GrabCAD Print 發行說明
GrabCAD Print 版本 1.98,一月 2025
構建號 1.98.6.50666 發佈于 21 一月 2025
- Print Pro: Easily transform solid parts into hollow or honeycomb-filled structures with the new Hollow and Lattice tool panel. Pick a shell thickness and choose between no lattice or hexagonal, and to drain the interior of material, choose faces to remove, when applicable. This feature is ideal for reducing weight, saving material, and minimizing thermal absorption during the manufacturing process.
- Print Pro: Export As... will remember the last selected export format (STL, 3MF) instead of always using the default format.
- Print Pro: The Assembly created while using the Split tool is now optional.
- An issue where holes were being filled for some models using double-high solid infill (e.g. 0.5000 mm, 0.0197 inch) has been resolved.
- For the best results when printing on the Stratasys F3300, pair GrabCAD Print 1.98 and Insight 19.1 with the printer firmware update version 2.5.1.
- The option “Max Reliability (45°)" was added to the dropdown for orientation optimization for P3, and the existing "Min Supported Area" option is updated to prevent orientations less than 30°.
- When a model on P3 or SL has unsupported anchor points, you must verify whether the support in these points is mandatory. If it is, rotate the model in a way that all anchor points can be supported. But if you want to print the job as is, a new warning will appear, asking you to confirm before printing.
- Z compensation values have been added to all validated and preferred material profiles in the Materials & Profiles library for Origin Two/One+ platforms.
- The dependency between the Z Compensation and Support penetration was removed for P3 and SL.
- If the “Add Z & Beam Comp to part name” preference is checked, the Z Compensation and Beam Compensation values are added to the support SLC file names. These were already added to the model SLC file names.
GrabCAD Print 版本 1.97,十二月 2024
構建號 1.97.10.49657 發佈于 17 十二月 2024
- Print Pro: GrabCAD Print Pro now supports the Neo line of printers. If you have a license for Print Pro, all the features described under the “Pro features for all supported technologies” section of this article are available for your Neo printer, including Labels, Split Model, and more.
- Print Pro: GrabCAD Print Pro now supports the Digital Anatomy line of Polyjet printers, including features like Labels, Split, Smart Insert and Print on Object.
- Print Pro: A new option under File > Preferences > Model Insert Settings allows you to automatically repair models that may have mesh errors without having to enter Analysis Mode. The preference is off by default.
- Print Pro: A new popup will prompt you to create a Group when you add an assembly or multi-body part to your project. Groups allow you to assign separate model settings for each component while printing as-assembled. The popup will allow you to automate this behavior with a “Remember this choice” checkbox. To undo this setting and make the popup appear again, locate it under File > Preferences > Warnings Settings.
- Print Pro: When you add a selection of STL files using File > Add as Assembly, and you choose to Group the assembly with the new popup described above, the “Separate bodies” group behavior is available, allowing you to assign different model settings to each component. Only Groups created on import using the popup (or its remembered choice) allow for the “Separate bodies” group behavior – Groups created manually from STL assemblies may only use “Combine bodies” group behavior.
- F3000 PC (polycarbonate) material with 0.2500 mm (0.0098 inch) slice height is now available for the F3300 printer. Although the material is not yet available for purchase, it can be selected in GrabCAD Print for estimation and comparison purposes.
- For the best results with the F3300, pair GrabCAD Print 1.97 and Insight 18.12 with the firmware update version 2.5.1.
- The Adobe RGB input color profile which was introduced in the 1.91 update is now the default selection for PolyJet printing. This enables full color printing with a larger color gamut for more saturated and vibrant colors. The color input profile can be reverted to the previous default option (sRGB) under File > Preferences > PolyJet or in the Tray Settings panel.
- ElasticoClear is a new flexible material for the J3 and J5 DentaJet printers. When combined with VeroMagenta, ElasticoClear enables the creation of pink gingiva masks with enhanced tear-resistance. Four new Digital Material blends with different Shore values are available. Please note that ElasticoClear is not a biocompatible material and cannot be printed on the same tray with surgical guides, try-ins or custom trays.
- Introducing the TechStyle Fabric Alignment Station, a precise imaging device which allows you to capture an image of your fabric mounted to the base plate and import it into GrabCAD Print, so that your 3D design may be perfectly aligned with any 2D design already on the fabric. Read more about the Fabric Alignment Station here.
- RadioMatrix (RM) is now available in color profiles using Digital Anatomy Printer.
A new material profile has been added to the Validated O2 collections.
30 new materials and material profiles have been added to Origin's Open AM Library. The new materials enable new applications such as automotive components, earbuds, prototyping, and gas/liquid flow adapters. The new materials also expand the offering in the ceramic, casting, and high stiffness application areas, with some examples below. All profiles were validated by partners on Origin One platform but available for all Origin platforms.
- Bison Porcelite (sintered ceramic for high temperature applications including metal investment casting)
- N3D-FR512 for FR-rating with higher elongation at break
- FL300 from Forward AM for low Shore hardness elastomers in a clear color
- MED414 for elastomeric applications requiring biocompatible capability such as ear bud
GrabCAD Print 版本 1.96,十一月 2024
構建號 1.96.8.49045 發佈于 20 十一月 2024
- Print Pro: You can now split a model using a plane. The plane has default X, Y, and Z orientations, or choose one to start then drag or rotate the plane to the desired orientation. When you are satisfied with the plane’s location click the Split button; two bodies in an assembly representing the pre-split model are created. Registrations may be added to the split face to simplify re-assembly after both halves are printed.
- Print Pro: Estimate the amount of Carbon Dioxide (CO2) output by your FDM print job. Estimates are generated automatically after the CO2 or CO2e emissions value is entered for your power provider on the Emission Rates tab of the Tray Estimations dialog. The CO2 emissions value is multiplied by the power required for the Printer and material, and the time estimated to print the job, to estimate the CO2 output in grams.
- Print Pro: If you produce high-requirement parts, you can now use datums for CAD-compare in Accuracy Center. Datums are optionally selected surfaces on your model that serve as references for consistently measuring and locating part features. In the Accuracy Center dialog, turn on the "Use datums for alignment" option, then select up to 3 datum surfaces.
- Print Pro: When filtering a model with a tree structure (Group, Assembly, Multi-body Part), only items that match the search string/filter and parents of the match will be displayed.
- GrabCAD Print now supports the Neo® line of printers, including the Neo800, Neo450s, and Neo450e. Users can now connect to Neo printers in GrabCAD Print and enjoy a simpler workflow including optimized orientation, automatic support generation, and advanced file handling. Read more here.
- The random color display mode, released in version 1.83 for SAF only, is now available for FDM, P3, and Neo printers. Click the color wheel icon on the view control strip and select the wheel with grayscale wedges. This will assign a random color to each model, as well as to the individual bodies in a Group or Assembly when it is in the disassembled state.
- Add perforations to FDM support structures. Perforations add layers of model material at defined intervals into support structures, making it easier to break these structures away from the model. When Model as Support is checked, perforation layers will be support material.
- PC-ESD is a strong, durable, resistant material for jobs where making sure components don’t get damaged by static discharge is most important. It is available for the Stratasys F900 and Fortus 450mc with a 0.0100 inch (0.2540 mm) slice height.
- ULTEM 9085 Red and ULTEM 9085 Aircraft Gray now support the 0.0130 inch (0.3302 mm) slice height on the Stratasys F900 printer.
- For best results pair GrabCAD Print 1.96 and Insight 18.11 with Stratasys F3300 printer firmware version 2.3.1.
- Introducing the validated material collection for P3. This collection includes materials validated by the P3 team with basic reliability testing to accelerate the expansion of material options available for our customers. For more details on material options, visit Stratasys Materials.
- A new material profile has been added to both the Validated O2 and Open AM collections for P3.
- New and updated support profiles for P3, including Rigid, Light Tough, Ultra Tough, and Elastomeric options, with both standard and conservative profile preferences available.
- The History report in GrabCAD Print now includes material consumption per-job for P3.
GrabCAD Print 版本 1.95,十月 2024
- Print Pro: Two model list filters have been added to the Project Panel. The search box will filter models by name, and the filter button allows you to find models with errors or warnings. If a model or its children match the selected filters, the entire model structure is shown in the list, and the child components are not filtered.
- A new button allows you to sort the model list. Models may be sorted alphabetically (forwards and backwards) or in the order in which they are added to the project (default).
- A Collapse/Expand All button has been added to the Project Panel to expand or collapse all assemblies, groups, and parts with a component structure.
- A new tool called Inline Anchor Points allows you to draw a polyline on the model to manually place support for P3 printing. If the line passes through an area that must not have support, anchor points are removed automatically.
- Anchor points from automatic support generation that could not generate support are shown in red. Unsupported anchor points created manually are shown in Black. A color legend is added to the Anchor Points panel.
- The material collection for the Origin One printer has been renamed from "Preferred & Validated Materials” to “Preferred O1 (Industrial) (Origin One)”
GrabCAD Print 版本 1.94,九月 2024
- New view controls are available when right-clicking on models: Show Model, Hide Model, Isolate Model, and Show All. These controls allow you to get a better view of the models on your tray in tightly packed arrangements. The hidden/shown state affects the display only, and does not impact whether models are printed. When models are hidden, you will see a “Show hidden models” button at the bottom of the viewer.
- The old hide/show behavior has been renamed to avoid confusion with the new view controls: Suppress (previously “Hide”) removes the model from the tray and prevents it from being printed. It remains in the project panel’s file list with a strikethrough. Resume (previously “Show”) restores a suppressed model or component to the project. It will maintain settings and manipulations previously applied, but may not be placed on the tray in its original location.
- When two or more models in a project have the same name, a number (in parenthesis) will be added to each model name so each may be uniquely identified. The identifier is retained until the number of like named models is reduced to one.
- If your company has an instance of GrabCAD Print Server running, and you are in the office with your printers, you may be connected to your printer either locally or remotely via Server. The connection method used to stick to whichever was used previously, but now GrabCAD Print will switch to a local connection when it’s available, for FDM printers only. This prevents you from getting blocked when trying to perform an action that requires a local connection, such as sending a firmware update or printing while Server is in Read-only mode.
- A new option called “No Supports” has been added to the Support Style selection in the Support Settings menu for FDM printers. The model will be printed with a base but no other support structures.
- The Contour Width may now be changed in the Model Settings for FDM printers. Contour Width should be edited together with Body Thickness – changing the Contour Width affects the number of contours required to achieve the minimum body thickness.
- The option to toggle between the standard gray model color and model material color(s) is now available for projects created for the Stratasys F3300 printer. When selected, the material color assigned to a model or body will be applied to the body on the tray.
- Unlock the potential of your J5 Digital Anatomy Printer and enhance your anatomical models with incredible accuracy and customization with the Digital Anatomy Creator. This tool lets you edit material structures to precisely control biomechanical behavior.
- Although J5 Digital Anatomy Printer cannot print the anatomy base materials in High Speed mode, it will allow selecting anatomy structures created with other materials to be used in High Speed mode.
- We’re excited to introduce the new, enhanced TrueDent Shade options, available to all Dental GrabCAD Print users, featuring:
- Advanced Color Assignment: designed to produce more accurate and consistent shades
- 10 New Optimized Teeth Shades: provides more options to replicate natural tooth colors and meet diverse patient needs
- 4 New Optimized Base Shades: each base shade offers 4 levels of translucency to achieve the perfect balance of opacity and depth
- New TrueDent Clear Appliances: for fully translucent models and try-ins
- Enhanced User Interface: for streamlined shade assignment and a more intuitive and efficient workflow
- VeroEco™ Bond 60 digitally applied material ensures a strong, durable connection while maintaining environmental sustainability. Perfect for fashion, automotive, and beyond, it's the ideal solution for seamlessly integrating printed parts onto textiles.
- When building support automatically for P3 printers, dental models placed flat on the build platform are skipped since they need no support. To override this when models are hollow and internal support is required, a new checkbox will force supports to generate.
GrabCAD Print 版本 1.93,八月 2024
- Print Pro: SUP710 support material is now available to select in the Support as Model Material feature for all Stratasys J3/5 printers.
- Introducing the Stratasys Origin Two printer and Origin One+ upgrade package! Both printers offer new materials and capabilities which you can read about here: Origin Two and Origin One+
- The section tool now supports setting the increment for stepping through sections as well as entering the position of the section in space.
- Wrap Model, described in the 1.79 release notes below, is now off by default for new projects using Stratasys F3300 printers. For all other FDM printers, Wrap Model remains on by default.
- VeroContactClear is now treated as a transparent material for all transparency-related features.
- Digital Materials (DMs) of ElasticoClear and MED610 were expanded for the Stratasys J5 MediJet and J5 Digital Anatomy Printer to include HS and LP print modes with SUP710 and WSS support materials.
- When WSS is the selected support material, "No Grid" becomes the only available support grid type.
- The following materials and their respective DMs were enabled for the Stratasys J5 Digital Anatomy Printer in HS mode: MED515, MED531, MED610, MED615, DraftWhite and MED-DABS IVORY-DM.
- A new preference is available in File > Preferences > P3 for the display colors of Model and Support in the tray prep view.
- Additional dental applications for Origin printers are now supported.
GrabCAD Print 版本 1.92,七月 2024
- Print Pro: The maximum number of instances in a 3D Array has been increased to 15,000 from 10,000.
- Print Pro: Exporting an assembly or selection is now possible, and the available output format now includes 3MF. Note that materials and colors assigned on a PolyJet printer are currently not exported.
- Print Pro: Accuracy Center is now available for SAF, and enables a printed part to be scanned and any deviation in the printed geometry can be used to print a part with corrected geometry. It can also be used to calculate a print quality score based on the deviation of the printed geometry from the loaded ‘CAD’ part
- Print Pro: Add inlay labels to multi-color models in GrabCAD Print for trays sent to Stratasys DentaJet Printers. Select one of the colors of the material loaded on the printer to use for the label.
- Print Pro: When using Support as Model Material for the J850 TechStyle or J850 Print Fabrix, support material cannot be used for adhesion layer.
- Stratasys Direct Parts on Demand can now be used to order parts and ship to Canada.
- A cloud-connected printer protected by Stratasys Shield is indicated with the same Shield icon as for local printers.
- Material usage and time estimation is now supported for ULTEM® 9085 Resin 0.2500 mm (0.0098 in) and 0.5000 mm (0.0197 in) slice heights on the Stratasys F3300 printer
- The adhesion layer under the Fashion Options panel is now checked by default for the Stratasys J850 TechStyle.
- For the P3 estimation results, model and support volumes are now separated. The Print Summary panel presents the total volume.
GrabCAD Print 版本 1.91,六月 2024
- Print Pro:新動作「將模型匯出為 STL」。選取單一組件、零件或主體,然後從右鍵功能表將其匯出為 STL 檔案。匯出的模型將包含在分析模式下進行的任何修復,以及套用的任何標籤。
- Print Pro:Print Pro 具有「在托盤上列印」、「在物件上列印」和智慧插入功能,這些功能以前僅適用於 J7/J8 系列印表機,現在適用於 J3/J5 系列印表機。
- GrabCAD Print 現在支援匯入 FBX (.fbx) 與 GLTF (.gltf, .glb) 檔案格式。
- 「碳纖維視覺列印選項」是 ABS-CF10 的新圖塊高度,可產生更光滑的表面效果,非常適用於零件視覺外觀對其應用很重要的情況。圖塊高度 (0.0050 英吋 0.1270 公釐) 適用於使用 T14H 列印噴頭的 F123 和 F123CR 系列印表機 (需要韌體版本 2.7)。
- Stratasys F900 印表機現在支援 OpenAM。材料套件是在使用 OpenAM™ 調整材料時建立的,並編譯、分發到 GrabCAD Print 和 F900 印表機。Stratasys 偏好和經過驗證的材料可以進行調整並包含在套件以及第三方開放材料中 (需要印表機韌體版本 4.23)。
- VICTREX AM™ 200 已新增至 Fortus 450mc 與 Stratasys F900 印表機的「已驗證材料」組合。VICTREX AM™ 200 是一種高強度、高機械屬性的 PEEK 基聚合物,耐高溫、耐腐蝕和耐化學性。使用 T14F 噴嘴可支撐 0.0100 英吋 (0.2540 公釐) 圖塊高度的 VICTREX AM™ 200,具有分離式 (SUP4000B) 和可溶性 (SR-100 Support) 支撐 (需要韌體版本 6.9)。
- 已更新 Nylon 12CF 收縮行為。當托盤的材料是 Nylon 12CF,且托盤包含稀疏填入和固體填入模型時,將使用固體填入的收縮率 (以 Z 為單位)。會顯示一則訊息通知使用者此項變更。當托盤上的所有模型均切換成固體填入或稀疏填入時,將使用所選填入風格的收縮率 (以 Z 為單位)。
- GrabCAD Print 在與 Stratasys F123 系列印表機通訊時支援 IPv6 位址,不包括 Stratasys F770 (需要韌件版本 2.7)。
- J5 DentaJet™ XL 及其 4kg 墨盒是 DentaJet 系列產品的最新創新。這款印表機專為大批量生產而設計,可滿足矯正器製造商、C&B 模型和植入物的需求,提供無與倫比的精確度。這是大規模製作完美產品的終極解決方案,同時也提供一種具有成本效益的解決方案,徹底改變工作流程。
- J5 Digital Anatomy 印表機允許在 J5 平台上列印獨特的數位解剖材料,包括 TissueMatrix、BoneMatrix、GelMatrix 和 RadioMatrix。可以使用多種解剖預設值來列印其生物力學行為類似人體組織的解剖模型。如需更多資訊,請按一下這裡。
- 現在,您可以選擇輸入色彩設定檔,以便在 PolyJet 上列印有顏色的模型。在「托盤設定」>「進階」下,在「sRGB (預設)」和新的 Adobe RGB 1998 設定檔之間進行選擇。Adobe 設定檔提供更飽和的顏色 (綠色/黃色/紅色),建議使用高飽和度的監視器,這能夠更好地知道列印結果會是什麼樣子。
- 支撐網格風格,之前已針對 J3/5 系列印表機鎖定,現在可以變更。注意:如果印表機裝有 TrueDent 材料,則將保持鎖定狀態。
- 對於適用的 PolyJet 印表機,「UV LED 配方」面板上現在提供以下作業:
- 儲存對私人配方的變更
- 將配方 (SSYS 或私人)另存為新的私人配方
- 重新命名私人配方
- 刪除私人配方
- 現在 SAF 的 3D 巢套設定 UI 中支援聚丙烯 (PP)
- 現在,「驗證」會報告軟性碰撞中所涉及物件之間的距離,讓使用者能夠決定是否可以繼續列印。
- 對於 P3 列印,您現在可以定義在開始新專案時會自動選取的預設材料和支撐設定檔。
- 對於 P3 列印,當您修改特定模型的支撐時,專案面板中的模型旁邊將出現一個警告圖示,並帶有「模型的支撐參數與托盤預設值不同」工具提示。
- 對於 P3 列印,當所有選取的模型都具有相同的支撐設定檔時,只需一個按鈕就可以自動產生其錨點和/或支撐結構。
GrabCAD Print 版本 1.90,五月 2024
- Print Pro:選擇托盤上的 STL 檔案時,右鍵功能表上將出現一個新動作「劃分」。「劃分」會將具有多個殼的 STL 檔案轉換為具有多個實體的組件。然後,「模型設定」可以套用至每個主體。如果只識別出一個殼,則模型不會變更。
- Print Pro:可以選取 Allerta Stencil 字型用於標籤。若要選擇此字型,請展開「標籤」下拉式功能表,然後選取「Allerta Stencil」。Atkinson Hyperlegible 字型仍然是預設字型。
- Print Pro:「組件名稱」模型屬性現在可以包含在「標籤範本」中。組件名稱具有與零件名稱相同的修飾詞 (開始/結束、略過和長度)。當沒有組件結構時,組件名稱和零件名稱的行為是相同的。
- Print Pro:「支撐作為材料」是 PolyJet 設定,允許您透過列印雙光面和亞光表面在設計上建立紋理效果,此設定已可供所有 J 系列印表機使用。
- 新檢視已新加到「檢視」工具列中。除了會將模型顯示為比色的「標準模式」外,新選項有「線框模式」和「線框比色模式」,分別可將模型顯示為透明或比色線框網格。新檢視與「預覽支撐的表面」不相容。
- GrabCAD Labs 新增了一個無需支撐結構即可在 FDM 中列印的選項。開啟該功能 (「檔案」>「偏好設定」>「GrabCAD Labs」),您將在「支撐設定」面板中找到「無支撐」作為「支撐樣式」選項。系統將列印該模型並附有底座,但沒有其他支撐結構。
- 已解決呈現完整高度犧牲塔時無法將模型重新定向的問題。
- 對於 SAF 列印,您現在可以選擇子巢套,以在定義的區域中建立巢套,並控制 X、Y、Z 大小尺寸,以及從套件任何所選邊角指定的區域原點其 X、Y、Z 位置
- SAF 標籤的最小文字大小已縮小到 10 pt。
- 對於 P3 列印,手動新增或移動的錨點將以與自動產生的錨點不同的顏色呈現。
GrabCAD Print 版本 1.89,四月 2024
在新「隨需零件」模式下,在 GrabCAD Print 中從 Stratasys Direct 取報價和訂購零件。適用於各種 FDM 材料和美國運送。
對於 FDM 列印,已解決為具有穩定器的模型產生的邊框大於所需大小時,導致其違反構建體積的問題。
- 儲存對私人配方的變更
- 重新命名私人配方
- 刪除私人配方
- 新的時尚功能:列印在服裝上。簡化的介面與新的創新「直接至服裝托盤」套件相容,使設計師能將複雜的 3D 元素直接整合在成品服裝上。
- H350 巢套面板中一個名為「已選取填滿」的新按鈕,允許您容納任意數量的單個零件副本。
- 對於 P3 列印,現在一旦所有模型共用相同的支撐設定檔,您便可以在一次作業中為多個模型產生錨點和/或支撐。
- 對於 P3 列印,某些材料 (主要是彈性體) 在產生高支架時,需要額外的支撐強化。您可以控制每個支撐設定檔、每個托盤或每個特定型號的強化類型。「SSYS 彈性體」設定檔已修改以設定此選項。
- 對於 P3 列印,「材料」定義為每個材料提供預設排列參數:「模型之間的空隙」和「列印邊界的空隙」。OpenAM 使用者可以修改其私人材料的這些值。任何使用者都可以修改每個托盤的這些參數 (透過「排列」面板)。
GrabCAD Print 版本 1.88,三月 2024
- Print Pro:GrabCAD Print Pro 現在包含 PolyJet 的功能!這些功能包括以前只能透過 PolyJet 研究套件取得的功能...
- 直接印在托盤上 (僅限 J7/8 系列) — 允許在如玻璃或碳纖維等材料上列印,在零件的下方建立完美的表面效果,無需在下方進行後處理。
- 空氣作為材料 (僅限 J7/8 系列) — 允許使用空氣代替樹脂,以顯著減輕零件的重量,進而省下多達 30% 的材料。
- 智慧插入™ (僅限 J7/8 系列) — 允許將各種功能/裝飾元素直接嵌入到列印中。
- 在物件上列印 (僅限 J7/8 系列) — 透過直接列印到各種基材上,允許模型自訂和個人化。
- Voxel Print 應用程式 (僅限 J7/8 系列) — 用於列印由其他軟體定義的圖塊資料的工具,允許控制模型的每個細節,包括體素等級的顏色、透明度和邵氏硬度。
- ...其他新功能...
- 支撐作為材料 (僅限 J750 和 J850 Prime) — 允許透過列印雙光面和亞光表面,在設計上建立紋理效果。
- 液體作為材料 (僅限 J7/8 系列) — 允許建立中空空腔,例如微流控結構、中空管、液壓零件等。
- 高速模式 (僅限 J55) — 保持相同的圖層厚度,但在使用 2 材料時以兩倍速度作業。
- ...以及 Print Pro for FDM 和 SAF 中已經提供的一些功能:
- 標籤
- 厚度分析
- 組裝/解散
- 第 3 方外掛程式
- Print Pro:匯出的預估結果現在使用 hh:mm 時間格式,因此更容易包含在計算中。
- GrabCAD Print 現在支援以下 CAD 版本:
- 實體作品2024
- Inventor 2024
- NX 2306 系列
- 新迪3D2024
- .X_T 36
- .JT 10.9
- 數位材料 (DM) 是 Agilus CMY 和 VeroUltraWhite、VeroPureWhite 或 VeroClear 的混合體,現在可用於允許使用這些材料的所有列印模式中的所有 J7/8 系列印表機。DM 名稱都有前置詞 FLXAC。
GrabCAD Print 版本 1.87,二月 2024
- Print Pro:Pro 專案的預估結果現在包括「托盤/巢套摘要」和「組建報告 (每個零件)」標籤中的成本預估。成本費率可在預估結果視窗的新標籤上或從「印表機設定」中進行設定。
- 「部分檢視」已新增至檢視器頂部的控制條中。這允許您查看模型的特徵 (否則這些特徵可能會被擋住),並且可以與測量工具或 Origin 的支撐產生工具結合使用。啟用「部分檢視」後,下方按鈕允許您選擇劃分平面和方向,也可以使用拖曳控點以其他角度進行劃分。
- 預估結果視窗中的文字現在是可選的,可以使用 Ctrl+C 複製到剪貼簿。
- 「位置」工具過去僅適用於 PolyJet 和 Print Pro 專案,現在可用於 Print Standard 中的所有技術。
- F123 系列印表機上「加厚薄壁」的預設設定已變更為「關閉」。
- 已修正零件殼中的輪廓以及在某些情況下未產生其相鄰填充物的問題。
- Stratasys F3300 是一款新型大幅面工業 FDM 印表機,現在可在 GrabCAD Print 中進行選擇。請在這裡了解 Stratasys F3300 的功能和性能,或從印表機範本清單中加以選擇以查看可用的材料和設定。
- PolyJet 支援視覺化功能,位於檢視器頂部的檢視控制條中,透過以藍色顯示支撐區域,而非以棋盤圖案顯示,而提高可見性。
- 此選項會將零件置於托盤在螢幕上顯示的實際位置,而不會最佳化列印程序。使用「絕對位置」時,可能會影響小零件的列印品質。
- 在 1.83 更新中為其他技術新增的測量工具,現在可用於 PolyJet 列印準備中。
- 對於 SAF 專案,現在提供了功能強大、動態的組建報告版本。從預估結果中,選取「組建報告」,然後從右上角的匯出下拉式清單中選擇「HTML」。產生的檔案可以在任何 Web 瀏覽器中開啟,並包含巢套和每個零件的預估,以及巢套與每個零件的互動式 3D 預覽,顯示其在巢套中的位置。此外還有一個搜尋工具可以協助按名稱尋找特定零件。
- 現在會預覽「燒結箱」的標籤,因此可以清楚地看到標籤是否適合可用空間。
- 對於 P3 專案,現在已修正會阻止接受 Z 補償值的錯誤。請注意,仍然有一條規則,即 Z 補償不能超過支撐零件穿透值。
- For P3 projects, two new values are added to the Anchor Points settings under "Extra Island Support" which add additional anchor points around the first contact with an island and carry default settings per support profile:
- 觸點支撐半徑:觸點第一個證據周圍的半徑,該觸點將收到額外的錨點。
- 觸點內部間距:這些附加錨點之間的間距。
- Additional updates for P3 support parameters:
- 對於工業模型,最大腳部直徑已從 10 增加為 30 公釐。
- 對於牙科模型,零件穿透可以是 0。
GrabCAD Print 版本 1.86,一月 2024
- 已修正 FDM 工具路徑計算導致大部分零件違反構建體積或小零件相互干擾的問題。
- 3D 檢視器已針對 PolyJet 列印準備進行更新。即將推出的功能需要此更新,但現在您應該不會注意到任何變更。然而,您可以視需求在「檔案」>「偏好設定」>「PolyJet」中切換回舊檢視器。
- 使用 GrabCAD Voxel Print 應用程式建立的檔案 (.gcvf 檔案) 現在可以由任何使用 J 系列印表機的人匯入。現在使用體素列印應用程式建立 .gcvf 檔案仍需要授權,但允許所有人匯入檔案。
- 已擴展在「多組合」列印模式中使用少於 7 個模型材料的選項 (透過對其他色版使用清潔劑),以包含「高品質」列印模式。
- 適用於 J5 DentaJet 使用者的三個更新
- 現在,當您選擇使用 TrueDent 材料的 J5 DentaJet 印表機時,會顯示 TrueDent 材料的 IFU (使用說明)。
- TrueDent 列印的「模型設定」面板已修改,以提高可用性。輕鬆選擇牙齦和牙齒比色的收藏夾和預設材料。
- J5 DentaJet 使用者現在可以使用 Exocad Model Creator 以利用點對點工作流程,從口腔內掃描到全彩列印模型。GrabCAD Print 中的新色彩設定檔允許與 Exocad 進行顏色比對。
- Origin 印刷的固化流程會導致多餘的材料堆積在朝下的表面上,稱為過度固化。一個名為 Z-Compensation 的新參數會透過向上偏移這些表面來修正此問題。
- 對於 Origin Dental 使用者,「篩選空洞中的支撐」選項將顯示一條新的警告訊息,通知您一些必要的支撐可能已遭移除。
- 當 P2P Strut 因長度或高度限制而不可行時,支撐產生將自動使用 P2P 支架。
GrabCAD Print 版本 1.85,十二月 2023
- Print Pro: 標籤的兩個更新
- 現在可以透過標籤面板中的按鈕以一次作業刪除所有標籤。
- 現在建立範本標籤時,可以預覽零件上的標籤文字,並在調整大小、位置和旋轉時提供視覺輔助工具。
- J8 系列印表機現在可以使用清潔液墨盒取代 7 材料列印模式中的模型材料。使用此功能,您最多可以將清潔液裝入 4 列印通道並繼續列印,允許您在交換材料的同時進行列印。
- 您現在可以將列印作業傳送到裝有 2 材料的 Connex3 印表機,這稱為 DM2 模式。(注意:在「檔案」>「偏好設定」>「PolyJet」中需要停用「進階切片機」)
- 在 HQ 模式下列印時,使用一個 UV 燈的選項已變成 J850 Prime、J850 Prime Fabrix、J850 Pro、J835 和 J750 的預設選項。
- 混合體內解剖材料與其他模型或支撐材料的比例是有限的。這些限制的驗證已新增到每個噪音調製步驟中。已修正 SUP706 的限制:SUP706 與 BoneMatrix、任何 Agilus30 材料或任何 Vero 材料混合時,在外層中必須小於 50%。
- Fashion 選項改善
- 無需開啟「配方」面板即可選取「UV LED 配方」。
- 「配方」面板由「管理配方」按鈕開啟。
- 圖塊總數包括定義的「附著力托盤」。
- 「取消」按鈕已新增到 Origin 印表機的「錨點」和「產生支撐」流程進度列中。如果錨點或支撐結構已產生,則將被移除。
- 在「錨點」和「支撐」面板中修改參數時,「支撐設定檔」名稱現在會在「支撐設定檔」名稱附近顯示星號 (*),以表示變更未儲存。請使用「重新設定設定檔」按鈕重設修改後的參數。
GrabCAD Print 版本 1.84,十一月 2023
- Print Pro:導入間隙分析!厚度分析工具已增強,允許使用者偵測模型中低於印表機解析度的間隙 (例如口袋),這可以在「厚度分析」面板中的新「間隙」標籤上找到。
- Print Pro:準確度中心 WAM 功能現在可以提供更高的準確度改進,並允許使用者反覆運算,即使是最具挑戰性的專案也能提高品質。
- 為 Fortus 450mc 導入的驗證材料 1.75 現在可用於 F900。這些材料在用於程式設計和列印作業之前,會使用基本的可靠性測試進行驗證。驗證材料需要韌體版本 4.22 安裝在 F900 上,並且僅適用於 0.0100 英吋 /0.2540 公厘的圖塊高度。
- FDM HIPS (耐衝擊聚苯乙烯)
- Kimya PC-FR (阻燃劑)
- ULTEM™ 9085 樹脂的新顏色 (紅、飛機灰、炮艇灰、夢幻灰、白色 7362 和 Jana White)
- PC 的新顏色 (紅色)
- PC-ABS 的新顏色 (紅)
- (測試版) VICTREX AM™ 200 PAEK (低熔點)
- 對於 PolyJet,Fashion 印表機的附著力托盤已得到改善。先前,當列印帶有附著力托盤的亞光模型時,附著力托盤被列印在模型及其周圍支撐的下方。當支撐物被移除時,附著力托盤可能仍殘留在模型周圍。最新更新後,僅在模型下方新增附著力托盤,這避免了移除支撐時附著力托盤殘留的問題。
- 我們解決了 PolyJet Objet30V3 和 V5 印表機中更新至 GrabCAD Print 1.83 後列印作業開始失敗的問題。
- 對於 SAF,「3D 巢套」面板現在以 X / Y 形式報告額外進度資訊,以便使用者可以清楚地看到選取了多少模型,以及目前包含在巢套中的模型數量。
- 對於 P3,導入了參數自動校正功能。每當使用者為含有效範圍的任何參數輸入無效值時,該值現在會自動修正為最接近的有效值,並顯示自動修正有效範圍的工具提示。
GrabCAD Print 版本 1.83,十月 2023
- Print Pro:構建報告現在可以預估使用清除零件或犧牲塔的印表機清除材料。
- Print Pro:構建報告現在包括作為 Excel 或 CSV 匯出一部分列印個別零件所需的時間估計值。
- Print Pro:當預估匯出至 Excel 檔案時,構建報告和托盤摘要現在會作為相同文件的單獨工作表包含在內。
- 推出測量工具!現在可以測量點到點、平面到點或點到平面的距離,並且可以選擇貼齊至頂點。FDM、SAF 和 P3 專案支援測量。
- 現在可以透過醒目提示模型並選取滑鼠右鍵功能表上的「重新命名」命令,在「專案面板」或「模型檢視器」中重新命名零件、組件和本體。
- 按右鍵功能表中新增了新的選取選項。「全選」現在可以套用至整個專案或僅套用至目前的托盤。至於新選項「反向選擇」可將選擇翻轉為目前托盤或整個專案上未選取的部分。
- 對於 H350 列印,視圖控制條中提供了兩個新選項:
- 「著色」可為巢套中的零件新增隨機顏色,以更好地視覺化密集的封裝。
- 「圖層線視覺化」會顯示向上或向下表面上的線條,其中圖層在最終列印中可能是可見的。
- 對於 P3,新增了一個新工具以在 GrabCAD Print 中產生支撐結構。現在您可以使用 GrabCAD Print 充分準備您的 CAD 檔案並傳送以進行列印,而不需額外的軟體。
GrabCAD Print 版本 1.82,九月 2023
- Print Pro:「分析」模式下一項名為「厚度分析」的新功能可讓使用者快速確定其零件是否包含低於印表機解析度的幾何結構。解析度是根據印表機技術預設設定的,使用者可以設定自己的值。顯示可以是二元的紅色失敗/綠色通過或連續的黃紅色漸層。遊標也提供了「探針」來顯示零件上任意點的特定值。
- Print Pro:現在可以為 FDM 3D Array 命令使用較小和負的間距值,可以更緊密地安排托盤上的零件。
- 現在可以隱藏托盤,從而可以更好地檢視緊密封裝零件的下方。
- GrabCAD Print 與 Stratasys H350、Fortus 450mc、Stratasys F900 和 Fortus 900mc印表機通訊時支援 IPv6 位址。Fortus 450mc 的 IPv6需要韌體版本 6.8。Stratasys F900 和 Fortus 900mc 需要韌體版本 4.22 以支援 IPv6。
- 推出 TrueDent™,FDA 核准的 (II 類) 樹脂,專為在 J5 DentaJet 平台上對假牙、臨時牙冠和牙橋進行 3D 列印。它可以在單一混合托盤上批次產生高度美觀、整體式、多重色彩的牙科器具。雖然 TrueDent™ 目前在特定地區推出,但它為尋求提高生產力和卓越結果的牙科實驗室提供了一個有前景的解決方案。
- 版本 1.81 中,新增了用於啟動/停用進階紋理處理的偏好設定。此核取方塊已移至「托盤設定」(在「進階」部分下),允許使用者確定每個作業的值。對於 J55 Prime 和 J850 Prime,預設會清除該核取方塊,這會列印帶有紋理的重型托盤。
- DAP 印表機上的結構心臟模型中新增了凝膠塗層 (如血管模型中所定義)。
- 對於 SAF 列印,燒結盒現在可以有一個使用者定義的標籤作為盒子幾何結構的一部分,使您能夠分解結構以瞭解燒結盒中包含哪些零件。長標籤會自動與燒結箱的最長軸對齊。
- 對於 SAF 列印,對於需要額外空間以改善熱管理的特定選定零件,可以覆寫巢套的最小間距值。
- 對於 SAF 列印,您現在可以選擇巢套作業是新增至巢套的現有內容還是清除巢套並重新開始。
- 對於 P3 列印,「適應托盤」選項應啟動方向改進,這會逐步旋轉模型,直到符合列印區域。
- 對於 P3 列印,所有牙齒支撐設定檔都應具有一個新參數,以篩除凹陷處上面向 90 之牙膠模型的錨點。
- 對於 P3 列印,當建立錨點時,可支撐區域將根據所選支撐設定檔中指定的自我承重角度進行著色。
- 擁有 P3 On-Prem 雲端的 GrabCAD Print 使用者可以在非管理員帳戶下執行 GrabCAD Print。
GrabCAD Print 版本 1.81,八月 2023
- Print Pro:準確度中心現在採用「原始」和「驗證」視圖的標籤。「原始」標籤顯示原始列印零件的精確度結果 (熱圖和列印準確度分數 (PAS))。「驗證」標籤允許使用者上傳 WAM 列印的掃描,以準確查看準確度提高的程度。它會顯示新的 PAS 與原始分數的比較,並且新的直方圖顯示時具有原始分數疊加的灰色輪廓,您可以輕鬆看到特定誤差範圍的減少。
- Print Pro: 準確度中心的新 WAM 控制可在水平表面上獲得更好的結果:
- 保留 (現在是預設) 僅允許對水平表面進行統一的垂直調整,以保持美觀並避免新增輪廓線至光滑水平區域。
- 釘選可防止水平表面發生任何移動。
- 自由調整允許水平表面自由去翹曲,包括在水平表面內新增輪廓,以實現最大準確度,其中貼合性優先於美觀。
- Print Pro:在準確度中心新增了所選掃描檔案的快速預覽,以協助使用者選擇正確的掃描檔案。
- Print Pro:準確度中心直方圖的 Y 軸現在會顯示每個誤差等級長條圖佔總組件的百分比,因此您現在可以看到組件的百分比高於或低於或處於所選允差範圍內。
- Print Pro:在準確度中心內比較掃描時,當您將滑鼠移到比較結果上時,現在會動態顯示列印和掃描組件的局部差異 (例如,該點的誤差與設計)。
- 對於擁有本機集線器和 OpenAM 授權的 P3 使用者,上傳「每一圖層設定」檔案時的問題已修正。
- 對於 P3 使用者,「模型插入設定」下的偏好設定「當模型不適合目前平台時自動建立托盤」現在適用於 P3 印表機,就像在其他平台上一樣。
GrabCAD Print 版本 1.80,七月 2023
- 2023 GrabCAD Print 中支援的 CAD 檔案版本如下:SOLIDWORKS 2023、SolidEdge 2023、Siemens NX 2212。
- Print Pro:現在可以將臨時文字標籤新增至 FDM 零件 (STL 和 CAD),它們可以進行浮雕或壓印,並且可以控制文字大小、深度和間距。此外,還可以建立可重複使用的標籤範本,這些範本可以嵌入文字、零件名稱,以及產生唯一的序號。按一下這裡以瞭解有關 GrabCAD Print Pro 的更多資訊。
- 對於 SAF 巢套,巢套方法的名稱已從「標準」和「進階」變更為「無互鎖」和「精簡」,讓使用者更瞭解其功能。現在的預設方法是「精簡」(先前稱為「進階」),通常會產生更密集的巢套。
- 對於 SAF,驗證在某些情況下可能非常緩慢,因此如果您需要對巢套進行進一步編輯,現在可以取消驗證程序。
- 全新的 VeroEcoFlex 系列半彈性材質現已可供 J850 TechStyle 使用者使用。在這裡閱讀更多內容。
- 大多數 PolyJet 印表機使用 UV 汞燈,但 J850 TechStyle 以 UV LED 取而代之。新型 UV LED 能夠實現更準確的固化,這對於具有輕薄特徵的小型時尚建模至關重要。GrabCAD Print 中的 UV LED 配方功能提供了一種將 UV 功能控制到特定圖塊或圖塊範圍的機制。您可以在列印程序的任何部分控制要使用的 LED 以及每個 LED 的密度。
- 我們解決了 GrabCAD Print 中 P3 機器未儲存為我的最愛的問題。此問題已修正,而使用者現在可以將機器指定為自己的最愛。
- 此前,存在 P3 作業長時間作業預估無法正確顯示的問題。這導致完成時間大幅縮短。我們已經解決了這個問題。
- 我們解決了 P3 中某些具有特定設定的材料無法開始列印時出現的問題。使用者將不再遇到此問題,而作業將如預期開始列印。
- 對於擁有 OpenAM 授權的 P3 使用者,材質設定檔下的「縮放」範圍已擴大,現在是 +2% 到 -1%,因此可以更好地調整縮放比例以補償樹脂收縮。
- 對於擁有 OpenAM 授權的 P3 使用者,我們修正了「上傳每一圖層設定」功能在某些情況下無法發揮最佳效能的問題。
- 對於擁有 OpenAM 授權的 P3 使用者,我們修正了新製作材料的作業無法開始列印的問題。
GrabCAD Print 版本 1.79,六月 2023
- 包覆模型工具可用於群組,其中成員主體可以具有個別的設定。此功能預設為啟用狀態。包覆會將模型主體封裝在常見殼中。當模型中主體之間的接合點並未設計為可承受壓力,殼將提高強度。當主體之間的接合點設計為可承受壓力,就不需要包覆功能,而且可以將其關閉。
- 與 CMB 匯入相關的衝突現在清楚描述新增的檔案與此專案不相符的地方。
- ASA 現在可用於 Stratasys F770 印表機,顏色有:白色、黑色、淺灰色、藍色、紅色、黃色。
- J3/J5 DentaJet 的底座高度增加至 1 公釐以改善附著力。
- J850 Prime FabriX 中新增「包裝最佳化」選項。此選項可改善透明包裝物體 (如瓶子) 的列印結果。
- 在 P3 印表機托盤設定下的縮放工具上,測量單位已從一個小數位增加到三個小數位。此增強功能可提升測量精確度和提供更精細的功能調整。
- 為 P3 印表機匯入圖塊堆疊現在支援帶有任何前置詞的堆疊檔名,例如,layer_xxx、slice_xxx 等。
- 對於擁有 OpenAM 授權的 P3 使用者,現在提供新的下載材料設定功能。其可讓您下載包含有關材料的第一層 + 過渡層資訊的 CSV 檔案。若要取得此資訊,請前往材料庫、選取材料,然後按下在「每層設定」表上方的「下載設定」按鈕。
- 專案面板現在會在使用鏡像命令建立的任何模型旁邊顯示圖示。
- 對於 SAF 列印,巢套進度條現在會告知使用者何時進行巢套以及何時進行驗證。
GrabCAD Print 版本 1.78,五月 2023
構建號 1.78.18.27879 發佈于 16 五月 2023
- GrabCAD Print Pro 現已推出!功能包括翹曲已適應模型、按零件的預估、製造範本等。
- 閱讀 Pro 版功能的完整清單
GrabCAD Print 內部用於呈現 FDM 作業螢幕圖形的軟體已更新,因為許多新功能都需要此功能。儘管舊檢視器會在未來淘汰,但現在仍可透過偏好設定功能表使用。
對於 FDM,外部輪廓的連結行為會更新為一律使用為模型材料和圖塊高度定義的行為。過去,會針對某些使用個案連結外部輪廓,而忽略材料連結行為。
Nylon-CF10 現已上市,可為 Stratasys F370CR 和 F190CR 印表機提供分離式支撐。SUP4000B 支撐材料提供了無罐支撐移除解決方案,並透過易於移除的分離式支撐縮短分離時間。SUP4000B 使用與 QSR 相同的支撐頭,以及與 Nylon-CF10 相同的圖塊高度 (0.0130 吋/0.3302 公釐;0.0100 吋/0.2504 公釐;0.0070 吋/0.1778 公釐)。
Nylon-CF10。具有分離式支撐的 Nylon-CF10 需要將印表機韌體更新至 2.6 版。
已更新具有 QSR 支撐的 Nylon-CF10 材料定義,以改善 0.0100 英吋 (0.2504 公釐) 和 0.0130 英吋 (0.3302 公釐) 圖塊高度。
提高構建時間和材料體積預估的準確性,以便:
- 在 Fortus 900mc 印表機上使用 T40A 噴嘴的 0.0200 吋 (0.5040 公釐) ASA
- 在 Stratasys F900 印表機上使用 T40C 噴嘴的 0.0200 吋 (0.5040 公釐) Nylon CF12 (黑色)
- 在 Stratasys F900 和 Fortus 900mc 印表機上使用 T40A 噴嘴的 0.0200 吋 (0.5040 公釐) ULTEM 9085 樹脂黑色。
- 按一下 P3 作業的「列印」按鈕後,您可以在「列印摘要」視窗中,輕鬆放大第 1 層或托盤預覽縮圖。您就可以在列印之前仔細查看第一個圖塊的細節。
- 如果模型位於 P3 作業的構建體積之外,專案面板視窗上將顯示橙色驚嘆號通知,將滑鼠停留在其上將可看見問題描述。
- 對於擁有 OpenAM 授權的 P3 使用者,GrabCAD Print 現在支援上傳包含「edgeBuildingCompensation」值的每層設定。上傳後,該欄將顯示在每層設定表中。
GrabCAD Print 版本 1.77,四月 2023
構建號 1.77.13.26873 發佈于 18 四月 2023
- 切換列印技術而無需開始新專案的能力已恢復。
- PolyJet:當變更特定組件的牙齦比色時,組件及其殼會複製並標記為隱藏在托盤樹狀結構中。(隱藏組件是為了簡化「撤銷」操作而建立的,此操作極其複雜。) 從現在起,您在樹狀結構中將看不見這些組件,而撤銷操作將繼續正常進行。
- SAF:您現在可以選取零件並建立單一燒結箱,來容納和保護零件、指定孔洞尺寸、光路厚度和間距。
- P3:過渡層參數經過最佳化,現在可在經過驗證的材料上自動處理。先前會在「材料屬性」下顯示此功能,但現在已隱藏。
- P3:先前的問題是,以英吋定義的模型在列印前會變更為公釐,而此問題已修復。
GrabCAD Print 版本 1.76,三月 2023
構建號 1.76.10.25761 發佈于 21 三月 2023
- 匯入 CMB 時檔案類型為堆疊 (*.zip) 的問題已恢復為 CMB 檔案 (*.cmb、*.cmb.gz)。
- 若是 P3 列印,您將在「托盤設定」/「材料屬性」下看到新的縮放參數。如果列印零件受到材料收縮的影響,此參數將有所幫助,您可以在作業級別編輯和最佳化材料的縮放值。
- 若是 P3 列印,您將在「托盤設定」/「材料屬性」下看到新的額外基礎層參數。如果零件的 Z 高度低於 CAD 設計,此參數將有所幫助。新增額外的基礎層將複製第一層,以補償其高度損失。
- 對於擁有 OpenAM 授權的 P3 使用者,使用 CSV 列印修改後的「每層設定」現在可以正常運作。
GrabCAD Print 版本 1.75,二月 2023
構建號 1.75.13.24793 發佈于 21 二月 2023
- 為了提升軟體的效能,切換到不同技術的印表機 (例如從 FDM 到 PolyJet) 將需要開始新的專案檔案。在將模型新增到專案之前,您可以在印表機技術之間自由切換。
- 為 Fortus 450mc 印表機進行程式設計作業時,您現在可以在 GrabCAD Print 中使用經過驗證的材料。在將這些材料用於程式設計和列印作業之前,會使用基本的可靠性測試對其進行驗證。驗證材料需要在 450mc 上安裝韌體版本 6.7。
經過驗證的材料 | 可用圖塊高度 | 模型提示 | 支撐材料 | 支援提示 |
FDM HIPS (耐衝擊聚苯乙烯) | 0.0100 吋 (0.2540 公釐) | T16 | SUP1500B | T12 |
Kimya PC-FR (阻燃劑) |
0.0100 吋 (0.2540 公釐) | T16 | SR100 | T12SR100 |
ULTEM™ 9085 樹脂的新顏色 (紅、飛機灰、炮艇灰、夢幻灰、白色 7362 和 Jana White) | 0.0100 吋 (0.2540 公釐) | T16 | SUP8500B | T16 |
PC 的新顏色 (紅、黑) | 0.0100 吋 (0.2540 公釐) | T16 | SR100 | T12SR100 |
PC-ABS 的新顏色 (紅) | 0.0100 吋 (0.2540 公釐) | T16 | SR100 | T12SR100 |
(測試版) VICTREX AM™ 200 PAEK (低熔點) |
0.0100 吋 (0.2540 公釐) | T14E | SR100 | T12SR100 |
(測試版) Covestro Addigy® PA6/66-GF20 FR LS (玻璃填充尼龍,阻燃劑) |
0.0100 吋 (0.2540 公釐) | T20G | SUP4000B | T16 |
- GrabCAD Print 中現在支撐材料套件。材料在 OpenAM™ 中經過調整、編譯並分發到 GrabCAD Print 和使用 OpenAM 授權啟用的 Fortus 450mc 印表機時,便會建立材料套件。Stratasys 偏好和經過驗證的材料可以進行調整並包含在套件以及第三方開放材料中。材料套件需要的印表機韌體版本為 6.7。
- 修復了 CMB 副本 (或複製/貼上) 的刀具路徑與原始 CMB 不同的錯誤。
- J3 DentaJet™ 以 J35 平台為基礎,是適用於中小型牙科實驗室的入門級 PolyJet 印表機。其可以產生三種生物相容性材料的混合托盤,包括大量移植模型、手術導引板和牙齦遮罩,所有這些都在同一個托盤上,並且具有無與倫比的準確度。請在此處查看新款 J3 DentaJet™。
- 現在,僅當 GrabCAD Print 和 Job Manager 的版本不一致時,才會出現提示 PolyJet 印表機 Job Manager 升級的警報。先前,當新版本可用時,就會出現警報。
- 現在可以向紋理 VRML 模型新增塗層以進行 PolyJet 列印。
- 若是 SAF 印表機,PA12 材料 (測試版) 現已可供使用。在這裡閱讀更多內容。
- 若是 SAF 印表機,新的右鍵點擊選項可讓您選取在預估或驗證後無效的任何模型。
- 若是 SAF 印表機,在某些情況下,有角度的零件會因切割而出現很小的表面偽影,切割演算法的準確度已提升,以避免此問題。
- 對於無需網際網路存取的 P3 列印,現在支援透過 Origin Local Hub 連接到 Origin One Local 印表機 (詳細資訊請參閱 Stratasys 支援中心下的 Origin One Local 參考指南)。請參閱此處的連接說明。
- 若是 P3 印表機,您現在可以使用以下命令匯入由 Netfabb 等應用程式建立的圖塊:「檔案」>「匯入圖塊堆疊」。
GrabCAD Print 版本 1.74,一月 2023
構建號 1.74.8.23921 發佈于 17 一月 2023
- 使用 FIPS 相容加密的 Windows 安全設定之前曾封鎖 GrabCAD 產品的印表機連線,而 GrabCAD Print 和 Print Server 的此問題已解決。在 PolyJet Job Manager 安裝所在的系統上仍必須停用 FIPS。
- 3DConnexion Spacemouse 支援(於 1.55 引進)現已恢復。
- 當托盤材料包含所有彩色 VeroFlex 材料時,均為所有 J7xx/8xx 印表機啟用 VeroFlex 材料的 CMYK 輸入。
- 已將邊緣補償新增到 Origin 印表機的材料參數中。這個新工具可讓您在每個圖塊中的模型邊緣增加或減去微米。如果您看到的特徵(例如孔洞)稍大或稍小,但又不想變更模型的縮放比例,此工具將有所幫助。
GrabCAD Print 版本 1.73,十二月 2022
構建號 1.73.5.23276 發佈于 20 十二月 2022
- 您���也無法透過工作台新增模型。請在此處的部落格文章中閱讀更多有關淘汰 GrabCAD Workbench 的資訊。
- 若是 PolyJet 牙科印表機,列出用於與 3Shape 整合的牙齒和牙齦比色名稱的檔案已更新,並新增 1.72 版本中的新比色。此外,當開啟舊專案或內含不存在比色名稱的作業時,比色名稱應為空且會出現通知。如果使用者選取的預設值是使用不存在的比色,則將自動設定預設比色。
- GrabCAD Print Manufacturing 備註現可用於 H350,如此可讓使用者為模型新增註解並建立 PDF 報告,內含模型螢幕擷取畫面和 PDF 隨行文件中的備註。
- 此外,H350 的錯誤已修復,現在會以正確的尺寸顯示標籤預覽。
GrabCAD Print 版本 1.72,十一月 2022
構建號 1.72.6.22542 發佈于 16 十一月 2022
- 在 Stratasys F900 印表機上為尼龍 12 CF 新增 0.0200 英吋 (0.508 公釐) 圖塊高度,這能夠加速大型零件的流通。此圖塊高度使用 T40C 模型提示。
- g在 Stratasys F900 和 Fortus 900mc 印表機上為 ULTEM™ 9085 樹脂、ULTEM™ 9085 CG 樹脂和 ULTEM™ 9085 黑色樹脂新增 0.0200 英吋 (0.508 公釐) 圖塊高度。新圖塊高度能夠加速大型零件的流通。此圖塊高度使用 T40A 模型提示。
- H350 「3D 巢套」中選取的模型在視覺上可以隔離的,因此會隱藏所有未選擇的模型,當使用者完成對隔離模型的工作時,他們可以再次顯示所有模型。請注意,這些作業不會變更「3D 巢套」中任何零件的位置。
- 對於 H350,可以選擇使用 Assemble 命令或分組的 3D Array 所建立 CAD 中的任何裝配,並可以分解裝配結構,留下單獨的模型。
- H350 的預估現在報告整個巢套和模型的質量,還有整個巢套的 HAF 流體。
- H350 的標籤命令現在會記住命令使用之間的設定,因此可以更快速地建立一系列的手動標籤,因為浮雕/壓印、文字大小等保持不變。
- 對於 J5 DentaJet,部分牙齒比色有所改善、顏色更準確,並新增了兩種新比色。
- 對於 J5 DentaJet,牙齦比色有所改善、具有更佳紋理,並新增了四種新比色。
GrabCAD Print 版本 1.71,十月 2022
構建號 1.71.7.21930 發佈于 18 十月 2022
- J5 DentaJet 使用者現在使用 3Shape 的 Dental System 軟體和 GrabCAD Print,即可以利用從口腔內掃描到全彩列印模型的端對端工作流程。當使用 VeroDent PureWhite 和 Vero CMYK 列印時,3「Shape 色彩模型設定檔」已新增至 J5 DentaJet。請注意,這需要 3Shape Dental System 軟體的 2022 版。
- 將作業傳送至「進階切片機」已啟用的 Connex 印表機時,列印確認畫面中會出現一則通知。
- 在「超高速」模式下使用 J7/J8 系列印表機列印的作業未出現在排程檢視中,此問題現在已修復。
- H350 的3「D 巢套」區域現在可以透過按一下專案面板上的預覽來重新命名,這類似於重新命名 FDM 或 PolyJet 的托盤,這會變更傳送到印表機的作業名稱。
- 在 H350 上為預估產生的報告內容現在可以複製並貼到其他檔案中 (例如試算表),或下載為 .XLSX 或 .CSV 檔案。
- 沒有 OpenAM 授權的 P3 使用者現在可以透過 GrabCAD Print 獲得準確的預估結果。在我們最新的部落格文章中可深入瞭解。
GrabCAD Print 版本 1.70,九月 2022
構建號 1.70.12.21501 發佈于 21 九月 2022
- GrabCAD Print 現在支援 Windows 11作業系統。如需完整的系統需求,請按一下此處。
- GrabCAD Print 現在支援來自最新版 CAD 軟體的檔案,包括 Creo9、Inventor 2023、NX2206 和 Parasolid 34.1。
- GrabCAD Print 現在支援 Origin One 和 Origin One Dental 印表機。在「檔案」>「偏好設定」>「P3 DLP」下登入您的 Origin 帳戶後,您可以設定作業並傳送到您的印表機。請於此處深入瞭解。
- 對於 FDM 專案,當擷取專案後找不到所選的印表機時,GrabCAD Print 現在會保留作業設定。已解決設定套用印表機預設值的問題。
- Stratasys F370、F270 和 F170 印表機現在支撐 T14H 強化擠壓噴頭。噴頭有 1500 小時的壽命,是使用 ABS-CF10 材料進行程式設計作業的預設選擇。
- 對於牙科用 PolyJet 印表機,現在可為牙齦複選指派的比色。但是,每個組件僅限一個外殼。
- 在 J850 Prime Fabrix 和 TechStyle 中,黏著劑層的有效厚度增加到 3 公釐。
- PolyJet 程式錯誤修復:
- 在 J850 Prime Fabrix 和 TechStyle 中,在具有計劃停止情況下儲存的專案在沒有計劃停止的情況下開啟。
- 在 J5 DentaJet 上,當開啟有效專案時驗證失敗。
- 在 SHS 模式的 J5 DentaJet 上,模型和支撐材料的總預估有誤。
- 以下命令已新增至 H350 的「3D 巢套」檢視,讓使用者能夠只在「3D 巢套」檢視中工作:分析模式、單位、比例、新增模型、在 X、Y 平面中自由拖曳。
- 建立多個模型的 H350 建構,其中包含一些因過大而無法巢套的模型將不再導致整個巢套作業失敗。系統將巢套適合的模型,並會發出警告列出過大而不適合的模型。
- 對於 H350,當使用名稱或數字自動功能建立模板標籤時,會自動檢查語法,如果不正確,會以紅色突出顯示,工具提示也會詳細說明錯誤。
GrabCAD Print 版本 1.69,八月 2022
構建號 1.69.12.20542 發佈于 16 八月 2022
- J5MediJet™ 現在支援兩種新樹脂
- Biocompatible Digital ABS Plus™ 旨在透過結合耐高溫性和韌性,來模擬標準 ABS 塑膠。此材料能顯著提高各種醫療應用方面生物相容性零件的機械性能。
WSS™150 是一種水溶性支撐材料,可快速去除支撐。當放入裝滿普通自來水的容器中時,該材料會變成可溶性。使用標準或桌上型洗碗機能夠加速去除支撐。
在此處瞭解更多。
- 若 J750/850 數位解剖托盤材料包含 RadioMatrix,則當插入該模型時,不會選擇它作為預設材料。
- 當您同時可以存取 PolyJet 研究套件和 3DFashion 印表機時,您需要選擇其中一個以用於目前專案,因為某些功能有衝突。
- 在 J7 和 J8 系列印表機中,改進了以彈性行為設定具有 Agilus 上色材料的模型時的使用者體驗。相關設定已從進階選項移至主要設定區段,並在所有設定選項中新增了詳細的工具提示。
- 1.67 更新為 Connex3 印表機引入使用進階切片機的選項,其中「檔案」>「偏好設定」>「PolyJet」下的核取方塊預設為開啟。進階切片機對圖形需求更為嚴格,一些使用者過去會看到有關圖形驅動程式的錯誤。先前有一個程式錯誤,就是在關閉進階切片機偏好設定後,錯誤仍然存在,導致阻止任何作業排入佇列。透過 1.69 更新,此程式錯誤已得到修復,取消勾選偏好設定後將會清除錯誤。
- 對於 H350,現在可以指定封裝的高度,可以是時間 (這對於準備針對適合班次中可用時間量身打造的作業很有用),也可以是封裝的高度,其中使用者輸入的數會更新另一個參數。
- Estimate for the H350 現在提供建構報告,其中包含摘要和詳細資訊頁面。摘要列出:列印時間、總體積、巢套的模型、未巢套的模型、密度、巢套高度和收縮率。詳細資訊列出:各個零件、每個零件的份數和每個零件的體積。
GrabCAD Print 版本 1.68,七月 2022
構建號 1.68.10.19783 發佈于 19 七月 2022
- 多檔案 3MF、OBJ 和 VRML 組件現在都可以使用「檔案」>「匯入為組件」以與 STL 相同的方式匯入。
- ULTEM™ 9085 樹脂的支撐材料更名為 SUP8500B 支撐,ULTEM™ 1010 樹脂的則更名為 SUP9000B 支撐。
- 對於標籤 (僅限 H350),現在可以指定標籤文字的浮雕高度或壓印深度。
- 對於 3D 陣列 (僅限 H350),現在可以選取多個模型並建立這些模型的陣列。
- 對於 J850 TechStyle 和 J850 Prime Fabrix,當連線印表機時,目前作業的托盤類型會自動與印表機上安裝的托盤同步。
- 在已收到並安裝「右 UV 燈風管」現場變更單的 J7 和 J8 系列印表機中,「印表機設定」對話方塊將擴大包含「已安裝更新的風管」語句。
- 為 MED620 與 SUP711 混合體的 ASR-620 DM 現在適用於 HQHS 列印模式中的 J5 DentaJet。
- Color Agilus 材料適用於 Voxel Print 應用程式。
- Flex-Touch (智慧型和完整型) 應按模型定義,而不是托盤上所有模型皆通用的 Flex-Touch。
GrabCAD Print 版本 1.67,六月 2022
構建號 1.67.10.19143 發佈于 22 六月 2022
- 進階 PolyJet 切片機以前僅適用於 J 系列印表機,現在支援 Connex3 印表機。進階切片機品質改善,並引入其他功能,例如:
- 具有透明度黑白設定檔的灰階
- 薄區域/角處理
- 更準確的預估和偏移
更好的網格控制
如果您需要確切複製先前的列印,可以使用「檔案」>「偏好設定」>「PolyJet」切換回舊版切片機。
- 適用於 J850™ Prime 的 FabriX™ 創新套件可讓您將 PolyJet™ 原型製作和 CMF 功能擴展到直接在織物和柔性基材上列印的新世界。現在,您可以針對包含網狀材料、功能性服裝原型甚至過濾系統視覺化的應用程式測試不同的設計。
- 引入 RadioMatrix™,此首創的 Radiopaque3 D 列印材料適用於數位解剖印表機。新材料讓 3D 列印出的解剖模型具有不同對比度的不透射線特性,這些特性會出現在 CT 或 X 光線掃描中。RadioMatrix™ 材料設定已新增至提供具有所需亨氏單位值之不透射線 3D 印列解剖模型的數位解剖印表機軟體。
- 新的「網狀織物插入」功能允許使用者在列印過程中計劃停止,以便插入要在作業期間列印的媒材。在 J850 TechStyle 和 J850 Prime FabriX 系統上啟用的功能。
- AgilusCMY 模型適用的剛度核心允許使用 Agilus 色彩設定檔列印「柔軟觸感」剛度模型一次。結果是產生一個具有全彩薄紋理 (1 公釐全彩邵氏硬度 30) 作為外部柔軟表面的剛度模型。
- AgilusCMY 材料的 CMYK 輸入允許透過純 AgilusCMY 材料的 CMYK 數值輸入定義特定的所需色調。
- 透過 J5 DentaJet 上的「高品質高速」模式,使用者現在可以用一半的時間列印出相同品質的列印牙齒模型、手術指南和其他的應用。選擇正確的材料組態後,可以在 GrabCAD Print 中選擇「高品質高速」模式,並在印表機上執行「材料更換精靈」。
- 對於 H350,現在可以從 GrabCAD Print 中載入的多個頂層模型建位組件。這些模型透過使用 3D 拖曳小工具或定位工具放置在 3 D 空間中,然後然後做成一個可以巢套的組件。
- H350 的 3 D 陣列工具現在支援組件作為陣列的來源。
- 現在可以使用封裝高度作為 H350 其「3D 巢套」工具的停止條件。如果巢套流程成功封裝所有選定的模型,則會嘗試降低封裝的高度,直到達到指定的高度為止。
- H350 其「3D 巢套」命令的「最小模型間距」現在為 2 公釐,從 3 公釐起減少,這表示您可以放心地建立密度更高的巢套。
GrabCAD Print 版本 1.66,五月 2022
構建號 1.66.7.17878 發佈于 17 五月 2022
- 介紹 F123 系列的最新成員,Stratasys F370 CR 和 Stratasys F190 CR。這些複合就緒 (CR) 印表機設計用於填充材料,包括 Stratasys 最新的 FDM 複合材料、尼龍-CF10 和目前的材料 ABS-CF10。這使得在內部生產堅固的工作夾具、工具和零件變得更加容易,而使用傳統製造技術和材料所需的時間只是其中的一小部分。這些印表機支援 8 工程級材料,並使用 GrabCAD Print 的直觀介面和易於使用的進階 FDM 功能進行程式設計。請參閱此處,以瞭解 F123 複合就緒印表機的更多資訊。
- J850 TechStyle 3D 印表機採用 3DFashion™ 技術,提供全彩、多材料功能,適用於可直接列印在紡織品、皮革和服裝上的設計,以及列印小型時尚配飾,進而提供傳統方法無法實現的效果。請參閱此處,以瞭解更多資訊。
- GrabCAD Print 現在支援 H350 SAF 技術印表機。授權的使用者可以列印,非授權使用者可以探索該功能以瞭解並評估其潛力。請參閱此處,以瞭解更多資訊。
- 您現在可以使用滑鼠右鍵按一下功能表,以鏡像 GrabCAD Print 中的模型。此功能支援:用於所有列印技術的網格和 CAD 零件的鏡像、具有表面顏色、紋理的模型、組件內的模型,以及整個組件。目前,這並不支援具有進階 FDM 功能的模型及具標籤之模型的鏡像。
- 尼龍-CF10 是一種碳增強尼龍混合物,可用於 Stratasys F370 CR 和 Stratasys F190 CR 印表機。該材料包括依重量計 10% 切碎的碳纖維,因此 3D 列印模型比 ABS-CF10 更硬、更堅固、耐化學性更好。尼龍-CF10 支援 0.0070英吋 (0.1778 公釐)、0.0100 英吋 (0.2540 公釐) 和 0.0130 英吋 (0.3302 公釐) 圖塊高度,並且需要新的強化噴頭 (T20H) 進行列印。請參閱此處,以深入瞭解尼龍-CF10 的相關資訊。
- 新的強化噴頭 (T14H) 可用於列印 ABS-CF10,列印壽命為 1500 小時。T14H 噴頭是選用的;T14 噴頭可繼續與 ABS-CF10 一起使用,但噴頭壽命會縮短。
- 新型 Agilus30™ 彩色樹脂 (青色、洋紅色和黃色) 使橡膠或矽膠紋理產品原型可用於全彩、類似橡膠的零件,具有高表面品質和柔軟性程度,可承受反覆撓曲和彎曲。請參閱此處,以瞭解更多資訊。
- 材料 WSS (水溶性支撐)、VeroUltraClearS 和 VeroUltraClear 現在可用於 VoxelPrint。
- 若為 H350,使用「標籤」工具將浮雕或壓印文字新增至模型表面。您還可以建立標籤範本,其可在複製零件時多次套用或自動套用,而這些範本可以自動包含零件名稱或產生序號。
- 若為 H350,您可於 X、Y、Z 中建立矩形陣列。可將陣列分組為單一物件,或將其建立為個別的模型。
GrabCAD Print 版本 1.65,四月 2022
構建號 1.65.13.17318 發佈于 21 四月 2022
- 介紹 J850 數位解剖印表機。J850 數位解剖印表機以令人難以置信的真實感將醫學模型變為現實,準確地呈現人體組織的外觀和反應。這些型號為醫療保健專業人員和醫療設備公司提供了無與倫比的臨床多功能性、可重複性和準確性。在此處閱讀更多內容。
- 我們更新了支援的檔案格式,包括 SOLIDWORKS 2022、Inventor 2022,等。按一下此處,以查看完整清單:支援檔案格式清單
- 由於 Proxy 或自我簽署憑證,某些使用者遇到了網路連接問題。「檔案」>「偏好設定」>「隱私權」中的新選項允許 Windows 憑證存放區中的憑證受到 GrabCAD Print 的信任,此應可解決其中的許多問題。若應用程式偵測到這些組態,其將會自動設定偏好設定。
- 介紹「數位解剖建立工具」,這是用於「數位解剖」印表機的新附加元件軟體模組。「建立工具」軟體使用複雜的數學函數,為使用者提供了前所未有的自由度,可自訂解剖模型的內部結構。超越現有解剖預設加以建立,並校準數位材料以滿足您的精確規格。輕鬆操控材料形成並自訂內部微觀結構,以達成特定的解剖結果。請參閱此處,以瞭解更多資訊。
- PolyJet 系統上的 Voxel Print 現在支援新的樹脂:所有支援的印表機上皆有 VeroUltraWhite 和 VeroUltraBlack,J5 MediJet 上則有 DraftWhite
GrabCAD Print 版本 1.64,三月 2022
構建號 1.64.9.16414 發佈于 17 三月 2022
- Diran 410MF07 的零件品質在 Stratasys F370 印表機上透過下列方式獲得改善:
- 對於 0.0070 英吋 (0.1778 公釐) 圖塊高度,可以改善向上和向下指向可見表面的填充密度,並改善零件底部表面與底座頂部表面之間的附著力。
對於 0.0130 英吋 (0.3302 公釐) 圖塊高度,接縫品質、垂直表面和填充密度皆有所提升。
這些改進需要將印表機韌體更新為版本 2.4。
GrabCAD Print 版本 1.63,二月 2022
構建號 1.63.8.15371 發佈于 16 二月 2022
- WSS™150 是一種水溶性支撐材料,用於在 J55 Prime 和 J35 Pro PolyJet 系統上快速移除支撐。WSS150 在放入裝滿普通自來水的容器中時會變得可溶。透過使用標準或桌上型洗碗機,可以更快達成支撐移除功能。此外,根據當地法規,L2S™ 粉末可用於安全處理廢水,無需進行後續處理。
- 「圖塊預覽」面板已更新:
- 現在顯示用於模型和支撐材料的名稱、圖塊高度和噴嘴
- 功能顯示 (穩定器、錨點、接縫、暫停) 的篩選將會重新整理
動畫 (播放動畫、選取圖層和列印噴頭移動) 和 Z 軸暫停 (新增/移除 Z 軸暫停,暫停清單) 的控制已進行分組
對「模型設定」面板的存取將從「圖塊預覽」中移除,因為有關材料和圖塊高度的資訊現在正顯示於「圖塊預覽」面板中。
- 於 J55 Prime 或 J8 Prime 中使用「最佳化包裝」功能時,您現在可以使用支援 VeroUltraClear 的 CMYK 輸入微調透明顏色,進而為任何瓶子或液體提供絕佳的透明度和飽和度。
- J5 DentaJet PolyJet 印表機現在使用一組經過改良的新參數,可以更快、更準確地進行牙科列印。
- PolyJet 系統上的 VoxelPrint 現在支援新樹脂:
- 所有支援印表機上的 VeroUltraWhite 和 VeroUltraBlack
- J5 MediJet 上的 DraftWhite
GrabCAD Print 版本 1.62,一月 2022
構建號 1.62.8.14676 發佈于 19 一月 2022
- 新增 T16A 模型噴嘴,在 Fortus 450mc 印表機上與 ULTEM™ 9085 和經認證等級的 ULTEM™ 9085 CG 模型材料搭配使用。與標準 T16 噴嘴相比,其具有高度可重複的機械性能及更高的品質,適用於需要零件認證的應用,包括航太內裝。T16A 型號噴嘴的每層厚度為 0.010 英寸 (0.2540 公釐)。如要使用 T16A 型號噴嘴,Fortus 450mc 的控制器軟體必須更新為版本 6.6.6906。
- ULTEM™ 9085 Black 現在支援使用 Fortus 450mc 印表機上的 T20 型號噴嘴的圖塊高度 0.0130 (以 (0.3302 mm) 為單位)。較厚的圖塊可讓零件建構加速並提高輸送量。新的圖塊高度需要將控制器軟體更新為版本 6.66906。
- 一些小錯誤已與其他改進一起修復。
GrabCAD Print 版本 1.61,十二月 2021
構建號 1.61.12.14139 發佈于 22 十二月 2021
- 對於全彩 PolyJet 列印件,使用顏色拾取器變更顏色時,「主體外觀」現在是紋理主體的預設核心。這與最近發佈的「覆寫紋理」選項密切相關,該選項依預設為關閉狀態 - 可讓您以簡單直觀的工作流程變更紋理主體的顏色和透明度。
- 在 J5 系列印表機上為作業設定延遲開始時間時,除了現有的開始時間或結束時間外,還有一個新的時間設定選項可用。當材料在作業期間用完時,您可以設定要變更材料儲罐的時間,而印表機將在適當的時間開始作業。
- 若為數位解剖印表機 - 新的「可縫合血管壁」預設為用於縫合的血管模型提供了改進的效能和耐用性。
- 無法在相同模型上建立「錨點」和「穩定器」的問題已獲得修復。
GrabCAD Print 版本 1.60,十一月 2021
構建號 1.60.9.13125 發佈于 17 十一月 2021
- 您將注意到 GrabCAD Print 右側經修改後的外觀。圖示稍微縮小,並固定在視窗的一側。我們持續新增更多工具,因此我們稍微減少空間佔用以適應較小的螢幕。
- PolyJet 印表機現在可以列印包含位移 (凹凸) 對應的模型。在啟用「檔案」>「偏好設定」「GrabCAD Labs」中的功能之後,Keyshot .3MF 或標準 .OBJ 模型所包含的凹凸對應將轉換為列印零件的表面效果。在過去,必須將凹凸對應寫入檔案的 3D 網格中,而建立不必要的大型檔案。現在,可以直接讀取凹凸對應。位移的高度可在「模型設定」中進行調整,或將 0 設定為停用。如同任何 Labs 功能,歡迎您提供意見回饋。
- J35 Pro 有一種稱為「材料使用模式」的新模式。新模式可供您選擇讓印表機自動決定顏色混合,以充分利用剩餘的材料。列印零件的外觀將與 GrabCAD Print 中的顯示不同,因為列印時的任何現有材料都將決定最終的顏色。這個選項在「列印摘要」視窗中可供使用。
- 能夠在變更主體顏色時保持紋理。在過去,將新顏色套用於紋理模型時,紋理將被覆蓋。現在,新的顏色將更新紋理下方零件的主體顏色,並可選擇加以覆蓋。如果項目不相符,則所選的「基本與核心選項」將會覆蓋顏色。
- 針對列印具有許多重型模型的 PolyJet 作業進行新的最佳化。當使用重型模型填充紙匣時,請使用此功能將其自動最佳化。此功能會自動降低模型複雜性,而不會降低品質或模型準確性。
- 最新的 NVIDIA 顯卡驅動程式存在一個問題,使某些 PolyJet 作業無法估計和列印,此問題已獲得修復。
- 已修復「圖塊預覽」顯示的模型具有與穩定器顏色相同穩定器的問題。
GrabCAD Print 版本 1.59,十月 2021
構建號 1.59.11.12349 發佈于 25 十月 2021
- 在 J55 Prime 上,當設定唯一可用顏色為黑色與白色的材料配置時,可以使用新的灰階滑塊。此外,在載入紋理時,系統將使用黑白設定檔。
- 已修復在儲存專案時未儲存對模型「主體厚度」變更的問題。
- 已修復當模型包含自我承重孔時,專案的主體和表面設定未儲存的問題。
GrabCAD Print 版本 1.58,九月 2021
構建號 1.58.9.11590 發佈于 23 九月 2021
- 「保留專案設定」允許 FDM 印表機的專案在將專案切換到相同類型的印表機 (例如 Stratasys F370 切換到 Stratasys F370) 時保留其設定。您可以選擇保留列印目前設定 (即使這些設定與新印表機不相符),也可以選擇根據新印表機更新設定。
- 修復了某些全彩 PolyJet 列印件即使在選擇「機身外觀」時也會列印白色核心的錯誤。必須重新建立儲存在 1.56 或 1.57 且已手動變更核心設定的專案。
GrabCAD Print 版本 1.57,八月 2021
構建號 1.57.8.10644 發佈于 19 八月 2021
- 介紹 Stratasys® J55™ Prime,這是 J55™ 的突破性更新。J55 Prime 3D 印表機推出全彩、高傳真度,並並具備觸覺、實用和感官的功能,使 PolyJet 技術的效率和品質比以往更實惠、更適合辦公室使用。包括最先進的列印能力,包含橡膠狀硬度 (Elastico™)、高衝擊 (數位 ABS)、剛度超視覺 (VeroUltra™,DraftGrey)、半透明 (VeroUltra™ClearS) 和生物相容性 (Vero™ContactClear) 材料的組合。從快速設計反覆運算到高品質的最終原型,一切都在體積小巧、安靜、無異味的流程中建立完成。在這裡查看新的 J55 Prime。
- 介紹 Stratasys® J35™ Pro。J35™ Pro 是以 J55™ Prime 為基礎的旋轉紙匣平台,是一種低成本的多打印頭 3D 列印解決方案,適用於共用辦公環境,具有多功能設計和概念建模的多材料功能。新型 3D 印表機包含最先進的列印能力,並結合高衝擊 (數位 ABS)、剛度超視覺 (VeroUltra™,DraftGrey)、半透明 (VeroUltra™ClearS) 和生物相容性 (Vero™ContactClear) 材料。印表機體積小巧,便於安裝在辦公室中,並使用 ProAero 過濾系統,使工作環境完全無異味。在這裡查看新的 J35 Pro。
- 我們首次對 Print 的 CAD 版本支援進行中期更新。
- 「圖塊預覽」現在提供對「錨點」和「穩定器」顯示的控制。
- 「錨點」和「穩定器」會以自己的顏色顯示,使其易於與模型和支援進行區分
- 使用「顯示」清單中的選項關閉錨點和穩定器的顯示,以便更輕鬆地檢查模型。
- 僅當作業包含這些功能時,才會顯示「錨點」和「穩定器」顯示選項
- 下次進入「圖塊預覽」時,將會記住「錨點」和「穩定器」顯示的設定。
- 此外,「圖層突出顯示」的顏色現在是透明白色,這樣可以更輕鬆地了解圖塊的哪些部分為模型、支援、「錨點」和「穩定器」。
- 數位解剖印表機的兩個更新:
- 混合使用 TissueMatrix 和 GelMatrix 列印超逼真的皮下脂肪組織模型,其中包含總共 6 個新的預設。柔軟度中變化的主要型號功能是收縮皮下脂肪 (非常柔軟) 和高度收縮皮下脂肪 (最柔軟),並具有以下塗層選項:
- 硬塗層 – 塗覆 2 公厘的 Agilus,以建立更耐用的獨立模型。
- 軟塗層 – 塗覆在 2 公厘的 Agilus 和 GelMatrix 混合物中,使獨立樣品具有逼真的柔軟、粘稠外觀和觸感。
- 非封裝 – 未經塗覆用於將脂肪組織作為器官模型一部分的應用。
- GelMatrix 增強功能提供了更多的解剖建模選項,且只需要更簡單、更簡短的後置處理。在「解剖模型設定」功能表中尋找兩項新功能:
- 使用 GelMatrix 作為支援材料列印各種解剖
- 使用純 GelMatrix 材料進行列印,無需任何其他材料
GrabCAD Print 版本 1.56,七月 2021
構建號 1.56.11.9996 發佈于 20 七月 2021
- PolyJet 模型設定面板現在包含一個名為「預設」的區段。已經有一個「我的最愛」區段,僅用於顏色選擇,但預設包含顏色以及所有其他模型設定。以右鍵按一下紙匣上的零件以儲存「預設」。新增「預設」後,您可以右鍵按一下並將其設定為預設值。之後新增到紙匣的模型將套用「預設」。
- J8 系列 Prime 的新功能:「針對包裝進行最佳化」透過簡單的工作流程為包裝原型提供絕佳的外觀。使用從 RGB 到列印顏色首屈一指的透明度轉換 - 使用者現在可以獲得更準確的透明度,例如液體或彩色玻璃。除此之外,還會在標籤後面建立一個自動的白色底印,透過高不透明度使圖形看起來很棒。此選項在使用 Vero 鮮豔色彩、UltraWhite+UltraBlack 和 UltraClear 的全彩 J8 印表機上可用,且適用於 Keyshot 中的 3MF 檔案。(請聯繫 print@grabcad.com 以啟用此功能。)
- 錨點功能的改善:
- 為了簡化在模型與紙匣之間建立和編輯「錨點」(最常見的使用案例),當「錨點」窗格開啟時,「模型視圖」會自動設定為「底部視圖」。
- 當編輯「錨點」且「模型視圖」為「前」、「後」、「左」或「右」時,紙匣會切換到精簡預覽,以便更輕鬆地檢查集合中「錨點」的預覽幾何圖形。關閉「錨點」窗格時,將恢復較厚的紙匣視圖。
- 已新增 Stratasys F900 和 Fortus 450mc 平台上 Antero 800NA 以及 F900 平台上 Antero 840CN03 的 T20F 模型提示。相較於目前的 T20D 模型提示,T20F 模型提示可利用同等的零件品質和準確度提供高達 20% 改善的機械效能。若要使用 T20F 模型提示,請選取 0.0100 於 | T20F (0.2540 公釐 | T20F),在選取支援的材質後,在「圖塊高度」下拉功能表中。
- 韌體版本 4.11。0 適用於 Stratasys F900 和 Fortus 900mc 印表機。使用標準下載的升級 (.upg) 檔案無法使用此更新。請聯絡服務代表或 Stratasys 客戶支援,瞭解有關此重要更新的資訊。
GrabCAD Print 版本 1.55,六月 2021
構建號 1.55.8.8912 發佈于 16 六月 2021
- 現在支援 SpaceMouse 3D 滑鼠在 GrabCAD Print 中進行視圖操作。請在此處查看相關教程。
- 對於在冷卻時可能會捲曲的寬扁模型,錨點功能方便您在列印時將模型固定在建置紙匣上。「錨點」功能是由模型材料製成的柱,可將模型的水平、底部表面固定到建置紙匣上。錨點可以是圓柱或圓錐,單獨建立,也可以是在共用型式和直徑的集合中建立。按一下此處瞭解更多關於配置錨點的資訊。支援 Stratasys F770、F370、F270、F170、F900 和 Fortus 系列印表機。)
- 穩定器現在要求您在產生前選取參考曲線。這樣可防止在面板首次打開時立即建立穩定器,並允許您在產生穩定器之前調整設定。
- 隆重介紹全新的多合一醫療印表機 J5 MediJet™,專為解剖模型、手術指南和醫療工具所設計,採用可殺菌和生物相容性材料的醫療模具。J5 MediJet 為醫療 3D 列印應用創建新標準。透過多種材料和多色功能,您可以在認證的系統上建立出色生動的解剖模型、鑽孔和切割指南,以及可殺菌和生物相容的醫療工具。此外,印表機經濟實惠且體積小巧,適用於小型實驗室空間。參閱此處獲得更詳細資訊。
- 您可在 PolyJet 印表機右側功能表上的新工具,使用「偏好設定」中定義的單位來設定紙匣上的準確位置。
- 注意:在下一個版本中,全彩色 J 系列印表機上的「進階色彩半色調」會在使用全彩色的 VeroPureWhite 時,預設檢查是否有新的紙匣。
GrabCAD Print 版本 1.54,五月 2021
構建號 1.54.6.7969 發佈于 18 五月 2021
- Stratasys F770™ 3D 印表機配備市面上最長的全加熱建構室 — 對角長46 英吋。寬敞的建置外殼超過 13 立方英呎 (372 公升),為製造、原型開發和生產零件應用開啟了小型印表機無法達成的新契機。瞭解更多 Stratasys F770 相關資訊 。
- 針對不需要太多傳統支撐的高瘦輕薄模型,新的穩定器功能可讓您在建立模型時為模型新增鷹架。穩定器是一種高大的支撐結構,定期連接到模型側面,提供額外的支撐力並減少震動。按一下此處 以進一步瞭解如何設定穩定器。(支援 Stratasys F770、F370、F270、F170、F900 和 Fortus 系列印表機。)
- F123 系列印表機無法使用「使用變數寬度填入」核取方塊的問題已修正。
- 針對 FDM 模型的封頂曲面,已修正下列路徑問題:
- 小封頂曲面不再接收兩次所要求的光柵填滿。
- 封閉曲面中的小孔不再被忽略。
- 在 1.48 中推出的 GrabCAD Labs 功能,可讓您為已發布組件的元件指派不同的 PolyJet 效果 (亞光或光面)。此功能不再是一個選項,且隨時可用。
GrabCAD Print 版本 1.53,四月 2021
構建號 1.53.15.7152 發佈于 20 四月 2021
- 選取「圖塊預覽」後,圖層範圍的預設值即為「所有圖層」。下次選取「圖塊預覽」時,將會記住針對「圖層範圍」的變更。
- 新的不透明材料可列印輕薄、逼真的塑膠模型,提供列印包裝標籤更高精確度的色域、清晰文字,以及平滑、高解析度的膚色。
GrabCAD Print 版本 1.52,三月 2021
構建號 1.52.8.6136 發佈于 16 三月 2021
- Stratasys F370、Stratasys F270 和 Stratasys F170 印表機現在可使用碳纖維強化 ABS 。Stratasys ABS-CF10 將標準 ABS (丙烯腈-丁二烯-苯乙烯苯乙烯) 材料與 10% 切碎的碳纖維按重量結合。創造出低濕度敏感的 FDM® 熱塑性,提升 50% 硬度、15% 強於標準 ABS 3D 列印材料。典型應用包括製造工具、模具、夾具和末端效應,能同時增加剛性和減輕重量。ABS-CF10 支援 0.0070 英吋 (0.1778 公釐)、0.0100 英吋 (0.2540 公釐) 和 0.0130 英吋 (0.3302 公釐) 圖塊高度。請參閱此處進一步了解新的 ABS-CF10 材料。
- 為您介紹 J5 DentaJet™。以 J55 平台為基礎,J5 DentaJet 3D 印表機是我們多材料牙科 3D 印表機系列的最新品項,這可讓技術人員能夠混合裝載牙科零件紙匣。新款 3D 印表機在單一混合紙匣上產生的牙科零件比競爭產品 3D 印表機多五倍,但其體積小巧僅耗用 4.6 平方英尺 (43 平方公尺) 的樓面空間。請在此處參閱 J5 DentaJet 相關資訊。
- 在支撐結構與模型之間由 Antero 840CN03 製成的基礎圖層和介面圖層已經過改善,提高向下彎曲模型表面的品質。支撐結構也會改變,以提高其穩定性。
- 針對 Diran 410MF07、圖塊高度 0.0010 英吋 (0.2540 公厘),最小本體厚度會降低為 0.0200 英吋 (0.5080 公厘) 以進行固體填入,預設的自我承重角度降低為 45 度,而其他列印設定則會更新以改善模型的整體列印品質。
- 全新的肝臟解剖現可在數位解剖印表機上推出。4 新的預設肝臟解剖功能具有不同壓縮值的,所有資料均可在完整的生物力學報告中獲得驗證。從高度收縮到適度僵硬的變化,印表機都可提供不同塗層。如需已執行的測試資料,請參閱此處。
GrabCAD Print 版本 1.51,二月 2021
構建號 1.51.18.5360 發佈于 22 二月 2021
- 您現在可以從大多數 CAD 套件的最新版本列印檔案,包括 SOLIDWORKS 2021、Inventor 2021 和 Creo 7。請參閱此處以取得支援檔案的完整清單。GRAbCAD Print 版本 1.50、一月 2021
- 隆重介紹 J850 Pro,一款專為快速原型開發而打造的 7 材質 PolyJet 印表機。J850 Pro 與 J850 Prime (前稱 J850) 具有相同的構建體積和材料容量,但 J850 Prime 在 CMF 原型開發方面表現卓越,J850 Pro 以 Digital ABS、Agilus 彈性材料、DraftGrey 和「超高速」模式構建速度和性能。請在此處查看新的 J8 系列產品陣容。
- 新的列印摘要視窗可以方便地將設定、估算、延遲開始選項,以及您點擊 PolyJet 的「列印」工作時需要看到的任何警告或通知。
- 在分析模式下修復模型時,任何零體積的主體 (例如薄片主體和噪音殼) 都會自動隱藏,因為這些主體無法解譯並可能導致估算或列印錯誤。
- 紙匣檢視中 CMB 檔案的圖形表示已獲得改善。CMB 顯示可提供模型實際造型更詳細資訊。系統現在會識別並顯示先前忽略的口袋。透過改良的 CMB 顯示,使用者不需要進入「圖塊預覽」即可瞭解 CMB 列印產生的模型。
- GrabCAD Print 中的功能表列和功能表可能會根據 Windows 佈景主題設定而變更顏色。
GrabCAD Print 版本 1.50,一月 2021
構建號 1.50.14.4357 發佈于 19 一月 2021
- 當 GrabCAD Print 有更新可用時,偏好設定 (在 1.22 版本中引入) 會決定是否在下一次啟動應用程式時自動安裝更新。預設為開啟,但是現在所有使用者可以將這個偏好設定關閉。未來的更新只會在您按一下「立即更新」按鈕時安裝,如果您想要的話,可以在「檔案」>「偏好設定」>「更新」中選擇回到自動更新。
- 模型載入的衝突偵測現在會偵測並且在發生模型重疊的時候警告您。對於 PolyJet 列印,這會協助您判斷是否需要變更零件優先權。備註:衝突偵測預設為關閉,可以在「偏好設定」>「模型插入設定」>「自動偵測組件內的衝突」中啟用。
- 當您在 J 系列印表機上插入具有平面結構的組件時,現在可以立即在清單中看見預設優先權。以前您必須對零件優先權進行變更才能看見。
- 在 J 系列印表機上使用黑色 + 白色時,您現在有一個灰階滑桿,可以與 B/W 色彩設定檔搭配使用 - 取代現有的全彩顏色選取器。
- DraftGrey 先前專屬於 Objet30 印表機的新 V5 版本,現在可以在 V3 印表機上使用 (列為 VeroGrey)。按一下這裡以瞭解更多。此外,此更新會啟用使用 Vero 材料的「高品質」模式。
- 在 1.49 版本中,某些 Connex 印表機不正確地報告不正確的圖形驅動程式版本。這已在 1.50 版本中修正
GrabCAD Print 版本 1.49,十二月 2020
構建號 1.49.12.3309 發佈于 16 十二月 2020
- J4100 升級套件適用於 Objet1000 印表機。套件透過新的列印噴頭技術和最先進的材料供應,增強 Objet1000 印表機功能。新的列印噴頭帶來額外的模型通道 (3),增加輸送量和生產力多達 90%。材料供應現在包括 Agilus 系列、UltraClear 和 VeroPureWhite。J4100 現在讓透過 ABS (包覆成型) 列印彈性材料變得可能。
- 某些 J 系列使用者遇到問題,因為作業卡在處理程序中而無法列印到他們的 J 系列印表機。這是由於印表機電腦上過期的圖形驅動程式所造成的,但是 GCP 無法偵測問題。此問題已修正,如果您遇到這種情形,現在會看到訊息為您指向更新驅動程式的連結。
- CMB 相關軟體修正
- 還原選項以在 CMB 匯出中包括/排除清除零件/犧牲塔。
- 還原能力以在包含 CMB 的紙匣上包含額外犧牲塔。
GrabCAD Print 版本 1.48,十一月 2020
構建號 1.48.14.2323 發佈于 17 十一月 2020
GrabCAD Print 現在支援 Objet30 桌上型印表機。除了現有的 Objet30 V3 印表機 (稱為 Objet30、Objet30 Pro 或 Objet30 Prime) 以外,也即將推出新一代:Objet30 V5 Pro 和 Prime。V5 模型是單色、方便使用的印表機,具有小的足跡和無懈可擊的列印品質。它們提供 3 列印模式和各種 13 模型材料 (包括 DraftGrey) 和彈性的生物相容性材料 (僅限 Prime)。若要搭配您的 Objet30 使用 GrabCAD Print,您必須遵循以下指南:針對 GrabCAD Print 設定您的 PolyJet 印表機
「基本風格」選項現在可以在 FDM 印表機的「支援設定」面板中取得。
- 模型和支援:基底新增在模型底下並且支援足跡。當基底重疊時,其會合併到通用基底。當基底形成封閉的迴圈時,會填充迴圈、建立大型、穩定的基底。
- 僅模型:基底只會新增在模型足跡底下。支援延伸到紙匣,迴圈不會填充。
- 「檔案」>「偏好設定」>「GrabCAD Labs」中的新選項可讓您針對 PolyJet 印表機,在組件中的主體上於亞光和光澤之間混合完成品。
- 新的列印模式「超高速」現在可用於 J826 印表機。這個新模式提供「高速模式」的兩倍流通量,對於許多應用都很實用,例如快速列印概念模型。
- 對於 Stratasys F900 和 Fortus 900mc 模型工具 (使用 SR30 或 SR35 支撐材料) 上使用 ASA 模型材料與 T40 擠壓噴嘴 (0.0200 英吋、0.5080 公厘圖塊高度) 的作業,零件第一層底下基底層的建構屬性是要改善零件第一層的品質,並且防止分層。
- 對於具有使用 T40 模型噴嘴 (0.0200 英吋、0.5080 公厘圖塊高度) 之 ASA 模型材料的 Stratasys F900 上的作業,時間和體積估算的準確度已經改善。此變更適用於新的 4.10.0 系統韌體。請注意,此韌體更新無法透過標準下載升級 (.upg) 檔案取得。請聯絡服務代表或 Stratasys 客戶支援以取得有關這個重要系統軟體更新的詳細資訊。
GrabCAD Print 版本 1.47,十月 2020
構建號 1.47.20.1644 發佈于 20 十月 2020
- 在 Stratasys F370 印表機上使用 0.0100 英吋 (0.2540 公厘) 圖塊高度時,上方表面的外觀和表面密度已針對 ABS 和 ASA 改善。
- 藉由更佳偵測短薄區域來改善剩餘部分填充,以填充可調整寬度剩餘部分路徑。
- 現在可以選取具有不同顯示簡化狀態的模型,並且全域將對於所有模型選取的設定設為「完整」解析度或「簡化」。
- 在 SolidWorks 中設為透明的紋理現在會正確匯入 GrabCAD Print,具有正確的透明度。
- UltraclearS 可模擬壓克力,實現該材料 95% 的透光,並且可用於玻璃、透明聚合物或透明包裝的原型。VeroUltraClear 以更高等級的清晰度、透明度和較低的黃色指數,改善 VeroClear 過去的效能。
- 支撐核心選項現在也可以在 J55 印表機中使用。支撐核心 (以前稱為「中空」) 可讓您在支撐材料外列印核心。在使用選項之前,請在「偏好設定」>「GrabCAD Labs」中將它開啟。
- 數位解剖印表機的「骨骼切片」可讓您將骨骼模型解剖為片段以模擬骨折,或移除紙匣上與應用程式不相關的零件。
- 先前在「變更材料」視窗內的顏色和紋理設定檔選項已移至「紙匣設定」工具面板中的「進階」區段。
GrabCAD Print 版本 1.46,九月 2020
構建號 1.46.21.661 發佈于 15 九月 2020
構建號 1.46.22.826 發佈于 18 九月 2020
- 先前是 PolyJet 模型設定中核取方塊的「中空」設定,現在在「基礎和核心選項」底下是「支撐」選項。此外, 1.42 版本中發行的「混合核心」偏好設定現在預設為開啟。
- 數位解剖印表機的新功能
- 骨骼預覽 - 啟用骨骼內部結構的逐片預覽,以驗證結構與您的意圖對應。
- 開啟/關閉端 - 在骨骼內部結構建立「開口」。您可以標示骨骼的平面橫截面,然後選擇包覆透明材料或保留原狀,也就是暴露在外面。
- 支援 3MF 檔案,在版本 1.40 中引入為 Labs 功能,現在正式上市。
- 具有透明背景紋理的 SOLIDWORKS 檔案現在會正確地載入 GrabCAD Print,透過透明背景顯示基礎外觀。
- Antero™ 840CN03 現在在 Fortus 450mc 上受到支援。Antero 840CN03 是 Stratasys® Antero 800NA 模型材料的混合,具有靜電放電 (ESD) 屬性並且可以在接觸敏感電子零件和元件的製造應用中使用。一個圖塊高度適用於 Antero 840CN03:0.010 英吋 (0.2540 公厘)。如需此材料的詳細資訊,請參閱這裡。
GrabCAD Print 版本 1.45,八月 2020
構建號 1.45.21.65369 發佈于 25 八月 2020
- 準確列印作業時,可以事先選取 PolyJet 列印模式。只會顯示可用於所選取「列印模式」的功能和設定,讓作業準備更容易。根據您選取的「列印模式」,無法使用的功能和設定仍然會停用,具有無法使用之原因的說明。
- 為 FDM 引入「適應性切割」風格!「適應性切割風格」針對需要更多細節的特徵 (例如圓頂、片狀和倒角) 使用選取的高度,而對於不需要細節的特徵使用較厚的圖塊高度。結果就是列印更快 (取決於幾何結構和圖塊高度,最多快速 24%)。「圖塊風格」是新選項,可設定模型的切割方式。請參閱這裡以獲得更多資訊。
- 「顯示設定」>「圖形品質」的偏好設定現在會控制套用到模型 (用於圖形顯示) 的簡化層級。注意:列印的模型仍然是完整解析度。有一個滑鼠右鍵功能表選項「圖形解析度」,可以在「簡化」與「完整」解析度顯示之間切換所選取模型的顯示。
- 現在有一個偏好設定會套用到所有檔案類型,以選擇組件的載入狀態,已組裝或已拆解。
GrabCAD Print 版本 1.44,七月 2020
構建號 1.44.22.64105 發佈于 22 七月 2020
- 可以自訂核心/基礎指派,以提供最符合的模型設計。
- J720 印表機的自動排列功能提供改善的零件巢狀,讓生產更有效率。
- 2.0 版以前的 GrabCAD Print Server 從 七月 21 起再也無法與 GrabCAD Cloud 連線。若要繼續透過 GrabCAD Print Server 與您的印表機連線,請手動解除安裝舊版並且安裝新版 Print Server 2.0。您可以在這裡下載最新版本。
- GrabCAD Print Server 2.0 僅在 Microsoft Windows 10 (64 位元) 與 Windows Server 2016 和更新版本上受到支援。在舊版 Windows (未收到 Microsoft 主流支援) 上執行的實例從 七月 21 起將不會自動更新也無法連線到 GrabCAD Cloud。您必須在您的 Print Server 實例上升級作業系統或是在有支援作業系統的機器上安裝 Print Server。
- GrabCAD Print 正在移至整個系統 (每機器) 安裝。如果這會對您造成影響,您會在有更新可用時收到通知,且移轉 (通常) 不需要您執行任何動作。在 v1.47 之後,您必須移轉至每機器安裝以繼續接收更新。
- GrabCAD Print 現在可讓您從您的印表機將診斷檔案傳送給 Stratasys 支援聯絡人。如果有硬體、材料、其他印表機甚至是軟體的問題,您現在可以前往「說明」->「取得印表機協助」,您可以在其中新增有關問題的詳細資料。GrabCAD Print 接著會產生電子郵件範本以及所有詳細資料和相關檔案,您可以將其傳送到在銷售時提供給您的電子郵件地址。
- 具有深度 (多層) 組件結構的 3MF 檔案現在會在「專案」面板顯示整個樹狀結構。
GrabCAD Print 版本 1.43,六月 2020
構建號 1.43.17.62943 發佈于 17 六月 2020
- 既然進階 FDM 功能可以在 GrabCAD Print 中使用,就不再需要進階 FDM 專案。「啟用進階 FDM」選項已從「偏好設定」功能表中移除,建立新的「進階 FDM 專案」的動作已從左側工具列中移除。
- 將「進階 FDM」功能移至核心 GrabCAD Print 期間,在「進階 FDM」中建立的專案會在 GrabCAD Print 中開啟,每個模型會在個別的紙匣上。會進行分組,分別是主體設定、表面設定、紙匣屬性、方向和製造備註。
- 將 VRML、OBJ 和 3MF 檔案轉譯成可列印物件的演算法已經重新撰寫,以防止切割失敗。
- 如果您選取純色的 VRML 主體,顏色選取器現在會直接顯示顏色,並且可讓您進行些微調整。
- 數位解剖印表機的兩個新功能
- 長骨軸工具讓使用者能夠定義長骨的近端和遠端區域。此功能讓具有不同密度的列印零件能近似長骨的結構。
- 需要鑽洞並將螺釘插入列印模型的多個骨科程序。在某些情況下,這會導致不想要的裂縫。為了防止這種情形發生,應力消除工具可讓您設定邊緣,設計來包含任何裂縫,防止列印出來的零件有更寬的裂縫。
- 為您介紹 Stratasys J55。不需要妥協任何步驟就可以建立。從快速的概念模型到有品質的高保真模型,對辦公室相當友善的 J55 3D 印表機是設計師最高輸出負擔得起的選項。在這裡瞭解更多。
GrabCAD Print 版本 1.42,五月 2020
構建號 1.42.19.62279 發佈于 20 五月 2020
- 使用新的操縱器更輕易地定位您的模型。按一下檢視控制條中最右側的按鈕以將其啟用,接著選取的模型就會顯示箭號,您可以往該方向點擊並拖曳,自由地或是準確沿著軸移動和旋轉您的選取範圍。
- 對於 FDM 印表機,紙匣上模型之間的空間可以透過「排列」工具面板中的滑桿從最小 0.2500 英吋 (6.35 公厘) 到最大 2.0000 英吋 (50.8 公厘) 進行調整。這樣可讓您將紙匣上的模型更緊密地合在一塊,或讓它們隔得更遠讓空氣流動更好。
- 當 CMYKW 和 CMYW 擬真材料載入印表機時,在 1.41 中新增的新 CMYKW 和 CMYW 色彩設定檔現在是預設色彩設定檔。設定檔名稱是 X-Rite i1Profiler CMYKW 或 CMYK。
- 以前 PolyJet 零件的核心是以黑白材料的交替層列印而成,但是「檔案」>「偏好設定」>「PolyJet」中新的「混合核心」偏好設定讓核心可以使用所有可用材料的混合列印出來。這樣可大幅降低噴嘴堵塞問題的可能性,因為每個列印噴頭可以更有效率地使用,但是需要每個已載入材料盒有足夠的材料才能完成作業。
GrabCAD Print 版本 1.41,四月 2020
構建號 1.41.31.61723 發佈于 27 四月 2020
- GrabCAD Print 現在支援最新版本的 CAD 套件。這包括 SOLIDWORKS 2020、Inventor 2020、Creo 6.0 等。在此處閱讀更多內容。
- 您現在可以變更 J 系列列印支撐網格中使用的材料,以節省常用的材料。紙匣上的所有支撐結構都會以選取的材料列印。材料選取可以在「紙匣設定」>「進階」>「用來強化支援的材料」中完成。
- 為了將更多進階 FDM 功能帶進列印,您現在可以在「群組」內將不同材料設定套用到主體。以滑鼠右鍵按一下「群組」,您可以在下列選項之間切換:
- 隔開主體 - 主體和表面可以獨立於其他主體和表面來套用設定。這與進階 FDM 的工作方式類似。
- 結合主體 - 群組中的所有主體當作單一主體,一個主體設定套用到整個群組,並且移除內部界線。這與您選擇「已組裝」但是未建立群組時組件的一般工作方式類似。
- 當已組裝群組已選取「隔開主體」時,可以在「表面」標籤底下的「模型設定」面板中使用表面厚度、接縫位置和插入。以前此功能只能在進階 FDM 中使用。
- 需要 FDM 列印支援的小型特徵,會產生在特徵之下成長得更寬的支援。現在可以由「成長支援」設定來控制,可讓您從預設的「僅成長小型支援」變更為「不成長支援」或「成長所有支援」。關閉支援成長可能會對減少某些零件的材料使用量和列印時間有所幫助。
- 新的 Vivid 2.0 色彩設定檔已新增至 GrabCAD Print,提供改善的色彩渲染。預設色彩設定檔未曾變更,依然是 Vivid 1.1。
- 具有表面色彩的 SOLIDWORKS 組件現在可以直接載入到 GrabCAD Print,不需要將它們儲存為多主體零件的額外步驟。
- 對於 FDM 印表機,具有組件結構的 3MF 檔案現在會一起載入它們的結構。
- 當您在滑桿上變更 FDM 設定時,黑色鑽石表示預設值。按一下以還原預設值。
- 使用這個版本的 GrabCAD Print,您可以輕易地在 GrabCAD Print 中的「紙匣」上開啟 GrabCAD Shop 中「訂單」的檔案。這樣可以節省時間,避免從電子郵件或其他請求管理軟體下載 CAD 檔案,協助有效率地計畫您的「紙匣」。如果您還未這麼做,請在這裡註冊 GrabCAD Shop。
- 「依 IP 新增」輸入方塊已新增至 GrabCAD Print Server,可以輕鬆連線到位於無法使用自動探索之位置的印表機。
GrabCAD Print 版本 1.40,三月 2020
構建號 1.40.28.60898 發佈于 24 三月 2020
- SOLIDWORKS 零件檔案 (包括多主體檔案) 現在針對 PolyJet 列印包括在表面層級套用的色彩資料。以前只有在主體層級套用的色彩會包含在 GrabCAD Print 中。
- 藉由建立使用者選取色彩的色樣,測試色彩在您的 PolyJet 印表機上的已列印模型中如何顯示。前往「應用程式」>「顏色色樣工具」來存取顏色色樣工具。
- GrabCAD Print 現在可讓使用者藉由最佳化電腦的 GPU 記憶體消耗來列印更大的 PolyJet 紙匣。此功能可以在「偏好設定」>「PolyJet」>「重型紙匣最佳化」中啟用。
- 進階切片機現在僅適用於 Stratasys J750 和 Stratasys J735 的切片機。舊版切片機不再適用於這些印表機。其他 PolyJet 印表機沒有變更。
- 將作業從獨立 Insight 傳送到 GrabCAD Print 時,獨立的版本必須是可用於 GrabCAD Print 之 Insight 版本的相同版本或更新版本,否則不會傳送作業。
- 我們已經將 GrabCAD Print 的核心元件升級至可用的最新版本。這不僅可以修正某些未解決的問題 (例如從 OneDrive 資料夾載入檔案),還可以改善整體效能和啟動時間。
- GrabCAD Print 現在可以從許多 CAD 工具匯入 3MF 檔案,在 SOLIDWORKS 建立的 3MF 檔案中,這包括:表面色彩、主體色彩、和紋理。對於 PolyJet 印表機,組件會有平面結構,而對於 FDM 印表機,則沒有組件結構。
- FDM 專屬的改善
- 為了在 Stratasys F370 印表機上使用 TPU 92A<b> </b>時提供更佳的整體零件品質,已減少可調整寬度剩餘填充。
- 自我承重孔的角度已增加為 55 度,以容納材料 Diran 410mf07 的自我承重角度。
- 解決了對某些模型和方向可能產生不完整支援的問題。
- 指派給「群組」的預設名稱 (在 GrabCAD Print 1.36 中引入) 現在可以重新命名為一或多個對使用者有邏輯的名稱。
GrabCAD Print 版本 1.39,二月 2020
構建號 1.39.14.59507 發佈于 18 二月 2020
- 新的 PolyJet 模型設定面板提供了改進的設計和使用者工作流程,能夠儲存材料和顏色我的最愛,以及使用新的 CMYK 輸入功能建立自己的顏色和數位材料。在此處解更多資訊。
- 從套用了比例或方向的組件建立群組時,新建立的群組將從組件繼承這些屬性。
- 您現在可以從印表機清單中刪除中斷連線的印表機。僅需按一下要刪除的印表機並選取「刪除印表機」即可。
- 現在,位於材料面板中 PolyJet 印表機的廢物箱狀態更為清晰、直觀且視覺化。
- 關於進階 PolyJet 切片機的提醒:在 3 月更新的 GrabCAD Print 版本中 1.40,停用 J750 和 J735 之進階 PolyJet 切片機的選項將不再可用。
GrabCAD Print 版本 1.38,一月 2020
構建號 1.38.21.59019 發佈于 28 一月 2020
- 如果您擁有 PolyJet 印表機,則可以試用新的模型設定面板,該面板改進了設計和儲存我的最愛的能力。請前往「檔案」>「偏好設定」>「PolyJet」,然後選取該核取方塊以使用新的 PolyJet 模型設定面板。
- 在 1.36 上針對 J850 和 J835 導入的新 VeroUltraClear 材料現已在 J750 和 J735 上提供使用。VeroUltraClear 可模擬壓克力,實現該材料 95% 的透光,並且可用於玻璃、透明聚合物或透明包裝的原型。在此處瞭解有關 VeroUltraClear 材料的更多資訊。
- 您可以透過在所選 VRML/OBJ 主體上新的按右鍵功能表選項,從「模型設定」面板中覆寫具有新顏色和材料指派的 VRML/OBJ 零件,並在必要時恢復原狀。
- VRML/OBJ 結構偏好設定的預設狀態已由「關閉」變更為「開啟」。
- 進階 FDM 上 Diran 410MF07 的填充模式現在包括單密度、雙密度和實心。此外,第一層材料已從支撐材料變更為模型材料,以改善進料匣的黏附性。
- 導致 Stratasys 印表機的型號名稱在「安排視圖」中不正確顯示的問題已解決。
GrabCAD Print 版本 1.37,十二月 2019
構建號 1.37.15.57828 發佈于 18 十二月 2019
- 在版本 1.20 中導入之 PolyJet 印表機的延遲啟動功能現在由進階 PolyJet 切片機提供支援。注意:印表機需要處於「閒置」狀態才可供選取。
- 新的 PolyJet 列印設定適用於後處理,可讓您新增用於拋光的透明材料薄層。拋光透明圖層可產生具有平滑表面和高保真度顏色和紋理的模型。
- 現在可以預覽和建立 PDF 隨行文件,其中包含目前作用中進料匣之模型的製造備註與螢幕擷取畫面。
GrabCAD Print 版本 1.36,十一月 2019
構建號 1.36.17.57117 發佈于 20 十一月 2019
- 新的 J750™ Digital Anatomy™ 3D 印表機現已獲得支援,該印表機與醫療設備製造商、世界級研究機構、醫院和醫護人員合作開發的一系列解剖應用程式進行了預先程式設計。精確、逼真且實用,可以達到真實事物的感覺、行為和尺寸。在此處瞭解有關 J750 Digital Anatomy 3D 印表機的更多詳細資訊。
- 現在支援新的 J850 和 J835。設計和創造力無遠弗屆。現在有了 Stratasys J850/J835,同樣的道理也適用於原型。我們久經考驗的技術簡化了整個設計流程並簡化了工作流程,因此您可以將更多時間花在重要事項上,也就是盡可能建立、改進和設計最佳產品。在此處瞭解有關 Stratasys J850 的更多詳細資訊。
- 所選模型現在可以透過「專案面板」頂部的新按鈕或滑鼠右鍵命令來進行分組。建立新群組時,這將會折疊並隱藏現有組件。您可以將新群組設定為組裝或拆解。您可以從原始組件建立其他群組。
- 在 PolyJet 進階切片機設定中,有一個新選項用於顯示 VRML 和 OBJ 檔案的組件結構。啟用此選項後,GrabCAD Print 即可確定 VRML 或 OBJ 檔案的幾何結構,並將結構顯示為專案面板中主體的組件。每個主體可以是多色 (例如具有紋理、已上色頂點、已上色表面或由多個不同顏色的薄片所組成) 或單色 (例如主體中的所有薄片共用單一擴散色彩)。使用者可以變更此類組件中任何單色主體的材料指派。
- 匯入 SOLIDWORKS 檔案 (.sldprt 或 .sldasm) 時,如果載入了透明材料,則附加到 SOLIDWORKS 主體的透明度屬性將自動轉換為 PolyJet 材料面板中的 Alpha 值。
- 適用於需要授權之 Stratasys 和 Fortus 印表機的材料授權可以從 GrabCAD Print 中更新。更新材料授權需要使用者擁有本機管理員權限。
- 專案面板已重新設計以提高可用性。變更包括重新設計的圖示、更好的對齊、更清晰的選取項目醒目提示、適用於組裝/拆解狀態的下拉式清單而非核取方塊,以及更明確地指示顯示/隱藏狀態。
- 當「列印」處於「表面」選取模式時,表面的切線選取現在可作為滑鼠右鍵命令使用。這在將製造備註新增至表面鏈結時非常有用。
- 您可以在主體和表面上新增標註,稱為製造備註。您可以使用滑鼠右鍵來執行新增備註的命令,而這將新增一個圖說文字,可以透過按一下以顯示備註並允許對其進行編輯來啟用該備註。
- 適用於 Stratasys J850 和 Stratasys J835 3D 印表機的新 VeroUltraClear 材料。VeroUltraClear 可模擬壓克力,實現該材料 95% 的透光,並且可用於玻璃、透明聚合物或透明包裝的原型。在此處瞭解有關 VeroUltraClear 材料的更多資訊。
- ABS ESD7 現在針對 GrabCAD Print 支援 Stratasys F370 印表機。ABS ESD7 是一種專為靜態敏感應用而設計的工具製造材料,用於防止排放或吸引其他材料,例如粉末、灰塵或微粒。在此處瞭解有關 ABS ESD7 材料的更多資訊。
GrabCAD Print 版本 1.35,十月 2019
構建號 1.35.21.56592 發佈于 24 十月 2019
- 我們改進了在 PolyJet 印表機需要 Job Manager 更新時的「列印」按鈕和印表機清單行為。列印按鈕將顯示一個快顯視窗,然後在按一下印表機清單時,系統會直接將您導向至「設定」畫面,您可以在其中執行升級。
- 在「進料匣設定」的「進階」區段下方新增了一個核取方塊,用於控制 J 系列印表機的 UV 燈。如果您在列印件中發生曝光過度問題,請洽詢您的轉銷商或 Stratasys 技術支援,以瞭解此設定是否有幫助。
- 在 J 系列印表機上使用 Pantone 顏色列印時,僅某些顏色需要 VeroBlackPlus。以前,如果您並未載入整個 Pantone 顏色拾取器,則會停用整個 Pantone 顏色拾取器,而現在僅停用特定顏色。Pantone 仍然需要所有三種 Vivid Vero 材料和 VeroPureWhite。
- 模型載入現在是一個可取消的動作。以前,如果您犯了錯誤並選取了錯誤的檔案,則必須等待其載入完成然後才能將其移除,現在您可以立即取消。
- 在進階 FDM 中對特定表面套用設定時,現在可以透過按右鍵功能表刪除這些設定。以前,您必須使用「撤銷」來還原表面設定。
- 支援新的 FDM 材料:
- TPU 92A 現在支援 Stratasys F370 印表機上的 0.0070 英吋 (0.1778公厘) 圖塊。 0.0070 圖塊和 0.0100 英吋 (0.2540公厘) 圖塊的列印品質獲得改善。F123 控制器軟體必須升級至版本 2.1 才能利用這些改進項目。
- 刪除印表機歷史記錄現在需要使用者擁有本機管理員權限。
GrabCAD Print 版本 1.34,九月 2019
構建號 1.34.16.55783 發佈于 19 九月 2019
- 作為 1.31 中的選項導入的 PolyJet 進階切片機現在依預設處於開啟狀態。它提高了預估的精確性,並啟用了此處列出的幾個功能。如果您出於任何原因需要使用舊切片機,則可以從「偏好設定」>「PolyJet」關閉它。
- 您現在可以存取與所選印表機相關 GrabCAD Print 之「説明功能表」中的 GrabCAD 教學課程和範例檔案。我們的應用程式工程師會持續新增內容,以協助您更妥善地利用您的電腦;相關內容將可透過「説明功能表」來取得。
- 使用標有「預覽支撐表面」的檢視列中的切換,您可以快速查看模型上將產生支撐的位置。此功能適用於 1.24 中的 PolyJet 印表機,且現在也可用於 FDM 印表機。這為 FDM 圖塊預覽提供了更快速的替代案例,以協助準備您的進料匣,因為它顯示出方向和支撐設定 (例如自我承重角度) 如何影響列印表面。
- 當您在「安排視圖」或 GrabCAD Print 行動應用程式中檢視正在進行中的 PolyJet 作業時,預測的「結束時間」現在大幅改善了精確性。預測將在整個作業中定期更新,以考慮列印暫停和初始預估中的其他錯誤。
- 選取 PolyJet 進料匣設定面板中的圖塊延遲選項將減少模型上出現凹陷的情況。該選項僅在與 Stratays 的技術支援人員洽談之後才能使用。使用該選項將增加作業的列印時間。
- PolyJet 印表機的「進料匣設定」面板中顯示的材料清單現在包括支撐材料。
- GrabCAD Print 現在將通知您選取印表機的相關更新,例如 F123 系列和 J750。這些可能包括有關新材料、學習內容和其他資訊。選取其中一台印表機並提供更新後,畫面左下角將看到禮品盒。
GrabCAD Print 版本 1.33,八月 2019
構建號 1.33.10.54793 發佈于 20 八月 2019
- 在進階 FDM 支援的印表機上,「模型設定」標籤中現在提供了一些進階功能。其中包括填充密度、填充角度和主體厚度,以及使用 CAD 檔案時,能夠將圓柱形孔變更為自我承重的菱形孔。
- 與上次更新中 FDM 設定面板所做的變更類似,PolyJet 設定面板現在被拆分為進料匣設定和模型設定,以便在未來的更新中保留空間以提供更多功能。
- 現在,您可以選擇匯出沒有清理零件或消耗柱的 CMB。這可讓您在作業中列印多個 CMB 檔案時防止列印多個清理零件。預設情況下會包括清除零件/消耗柱。
- 針對 Stratasys F900、Fortus 900mc 和 Fortus 400mc 印表機範本,ABS 現在是預設材料。針對即時印表機,材料將繼續使用目前配置作為預設值。
- 適用於 J750 和 J735 使用者的提醒:在 1.31 中導入的進階切片機將在未來幾個月升級時預設為 *開啟*,版本 1.34。
GrabCAD Print 版本 1.32,七月 2019
構建號 1.32.19.54065 發佈于 22 七月 2019
- FDM 列印準備的「列印設定」面板已拆分為 3 個面板:進料匣設定、模型設定和支撐設定。新圖示也已新增。
- 分析模式現在可以修復具有頂點顏色的 VRML 和 OBJ 檔案,並改善了對具有表面顏色和紋理之檔案的修復。
- J750 和 J735 使用者現在可以使用 Vivid 材料與進階切片機來列印不透明模型。取消選中「列印設定」面板中的「半透明」核取方塊以列印帶有白色核心的主體。這目前僅適用於不具有紋理的網面檔案/組件。
- 針對某些 Fortus 和 F123 作業的問題導致清理零件/消耗柱出現一些奇怪的行為,從而導致建構失敗。此問題已獲得解決。
- 選取 Agilus 30清除時,模型將顯示在與您所設定邵氏硬度值相關聯的透明度水平。
GrabCAD Print 版本 1.31,六月 2019
構建號 1.31.52720.53058 發佈于 20 六月 2019
- 在適用於 F900、F370 和 Fortus 印表機的 1.24 中導入進階 FDM 現在適用於 F170 和 F270。進階 FDM 可讓您使用實際 CAD 幾何結構自訂模型不同截面的填充,以及修改承重孔幾何結構以成功列印。在此處閱讀更多內容。
- 現在可從「檔案」>「偏好設定」>「Polyjet」中使用進階切片機,可為 J750 和 J735 使用者帶來了一系列的改進和新功能:
- 顏色拾取器中經過 Pantone® 驗證的顏色。
- 具有紋理透明度的 VRML 將使用透明的核心。
- 提高了小型特徵和文字的預估和列印精確度。
- 自訂支撐選項,用於修正具有承重孔之垂直牆面上的「支撐陰影」效果。
- 自訂組件零零件重疊時的零件優先順序。
- 完全控制進料匣上的零件放置。
- 新版本的 GrabCAD Print Server 作為 Windows 服務執行,即使 Windows 使用者已登出,它仍將繼續執行。此外,它與 Windows Server 2012相容,且可以隨著每機版本的 GrabCAD Print 進行安裝。此升級不是自動的,您必須在此處下載新版本。如需有關安裝的説明,請按一下此處。
- 「分析模式」現在可以修復具有紋理之 VRML 檔案中的網面錯誤。
- 當您嘗試從尚不支援的 CAD 套件 (例如 Inventor 2020) 新增模型時,錯誤訊息現在將比一般故障提供更多資訊。
- 針對 FDM 印表機,當零件表面的角度下降到指定值以下 (稱為自我承重角度) 時便會產生支撐,現在該值可在「列印設定」面板中進行調整。您可以增加或減少產生的支撐量,也可以將值還原到預設建議,而該值因印表機和材料而有所不同。
- 新增與目前 GrabCAD Print 專案中檔案或設定不相符的 CAD 或 CMB 檔會產生衝突而非錯誤,新的警告可讓您儲存變更並開啟新專案。
GrabCAD Print 版本 1.30,五月 2019
構建號 1.30.28.52238 發佈于 22 五月 2019
- 印表機歷史記錄可以從 GrabCAD Print 應用程式的「印表機歷史記錄」頁面中刪除。該選項可由偏好設定來啟用;該偏好設定僅針對 GrabCAD 工作階段啟用。刪除歷史記錄時,即使佇列中可能有作業,印表機仍必須處於閒置狀態。
- 我們審查了 GrabCAD Print 中的翻譯並已修復 6 個位置中的錯誤。
GrabCAD Print 版本 1.29,四月 2019
構建號 1.29.6.51061 發佈于 16 四月 2019
- GrabCAD Print 現在支援最新版本的 CAD 套件。這包括 SOLIDWORKS 2019、Inventor 2019、Creo 5.0 和 NX 12.0 等。在此處閱讀更多內容。
- 使用新的印表機面板輕鬆存取印表機。這是具有將印表機加入我的最愛、進階搜尋與篩選,以及許多其他改進項目的功能。我們希望您對此發表回饋意見!請從「檔案」>「偏好設定」>「GrabCAD Labs」開啟它,並告訴我們您的想法。
- Stratasys F123 系列最新成員 F120 的測試版本由 GrabCAD Print 版提供支援。在此處閱讀相關資訊。
- 現在當您選取智慧、稀疏或方塊支撐樣式時,可以在 FDM 列印的支撐結構中使用模型材料。由於印表機在模型和支撐材料之間切換需要幾秒鐘,此功能允許作業的許多層僅使用模型材料,從而節省了列印時間。
- 現在僅需按一下按鈕,即可從 Insight 將 Insight 模型傳送至 GrabCAD Print。在 Insight 工具列上選取「在 GrabCAD Print 中建構作業」圖示可建立 CMB 檔案,並將檔案從 Insight 傳遞至 GrabCAD Print,且將會自動選取正確的印表機類型。
GrabCAD Print 版本 1.28,三月 2019
構建號 1.28.16.50383 發佈于 21 三月 2019
- 缺少列印更多零件的技術或能力嗎?請前往「應用程式」>「使用 Stratasys Direct Manufacturing 生產我的零件」,以進入 SDM 首頁。(僅適用於美國/加拿大客戶。)
- 自動定向現在可在進階 FDM 標籤中使用。標準和合併主體都可以自動定向,以盡量減少支撐並縮短建構時間。
- 現在支援具有影像紋理的 OBJ 檔案。在 PolyJet 印表機上列印時,系統將讀取、顯示與 OBJ 檔案關聯的影像紋理檔案,並列印合併的結果。
- 修復了 F123 系列印表機上使用六角形填充時的零件品質問題。針對材料 F123 ASA 和 F123 ABS,在 0.005 英吋 (0.127 公厘) 和 0.007英吋 (0.178公厘) 圖塊高度上,填充密度降低以防止過度填充。
- 列印設定、定向和縮放面板已更新為僅計算活動進料匣上的模型或主體。
- 印表機歷史記錄中出現了從桌面應用程式匯出的 Bug,其中「持續時間」顯示所有作業的 00:00:00。此錯誤已修復。
- 應用程式會在臨時目錄中產生一些檔案,且它們在過去會隨時間而累積。現在它們會在應用程式關閉時會自動清除。
- 某些使用者遇到一個無法啟動 GrabCAD Print 的 Bug,並看到「太多執行個體...」錯誤。這是由 SOLIDWORKS 附加元件的 GrabCAD Print 所造成的,該附加元件現已停止。
GrabCAD Print 版本 1.27,二月 2019
構建號 1.27.17.49710 發佈于 25 二月 2019
- 導入 1.24 F123 系列和 Fortus 900mc 的可調整寬度填充,現在可用於 Fortus 380mc、380mc CFE 和 450mc。此功能需要印表機韌體的版本 6.1 (自 13 三月 2019 起可用)。請按照此處的指示更新電腦上的韌體。
- 當您匯入要列印在 FDM 印表機上的 CMB 檔案時,系統將自動選取正確的印表機。此外,您現在可以圍繞 Z 軸旋轉該模型。
- 特定材料組合不允許在 PolyJet 列印工作中使用,例如 Vero 和 VeroFlex,或者僅使用數位 ABS 之兩種 RGD 材料的其中之一。以前,如果印表機載入了這種不支援的材料組合,印表機將顯示「錯誤」狀態,且即使作業本身並未使用不支援的組合,系統仍會停用列印。現在,無論印表機中目前載入的哪些材料,只要作業中並未使用不支援的組合,使用者將能夠列印其工作。
GrabCAD Print 版本 1.26,一月 2019
構建號 1.26.13.48725 發佈于 28 一月 2019
- 作為「列印設定」面板的一部分,在 GrabCAD Print 1.24 中導入了可調整寬度的填充,現在可用於進階 FDM。
- 清理零件 (F123 系列) 和消耗柱 (某些 Fortus 印表機) 會自動自行放置於進料匣上的最佳位置,儘管您可以手動將其移動。現在當您這樣做時,它將保留在該位置,直到您使用「排列進料匣」或「排列專案」工具。您也可以透過在清理零件/消耗柱上按右鍵並選取「自動定位」以將其重新置。
- 重設現在可用於 GrabCAD Print 和進階 FDM 中的方向。選取模型並選取「重設」將會在模型最初新增至進料匣時將模型返回到其方向。
- 解決了在特定情況下阻止安裝 GrabCAD Print 的問題。如果您在安裝時仍遇到問題,請聯絡 print@grabcad.com。
GrabCAD Print 版本 1.25,十二月 2018
構建號 1.25.17.47934 發佈于 4 一月 2019
- 針對 1.16 中測試版測試而發佈的每電腦安裝程式現在已從 print.grabcad.com 正式提供。除了比目前每使用者安裝程式更為穩定之外,它也允許 IT 系統管理員在學校和企業組織中進行部署。如需有關切換的詳細資訊和指示,請閱讀我們的説明文章。
- 具有自相交、水密性/開口面問題的 OBJ 和 VRML 檔案以及倒轉法線,現在可以在列印至 PolyJet 技術之前由 GrabCAD Print 進行修復。若要試用,請聯絡 print@grabcad.com。
- 「列印設定」面板上的工具提示會說明可調整寬度填充、零件建構樣式、清理零件或消耗柱類型、系統模式以及第一層材料的行為。工具提示內容僅會相應顯示適用於動作的可用選項內容。
GrabCAD Print 版本 1.24,十一月 2018
構建號 1.24.15.46944 發佈于 20 十一月 2018
- GrabCAD Print 進階 FDM 提供強大而直觀的工具集,可透過自動控制 FDM 建構屬性來取得所需的零件特徵。透過將屬性直接指派給 CAD 檔案的幾何結構,您可以指定強度和剛度區域、控制填充、確保嵌件承重孔周圍有足夠的材料,以及避免接縫,然後系統會自動計算所有必要的工具路徑,而不需手動操作個別階層,最終減少了準備作業所需的時間,同時改善了整體零件品質。進階 FDM 在選取印表機 (F370、380mc、380mc CFE、400mc、450mc、900mc 和 F900) 時提供使用,且可從「檔案」>「偏好設定」>「FDM」下方存取。
- OBJ 檔案現在可以新增至 GrabCAD Print 中,且包含顏色、相關聯的 .mtl 檔案和視覺紋理,以便進行 PolyJet 列印。此功能需要在檔案 > 偏好設定 > GrabCAD Labs 中啟用。若想知道支援的內容,請前往此處。
- GrabCAD Print 中支援新提供的材料,包括 VeroCyan Vivid、VeroFlex 青色/洋紅色/黃色 Vivid 以及 J750/J735 上的 Agilus 30 白色、Connex3 上的 MedABS 和 Med615、F900 上的 Antero 800NA,以及 F123 系列稱為 FDM TPU 92A 的所有全新彈性材料。請注意,適用於 Connex3 和 J750/J735 的新材料需要更新嵌入式軟體。
- 選取 PolyJet 印表機後,3D 檢視器上方的按鈕頂端列中提供了新的顯示模式,將允許使用者查看支撐材料將放置在模型表面上的位置。這會決定光澤效果的邊界。
- 部分 FDM 印表機現在提供可選設定,用於對內部零件建構使用可調整寬度填充。設定之後,可調整寬度工具路徑會自動放置在預設寬度工具路徑小於預設寬度且大於指定噴嘴大小之最小寬度之間的間隙。安裝最新的韌體更新 (版本 1.8 和 3.26 或更高版本) 之後,F123 系列和 F900 和 Fortus 900mc 皆支援此功能。
- 對「安排視圖」中作業詳細資訊面板的更新,以直觀地指出所選作業預估要使用多少材料。工具提示會向使用者顯示工作完成後儲罐或材料盒上的預估剩餘材料量。針對 FDM,第一個佇列中作業將指出作業開始時儲罐/材料盒上有多少材料。
- 「安排視圖」中的作業詳細資訊面板現在將會列出 FDM 印表機作業所需的噴嘴大小和建構解析度。這對於使用者檢查作業所需的內容與印表機上目前載入的內容非常有用。
GrabCAD Print 版本 1.23,十月 2018
構建號 1.23.20.45529 發佈于 17 十月 2018
- 歷史記錄報告有幾項改進項目:
- 「作業歷史記錄」的匯出現在可用於 XLSX 和 CSV 格式,而 XLSX 是預設值。
- 為了區分列印時間與預熱和作業期間花費的其他時間,「持續時間」欄現在拆分為「作業總時間」,即開始和結束之間的總經過時間,以及排除印表機暫停或預熱的「列印總時間」。
- 「歷史記錄視圖」中的新欄位會顯示作業中的零件清單。相同零件的數量將在零件名稱後方以 (#) 顯示。例如「HingePin(3)」。目前此功能僅適用於 FDM 印表機。(注意:使用 GrabCAD Print 和更早版本列印的作業 1.22將在此處顯示加密的零件名稱。)
- 針對 FDM 印表機,匯出的「作業歷史記錄」現在包括兩欄用於支撐和模型噴嘴大小。
- 零件可於 Fortus 450mc 印表機上使用 .013” 解析度的 ULTEM™ 9085 進行列印
- 根據設定的材料屬性,模型會以亞光或光澤來顯示
GrabCAD Print 版本 1.22,九月 2018
構建號 1.22.24.44746 發佈于 26 九月 2018
- 新的偏好設定可停用 GrabCAD Print 的自動更新。當更新可用時,您仍會收到通知。
- 新的偏好設定可讓匯入 CAD 檔更為精確,這將新增更多三角形至呈現 CAD 檔案的網面。但是這將會影響效能。
- 透過此版本,我們修復了印表機如何連線至 GrabCAD Print 的特定問題 (包括更新後消失的印表機清單),並改進了我們的錯誤報告,以便更好地解決將來的潛在連線問題。
- 現在,所有 FDM 印表機的型號都可以自動定向,從而定向模型以產生最少的支撐材料。
- 現在使用 .005” 解析度時,可以針對 ABS 和 ASA 使用支撐材料作為 F123 印表機上的基礎層來列印工作。這增加了進料匣黏附問題的風險,但可讓您更輕鬆地移除小型零件。
- 在提供雙密度填入的 FDM 印表機上,六角形填入樣式現在是一個選項。這種模式非常強大,且建構效率很高。
- 辦公時間和延遲的列印啟動可能會讓佇列錯誤地在「安排視圖」中顯示為空,因此當您需要向右捲動以查看佇列中作業時,便會出現一個新按鈕。
- 按一下目前在「安排視圖」中列印的作業時,您現在將看到作業完成後剩餘材料量的預估。針對 FDM 印表機,您也可以看到以下作業的起始材料水準的預估值。
- 接縫 (FDM 印表機工具路徑開始和結束的位置) 現在於「圖塊預覽」中可見。
- 零件可以在 450mc 印表機上使用. Antero 800NA 進行列印。
GrabCAD Print 版本 1.20,七月 2018
構建號 1.20.50.42688 發佈于 18 七月 2018
- 適用於 PolyJet 印表機的延遲啟動現已可供使用!當 PolyJet 印表機處於閒置狀態且佇列為空時,現在您可以在按「列印」按鈕之後將列印安排在指定的時間開始。請注意,如果您透過 GrabCAD Print Server 遠端連線至印表機,則此功能尚無法使用。
- 在「安排視圖」中,您現在可以按一下 F123 系列印表機中相機影像上的按鈕將其放大至高解析度。相同的功能可用於所有印表機的作業預覽影像。
- 經過 3 個月的測試,Connex3 系統獲得了 GrabCAD Print 的完整支援。請詳讀設定指南以開始使用。
- GrabCAD Print 現在支援新的 Fortus 380mc Carbon Fiber Edition 印表機。
- GrabCAD Print 的登入工作階段僅在 2 個月無活動後才會過期。以前為經過 1 週之後過期。
- 如果您為 PolyJet 印表機購買了新的 Vivid Vero 材料,則現在可以在 GrabCAD Print 中選取這些材料。
GrabCAD Print 版本 1.19,六月 2018
構建號 1.19.14.41748 發佈于 15 六月 2018
- 當您按一下「列印」將作業傳送至 PolyJet 印表機時,如果印表機未載入足夠的材料或廢物箱已滿,系統將顯示警告。
- 包含大量重複檔案的工作處理速度將比以前更快。此外,複雜或多主體 VRML 檔案的檔案載入時間改善了 60-80%。
- 現在,無論您是在本機連接至印表機還是透過 GrabCAD Print Server 遠端連線至印表機,您都可以匯出印表機設定檔。
- GrabCAD Print 現在支援新的 Stratasys F900 系統類型。Stratasys F900 是 Fortus 900mc 系統的替代產品,且包括升級後的濕度控制系統和一般系統增強功能。
GrabCAD Print 版本 1.18,五月 2018
構建號 1.18.19.40241 發佈于 10 五月 2018
- 適用於 PolyJet 使用者的一些增強功能,包括:
- 用於列印設定的新複製和貼上功能。
- 用於進料匣驗證、預估和排隊的進度條。
- 改進了用於列印重複高密度 STL 的切片機穩定性。
- Agilus 材料現在可以使用 SUP706B 支撐材料進行列印。請僅於您收到新的支撐配方 (也稱為 706B) 時,才使用此組合。
- SOLIDWORKS 的 GrabCAD Print 附加元件現在支援 SOLIDWORKS 2018。更新至 GrabCAD Print 1.18之後,請在「控制台」中修改您的安裝以安裝附加元件。
GrabCAD Print 版本 1.17,四月 2018
構建號 1.17.14.39209 發佈于 12 四月 2018
- Connex3 系統 (包括 Objet260、Objet350 和 Objet500) 將很快得到支援,您現在可以加入我們的公開測試版測試!此外,請安裝現在提供下載的最新嵌入式軟體更新。無需簽署正式的測試版協議,僅需前往此處下載連結和完整指示。
- 適用於 PolyJet 紙匣的紙匣估算現在將顯示真正的進度條。
- 當您變更 PolyJet 印表機的進料匣材料時,顏色和紋理設定檔將還原為預設值,以防止使用者意外將設定檔保留在不建議的值。
GrabCAD Print 版本 1.16,三月 2018
構建號 1.16.29.38429 發佈于 20 三月 2018
- 提供面向 GrabCAD Print 的全新的每機器安裝程式。這就可以把 GrabCAD Print 輕鬆地安裝在電腦實驗室 PC 上,以及由系統管理員在企業層面進行部署。在此閱讀更多資訊並透過電子郵件print@grabcad.com請求存取。
- 現在支援最新版本的 CAD 套裝軟體。這包括 SOLIDWORKS 2018、Creo 4.0、Inventor 2018 等。完整清單請閱讀此處。
- 在上次更新中,我們引入了一項新功能,可讓您將列印設定與所選印表機的當前配置同步。在這次更新中,我們已經使這種行為實現自動化 - 在您啟動應用程式時立刻執行。
- 在 PolyJet 列印支撐網格中使用的材料(通常是 VeroPureWht)現在於估算結果視窗中指定,而不是假設為「其他」。
GrabCAD Print 版本 1.15,二月 2018
組建編號 1.15。13.37334 發佈時間:19 二月 2018。
- FDM 印表機的「列印設定」面板具有新的外觀。當您的設定與當前的印表機配置不同時,您會看到一個指示,只需按一下該指示,即可更新所有設定以實現匹配。此外,任何新建紙匣的設定將始終與您當前正在檢視的紙匣設定相匹配,以加快為具有多個設定的專案進行列印準備。
- 「排列」工具中提供了一個新滑塊,用於控制 PolyJet 使用者的「優化」核取方塊。您可以控制排列是否經過優化,以盡可能縮短列印時間或減少支撐材料的使用情況。
- 修復內容:如果「安排視圖」在螢幕上保留一段時間,則「現在」行將停留在原位,而不是慢慢移出視圖。
GrabCAD Print 版本 1.14,一月 2018
構建號 1.14.20.36110 發佈于 17 一月 2018
- 印表機面板中的詳細資訊螢幕現在顯示模型和支撐噴嘴計量表,以及 FDM 系統的封包和打印頭溫度。
- 如果您的 FDM 系統有多個材料艙,則印表機面板中的新圖示指示當前打印頭中載入了哪些材料艙。
- 如果在作業中選擇了與當前印表機配置不匹配的材料或噴嘴,按一下「列印」按鈕時現在將出現彈出式警告。
- 現在可以為 Fortus 900mc 印表機以 XML 格式下載詳細的獨立列印工作日誌。轉到報告視圖並使用「選項」列中的下載按鈕。
- GrabCAD Print 現在支援 Stratasys J700 Dental 印表機。
- 修復內容:無論您的單位偏好設定如何,這些報告都以 cm³ 為單位標記材料單位。此問題已得到修復。
GrabCAD Print 版本 1.13,十二月 2017
構建號 1.13.21.34870 發佈于 12 十二月 2017
構建號 1.13.23.35192 發佈于 19 十二月 2017
- 如果您設定了 GrabCAD Print Server,則以前只能享受 PolyJet 系統的一些遠端存取功能,例如移動端應用程式連線和線上報告。現在我們啟用了最新功能:從遠端 PC 上的 GrabCAD Print 發送作業。
- 一些相關改進
- GrabCAD Print 中的「報告視圖」現在包含一個匯出按鈕,可同時作用於 FDM 和 PolyJet 系統。
- 修復了「報告視圖」中某些使用者無法選擇印表機的錯誤。
- 修復了 Internet Explorer 線上報告中的一些問題。
- 估算結果準備就緒後,您不再需要點擊「檢視估算」,它們會自動彈出。
- 在 iOS 版的 GrabCAD Print 應用程式中,作業詳細資訊現在將包含預測的結束時間。
GrabCAD Print 版本 1.12,十一月 2017
構建號 1.12.26.33454 發佈于 13 十一月 2017
- 現在,您可以從 GrabCAD Print 桌面應用程式的「報告視圖」中存取本地印表機的作業歷史記錄。這將對離線模式下的使用者有很大的幫助,因為此報告以前僅在設置 GrabCAD Print Server 後才可從線上的「報告」頁面上獲得。(尚未提供 PolyJet 系統、遠端印表機和 CSV 匯出的歷史記錄。)
- 新的高級 PolyJet 材料剛剛由 Stratasys 推出,現在由 GrabCAD Print 提供支援。詳細了解 Agilus、VeroFlex 和 DABS2 Plus。
- 如果帳戶連線了很多印表機,Android 應用程式有時會報告找不到印表機。我們增加了超時時間,因此這種情況應該不再發生。
- 細微的可用性改進
- 2 GB 的單個檔案大小和紙匣大小限制已取消。
- 當另一個操作正在進行時,不再阻止切換到「安排視圖」。
GrabCAD Print 版本 1.11,十月 2017
構建號 1.11.17.31736 發佈于 11 十月 2017
- 全新紙匣顯示,特色為...
- 適用於 uPrint、Dimension、F123 Series 和較小 Fortus 系統的真實紙匣形狀和格線。
- 適用於較大 Fortus 系統的釐米或英吋格線(取決於您的顯示單位偏好設定)。
- 面向適用印表機的校準觸點。
- Fortus 900mc 將顯示較小紙匣的輪廓。
- 您現在可以使用 GrabCAD Print,透過「圖塊預覽」向 FDM 列印作業添加一個暫停。在此之前,此功能僅在 Catalyst 和 Insight 中提供。
- 您現在可以使用 GrabCAD Print 為 ULTEM™ 9085 CG 準備作業。此材料之前僅可使用「Insight 與 Control Center」取得。使用者還可選擇使用 T16A 噴頭及其 Fortus 900mc。
- 解決了阻止某些使用者在 SOLIDWORKS 中啟動 GrabCAD Print 載入項的問題。
GrabCAD Print 版本 1.10,九月 2017
構建號 1.10.19.30507 發佈于 13 九月 2017
- 現在您就可以直接從 Workbench 專案中向 GrabCAD Print 新增模型。前往此處以瞭解有關結合使用 Workbench 與 Print 的更多資訊。
- 如果您正在使用 GrabCAD Print Server,則在列印作業完成或需要引起關注時,您和團隊將獲得電子郵件通知。從 GrabCAD 個人資料中調整您的設定。
- 現在您可透過按兩下或拖放的方式打開 .PRINT 文件。
- GrabCAD Print 現在支援 Objet1000 Plus 印表機。閱讀設定指南。
- 過去存在的問題是:檔案名或路徑中包含非 ASCII 字元的 CAD 檔案可能無法載入 GrabCAD Print。此問題已得到修復。
- CAD 檔案的匯入已得到改進。在之前的版本中,某些零件顯示部分粗糙或彎曲的表面,但相關改進將提供更加平滑的表面。
- 您現在可在「開始」功能表中發現指向「Insight for GrabCAD Print」的快速鍵。該快速鍵會將您帶到隨附的 Insight 版本,而之前只能從 GrabCAD Print 的「應用程式」功能表存取 Insight。
GrabCAD Print 版本 1.9,八月 2017
構建號 1.9.27.701 發佈于 9 八月 2017
- 現在可將犧牲塔新增到 Fortus 列印作業。這有助於改善接縫品質,並且在使用 Nylon 12 CF 列印時要求引入犧牲塔。
- Nylon 材料現可供 GrabCAD Print 中的 Fortus 印表機使用。
- 在安排視圖中,需要引起注意的作業(例如,如果材料在作業執行期間或之前耗盡)將顯示有圖示。帶有警告的印表機總數將顯示為應用程式左側「安排視圖」圖示上的數位。
- 使用者將能夠從「印表機面板」中匯出包含印表機作業歷史記錄的 CSV 檔案(僅限 FDM)。這就允許離線客戶直接匯出其作業歷史記錄資料,而無需啟用報告。
- 之前版本的 GrabCAD Print 要求在初次安裝時具備系統管理員許可權。而在版本 1.9 中,任意使用者都可執行安裝,而無需具有系統管理員憑據(除非包括可選的 SW 載入項)。
GrabCAD Print 版本 1.8,七月 2017
構建號 1.8.16.652 發佈于 12 七月 2017
新功能:
- GrabCAD Print 現在支援使用 ULTEM™ 9085 和 ULTEM™ 1010 進行列印。此亦表示,於 Insight 中利用這些材料準備的 CMB 檔案現在可以使用 GrabCAD Print 進行列印。 如要修改參數或使用固定銷或牆面穩定器等功能,您可以使用「應用程式」功能表中的 Insight。您仍然需要使用 Control Center 來新增犧牲塔。(GrabCAD Print 中尚不支援 ULTEM™ 9085 CG。)
- 使用者現在可在其 FDM 印表機上執行整個專案的優化排列(一次性排列所有紙匣)。這樣就可讓使用者以最佳方式打包帶有盡可能多零件的多個紙匣。
- 在將零件插入 FDM 印表機時,會從紙匣的中心排列這些零件,以提供改進的列印品質。
- 對於 F123 系列印表機,透過已得到支援或未獲得支援的功能改進底部表面的平滑度。
錯誤修復:
- 在建立 J750 印表機的連線時,Windows 使用者名中的特殊字元不再會引發問題。
- 在安排視圖中檢視 PolyJet 作業時,「列印模式」和「列印的圖塊」會再次出現。
- 修復零件上的轉換導致部分顯示頂層的問題。
- 修復在某些 FDM 印表機之間切換造成匯入的 CMB 消失的錯誤。
GrabCAD Print 版本 1.7,六月 2017
構建號 1.7.28.633 發佈于 14 六月 2017
- 現在可在紙匣上排列多個匯入的 CMB 檔案。在此之前,操作多個 CMB 檔案的使用者必須使用「控制中心」實施其作業流程。出於性能考量,CMB 在模型視圖中有所簡化,但可在圖塊預覽中看到實際的形狀。從空專案開始,然後轉到「檔案」 > 「匯入 CMB...」
- 我們在「檔案」功能表中新增了「最近檔案」選項。您可存取5最近新增的檔案(任意 CAD 格式、CMB 或 OBJZF)以及最近的5 Print 專案。
- 您現在可以在安排視圖中透過拖放的方式重新排列作業。
- GrabCAD Print 的 SOLIDWORKS 載入項現在封裝在 GrabCAD Print 的安裝程式中。The SolidWorks add-in allows you to prepare your CAD files for printing right from within SOLIDWORKS.有關安裝說明,請轉到 GrabCAD Print 中的「應用程式」功能表。
- 您的列印作業現在顯示有您的真實姓名,而非本地作業中的電腦個人資料姓名。
- GrabCAD Print 現在支援 .JT 檔案類型
- 修復內容:包含非 ASCII 字元(例如 é 或 à)的零件現在可在 J750 上進行列印。
- 修復內容:在紙匣中載入 Tango+ 材料但未使用時出現了 J750 零件的縮放問題,此問題已得到修復。
GrabCAD Print 版本 1.6,五月 2017
構建號 1.6.19.601 發佈于 9 五月 2017
- 介紹操作小時數!您公司的管理員啟用這些功能之後,安排視圖將自動調整印表機佇列顯示,反映列印工作通常僅在工作期間啟動,這樣可為您提供更加準確的安排預測。
- 使用 Shift 鍵選擇方式,在「專案面板」中快速選擇多個模型。借助此方式以及框選方式(在 1.5 中發佈),可以更加快速地一次性更改多個模型的設定。
- 在「印表機面板」的佇列清單中使用按一下拖動方式輕鬆記錄作業。
- 為加快檢視器的瀏覽效能,「模型視圖」將顯示模型的「簡化」版本。您可能注意到曲面上出現更多三角形。這不會影響列印品質。為確切瞭解將傳送到印表機的切片資料,可轉至「圖塊預覽」,或在「系統偏好設定」>「顯示設定」中將「圖形品質」改為「高」。
- 對於 F123 系列印表機,我們現在提供了「磚塊模式」成型風格。當列印大型、高密度、實心填充的零件時,這有助於減少零件捲曲。僅在對 ABS、ASA 或 PC-ABS 使用 0.005” 的切片高度時,才採用這種模式。
- 修復內容:對於 J750 印表機,我們已修復了可能造成列印過程錯誤的一些問題。請確保更新 GrabCAD Print 和 Job Manager 以利用這些修復。
- 修復內容:顯示單位設為公制的使用者現在可採用所選的單位檢視切片高度。
GrabCAD Print 版本 1.5,四月 2017
構建號 1.5.15.549 發佈于 18 四月 2017
- 離線模式部分2在此處!現在,當您初次安裝時,如果沒有網際網路連線,就可以跳過登入。這是對 GrabCAD Print 1.3 中引入的離線模式的後續增強,相關詳情可閱讀此處。
- GrabCAD Print 現在支援最新版本的 CAD 套裝軟體,包括 SOLIDWORKS 2017、Inventor 2017、NX 11.0 和 Solid Edge ST9。完整清單請閱讀此處。
- 您現在可從專案面板的紙匣預覽中為您的紙匣提供自訂名稱。當您按一下「列印」時,作業將繼承此名稱。
- 使用版本 1.5 傳送的所有作業將在「安排視圖」作業詳情中包括紙匣的預覽(線上方式和在桌面應用程式中)。可在「系統偏好設定」>「隱私」中禁用此功能。
- 「模型視圖」中的框選方式有助於一次性更改多個模型的列印設定。使用滑鼠左鍵按一下並拖動。向右拖動滑鼠時,僅會選擇完全包含在框中的模型。向左拖動滑鼠時,也會選擇部分包含在框邊界中的模型。
- 視圖快速鍵和透視設定現在成為檢視器頂部的便捷按鈕。
- 您現在可選擇材料單位在移動應用程式以及線上報告和安排視圖中的顯示方式。在此處變更您的設定。(移動應用程式在註冊後更新)
- 我們改進了您獲得如下通知的方式:需要為 J750 更新 Job Manager。
- 對於 F123 系列印表機,基礎層將由使用 ABS 或 ASA 以及 0.005” 切片高度進行列印的模型材料組成,以便改善紙匣粘著力。
- 我們對核心流程和列印功能進行了大量調整,改進了 Stratasys F123 系列印表機的列印品質。
GrabCAD Print 版本 1.4,三月 2017
構建號 1.4.20.531 發佈于 14 三月 2017
新功能:
- GrabCAD Print 現在支援所有 uPrint、Fortus 和 Dimension 印表機。檢視完整清單。
- 在 1.3 中,如果您在估計紙匣之後點擊「排列紙匣」,則可大幅度改進 FDM 列印的包裝。現在只需採用「排列」工具中的「優化」核取方塊,即可更加輕鬆地執行此操作。在某些情況下,這可以在每個紙匣中放入之前兩倍數量的零件!
- 自訂印表機名稱介紹!從「印表機設定」面板中重命名印表機,您的自訂名稱將出現在桌面、網路和移動平臺上,供您公司帳戶的所有成員檢視。在此瞭解更多內容。
- 對於 GrabCAD Print Server 的最新更新版本(版本號 0.144.0318),GrabCAD Print 移動應用程式以及線上安排和報告中現在支援 Stratasys J750。遠端存取列印功能即將提供。
- 此外,如果 PC 上已運行 GrabCAD PolyJet Job Manager,則現在可初次就使用「新增網路印表機」選項連線到 J750。
- 我們已改進了在印表機面板的「我的印表機」中列出印表機的方式。
- 如果您丟失印表機連線,該印表機將不會從清單中消失。相反,它將顯示「斷開連線」的狀態。
- 「離線印表機」現在稱為「印表機範本」,將出現在網路印表機下方的單獨部分中。
- 對 F370 列印設定進行了小規模更新:
- PLA 列印現在稱為「草稿模式」。
- 清除零件風格預設使用「全高」。
錯誤修復:
- 一些 J750 使用者報告,在紙匣中載入 Tango+ 材料但未使用時出現了估計不正確或列印失敗的問題,這些問題已得到解決。
- 「安排視圖」現在顯示接下來的 J750 作業的時間和材料估計。
- 一些 J750 使用者報告了帶有神秘的「錯誤 0」故障訊息的列印錯誤。造成此列印故障的問題已得到修復,如果再次發生相同問題,則故障訊息現在是有意義的文字。
- 「定向」面板中的兩個小錯誤已得到修復:一個涉及負的小數值,另一個則與 + 和 - 按鈕有關。
- 一些 F370 使用者已注意到包含一些不正確層的清除零件,此問題已得到修復。
GrabCAD Print 版本 1.3,二月 2017
構建號 1.3.25.508 發佈于 21 二月 2017
構建號 1.3.23.503 發佈于 7 二月 2017
- Stratasys F123 系列介紹!我們最新的印表機專門運行在 GrabCAD Print 上。在此瞭解更多。
- GrabCAD Print 中對 J750 的支援現已完成測試!感謝所有參與測試專案的人員。如果您擁有 J750,則可遵循此指南以開始使用 GrabCAD Print 進行列印。
- 我們現在已提供 SOLIDWORKS 載入項,可讓您直接在 CAD 環境中列印 .SLDPRT 檔案。瞭解更多關於此方面的資訊或者在此下載。
- 許多使用者已要求能夠安裝並直觀地列印,而無需登入 GrabCAD,因此我們引入
- 如果網際網路連線掉線,GrabCAD Print 將允許您繼續使用本地印表機進行列印。
- 如果這是您大部分時間內的工作方式,則可在「系統偏好設定」>「隱私」中切換至離線模式,從而關閉警告訊息。
- 您仍然需要在初次啟動應用程式時至少登入一次。如果您有網際網路存取權,但登入遇到問題,請檢視故障排除指南。
- 離線功能的第二部分將是「完全離線」解決方案,在此解決方案中可跳過初始登入。我們預計此部分將在今年末準備就緒。
- 如果您曾經認為「排列」工具不像 Insight 或 Catalyst 那麼優秀,您應注意到此次更新對該工具進行了重大改進。首先,點擊「估計」以對紙匣進行切片,然後「安排紙匣」將更緊密地打包零件。
- 參與過 J750 測試計畫的使用者可以注意到此次更新帶來的一些改進:
- 現在可從 GrabCAD Print 中的「印表機」面板更新 Job Manager,如同執行韌體更新一樣。
- 「列印設定」面板中的透明滑塊問題已得到修復!
- Insight 現在與 GrabCAD Print 綁定,因此您可將更多高級功能(如組或路徑編輯)用於您的 F370 或 Fortus 系統。在此瞭解更多。
GrabCAD Print 版本 1.2,一月 2017
構建號 1.2.11.469 發佈于 24 一月 2017
構建號 1.2.9.464 發佈于 16 一月 2017
- 如果您錯失,報告就在此處!在 Web 瀏覽器的右側檢查您的作業歷史記錄和材料使用。
- 提供新的系統偏好設定,用於更改在為一個紙匣新增過多零件時是否要自動建立新的紙匣。
- 工具圖示更大、更醒目。檢查這些圖示:工具。
- 在「旋轉」工具中,您現在可自訂每次按一下的旋轉度數,從而可更輕鬆地獲得最適宜的方向。
- VRML 檔案現在包括在「分析模式」中,但若要修復模型而不破壞紋理映射,必須使用其他軟體。
- 我們修復了一些涉及 CAD 檔案閱讀器的問題,特別是圍繞環狀模型的問題。
GrabCAD Print 版本 1.1,十二月 2016
構建號 1.1.28.454 發佈于 16 十二月 2016
- 改進主導航和專案面板中的顏色與圖示。
- 存在一個問題,即您的單位偏好未反映在「安排」視圖中,此問題已得到修復。
- 其他小範圍修復和改進。
GrabCAD Print 版本 1.0,十一月 2016
構建號 1.0.32.424 發佈于 15 十一月 2016
- 更多印表機!您現在可將 GrabCAD Print 用於您的 Fortus 380/450 和 Fortus 900 印表機(有限支援*),而 Fortus 360/400 和 J750 目前處於測試階段。傳送電子郵件至 print@grabcad.com 以請求存取權。
- 能夠以立方釐米為單位檢視材料的體積。轉至「檔案」>「系統偏好設定」>「單位控制」>「顯示單位」,然後更改任何公制單位。
- 能夠匯入 .CMB.GZ 檔案。
- 安裝程式現在預設採用作業系統語言進行安裝。您可透過在安裝程式的第一個螢幕中選擇返回按鈕來更改語言,也可從「系統偏好設定」中更改。
- 為新使用者提供更加直觀的預設滑鼠控制。更新的配置請參見此處。現有使用者不受此次更新影響。
- 填充、切片高度和支撐風格現在自動更新到建議的所選模型和支撐材料設定中。
- 小規模的 UI 改進和問題修復。
*有限的支援表示支援基本的列印準備 (類似於 Insight 中的「綠色標幟」),但是某些進階功能,例如列印 ULTEM™ 或尼龍 12 時使用犧牲塔,尚無法使用。
