印。请注意,如果您通过 GrabCAD Print Server 远程连接到打印机,则此功能尚不可用。
  • 现在,您可以在“安排视图”中单击 F123 系列打印机的摄像头图像上的按钮,将其放大到全分辨率。可以对所有打印机的作业预览图像使用这项功能。
  • 经过 3 个月的测试,GrabCAD Print 完全支持 Connex3 系统。请通读设置指南以开始使用。
  • GrabCAD Print 现在支持新型 Fortus 380mc Carbon Fiber Edition 打印机。
  • 仅在您处于不活动状态的时间达到 2 个月时,您的 GrabCAD Print 登录会话才会过期。以前的过期时间为 1 周。
  • 如果您为 PolyJet 打印机购买了新的 Vivid Vero 材料,现在可以在 GrabCAD Print 中选择这些材料。
GrabCAD Print 版本 1.19,六月 2018
构建号 1.19.14.41748 发布于 15 六月 2018
  • 当您单击“打印”将作业发送到 PolyJet 打印机时,如果打印机未加载足够的材料或废物箱已满,则会显示警告信息。
  • 包含大量重复文件的作业将比以前更快完成处理。此外,复杂或多主体 VRML 文件的文件加载时间缩短了 60-80%。
  • 现在,无论您是在本地连接到打印机,还是通过 GrabCAD Print Server 远程连接到打印机,都可以导出打印机配置文件。
  • GrabCAD Print 现在支持新的 Stratasys F900 系统类型。Stratasys F900 用于取代 Fortus 900mc 系统,并且包含升级的湿度控制系统和一般性系统增强功能。
GrabCAD Print 版本 1.18,五月 2018
构建号 1.18.19.40241 发布于 10 五月 2018
  • 面向 PolyJet 用户的一些增强功能,包括:
    • 用于打印设置的新复制和粘贴功能。
    • 托盘验证、估算和排队的进度条。
    • 提高了在打印重复的重型 STL 时的切片机稳定性。
    • 现在,Agilus 材料可以与 SUP706B 支撑材料一起打印。请仅在您收到了新的支撑材料配方(也称为 706B)时使用此组合。
  • 现在,SOLIDWORKS 2018 支持适用于 SOLIDWORKS 的 GrabCAD Print 增件。更新到 GrabCAD Print 1.18 后,在“控制面板”中修改安装以安装该增件。
GrabCAD Print 版本 1.17,四月 2018
构建号 1.17.14.39209 发布于 12 四月 2018
  • Connex3 系统(包括 Objet260、Objet350 和 Objet500)将很快得到支持,您现在可以加入我们的公共测试版测试!此外,请安装现在可下载的最新嵌入式软件更新。无需签署正式的测试版协议,只需前往此处获取下载链接和完整说明即可。
  • 适用于 PolyJet 托盘的托盘估算现在将显示真正的进度条。
  • 当您更改 PolyJet 打印机的托盘材料时,颜色和纹理配置文件将恢复为默认值,以防止用户意外留下不推荐的配置文件。
GrabCAD Print 版本 1.16,三月 2018
构建号 1.16.29.38429 发布于 20 三月 2018
  • 提供面向 GrabCAD Print 的全新的每机器安装程序。这就可以把 GrabCAD Print 轻松地安装在计算机实验室 PC 上,以及由系统管理员在企业层面进行部署。在此阅读更多信息并通过电子邮件print@grabcad.com请求访问。
  • 现在支持最新版本的 CAD 软件包。这包括 SOLIDWORKS 2018、 Creo 4.0、Inventor 2018 等。完整列表请阅读此处
  • 在上次更新中,我们引入了一项新功能,可让您将打印设置与所选打印机的当前配置同步。在这次更新中,我们已经使这种行为实现自动化 - 在您启动应用程序时立刻执行。
  • 在 PolyJet 打印支撑网格中使用的材料(通常是 VeroPureWht)现在于估算结果窗口中指定,而不是假设为“其他”。
GrabCAD Print 版本 1.15,二月 2018
内部版本号 1.15.13.37334 发布日期为 19 二月 2018。
  • FDM 打印机的“打印设置”面板具有新的外观。当您的设置与当前的打印机配置不同时,您会看到一个指示,只需单击一下该指示,即可更新所有设置以实现匹配。此外,任何新建托盘的设置将始终与您当前正在查看的托盘设置相匹配,以加快为具有多个托盘的项目进行打印准备。
  • “排列”工具中提供了一个新滑块,用于控制 PolyJet 用户的“优化”复选框。您可以控制排列是否经过优化,以尽可能缩短打印时间或减少支撑材料的使用情况。
  • 修复内容:如果“安排视图”在屏幕上保留一段时间,则“现在”行将停留在原位,而不是慢慢移出视图。
GrabCAD Print 版本 1.14,一月 2018
构建号 1.14.20.36110 发布 17 一月 2018
  • 打印机面板中的详细信息屏幕现在显示模型和支撑喷嘴计量表,以及 FDM 系统的封包和打印头温度。
  • 如果您的 FDM 系统有多个材料舱,则打印机面板中的新图标指示当前打印头中加载了哪些材料舱。
  • 如果在作业中选择了与当前打印机配置不匹配的材料或喷嘴,单击“打印”按钮时现在将出现弹出式警告。
  • 现在可以为 Fortus 900mc 打印机以 XML 格式下载详细的独立打印作业日志。转到报告视图并使用“选项”列中的下载按钮。
  • GrabCAD Print 现在支持 Stratasys J700 Dental 打印机。
  • 修复内容:无论您的单位偏好设定如何,这些报告都以 cm³ 为单位标记材料单位。此问题已得到修复。
GrabCAD Print 版本 1.13,十二月 2017
构建号 1.13.21.34870 发布 12 十二月 2017
构建号 1.13.23.35192 发布 19 十二月 2017
  • 如果您设置了 GrabCAD Print Server,则以前只能享受 PolyJet 系统的一些远程访问功能,例如移动端应用程序连接和在线报告。现在我们启用了最新功能:从远程 PC 上的 GrabCAD Print 发送作业。
  • 几个相关改进
    • GrabCAD Print 中的“报告视图”现在包含一个导出按钮,可同时作用于 FDM 和 PolyJet 系统。
    • 修复了“报告视图”中某些用户无法选择打印机的错误。
    • 修复了 Internet Explorer 在线报告中的一些问题。
  • You no longer have to click “View Estimates” when the estimation results are ready, they will automatically pop up.
  • 在 iOS 版的 GrabCAD Print 应用程序中,作业详细信息现在将包含预测的结束时间。
GrabCAD Print 版本 1.12,十一月 2017
构建号 1.12.26.33454 发布 13 十一月 2017
  • 现在,您可以从 GrabCAD Print 桌面应用程序的“报告视图”中访问本地打印机的作业历史记录。这将对离线模式下的用户有很大的帮助,因为此报告以前仅在设置 GrabCAD Print Server 后才可从在线的“报告”页面上获得。(尚未提供 PolyJet 系统、远程打印机和 CSV 导出的历史记录。)
  • 新的高级 PolyJet 材料刚刚由 Stratasys 推出,现在由 GrabCAD Print 提供支持。了解有关 AgilusVeroFlexDABS2 Plus 的更多信息。
  • 如果帐户连接了很多打印机,Android 应用程序有时会报告找不到打印机。我们增加了超时时间,因此这种情况应该不再发生。
  • 细微的可用性改进
    • 2 GB 的单个文件大小和托盘大小限制已取消。
    • 当另一个操作正在进行时,不再阻止切换到“安排视图”。
GrabCAD Print 版本 1.11,十月 2017
构建号 1.11.17.31736 发布 11 十月 2017
  • 全新托盘显示,特点为...
    • 适用于 uPrint、Dimension、F123 Series 和较小 Fortus 系统的真实托盘形状和格线。
    • 适用于较大 Fortus 系统的厘米或英寸格线(取决于您的显示单位偏好设置)。
    • 适用打印机的校准触点。
    • Fortus 900mc 将显示较小托盘大小的轮廓。
  • 您现在可以使用 GrabCAD Print,通过“切片预览”向 FDM 打印作业添加暂停。在此之前,此功能仅在 Catalyst 和 Insight 中提供。
  • 您现在可以使用 GrabCAD Print 为 ULTEM™ 9085 CG 准备作业。以前,此材料只能使用 Insight 和 Control Center 才能使用。用户还可以选择将 T16A 喷嘴与 Fortus 900mc 搭配使用。
  • 解决了阻止某些用户在 SOLIDWORKS 中启动 GrabCAD Print 加载项的问题。
GrabCAD Print 版本 1.10,九月 2017
构建号 1.10.19.30507 发布 13 九月 2017
  • 现在您就可以直接从 Workbench 项目中向 GrabCAD Print 添加模型。前往此处以了解有关结合使用 Workbench 与 Print 的更多信息。
  • 如果您正在使用 GrabCAD Print Server,则在打印作业完成或需要引起关注时,您和团队将获得电子邮件通知。从 GrabCAD 个人资料中调整您的设置。
  • 现在您可通过双击或拖放的方式打开 .PRINT 文件。
  • GrabCAD Print 现在支持 Objet1000 Plus 打印机。阅读设置指南
  • 过去存在的问题是:文件名或路径中包含非 ASCII 字符的 CAD 文件可能无法载入 GrabCAD Print。此问题已得到修复。
  • CAD 文件的导入已得到改进。在之前的版本中,某些零件显示部分粗糙或弯曲的表面,但相关改进将提供更加平滑的表面。
  • 您现在可在“开始”菜单中发现指向 "Insight for GrabCAD Print" 的快捷方式。该快捷方式会将您带到随附的 Insight 版本,而之前只能从 GrabCAD Print 的“应用程序”菜单访问 Insight。
GrabCAD Print 版本 1.9,八月 2017
构建号 1.9.27.701 发布 9 八月 2017
  • 现在可将牺牲塔添加到 Fortus 打印作业。这有助于改善接缝质量,并且在使用 Nylon 12 CF 打印时要求引入牺牲塔。
  • Nylon 材料现可供 GrabCAD Print 中的 Fortus 打印机使用。
  • 在安排视图中,需要引起注意的作业(例如,如果材料在作业执行期间或之前耗尽)将显示有图标。带有警告的打印机总数将显示为应用程序左侧“安排视图”图标上的数字。
  • 用户将能够从“打印机面板”中导出包含打印机作业历史记录的 CSV 文件(仅限 FDM)。这就允许离线客户直接导出其作业历史记录数据,而无需启用报告。
  • 之前版本的 GrabCAD Print 要求在初次安装时具备系统管理员权限。而在版本 1.9 中,任意用户都可执行安装,而无需具有系统管理员凭据(除非包括可选的 SW 加载项)。
GrabCAD Print 版本 1.8,七月 2017
构建号 1.8.16.652 发布 12 七月 2017
新功能:
  • GrabCAD Print 现在支持使用 ULTEM™ 9085 和 ULTEM™ 1010 打印。这也就意味着,目前可以使用 GrabCAD Print 打印在 Insight 中使用这些材料准备好的 CMB 文件。要修改参数或使用“固定器引脚”或“壁稳定器”等功能,您可以使用应用程序菜单中的 Insight。您还必须使用 Control Center 来添加牺牲塔。(GrabCAD Print 尚不支持 ULTEM™ 9085 CG。)
  • 用户现在可在其 FDM 打印机上执行整个项目的优化排列(一次性排列所有托盘)。这样就可让用户以最佳方式打包带有尽可能多零件的多个托盘。
  • 在将零件插入 FDM 打印机时,会从托盘的中心排列这些零件,以提供改进的打印质量。
  • 对于 F123 系列打印机,通过已得到支持或未获得支持的功能改进底部表面的平滑度。
错误修复:
  • 在建立 J750 打印机的连接时,Windows 用户名中的特殊字符不再会引发问题。
  • 在安排视图中查看 PolyJet 作业时,“打印模式”和“打印的切片”会再次出现。
  • 修复零件上的转换导致部分显示顶层的问题。
  • 修复在某些 FDM 打印机之间切换造成导入的 CMB 消失的错误。
GrabCAD Print 版本 1.7,六月 2017
构建号 1.7.28.633 发布 14 六月 2017
  • 现在可在托盘上排列多个导入的 CMB 文件。在此之前,操作多个 CMB 文件的用户必须使用“控制中心”实施其工作流程。出于性能考量,CMB 在模型视图中有所简化,但可在切片预览中看到实际的形状。从空项目开始,然后转到“文件” > “导入 CMB...”
  • 我们在“文件”菜单中添加了“最近文件”选项。您可访问5最近添加的文件(任意 CAD 格式、CMB 或 OBJZF)以及最近的5 Print 项目。
  • 您现在可以在安排视图中通过拖放的方式重新排列作业。
  • GrabCAD Print 的 SOLIDWORKS 加载项现在封装在 GrabCAD Print 的安装程序中。SOLIDWORKS 加载项用于直接从 SOLIDWORKS 内准备进行打印的 CAD 文件。有关安装说明,请转到 GrabCAD Print 中的“应用程序”菜单。
  • 您的打印作业现在显示有您的真实姓名,而非本地作业中的计算机个人资料姓名。
  • GrabCAD Print 现在支持 .JT 文件类型
  • 修复内容:包含非 ASCII 字符(例如 é 或 à)的零件现在可在 J750 上进行打印。
  • 修复内容:在托盘中载入 Tango+ 材料但未使用时出现了 J750 零件的缩放问题,此问题已得到修复。
GrabCAD Print 版本 1.6,五月 2017
构建号 1.6.19.601 发布 9 五月 2017
  • 介绍操作小时数!您公司的管理员启用这些功能之后,安排视图将自动调整打印机队列显示,反映打印作业通常仅在工作期间启动,这样可为您提供更加准确的安排预测。
  • 使用 Shift 键选择方式,在“项目面板”中快速选择多个模型。借助此方式以及框选方式(在 1.5 中发布),可以更加快速地一次性更改多个模型的设置。
  • 在“打印机面板”的队列列表中使用单击拖动方式轻松记录作业。
  • 为加快查看器的浏览性能,“模型视图”将显示模型的“简化”版本。您可能注意到曲面上出现更多三角形。这不会影响打印质量。为确切了解将发送到打印机的切片数据,可转至“切片预览”,或在“系统偏好设置”>“显示设置”中将“图形质量”改为“高”。
  • 对于 F123 系列打印机,我们现在提供了“砖块模式”成型风格。当打印大型、高密度、实心填充的零件时,这有助于减少零件卷曲。仅在对 ABS、ASA 或 PC-ABS 使用 0.005" 的切片高度时,才采用这种模式。
  • 修复内容:对于 J750 打印机,我们已修复了可能造成打印过程错误的一些问题。请确保更新 GrabCAD Print 和 Job Manager 以利用这些修复。
  • 修复内容:显示单位设为公制的用户现在可采用所选的单位查看切片高度。
GrabCAD Print 版本 1.5,四月 2017
构建号 1.5.15.549 发布 18 四月 2017
  • 离线模式部分2在此处!现在,当您初次安装时,如果没有互联网连接,就可以跳过登录。这是对 GrabCAD Print 1.3 中引入的离线模式的后续增强,相关详情可阅读此处
  • GrabCAD Print 现在支持最新版本的 CAD 软件包,包括 SOLIDWORKS2017、Inventor2017、NX 11.0 和 Solid Edge ST9。完整列表请阅读此处
  • 您现在可从项目面板的托盘预览中为您的托盘提供自定义名称。当您单击“打印”时,作业将继承此名称。
  • 使用版本 1.5 发送的所有作业将在“安排视图”作业详情中包括托盘的预览(在线方式和在桌面应用程序中)。可在“系统偏好设置”>“隐私”中禁用此功能。
  • “模型视图”中的框选方式有助于一次性更改多个模型的打印设置。使用鼠标左键单击并拖动。向右拖动鼠标时,仅会选择完全包含在框中的模型。向左拖动鼠标时,也会选择部分包含在框边界中的模型。
  • 视图快捷键和透视设置现在成为查看器顶部的便捷按钮。
  • 您现在可选择材料单位在移动应用程序以及在线报告和安排视图中的显示方式。在此更改您的设置。(移动应用程序在注册后更新)
  • 我们改进了您获得如下通知的方式:需要为 J750 更新 Job Manager。
  • 对于 F123 系列打印机,基础层将由使用 ABS 或 ASA 以及 0.005" 切片高度进行打印的模型材料组成,以便改善托盘粘着力。
  • 我们对核心流程和打印功能进行了大量调整,改进了 Stratasys F123 系列打印机的打印质量。
GrabCAD Print 版本 1.4,三月 2017
构建号 1.4.20.531 发布 14 三月 2017
新功能:
  • GrabCAD Print 现在支持所有 uPrint、Fortus 和 Dimension 打印机。查看完整列表
  • 在 1.3 中,如果您在估计托盘之后点击“排列托盘”,则可大幅度改进 FDM 打印的包装。现在只需采用“排列”工具中的“优化”复选框,即可更加轻松地执行此操作。在某些情况下,这可以在每个托盘中放入之前两倍数量的零件!
  • 自定义打印机名称介绍!从“打印机设置”面板中重命名打印机,您的自定义名称将出现在桌面、网络和移动平台上,供您公司帐户的所有成员查看。在此了解更多内容。
  • 对于 GrabCAD Print Server 的最新更新版本(版本号  0.144.0318),GrabCAD Print 移动应用程序以及在线安排和报告中现在支持 Stratasys J750。远程访问打印功能即将提供。
  • 此外,如果 PC 上已运行 GrabCAD PolyJet Job Manager,则现在可使用“添加网络打印机”选项初次连接到 J750。
  • 我们已改进了在打印机面板的“我的打印机”中列出打印机的方式。
    • 如果您丢失打印机连接,该打印机将不会从列表中消失。相反,它将显示“断开连接”的状态。
    • “离线打印机”现在称为“打印机模板”,将出现在网络打印机下方的单独部分中。
  • 对 F370 打印设置进行了小规模更新:
    • PLA 打印现在称为“草稿模式”。
    • 清除零件风格默认使用“全高”。
错误修复:
  • 一些 J750 用户报告,在托盘中载入 Tango+ 材料但未使用时出现了估计不正确或打印失败的问题,这些问题已得到解决。
  • “安排视图”现在显示接下来的 J750 作业的时间和材料估计。
  • 一些 J750 用户报告了带有神秘的“错误 0”故障消息的打印错误。造成此打印故障的问题已得到修复,如果再次发生相同问题,则故障消息现在是有意义的文本。
  • “定向”面板中的两个小错误已得到修复:一个涉及负的小数值,另一个则与 + 和 - 按钮有关。
  • 一些 F370 用户已注意到包含一些不正确层的清除零件,此问题已得到修复。
GrabCAD Print 版本 1.3,二月 2017
构建号 1.3.25.508 发布 21 二月 2017
构建号 1.3.23.503 发布 7 二月 2017
  • Stratasys F123 系列介绍!我们最新的打印机专门运行在 GrabCAD Print 上。在此了解更多
  • GrabCAD Print 中对 J750 的支持现已完成测试!感谢所有参与测试项目的人员。如果您拥有 J750,则可遵循此指南以开始使用 GrabCAD Print 进行打印。
  • 我们现在已提供 SOLIDWORKS 加载项,可让您直接在 CAD 环境中打印 .SLDPRT 文件。了解更多关于此方面的信息或者在此下载
  • 许多用户已要求能够安装并直观地打印,而无需登录 GrabCAD,因此我们引入
    • 如果互联网连接掉线,GrabCAD Print 将允许您继续使用本地打印机进行打印。
    • 如果这是您大部分时间内的工作方式,则可在“系统偏好设置”>“隐私”中切换至离线模式,从而关闭警告消息。
    • 您仍然需要在初次启动应用程序时至少登录一次。如果您有互联网访问权,但登录遇到问题,请查看故障排除指南
    • 离线功能的第二部分将是“完全离线”解决方案,在此解决方案中可跳过初始登录。我们预计此部分将在今年末准备就绪。
  • 如果您曾经认为“排列”工具不像 Insight 或 Catalyst 那么优秀,您应注意到此次更新对该工具进行了重大改进。首先,点击“估计”以对托盘进行切片,然后“安排托盘”将更紧密地打包零件。
  • 参与过 J750 测试计划的用户可以注意到此次更新带来的一些改进:
    • 现在可从 GrabCAD Print 中的“打印机”面板更新 Job Manager,如同执行固件更新一样。
    • “打印设置”面板中的透明滑块问题已得到修复!
  • Insight 现在与 GrabCAD Print 绑定,因此您可将更多高级功能(如组或工具路径编辑)用于您的 F370 或 Fortus 系统。在此了解更多
GrabCAD Print 版本 1.2,一月 2017
构建号 1.2.11.469 发布 24 一月 2017
构建号 1.2.9.464 发布 16 一月 2017
  • 如果您错失,报告就在此处!在 Web 浏览器的右侧检查您的作业历史记录和材料使用。
  • 提供新的系统偏好设置,用于更改在为一个托盘添加过多零件时是否要自动创建新的托盘。
  • 工具图标更大、更醒目。检查这些图标:工具
  • 在“旋转”工具中,您现在可自定义每次单击的旋转度数,从而可更轻松地获得最适宜的方向。
  • VRML 文件现在包括在“分析模式”中,但若要修复模型而不破坏纹理映射,必须使用其他软件。
  • 我们修复了一些涉及 CAD 文件阅读器的问题,特别是围绕环状模型的问题。
GrabCAD Print 版本 1.1,十二月 2016
构建号 1.1.28.454 发布 16 十二月 2016
  • 改进主导航和项目面板中的颜色与图标。
  • 存在一个问题,即您的单位偏好未反映在“安排”视图中,此问题已得到修复。
  • 其他小范围修复和改进。
GrabCAD Print 版本 1.0,十一月 2016
构建号 1.0.32.424 发布 15 十一月 2016
  • 更多打印机!您现在可将 GrabCAD Print 用于您的 Fortus 380/450 和 Fortus 900 打印机(有限支持*),而 Fortus 360/400 和 J750 目前处于测试阶段。发送电子邮件print@grabcad.com以请求访问权。
  • 能够以立方厘米为单位查看材料的体积。转至 “文件”>“系统偏好设置”>“单位控制”>“显示单位”,然后更改任何公制单位。
  • 能够导入 .CMB.GZ 文件。
  • 安装程序现在默认采用操作系统语言进行安装。您可通过在安装程序的第一个屏幕中选择返回按钮来更改语言,也可从“系统偏好设置”中更改。
  • 为新用户提供更加直观的默认鼠标控制。更新的配置请参见此处。现有用户不受此次更新影响。
  • 填充、切片高度和支撑风格现在自动更新到建议的所选模型和支撑材料设置中。
  • 小规模的 UI 改进和问题修复。
*有限支持意味着支持基本的打印准备(与 Insight 中的“绿色标签”选项相似),但是打印 ULTEM™ 或尼龙 12 时使用“牺牲塔”等高级功能尚不可用。
在此阅读早期版本的发行说明。
找不到所需内容? 向我们发送消息 向我们发送消息
